  4. JS.Controller Update geht nicht
193
4 Beiträge 3 Kommentatoren 384 Aufrufe 3 Beobachtet
  • K Offline
    kg36304
    ich wollte heute auf 2.2.9 updaten. Beim Slave hat alles geklappt.
    Hier die Meldung vom Master:
    pi@raspberrypi4-iob:~ $ iobroker upgrade self
    Update js-controller from @2.2.8 to @2.2.9
    NPM version: 6.13.4
    npm install iobroker.js-controller@2.2.9 --unsafe-perm --loglevel error --prefix "/opt/iobroker" (System call)
    In file included from ../node_modules/nan/nan.h:82,
                     from ../src/bufferutil.cc:16:
    ../node_modules/nan/nan_new.h: In function ‘v8::Local<T> NanIntern::To(v8::Handle<v8::Integer>) [with T = v8::Integer; v8::Handle<v8::Integer> = v8::Local<v8::Integer>]’:
    ../node_modules/nan/nan_new.h:29:66: warning: ‘v8::Local<v8::Integer> v8::Value::ToInteger() const’ is deprecated: Use maybe version [-Wdeprecated-declarations]
     To<v8::Integer>(v8::Handle<v8::Integer> i) { return i->ToInteger(); }
    In file included from ../src/bufferutil.cc:7:
    /home/iobroker/.cache/node-gyp/10.19.0/include/node/v8.h:10052:16: note: declared here
     Local<Integer> Value::ToInteger() const {
    ../node_modules/nan/nan_new.h: In function ‘v8::Local<T> NanIntern::To(v8::Handle<v8::Integer>) [with T = v8::Int32; v8::Handle<v8::Integer> = v8::Local<v8::Integer>]’:
    ../node_modules/nan/nan_new.h:34:64: error: no matching function for call to ‘v8::Integer::ToInt32()’
     To<v8::Int32>(v8::Handle<v8::Integer> i)   { return i->ToInt32(); }
    /home/iobroker/.cache/node-gyp/10.19.0/include/node/v8.h:2437:43: note: candidate: ‘v8::MaybeLocal<v8::Int32> v8::Value::ToInt32(v8::Local<v8::Context>) const’
       V8_WARN_UNUSED_RESULT MaybeLocal<Int32> ToInt32(Local<Context> context) const;
    /home/iobroker/.cache/node-gyp/10.19.0/include/node/v8.h:2437:43: note:   candidate expects 1 argument, 0 provided
    In file included from /home/iobroker/.cache/node-gyp/10.19.0/include/node/v8.h:26,
    /home/iobroker/.cache/node-gyp/10.19.0/include/node/v8.h:2450:30: note: candidate: ‘v8::Local<v8::Int32> v8::Value::ToInt32(v8::Isolate*) const’
                     Local<Int32> ToInt32(Isolate* isolate) const);
    /home/iobroker/.cache/node-gyp/10.19.0/include/node/v8config.h:324:3: note: in definition of macro ‘V8_DEPRECATED’
       declarator __attribute__((deprecated(message)))
    /home/iobroker/.cache/node-gyp/10.19.0/include/node/v8.h:2450:30: note:   candidate expects 1 argument, 0 provided
    ../node_modules/nan/nan_new.h: In function ‘v8::Local<T> NanIntern::To(v8::Handle<v8::Integer>) [with T = v8::Uint32; v8::Handle<v8::Integer> = v8::Local<v8::Integer>]’:
    ../node_modules/nan/nan_new.h:39:65: error: no matching function for call to ‘v8::Integer::ToUint32()’
     To<v8::Uint32>(v8::Handle<v8::Integer> i)  { return i->ToUint32(); }
    /home/iobroker/.cache/node-gyp/10.19.0/include/node/v8.h:2435:44: note: candidate: ‘v8::MaybeLocal<v8::Uint32> v8::Value::ToUint32(v8::Local<v8::Context>) const’
       V8_WARN_UNUSED_RESULT MaybeLocal<Uint32> ToUint32(
    /home/iobroker/.cache/node-gyp/10.19.0/include/node/v8.h:2435:44: note:   candidate expects 1 argument, 0 provided
    In file included from ../node_modules/nan/nan_new.h:189,
    ../node_modules/nan/nan_implementation_12_inl.h: In static member function ‘static NanIntern::FactoryBase<v8::BooleanObject>::return_t NanIntern::Factory<v8::BooleanObject>::New(bool)’:
    ../node_modules/nan/nan_implementation_12_inl.h:49:38: error: no matching function for call to ‘v8::BooleanObject::New(bool&)’
       return v8::BooleanObject::New(value).As<v8::BooleanObject>();
    /home/iobroker/.cache/node-gyp/10.19.0/include/node/v8.h:5035:23: note: candidate: ‘static v8::Local<v8::Value> v8::BooleanObject::New(v8::Isolate*, bool)’
       static Local<Value> New(Isolate* isolate, bool value);
    /home/iobroker/.cache/node-gyp/10.19.0/include/node/v8.h:5035:23: note:   candidate expects 2 arguments, 1 provided
    ../node_modules/nan/nan_implementation_12_inl.h:49:60: error: expected primary-expression before ‘>’ token
    ../node_modules/nan/nan_implementation_12_inl.h:49:62: error: expected primary-expression before ‘)’ token
    ../node_modules/nan/nan_implementation_12_inl.h: In static member function ‘static NanIntern::FactoryBase<v8::RegExp>::return_t NanIntern::Factory<v8::RegExp>::New(v8::Handle<v8::String>, v8::RegExp::Flags)’:
    ../node_modules/nan/nan_implementation_12_inl.h:158:40: warning: ‘static v8::Local<v8::RegExp> v8::RegExp::New(v8::Local<v8::String>, v8::RegExp::Flags)’ is deprecated: Use maybe version [-Wdeprecated-declarations]
       return v8::RegExp::New(pattern, flags);
    /home/iobroker/.cache/node-gyp/10.19.0/include/node/v8.h:5110:38: note: declared here
                            Local<RegExp> New(Local<String> pattern, Flags flags));
    ../node_modules/nan/nan_implementation_12_inl.h: In static member function ‘static NanIntern::FactoryBase<v8::Script>::return_t NanIntern::Factory<v8::Script>::New(v8::Local<v8::String>)’:
    ../node_modules/nan/nan_implementation_12_inl.h:166:69: error: no matching function for call to ‘v8::ScriptCompiler::Compile(v8::Isolate*, v8::ScriptCompiler::Source*)’
       return v8::ScriptCompiler::Compile(v8::Isolate::GetCurrent(), &src);
    /home/iobroker/.cache/node-gyp/10.19.0/include/node/v8.h:1510:51: note: candidate: ‘static v8::MaybeLocal<v8::Script> v8::ScriptCompiler::Compile(v8::Local<v8::Context>, v8::ScriptCompiler::Source*, v8::ScriptCompiler::CompileOptions, v8::ScriptCompiler::NoCacheReason)’
       static V8_WARN_UNUSED_RESULT MaybeLocal<Script> Compile(
    /home/iobroker/.cache/node-gyp/10.19.0/include/node/v8.h:1510:51: note:   no known conversion for argument 1 from ‘v8::Isolate*’ to ‘v8::Local<v8::Context>’
    /home/iobroker/.cache/node-gyp/10.19.0/include/node/v8.h:1537:51: note: candidate: ‘static v8::MaybeLocal<v8::Script> v8::ScriptCompiler::Compile(v8::Local<v8::Context>, v8::ScriptCompiler::StreamedSource*, v8::Local<v8::String>, const v8::ScriptOrigin&)’
    /home/iobroker/.cache/node-gyp/10.19.0/include/node/v8.h:1537:51: note:   candidate expects 4 arguments, 2 provided
    ../node_modules/nan/nan_implementation_12_inl.h: In static member function ‘static NanIntern::FactoryBase<v8::Script>::return_t NanIntern::Factory<v8::Script>::New(v8::Local<v8::String>, const v8::ScriptOrigin&)’:
    ../node_modules/nan/nan_implementation_12_inl.h:173:69: error: no matching function for call to ‘v8::ScriptCompiler::Compile(v8::Isolate*, v8::ScriptCompiler::Source*)’
    ../node_modules/nan/nan_implementation_12_inl.h: In static member function ‘static NanIntern::FactoryBase<v8::String>::return_t NanIntern::Factory<v8::String>::New(const uint8_t*, int)’:
    ../node_modules/nan/nan_implementation_12_inl.h:206:42: error: no matching function for call to ‘v8::String::NewFromOneByte(v8::Isolate*, const uint8_t*&, v8::String::NewStringType, int&)’
             v8::String::kNormalString, length);
    /home/iobroker/.cache/node-gyp/10.19.0/include/node/v8.h:2802:51: note: candidate: ‘static v8::MaybeLocal<v8::String> v8::String::NewFromOneByte(v8::Isolate*, const uint8_t*, v8::NewStringType, int)’
       static V8_WARN_UNUSED_RESULT MaybeLocal<String> NewFromOneByte(
    /home/iobroker/.cache/node-gyp/10.19.0/include/node/v8.h:2802:51: note:   no known conversion for argument 3 from ‘v8::String::NewStringType’ to ‘v8::NewStringType’
    ../node_modules/nan/nan_implementation_12_inl.h: In static member function ‘static NanIntern::FactoryBase<v8::String>::return_t NanIntern::Factory<v8::String>::New(v8::String::ExternalStringResource*)’:
    ../node_modules/nan/nan_implementation_12_inl.h:217:66: error: no matching function for call to ‘v8::String::NewExternal(v8::Isolate*, v8::String::ExternalStringResource*&)’
       return v8::String::NewExternal(v8::Isolate::GetCurrent(), value);
    /home/iobroker/.cache/node-gyp/10.19.0/include/node/v8.h:2861:21: note: candidate: ‘static v8::Local<v8::String> v8::String::NewExternal(v8::Isolate*, v8::String::ExternalOneByteStringResource*)’
           Local<String> NewExternal(Isolate* isolate,
    /home/iobroker/.cache/node-gyp/10.19.0/include/node/v8config.h:346:48: note: in definition of macro ‘V8_DEPRECATE_SOON’
     #define V8_DEPRECATE_SOON(message, declarator) declarator
    /home/iobroker/.cache/node-gyp/10.19.0/include/node/v8.h:2861:21: note:   no known conversion for argument 2 from ‘v8::String::ExternalStringResource*’ to ‘v8::String::ExternalOneByteStringResource*’
    ../node_modules/nan/nan_implementation_12_inl.h: In static member function ‘static NanIntern::FactoryBase<v8::UnboundScript>::return_t NanIntern::Factory<v8::UnboundScript>::New(v8::Local<v8::String>)’:
    ../node_modules/nan/nan_implementation_12_inl.h:237:30: error: ‘CompileUnbound’ is not a member of ‘v8::ScriptCompiler’
       return v8::ScriptCompiler::CompileUnbound(v8::Isolate::GetCurrent(), &src);
    ../node_modules/nan/nan_implementation_12_inl.h: In static member function ‘static NanIntern::FactoryBase<v8::UnboundScript>::return_t NanIntern::Factory<v8::UnboundScript>::New(v8::Local<v8::String>, const v8::ScriptOrigin&)’:
    ../node_modules/nan/nan_implementation_12_inl.h:244:30: error: ‘CompileUnbound’ is not a member of ‘v8::ScriptCompiler’
    In file included from ../src/bufferutil.cc:16:
    ../node_modules/nan/nan.h: In function ‘uint32_t NanUInt32OptionValue(v8::Local<v8::Object>, v8::Handle<v8::String>, uint32_t)’:
    ../node_modules/nan/nan.h:248:43: warning: ‘uint32_t v8::Value::Uint32Value() const’ is deprecated: Use maybe version [-Wdeprecated-declarations]
           ? optionsObj->Get(opt)->Uint32Value()
    /home/iobroker/.cache/node-gyp/10.19.0/include/node/v8.h:2477:47: note: declared here
       V8_DEPRECATED("Use maybe version", uint32_t Uint32Value() const);
    ../node_modules/nan/nan.h: At global scope:
    ../node_modules/nan/nan.h:261:25: error: redefinition of ‘template<class T> v8::Local<T> _NanEnsureLocal(v8::Local<T>)’
     NAN_INLINE v8::Local<T> _NanEnsureLocal(v8::Local<T> val) {
    ../node_modules/nan/nan.h:256:25: note: ‘template<class T> v8::Local<T> _NanEnsureLocal(v8::Handle<T>)’ previously declared here
     NAN_INLINE v8::Local<T> _NanEnsureLocal(v8::Handle<T> val) {
    ../node_modules/nan/nan.h: In function ‘bool NanIdleNotification(int)’:
    ../node_modules/nan/nan.h:289:39: error: ‘class v8::Isolate’ has no member named ‘IdleNotification’; did you mean ‘IdleNotificationDeadline’?
         return v8::Isolate::GetCurrent()->IdleNotification(idle_time_in_ms);
    ../node_modules/nan/nan.h:473:20: error: variable or field ‘NanAddGCEpilogueCallback’ declared void
           v8::Isolate::GCEpilogueCallback callback
    ../node_modules/nan/nan.h:473:20: error: ‘GCEpilogueCallback’ is not a member of ‘v8::Isolate’
    ../node_modules/nan/nan.h:474:18: error: expected primary-expression before ‘gc_type_filter’
         , v8::GCType gc_type_filter = v8::kGCTypeAll) {
    ../node_modules/nan/nan.h:479:20: error: variable or field ‘NanRemoveGCEpilogueCallback’ declared void
           v8::Isolate::GCEpilogueCallback callback) {
    ../node_modules/nan/nan.h:479:20: error: ‘GCEpilogueCallback’ is not a member of ‘v8::Isolate’
    ../node_modules/nan/nan.h:484:20: error: variable or field ‘NanAddGCPrologueCallback’ declared void
           v8::Isolate::GCPrologueCallback callback
    ../node_modules/nan/nan.h:484:20: error: ‘GCPrologueCallback’ is not a member of ‘v8::Isolate’
    ../node_modules/nan/nan.h:485:18: error: expected primary-expression before ‘gc_type_filter’
    ../node_modules/nan/nan.h:490:20: error: variable or field ‘NanRemoveGCPrologueCallback’ declared void
           v8::Isolate::GCPrologueCallback callback) {
    ../node_modules/nan/nan.h:490:20: error: ‘GCPrologueCallback’ is not a member of ‘v8::Isolate’
    ../node_modules/nan/nan.h:569:15: error: ‘WeakCallbackData’ in namespace ‘v8’ does not name a template type
         const v8::WeakCallbackData<T, _NanWeakCallbackInfo<T, P> > &data) {
    ../node_modules/nan/nan.h:569:11: note: suggested alternative: ‘WeakCallbackType’
               WeakCallbackType
    ../node_modules/nan/nan.h:569:31: error: expected ‘,’ or ‘...’ before ‘<’ token
    ../node_modules/nan/nan.h: In function ‘void _NanWeakCallbackDispatcher(int)’:
    ../node_modules/nan/nan.h:570:42: error: ‘data’ was not declared in this scope
           _NanWeakCallbackInfo<T, P> *info = data.GetParameter();
    ../node_modules/nan/nan.h:661:13: error: ‘node::smalloc’ has not been declared
         , node::smalloc::FreeCallback callback
    ../node_modules/nan/nan.h:661:35: error: expected ‘,’ or ‘...’ before ‘callback’
    ../node_modules/nan/nan.h: In function ‘v8::Local<v8::Object> NanNewBufferHandle(char*, size_t, int)’:
    ../node_modules/nan/nan.h:665:50: error: ‘callback’ was not declared in this scope
             v8::Isolate::GetCurrent(), data, length, callback, hint);
    ../node_modules/nan/nan.h:665:50: note: suggested alternative: ‘calloc’
                                                      calloc
    ../node_modules/nan/nan.h:665:60: error: ‘hint’ was not declared in this scope
    ../node_modules/nan/nan.h:665:60: note: suggested alternative: ‘uint’
        uint
    ../node_modules/nan/nan.h: In function ‘v8::Local<v8::Object> NanNewBufferHandle(const char*, uint32_t)’:
    ../node_modules/nan/nan.h:672:57: error: invalid conversion from ‘const char*’ to ‘char*’ [-fpermissive]
         return node::Buffer::New(v8::Isolate::GetCurrent(), data, size);
    In file included from ../src/bufferutil.cc:10:
    /home/iobroker/.cache/node-gyp/10.19.0/include/node/node_buffer.h:69:50: note:   initializing argument 2 of ‘v8::MaybeLocal<v8::Object> node::Buffer::New(v8::Isolate*, char*, size_t)’
                                                char* data,
    ../node_modules/nan/nan.h:672:29: error: could not convert ‘node::Buffer::New(v8::Isolate::GetCurrent(), ((char*)data), size)’ from ‘v8::MaybeLocal<v8::Object>’ to ‘v8::Local<v8::Object>’
    ../node_modules/nan/nan.h: In function ‘v8::Local<v8::Object> NanNewBufferHandle(uint32_t)’:
    ../node_modules/nan/nan.h:676:29: error: could not convert ‘node::Buffer::New(v8::Isolate::GetCurrent(), size)’ from ‘v8::MaybeLocal<v8::Object>’ to ‘v8::Local<v8::Object>’
         return node::Buffer::New(v8::Isolate::GetCurrent(), size);
    ../node_modules/nan/nan.h: In function ‘v8::Local<v8::Object> NanBufferUse(char*, uint32_t)’:
    ../node_modules/nan/nan.h:683:26: error: ‘Use’ is not a member of ‘node::Buffer’
         return node::Buffer::Use(v8::Isolate::GetCurrent(), data, size);
    ../node_modules/nan/nan.h: In function ‘v8::Local<v8::Script> NanCompileScript(v8::Local<v8::String>, const v8::ScriptOrigin&)’:
    ../node_modules/nan/nan.h:710:74: error: no matching function for call to ‘v8::ScriptCompiler::Compile(v8::Isolate*, v8::ScriptCompiler::Source*)’
         return v8::ScriptCompiler::Compile(v8::Isolate::GetCurrent(), &source);
    ../node_modules/nan/nan.h: In function ‘v8::Local<v8::Script> NanCompileScript(v8::Local<v8::String>)’:
    ../node_modules/nan/nan.h:717:74: error: no matching function for call to ‘v8::ScriptCompiler::Compile(v8::Isolate*, v8::ScriptCompiler::Source*)’
    ../node_modules/nan/nan.h: In function ‘v8::Local<v8::Value> NanRunScript(v8::Handle<v8::UnboundScript>)’:
    ../node_modules/nan/nan.h:723:48: warning: ‘v8::Local<v8::Value> v8::Script::Run()’ is deprecated: Use maybe version [-Wdeprecated-declarations]
         return script->BindToCurrentContext()->Run();
    /home/iobroker/.cache/node-gyp/10.19.0/include/node/v8.h:1271:51: note: declared here
       V8_DEPRECATED("Use maybe version", Local<Value> Run());
    ../node_modules/nan/nan.h: In function ‘v8::Local<v8::Value> NanRunScript(v8::Handle<v8::Script>)’:
    ../node_modules/nan/nan.h:729:24: warning: ‘v8::Local<v8::Value> v8::Script::Run()’ is deprecated: Use maybe version [-Wdeprecated-declarations]
         return script->Run();
    ../node_modules/nan/nan.h: In function ‘v8::Local<v8::Value> NanMakeCallback(v8::Handle<v8::Object>, v8::Handle<v8::Function>, int, v8::Handle<v8::Value>*)’:
    ../node_modules/nan/nan.h:738:60: warning: ‘v8::Local<v8::Value> node::MakeCallback(v8::Isolate*, v8::Local<v8::Object>, v8::Local<v8::Function>, int, v8::Local<v8::Value>*)’ is deprecated: Use MakeCallback(..., async_context) [-Wdeprecated-declarations]
             v8::Isolate::GetCurrent(), target, func, argc, argv));
    In file included from ../src/bufferutil.cc:8:
    /home/iobroker/.cache/node-gyp/10.19.0/include/node/node.h:177:50: note: declared here
                     NODE_EXTERN v8::Local<v8::Value> MakeCallback(
    /home/iobroker/.cache/node-gyp/10.19.0/include/node/node.h:91:42: note: in definition of macro ‘NODE_DEPRECATED’
         __attribute__((deprecated(message))) declarator
    ../node_modules/nan/nan.h: In function ‘v8::Local<v8::Value> NanMakeCallback(v8::Handle<v8::Object>, v8::Handle<v8::String>, int, v8::Handle<v8::Value>*)’:
    ../node_modules/nan/nan.h:747:62: warning: ‘v8::Local<v8::Value> node::MakeCallback(v8::Isolate*, v8::Local<v8::Object>, v8::Local<v8::String>, int, v8::Local<v8::Value>*)’ is deprecated: Use MakeCallback(..., async_context) [-Wdeprecated-declarations]
             v8::Isolate::GetCurrent(), target, symbol, argc, argv));
    /home/iobroker/.cache/node-gyp/10.19.0/include/node/node.h:170:50: note: declared here
    ../node_modules/nan/nan.h: In function ‘v8::Local<v8::Value> NanMakeCallback(v8::Handle<v8::Object>, const char*, int, v8::Handle<v8::Value>*)’:
    ../node_modules/nan/nan.h:756:62: warning: ‘v8::Local<v8::Value> node::MakeCallback(v8::Isolate*, v8::Local<v8::Object>, const char*, int, v8::Local<v8::Value>*)’ is deprecated: Use MakeCallback(..., async_context) [-Wdeprecated-declarations]
             v8::Isolate::GetCurrent(), target, method, argc, argv));
    /home/iobroker/.cache/node-gyp/10.19.0/include/node/node.h:163:50: note: declared here
    ../node_modules/nan/nan.h: In member function ‘v8::Handle<v8::Value> NanCallback::Call_(v8::Isolate*, v8::Handle<v8::Object>, int, v8::Handle<v8::Value>*) const’:
    ../node_modules/nan/nan.h:1569:5: warning: ‘v8::Local<v8::Value> node::MakeCallback(v8::Isolate*, v8::Local<v8::Object>, v8::Local<v8::Function>, int, v8::Local<v8::Value>*)’ is deprecated: Use MakeCallback(..., async_context) [-Wdeprecated-declarations]
    ../node_modules/nan/nan.h:398:59: note: in definition of macro ‘NanEscapeScope’
     # define NanEscapeScope(val) scope.Escape(_NanEnsureLocal(val))
    ../node_modules/nan/nan.h: In function ‘void NanAsyncQueueWorker(NanAsyncWorker*)’:
    ../node_modules/nan/nan.h:1800:25: warning: cast between incompatible function types from ‘void (*)(uv_work_t*)’ {aka ‘void (*)(uv_work_s*)’} to ‘uv_after_work_cb’ {aka ‘void (*)(uv_work_s*, int)’} [-Wcast-function-type]
         , (uv_after_work_cb)NanAsyncExecuteComplete
    ../node_modules/nan/nan.h: In function ‘void* _NanRawString(v8::Handle<v8::Value>, Nan::Encoding, size_t*, void*, size_t, int)’:
    ../node_modules/nan/nan.h:2164:38: warning: ‘v8::String::Value::Value(v8::Local<v8::Value>)’ is deprecated: Use Isolate version [-Wdeprecated-declarations]
             v8::String::Value value(toStr);
    /home/iobroker/.cache/node-gyp/10.19.0/include/node/v8.h:2916:51: note: declared here
         V8_DEPRECATED("Use Isolate version", explicit Value(Local<v8::Value> obj));
    ../node_modules/nan/nan.h:2198:38: warning: ‘v8::String::Value::Value(v8::Local<v8::Value>)’ is deprecated: Use Isolate version [-Wdeprecated-declarations]
    ../node_modules/nan/nan.h: In constructor ‘NanTap::NanTap(v8::Handle<v8::Value>)’:
    ../node_modules/nan/nan.h:2292:41: warning: ‘v8::Local<v8::Object> v8::Value::ToObject() const’ is deprecated: Use maybe version [-Wdeprecated-declarations]
         NanAssignPersistent(t_, t->ToObject());
    /home/iobroker/.cache/node-gyp/10.19.0/include/node/v8.h:10046:15: note: declared here
     Local<Object> Value::ToObject() const {
    ../src/bufferutil.cc: In static member function ‘static void BufferUtil::Initialize(v8::Handle<v8::Object>)’:
    ../src/bufferutil.cc:30:52: error: call of overloaded ‘NODE_SET_METHOD(v8::Local<v8::FunctionTemplate>&, const char [7], void (&)(const v8::FunctionCallbackInfo<v8::Value>&))’ is ambiguous
         NODE_SET_METHOD(t, "unmask", BufferUtil::Unmask);
    /home/iobroker/.cache/node-gyp/10.19.0/include/node/node.h:372:13: note: candidate: ‘void node::NODE_SET_METHOD(v8::Local<v8::Template>, const char*, v8::FunctionCallback)’
     inline void NODE_SET_METHOD(v8::Local<v8::Template> recv,
    /home/iobroker/.cache/node-gyp/10.19.0/include/node/node.h:386:13: note: candidate: ‘void node::NODE_SET_METHOD(v8::Local<v8::Object>, const char*, v8::FunctionCallback)’
     inline void NODE_SET_METHOD(v8::Local<v8::Object> recv,
    ../src/bufferutil.cc:31:48: error: call of overloaded ‘NODE_SET_METHOD(v8::Local<v8::FunctionTemplate>&, const char [5], void (&)(const v8::FunctionCallbackInfo<v8::Value>&))’ is ambiguous
         NODE_SET_METHOD(t, "mask", BufferUtil::Mask);
    ../src/bufferutil.cc:32:50: error: call of overloaded ‘NODE_SET_METHOD(v8::Local<v8::FunctionTemplate>&, const char [6], void (&)(const v8::FunctionCallbackInfo<v8::Value>&))’ is ambiguous
         NODE_SET_METHOD(t, "merge", BufferUtil::Merge);
    ../src/bufferutil.cc: In static member function ‘static void BufferUtil::Merge(const v8::FunctionCallbackInfo<v8::Value>&)’:
    ../src/bufferutil.cc:49:49: warning: ‘v8::Local<v8::Object> v8::Value::ToObject() const’ is deprecated: Use maybe version [-Wdeprecated-declarations]
         Local<Object> bufferObj = args[0]->ToObject();
    ../src/bufferutil.cc:56:51: warning: ‘v8::Local<v8::Object> v8::Value::ToObject() const’ is deprecated: Use maybe version [-Wdeprecated-declarations]
           Local<Object> src = array->Get(i)->ToObject();
    ../src/bufferutil.cc: In static member function ‘static void BufferUtil::Unmask(const v8::FunctionCallbackInfo<v8::Value>&)’:
    ../src/bufferutil.cc:67:50: warning: ‘v8::Local<v8::Object> v8::Value::ToObject() const’ is deprecated: Use maybe version [-Wdeprecated-declarations]
         Local<Object> buffer_obj = args[0]->ToObject();
    ../src/bufferutil.cc:69:48: warning: ‘v8::Local<v8::Object> v8::Value::ToObject() const’ is deprecated: Use maybe version [-Wdeprecated-declarations]
         Local<Object> mask_obj = args[1]->ToObject();
    ../src/bufferutil.cc: In static member function ‘static void BufferUtil::Mask(const v8::FunctionCallbackInfo<v8::Value>&)’:
    ../src/bufferutil.cc:88:50: warning: ‘v8::Local<v8::Object> v8::Value::ToObject() const’ is deprecated: Use maybe version [-Wdeprecated-declarations]
    ../src/bufferutil.cc:89:48: warning: ‘v8::Local<v8::Object> v8::Value::ToObject() const’ is deprecated: Use maybe version [-Wdeprecated-declarations]
    ../src/bufferutil.cc:91:50: warning: ‘v8::Local<v8::Object> v8::Value::ToObject() const’ is deprecated: Use maybe version [-Wdeprecated-declarations]
         Local<Object> output_obj = args[2]->ToObject();
    ../src/bufferutil.cc:92:51: warning: ‘int32_t v8::Value::Int32Value() const’ is deprecated: Use maybe version [-Wdeprecated-declarations]
         unsigned int dataOffset = args[3]->Int32Value();
    /home/iobroker/.cache/node-gyp/10.19.0/include/node/v8.h:2478:46: note: declared here
       V8_DEPRECATED("Use maybe version", int32_t Int32Value() const);
    ../src/bufferutil.cc:93:47: warning: ‘int32_t v8::Value::Int32Value() const’ is deprecated: Use maybe version [-Wdeprecated-declarations]
         unsigned int length = args[4]->Int32Value();
    ../src/bufferutil.cc: At global scope:
    /home/iobroker/.cache/node-gyp/10.19.0/include/node/node.h:573:43: warning: cast between incompatible function types from ‘void (*)(v8::Handle<v8::Object>)’ {aka ‘void (*)(v8::Local<v8::Object>)’} to ‘node::addon_register_func’ {aka ‘void (*)(v8::Local<v8::Object>, v8::Local<v8::Value>, void*)’} [-Wcast-function-type]
           (node::addon_register_func) (regfunc),                          \
    /home/iobroker/.cache/node-gyp/10.19.0/include/node/node.h:607:3: note: in expansion of macro ‘NODE_MODULE_X’
       NODE_MODULE_X(modname, regfunc, NULL, 0)  // NOLINT (readability/null_usage)
    ../src/bufferutil.cc:120:1: note: in expansion of macro ‘NODE_MODULE’
     NODE_MODULE(bufferutil, init)
    /home/iobroker/.cache/node-gyp/10.19.0/include/node/v8.h: In instantiation of ‘void v8::PersistentBase<T>::SetWeak(P*, typename v8::WeakCallbackInfo<P>::Callback, v8::WeakCallbackType) [with P = node::ObjectWrap; T = v8::Object; typename v8::WeakCallbackInfo<P>::Callback = void (*)(const v8::WeakCallbackInfo<node::ObjectWrap>&)]’:
    /home/iobroker/.cache/node-gyp/10.19.0/include/node/node_object_wrap.h:84:78:   required from here
    /home/iobroker/.cache/node-gyp/10.19.0/include/node/v8.h:9502:16: warning: cast between incompatible function types from ‘v8::WeakCallbackInfo<node::ObjectWrap>::Callback’ {aka ‘void (*)(const v8::WeakCallbackInfo<node::ObjectWrap>&)’} to ‘Callback’ {aka ‘void (*)(const v8::WeakCallbackInfo<void>&)’} [-Wcast-function-type]
                    reinterpret_cast<Callback>(callback), type);
    make: *** [bufferutil.target.mk:103: Release/obj.target/bufferutil/src/bufferutil.o] Fehler 1
    gyp ERR! build error
    gyp ERR! stack Error: `make` failed with exit code: 2
    gyp ERR! stack     at ChildProcess.onExit (/usr/lib/node_modules/npm/node_modules/node-gyp/lib/build.js:191:23)
    gyp ERR! stack     at ChildProcess.emit (events.js:198:13)
    gyp ERR! stack     at Process.ChildProcess._handle.onexit (internal/child_process.js:248:12)
    gyp ERR! System Linux 4.19.97-v7l+
    gyp ERR! command "/usr/bin/node" "/usr/lib/node_modules/npm/node_modules/node-gyp/bin/node-gyp.js" "rebuild"
    gyp ERR! cwd /opt/iobroker/node_modules/bufferutil
    gyp ERR! node -v v10.19.0
    gyp ERR! node-gyp -v v5.0.5
    gyp ERR! not ok
                     from ../src/validation.cc:15:
    In file included from ../src/validation.cc:7:
    In file included from ../src/validation.cc:15:
               WeakCallbackType
                                                      calloc
        uint
    In file included from ../src/validation.cc:10:
                                                char* data,
    In file included from ../src/validation.cc:8:
    ../src/validation.cc: In static member function ‘static void Validation::Initialize(v8::Handle<v8::Object>)’:
    ../src/validation.cc:112:62: error: call of overloaded ‘NODE_SET_METHOD(v8::Local<v8::FunctionTemplate>&, const char [12], void (&)(const v8::FunctionCallbackInfo<v8::Value>&))’ is ambiguous
         NODE_SET_METHOD(t, "isValidUTF8", Validation::IsValidUTF8);
    ../src/validation.cc: In static member function ‘static void Validation::IsValidUTF8(const v8::FunctionCallbackInfo<v8::Value>&)’:
    ../src/validation.cc:132:50: warning: ‘v8::Local<v8::Object> v8::Value::ToObject() const’ is deprecated: Use maybe version [-Wdeprecated-declarations]
    ../src/validation.cc: At global scope:
    ../src/validation.cc:147:1: note: in expansion of macro ‘NODE_MODULE’
     NODE_MODULE(validation, init)
    ../src/validation.cc: In function ‘int is_valid_utf8(size_t, char*)’:
    ../src/validation.cc:82:47: warning: this statement may fall through [-Wimplicit-fallthrough=]
           case 5 : ch += (uint8_t) value[i++]; ch <<= 6;
    ../src/validation.cc:83:7: note: here
           case 4 : ch += (uint8_t) value[i++]; ch <<= 6;
    ../src/validation.cc:83:47: warning: this statement may fall through [-Wimplicit-fallthrough=]
    ../src/validation.cc:84:7: note: here
           case 3 : ch += (uint8_t) value[i++]; ch <<= 6;
    ../src/validation.cc:84:47: warning: this statement may fall through [-Wimplicit-fallthrough=]
    ../src/validation.cc:85:7: note: here
           case 2 : ch += (uint8_t) value[i++]; ch <<= 6;
    ../src/validation.cc:85:47: warning: this statement may fall through [-Wimplicit-fallthrough=]
    ../src/validation.cc:86:7: note: here
           case 1 : ch += (uint8_t) value[i++]; ch <<= 6;
    ../src/validation.cc:86:47: warning: this statement may fall through [-Wimplicit-fallthrough=]
    ../src/validation.cc:87:7: note: here
           case 0 : ch += (uint8_t) value[i];
    ../src/validation.cc: In function ‘int isLegalUTF8(const uint8_t*, int)’:
    ../src/validation.cc:51:11: warning: this statement may fall through [-Wimplicit-fallthrough=]
       case 4: if ((a = (*--srcptr)) < 0x80 || a > 0xBF) return 0;
    ../src/validation.cc:52:3: note: here
       case 3: if ((a = (*--srcptr)) < 0x80 || a > 0xBF) return 0;
    ../src/validation.cc:52:11: warning: this statement may fall through [-Wimplicit-fallthrough=]
    ../src/validation.cc:53:3: note: here
       case 2: if ((a = (*--srcptr)) > 0xBF) return 0;
    ../src/validation.cc:54:5: warning: this statement may fall through [-Wimplicit-fallthrough=]
         switch (*source) {
    ../src/validation.cc:63:3: note: here
       case 1: if (*source >= 0x80 && *source < 0xC2) return 0;
    make: *** [validation.target.mk:103: Release/obj.target/validation/src/validation.o] Fehler 1
    gyp ERR! cwd /opt/iobroker/node_modules/utf-8-validate
    gyp ERR! not ok
    Starting node restart.js
    pi@raspberrypi4-iob:~ $ iobroker start
    Ich muss zugeben, dass ich nicht weiß was ich falsch gemacht habe bzw. was ich jetzt tun muss.
    Danke.
    • K Offline
      kg36304
      Okay, hat scheinbar doch geklappt.
      Danke.
      • K Offline
        knopers1
        @kg36304 said in JS.Controller Update geht nicht:
        solltestdu nich erst in das richrige Verzeichniss wechseln?
        cd /opt/iobroker
        • K knopers1
          cd /opt/iobroker
          AlCalzoneA Offline
          AlCalzoneA Offline
          AlCalzone
          @knopers1 Nicht nötig. Die ioBroker-Kommandos werden automatisch im richtigen Verzeichnis ausgeführt.
          Bei npm install kommt es allerdings aufs Verzeichnis an.
          Warum sudo böse ist: https://forum.iobroker.net/post/17109
