  4. Falsche repository
Falsche repository
repository
50 Beiträge 4 Kommentatoren 2.7k Aufrufe 2 Beobachtet
    @zgadgeter
    iobroker list instances
    Z Offline
    Z Offline
    zgadgeter
    @Thomas-Braun said in Falsche repository:
    @zgadgeter
    tyrone@Iobroker:~$ iobroker list instances
      system.adapter.admin.0                 : admin                 -  enabled, port: 8081, bind: 0.0.0.0, run as: admin
    + system.adapter.backitup.0              : backitup              -  enabled
      system.adapter.chromecast.0            : chromecast            - disabled
    + system.adapter.chromecast.1            : chromecast            -  enabled
    + system.adapter.cloud.0                 : cloud                 -  enabled
      system.adapter.discovery.0             : discovery             - disabled
    + system.adapter.enigma2.0               : enigma2               -  enabled
    + system.adapter.fhem.0                  : fhem                  -  enabled, port: 7072
      system.adapter.flot.0                  : flot                  -  enabled
    + system.adapter.history.0               : history               -  enabled
    + system.adapter.hm-rega.0               : hm-rega               -  enabled
      system.adapter.hm-rpc.0                : hm-rpc                - disabled, port: 18701
    + system.adapter.hm-rpc.1                : hm-rpc                -  enabled, port: 0
      system.adapter.homeconnect.0           : homeconnect           - disabled
      system.adapter.icons-icons8.0          : icons-icons8          -  enabled
      system.adapter.icons-open-icon-library-png.0: icons-open-icon-library-png -  enabled
      system.adapter.info.0                  : info                  - disabled
    + system.adapter.javascript.0            : javascript            -  enabled
    + system.adapter.lgtv11.0                : lgtv11                -  enabled, port: 8080
      system.adapter.luftdaten.0             : luftdaten             - disabled
    + system.adapter.meross.0                : meross                -  enabled
    + system.adapter.onvif.0                 : onvif                 -  enabled
    + system.adapter.ping.0                  : ping                  -  enabled
    + system.adapter.proxmox.0               : proxmox               -  enabled, port: 8006
    + system.adapter.scenes.0                : scenes                -  enabled
    + system.adapter.shuttercontrol.0        : shuttercontrol        -  enabled
    + system.adapter.simple-api.0            : simple-api            -  enabled, port: 8087, bind: 0.0.0.0, run as: admin
    + system.adapter.sonoff.0                : sonoff                -  enabled, port: 1883, bind: 192.168.178.11
      system.adapter.spotify-premium.0       : spotify-premium       - disabled
    + system.adapter.telegram.0              : telegram              -  enabled, port: 8443, bind: 0.0.0.0
    + system.adapter.text2command.0          : text2command          -  enabled
      system.adapter.vis-bars.0              : vis-bars              -  enabled
      system.adapter.vis-canvas-gauges.0     : vis-canvas-gauges     -  enabled
      system.adapter.vis-colorpicker.0       : vis-colorpicker       -  enabled
      system.adapter.vis-fancyswitch.0       : vis-fancyswitch       -  enabled
      system.adapter.vis-hqwidgets.0         : vis-hqwidgets         -  enabled
      system.adapter.vis-jqui-mfd.0          : vis-jqui-mfd          -  enabled
      system.adapter.vis.0                   : vis                   -  enabled
    + system.adapter.web.0                   : web                   -  enabled, port: 8082, bind: 0.0.0.0, run as: admin
    + system.adapter.zigbee.0                : zigbee                -  enabled, port: /dev/ttyACM0
    + instance is alive
    • Z zgadgeter
      @zgadgeter
      + instance is alive
      @zgadgeter
      iobroker version
      which nodejs && nodejs -v && which node && node -v && which npm && npm -v
      Z 1 Antwort Letzte Antwort
        @zgadgeter
        iobroker version
        Z Offline
        Z Offline
        zgadgeter
        @zgadgeter
        iobroker version
        iobroker version:
        tyrone@Iobroker:~$ iobroker version
        3.1.4
        tyrone@Iobroker:~$ which nodejs && nodejs -v && which node && node -v && which npm && npm -v
        /usr/bin/nodejs
        v10.20.1
        /usr/bin/node
        v10.20.1
        /usr/bin/npm
        6.14.4
        • Z zgadgeter
          @zgadgeter
          iobroker version
          iobroker version:
          3.1.4
          /usr/bin/nodejs
          v10.20.1
          /usr/bin/node
          v10.20.1
          /usr/bin/npm
          6.14.4
          @zgadgeter
          sudo netstat -tulpen
            @zgadgeter
            Z Offline
            Z Offline
            zgadgeter
            @zgadgeter
            den command findet er nicht, muss ich das vorher installieren?
            tyrone@Iobroker:~$ sudo netstat -tulpen
            sudo: netstat: Befehl nicht gefunden
            • Z zgadgeter
              @zgadgeter
              Z Offline
              Z Offline
              zgadgeter
              @zgadgeter said in Falsche repository:
              @zgadgeter
              Ok, habe netstat installiert und laufen lassen:
              Aktive Internetverbindungen (Nur Server)
              Proto Recv-Q Send-Q Local Address           Foreign Address         State       Benutzer   Inode      PID/Program name
              tcp        0      0 192.168.178.11:1883     0.0.0.0:*               LISTEN      1001       80369      8557/io.sonoff.0
              tcp        0      0 127.0.0.1:9000          0.0.0.0:*               LISTEN      1001       78387      8350/iobroker.js-co
              tcp        0      0 127.0.0.1:9001          0.0.0.0:*               LISTEN      1001       79747      8350/iobroker.js-co
              tcp        0      0 192.168.178.11:2001     0.0.0.0:*               LISTEN      1001       80009      8453/io.hm-rpc.1
              tcp        0      0 0.0.0.0:22              0.0.0.0:*               LISTEN      0          13790      393/sshd
              tcp6       0      0 :::8082                 :::*                    LISTEN      1001       79926      8427/io.web.0
              tcp6       0      0 :::22                   :::*                    LISTEN      0          13801      393/sshd
              tcp6       0      0 :::8087                 :::*                    LISTEN      1001       81577      8732/io.simple-api.
              udp        0      0 0.0.0.0:5353            0.0.0.0:*                           1001       80804      8766/io.chromecast.
              udp        0      0 0.0.0.0:68              0.0.0.0:*                           0          12182      331/dhclient
              • Z zgadgeter
                @zgadgeter
                @zgadgeter
                iobroker fix
                Dann starte die Kiste mal neu.
                  @zgadgeter
                  iobroker fix
                  Z Offline
                  Z Offline
                  zgadgeter
                  @zgadgeter
                  iobroker fix
                  habe das gemacht, die VM neu gestartet, VIS funktioniert nach wie vor, aber komme immer noch nicht auf die Weboberflaeche....haettest Du noch eine Idee?
                  danke nochmals.
                  • Z zgadgeter
                    @zgadgeter
                    iobroker fix
                    danke nochmals.
                    @zgadgeter
                    iobroker rebuild admin
                      @zgadgeter
                      Z Offline
                      Z Offline
                      zgadgeter
                      @zgadgeter
                      Funktioniert nicht, Oberflaeche nicht erreichbar.
                      tyrone@Iobroker:~$ iobroker stop
                      tyrone@Iobroker:~$ iobroker rebuild admin
                      npm rebuild --loglevel error (System call) in "/opt/iobroker/node_modules/iobroker.admin"
                      Rebuild admin done
                      tyrone@Iobroker:~$ iobroker start
                      • Z zgadgeter
                        @zgadgeter
                        Rebuild admin done
                        @zgadgeter Dann weiß ich auch nicht.
                        • Z zgadgeter
                          @zgadgeter
                          Rebuild admin done
                          @zgadgeter
                          zweite Instanz und mal testen
                          iobroker add admin --port 8099
                          https://www.iobroker.net/#de/documentation/trouble/RunsNoMore.md
                            @zgadgeter
                            Z Offline
                            Z Offline
                            zgadgeter
                            @Homoran said in Falsche repository:
                            habe das gemacht, aber komme nirgends auf die Oberflaeche:
                            tyrone@Iobroker:~$ iobroker add admin --port 8099
                            host.Iobroker create instance admin
                            host.Iobroker object admin.1.connected created
                            host.Iobroker object admin.1 created
                            host.Iobroker object admin.1.info created
                            host.Iobroker object system.adapter.admin.upload created
                            host.Iobroker object system.adapter.admin.1.sigKill created
                            host.Iobroker object system.adapter.admin.1.eventLoopLag created
                            host.Iobroker object system.adapter.admin.1.outputCount created
                            host.Iobroker object system.adapter.admin.1.inputCount created
                            host.Iobroker object system.adapter.admin.1.uptime created
                            host.Iobroker object system.adapter.admin.1.memRss created
                            host.Iobroker object system.adapter.admin.1.memHeapTotal created
                            host.Iobroker object system.adapter.admin.1.memHeapUsed created
                            host.Iobroker object system.adapter.admin.1.cputime created
                            host.Iobroker object system.adapter.admin.1.cpu created
                            host.Iobroker object system.adapter.admin.1.compactMode created
                            host.Iobroker object system.adapter.admin.1.connected created
                            host.Iobroker object system.adapter.admin.1.alive created
                            host.Iobroker object system.adapter.admin.1 created
                            tyrone@Iobroker:~$
                            • Z zgadgeter
                              tyrone@Iobroker:~$
                              @zgadgeter
                              http://ip_des_hosts:8099
                                @zgadgeter
                                Z Offline
                                Z Offline
                                zgadgeter
                                @zgadgeter
                                ja, genau das habe ich probiert...kommt aber nichts.
                                • Z zgadgeter
                                  @zgadgeter
                                  @zgadgeter
                                    @zgadgeter
                                    Z Offline
                                    Z Offline
                                    zgadgeter
                                    schrieb am zuletzt editiert von zgadgeter
                                    @zgadgeter
                                      system.adapter.admin.1                 : admin                 -  enabled, port: 8099, bind: 0.0.0.0, run as: admin
                                    + instance is alive
                                    • Z zgadgeter
                                      @zgadgeter
                                      + instance is alive
                                      @zgadgeter leider abgeschnitten :-(
                                      • Z zgadgeter
                                        @zgadgeter
                                        + instance is alive
                                        @zgadgeter Auch wenn ich da keine Hoffnung habe würde ich den gesamten admin löschen und neu installieren:
                                        iobroker del admin
                                        und dann
                                        iobroker add admin
                                          @zgadgeter
                                          Mal mal ein zweites Terminal auf:
                                          tail -f /opt/iobroker/log/iobroker.current.log
                                          Und dann schaust du, was da passiert, wenn im anderen Terminal der iobroker gestartet wird:
                                          iobroker restart
