  4. Problem mit LetsEncrypt
sslletsencrypt
34 Beiträge 11 Kommentatoren 4.9k Aufrufe 11 Beobachtet
    SwApy
    schrieb am zuletzt editiert von SwApy
    Ich bin recht neu im Thema Smart Home/Iobroker und habe aktuell das Problem kein zertifikat von LetsEncrypt über den Admin adapter zu bekommen.
    admin.0 2020-05-08 19:07:11.866 error (1461) Cannot get certificates: TypeError: invalid options argument
    admin.0 2020-05-08 19:07:06.647 info (1461) accountId:
    admin.0 2020-05-08 19:07:06.603 info (1461) checkAsync failed to find certificates
    admin.0 2020-05-08 19:07:06.564 info (1461) gl getting from disk or registering new
    admin.0 2020-05-08 19:07:06.562 info (1461) [object Object]
    admin.0 2020-05-08 19:07:06.560 info (1461) gl.approveDomains called with certs forNONEand options:
    admin.0 2020-05-08 19:07:06.554 info (1461) gl.getCertificates called for******************.myfritz.netwith certs for
    admin.0 2020-05-08 19:07:01.283 info (1461) Use link "https://localhost:8081" to configure.
    admin.0 2020-05-08 19:07:01.282 info (1461) https server listening on port 8081
    admin.0 2020-05-08 19:07:01.278 info (1461) LetsEncrypt challenge server is started on 81
    admin.0 2020-05-08 19:07:01.210 info (1461) created middleware
    admin.0 2020-05-08 19:07:00.944 info (1461) received all objects
    admin.0 2020-05-08 19:06:59.692 info (1461) requesting all objects
    admin.0 2020-05-08 19:06:59.690 info (1461) requesting all states
    admin.0 2020-05-08 19:06:59.606 info (1461) starting. Version 4.1.1 in /opt/iobroker/node_modules/iobroker.admin, node: v12.16.3, js-controller: 3.0.20
    Nach mehrfachen testen kommt natürlich die Sperre >.<
    admin.0 2020-05-08 19:56:10.665 error {"termsOfServiceAgreed":true,"onlyReturnExisting":false,"contact":["mailto:@web.de"]}
    admin.0 2020-05-08 19:56:10.665 error (609) Cannot get certificates: Error: account error: 429 {"type":"urn:ietf:params:acme:error:rateLimited","detail":"Error creating new account :: too many registrations for this IP: see https://letse
    admin.0 2020-05-08 19:56:07.834 info (609) accountId:
    admin.0 2020-05-08 19:56:07.806 info (609) checkAsync failed to find certificates
    admin.0 2020-05-08 19:56:07.769 info (609) gl getting from disk or registering new
    admin.0 2020-05-08 19:56:07.768 info (609) [object Object]
    admin.0 2020-05-08 19:56:07.767 info (609) gl.approveDomains called with certs forNONEand options:
    admin.0 2020-05-08 19:56:07.763 info (609) gl.getCertificates called for
    admin.0 2020-05-08 19:56:06.554 info (609) Use link "https://localhost:8081" to configure.
    admin.0 2020-05-08 19:56:06.553 info (609) https server listening on port 8081
    admin.0 2020-05-08 19:56:06.549 info (609) LetsEncrypt challenge server is started on 81
    admin.0 2020-05-08 19:56:06.470 info (609) created middleware
    admin.0 2020-05-08 19:56:05.995 info (609) received all objects
    admin.0 2020-05-08 19:56:04.568 info (609) requesting all objects
    admin.0 2020-05-08 19:56:04.566 info (609) requesting all states
    admin.0 2020-05-08 19:56:03.924 info (609) starting. Version 4.1.1 in /opt/iobroker/node_modules/iobroker.admin, node: v12.16.3, js-controller: 3.0.20
    und ja die benötigten Ports sind offen denke ich 🤔
    folgende Ports sind offen:
    80, 81, 443, 8081
    wendy2702W S 2 Antworten Letzte Antwort
    • S SwApy
      80, 81, 443, 8081
      wendy2702W Online
      wendy2702W Online
      wendy2702
      @SwApy sagte in Problem mit LetsEncrypt:
      Denkst oder weißt du bzw. Bist dir sicher?
        SwApy
        die ports sind offen habe den beitrag kurz angepasst ...
        80, 81, 443, 8081
          SwApy
          keiner eine idee?
          • J Offline
            jumpmaster
            Ich habe das gleiche Problem, gibt es iwie eine Lösung?
            • G Offline
              g.pitzer
              Konntet Ihr es schon lösen? Ich habe das gleiche Problem :(
              • apollon77A Online
                apollon77A Online
                Let's encrypt ist im Moment nicht unterstützt, da die API die genutzt wurde nicht mehr verfügbar ist. Wir kamen noch nicht dazu es anzupassen
                M W 2 Antworten Letzte Antwort
                • apollon77A apollon77
                  mkohler
                  @apollon77
                  Hallo Apollon77
                  Ich kämpfe auch mit LetsEncrypt und habe mein System mittlerweile so "verbastelt" bei dem Versuch LetsEncrypt zu aktivieren, dass ich nun parallel eine Neuinstallation mache. Dabei bin ich auf diesen Forumsbeitrag gestossen.
                  Wenn die API in ioBroker nicht mehr funktioniert, gibt es eine Möglichkeit, dass die Zertifikate nicht durch ioBroker abgerufen werden, "Extern" von ioBroker?
                  Besten Dank für Deine Tipps
                  Mike
                  • M mkohler
                    @apollon77
                    Hallo Apollon77
                    Mike
                    apollon77A Online
                    apollon77A Online
                    @mkohler Naja du kannst Sie manuell in die Konfig via Admin eintragen ...
                      mkohler
                      @apollon77 Danke für Deine schnelle Antwort. Damit ich ein Zertifikat erhalte (von LetsEncrypt) muss ich dies irgendwie anstossen. Bei meinen Versuchen mit dem alten System habe ich cerbot installiert. Aber irgendwie wollte es nicht so richtig klappen. Deshalb der Versuch auf einen "jungfräulichen" System. Währe der Ansatz richtig?
                      • M mkohler
                        apollon77A Online
                        apollon77A Online
                        @mkohler Da kann ich wenig helfen, sorry. Ich kenne mich mit lets-encrypt auf "plain system" nicht aus. Wenn Du die Zertifikat-Files hast dann kann man schauen wie Du Sie rein bekommst
                          mkohler
                          schrieb am zuletzt editiert von mkohler
                          @apollon77 So ich habe auf dem neuen System den Cerbot installiert und die Zertifikate sind da:
                          Kann im ioBroker bei den Zertifikaten der Pfad angegeben werden (Habe ich die Tage irgendwo gelesen/gesehen)?
                          Der Order "Live" und die Unterordner in denen die Zertifikate sind haben Root Rechte. Kann der ioBroker überhaupt auf die *.pem Dateien zugreifen?
                          Welche Datei ist für welches Zertifikat?
                          Besten Dank
                          • M mkohler
                            Besten Dank
                            apollon77A Online
                            apollon77A Online
                            @mkohler Ja du kannst im Admin unter den EInstellungen (schraubenschlüssel im Admin) auch die zertifikate editieren. Da kannst du entweder das Zert reinpasten ODER den absoluten Pfad reinshcreiben.
                              mkohler
                              @apollon77 Wenn ich die Pfade eintrage (beim Schraubenschlüssel/Zertifikate) z.B. /etc/letsencrypt/live/Domaine.com/cert.pem für das Öffentliches Zertifikat und dementsprechend auch für das Private und das Verkettete und diese Zertifikate im Web Adapter auswähle, startet dieser nachher nicht mehr.
                              code_text
                              ```host.ioBroker-II	2020-10-05 23:34:42.162	info	Do not restart adapter system.adapter.web.0 because desired by instance
                              host.ioBroker-II	2020-10-05 23:34:42.161	error	instance system.adapter.web.0 terminated by request of the instance itself and will not be restarted, before user restarts it.
                              web.0	2020-10-05 23:34:41.610	info	(25678) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
                              web.0	2020-10-05 23:34:41.607	error	(25678) Cannot create webserver
                              web.0	2020-10-05 23:34:41.605	error	(25678) HTTPS server could not be started: Error: error:0909006C:PEM routines:get_name:no start line
                              web.0	2020-10-05 23:34:41.358	info	(25678) starting. Version 3.0.12 in /opt/iobroker/node_modules/iobroker.web, node: v12.18.4, js-controller: 3.1.6
                              host.ioBroker-II	2020-10-05 23:34:39.644	info	instance system.adapter.web.0 started with pid 25678```
                              code_text
                              Wenn ich jedoch die Inhalte der drei *.pem Dateien reinkopiere funktioniert es. Dies bedingt natürlich alle paar Wochen die Zertifikate manuell anzupassen.
                              Woran kann es liegen, dass die Zertifikate mit der Pfadangabe nicht funktionieren? Liegt es daran, dass der Speicherort (ab Verzeichnis "Live") Root Recht besitzt?
                              • M mkohler
                                code_text
                                code_text
                                apollon77A Online
                                apollon77A Online
                                @mkohler ABer lesen darf auch der iobroker user?? Wenn nicht dann musst Du ihm schon lesen erlauben
                                  mkohler
                                  @apollon77 Ich denke genau da liegt der Fehler.
                                  Ich möchte meine Installation nicht durch Fehlerhafte Berechtigung unsicher machen und erlaube mir Dir die verzeichnisrechte anzugeben. Kannst Du mir bitte helfen bei der richtigen Rechte Vergabe:
                                  • M mkohler
                                    apollon77A Online
                                    apollon77A Online
                                    @mkohler DIe Rechte der Links sind jetzt hier nicht so relevant ... die Rechte der Link-Ziele aber :-)
                                    Wie sind die denn?
                                      Wie sind die denn?
                                      mkohler
                                      @apollon77 Da sehen die Rechte schon anders aus
                                      • M mkohler
                                        apollon77A Online
                                        apollon77A Online
                                        @mkohler ausser privkey1 sind alle ok ... aber der letzte ist nicht lesbar für iobroker user
                                          W Offline
                                          W Offline
                                          WernerS
                                          @apollon77
                                          Hallo apollon77
                                          ist ungefähr absehbar wann das wieder geht. Ich will jetzt nicht extra apache und certbot installieren und riskieren das ich mein System vermurkse.
                                          Werner
