  4. Error-Meldungen bei Adapter-Updates
errorsupdate
2 Beiträge 2 Kommentatoren 363 Aufrufe 2 Beobachtet
    AndreasK
    Ich bekomme bei Updates von Adaptern immer Errors angezeigt. Das Update läuft durch und es funktioniert eigentlich auch alles.
    Ich habe mal einen Log-Eintrag eines Updates angehängt.
    Iobroker ist auf einem Raspi installiert
    2020-06-14 16:53:10.675 - info: host.iobroker-pi Update repository "latest" under "http://download.iobroker.net/sources-dist-latest.json"
    2020-06-14 16:53:37.752 - info: host.iobroker-pi iobroker upgrade scenes
    2020-06-14 16:53:39.764 - info: host.iobroker-pi iobroker Update scenes from @1.1.0 to @2.0.1
    2020-06-14 16:53:40.354 - info: host.iobroker-pi iobroker NPM version: 6.14.4
    2020-06-14 16:53:40.357 - info: host.iobroker-pi iobroker npm install iobroker.scenes@2.0.1 --loglevel error --prefix "/opt/iobroker" (System call)
    2020-06-14 16:54:08.923 - info: host.iobroker-pi iobroker Package pixman-1 was not found in the pkg-config search path.Perhaps you should add the directory containing `pixman-1.pc'to the PKG_CONFIG_PATH environment variableNo package 'pixman-1' found
    2020-06-14 16:54:08.925 - info: host.iobroker-pi iobroker gyp: Call to 'pkg-config pixman-1 --libs' returned exit status 1 while in binding.gyp. while trying to load binding.gyp
    2020-06-14 16:54:08.945 - info: host.iobroker-pi iobroker gyp
    2020-06-14 16:54:08.949 - info: host.iobroker-pi iobroker ERR! configure error gyp ERR! stack Error: `gyp` failed with exit code: 1gyp ERR! stack at ChildProcess.onCpExit (/usr/lib/node_modules/npm/node_modules/node-gyp/lib/configure.js:351:16)gyp ERR! stack at ChildProcess.emit (events.js:315:20)gyp ERR! stack at Process.ChildProcess._handle.onexit (internal/child_process.js:275:12)gyp ERR! System Linux 4.19.118-v7l+
    2020-06-14 16:54:08.950 - info: host.iobroker-pi iobroker gyp ERR! command "/usr/bin/node" "/usr/lib/node_modules/npm/node_modules/node-gyp/bin/node-gyp.js" "configure" "--fallback-to-build" "--module=/opt/iobroker/node_modules/canvas/build/Release/canvas.node" "--module_name=canvas" "--module_path=/opt/iobroker/node_modules/canvas/build/Release" "--napi_version=6" "--node_abi_napi=napi" "--napi_build_version=0" "--node_napi_label=node-v72"gyp ERR! cwd /opt/iobroker/node_modules/canvasgyp ERR! node -v v12.18.0gyp ERR! node-gyp -v v5.1.0gyp ERR! not ok
    2020-06-14 16:54:08.958 - info: host.iobroker-pi iobroker node-pre-gyp ERR! build error
    2020-06-14 16:54:08.959 - info: host.iobroker-pi iobroker node-pre-gyp
    2020-06-14 16:54:08.960 - info: host.iobroker-pi iobroker ERR! stack Error: Failed to execute '/usr/bin/node /usr/lib/node_modules/npm/node_modules/node-gyp/bin/node-gyp.js configure --fallback-to-build --module=/opt/iobroker/node_modules/canvas/build/Release/canvas.node --module_name=canvas --module_path=/opt/iobroker/node_modules/canvas/build/Release --napi_version=6 --node_abi_napi=napi --napi_build_version=0 --node_napi_label=node-v72' (1)node-pre-gyp ERR! stack at ChildProcess. (/opt/iobroker/node_modules/canvas/node_modules/node-pre-gyp/lib/util/compile.js:83:29)node-pre-gyp ERR! stack at ChildProcess.emit (events.js:315:20)node-pre-gyp ERR! stack at maybeClose (internal/child_process.js:1021:16)node-pre-gyp ERR! stack at Process.ChildProcess._handle.onexit (internal/child_process.js:286:5)
    2020-06-14 16:54:08.962 - info: host.iobroker-pi iobroker node-pre-gyp ERR! System Linux 4.19.118-v7l+node-pre-gyp ERR! command "/usr/bin/node" "/opt/iobroker/node_modules/canvas/node_modules/.bin/node-pre-gyp" "install" "--fallback-to-build"node-pre-gyp ERR! cwd /opt/iobroker/node_modules/canvasnode-pre-gyp ERR! node -v v12.18.0node-pre-gyp ERR! node-pre-gyp -v v0.11.0node-pre-gyp ERR! not ok
    2020-06-14 16:54:08.964 - info: host.iobroker-pi iobroker
    2020-06-14 16:54:14.907 - info: host.iobroker-pi iobroker upload [18] scenes.admin /opt/iobroker/node_modules/iobroker.scenes/admin/tab.html tab.html text/html
    2020-06-14 16:54:14.960 - info: host.iobroker-pi iobroker Update "system.adapter.scenes.0"
    2020-06-14 16:54:14.982 - info: host.iobroker-pi stopInstance system.adapter.scenes.0 (force=false, process=true)
    2020-06-14 16:54:14.985 - info: host.iobroker-pi stopInstance system.adapter.scenes.0 send kill signal
    2020-06-14 16:54:14.988 - info: scenes.0 (13046) Got terminate signal TERMINATE_YOURSELF
    2020-06-14 16:54:15.088 - info: host.iobroker-pi iobroker upload [17] scenes.admin /opt/iobroker/node_modules/iobroker.scenes/admin/style.css style.css text/css
    2020-06-14 16:54:15.157 - info: host.iobroker-pi iobroker upload [16] scenes.admin /opt/iobroker/node_modules/iobroker.scenes/admin/static/js/runtime-main.8cdd9b0f.js.map static/js/runtime-main.8cdd9b0f.js.map application/json
    2020-06-14 16:54:15.220 - info: host.iobroker-pi iobroker upload [15] scenes.admin /opt/iobroker/node_modules/iobroker.scenes/admin/static/js/runtime-main.8cdd9b0f.js static/js/runtime-main.8cdd9b0f.js application/javascript
    2020-06-14 16:54:15.278 - info: host.iobroker-pi iobroker upload [14] scenes.admin /opt/iobroker/node_modules/iobroker.scenes/admin/static/js/main.7e2a3f00.chunk.js.map static/js/main.7e2a3f00.chunk.js.map application/json
    2020-06-14 16:54:15.338 - info: host.iobroker-pi iobroker upload [13] scenes.admin /opt/iobroker/node_modules/iobroker.scenes/admin/static/js/main.7e2a3f00.chunk.js static/js/main.7e2a3f00.chunk.js application/javascript
    2020-06-14 16:54:15.395 - info: host.iobroker-pi iobroker upload [12] scenes.admin /opt/iobroker/node_modules/iobroker.scenes/admin/static/js/2.81b5e61b.chunk.js.map static/js/2.81b5e61b.chunk.js.map application/json
    2020-06-14 16:54:15.506 - info: scenes.0 (13046) terminating
    2020-06-14 16:54:15.508 - info: scenes.0 (13046) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
    2020-06-14 16:54:15.865 - info: host.iobroker-pi Update repository "latest" under "http://download.iobroker.net/sources-dist-latest.json"
    2020-06-14 16:54:15.995 - info: host.iobroker-pi stopInstance system.adapter.scenes.0 killing pid 13046
    2020-06-14 16:54:16.045 - info: host.iobroker-pi instance system.adapter.scenes.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
    2020-06-14 16:54:18.185 - info: host.iobroker-pi instance system.adapter.scenes.0 started with pid 22868
    2020-06-14 16:54:18.278 - info: host.iobroker-pi iobroker upload [11] scenes.admin /opt/iobroker/node_modules/iobroker.scenes/admin/static/js/2.81b5e61b.chunk.js.LICENSE.txt static/js/2.81b5e61b.chunk.js.LICENSE.txt text/plain
    2020-06-14 16:54:18.346 - info: host.iobroker-pi iobroker upload [10] scenes.admin /opt/iobroker/node_modules/iobroker.scenes/admin/static/js/2.81b5e61b.chunk.js static/js/2.81b5e61b.chunk.js application/javascript
    2020-06-14 16:54:18.744 - info: host.iobroker-pi iobroker upload [9] scenes.admin /opt/iobroker/node_modules/iobroker.scenes/admin/static/css/main.d4bed9c6.chunk.css.map static/css/main.d4bed9c6.chunk.css.map application/json
    2020-06-14 16:54:18.805 - info: host.iobroker-pi iobroker upload [8] scenes.admin /opt/iobroker/node_modules/iobroker.scenes/admin/static/css/main.d4bed9c6.chunk.css static/css/main.d4bed9c6.chunk.css text/css
    2020-06-14 16:54:18.868 - info: host.iobroker-pi iobroker upload [7] scenes.admin /opt/iobroker/node_modules/iobroker.scenes/admin/static/css/2.9ba4c952.chunk.css.map static/css/2.9ba4c952.chunk.css.map application/json
    2020-06-14 16:54:18.927 - info: host.iobroker-pi iobroker upload [6] scenes.admin /opt/iobroker/node_modules/iobroker.scenes/admin/static/css/2.9ba4c952.chunk.css static/css/2.9ba4c952.chunk.css text/css
    2020-06-14 16:54:18.987 - info: host.iobroker-pi iobroker upload [5] scenes.admin /opt/iobroker/node_modules/iobroker.scenes/admin/service-worker.js service-worker.js application/javascript
    2020-06-14 16:54:19.046 - info: host.iobroker-pi iobroker upload [4] scenes.admin /opt/iobroker/node_modules/iobroker.scenes/admin/scenes.png scenes.png image/png
    2020-06-14 16:54:19.106 - info: host.iobroker-pi iobroker upload [3] scenes.admin /opt/iobroker/node_modules/iobroker.scenes/admin/precache-manifest.ca572777f78efc82209ab7d733124f20.js precache-manifest.ca572777f78efc82209ab7d733124f20.js application/javascript
    2020-06-14 16:54:19.165 - info: host.iobroker-pi iobroker upload [2] scenes.admin /opt/iobroker/node_modules/iobroker.scenes/admin/manifest.json manifest.json application/json
    2020-06-14 16:54:19.227 - info: host.iobroker-pi iobroker upload [1] scenes.admin /opt/iobroker/node_modules/iobroker.scenes/admin/favicon.ico favicon.ico image/vnd.microsoft.icon
    2020-06-14 16:54:19.290 - info: host.iobroker-pi iobroker upload [0] scenes.admin /opt/iobroker/node_modules/iobroker.scenes/admin/asset-manifest.json asset-manifest.json application/json
    2020-06-14 16:54:19.351 - info: host.iobroker-pi iobroker Adapter "scenes" updated
    2020-06-14 16:54:19.438 - info: scenes.0 (22868) starting. Version 2.0.1 in /opt/iobroker/node_modules/iobroker.scenes, node: v12.18.0, js-controller: 3.1.5
    2020-06-14 16:54:20.364 - info: host.iobroker-pi iobroker exit 0
    Andreas
    • A AndreasK
      Andreas
      @AndreasK sagte in Error-Meldungen bei Adapter-Updates:
      pixman-1
      sudo apt install build-essential libpixman-1-dev libpango1.0-dev libjpeg62-turbo-dev libgif-dev
      cd /opt/iobroker
      npm rebuild canvas --build-from-source
