  4. Probleme mit Sonoff Adapter
sonoff tasmota
11 Beiträge 5 Kommentatoren 1.5k Aufrufe 4 Beobachtet
  • 2 Offline
    2 Offline
    2hot4you
    moin,
    habe seit heute Probleme mit dem Sonoff Adapter. Beim hinzufügen neuer Klients werden nicht mehr
    alle Datenpunkte geschrieben. Habe schon den Adapter neu installiert, auch keine Änderung.
    Adapter Version : 2.3.3
    Tasmota Version: 8.3.1
    in der Log werden die Datenpunkte angezeigt, angelegt werden diese aber nicht ??
    Jemand ne Idee ?
    Auszug vom Log
    sonoff.0	2020-06-16 12:50:09.391	debug	(2267) [Tasmota_Teich] Received: Tasmota_Teich/STATUS11 = {"StatusSTS":{"Time":"2020-06-16T11:50:06","Uptime":"0T01:26:14","UptimeSec":5174,"Heap":12,"SleepMode":"Dynamic","Sleep":50,"LoadAvg":50,"Mqt
    sonoff.0	2020-06-16 12:50:09.391	debug	(2267) [Tasmota_Teich] Received: Tasmota_Teich/STATUS10 = {"StatusSNS":{"Time":"2020-06-16T11:50:06","DS18B20":{"Id":"0517B007B3FF","Temperature":19.2},"TempUnit":"C"}}
    sonoff.0	2020-06-16 12:50:09.391	debug	(2267) [Tasmota_Teich] Received: Tasmota_Teich/STATUS7 = {"StatusTIM":{"UTC":"2020-06-16T10:50:06","Local":"2020-06-16T11:50:06","StartDST":"2020-03-29T02:00:00","EndDST":"2020-10-25T03:00:00","Timezo
    sonoff.0	2020-06-16 12:50:09.391	debug	(2267) [Tasmota_Teich] Received: Tasmota_Teich/STATUS6 = {"StatusMQT":{"MqttHost":"192.168.30.94","MqttPort":1883,"MqttClientMask":"Tasmota_Teich","MqttClient":"Tasmota_Teich","MqttUser":"Sonoff","Mqt
    sonoff.0	2020-06-16 12:50:09.391	debug	(2267) [Tasmota_Teich] Received: Tasmota_Teich/STATUS5 = {"StatusNET":{"Hostname":"Tasmota_Teich-1221","IPAddress":"192.168.30.51","Gateway":"192.168.30.1","Subnetmask":"255.255.255.0","DNSServer":"19
    sonoff.0	2020-06-16 12:50:09.365	debug	(2267) [Tasmota_Teich] Received: Tasmota_Teich/STATUS4 = {"StatusMEM":{"ProgramSize":616,"Free":384,"Heap":14,"ProgramFlashSize":1024,"FlashSize":1024,"FlashChipId":"14405E","FlashMode":3,"Features":[
    sonoff.0	2020-06-16 12:50:09.365	debug	(2267) [Tasmota_Teich] Received: Tasmota_Teich/STATUS3 = {"StatusLOG":{"SerialLog":2,"WebLog":2,"MqttLog":0,"SysLog":0,"LogHost":"","LogPort":514,"SSId":["xxxxxx",""],"TelePeriod":300,"Resolution":"
    sonoff.0	2020-06-16 12:50:09.365	debug	(2267) [Tasmota_Teich] Received: Tasmota_Teich/STATUS2 = {"StatusFWR":{"Version":"8.3.1(sensors)","BuildDateTime":"2020-05-18T15:41:26","Boot":6,"Core":"2_7_1","SDK":"2.2.2-dev(38a443e)","Hardware":"E
    sonoff.0	2020-06-16 12:50:09.364	debug	(2267) [Tasmota_Teich] Received: Tasmota_Teich/STATUS1 = {"StatusPRM":{"Baudrate":115200,"SerialConfig":"8N1","GroupTopic":"sonoffs","OtaUrl":"http://thehackbox.org/tasmota/release/sonoff-DE.bin","Res
    Gruß Michael
    • 2 2hot4you
      moin,
      Jemand ne Idee ?
      Auszug vom Log
      Gruß Michael
      GlasfaserG Offline
      GlasfaserG Offline
      Glasfaser
      @2hot4you
      hier ... alle Haken gesetzt !?
      K 1 Antwort Letzte Antwort
      • 2 Offline
        2 Offline
        2hot4you
        ja, waren immer an, nichts geändert
        • 2 2hot4you
          GlasfaserG Offline
          GlasfaserG Offline
          Glasfaser
          @2hot4you
          hier alles richtig ausgefüllt !?
          bzw. schau mal in der Konsole von deinem Sonoff was er sendet !?
          653ef64b-2eaa-410b-86b4-a0c60ee2436f-image.png c0cf4160-8563-4dd4-9104-6467a5b238fe-image.png 6398a7e3-a080-44fa-857f-60111673a099-image.png
          • 2 Offline
            2 Offline
            2hot4you
            schrieb am zuletzt editiert von 2hot4you
            Hallo @Glasfaser
            ich habe die Punkte auch so eingestellt. Bisher lief alles ohne Probleme. Wollte jetzt nur ein neues Gerät
            einfügen, da ist es mir aufgefallen. Auch wenn ich die Datenpunkte eines bisher ohne Probleme laufendes
            Gerät lösche und neu erstellen lasse, werden nur die oben gezeigten beiden Datenpunkte erstellt.
            Nachtrag: HAbe die topic und full topic und das Passwort nochmal neu eingegeben, die
            Datenpunkte wurde erstellt, Danke noch mal für den Tipp
            • 2 2hot4you
              Hallo @Glasfaser
              crunchipC Offline
              crunchipC Offline
              @2hot4you hast du das Gerät mal neu gestartet, (hatte ich auch mal, das erst nach Neustart, nach ner weile die DP`s angelegt wurden)
              übrigens @Glasfaser ist in v8.x das topic nicht mehr sonoff, sondern tasmota
                GlasfaserG Offline
                GlasfaserG Offline
                Glasfaser
                @crunchip
                Das war dein Screenshot ... aus einem anderen Beitrag die Tage :) ;) 😀
                Link Text
                • GlasfaserG Glasfaser
                  @crunchip
                  Link Text
                  crunchipC Offline
                  crunchipC Offline
                  @Glasfaser ich weiss, kam mir sofort bekannt vor😁
                  deshalb war die Info dazu, weil der screen meiner Dose mit V6.4.1) (passend beim anderen Beitrag)war,
                  hier es sich jedoch um v8.3.1 handelt
                    @2hot4you
                    Kugelkopf
                    @Glasfaser @2hot4you Auch gerne mal die Häkchen wegmachen speichern, Adapter neustarten, Häkchen wieder anklicken, neu starten. Hat bei mir geholfen.
                      Buko
                      schrieb am zuletzt editiert von Buko
                      Bei mir klappen 1-2 s2x nicht keine ahnung alles lief vorher wunderbar !
                      Update gemacht von 8.2 auf 8.3.1 auch keine besserung häcken nmeu gesetzt und und und
                        Buko
                        Fritzbox löst iobroker server name nicht richtig auf muste ie IP angeben
