  4. Probleme mit Sonoff Adapter
sonoff tasmota
11 Beiträge 5 Kommentatoren 1.5k Aufrufe 4 Beobachtet
  • 2 2hot4you
    moin,
    habe seit heute Probleme mit dem Sonoff Adapter. Beim hinzufügen neuer Klients werden nicht mehr
    alle Datenpunkte geschrieben. Habe schon den Adapter neu installiert, auch keine Änderung.
    Adapter Version : 2.3.3
    Tasmota Version: 8.3.1
    in der Log werden die Datenpunkte angezeigt, angelegt werden diese aber nicht ??
    Jemand ne Idee ?
    Auszug vom Log
    sonoff.0	2020-06-16 12:50:09.391	debug	(2267) [Tasmota_Teich] Received: Tasmota_Teich/STATUS11 = {"StatusSTS":{"Time":"2020-06-16T11:50:06","Uptime":"0T01:26:14","UptimeSec":5174,"Heap":12,"SleepMode":"Dynamic","Sleep":50,"LoadAvg":50,"Mqt
    sonoff.0	2020-06-16 12:50:09.391	debug	(2267) [Tasmota_Teich] Received: Tasmota_Teich/STATUS10 = {"StatusSNS":{"Time":"2020-06-16T11:50:06","DS18B20":{"Id":"0517B007B3FF","Temperature":19.2},"TempUnit":"C"}}
    sonoff.0	2020-06-16 12:50:09.391	debug	(2267) [Tasmota_Teich] Received: Tasmota_Teich/STATUS7 = {"StatusTIM":{"UTC":"2020-06-16T10:50:06","Local":"2020-06-16T11:50:06","StartDST":"2020-03-29T02:00:00","EndDST":"2020-10-25T03:00:00","Timezo
    sonoff.0	2020-06-16 12:50:09.391	debug	(2267) [Tasmota_Teich] Received: Tasmota_Teich/STATUS6 = {"StatusMQT":{"MqttHost":"192.168.30.94","MqttPort":1883,"MqttClientMask":"Tasmota_Teich","MqttClient":"Tasmota_Teich","MqttUser":"Sonoff","Mqt
    sonoff.0	2020-06-16 12:50:09.391	debug	(2267) [Tasmota_Teich] Received: Tasmota_Teich/STATUS5 = {"StatusNET":{"Hostname":"Tasmota_Teich-1221","IPAddress":"192.168.30.51","Gateway":"192.168.30.1","Subnetmask":"255.255.255.0","DNSServer":"19
    sonoff.0	2020-06-16 12:50:09.365	debug	(2267) [Tasmota_Teich] Received: Tasmota_Teich/STATUS4 = {"StatusMEM":{"ProgramSize":616,"Free":384,"Heap":14,"ProgramFlashSize":1024,"FlashSize":1024,"FlashChipId":"14405E","FlashMode":3,"Features":[
    sonoff.0	2020-06-16 12:50:09.365	debug	(2267) [Tasmota_Teich] Received: Tasmota_Teich/STATUS3 = {"StatusLOG":{"SerialLog":2,"WebLog":2,"MqttLog":0,"SysLog":0,"LogHost":"","LogPort":514,"SSId":["xxxxxx",""],"TelePeriod":300,"Resolution":"
    sonoff.0	2020-06-16 12:50:09.365	debug	(2267) [Tasmota_Teich] Received: Tasmota_Teich/STATUS2 = {"StatusFWR":{"Version":"8.3.1(sensors)","BuildDateTime":"2020-05-18T15:41:26","Boot":6,"Core":"2_7_1","SDK":"2.2.2-dev(38a443e)","Hardware":"E
    sonoff.0	2020-06-16 12:50:09.364	debug	(2267) [Tasmota_Teich] Received: Tasmota_Teich/STATUS1 = {"StatusPRM":{"Baudrate":115200,"SerialConfig":"8N1","GroupTopic":"sonoffs","OtaUrl":"http://thehackbox.org/tasmota/release/sonoff-DE.bin","Res
    Gruß Michael
    GlasfaserG Offline
    GlasfaserG Offline
    @2hot4you
    hier ... alle Haken gesetzt !?
    • 2 Offline
      2 Offline
      2hot4you
      ja, waren immer an, nichts geändert
      • 2 2hot4you
        GlasfaserG Offline
        GlasfaserG Offline
        @2hot4you
        hier alles richtig ausgefüllt !?
        bzw. schau mal in der Konsole von deinem Sonoff was er sendet !?
        653ef64b-2eaa-410b-86b4-a0c60ee2436f-image.png c0cf4160-8563-4dd4-9104-6467a5b238fe-image.png 6398a7e3-a080-44fa-857f-60111673a099-image.png
        • 2 Offline
          2 Offline
          2hot4you
          schrieb am zuletzt editiert von 2hot4you
          Hallo @Glasfaser
          ich habe die Punkte auch so eingestellt. Bisher lief alles ohne Probleme. Wollte jetzt nur ein neues Gerät
          einfügen, da ist es mir aufgefallen. Auch wenn ich die Datenpunkte eines bisher ohne Probleme laufendes
          Gerät lösche und neu erstellen lasse, werden nur die oben gezeigten beiden Datenpunkte erstellt.
          Nachtrag: HAbe die topic und full topic und das Passwort nochmal neu eingegeben, die
          Datenpunkte wurde erstellt, Danke noch mal für den Tipp
          • 2 2hot4you
            Hallo @Glasfaser
            crunchipC Offline
            crunchipC Offline
            @2hot4you hast du das Gerät mal neu gestartet, (hatte ich auch mal, das erst nach Neustart, nach ner weile die DP`s angelegt wurden)
            übrigens @Glasfaser ist in v8.x das topic nicht mehr sonoff, sondern tasmota
              GlasfaserG Offline
              GlasfaserG Offline
              @crunchip
              Das war dein Screenshot ... aus einem anderen Beitrag die Tage :) ;) 😀
              Link Text
              • GlasfaserG Glasfaser
                @crunchip
                Link Text
                crunchipC Offline
                crunchipC Offline
                @Glasfaser ich weiss, kam mir sofort bekannt vor😁
                deshalb war die Info dazu, weil der screen meiner Dose mit V6.4.1) (passend beim anderen Beitrag)war,
                hier es sich jedoch um v8.3.1 handelt
                  @2hot4you
                  Kugelkopf
                  @Glasfaser @2hot4you Auch gerne mal die Häkchen wegmachen speichern, Adapter neustarten, Häkchen wieder anklicken, neu starten. Hat bei mir geholfen.
                    Buko
                    schrieb am zuletzt editiert von Buko
                    Bei mir klappen 1-2 s2x nicht keine ahnung alles lief vorher wunderbar !
                    Update gemacht von 8.2 auf 8.3.1 auch keine besserung häcken nmeu gesetzt und und und
                      Buko
                      Fritzbox löst iobroker server name nicht richtig auf muste ie IP angeben
