  4. Adapter Update probleme
adapter update probleme
33 Beiträge 2 Kommentatoren 3.2k Aufrufe 2 Beobachtet
    Motsche1
    pi@haussteuerung:~$ sudo apt install node-gyp
    Reading package lists... Done
    Building dependency tree
    Some packages could not be installed. This may mean that you have
    requested an impossible situation or if you are using the unstable
    distribution that some required packages have not yet been created
    or been moved out of Incoming.
    The following information may help to resolve the situation:
    The following packages have unmet dependencies:
     node-gyp : Depends: libnode-dev but it is not going to be installed
    E: Unable to correct problems, you have held broken packages.
    • M Motsche1
      @Motsche1 Hatte ich gesagt, dass du das installieren sollst?
      Tu doch bitte was dir gesagt wird und mach keinen Kram nebenher.
        Motsche1
        pi@haussteuerung:~$ cd /home/iobroker
        pi@haussteuerung:/home/iobroker$ lsb_release -a
        No LSB modules are available.
        Distributor ID: Debian
        Description:    Debian GNU/Linux 10 (buster)
        Release:        10
        Codename:       buster
        pi@haussteuerung:/home/iobroker$ nodejs -v && node -v && npm -v
        v12.16.3
        v12.16.3
        6.14.4
        pi@haussteuerung:/home/iobroker$ which nodejs && which node && which npm
        /usr/bin/nodejs
        /usr/bin/node
        /usr/bin/npm
        • M Motsche1
          Release:        10
          Codename:       buster
          v12.16.3
          v12.16.3
          6.14.4
          /usr/bin/nodejs
          /usr/bin/node
          /usr/bin/npm
          @Motsche1
          sudo apt update
          apt policy nodejs
          sudo apt install nodejs --reinstall
            Motsche1
            brauchst da auch die ausgaben?
            • M Motsche1
              @Motsche1 Nee, ich habe 'ne Glaskugel... :-D
                Motsche1
                Ach ECHT 😳
                • M Motsche1
                  Ach ECHT 😳
                  @Motsche1 Ja, die ist allerdings gerade in der Spülmaschine. Musste halt doch die Ausgaben hier posten.
                    Motsche1
                    pi@haussteuerung:/home/iobroker$ sudo apt update
                    [sudo] password for pi:
                    Get:1 file:/var/cache/openmediavault/archives  InRelease
                    Ign:1 file:/var/cache/openmediavault/archives  InRelease
                    Get:2 file:/var/cache/openmediavault/archives  Release
                    Ign:2 file:/var/cache/openmediavault/archives  Release
                    Get:3 file:/var/cache/openmediavault/archives  Packages
                    Ign:3 file:/var/cache/openmediavault/archives  Packages
                    Get:4 file:/var/cache/openmediavault/archives  Contents (deb)
                    Ign:4 file:/var/cache/openmediavault/archives  Contents (deb)
                    Get:5 file:/var/cache/openmediavault/archives  Contents (deb)
                    Ign:5 file:/var/cache/openmediavault/archives  Contents (deb)
                    Get:6 file:/var/cache/openmediavault/archives  Contents (deb)
                    Ign:6 file:/var/cache/openmediavault/archives  Contents (deb)
                    Hit:7 http://security.debian.org buster/updates InRelease
                    Hit:8 http://httpredir.debian.org/debian buster InRelease
                    Hit:9 http://packages.openmediavault.org/public usul InRelease
                    Hit:10 http://linux.teamviewer.com/deb stable InRelease
                    Hit:11 http://download.virtualbox.org/virtualbox/debian buster InRelease
                    Hit:12 http://packages.openmediavault.org/public usul-proposed InRelease
                    Get:13 http://httpredir.debian.org/debian buster-updates InRelease [49.3 kB]
                    Hit:14 https://download.docker.com/linux/debian buster InRelease
                    Hit:16 https://openmediavault.github.io/packages usul InRelease
                    Get:17 http://httpredir.debian.org/debian buster-backports InRelease [46.7 kB]
                    Hit:18 https://deb.nodesource.com/node_12.x buster InRelease
                    Ign:19 https://dl.bintray.com/openmediavault-plugin-developers/usul buster InRelease
                    Ign:20 https://dl.bintray.com/openmediavault-plugin-developers/usul-testing buster InRelease
                    Ign:21 https://dl.bintray.com/openmediavault-plugin-developers/usul-extras buster InRelease
                    Get:22 https://dl.bintray.com/openmediavault-plugin-developers/usul buster Release [4363 B]
                    Get:23 https://dl.bintray.com/openmediavault-plugin-developers/usul-testing buster Release [3538 B]
                    Get:24 https://dl.bintray.com/openmediavault-plugin-developers/usul-extras buster Release [3538 B]
                    Hit:15 https://apt.armbian.com buster InRelease
                    Get:25 http://httpredir.debian.org/debian buster-backports/main arm64 Packages.diff/Index [27.8 kB]
                    Get:26 http://httpredir.debian.org/debian buster-backports/main armhf Packages.diff/Index [27.8 kB]
                    Get:27 http://httpredir.debian.org/debian buster-backports/main armhf Contents (deb).diff/Index [27.9 kB]
                    Get:28 http://httpredir.debian.org/debian buster-backports/main arm64 Contents (deb).diff/Index [27.9 kB]
                    Get:29 http://httpredir.debian.org/debian buster-backports/main arm64 Packages 2020-05-22-1409.45.pdiff [390 B]
                    Get:30 http://httpredir.debian.org/debian buster-backports/main armhf Packages 2020-05-22-1409.45.pdiff [394 B]
                    Get:31 http://httpredir.debian.org/debian buster-backports/main armhf Contents (deb) 2020-05-22-1409.45.pdiff [101 B]
                    Get:32 http://httpredir.debian.org/debian buster-backports/main arm64 Contents (deb) 2020-05-22-1409.45.pdiff [100 B]
                    Fetched 220 kB in 7s (30.7 kB/s)
                    All packages are up to date.
                    N: Skipping acquire of configured file 'main/binary-arm64/Packages' as repository 'http://linux.teamviewer.com/deb stable InRelease' doesn't support architecture 'arm64'
                    N: Skipping acquire of configured file 'contrib/binary-armhf/Packages' as repository 'http://download.virtualbox.org/virtualbox/debian buster InRelease' doesn't support architecture 'armhf'
                    N: Skipping acquire of configured file 'contrib/binary-arm64/Packages' as repository 'http://download.virtualbox.org/virtualbox/debian buster InRelease' doesn't support architecture 'arm64'
                    pi@haussteuerung:/home/iobroker$ apt policy nodejs
                    nodejs:
                      Installed: 12.16.3-1nodesource1
                      Candidate: 12.16.3-1nodesource1
                      Version table:
                     *** 12.16.3-1nodesource1 500
                            500 https://deb.nodesource.com/node_12.x buster/main arm64 Packages
                            100 /var/lib/dpkg/status
                         10.19.0~dfsg1-1 500
                            500 http://httpredir.debian.org/debian buster/main arm64 Packages
                            500 http://security.debian.org buster/updates/main arm64 Packages
                    pi@haussteuerung:/home/iobroker$ sudo apt install nodejs --reinstall
                    0 upgraded, 0 newly installed, 1 reinstalled, 0 to remove and 0 not upgraded.
                    Need to get 0 B/17.2 MB of archives.
                    After this operation, 0 B of additional disk space will be used.
                    (Reading database ... 74383 files and directories currently installed.)
                    Preparing to unpack .../nodejs_12.16.3-1nodesource1_arm64.deb ...
                    Detected old npm client, removing...
                    Unpacking nodejs (12.16.3-1nodesource1) over (12.16.3-1nodesource1) ...
                    Setting up nodejs (12.16.3-1nodesource1) ...
                    Processing triggers for man-db (2.8.5-2) ...
                    • M Motsche1
                      nodejs:
                        Version table:
                           10.19.0~dfsg1-1 500
                      @Motsche1
                      Bei der Gemischtwarenladen an Repos bin ich raus. Das kannste nicht mehr warten.
                      Da spukt auch noch irgendein Kram von armbian drin rum, das passt aber ganz garantiert nicht zu deinem Raspberry. Ist doch ein Pi, oder?
                        Motsche1
                        ist ja auch keiner . ist ein Rockpro64
                        • M Motsche1
                          @Motsche1
                          Gut, mit ist da trotzdem zu viel 'dubioses' Zeug drin.
                            Motsche1
                            so ein backup kann man doch egal wo draufspielen oder ? frag nur weil vieleicht mach ich alles auf nen raspi
