  4. [Vorlage] MDCSS v2: ical Kalendar anzeigen
    5.1k
vismaterial uimaterial css
56 Beiträge 15 Kommentatoren 11.2k Aufrufe 20 Beobachtet
  • Holger EtzelH Online
    Holger Etzel
    schrieb am zuletzt editiert von Holger Etzel
    #41
    bekomme beim starten des Scripts folgende Meldung:
    14:54:45.933 warn javascript.0 (22584) at MduiShowIcal.getState (script.js.Allgemein.Kalenderansicht:187:16)
    14:54:45.934 warn javascript.0 (22584) at MduiShowIcal.onBuildHTML (script.js.Allgemein.Kalenderansicht:608:73)
    14:54:45.934 warn javascript.0 (22584) at MduiShowIcal.doStart (script.js.Allgemein.Kalenderansicht:366:14)
    14:54:45.935 warn javascript.0 (22584) at MduiShowIcal.start (script.js.Allgemein.Kalenderansicht:112:26)
    14:54:45.936 warn javascript.0 (22584) at script.js.Allgemein.Kalenderansicht:724:18
    14:54:46.027 info javascript.0 (22584) script.js.Allgemein.Kalenderansicht: [mduiShowIcal] script started
    14:54:46.027 info javascript.0 (22584) script.js.Allgemein.Kalenderansicht: registered 3 subscriptions and 0 schedules
    und im log:
    javascript.0 2020-07-19 15:00:08.698 warn (22584) at process.topLevelDomainCallback (domain.js:126:23)
    javascript.0 2020-07-19 15:00:08.697 warn (22584) at processImmediate (timers.js:658:5)
    javascript.0 2020-07-19 15:00:08.696 warn (22584) at tryOnImmediate (timers.js:676:5)
    javascript.0 2020-07-19 15:00:08.696 warn (22584) at runCallback (timers.js:705:18)
    javascript.0 2020-07-19 15:00:08.695 warn (22584) at Immediate.setImmediate (/opt/iobroker/node_modules/iobroker.js-controller/lib/adapter.js:5384:37)
    javascript.0 2020-07-19 15:00:08.695 warn (22584) at Object.stateChange (/opt/iobroker/node_modules/iobroker.javascript/main.js:451:25)
    javascript.0 2020-07-19 15:00:08.694 warn (22584) at Object.callback (/opt/iobroker/node_modules/iobroker.javascript/lib/sandbox.js:1052:38)
    javascript.0 2020-07-19 15:00:08.694 warn (22584) at Object.subscribe.obj (script.js.Allgemein.Kalenderansicht:364:60)
    javascript.0 2020-07-19 15:00:08.694 warn (22584) at MduiShowIcal.onIcalTable (script.js.Allgemein.Kalenderansicht:391:12)
    javascript.0 2020-07-19 15:00:08.693 warn (22584) at MduiShowIcal.onBuildHTML (script.js.Allgemein.Kalenderansicht:608:73)
    javascript.0 2020-07-19 15:00:08.693 warn (22584) at MduiShowIcal.getState (script.js.Allgemein.Kalenderansicht:187:16)
    javascript.0 2020-07-19 15:00:08.690 warn (22584) getState "0_userdata.0.mdui.showIcal.log0.filter" not found (3)
    Habe ich noch was vergessen einzustellen?
    Nach stundenlanger Wartezeit geht es auf einmal.
    Gruß Holger
    E 1 Antwort Letzte Antwort
    • Holger EtzelH Holger Etzel
      und im log:
      Gruß Holger
      Ente
      #42
      @sigi234
      Hallo siggi234,
      danke für den Install-Screenshot. ;-)
      • E Ente
        @sigi234
        Hallo siggi234,
        sigi234S Online
        sigi234S Online
        sigi234
        #43
        @Ente sagte in [Vorlage] MDCSS v2: ical Kalendar anzeigen:
        @sigi234
        Hallo siggi234,
        *** MduiShowIcal
        Dieses Script überwacht den ical-Adapter und erzeugt bei Änderungen an dessen States HTML-List States für die Anzeige als
        Kalender in Listform mit
        * Tagesauflösung von "von/bis"-Terminen, inkl. Berücksichtigung der Uhrzeiten
        * Tagesdatum, Kalendarfarben aus ical oder optional aus dem Script
        * Termintext und -ort
        * optionalem Icon je Kalendar
        * optionalem "ignore", wenn ein Kalendar unberücksichtigt bleiben soll
        Es werden States für n-Logs erzeugt, jedem, Log kann ein Standardfilter mitgegeben werden. In jedem Log-Ordner
        befindet sich ein list-HTML State, welcher direkt in der vis angezeigt werden kann (jeweils im basic-string (unescaped) Widget).
        Über optionale Filter als string (Bsp:':Abfall:') oder als RegExp (Bsp:'/Feiertag|Geburtstag/') kann festgelegt werden,
        welche Einträge beim Aufbau der list-HTML States berücksichtigt werden.
        Bsp.:
        log0 Filter: "abfall" oder ":Abfall:" (=Kalendarname) -> Zeigt nur Abfalltermine
        log0 Filter: "ferien" oder ":Ferien:" (=Kalendarname) -> Zeigt nur Ferientermine
        **** Installation
        Einfach als serverseitiges Script installieren und starten-5 Sek warten-stoppen-starten. Beim 1.Start werden
        die notwendigen States unter STATE_PATH = '0_userdata.0.mdui.showIcal.' erzeugt. Erst beim 2.Start
        instanziiert das Script die Event-Handler und läuft dann.
        **** Konfiguration
        Eigentlich ist keine notwendig.
        Optional in der Funktion MduiShowIcal|doInit() eine Anpassung der KONFIGURATION vornehmen
        Optional Anpassung der tmpList.
        **** Dokumentation
        https://github.com/Uhula/ioBroker-Material-Design-Style/wiki/3.5-MduiShowIcal
        ###### Um ein Feedback zu erhalten wäre es schön, wenn jeder, der diese Vorlagen nutzt, den  1.Beitrag des Themas positiv bewertet (Pfeil nach oben oder unten ;-) ). Ich kann dann auch abschätzen, ob sich die weitere Pflege lohnt. Thx!
        ***** States
        Unter dem STATE_PATH werden die folgenden States erzeugt:
        version : Script-Version, wird verwendet um Script-Updates zu erkennen
        updatePressed : auf true setzen, wenn ein table/list update außerhalb des Intervals erfolgen soll
        Weiterhin werden MAX_LOG_FOLDER Unterordner im STATE_PATH erzeugt (N=0-9):
        * LogN.table        : enthält die table-HTML für ein basic-string (unescaped) Widget
        * LogN.list         : enthält die list-HTML für ein basic-string (unescaped) Widget
        * LogN.count        : Anzahl der Log-Zeilen (wenn das Log mit '/:error:|:warn:/' gefiltert ist, dann ist es die Anzahl der Fehler/Warnungen)
        * LogN.filter       : Filter, der auch die logCache angewendet wurde im .table/.list zu erzeugen (siehe Filter)
        * LogN.lastUpdate   : Timestamp des letzten Updates
        ***** Filter
        In den filter-States können sowohl strings (Bsp:'error') als auch RegExp-Strings (Bsp:'/warn|error/')
        hinterlegt werden. RegExp-Strings werden an den einschließenden  '/' erkannt. Über den ':' kann der Anfang
        eines Feldes mit in den Filter einbezogen werden.
        Beispiele:
        '/Feiertag|Geburtstag/' (RegExp) zeigt alle Zeilen an, in denen 'Feiertag' oder 'Geburtstag' in irgendeinem Feld vorkommen
        ':Abfall:' (string) zeigt alle Zeilen an, welche derKalendar 'Abfall' lautet
        'Arzt' (string) zeigt alle Zeilen an, in denen 'Arzt' in irgendeinem Feld vorkommt
        **** Lizenz
        (c) 2020 by UH, MIT License, no warranty, use on your own risc
        *** Changelog
        2020.05.01 UH
        * Anpassung an neues MduiBase (intern)
        * Anpassung an MDCSS 2.5
        * Serientermine vor dem aktuellem Datum werden nicht mehr angezeigt
        // MduiBase
        class MduiBase {
            constructor() {
              this.init();
            init() {
                // const
                this.DEBUG      = false;
                this.VERSION    = '1.0/2020-01-01';
                this.NAME       = 'mduiBase';
                this.STATE_PATH = '0_userdata.0.mdui.base.';
                this.STATE_UNKNOWN    =  0;
                this.STATE_INSTALLING = 10;
                this.STATE_INSTALLED  = 11;
                this.STATE_STARTING   = 20;
                this.STATE_STARTED    = 21;
                this.STATE_STOPPING   = 30;
                this.STATE_STOPPED    = 31;
                // var
                this.state = this.STATE_UNKNOWN;
                this.states = [];
                this.subscribers = [];
                this.schedulers = [];
                this.doInit();
                // init der states
                this.states.push( { id:'version',     common:{name:'installed script-version', write:false, def:this.VERSION} } );
            // start the script/class
            start() {
                // beim 1.Start nur die States erzeugen
                if ( !this.existState("version") || (this.getState('version').val!=this.VERSION) ) {
                    for (let s=0; s<this.states.length; s++) { this.createState( this.states[s].id ); }
                    this.logWarn('first script start, creating states for version '+this.VERSION+', automatic restarting script again in 10 sec ...');
                    setStateDelayed(this.STATE_PATH + 'version', this.VERSION, 3000);
                    setTimeout( this.start.bind(this), 10000 );
                    this.state = this.STATE_INSTALLED;
                    return;
                switch (this.state) {
                    case this.STATE_UNKNOWN : ;
                    case this.STATE_INSTALLING : ;
                    case this.STATE_INSTALLED : ;
                    case this.STATE_STOPPED : {
                        this.state = this.STATE_STARTING;
                        if (this.doStart()) {
                            this.log('script started');
                            this.state = this.STATE_STARTED;
                        break;
                    case this.STATE_STARTING : ;
                    case this.STATE_STARTED : {
                        this.logWarn('script already starting/started');
                        break;
                    case this.STATE_STOPPING : {
                        this.logWarn('script is stopping, pls start later again');
                        break;
            // stop the script/class
            stop() {
                        this.state = this.STATE_STOPPING;
                        if (this.doStop()) {
                            for (let i=0; i<this.subscribers.length; i++) if (this.subscribers[i] !== undefined) unsubscribe( this.subscribers[i] );
                            for (let i=0; i<this.schedulers.length; i++) if (this.schedulers[i] !== undefined) clearSchedule( this.schedulers[i] );
                            this.state = this.STATE_STOPPED;
                            this.log('script stopped');
                        break;
                    default : {
                        this.log('cant stopp script, because not startet');
            // virtual functions, overwrite it
            doInit() { return true; }
            doStart() { return true; }
            doStop() { return true; }
            // einen on-Handler registrieren
            subscribe( handler ) {
                this.subscribers.push( handler );
            // einen timer registrieren
            schedule( handler ) {
                this.schedulers.push( handler );
            // tool functions
            logDebug(msg) { if (this.DEBUG) console.log('['+this.NAME+'] '+msg); }
            log(msg) { console.log('['+this.NAME+'] '+msg); }
            logWarn(msg) { console.warn('['+this.NAME+'] '+msg); }
            logError(msg) { console.error('['+this.NAME+'] '+msg); }
            // über den $-Operator nachsehen, ob der state bereits vorhanden ist
            // getState().notExists geht auch, erzeugt aber Warnmeldungen!
            existState(id) {
                return ( $(this.STATE_PATH+id).length==0?false:true);
            // wrapper, adds statepath to state-ID
            getState(id) {
                return getState(this.STATE_PATH + id);
            // like setState(), but adds statepath to state_ID and checks if state exists, when not, creates it
            setState(id,value) {
                if ( !this.existState(id) ) this.createState(id,value,undefined);
                else setState( this.STATE_PATH + id, value);
            // like cresteState(), but adds statepath to state_ID and checks if state exists, when not, creates it
            createState(id,value,common) {
                if ( !this.existState(id) ) {
                    if (common===undefined) {
                        // id im states-Array suchen
                        for (var i=0; i<this.states.length; i++) {
                            if (this.states[i].id==id) {
                                if (this.states[i].hasOwnProperty('common'))
                                    common = this.states[i].common;
                               break;
                    if ( (typeof value === 'undefined') && (common.hasOwnProperty('def'))) value = common.def;
                    // unter "0_userdata.0"
                    let obj = {};
                    obj.type = 'state';
                    obj.native = {};
                    obj.common = common;
                    setObject(this.STATE_PATH + id, obj, (err) => {
                            if (err) {
                                this.log('cant write object for state "' + this.STATE_PATH + id + '": ' + err);
                            } else {
                                this.log('state "' + this.STATE_PATH + id + '" created');
                    setTimeout( setState, 3000, this.STATE_PATH + id, value );
            // true, if str contains filter string or regexp
            fitsFilter(str, filter) {
                if ( (filter===undefined) || !filter || (filter=='') )
                    return true;
                if ( filter instanceof RegExp )  {
                    if (str.match( filter ) != null) return true;
                } else if (typeof filter == 'string') {
                    if(str.includes(filter)) return true;
                return false;
            escapeRegExp(str) {
                return str.replace(/[.*+?^${}()|[\]\\]/g, '\\$&');
            // wandelt eine Farbe im hex-Format (#000000) in ein RGB-Array[2] um
            hexToRGB(hex) {
                var result = /^#?([a-f\d]{2})([a-f\d]{2})([a-f\d]{2})$/i.exec(hex);
                return result
                    ? [parseInt(result[1],16),parseInt(result[2],16),parseInt(result[3],16)]
                    : [0,0,0];
            // Helligkeit berechnen
            getLuminance(r, g, b) {
                var a = [r, g, b].map(function (v) {
                    v /= 255;
                    return v <= 0.03928
                        ? v / 12.92
                        : Math.pow( (v + 0.055) / 1.055, 2.4 );
                return a[0] * 0.2126 + a[1] * 0.7152 + a[2] * 0.0722;
            // Kontrats berechnen
            getContrast(rgb1, rgb2) {
                var l1 = this.getLuminance(rgb1[0], rgb1[1], rgb1[2]) + 0.05;
                var l2 = this.getLuminance(rgb2[0], rgb2[1], rgb2[2]) + 0.05;
                if ( l1 > l2 ) return l1 / l2
                else return l2 / l1;
            // liefert die fontColor auf Basis der backgroundColor durch Berechnung
            // des Kontrasts
            getFontColor(backgroundColor) {
                if ( this.getContrast(this.hexToRGB(backgroundColor),this.hexToRGB("#000000")) < 6 )
                    return "#ffffff";
                else
                    return "#000000";
            // MduiLogHMDevices
            class MduiShowIcal extends MduiBase {
            constructor() {
                super();
            doInit() {
              super.doInit();
              // const
              this.DEBUG = false;
              this.VERSION = '1.0/2020-03-22';
              this.NAME = 'mduiShowIcal';
              this.DAY_MILLISECONDS = 60 * 60 * 24 * 1000;
              // optional: KONFIGURATION
                                   // state-Pfad unter dem die States angelegt werden
              this.STATE_PATH      = '0_userdata.0.mdui.showIcal.';
                                   // Anzahl der Table/List Ordner mit eigenem Filter/View
              this.MAX_LOG_FOLDER  = 3;
                                   // max.Anzahl der Zeilen für die Table/List Ausgabe
              this.MAX_TABLE_ROWS  = 200;
                                   // Objekt-Pfad zum ical.x.data.table
              this.ICAL_TABLE      = 'ical.0.data.table';
                                   // siehe: https://github.com/ioBroker/ioBroker.javascript/blob/master/docs/en/javascript.md#formatdate
              this.DATE_FORMAT     = 'W DD.MM.YYYY hh:mm';
                                   // optional können dem Kalendar noch Icons und abweichende
                                   // Farben angegeben werden (diese überschreiben jene aus iCal)
                                   // 'icon'     : 'Icon-Name' (MDCSS/Google WebFont)
                                   // 'calColor' : *#rrggbb' abweichende Kalendarfarbe
                                   // 'ignore'   : true|false Kalendar komplett ignorieren
              this.CALENDAR        = {'mdui-Abfall'      : {'icon':'delete_outline', 'calcolor':'orange' },
                                      'mdui-Geburtstage' : {'icon':'cake'},
                                      'Familie'          : {'ignore':true}
              // ENDE KONFIGURATION
              // var
              this.logs = [];
              for (let i=0; i<=this.MAX_LOG_FOLDER && i<10; i++)
                  this.logs.push({filter:'' });
              // init der states
              this.states.push( { id:'updatePressed',common:{name:'update button pressed', write:true, type:'boolean', def:'false', role:'button' }} );
              let defFilter;
              for (let i=0; i<=this.MAX_LOG_FOLDER && i<10; i++) {
                  switch (i) {
                      case 1 : defFilter = ':Abfall:'; break;
                      case 2 : defFilter = 'Geburtstag'; break;
                      case 3 : defFilter = ''; break;
                      default: defFilter = undefined;
                  this.states.push( { id:'log'+i+'.table',      common:{name:'ioBroker-log as table', write:false, role:'html' }} );
                  this.states.push( { id:'log'+i+'.list',       common:{name:'ioBroker-log as list', write:false, role:'html' }} );
                  this.states.push( { id:'log'+i+'.count',      common:{name:'ioBroker-log count', write:false, type:'number', def:'0' }} );
                  this.states.push( { id:'log'+i+'.filter',     common:{name:'ioBroker-log filter', write:true, def:defFilter}} );
                  this.states.push( { id:'log'+i+'.lastUpdate', common:{name:'ioBroker-log last update', write:false, def:'0' }} );
              return true;
            doStart() {
                super.doStart();
                // subscriber erzeugen
                this.subscribe( on( this.STATE_PATH+'updatePressed', obj => { this.onUpdate(obj) } ));
                this.subscribe( on( new RegExp( this.STATE_PATH+'*.filter' ), obj => { this.onFilter(obj) } ));
                this.subscribe( on( this.ICAL_TABLE, obj => { this.onIcalTable(obj) } ));
                this.onBuildHTML();
                return true;
            doStop() {
                super.doStop();
                return true;
            onUpdate(obj) {
                if (obj.state.val===true) {
                    this.onBuildHTML();
                this.setState('updatePressed', false);
            // filter, sort events
            onFilter(obj) {
              this.onBuildHTML();
            // Ical table hat sich geändert
            onIcalTable(obj) {
              this.onBuildHTML();
            // creates the HTML states for every log
            'date' => "→ 16.10.2017"
            'event' => "9.30 - 16.30 Uhr Stopka "
            '_class' => "ical_Kerstin ical_today"
            '_date' => "2017-10-16T07:30:00.000Z"
            '_end' => "2017-10-16T14:30:00.000Z"
            '_section' => ""
            '_IDID' => "040000008200E00074C5B7101A82E008000000007645DC55A6DFC44FB2EC6FEA9EFEA33C100000007688316058136F42AD128D91103543C9"
            '_allDay' => "false"
            '_rule' => " "
            '_calName' => "Kerstin"
            Optionen der ical-Instanz:
                'daysPreview' => "7"
                'colorize' => "false"
                'defColor' => "white"
                'fulltime' => " 00:00"
                'dataPaddingWithZeros' => "true"
                'replaceDates' => "false"
                'language' => "de"
                'everyCalOneColor' => "true"
                'calendars' (array)
                    '0' (array)
                        'name' => "Abfall"
                        'url' => "https://calendar.google.com/calendar/ical/ruo0ddgalu03qq2ehpm8imqnk4%40group.calendar.google.com/private-a30aac0367f8b50cfd7373f6222d29b4/basic.ics"
                        'user' => ""
                        'pass' => ""
                        'sslignore' => ""
                        'color' => ""
            isSameDay(d1,d2) {
                return (d1.getDate()==d2.getDate()) && (d1.getMonth()==d2.getMonth()) && (d1.getFullYear()==d2.getFullYear());
            getWeekNumber( date ) {
                let d = new Date(date);
                d.setHours(0,0,0);
                d.setDate(d.getDate()+4-(d.getDay()||7));
                return Math.ceil((((d-new Date(d.getFullYear(),0,1))/8.64e7)+1)/7);
            buildEntry( entry ) {
                const WEEKDAY_NAMES = ["So", "Mo", "Di", "Mi", "Do", "Fr", "Sa"];
                const MONTH_NAMES = ["Jan", "Feb", "Mär", "Apr", "Mai", "Jun", "Jul", "Aug", "Sep", "Okt", "Nov", "Dez"];
                let beginDate = new Date( entry.beginDateISO );
                entry.beginTime = beginDate.getTime();
                entry.beginWeekDay = beginDate.getDay(); // 0=Sonntag 6=Samstag
                entry.beginWeekDayName = WEEKDAY_NAMES[entry.beginWeekDay];
                entry.beginDay = beginDate.getDate();
                entry.beginMonth = beginDate.getMonth();
                entry.beginMonthName = MONTH_NAMES[entry.beginMonth];
                entry.beginYear = beginDate.getFullYear();
                entry.beginHour = beginDate.getHours();
                entry.beginMinute = beginDate.getMinutes();
                entry.beginDate = formatDate(beginDate,  this.DATE_FORMAT);
                let currDate = new Date( entry.currDateISO );
                entry.currTime = currDate.getTime();
                entry.currWeekDay = currDate.getDay(); // 0=Sonntag 6=Samstag
                entry.currWeekDayName = WEEKDAY_NAMES[entry.currWeekDay];
                entry.currDay = currDate.getDate();
                entry.currMonth = currDate.getMonth();
                entry.currMonthName = MONTH_NAMES[entry.currMonth];
                entry.currYear = currDate.getFullYear();
                entry.currHour = currDate.getHours();
                entry.currMinute = currDate.getMinutes();
                entry.currDate = formatDate(currDate,  this.DATE_FORMAT);
                entry.currDateOnly = entry.currYear*10000+entry.currMonth*100+entry.currDay;
                let endDate = new Date( entry.endDateISO );
                //allDay Korrektur: liefert immer einen Tag zu viel
                if (entry.allDay && endDate.getHours()==0) endDate.setTime( endDate.getTime() - this.DAY_MILLISECONDS);
                entry.endTime = endDate.getTime();
                entry.endWeekDay = endDate.getDay(); // 0=Sonntag 6=Samstag
                entry.endDay = endDate.getDate();
                entry.endMonth = endDate.getMonth();
                entry.endYear = endDate.getFullYear();
                entry.endHour = endDate.getHours();
                entry.endMinute = endDate.getMinutes();
                entry.endDate = formatDate(endDate, this.DATE_FORMAT);
                if (entry.currWeekDay==0 || entry.currWeekDay==6) entry.dayColor = '#f44336'
                else entry.dayColor = 'inherited';
                if (entry.currWeekDay==1) entry.week = this.getWeekNumber(currDate)+'.W';
                else entry.week = '';
                if (entry.currTime < Date.now() ) entry.opacity = '.66'
                else entry.opacity = '1';
                // Zeitraumangabe berechnen
                entry.hint = '';
                if ( !this.isSameDay(beginDate, endDate) ) {
                        // mehrtägig
                        if (entry.allDay)
                            entry.timeSpan = 'ganztägig ';
                        else if ( this.isSameDay(beginDate, currDate) )
                                entry.timeSpan = 'ab ' + formatDate(beginDate,'hh:mm');
                             else if ( this.isSameDay(endDate, currDate) )
                                      entry.timeSpan = 'bis ' + formatDate(endDate,'hh:mm');
                                  else
                    } else {
                        // an einem Tag
                        if (entry.allDay)
                            entry.timeSpan = 'ganztägig';
                        else if ( (entry.beginHour!=entry.endHour) || (entry.beginMinute!=entry.endMinute)  )
                                 entry.timeSpan = formatDate(beginDate,'hh:mm') + '-' + formatDate(endDate,'hh:mm');
                             else
                                 entry.timeSpan = formatDate(beginDate,'hh:mm');
                return entry;
            onBuildHTML() { try {
                let json = [];
                let calTable = getState(this.ICAL_TABLE);
                let inst     = getObject("system.adapter."+this.ICAL_TABLE.substr(0,6));
                let instopt  = inst.native;
                let calendar = {};
                let cal      = {};
                let calOptions = {};
                let todayDate = new Date();
                let today = todayDate.getFullYear()*10000+todayDate.getMonth()*100+todayDate.getDate();
                for (var i = 0; i < calTable.val.length; i++) {
                  cal = calTable.val[i];
                  let entry = {};
                  if ( cal._calName != calendar.name ) {
                        calendar = {};
                        // color suchen
                        for (let c = 0; c < instopt.calendars.length; c++ ) {
                            if (cal._calName == instopt.calendars[c].name ) {
                                calendar = instopt.calendars[c];
                                break;
                        // options suchen
                        if (this.CALENDAR.hasOwnProperty(cal._calName)) calOptions = this.CALENDAR[cal._calName];
                        else calOptions={};
                    if (calOptions.hasOwnProperty('ignore') && calOptions.ignore ) continue;
                    if (calOptions.hasOwnProperty('calcolor')) entry.calColor = calOptions.calcolor;
                    else if (calendar.color !== "") entry.calColor = calendar.color;
                         else entry.calColor = '#000000';
                    entry.color = this.getFontColor( entry.calColor );
                    if (calOptions.hasOwnProperty('icon')) entry.icon = calOptions.icon;
                    else entry.icon='';
                    entry.date = cal.date;
                    entry.event = cal.event;
                    entry.calName = cal._calName;
                    entry.beginDateISO = cal._date;
                    entry.currDateISO = cal._date;
                    entry.endDateISO  = cal._end;
                    entry.allDay  = cal._allDay;
                    entry.location = cal.location;
                    entry = this.buildEntry( entry);
                    if (entry.currDateOnly >= today)
                        json.push( entry );
                    // Listenansicht
                    // in calTable steht nur ein Eintrag für jeden Beginn, für die List-Darstellung
                    // sind diese auch je Tag notwendig - hier jetzt bilden
                    if ( (entry.beginDay!=entry.endDay) || (entry.beginMonth!=entry.endMonth) || (entry.beginYear!=entry.endYear) ) {
                        let currTime = new Date(entry.beginDateISO).getTime() + this.DAY_MILLISECONDS;
                        let endTime = new Date(entry.endDateISO).getTime();
                        if (entry.allDay) endTime -= + this.DAY_MILLISECONDS;
                        let dayMax=Math.trunc( 2 + (endTime - currTime) /this. DAY_MILLISECONDS);
                        entry.hint += ' (Tag 1/'+dayMax+')';
                        let dayCount=2;
                        while (currTime <= endTime && dayCount<100) {
                            let newEntry = {};
                            Object.assign(newEntry, entry);
                            newEntry.currDateISO = new Date(currTime).toISOString();
                            newEntry = this.buildEntry( newEntry );
                            newEntry.hint += ' (Tag '+dayCount+'/'+dayMax+')';
                            if (newEntry.currDateOnly >= today)
                                json.push( newEntry );
                            currTime = currTime + this.DAY_MILLISECONDS;
                            dayCount++;
                // sortieren
                json.sort( (l,r) => {
                          let lv=l['currTime'],rv=r['currTime'];
                          return ((lv < rv) ? -1 : (lv > rv) ? 1 : 0);
              // build table/list HTML
                  let log = this.logs[i];
                  log.filter = '';
                  log.ts = 0;
                  log.idState = 'log'+i;
                  if (this.existState(log.idState+'.filter')) log.filter = this.getState(log.idState+'.filter').val;
                  if (this.existState(log.idState+'.lastClear')) log.ts = this.getState(log.idState+'.lastClear').val;
                  this.convertJSON2HTML(json, log);
            } catch(err) { this.logError( 'onBuildHTML: '+err.message ); }  }
            // color date event calName beginDate endDate allDay
            convertJSON2HTML(json, log) {
            const tmpTable = {
            header :
            `<tr>
            <th style="text-align:right;"></th>
            <th style="text-align:left;"></th>
            <th style="text-align:left; min-width:12em;">Betreff</th>
            <th style="text-align:left;">Zeit</th>
            <th style="text-align:left;">Ort</th>
            <th style="text-align:left;">Kalendar</th>
            </tr>`,
            row :
            `<tr>
            <td style="text-align:right;">
               <span style="display:{showDay}; color:{dayColor}; font-size:1.5em; opacity:1; font-weight:bold;">{currDay}</span>
            </td>
            <td>
               <span style="display:{showDay}; font-size:0.8em; margin-top:0.3em; margin-left:4px; opacity:.8;">{currMonthName}</span>
            </td>
            <td>
               <span style="display:{showDay}; font-size:0.8em; margin-top:0.3em; opacity:.8;">{currWeekDayName}</span>
            </td>
            <td>
              <span style="display:inline-block; width:.8em; height:.8em; margin-top:0.3em; background:{calColor}; border-radius:50%;">&nbsp;</span>
            </td>
            <td>
              <i class='material-icons mdui-center {color}' style='font-size:1.2em;'>{icon}</i>
            </td>
            <td>{event}</td>
            <td><span style="font-size:1.0em; opacity:.8;">{timeSpan} {hint}</span></td>
            <td>{location}</td>
            <td><span style="font-size:0.8em; opacity:.8;color:{calColor};">{calName}</span></td>
            <td></td>
            </tr>`
            const tmpList = {
            row :
            `<div class="mdui-listitem" style="font-size:1em; width:100%; display:flex; opacity:{opacity};">
              <div style="min-width:3.5em;">
                <div style="display:{showDay}; color:{dayColor};">
                  <span style="font-size:1.5em; opacity:1; font-weight:bold;">{currDay}</span>
                  <span style="font-size:0.8em; margin:4px; opacity:.8;">{currMonthName}<br/>
                </div>
                <div style="display:{showDay}; text-align:right; font-size:0.6em; opacity:.6;">{week}</div>
              </div>
              <div style="min-width:1.2em;">
                <div style="width:.8em; height:.8em;  margin:.1em; text-align:center; background:{calColor}; border-radius:50%;">&nbsp;</div>
                <div class="mdui-icon" style="font-size:1.1em; text-align:center; margin-top:0.33em;">{icon}</div>
              </div>
              <div style="width:100%; margin-left:.25em;">
                <div style="">
                  <div style="font-size:1.1em;">{event}</div>
                </div>
                <div style="width:100%; display:flex; flex-wrap:wrap; align-items:baseline; justify-content:space-between;">
                  <div style="font-size:1.0em; opacity:.8;">
                    {timeSpan}
                    <span style="font-size:0.8em;">{hint} {location}</span>
                  </div>
                  <div style="font-size:0.8em; opacity:.8;color:{calColor};">{calName}</div>
                </div>
              </div>
            </div>`}
                // build htmlTable and htmlList
                let htmlTable  = "<table><thead>"+tmpTable.header+"</thead><tbody>";
                for (let [key, value] of Object.entries(log)) htmlTable = htmlTable.replace(new RegExp('{'+key+'}','g'),value);
                let htmlList  = "";
                let entry, tr;
                let count = 0;
                // filter as regex?
                if ( log.filter!==undefined && typeof log.filter == 'string' && log.filter.startsWith('/') && log.filter.endsWith('/') && (log.filter.length>=2) )  {
                    log.filter = new RegExp(log.filter.substr(1,log.filter.length-2), 'i');
                let lastEntry = {};
                for (var i = 0; i < json.length && count<this.MAX_TABLE_ROWS; i++) {
                    entry = json[i];
                    if (this.fitsFilter(':' + entry.currDate + ':' + entry.event +':'+entry.calName + ':' + entry.location + ':',log.filter)) {
                        entry.showDay = (lastEntry=={}) || (entry.currDay!=lastEntry.currDay) || (entry.currMonth!=lastEntry.currMonth) || (entry.currYear!=lastEntry.currYear)?'flex':'none';
                        lastEntry = entry;
                        tr = tmpTable.row;
                        for (let [key, value] of Object.entries(entry)) tr = tr.replace(new RegExp('{'+key+'}','g'),value);
                        htmlTable+=tr;
                        tr = tmpList.row;
                        htmlList+=tr;
                        count++;
                htmlTable+="</body></table>";
                this.setState(log.idState+'.table', htmlTable);
                this.setState(log.idState+'.list', htmlList);
                this.setState(log.idState+'.count', count);
                this.setState(log.idState+'.lastUpdate', +new Date());
            // create instance and start
            var mduiShowIcal = new MduiShowIcal( );
            mduiShowIcal.start();
            // on script stop, stop instance too
            onStop(function () {
                mduiShowIcal.stop();
            }, 1000 );
        Immer Daten sichern!
        • sigi234S sigi234
          @sigi234
          Hallo siggi234,
          *** MduiShowIcal
          Bsp.:
          **** Installation
          **** Konfiguration
          **** Dokumentation
          ***** States
          ***** Filter
          Beispiele:
          **** Lizenz
          *** Changelog
          2020.05.01 UH
          // MduiBase
          class MduiBase {
              constructor() {
                this.init();
              init() {
                  // const
                  this.DEBUG      = false;
                  // var
                  this.states = [];
                  this.doInit();
                  // init der states
              start() {
                      return;
                          break;
                          break;
                          break;
              stop() {
                          break;
                      default : {
              // tool functions
              existState(id) {
              getState(id) {
                                 break;
                      let obj = {};
                      obj.type = 'state';
                      obj.native = {};
                              if (err) {
                              } else {
                      return true;
                  return false;
              escapeRegExp(str) {
              hexToRGB(hex) {
                  return result
                      : [0,0,0];
                      v /= 255;
                      return v <= 0.03928
                          ? v / 12.92
              // des Kontrasts
                      return "#ffffff";
                  else
                      return "#000000";
              // MduiLogHMDevices
              constructor() {
                  super();
              doInit() {
                super.doInit();
                // const
                this.DEBUG = false;
                // var
                this.logs = [];
                // init der states
                let defFilter;
                    switch (i) {
                return true;
              doStart() {
                  super.doStart();
                  this.onBuildHTML();
                  return true;
              doStop() {
                  super.doStop();
                  return true;
              onUpdate(obj) {
                      this.onBuildHTML();
              onFilter(obj) {
                this.onBuildHTML();
              onIcalTable(obj) {
                this.onBuildHTML();
              '_section' => ""
              '_rule' => " "
                  'language' => "de"
                  'calendars' (array)
                      '0' (array)
                          'name' => "Abfall"
                          'user' => ""
                          'pass' => ""
                          'sslignore' => ""
                          'color' => ""
              isSameDay(d1,d2) {
                  d.setHours(0,0,0);
                  entry.hint = '';
                          // mehrtägig
                          if (entry.allDay)
                                    else
                      } else {
                          // an einem Tag
                          if (entry.allDay)
                               else
                  return entry;
                  let json = [];
                  let calendar = {};
                  let cal      = {};
                    let entry = {};
                          calendar = {};
                          // color suchen
                                  break;
                          // options suchen
                          else calOptions={};
                      else entry.icon='';
                          json.push( entry );
                      // Listenansicht
                          let dayCount=2;
                              let newEntry = {};
                              dayCount++;
                  // sortieren
                    log.filter = '';
                    log.ts = 0;
              const tmpTable = {
              header :
              `<tr>
              </tr>`,
              row :
              `<tr>
              </td>
              <td>
              </td>
              <td>
              </td>
              <td>
              </td>
              <td>
              </td>
              <td>{event}</td>
              <td>{location}</td>
              <td></td>
              </tr>`
              const tmpList = {
              row :
                  </div>
                </div>
                </div>
                  <div style="">
                  </div>
                      {timeSpan}
                    </div>
                  </div>
                </div>
              </div>`}
                  let htmlList  = "";
                  let entry, tr;
                  let count = 0;
                  // filter as regex?
                  let lastEntry = {};
                      entry = json[i];
                          lastEntry = entry;
                          tr = tmpTable.row;
                          htmlTable+=tr;
                          tr = tmpList.row;
                          htmlList+=tr;
                          count++;
              }, 1000 );
          Ente
          schrieb am zuletzt editiert von Ente
          #44
          @sigi234
          Skript läuft. Vielen Dank.
          Tut mir leid sigi. Wie bekomme ich das nun in meine vis integriert. Entschuldige bitte die Dummy-Frage.
          • E Ente
            @sigi234
            sigi234S Online
            sigi234S Online
            sigi234
            #45
            @sigi234
            • sigi234S sigi234
              @sigi234
              Ente
              #46
              @sigi234 said in [Vorlage] MDCSS v2: ical Kalendar anzeigen:
              @sigi234
              Genau das habe ich gerade gefunden. Es zeigt auch die Termine an,
              leider nicht so wie in dem Bild im 1. Post. bzw. wie hier:
              https://forum.iobroker.net/topic/31635/vorlage-mdcss-v2-ical-kalendar-anzeigen/15
              Ich vermute mal, dass ich das im Skript selbst ändern muss. Mal sehen.
              Edit: Das Datum erscheint schon einmal. Jetzt will ich noch die Farben ändern. Den Filter habe ich auch nicht.
              • E Ente
                @sigi234
                sigi234S Online
                sigi234S Online
                sigi234
                #47
                @Ente
                Hast du die Vorlage heruntergeladen und als View importiert?
                https://github.com/Uhula/ioBroker-Material-Design-Style/tree/master/templates/MduiShowIcal
                • sigi234S sigi234
                  @Ente
                  Ente
                  #48
                  @Ente
                  Ja, den JS von MduiShowIcal_Tableview.json und als View importiert. Das Ergebnis, naja:
                  Das ganze verstehe ich nicht. Das Anzeigen der Termine reicht.
                  • E Ente
                    @Ente
                    sigi234S Online
                    sigi234S Online
                    sigi234
                    #49
                    @Ente
                    Welche Version hast du von MDCSS ?
                    • sigi234S sigi234
                      @Ente
                      Ente
                      #50
                      @Ente
                      Äh?? Wo finde ich das?
                      • E Ente
                        @Ente
                        sigi234S Online
                        sigi234S Online
                        sigi234
                        #51
                        @Ente
                        • sigi234S sigi234
                          @Ente
                          Ente
                          #52
                          @Ente
                          Hab das Skript jetzt eingefügt. > 2.5
                          Diese Objects habe allerdings ich nicht:
                          Bei User.Datea habe ich nur das:
                          Irgendetwas habe ich grundsätzlich falsch gemacht.
                          • E Ente
                            @Ente
                            Ente
                            #53
                            wie bekomme ich die Einträge in der view in weiß:
                            Im Edit-Modus sind sie es.
                            Edit: Gefunden:
                            root.mdui-runtime {
                            --content-background: #f8f8f8;
                            --design-font-color: #000000;
                            --frame-color:#cfcfcf;
                            • H Offline
                              hendrik87
                              #54
                              Hallo
                              Gibt es auch eine Möglichkeit sich die freien Tage anzeigen zu lassen?
                              • H hendrik87
                                Hallo
                                ChaotC Offline
                                ChaotC Offline
                                Chaot
                                #55
                                @hendrik87 Was meinst du? Die Tage ohne Eintrag?
                                Habe ich noch nicht probiert, aber versuche doch mal den Filter auf
                                zu setzen und schau was passiert.
                                H 1 Antwort Letzte Antwort
                                • ChaotC Chaot
                                  hendrik87
                                  #56
                                  @chaot
                                  Die Tage wo es keinen Termin zu gibt sollen auch angezeigt werden. Also in meinem Fall der 28, 30, 31, ....
                                  Eigentlich bin ich auf der Suche nach einem monatsweisen Zeilenkalender.
                                  Da habe ich mit dem MDCSS bislang die beste Lösung gefunden.
