  4. [gelöst] - js-controller nach update nicht mehr zu starten
39 Beiträge 14 Kommentatoren 47.0k Aufrufe 4 Beobachtet
  • stephan1827S stephan1827
    pi@raspberrypi:/opt/iobroker/node_modules $ sudo npm install iobroker.js-controller --production
    npm WARN deprecated request@2.88.2: request has been deprecated, see https://github.com/request/request/issues/3142
    npm WARN deprecated har-validator@5.1.5: this library is no longer supported
    npm WARN deprecated uuid@3.4.0: Please upgrade  to version 7 or higher.  Older versions may use Math.random() in certain circumstances, which is known to be problematic.  See https://v8.dev/blog/math-random for details.
    > iobroker.js-controller@4.0.21 preinstall /opt/iobroker/node_modules/iobroker.js-controller
    > node lib/preinstallCheck.js
    NPM version: 6.14.16
    > iobroker.js-controller@4.0.21 install /opt/iobroker/node_modules/iobroker.js-controller
    > node iobroker.js setup first
    Cannot delete file. Not critical: EACCES: permission denied, unlink '/opt/iobroker/node_modules/iobroker.js-controller/lib/setup/../../_service_iobroker.bat'
    Cannot delete file. Not critical: EACCES: permission denied, unlink '/opt/iobroker/node_modules/iobroker.js-controller/lib/setup/../../iobroker.bat'
    Cannot delete file. Not critical: EACCES: permission denied, unlink '/opt/iobroker/node_modules/iobroker.js-controller/lib/setup/../../iob.bat'
    Uncaught Rejection: Error: EACCES: permission denied, mkdir '/opt/iobroker/node_modules/iobroker.js-controller/lib/setup/../../tmp'
        at Object.mkdirSync (fs.js:921:3)
        at Setup.setup (/opt/iobroker/node_modules/iobroker.js-controller/lib/setup/setupSetup.js:1054:16)
        at processCommand (/opt/iobroker/node_modules/iobroker.js-controller/lib/setup.js:571:23)
        at Object.module.exports.execute (/opt/iobroker/node_modules/iobroker.js-controller/lib/setup.js:3314:5)
        at Object.<anonymous> (/opt/iobroker/node_modules/iobroker.js-controller/iobroker.js:1:24)
        at Module._compile (internal/modules/cjs/loader.js:999:30)
        at Object.Module._extensions..js (internal/modules/cjs/loader.js:1027:10)
        at Module.load (internal/modules/cjs/loader.js:863:32)
        at Function.Module._load (internal/modules/cjs/loader.js:708:14)
        at Function.executeUserEntryPoint [as runMain] (internal/modules/run_main.js:60:12)
    npm WARN optional SKIPPING OPTIONAL DEPENDENCY: fsevents@~2.3.2 (node_modules/chokidar/node_modules/fsevents):
    npm WARN notsup SKIPPING OPTIONAL DEPENDENCY: Unsupported platform for fsevents@2.3.2: wanted {"os":"darwin","arch":"any"} (current: {"os":"linux","arch":"arm"})
    npm WARN optional SKIPPING OPTIONAL DEPENDENCY: fsevents@2.3.2 (node_modules/zigbee-herdsman-converters/node_modules/fsevents):
    npm WARN optional SKIPPING OPTIONAL DEPENDENCY: fsevents@2.3.2 (node_modules/zigbee-herdsman/node_modules/fsevents):
    npm WARN optional SKIPPING OPTIONAL DEPENDENCY: fsevents@2.3.2 (node_modules/zigbee-herdsman-converters/node_modules/zigbee-herdsman/node_modules/fsevents):
    npm ERR! code ELIFECYCLE
    npm ERR! errno 6
    npm ERR! iobroker.js-controller@4.0.21 install: `node iobroker.js setup first`
    npm ERR! Exit status 6
    npm ERR!
    npm ERR! Failed at the iobroker.js-controller@4.0.21 install script.
    npm ERR! This is probably not a problem with npm. There is likely additional logging output above.
    npm ERR!     /root/.npm/_logs/2022-04-29T04_58_56_926Z-debug.log
    Bei mir startet iobroker ebenfalls nicht mehr. Ich habe versucht js neu zu installieren aber bekomme eine Fehlermeldung. Der Ordner /opt/iobroker/node_modules/iobroker.js-controller existiert nicht. Hat jemand noch eine Idee?
    Stephan
    @stephan1827
    Wo kommt der Murks immer her?
    NICHT npm mit sudo anfassen!
    iobroker fix
    Wenn das nicht funktioniert:
    cd /opt/iobroker
    sudo -H -u iobroker npm install iobroker.js-controller
    • stephan1827S Offline
      stephan1827
      @thomas-braun sagte in [gelöst] - js-controller nach update nicht mehr zu starten:
      @stephan1827
      iobroker fix
      cd /opt/iobroker
      Das kommt aus dem 3. Post in diesem Thread. Ohne sudo hat es jetzt geklappt 👍
        @stephan1827
        iobroker fix
        cd /opt/iobroker
        @stephan1827 sagte in [gelöst] - js-controller nach update nicht mehr zu starten:
        Der 6 Jahre alt ist...
        In der Zeit hat sich einiges geändert.
          @stephan1827
          iobroker fix
          cd /opt/iobroker
          Schlimm genug, dass du einen Thread von 2016 nochmal aufwärmst.
          Aber dann noch ungefiltert vollkommen veraltete Anleitungen abarbeiten willst, obwohl du gemerkt hast, dass heute nicht einmal die Datenstruktur stimmt, setzt dem Ganzen noch die Krone auf.
          Es gibt aktuelle Anleitungen, und ein eigener Thread mit spezifischen Fragen hätte dir mehr geholfen.
          FichtendickichtF 1 Antwort Letzte Antwort
            FichtendickichtF Offline
            Fichtendickicht
            "der Installationsfixer: curl -fsL https://iobroker.net/fix.sh | bash -"
            hat mir den Tag gerettet. Danke
            (iobroker auf Synology 6.2 Docker)
            • FichtendickichtF Fichtendickicht
              @fichtendickicht sagte in [gelöst] - js-controller nach update nicht mehr zu starten:
              heute ist der Fixer in ioBroker eingebaut und es reicht iob fix
              A 1 Antwort Letzte Antwort
                adarof
                schrieb am zuletzt editiert von adarof
                Hallo
                ich bin in einem ganz ähnlichen Fehler gelandet:
                iob status
                node:internal/modules/cjs/loader:1143
                  throw err;
                Error: Cannot find module '/opt/iobroker/node_modules/iobroker.js-controller/iobroker.js'
                    at Module._resolveFilename (node:internal/modules/cjs/loader:1140:15)
                    at Module._load (node:internal/modules/cjs/loader:981:27)
                    at Function.executeUserEntryPoint [as runMain] (node:internal/modules/run_main:128:12)
                    at node:internal/main/run_main_module:28:49 {
                  code: 'MODULE_NOT_FOUND',
                  requireStack: []
                Als letztes habe ich (per Weboberfläche direkt von Github ) einen (vermutlich defekten...) Adapter installiert.
                "iob fix" (genau wie curl -fsL https://iobroker.net/fix.sh | bash -) sagt, dass alles gefixed wäre, aber es gibt immernoch den gleichen Fehler:
                ~$ iob status
                  throw err;
                  requireStack: []
                Node.js v18.20.2
                Die Datei iobroker.js ist wirklich nicht in dem angegebenen Verzeichnis vorhanden.
                Kann ich den Js-controller per npm neu installieren? "cd /opt/iobroker && sudo npm ..." oder wie?
                Mein iobroker backup enthält anscheinend keine Kopie des /opt/iobroker-Ordners selber, sodass ich daher nicht einfach wiederherstellen kann.
                Danke + Gruss - Henning
                • A adarof
                  Hallo
                  iob status
                    throw err;
                    requireStack: []
                  ~$ iob status
                    throw err;
                    requireStack: []
                  Node.js v18.20.2
                  @adarof
                  cd /opt/iobroker
                  Und woher bitte nimmst du sowas wie sudo npm???? Bitte NIE, NIE, NIE npm und/oder iobroker-Kommandos mit sudo (ohne -u Option) einleiten.
                    @adarof
                    cd /opt/iobroker
                    adarof
                    @thomas-braun Ähhhh -- schieben wir es auf "Panikmode weil die Heimautomatisierung nicht mehr aufstartet" ? ;-)
                    Danke wieder was gelernt - und vor allem: Gut gefragt zu haben :-)
                    ... und am wichtigsten DANKE, er startet wieder!
                    • A adarof
                      adarof
                      Hi
                      Ich hab das gleiche(?) Problem wieder - diesmal kann ich zwar
                      cd /opt/iobroker
                      durchlaufen lassen:
                      npm warn skipping integrity check for git dependency ssh://git@github.com/eifel-tech/ioBroker.syrconnect.git
                      npm warn skipping integrity check for git dependency ssh://git@github.com/nbuenger/ioBroker.govee.git
                      npm warn deprecated dgram@1.0.1: npm is holding this package for security reasons. As it's a core Node module, we will not transfer it over to other users. You may safely remove the package from your dependencies.
                      npm warn deprecated @npmcli/move-file@1.1.2: This functionality has been moved to @npmcli/fs
                      npm warn deprecated inflight@1.0.6: This module is not supported, and leaks memory. Do not use it. Check out lru-cache if you want a good and tested way to coalesce async requests by a key value, which is much more comprehensive and powerful.
                      npm warn deprecated npmlog@6.0.2: This package is no longer supported.
                      npm warn deprecated har-validator@5.1.5: this library is no longer supported
                      npm warn deprecated rimraf@3.0.2: Rimraf versions prior to v4 are no longer supported
                      npm warn deprecated are-we-there-yet@3.0.1: This package is no longer supported.
                      npm warn deprecated q@1.1.2: You or someone you depend on is using Q, the JavaScript Promise library that gave JavaScript developers strong feelings about promises. They can almost certainly migrate to the native JavaScript promise now. Thank you literally everyone for joining me in this bet against the odds. Be excellent to each other.
                      npm warn deprecated
                      npm warn deprecated (For a CapTP with native promises, see @endo/eventual-send and @endo/captp)
                      npm warn deprecated glob@7.2.3: Glob versions prior to v9 are no longer supported
                      npm warn deprecated glob@8.1.0: Glob versions prior to v9 are no longer supported
                      npm warn deprecated querystring@0.2.1: The querystring API is considered Legacy. new code should use the URLSearchParams API instead.
                      npm warn deprecated node-inspect@2.0.0: This module is part of Node.js core and does not need to be installed separately. It is now unmaintained.
                      npm warn deprecated debug@4.1.1: Debug versions >=3.2.0 <3.2.7 || >=4 <4.3.1 have a low-severity ReDos regression when used in a Node.js environment. It is recommended you upgrade to 3.2.7 or 4.3.1. (https://github.com/visionmedia/debug/issues/797)
                      npm warn deprecated gauge@4.0.4: This package is no longer supported.
                      npm warn deprecated uuid@3.4.0: Please upgrade  to version 7 or higher.  Older versions may use Math.random() in certain circumstances, which is known to be problematic.  See https://v8.dev/blog/math-random for details.
                      npm warn deprecated request@2.88.2: request has been deprecated, see https://github.com/request/request/issues/3142
                      npm warn deprecated sinon@15.2.0: 16.1.1
                      ...ein "iob start" startet zwar auch, da ein "iob status" sagt
                      Objects type: jsonl
                      States  type: jsonl
                      sogar der admin.0 soll laufen:
                      @RoofServer:/opt/iobroker$ iob status admin
                      Instance "admin.0" is running
                      ...aber eine Admin Weboberfläche (und auch meine VIS usw) bekomme ich nicht. Der Webserver läuft einfahc nicht
                      Was könnt ich da wohl noch tun?
                      Gruss
                      • A adarof
                        Hi
                        cd /opt/iobroker
                        durchlaufen lassen:
                        npm warn deprecated
                        Objects type: jsonl
                        States  type: jsonl
                        Gruss
                        @adarof sagte in [gelöst] - js-controller nach update nicht mehr zu starten:
                        Die Langfassung von
                        iob diag
                        anschauen.
                          Die Langfassung von
                          iob diag
                          anschauen.
                          adarof
                          @thomas-braun Danke. Interessant, kannte ich noch nicht. Hat keine Fehler ausgegeben ausser dem hier
                          2024-08-18 19:00:37.075  - error: sql.0 (3013) Cannot insert INSERT INTO `iobroker`.ts_number (id, ts, val, ack, _from, q) VALUES (245, 1724000437013, 20, 1, 28, 0);: Error: Duplicate entry '245-1724000437013' for key 'ts_number.PRIMARY' (id: modbus.1.holdingRegisters.1078_Grid_Power)
                          Zwischenzeitlich ist der Webserver einfach da - der hat min 15min gebraucht (da hatte ich dann für den Abend erstmal aufgegeben), obwohl eigentlich nichts los ist auf dem System. Merkwürdig - heute morgen tat auf einmal alles. Danke abermals!
                          • A adarof
                            bitte die Langfassung hier zeigen!
                            ausser dem hier
                            ist ganz normales iobroker log.
                              ausser dem hier
                              adarof
                              @homoran Hier :) Vor einigen Wochen (Monaten mittlerweile?) hatte ich schon bemerkt, dass die Updates einzelner Adapter jeweils sehr lange brauchen.
                              ======== Start marking the full check here =========
                              Skript v.2024-05-22
                              *** BASE SYSTEM ***
                                 Static hostname: RoofServer
                                       Icon name: computer-desktop
                                         Chassis: desktop
                                Operating System: Ubuntu 20.04.6 LTS
                                          Kernel: Linux 5.4.0-192-generic
                                    Architecture: x86-64
                              model name      : Intel(R) Core(TM) i3-5010U CPU @ 2.10GHz
                              Docker          : false
                              Virtualization  : none
                              Kernel          : x86_64
                              Userland        : 64 bit
                              Systemuptime and Load:
                               19:00:01 up 21:40,  1 user,  load average: 0.49, 0.54, 0.54
                              CPU threads: 4
                              *** Time and Time Zones ***
                                             Local time: Sun 2024-08-18 19:00:01 CEST
                                         Universal time: Sun 2024-08-18 17:00:01 UTC
                                               RTC time: Sun 2024-08-18 17:00:01
                                            NTP service: active
                                        RTC in local TZ: no
                              *** Users and Groups ***
                              User that called 'iob diag':
                              myuser
                              DERBY_HOME=/usr/lib/jvm/java-8-oracle/db
                              JAVA_HOME=/usr/lib/jvm/java-8-oracle
                              HOME=/home/myuser
                              GROUPS=myuser dialout sudo sambashare user iobroker
                              iobroker
                              HOME=/home/iobroker
                              GROUPS=iobroker tty dialout audio video plugdev bluetooth
                              *** Display-Server-Setup ***
                              Display-Server: true
                              Desktop:
                              Terminal:       tty
                              *** MEMORY ***
                              Mem:            15G        5.7G        729M         17M        9.5G        9.9G
                              Swap:          2.0G          0B        2.0G
                              Total:          17G        5.7G        2.8G
                              Active iob-Instances:   41
                                      15883 M total memory
                                       5652 M used memory
                                       8075 M active memory
                                       6177 M inactive memory
                                        729 M free memory
                                       1548 M buffer memory
                                       7953 M swap cache
                                       2047 M total swap
                                          0 M used swap
                                       2047 M free swap
                              top - 19:00:01 up 21:40,  1 user,  load average: 0.49, 0.54, 0.54
                              Tasks: 312 total,   1 running, 311 sleeping,   0 stopped,   0 zombie
                              %Cpu(s):  9.0 us,  3.0 sy,  0.0 ni, 86.6 id,  0.0 wa,  0.0 hi,  1.5 si,  0.0 st
                              MiB Mem :  15883.2 total,    728.8 free,   5652.2 used,   9502.3 buff/cache
                              MiB Swap:   2048.0 total,   2048.0 free,      0.0 used.   9882.1 avail Mem
                              *** FAILED SERVICES ***
                                UNIT                 LOAD   ACTIVE SUB    DESCRIPTION
                              * vncserver@1.service  loaded failed failed Remote desktop service (VNC)
                              * wg-quick@VPN.service loaded failed failed WireGuard via wg-quick(8) for VPN
                              * wg-quick@wg0.service loaded failed failed WireGuard via wg-quick(8) for wg0
                              3 loaded units listed.
                              *** FILESYSTEM ***
                              udev           devtmpfs  7.8G     0  7.8G   0% /dev
                              tmpfs          tmpfs     1.6G  4.1M  1.6G   1% /run
                              /dev/sdb1      ext4      458G   50G  385G  12% /
                              tmpfs          tmpfs     7.8G  616K  7.8G   1% /dev/shm
                              tmpfs          tmpfs     7.8G     0  7.8G   0% /sys/fs/cgroup
                              /dev/loop2     squashfs  105M  105M     0 100% /snap/core/17200
                              /dev/loop4     squashfs   64M   64M     0 100% /snap/core20/2264
                              /dev/loop3     squashfs   56M   56M     0 100% /snap/core18/2829
                              /dev/loop0     squashfs  128K  128K     0 100% /snap/bare/5
                              /dev/loop5     squashfs   56M   56M     0 100% /snap/core18/2823
                              /dev/loop6     squashfs   75M   75M     0 100% /snap/core22/1380
                              /dev/loop1     squashfs  104M  104M     0 100% /snap/core/16928
                              /dev/loop7     squashfs   64M   64M     0 100% /snap/core20/2318
                              /dev/loop8     squashfs  141M  141M     0 100% /snap/gnome-3-26-1604/111
                              /dev/loop9     squashfs  1.7M  1.7M     0 100% /snap/gnome-system-monitor/186
                              /dev/loop10    squashfs  165M  165M     0 100% /snap/gnome-3-28-1804/194
                              /dev/loop11    squashfs  219M  219M     0 100% /snap/gnome-3-34-1804/90
                              /dev/loop12    squashfs  1.5M  1.5M     0 100% /snap/gnome-system-monitor/184
                              /dev/loop13    squashfs  165M  165M     0 100% /snap/gnome-3-28-1804/198
                              /dev/loop14    squashfs  506M  506M     0 100% /snap/gnome-42-2204/176
                              /dev/loop15    squashfs  350M  350M     0 100% /snap/gnome-3-38-2004/143
                              /dev/loop16    squashfs   82M   82M     0 100% /snap/gtk-common-themes/1534
                              /dev/loop17    squashfs  141M  141M     0 100% /snap/gnome-3-26-1604/104
                              /dev/loop19    squashfs  350M  350M     0 100% /snap/gnome-3-38-2004/140
                              /dev/loop18    squashfs  219M  219M     0 100% /snap/gnome-3-34-1804/93
                              /dev/loop20    squashfs  505M  505M     0 100% /snap/gnome-42-2204/172
                              /dev/loop21    squashfs   92M   92M     0 100% /snap/gtk-common-themes/1535
                              /dev/loop22    squashfs   75M   75M     0 100% /snap/core22/1439
                              /dev/sda1      ext4      916G  382G  488G  44% /media/data
                              /dev/sdc1      ext4      4.6T  4.0T  317G  93% /media/storage
                              tmpfs          tmpfs     1.6G   16K  1.6G   1% /run/user/121
                              tmpfs          tmpfs     1.6G     0  1.6G   0% /run/user/999
                              tmpfs          tmpfs     1.6G  4.0K  1.6G   1% /run/user/1002
                              [Sat Aug 17 21:19:49 2024] EXT4-fs (sdb1): mounted filesystem with ordered data mode. Opts: (null)
                              [Sat Aug 17 21:19:49 2024] EXT4-fs (sdb1): re-mounted. Opts: errors=remount-ro
                              [Sat Aug 17 21:19:52 2024] EXT4-fs (sda1): mounted filesystem with ordered data mode. Opts: errors=remount-ro
                              [Sat Aug 17 21:19:53 2024] EXT4-fs (sdc1): mounted filesystem with ordered data mode. Opts: (null)
                              Show mounted filesystems:
                              TARGET                                SOURCE      FSTYPE      OPTIONS
                              /                                     /dev/sdb1   ext4        rw,relatime,errors=remount-ro
                              |-/sys                                sysfs       sysfs       rw,nosuid,nodev,noexec,relatime
                              | |-/sys/kernel/security              securityfs  securityfs  rw,nosuid,nodev,noexec,relatime
                              | |-/sys/fs/cgroup                    tmpfs       tmpfs       ro,nosuid,nodev,noexec,mode=755
                              | | |-/sys/fs/cgroup/unified          cgroup2     cgroup2     rw,nosuid,nodev,noexec,relatime,nsdelegate
                              | | |-/sys/fs/cgroup/systemd          cgroup      cgroup      rw,nosuid,nodev,noexec,relatime,xattr,name=systemd
                              | | |-/sys/fs/cgroup/devices          cgroup      cgroup      rw,nosuid,nodev,noexec,relatime,devices
                              | | |-/sys/fs/cgroup/cpu,cpuacct      cgroup      cgroup      rw,nosuid,nodev,noexec,relatime,cpu,cpuacct
                              | | |-/sys/fs/cgroup/perf_event       cgroup      cgroup      rw,nosuid,nodev,noexec,relatime,perf_event
                              | | |-/sys/fs/cgroup/hugetlb          cgroup      cgroup      rw,nosuid,nodev,noexec,relatime,hugetlb
                              | | |-/sys/fs/cgroup/net_cls,net_prio cgroup      cgroup      rw,nosuid,nodev,noexec,relatime,net_cls,net_prio
                              | | |-/sys/fs/cgroup/pids             cgroup      cgroup      rw,nosuid,nodev,noexec,relatime,pids
                              | | |-/sys/fs/cgroup/freezer          cgroup      cgroup      rw,nosuid,nodev,noexec,relatime,freezer
                              | | |-/sys/fs/cgroup/cpuset           cgroup      cgroup      rw,nosuid,nodev,noexec,relatime,cpuset
                              | | |-/sys/fs/cgroup/blkio            cgroup      cgroup      rw,nosuid,nodev,noexec,relatime,blkio
                              | | |-/sys/fs/cgroup/rdma             cgroup      cgroup      rw,nosuid,nodev,noexec,relatime,rdma
                              | | `-/sys/fs/cgroup/memory           cgroup      cgroup      rw,nosuid,nodev,noexec,relatime,memory
                              | |-/sys/fs/pstore                    pstore      pstore      rw,nosuid,nodev,noexec,relatime
                              | |-/sys/fs/bpf                       none        bpf         rw,nosuid,nodev,noexec,relatime,mode=700
                              | |-/sys/kernel/debug                 debugfs     debugfs     rw,nosuid,nodev,noexec,relatime
                              | |-/sys/kernel/tracing               tracefs     tracefs     rw,nosuid,nodev,noexec,relatime
                              | |-/sys/fs/fuse/connections          fusectl     fusectl     rw,nosuid,nodev,noexec,relatime
                              | `-/sys/kernel/config                configfs    configfs    rw,nosuid,nodev,noexec,relatime
                              |-/proc                               proc        proc        rw,nosuid,nodev,noexec,relatime
                              | |-/proc/sys/fs/binfmt_misc          systemd-1   autofs      rw,relatime,fd=28,pgrp=1,timeout=0,minproto=5,maxproto=5,direct,pipe_ino=16849
                              | | `-/proc/sys/fs/binfmt_misc        binfmt_misc binfmt_misc rw,nosuid,nodev,noexec,relatime
                              | `-/proc/fs/nfsd                     nfsd        nfsd        rw,relatime
                              |-/dev                                udev        devtmpfs    rw,nosuid,noexec,relatime,size=8085972k,nr_inodes=2021493,mode=755
                              | |-/dev/pts                          devpts      devpts      rw,nosuid,noexec,relatime,gid=5,mode=620,ptmxmode=000
                              | |-/dev/shm                          tmpfs       tmpfs       rw,nosuid,nodev
                              | |-/dev/hugepages                    hugetlbfs   hugetlbfs   rw,relatime,pagesize=2M
                              | `-/dev/mqueue                       mqueue      mqueue      rw,nosuid,nodev,noexec,relatime
                              |-/run                                tmpfs       tmpfs       rw,nosuid,nodev,noexec,relatime,size=1626448k,mode=755
                              | |-/run/lock                         tmpfs       tmpfs       rw,nosuid,nodev,noexec,relatime,size=5120k
                              | |-/run/rpc_pipefs                   sunrpc      rpc_pipefs  rw,relatime
                              | |-/run/user/1002                    tmpfs       tmpfs       rw,nosuid,nodev,relatime,size=1626444k,mode=700,uid=1002,gid=1002
                              | |-/run/user/121                     tmpfs       tmpfs       rw,nosuid,nodev,relatime,size=1626444k,mode=700,uid=121,gid=125
                              | `-/run/user/999                     tmpfs       tmpfs       rw,nosuid,nodev,relatime,size=1626444k,mode=700,uid=999,gid=999
                              |-/snap/core/17200                    /dev/loop2  squashfs    ro,nodev,relatime
                              |-/snap/core20/2264                   /dev/loop4  squashfs    ro,nodev,relatime
                              |-/snap/core18/2829                   /dev/loop3  squashfs    ro,nodev,relatime
                              |-/snap/bare/5                        /dev/loop0  squashfs    ro,nodev,relatime
                              |-/snap/core18/2823                   /dev/loop5  squashfs    ro,nodev,relatime
                              |-/snap/core22/1380                   /dev/loop6  squashfs    ro,nodev,relatime
                              |-/snap/core/16928                    /dev/loop1  squashfs    ro,nodev,relatime
                              |-/snap/core20/2318                   /dev/loop7  squashfs    ro,nodev,relatime
                              |-/snap/gnome-3-26-1604/111           /dev/loop8  squashfs    ro,nodev,relatime
                              |-/snap/gnome-system-monitor/186      /dev/loop9  squashfs    ro,nodev,relatime
                              |-/snap/gnome-3-28-1804/194           /dev/loop10 squashfs    ro,nodev,relatime
                              |-/snap/gnome-3-34-1804/90            /dev/loop11 squashfs    ro,nodev,relatime
                              |-/snap/gnome-system-monitor/184      /dev/loop12 squashfs    ro,nodev,relatime
                              |-/snap/gnome-3-28-1804/198           /dev/loop13 squashfs    ro,nodev,relatime
                              |-/snap/gnome-42-2204/176             /dev/loop14 squashfs    ro,nodev,relatime
                              |-/snap/gnome-3-38-2004/143           /dev/loop15 squashfs    ro,nodev,relatime
                              |-/snap/gtk-common-themes/1534        /dev/loop16 squashfs    ro,nodev,relatime
                              |-/snap/gnome-3-26-1604/104           /dev/loop17 squashfs    ro,nodev,relatime
                              |-/snap/gnome-3-38-2004/140           /dev/loop19 squashfs    ro,nodev,relatime
                              |-/snap/gnome-3-34-1804/93            /dev/loop18 squashfs    ro,nodev,relatime
                              |-/snap/gnome-42-2204/172             /dev/loop20 squashfs    ro,nodev,relatime
                              |-/snap/gtk-common-themes/1535        /dev/loop21 squashfs    ro,nodev,relatime
                              |-/snap/core22/1439                   /dev/loop22 squashfs    ro,nodev,relatime
                              |-/media/data                         /dev/sda1   ext4        rw,relatime,errors=remount-ro
                              `-/media/storage                      /dev/sdc1   ext4        rw,nosuid,nodev,relatime
                              /var:
                              22G     /var/
                              17G     /var/lib
                              5.6G    /var/lib/unifi
                              5.4G    /var/lib/unifi/db
                              5.0G    /var/lib/snapd
                              Archived and active journals take up 120.0M in the file system.
                              /opt/iobroker/backups:
                              3.0G    /opt/iobroker/backups/
                              4.0K    /opt/iobroker/backups/redistmp
                              /opt/iobroker/iobroker-data:
                              1.2G    /opt/iobroker/iobroker-data/
                              787M    /opt/iobroker/iobroker-data/files
                              441M    /opt/iobroker/iobroker-data/files/javascript.admin
                              409M    /opt/iobroker/iobroker-data/files/javascript.admin/static
                              408M    /opt/iobroker/iobroker-data/files/javascript.admin/static/js
                              52M     /opt/iobroker/iobroker-data/objects.jsonl
                              41M     /opt/iobroker/iobroker-data/files/material/static/js/main.c5478f66.js.map
                              29M     /opt/iobroker/iobroker-data/states.jsonl
                              28M     /opt/iobroker/iobroker-data/sqlite/sqlite.db
                              27M     /opt/iobroker/iobroker-data/files/backitup.admin/static/js/main.ce422ec2.js.map
                              USB-Devices by-id:
                              No Devices found 'by-id'
                              HINT:
                              Your zigbee.0 COM-Port is NOT matching 'by-id'. Please check your setting:
                              /dev/ttyACM0
                              *** NodeJS-Installation ***
                              /usr/bin/nodejs         v18.20.4
                              /usr/bin/node           v18.20.4
                              /usr/bin/npm            10.7.0
                              /usr/bin/npx            10.7.0
                              /usr/bin/corepack       0.28.0
                              nodejs:
                                Installed: 18.20.4-1nodesource1
                                Candidate: 18.20.4-1nodesource1
                                Version table:
                               *** 18.20.4-1nodesource1 1001
                                      500 https://deb.nodesource.com/node_18.x nodistro/main amd64 Packages
                                      100 /var/lib/dpkg/status
                                   18.20.3-1nodesource1 1001
                                   18.20.2-1nodesource1 1001
                                   18.20.1-1nodesource1 1001
                                   18.20.0-1nodesource1 1001
                                   18.19.1-1nodesource1 1001
                                   18.19.0-1nodesource1 1001
                                   18.18.2-1nodesource1 1001
                                   18.18.1-1nodesource1 1001
                                   18.18.0-1nodesource1 1001
                                   18.17.1-1nodesource1 1001
                                   18.17.0-1nodesource1 1001
                                   18.16.1-1nodesource1 1001
                                   18.16.0-1nodesource1 1001
                                   18.15.0-1nodesource1 1001
                                   18.14.2-1nodesource1 1001
                                   18.14.1-1nodesource1 1001
                                   18.14.0-1nodesource1 1001
                                   18.13.0-1nodesource1 1001
                                   18.12.0-1nodesource1 1001
                                   18.11.0-1nodesource1 1001
                                   18.10.0-1nodesource1 1001
                                   18.9.1-1nodesource1 1001
                                   18.9.0-1nodesource1 1001
                                   18.8.0-1nodesource1 1001
                                   18.7.0-1nodesource1 1001
                                   18.6.0-1nodesource1 1001
                                   18.5.0-1nodesource1 1001
                                   18.4.0-1nodesource1 1001
                                   18.3.0-1nodesource1 1001
                                   18.2.0-1nodesource1 1001
                                   18.1.0-1nodesource1 1001
                                   18.0.0-1nodesource1 1001
                                   10.19.0~dfsg-3ubuntu1.6 500
                                      500 http://de.archive.ubuntu.com/ubuntu focal-updates/universe amd64 Packages
                                      500 http://security.ubuntu.com/ubuntu focal-security/universe amd64 Packages
                                   10.19.0~dfsg-3ubuntu1 500
                                      500 http://de.archive.ubuntu.com/ubuntu focal/universe amd64 Packages
                              No problems detected
                              Errors in npm tree:
                              *** ioBroker-Installation ***
                              ioBroker Status
                              Objects type: jsonl
                              States  type: jsonl
                              Core adapters versions
                              js-controller:  6.0.10
                              admin:          7.0.22
                              javascript:     8.7.6
                              nodejs modules from github:     1
                              |   `-- xmlbuilder@0.4.2 invalid: "https://github.com/hobbyquaker/xmlbuilder-js/tarball/29fe5030dc6852007dc8d1bfd5109d75f8da58d5" from node_modules/homematic-xmlrpc
                              Adapter State
                              + system.adapter.admin.0                  : admin                 : RoofServer                               -  enabled, port: 8081, bind: 0.0.0.0, run as: admin
                              + system.adapter.alexa2.0                 : alexa2                : RoofServer                               -  enabled
                              + system.adapter.backitup.0               : backitup              : RoofServer                               -  enabled
                                system.adapter.cloudflare.0             : cloudflare            : RoofServer                               - disabled
                                system.adapter.daswetter.0              : daswetter             : RoofServer                               -  enabled
                              + system.adapter.discovery.0              : discovery             : RoofServer                               -  enabled
                                system.adapter.dwd.0                    : dwd                   : RoofServer                               -  enabled
                              + system.adapter.easee.1                  : easee                 : RoofServer                               -  enabled
                              + system.adapter.email.0                  : email                 : RoofServer                               -  enabled
                              + system.adapter.evcc.0                   : evcc                  : RoofServer                               -  enabled, port: 7070
                                system.adapter.flot.0                   : flot                  : RoofServer                               -  enabled
                              + system.adapter.govee.0                  : govee                 : RoofServer                               -  enabled
                              + system.adapter.ham.0                    : ham                   : RoofServer                               -  enabled
                              + system.adapter.history.0                : history               : RoofServer                               -  enabled
                              + system.adapter.hm-rega.0                : hm-rega               : RoofServer                               -  enabled
                              + system.adapter.hm-rpc.0                 : hm-rpc                : RoofServer                               -  enabled, port: 18701
                              + system.adapter.hm-rpc.1                 : hm-rpc                : RoofServer                               -  enabled, port: 12001
                              + system.adapter.hm-rpc.2                 : hm-rpc                : RoofServer                               -  enabled, port: 0
                              + system.adapter.homeconnect.0            : homeconnect           : RoofServer                               -  enabled
                                system.adapter.ical.0                   : ical                  : RoofServer                               -  enabled
                                system.adapter.icons-addictive-flavour-png.0: icons-addictive-flavour-png: RoofServer                               -  enabled
                                system.adapter.icons-material-png.0     : icons-material-png    : RoofServer                               -  enabled
                                system.adapter.icons-mfd-png.0          : icons-mfd-png         : RoofServer                               -  enabled
                                system.adapter.icons-mfd-svg.0          : icons-mfd-svg         : RoofServer                               -  enabled
                              + system.adapter.javascript.0             : javascript            : RoofServer                               -  enabled
                              + system.adapter.klf200.0                 : klf200                : RoofServer                               -  enabled
                              + system.adapter.lg-thinq.0               : lg-thinq              : RoofServer                               -  enabled
                                system.adapter.material.0               : material              : RoofServer                               -  enabled
                              + system.adapter.mielecloudservice.0      : mielecloudservice     : RoofServer                               -  enabled
                                system.adapter.mobile.0                 : mobile                : RoofServer                               -  enabled
                              + system.adapter.modbus.0                 : modbus                : RoofServer                               -  enabled
                              + system.adapter.modbus.1                 : modbus                : RoofServer                               -  enabled
                              + system.adapter.nina.0                   : nina                  : RoofServer                               -  enabled
                              + system.adapter.nut.0                    : nut                   : RoofServer                               -  enabled
                              + system.adapter.opendtu.0                : opendtu               : RoofServer                               -  enabled
                              + system.adapter.parser.0                 : parser                : RoofServer                               -  enabled
                              + system.adapter.ping.0                   : ping                  : RoofServer                               -  enabled
                                system.adapter.rickshaw.0               : rickshaw              : RoofServer                               -  enabled
                              + system.adapter.simple-api.0             : simple-api            : RoofServer                               -  enabled, port: 8087, bind: 0.0.0.0, run as: admin
                              + system.adapter.sonoff.0                 : sonoff                : RoofServer                               -  enabled, port: 1883, bind: 192.168.66.75
                              + system.adapter.sql.0                    : sql                   : RoofServer                               -  enabled, port: 0
                              + system.adapter.telegram.0               : telegram              : RoofServer                               -  enabled, port: 8443, bind: 0.0.0.0
                              + system.adapter.text2command.0           : text2command          : RoofServer                               -  enabled
                              + system.adapter.tr-064.0                 : tr-064                : RoofServer                               -  enabled
                              + system.adapter.tuya.0                   : tuya                  : RoofServer                               -  enabled
                              + system.adapter.unifi.0                  : unifi                 : RoofServer                               -  enabled
                                system.adapter.vis-bars.0               : vis-bars              : RoofServer                               -  enabled
                                system.adapter.vis-canvas-gauges.0      : vis-canvas-gauges     : RoofServer                               -  enabled
                                system.adapter.vis-colorpicker.0        : vis-colorpicker       : RoofServer                               -  enabled
                                system.adapter.vis-fancyswitch.0        : vis-fancyswitch       : RoofServer                               -  enabled
                                system.adapter.vis-history.0            : vis-history           : RoofServer                               -  enabled
                                system.adapter.vis-hqwidgets.0          : vis-hqwidgets         : RoofServer                               -  enabled
                                system.adapter.vis-jqui-mfd.0           : vis-jqui-mfd          : RoofServer                               -  enabled
                                system.adapter.vis-metro.0              : vis-metro             : RoofServer                               -  enabled
                                system.adapter.vis-rgraph.0             : vis-rgraph            : RoofServer                               -  enabled
                                system.adapter.vis-timeandweather.0     : vis-timeandweather    : RoofServer                               -  enabled
                                system.adapter.vis.0                    : vis                   : RoofServer                               -  enabled
                              + system.adapter.vw-connect.0             : vw-connect            : RoofServer                               -  enabled
                              + system.adapter.web.0                    : web                   : RoofServer                               -  enabled, port: 8082, bind: 0.0.0.0 (SSL), run as: admin
                              + system.adapter.wiegand-tcpip.0          : wiegand-tcpip         : RoofServer                               -  enabled, port: 60000, bind: 192.168.66.75
                              + system.adapter.wifilight.0              : wifilight             : RoofServer                               -  enabled
                              + system.adapter.wireguard.0              : wireguard             : RoofServer                               -  enabled
                              + system.adapter.zigbee.0                 : zigbee                : RoofServer                               -  enabled, port: /dev/ttyACM0
                              + instance is alive
                              ioBroker-Repositories
                              │ (index) │   name    │                                             url                                             │ auto upgrade │
                              │    0    │ 'sources' │                                  'conf/sources-dist.json'                                   │    false     │
                              │    1    │ 'online'  │ 'https://raw.githubusercontent.com/ioBroker/ioBroker.repositories/master/sources-dist.json' │    false     │
                              │    2    │ 'stable'  │                      'http://download.iobroker.net/sources-dist.json'                       │    false     │
                              │    3    │  'beta'   │                   'http://download.iobroker.net/sources-dist-latest.json'                   │    false     │
                              Active repo(s): stable
                              Upgrade policy: none
                              Installed ioBroker-Instances
                              Used repository: stable
                              Cannot download repository hash file from "http://download.iobroker.net/sources-dist-hash.json": timeout of 10000ms exceeded
                              Adapter    "admin"        : 7.0.22   , installed 7.0.22
                              Adapter    "alexa2"       : 3.26.5   , installed 3.26.5
                              Adapter    "amazon-dash"  : 1.2.0    , installed 1.2.0
                              Adapter    "backitup"     : 3.0.16   , installed 3.0.16
                              Adapter    "cloudflare"   : 1.1.1    , installed 1.2.1
                              Adapter    "daswetter"    : 3.1.15   , installed 3.1.15
                              Adapter    "discovery"    : 4.5.0    , installed 4.5.0
                              Adapter    "easee"        : 1.0.10   , installed 1.0.10
                              Adapter    "email"        : 1.3.1    , installed 1.3.1
                              Adapter    "evcc"         : 0.1.1    , installed 0.1.1
                              Adapter    "ham"          : 5.3.1    , installed 5.3.1
                              Adapter    "hm-rega"      : 4.0.0    , installed 4.0.0
                              Adapter    "hm-rpc"       : 1.17.0   , installed 1.17.0
                              Adapter    "homeconnect"  : 1.4.1    , installed 1.4.1
                              Adapter    "ical"         : 1.15.0   , installed 1.15.0
                              Adapter    "icons-addictive-flavour-png": 0.1.0, installed 0.1.0
                              Adapter    "icons-material-png": 0.1.0, installed 0.1.0
                              Adapter    "icons-mfd-png": 1.2.1    , installed 1.2.1
                              Adapter    "javascript"   : 8.7.6    , installed 8.7.6
                              Controller "js-controller": 6.0.9    , installed 6.0.10
                              Adapter    "klf200"       : 1.2.0    , installed 1.2.0
                              Adapter    "lg-thinq"     : 1.0.1    , installed 1.0.1
                              Adapter    "material"     : 1.3.1    , installed 1.3.1
                              Adapter    "mielecloudservice": 6.5.6, installed 6.5.6
                              Adapter    "mobile"       : 1.0.1    , installed 1.0.1
                              Adapter    "modbus"       : 6.2.3    , installed 6.2.3
                              Adapter    "nina"         : 0.0.25   , installed 0.0.25
                              Adapter    "nut"          : 1.6.0    , installed 1.6.0
                              Adapter    "opendtu"      : 1.0.1    , installed 1.0.1
                              Adapter    "parser"       : 2.2.2    , installed 2.2.2
                              Adapter    "rickshaw"     : 1.0.0    , installed 1.0.0
                              Adapter    "rpi2"         : 1.3.2    , installed 1.3.2
                              Adapter    "sbfspot"      : 4.3.3    , installed 4.3.3
                              Adapter    "socketio"     : 6.7.1    , installed 6.7.1
                              Adapter    "solarmanpv"   : 0.5.1    , installed 0.5.1
                              Adapter    "sonoff"       : 3.1.0    , installed 3.1.0
                              Adapter    "sql"          : 3.0.1    , installed 3.0.1
                              Adapter    "telegram"     : 3.9.0    , installed 3.3.2  [Updatable]
                              Adapter    "text2command" : 3.0.3    , installed 3.0.3
                              Adapter    "tuya"         : 3.16.0   , installed 3.15.0 [Updatable]
                              Adapter    "unifi"        : 0.7.0    , installed 0.7.0
                              Adapter    "vis-colorpicker": 2.0.3  , installed 2.0.3
                              Adapter    "vis-jqui-mfd" : 1.1.1    , installed 1.1.1
                              Adapter    "vis-rgraph"   : 0.0.2    , installed 0.0.2
                              Adapter    "wiegand-tcpip": 0.4.6    , installed 0.4.6
                              Adapter    "wifilight"    : 1.2.2    , installed 1.2.2
                              Adapter    "wireguard"    : 1.6.4    , installed 1.6.4
                              Adapter    "ws"           : 2.6.2    , installed 2.6.2
                              Adapter    "zigbee"       : 1.10.3   , installed 1.10.3
                              Objects and States
                              Objects:        48180
                              States:         41750
                              Hit:2 http://de.archive.ubuntu.com/ubuntu focal InRelease
                              Hit:3 http://dl.google.com/linux/chrome/deb stable InRelease
                              Hit:4 http://de.archive.ubuntu.com/ubuntu focal-updates InRelease
                              Hit:5 https://deb.nodesource.com/node_18.x nodistro InRelease
                              Hit:6 http://de.archive.ubuntu.com/ubuntu focal-backports InRelease
                              Hit:7 http://security.ubuntu.com/ubuntu focal-security InRelease
                              Hit:8 http://repo.feed.flightradar24.com flightradar24 InRelease
                              Get:9 https://dl.cloudsmith.io/public/tvheadend/tvheadend/deb/ubuntu focal InRelease [4418 B]
                              Hit:1 https://dl.ui.com/unifi/debian stable InRelease
                              Fetched 4418 B in 16s (280 B/s)
                              Reading package lists...
                              Pending Updates: 2
                              *** Listening Ports ***
                              tcp        0      0 0.0.0.0:143             0.0.0.0:*               LISTEN      0          40956      1908/dovecot
                              tcp        0      0 0.0.0.0:111             0.0.0.0:*               LISTEN      0          371        1/init
                              tcp        0      0 0.0.0.0:80              0.0.0.0:*               LISTEN      0          45238      1998/lighttpd
                              tcp        0      0 0.0.0.0:56081           0.0.0.0:*               LISTEN      0          29519      1413/rpc.mountd
                              tcp        0      0 0.0.0.0:44659           0.0.0.0:*               LISTEN      0          34990      -
                              tcp        0      0 0.0.0.0:53              0.0.0.0:*               LISTEN      999        43001      2193/pihole-FTL
                              tcp        0      0 0.0.0.0:22              0.0.0.0:*               LISTEN      0          34038      1406/sshd: /usr/sbi
                              tcp        0      0 0.0.0.0:631             0.0.0.0:*               LISTEN      0          163515     10769/cupsd
                              tcp        0      0 0.0.0.0:2010            0.0.0.0:*               LISTEN      1001       50070      3227/io.hm-rpc.2
                              tcp        0      0 192.168.66.75:1883      0.0.0.0:*               LISTEN      1001       50040      3043/io.sonoff.0
                              tcp        0      0 0.0.0.0:443             0.0.0.0:*               LISTEN      0          45239      1998/lighttpd
                              tcp        0      0 0.0.0.0:445             0.0.0.0:*               LISTEN      0          41351      2086/smbd
                              tcp        0      0 0.0.0.0:9981            0.0.0.0:*               LISTEN      0          34735      1506/tvheadend
                              tcp        0      0 0.0.0.0:42333           0.0.0.0:*               LISTEN      0          29532      1413/rpc.mountd
                              tcp        0      0 0.0.0.0:9982            0.0.0.0:*               LISTEN      0          34739      1506/tvheadend
                              tcp        0      0 0.0.0.0:6080            0.0.0.0:*               LISTEN      1002       39133      1672/python3
                              tcp        0      0 0.0.0.0:12001           0.0.0.0:*               LISTEN      1001       50580      2738/io.hm-rpc.1
                              tcp        0      0 0.0.0.0:993             0.0.0.0:*               LISTEN      0          40958      1908/dovecot
                              tcp        0      0 0.0.0.0:2049            0.0.0.0:*               LISTEN      0          36873      -
                              tcp        0      0 0.0.0.0:56801           0.0.0.0:*               LISTEN      0          29546      1413/rpc.mountd
                              tcp        0      0 127.0.0.1:33060         0.0.0.0:*               LISTEN      124        39328      1547/mysqld
                              tcp        0      0 127.0.0.1:3493          0.0.0.0:*               LISTEN      0          39140      1674/upsd
                              tcp        0      0 127.0.0.1:4711          0.0.0.0:*               LISTEN      999        41434      2193/pihole-FTL
                              tcp        0      0 0.0.0.0:9000            0.0.0.0:*               LISTEN      1001       45854      1369/iobroker.js-co
                              tcp        0      0 0.0.0.0:9001            0.0.0.0:*               LISTEN      1001       45421      1369/iobroker.js-co
                              tcp        0      0 127.0.0.1:27017         0.0.0.0:*               LISTEN      125        36916      1371/mongod
                              tcp        0      0 127.0.0.1:3306          0.0.0.0:*               LISTEN      124        40403      1547/mysqld
                              tcp        0      0 0.0.0.0:139             0.0.0.0:*               LISTEN      0          41352      2086/smbd
                              tcp        0      0 0.0.0.0:18701           0.0.0.0:*               LISTEN      1001       48987      2721/io.hm-rpc.0
                              tcp        0      0 127.0.0.1:27117         0.0.0.0:*               LISTEN      126        49442      2490/bin/mongod
                              tcp6       0      0 :::143                  :::*                    LISTEN      0          40957      1908/dovecot
                              tcp6       0      0 :::58031                :::*                    LISTEN      0          29539      1413/rpc.mountd
                              tcp6       0      0 :::111                  :::*                    LISTEN      0          375        1/init
                              tcp6       0      0 :::8880                 :::*                    LISTEN      126        47344      1499/java
                              tcp6       0      0 :::8080                 :::*                    LISTEN      126        47343      1499/java
                              tcp6       0      0 :::80                   :::*                    LISTEN      0          45240      1998/lighttpd
                              tcp6       0      0 :::8081                 :::*                    LISTEN      1001       49993      2750/io.admin.0
                              tcp6       0      0 :::8082                 :::*                    LISTEN      1001       55340      3694/io.web.0
                              tcp6       0      0 :::8754                 :::*                    LISTEN      997        44532      2060/fr24feed
                              tcp6       0      0 :::40787                :::*                    LISTEN      0          34992      -
                              tcp6       0      0 :::53                   :::*                    LISTEN      999        43003      2193/pihole-FTL
                              tcp6       0      0 ::1:3350                :::*                    LISTEN      0          34134      1434/xrdp-sesman
                              tcp6       0      0 :::22                   :::*                    LISTEN      0          34049      1406/sshd: /usr/sbi
                              tcp6       0      0 :::631                  :::*                    LISTEN      0          163516     10769/cupsd
                              tcp6       0      0 :::8087                 :::*                    LISTEN      1001       55129      3855/io.simple-api.
                              tcp6       0      0 :::53977                :::*                    LISTEN      0          29525      1413/rpc.mountd
                              tcp6       0      0 :::8443                 :::*                    LISTEN      126        48394      1499/java
                              tcp6       0      0 :::3389                 :::*                    LISTEN      127        37136      1479/xrdp
                              tcp6       0      0 :::34653                :::*                    LISTEN      0          29552      1413/rpc.mountd
                              tcp6       0      0 :::445                  :::*                    LISTEN      0          41349      2086/smbd
                              tcp6       0      0 :::7070                 :::*                    LISTEN      141        47218      1914/evcc
                              tcp6       0      0 :::993                  :::*                    LISTEN      0          40959      1908/dovecot
                              tcp6       0      0 :::2049                 :::*                    LISTEN      0          34987      -
                              tcp6       0      0 :::6789                 :::*                    LISTEN      126        50449      1499/java
                              tcp6       0      0 ::1:4711                :::*                    LISTEN      999        46092      2193/pihole-FTL
                              tcp6       0      0 :::8843                 :::*                    LISTEN      126        48399      1499/java
                              tcp6       0      0 :::139                  :::*                    LISTEN      0          41350      2086/smbd
                              udp        0      0 0.0.0.0:43959           0.0.0.0:*                           0          34989      -
                              udp        0      0 0.0.0.0:44004           0.0.0.0:*                           116        29004      1212/avahi-daemon:
                              udp        0      0 0.0.0.0:60434           0.0.0.0:*                           137        45866      1506/tvheadend
                              udp        0      0 0.0.0.0:45886           0.0.0.0:*                           997        45401      2060/fr24feed
                              udp        0      0 0.0.0.0:46190           0.0.0.0:*                           997        45888      2060/fr24feed
                              udp        0      0 192.168.66.75:5353      0.0.0.0:*                           1001       50403      2660/io.tr-064.0
                              udp        0      0 0.0.0.0:5353            0.0.0.0:*                           141        47212      1914/evcc
                              udp        0      0 0.0.0.0:5353            0.0.0.0:*                           116        29002      1212/avahi-daemon:
                              udp        0      0 0.0.0.0:6666            0.0.0.0:*                           1001       54745      3569/io.tuya.0
                              udp        0      0 0.0.0.0:6667            0.0.0.0:*                           1001       54746      3569/io.tuya.0
                              udp        0      0 0.0.0.0:53              0.0.0.0:*                           999        43000      2193/pihole-FTL
                              udp        0      0 0.0.0.0:68              0.0.0.0:*                           0          40101      1423/dhcpcd
                              udp        0      0 0.0.0.0:111             0.0.0.0:*                           0          372        1/init
                              udp        0      0 192.168.66.255:137      0.0.0.0:*                           0          42390      1931/nmbd
                              udp        0      0 192.168.66.75:137       0.0.0.0:*                           0          42389      1931/nmbd
                              udp        0      0 0.0.0.0:137             0.0.0.0:*                           0          42377      1931/nmbd
                              udp        0      0 192.168.66.255:138      0.0.0.0:*                           0          42392      1931/nmbd
                              udp        0      0 192.168.66.75:138       0.0.0.0:*                           0          42391      1931/nmbd
                              udp        0      0 0.0.0.0:138             0.0.0.0:*                           0          42378      1931/nmbd
                              udp        0      0 0.0.0.0:631             0.0.0.0:*                           0          166376     10770/cups-browsed
                              udp        0      0 0.0.0.0:58040           0.0.0.0:*                           0          29516      1413/rpc.mountd
                              udp        0      0 0.0.0.0:58609           0.0.0.0:*                           0          29528      1413/rpc.mountd
                              udp        0      0 239.255.255.250:1900    0.0.0.0:*                           137        45863      1506/tvheadend
                              udp        0      0 0.0.0.0:2049            0.0.0.0:*                           0          34986      -
                              udp        0      0 192.168.66.75:60001     0.0.0.0:*                           1001       53974      3910/io.wiegand-tcp
                              udp        0      0 0.0.0.0:51899           0.0.0.0:*                           0          29543      1413/rpc.mountd
                              udp6       0      0 :::60415                :::*                                0          29536      1413/rpc.mountd
                              udp6       0      0 :::3478                 :::*                                126        49578      1499/java
                              udp6       0      0 :::36817                :::*                                0          29549      1413/rpc.mountd
                              udp6       0      0 :::53360                :::*                                0          34991      -
                              udp6       0      0 :::5353                 :::*                                141        47213      1914/evcc
                              udp6       0      0 :::5353                 :::*                                116        29003      1212/avahi-daemon:
                              udp6       0      0 192.168.66.75:48465     :::*                                126        49619      1499/java
                              udp6       0      0 :::53                   :::*                                999        43002      2193/pihole-FTL
                              udp6       0      0 :::111                  :::*                                0          378        1/init
                              udp6       0      0 :::33653                :::*                                116        29005      1212/avahi-daemon:
                              udp6       0      0 :::58880                :::*                                0          29522      1413/rpc.mountd
                              udp6       0      0 :::10001                :::*                                126        49620      1499/java
                              udp6       0      0 :::2049                 :::*                                0          34988      -
                              2024-08-18 18:48:04.363  - warn: wireguard.0 (3644) Error: All configured authentication methods failed
                              2024-08-18 18:50:04.362  - warn: wireguard.0 (3644) Error: All configured authentication methods failed
                              2024-08-18 18:50:19.017  - info: host.RoofServer instance system.adapter.dwd.0 in version "2.8.5" started with pid 53151
                              2024-08-18 18:50:33.302  - info: host.RoofServer instance system.adapter.dwd.0 having pid 53151 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
                              2024-08-18 18:50:53.292  - info: javascript.0 (2869) script.js.TelegramOnDWDWarning_v2: info: Alert States wurden gesetzt
                              2024-08-18 18:52:04.363  - warn: wireguard.0 (3644) Error: All configured authentication methods failed
                              2024-08-18 18:53:13.773  - info: alexa2.0 (3461) Alexa-Push-Connection disconnected - retry: Retry Connection in 1s
                              2024-08-18 18:53:15.106  - info: alexa2.0 (3461) Alexa-Push-Connection (macDms = true) established. Disable Polling
                              2024-08-18 18:54:04.364  - warn: wireguard.0 (3644) Error: All configured authentication methods failed
                              2024-08-18 18:55:19.018  - info: host.RoofServer instance system.adapter.dwd.0 in version "2.8.5" started with pid 53297
                              2024-08-18 18:55:32.977  - info: host.RoofServer instance system.adapter.dwd.0 having pid 53297 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
                              2024-08-18 18:55:52.970  - info: javascript.0 (2869) script.js.TelegramOnDWDWarning_v2: info: Alert States wurden gesetzt
                              2024-08-18 18:56:04.366  - warn: wireguard.0 (3644) Error: All configured authentication methods failed
                              2024-08-18 18:58:04.372  - warn: wireguard.0 (3644) Error: All configured authentication methods failed
                              2024-08-18 18:59:21.599  - info: vw-connect.0 (3948) Login in with id
                              2024-08-18 19:00:04.368  - warn: wireguard.0 (3644) Error: All configured authentication methods failed
                              2024-08-18 19:00:19.017  - info: host.RoofServer instance system.adapter.dwd.0 in version "2.8.5" started with pid 53959
                              2024-08-18 19:00:32.089  - info: host.RoofServer instance system.adapter.daswetter.0 in version "3.1.15" started with pid 54009
                              2024-08-18 19:00:37.061  - info: host.RoofServer instance system.adapter.dwd.0 having pid 53959 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
                              2024-08-18 19:00:39.197  - info: daswetter.0 (54009) starting. Version 3.1.15 in /opt/iobroker/node_modules/iobroker.daswetter, node: v18.20.4, js-controller: 6.0.10
                              2024-08-18 19:00:51.831  - info: daswetter.0 (54009) Terminated (ADAPTER_REQUESTED_TERMINATION): All data handled, adapter stopped until next scheduled moment
                              2024-08-18 19:00:52.345  - info: daswetter.0 (54009) cleaned everything up...
                              2024-08-18 19:00:52.354  - info: host.RoofServer instance system.adapter.daswetter.0 having pid 54009 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
                              2024-08-18 19:00:53.759  - info: javascript.0 (2869) script.js.TelegramOnDWDWarning_v2: info: Alert States wurden gesetzt
                              • A adarof
                                Skript v.2024-05-22
                                *** BASE SYSTEM ***
                                           Chassis: desktop
                                Docker          : false
                                Kernel          : x86_64
                                Userland        : 64 bit
                                CPU threads: 4
                                              NTP service: active
                                          RTC in local TZ: no
                                myuser
                                HOME=/home/myuser
                                iobroker
                                HOME=/home/iobroker
                                Desktop:
                                Terminal:       tty
                                *** MEMORY ***
                                Swap:          2.0G          0B        2.0G
                                         5652 M used memory
                                          729 M free memory
                                         7953 M swap cache
                                         2047 M total swap
                                            0 M used swap
                                         2047 M free swap
                                *** FILESYSTEM ***
                                /var:
                                22G     /var/
                                17G     /var/lib
                                5.6G    /var/lib/unifi
                                5.0G    /var/lib/snapd
                                USB-Devices by-id:
                                HINT:
                                /dev/ttyACM0
                                /usr/bin/npm            10.7.0
                                /usr/bin/npx            10.7.0
                                nodejs:
                                  Version table:
                                Errors in npm tree:
                                ioBroker Status
                                Objects type: jsonl
                                States  type: jsonl
                                admin:          7.0.22
                                javascript:     8.7.6
                                Adapter State
                                + instance is alive
                                Objects and States
                                Objects:        48180
                                States:         41750
                                Pending Updates: 2
                                da läuft aber noch eines anderes! (oder besser: läuft nicht!)
                                  Dafür läuft das ein Desktop und ein VNC-Server.
                                  Hat beides auf einem Server nix verloren.
                                    adarof
                                    @thomas-braun Jaha - ist kein reiner Server (mehr). UserCases ändern sich; der Name bleibt :-D
                                    • A adarof
                                      @adarof
                                      Jaha...
                                      DESKTOPS und VNCs haben trotzdem auf den Kisten nix verloren.
                                        @adarof
                                        Jaha...
                                        adarof
                                        @homoran Stimmt - dass das wireguard wg0 nicht mehr hochgekommen ist, ist merkwürdig. Vielleicht passte was mitm Netzwerk nicht beim aufstarten - das passiert immer mal wieder und ich hab noch nicht rausgefunden, woran es liegen kann.
