  4. Zigbee startet nicht mehr
zigbee
30 Beiträge 5 Kommentatoren 2.7k Aufrufe 6 Beobachtet
    @bishop Wenn du nichts gemacht hast ist vielleicht das Dateisystem in Auflösung begriffen.
    bishop
    @Thomas-Braun
    Also vermutlich sd karte tauschen?
    • B bishop
      @Thomas-Braun
      @bishop
      Schau mal per
      dmesg
      was da ggf. los ist.
        @bishop
        Schau mal per
        dmesg
        bishop
        @Thomas-Braun
        pi@raspberrypi:~ $ dmesg
        [    0.000000] Booting Linux on physical CPU 0xf00
        [    0.000000] Linux version 4.19.118-v7+ (dom@buildbot) (gcc version 4.9.3 (crosstool-NG crosstool-ng-1.22.0-88-g8460611)) #1311 SMP Mon Apr 27 14:21:24 BST 2020
        [    0.000000] CPU: ARMv7 Processor [410fc075] revision 5 (ARMv7), cr=10c5387d
        [    0.000000] CPU: div instructions available: patching division code
        [    0.000000] CPU: PIPT / VIPT nonaliasing data cache, VIPT aliasing instruction cache
        [    0.000000] OF: fdt: Machine model: Raspberry Pi 2 Model B Rev 1.1
        [    0.000000] Memory policy: Data cache writealloc
        [    0.000000] cma: Reserved 8 MiB at 0x3ac00000
        [    0.000000] On node 0 totalpages: 242688
        [    0.000000]   Normal zone: 2133 pages used for memmap
        [    0.000000]   Normal zone: 0 pages reserved
        [    0.000000]   Normal zone: 242688 pages, LIFO batch:63
        [    0.000000] random: get_random_bytes called from start_kernel+0xac/0x4b4 with crng_init=0
        [    0.000000] percpu: Embedded 16 pages/cpu s36864 r8192 d20480 u65536
        [    0.000000] pcpu-alloc: s36864 r8192 d20480 u65536 alloc=16*4096
        [    0.000000] pcpu-alloc: [0] 0 [0] 1 [0] 2 [0] 3
        [    0.000000] Built 1 zonelists, mobility grouping on.  Total pages: 240555
        [    0.000000] Kernel command line: coherent_pool=1M snd_bcm2835.enable_compat_alsa=0 snd_bcm2835.enable_hdmi=1 snd_bcm2835.enable_headphones=1 bcm2708_fb.fbwidth=656 bcm2708_fb.fbheight=416 bcm2708_fb.fbswap=1 vc_mem.mem_base=0x3ec00000 vc_mem.mem_size=0x40000000  console=tty1 root=PARTUUID=6c586e13-02 rootfstype=ext4 elevator=deadline fsck.repair=yes rootwait
        [    0.000000] Dentry cache hash table entries: 131072 (order: 7, 524288 bytes)
        [    0.000000] Inode-cache hash table entries: 65536 (order: 6, 262144 bytes)
        [    0.000000] Memory: 939068K/970752K available (8192K kernel code, 656K rwdata, 2232K rodata, 1024K init, 831K bss, 23492K reserved, 8192K cma-reserved)
        [    0.000000] Virtual kernel memory layout:
                           vector  : 0xffff0000 - 0xffff1000   (   4 kB)
                           fixmap  : 0xffc00000 - 0xfff00000   (3072 kB)
                           vmalloc : 0xbb800000 - 0xff800000   (1088 MB)
                           lowmem  : 0x80000000 - 0xbb400000   ( 948 MB)
                           modules : 0x7f000000 - 0x80000000   (  16 MB)
                             .text : 0x(ptrval) - 0x(ptrval)   (9184 kB)
                             .init : 0x(ptrval) - 0x(ptrval)   (1024 kB)
                             .data : 0x(ptrval) - 0x(ptrval)   ( 657 kB)
                              .bss : 0x(ptrval) - 0x(ptrval)   ( 832 kB)
        [    0.000000] SLUB: HWalign=64, Order=0-3, MinObjects=0, CPUs=4, Nodes=1
        [    0.000000] ftrace: allocating 27093 entries in 80 pages
        [    0.000000] rcu: Hierarchical RCU implementation.
        [    0.000000] NR_IRQS: 16, nr_irqs: 16, preallocated irqs: 16
        [    0.000000] arch_timer: cp15 timer(s) running at 19.20MHz (phys).
        [    0.000000] clocksource: arch_sys_counter: mask: 0xffffffffffffff max_cycles: 0x46d987e47, max_idle_ns: 440795202767 ns
        [    0.000009] sched_clock: 56 bits at 19MHz, resolution 52ns, wraps every 4398046511078ns
        [    0.000031] Switching to timer-based delay loop, resolution 52ns
        [    0.000355] Console: colour dummy device 80x30
        [    0.001081] console [tty1] enabled
        [    0.001155] Calibrating delay loop (skipped), value calculated using timer frequency.. 38.40 BogoMIPS (lpj=192000)
        [    0.001208] pid_max: default: 32768 minimum: 301
        [    0.001681] Mount-cache hash table entries: 2048 (order: 1, 8192 bytes)
        [    0.001729] Mountpoint-cache hash table entries: 2048 (order: 1, 8192 bytes)
        [    0.003013] CPU: Testing write buffer coherency: ok
        [    0.003727] CPU0: update cpu_capacity 1024
        [    0.003771] CPU0: thread -1, cpu 0, socket 15, mpidr 80000f00
        [    0.004805] Setting up static identity map for 0x100000 - 0x10003c
        [    0.005073] rcu: Hierarchical SRCU implementation.
        [    0.006308] smp: Bringing up secondary CPUs ...
        [    0.007638] CPU1: update cpu_capacity 1024
        [    0.007650] CPU1: thread -1, cpu 1, socket 15, mpidr 80000f01
        [    0.009078] CPU2: update cpu_capacity 1024
        [    0.009089] CPU2: thread -1, cpu 2, socket 15, mpidr 80000f02
        [    0.010503] CPU3: update cpu_capacity 1024
        [    0.010515] CPU3: thread -1, cpu 3, socket 15, mpidr 80000f03
        [    0.010674] smp: Brought up 1 node, 4 CPUs
        [    0.010831] SMP: Total of 4 processors activated (153.60 BogoMIPS).
        [    0.010859] CPU: All CPU(s) started in HYP mode.
        [    0.010882] CPU: Virtualization extensions available.
        [    0.012193] devtmpfs: initialized
        [    0.028028] VFP support v0.3: implementor 41 architecture 2 part 30 variant 7 rev 5
        [    0.028460] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 19112604462750000 ns
        [    0.028528] futex hash table entries: 1024 (order: 4, 65536 bytes)
        [    0.029410] pinctrl core: initialized pinctrl subsystem
        [    0.030817] NET: Registered protocol family 16
        [    0.034604] DMA: preallocated 1024 KiB pool for atomic coherent allocations
        [    0.042185] hw-breakpoint: found 5 (+1 reserved) breakpoint and 4 watchpoint registers.
        [    0.042243] hw-breakpoint: maximum watchpoint size is 8 bytes.
        [    0.042533] Serial: AMBA PL011 UART driver
        [    0.045622] bcm2835-mbox 3f00b880.mailbox: mailbox enabled
        [    0.060139] raspberrypi-firmware soc:firmware: Attached to firmware from 2020-04-15 11:43, variant start
        [    0.070158] raspberrypi-firmware soc:firmware: Firmware hash is 82f9bb929ce2186eb1824178c1ae82902ad6275c
        [    0.123338] bcm2835-dma 3f007000.dma: DMA legacy API manager at (ptrval), dmachans=0x1
        [    0.125597] SCSI subsystem initialized
        [    0.125969] usbcore: registered new interface driver usbfs
        [    0.126075] usbcore: registered new interface driver hub
        [    0.126259] usbcore: registered new device driver usb
        [    0.128419] clocksource: Switched to clocksource arch_sys_counter
        [    0.232496] VFS: Disk quotas dquot_6.6.0
        [    0.232650] VFS: Dquot-cache hash table entries: 1024 (order 0, 4096 bytes)
        [    0.232948] FS-Cache: Loaded
        [    0.233289] CacheFiles: Loaded
        [    0.247211] NET: Registered protocol family 2
        [    0.248870] tcp_listen_portaddr_hash hash table entries: 512 (order: 0, 6144 bytes)
        [    0.248962] TCP established hash table entries: 8192 (order: 3, 32768 bytes)
        [    0.249118] TCP bind hash table entries: 8192 (order: 4, 65536 bytes)
        [    0.249331] TCP: Hash tables configured (established 8192 bind 8192)
        [    0.249567] UDP hash table entries: 512 (order: 2, 16384 bytes)
        [    0.249665] UDP-Lite hash table entries: 512 (order: 2, 16384 bytes)
        [    0.250047] NET: Registered protocol family 1
        [    0.251015] RPC: Registered named UNIX socket transport module.
        [    0.251057] RPC: Registered udp transport module.
        [    0.251083] RPC: Registered tcp transport module.
        [    0.251108] RPC: Registered tcp NFSv4.1 backchannel transport module.
        [    0.253377] hw perfevents: enabled with armv7_cortex_a7 PMU driver, 5 counters available
        [    0.257602] Initialise system trusted keyrings
        [    0.257972] workingset: timestamp_bits=14 max_order=18 bucket_order=4
        [    0.271326] FS-Cache: Netfs 'nfs' registered for caching
        [    0.272207] NFS: Registering the id_resolver key type
        [    0.272275] Key type id_resolver registered
        [    0.272302] Key type id_legacy registered
        [    0.272341] nfs4filelayout_init: NFSv4 File Layout Driver Registering...
        [    0.279580] Key type asymmetric registered
        [    0.279633] Asymmetric key parser 'x509' registered
        [    0.279745] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 250)
        [    0.280027] io scheduler noop registered
        [    0.280064] io scheduler deadline registered (default)
        [    0.280362] io scheduler cfq registered
        [    0.280396] io scheduler mq-deadline registered (default)
        [    0.280425] io scheduler kyber registered
        [    0.282994] bcm2708_fb soc:fb: FB found 1 display(s)
        [    0.293426] Console: switching to colour frame buffer device 82x26
        [    0.301272] bcm2708_fb soc:fb: Registered framebuffer for display 0, size 656x416
        [    0.309433] bcm2835-rng 3f104000.rng: hwrng registered
        [    0.312530] vc-mem: phys_addr:0x00000000 mem_base=0x3ec00000 mem_size:0x40000000(1024 MiB)
        [    0.318841] vc-sm: Videocore shared memory driver
        [    0.322101] gpiomem-bcm2835 3f200000.gpiomem: Initialised: Registers at 0x3f200000
        [    0.343698] brd: module loaded
        [    0.360984] loop: module loaded
        [    0.364585] Loading iSCSI transport class v2.0-870.
        [    0.368545] libphy: Fixed MDIO Bus: probed
        [    0.371437] usbcore: registered new interface driver lan78xx
        [    0.374233] usbcore: registered new interface driver smsc95xx
        [    0.376907] dwc_otg: version 3.00a 10-AUG-2012 (platform bus)
        [    0.407595] dwc_otg 3f980000.usb: base=(ptrval)
        [    0.610756] Core Release: 2.80a
        [    0.613459] Setting default values for core params
        [    0.616236] Finished setting default values for core params
        [    0.819465] Using Buffer DMA mode
        [    0.822175] Periodic Transfer Interrupt Enhancement - disabled
        [    0.824915] Multiprocessor Interrupt Enhancement - disabled
        [    0.827595] OTG VER PARAM: 0, OTG VER FLAG: 0
        [    0.830269] Dedicated Tx FIFOs mode
        [    0.833481] WARN::dwc_otg_hcd_init:1074: FIQ DMA bounce buffers: virt = bad14000 dma = 0xfad14000 len=9024
        [    0.838712] FIQ FSM acceleration enabled for :
                       Non-periodic Split Transactions
                       Periodic Split Transactions
                       High-Speed Isochronous Endpoints
                       Interrupt/Control Split Transaction hack enabled
        [    0.851021] dwc_otg: Microframe scheduler enabled
        [    0.851106] WARN::hcd_init_fiq:457: FIQ on core 1
        [    0.853631] WARN::hcd_init_fiq:458: FIQ ASM at 8068fda0 length 36
        [    0.856133] WARN::hcd_init_fiq:497: MPHI regs_base at bb810000
        [    0.858693] dwc_otg 3f980000.usb: DWC OTG Controller
        [    0.861266] dwc_otg 3f980000.usb: new USB bus registered, assigned bus number 1
        [    0.863899] dwc_otg 3f980000.usb: irq 56, io mem 0x00000000
        [    0.866499] Init: Port Power? op_state=1
        [    0.869076] Init: Power Port (0)
        [    0.871895] usb usb1: New USB device found, idVendor=1d6b, idProduct=0002, bcdDevice= 4.19
        [    0.876977] usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=1
        [    0.879735] usb usb1: Product: DWC OTG Controller
        [    0.882412] usb usb1: Manufacturer: Linux 4.19.118-v7+ dwc_otg_hcd
        [    0.885153] usb usb1: SerialNumber: 3f980000.usb
        [    0.888742] hub 1-0:1.0: USB hub found
        [    0.891357] hub 1-0:1.0: 1 port detected
        [    0.894635] dwc_otg: FIQ enabled
        [    0.894644] dwc_otg: NAK holdoff enabled
        [    0.894650] dwc_otg: FIQ split-transaction FSM enabled
        [    0.894663] Module dwc_common_port init
        [    0.895082] usbcore: registered new interface driver usb-storage
        [    0.897958] mousedev: PS/2 mouse device common for all mice
        [    0.901767] bcm2835-wdt bcm2835-wdt: Broadcom BCM2835 watchdog timer
        [    0.904796] bcm2835-cpufreq: min=600000 max=900000
        [    0.908086] sdhci: Secure Digital Host Controller Interface driver
        [    0.910866] sdhci: Copyright(c) Pierre Ossman
        [    0.914133] sdhost-bcm2835 3f202000.mmc: could not get clk, deferring probe
        [    0.917192] sdhci-pltfm: SDHCI platform and OF driver helper
        [    0.920945] ledtrig-cpu: registered to indicate activity on CPUs
        [    0.923977] hidraw: raw HID events driver (C) Jiri Kosina
        [    0.927104] usbcore: registered new interface driver usbhid
        [    0.930031] usbhid: USB HID core driver
        [    0.933877] vchiq: vchiq_init_state: slot_zero = (ptrval), is_master = 0
        [    0.938750] [vc_sm_connected_init]: start
        [    0.947730] [vc_sm_connected_init]: end - returning 0
        [    0.952065] Initializing XFRM netlink socket
        [    0.954801] NET: Registered protocol family 17
        [    0.957624] Key type dns_resolver registered
        [    0.960867] Registering SWP/SWPB emulation handler
        [    0.964533] registered taskstats version 1
        [    0.967242] Loading compiled-in X.509 certificates
        [    0.981054] sdhost: log_buf @ (ptrval) (fad13000)
        [    1.030788] mmc0: sdhost-bcm2835 loaded - DMA enabled (>1)
        [    1.035217] of_cfs_init
        [    1.038026] of_cfs_init: OK
        [    1.041487] Waiting for root device PARTUUID=6c586e13-02...
        [    1.092327] mmc0: host does not support reading read-only switch, assuming write-enable
        [    1.099771] mmc0: new high speed SDHC card at address b368
        [    1.103915] mmcblk0: mmc0:b368       7.46 GiB
        [    1.108652] Indeed it is in host mode hprt0 = 00021501
        [    1.171432]  mmcblk0: p1 p2
        [    1.198485] random: fast init done
        [    1.203964] EXT4-fs (mmcblk0p2): mounted filesystem with ordered data mode. Opts: (null)
        [    1.209170] VFS: Mounted root (ext4 filesystem) readonly on device 179:2.
        [    1.222989] devtmpfs: mounted
        [    1.233729] Freeing unused kernel memory: 1024K
        [    1.248798] Run /sbin/init as init process
        [    1.318501] usb 1-1: new high-speed USB device number 2 using dwc_otg
        [    1.321575] Indeed it is in host mode hprt0 = 00001101
        [    1.558901] usb 1-1: New USB device found, idVendor=0424, idProduct=9514, bcdDevice= 2.00
        [    1.564770] usb 1-1: New USB device strings: Mfr=0, Product=0, SerialNumber=0
        [    1.568876] hub 1-1:1.0: USB hub found
        [    1.572170] hub 1-1:1.0: 5 ports detected
        [    1.888525] usb 1-1.1: new high-speed USB device number 3 using dwc_otg
        [    2.018921] usb 1-1.1: New USB device found, idVendor=0424, idProduct=ec00, bcdDevice= 2.00
        [    2.024940] usb 1-1.1: New USB device strings: Mfr=0, Product=0, SerialNumber=0
        [    2.031147] smsc95xx v1.0.6
        [    2.123246] smsc95xx 1-1.1:1.0 eth0: register 'smsc95xx' at usb-3f980000.usb-1.1, smsc95xx USB 2.0 Ethernet, b8:27:eb:79:91:b1
        [    2.160254] systemd[1]: System time before build time, advancing clock.
        [    2.228491] usb 1-1.2: new high-speed USB device number 4 using dwc_otg
        [    2.363585] NET: Registered protocol family 10
        [    2.369119] Segment Routing with IPv6
        [    2.376426] usb 1-1.2: New USB device found, idVendor=148f, idProduct=5370, bcdDevice= 1.01
        [    2.383150] usb 1-1.2: New USB device strings: Mfr=1, Product=2, SerialNumber=3
        [    2.386669] usb 1-1.2: Product: 802.11 n WLAN
        [    2.390115] usb 1-1.2: Manufacturer: Ralink
        [    2.393430] usb 1-1.2: SerialNumber: 1.0
        [    2.431840] systemd[1]: systemd 241 running in system mode. (+PAM +AUDIT +SELINUX +IMA +APPARMOR +SMACK +SYSVINIT +UTMP +LIBCRYPTSETUP +GCRYPT +GNUTLS +ACL +XZ +LZ4 +SECCOMP +BLKID +ELFUTILS +KMOD -IDN2 +IDN -PCRE2 default-hierarchy=hybrid)
        [    2.443318] systemd[1]: Detected architecture arm.
        [    2.488326] systemd[1]: Set hostname to <raspberrypi>.
        [    2.708574] usb 1-1.4: new full-speed USB device number 5 using dwc_otg
        [    2.856174] usb 1-1.4: New USB device found, idVendor=0a5c, idProduct=21e8, bcdDevice= 1.12
        [    2.862539] usb 1-1.4: New USB device strings: Mfr=1, Product=2, SerialNumber=3
        [    2.865786] usb 1-1.4: Product: BCM20702A0
        [    2.868962] usb 1-1.4: Manufacturer: Broadcom Corp
        [    2.872127] usb 1-1.4: SerialNumber: 5CF3706272AB
        [    3.573759] systemd[1]: /lib/systemd/system/pivccu.service:8: PIDFile= references path below legacy directory /var/run/, updating /var/run/pivccu3.pid → /run/pivccu3.pid; please update the unit file accordingly.
        [    3.750642] random: systemd: uninitialized urandom read (16 bytes read)
        [    3.768991] random: systemd: uninitialized urandom read (16 bytes read)
        [    3.773096] systemd[1]: Started Dispatch Password Requests to Console Directory Watch.
        [    3.783665] random: systemd: uninitialized urandom read (16 bytes read)
        [    3.795412] systemd[1]: Created slice system-getty.slice.
        [    3.813664] systemd[1]: Listening on Syslog Socket.
        [    3.824436] systemd[1]: Created slice system-systemd\x2dfsck.slice.
        [    3.832013] systemd[1]: Reached target Swap.
        [    3.840120] systemd[1]: Listening on Journal Socket (/dev/log).
        [    4.942046] EXT4-fs (mmcblk0p2): re-mounted. Opts: (null)
        [    5.118294] systemd-journald[116]: Received request to flush runtime journal from PID 1
        [    5.896855] generic_raw_uart: loading out-of-tree module taints kernel.
        [    5.900673] vc_sm_cma: module is from the staging directory, the quality is unknown, you have been warned.
        [    5.903856] bcm2835_vc_sm_cma_probe: Videocore shared memory driver
        [    5.903880] [vc_sm_connected_init]: start
        [    5.905869] [vc_sm_connected_init]: installed successfully
        [    5.926379] media: Linux media interface: v0.10
        [    5.974979] videodev: Linux video capture interface: v2.00
        [    6.080575] bcm2835_mmal_vchiq: module is from the staging directory, the quality is unknown, you have been warned.
        [    6.084455] bcm2835_mmal_vchiq: module is from the staging directory, the quality is unknown, you have been warned.
        [    6.100013] bcm2835_v4l2: module is from the staging directory, the quality is unknown, you have been warned.
        [    6.107399] snd_bcm2835: module is from the staging directory, the quality is unknown, you have been warned.
        [    6.114445] bcm2835_codec: module is from the staging directory, the quality is unknown, you have been warned.
        [    6.119977] pl011_raw_uart 3f201000.serial: Initialized pl011 device; mapbase=0x3f201000; irq=81; clockrate=47999625
        [    6.144579] bcm2835-codec bcm2835-codec: Device registered as /dev/video10
        [    6.144647] bcm2835-codec bcm2835-codec: Loaded V4L2 decode
        [    6.151741] bcm2835-codec bcm2835-codec: Device registered as /dev/video11
        [    6.151796] bcm2835-codec bcm2835-codec: Loaded V4L2 encode
        [    6.160607] bcm2835-codec bcm2835-codec: Device registered as /dev/video12
        [    6.160692] bcm2835-codec bcm2835-codec: Loaded V4L2 isp
        [    6.170300] bcm2835_audio soc:audio: card created with 8 channels
        [    6.760347] cfg80211: Loading compiled-in X.509 certificates for regulatory database
        [    6.832439] cfg80211: Loaded X.509 cert 'sforshee: 00b28ddf47aef9cea7'
        [    6.894465] Bluetooth: Core ver 2.22
        [    6.894600] NET: Registered protocol family 31
        [    6.894610] Bluetooth: HCI device and connection manager initialized
        [    6.894640] Bluetooth: HCI socket layer initialized
        [    6.894659] Bluetooth: L2CAP socket layer initialized
        [    6.894719] Bluetooth: SCO socket layer initialized
        [    7.004257] usbcore: registered new interface driver btusb
        [    7.121047] Bluetooth: hci0: BCM: chip id 63
        [    7.122011] Bluetooth: hci0: BCM: features 0x07
        [    7.138071] Bluetooth: hci0: BCM20702A
        [    7.139039] Bluetooth: hci0: BCM20702A1 (001.002.014) build 0000
        [    7.150835] bluetooth hci0: Direct firmware load for brcm/BCM20702A1-0a5c-21e8.hcd failed with error -2
        [    7.150868] Bluetooth: hci0: BCM: Patch brcm/BCM20702A1-0a5c-21e8.hcd not found
        [    7.258632] usb 1-1.2: reset high-speed USB device number 4 using dwc_otg
        [    7.399537] ieee80211 phy0: rt2x00_set_rt: Info - RT chipset 5390, rev 0502 detected
        [    7.418605] rtc-rx8130 1-0032: Unable to read registers #28..#30
        [    7.418629] i2c i2c-1: probing for rx8130 failed
        [    7.418674] rtc-rx8130: probe of 1-0032 failed with error -121
        [    7.436032] ieee80211 phy0: rt2x00_set_rf: Info - RF chipset 5370 detected
        [    7.510636] ieee80211 phy0: Selected rate control algorithm 'minstrel_ht'
        [    7.513155] usbcore: registered new interface driver rt2800usb
        [    7.891336] random: crng init done
        [    7.891360] random: 7 urandom warning(s) missed due to ratelimiting
        [    8.709566] bridge: filtering via arp/ip/ip6tables is no longer available by default. Update your scripts to load br_netfilter if you need this.
        [    8.744663] br0: port 1(eth0) entered blocking state
        [    8.744683] br0: port 1(eth0) entered disabled state
        [    8.745296] device eth0 entered promiscuous mode
        [    8.859939] smsc95xx 1-1.1:1.0 eth0: hardware isn't capable of remote wakeup
        [    8.880195] br0: port 1(eth0) entered blocking state
        [    8.880216] br0: port 1(eth0) entered forwarding state
        [    8.880460] IPv6: ADDRCONF(NETDEV_UP): br0: link is not ready
        [    9.426793] new mount options do not match the existing superblock, will be ignored
        [    9.573415] fuse init (API version 7.27)
        [    9.758558] IPv6: ADDRCONF(NETDEV_CHANGE): br0: link becomes ready
        [   10.471647] smsc95xx 1-1.1:1.0 eth0: link up, 100Mbps, full-duplex, lpa 0xCDE1
        [   10.528482] usb 1-1.5: new full-speed USB device number 6 using dwc_otg
        [   10.661904] usb 1-1.5: New USB device found, idVendor=0451, idProduct=16c8, bcdDevice= 1.00
        [   10.661922] usb 1-1.5: New USB device strings: Mfr=1, Product=2, SerialNumber=0
        [   10.661930] usb 1-1.5: Product: CC2538 USB CDC
        [   10.661938] usb 1-1.5: Manufacturer: Texas Instruments
        [   10.939175] cdc_acm 1-1.5:1.0: ttyACM0: USB ACM device
        [   10.941706] usbcore: registered new interface driver cdc_acm
        [   10.941723] cdc_acm: USB Abstract Control Model driver for USB modems and ISDN adapters
        [   11.123432] Adding 102396k swap on /var/swap.  Priority:-2 extents:5 across:1295108k SSFS
        [   11.128180] Bluetooth: BNEP (Ethernet Emulation) ver 1.3
        [   11.128192] Bluetooth: BNEP filters: protocol multicast
        [   11.128224] Bluetooth: BNEP socket layer initialized
        [   27.775554] raw-uart raw-uart: Reset radio module
        [   65.110423] br0: port 2(vethpivccu) entered blocking state
        [   65.110448] br0: port 2(vethpivccu) entered disabled state
        [   65.111205] device vethpivccu entered promiscuous mode
        [   65.112717] IPv6: ADDRCONF(NETDEV_UP): vethpivccu: link is not ready
        [   65.204212] eth0: renamed from vethNCHQWD
        [   65.280463] IPv6: ADDRCONF(NETDEV_UP): eth0: link is not ready
        [   65.286128] IPv6: ADDRCONF(NETDEV_CHANGE): eth0: link becomes ready
        [   65.286461] IPv6: ADDRCONF(NETDEV_CHANGE): vethpivccu: link becomes ready
        [   65.286612] br0: port 2(vethpivccu) entered blocking state
        [   65.286623] br0: port 2(vethpivccu) entered forwarding state
        [   71.270612] FS-Cache: Netfs 'cifs' registered for caching
        [   71.271586] Key type cifs.spnego registered
        [   71.271622] Key type cifs.idmap registered
        [   84.150212] eq3loop: created slave mmd_hmip
        [   84.151404] eq3loop: created slave mmd_bidcos
        [   99.133310] eq3loop: eq3loop_open_slave() mmd_bidcos
        [  150.109984] eq3loop: eq3loop_open_slave() mmd_hmip
        [  150.110396] eq3loop: eq3loop_close_slave() mmd_hmip
        [  150.116545] eq3loop: eq3loop_open_slave() mmd_hmip
        [  150.116880] eq3loop: eq3loop_close_slave() mmd_hmip
        [  150.144191] eq3loop: eq3loop_open_slave() mmd_hmip
        [  902.398362] usb 1-1.5: USB disconnect, device number 6
        [  916.778168] usb 1-1.5: new full-speed USB device number 7 using dwc_otg
        [  916.911539] usb 1-1.5: New USB device found, idVendor=0451, idProduct=16c8, bcdDevice= 1.00
        [  916.911557] usb 1-1.5: New USB device strings: Mfr=1, Product=2, SerialNumber=0
        [  916.911565] usb 1-1.5: Product: CC2538 USB CDC
        [  916.911572] usb 1-1.5: Manufacturer: Texas Instruments
        [  916.912911] cdc_acm 1-1.5:1.0: ttyACM0: USB ACM device
        ich kann da nichts ungewöhnliches sehen!
        • B bishop
          @Thomas-Braun
          @bishop sagte in Zigbee startet nicht mehr:
          [    1.209170] VFS: Mounted root (ext4 filesystem) readonly on device 179:2..426793] new mount options do not match the existing superblock, will be ignored
          Sieht ein wenig verdächtig aus, imho.
          Insbesondere, dass / nur ro gemounted wird.
          Schau mal mit
          mount | grep ^/dev
          danach.
            Schau mal mit
            mount | grep ^/dev
            danach.
            bishop
            @Thomas-Braun
            /dev/mmcblk0p2 on / type ext4 (rw,noatime)
            /dev/mmcblk0p1 on /boot type vfat (rw,relatime,fmask=0022,dmask=0022,codepage=437,iocharset=ascii,shortname=mixed,errors=remount-ro)
            • B bishop
              @Thomas-Braun
              @bishop
              which nodejs && nodejs -v && which node && node -v && which npm && npm -v && apt policy nodejs
                @bishop
                bishop
                schrieb am zuletzt editiert von bishop
                @Thomas-Braun
                pi@raspberrypi:~ $ which nodejs && nodejs -v && which node && node -v && which npm && npm -v && apt policy nodejs
                /usr/bin/nodejs
                v10.21.0
                /usr/bin/node
                v10.21.0
                /usr/bin/npm
                6.14.4
                nodejs:
                  Installiert:           10.21.0-1nodesource1
                  Installationskandidat: 10.21.0-1nodesource1
                  Versionstabelle:
                 *** 10.21.0-1nodesource1 500
                        500 https://deb.nodesource.com/node_10.x buster/main armhf Packages
                     10.21.0~dfsg-1~deb10u1+rpi1 500
                hab mal eine andere Sd Karte benutzt aber leider das gleiche!
                host.raspberrypi	2020-06-28 13:21:51.274	info	"system.adapter.zigbee.0" disabled
                zigbee.0	2020-06-28 13:21:21.452	error	at process._tickCallback (internal/process/next_tick.js:68:7)
                zigbee.0	2020-06-28 13:21:21.452	error	at fulfilled (/opt/iobroker/node_modules/zigbee-herdsman/dist/controller/controller.js:5:58)
                zigbee.0	2020-06-28 13:21:21.452	error	at Generator.next (<anonymous>)
                zigbee.0	2020-06-28 13:21:21.452	error	at Controller.<anonymous> (/opt/iobroker/node_modules/zigbee-herdsman/dist/controller/controller.js:91:48)
                zigbee.0	2020-06-28 13:21:21.452	error	at Function.open (/opt/iobroker/node_modules/zigbee-herdsman/dist/controller/database.js:17:35)
                zigbee.0	2020-06-28 13:21:21.452	error	at JSON.parse (<anonymous>)
                zigbee.0	2020-06-28 13:21:21.452	error	(1898) SyntaxError: Unexpected token in JSON at position 895
                zigbee.0	2020-06-28 13:21:21.449	error	(1898) Failed to start Zigbee
                zigbee.0	2020-06-28 13:21:21.014	info	(1898) Starting Zigbee...
                zigbee.0	2020-06-28 13:21:21.012	info	(1898) Try to reconnect. 1 attempts left
                zigbee.0	2020-06-28 13:21:11.008	error	at process._tickCallback (internal/process/next_tick.js:68:7)
                zigbee.0	2020-06-28 13:21:11.008	error	at fulfilled (/opt/iobroker/node_modules/zigbee-herdsman/dist/controller/controller.js:5:58)
                zigbee.0	2020-06-28 13:21:11.008	error	at Generator.next (<anonymous>)
                zigbee.0	2020-06-28 13:21:11.008	error	at Controller.<anonymous> (/opt/iobroker/node_modules/zigbee-herdsman/dist/controller/controller.js:91:48)
                zigbee.0	2020-06-28 13:21:11.008	error	at Function.open (/opt/iobroker/node_modules/zigbee-herdsman/dist/controller/database.js:17:35)
                zigbee.0	2020-06-28 13:21:11.008	error	at JSON.parse (<anonymous>)
                zigbee.0	2020-06-28 13:21:11.008	error	(1898) SyntaxError: Unexpected token in JSON at position 895
                zigbee.0	2020-06-28 13:21:11.005	error	(1898) Failed to start Zigbee
                zigbee.0	2020-06-28 13:21:09.960	info	(1898) Starting Zigbee...
                zigbee.0	2020-06-28 13:21:09.838	info	(1898) starting. Version 1.1.1 in /opt/iobroker/node_modules/iobroker.zigbee, node: v10.21.0, js-controller: 3.1.5
                ohne den Stick wird der Adapter auch nicht Grün, also kann es wohl nicht am Stick liegen oder?
                Ein komplettes löschen des ZigbeeAdapters habe ich auch schon versucht.
                • M Malz1902
                  Habe bevor ich hier den Thread aufgemacht schon alles gemacht und jetzt auch nochmal.
                  /dev/serial/by-id/usb-Texas_Instruments_XDS110__03.00.00.07__Embed_with_CMSIS-DAP_L4300302-if00
                  isgt der COM Port
                  über USB ist nur der Zigbee Stick dran
                  dimaiv
                  schrieb am zuletzt editiert von dimaiv
                  @Malz1902 sagte in Zigbee startet nicht mehr:
                  isgt der COM Port
                  Das ist aber kein Stick, oder hast du den umgeflasht?
                  ioBroker- NUC8i3 / Proxmox / VM
                  Node.js v22.21.0
                  NPM v10.9.4
                  JS controller 7.1.0
                  Admin 7.7.20
                  ZigBee Adapter 3.3.1alpha.0
                  Zigbee LAN Gateway CC2652P
                  Zigbee Firmware 20250321
                  • D dimaiv
                    isgt der COM Port
                    Malz1902
                    @dimaiv
                    Nutze einen CC1352R1
                    Hab die Firmware nochmal neugeflasht, daanch ging wieder alles
                      bishop
                      hat vielleicht noch jemand ein Tip für mich das ich tun kann?
                      • B bishop
                        dimaiv
                        @bishop
                        Hi, hast du das schon mal gemacht:
                        ls -la /dev/serial/by-id
                        Node.js v22.21.0
                        NPM v10.9.4
                        JS controller 7.1.0
                        Admin 7.7.20
                        • D dimaiv
                          @bishop
                          bishop
                          @dimaiv
                          ja
                          pi@raspberrypi:~ $ ls -la /dev/serial/by-id
                          insgesamt 0
                          drwxr-xr-x 2 root root 60 Jun 29 18:21 .
                          drwxr-xr-x 4 root root 80 Jun 29 18:21 ..
                          lrwxrwxrwx 1 root root 13 Jun 29 18:21 usb-Texas_Instruments_CC2538_USB_CDC-if00 -> ../../ttyACM0
                          ich habe pivccu3 noch auf dem Raspberry laufen mit den dementsprechenden Adapter, kann das ein Problem sein?
                          Lief jetzt alles Monate lang ohne Probleme...
                          • B bishop
                            @dimaiv
                            ja
                            insgesamt 0
                            dimaiv
                            @bishop
                            Also, der Stick funktioniert.
                            Mit pivccu3 kenne mich nicht aus.
                            Node.js v22.21.0
                            NPM v10.9.4
                            JS controller 7.1.0
                            Admin 7.7.20
                            • D dimaiv
                              @bishop
                              bishop
                              @dimaiv
                              mittlerweile kommt:
                              pi@raspberrypi:~ $ ls -la /dev/serial/by-path/
                              insgesamt 0
                              drwxr-xr-x 2 root root 60 Jun 30 16:36 .
                              drwxr-xr-x 4 root root 80 Jun 30 16:36 ..
                              lrwxrwxrwx 1 root root 13 Jun 30 16:36 platform-3f980000.usb-usb-0:1.5:1.0 -> ../../ttyACM0
                              ah falsch von mir
                              insgesamt 0
                              lrwxrwxrwx 1 root root 13 Jun 30 16:36 usb-Texas_Instruments_CC2538_USB_CDC-if00 -> ../../ttyACM0
