  4. [gelöst] Zigbee Adapter problem neuinstallation
    3.1k
zigbee-adapterzigbee
11 Beiträge 4 Kommentatoren 2.1k Aufrufe 3 Beobachtet
  • E Offline
    eMd
    schrieb am zuletzt editiert von eMd
    Systemdata Bitte Ausfüllen
    Hardwaresystem: Timkerboard
    Arbeitsspeicher: 4GB
    Festplattenart: emmc
    Betriebssystem: Ubuntu
    Nodejs-Version: 8.15.0
    NPM-Version: 6.4. 1
    Installationsart: Manuell
    Image genutzt: Ja
    Hallo, habe Update auf JS-Controller 2.2x gemacht.
    Nun hatte ich folgende Fehlermeldung:
     close	Zeit
    Meldung
    zigbee.0	2020-01-27 19:36:38.145	error	(31601) SyntaxError: Unexpected end of JSON input at JSON.parse (<anonymous>) at Function.open (/opt/iobroker/node_modules/iobroker.zigbee/node_modules/zigbee-herdsman/dist/controller/database
    zigbee.0	2020-01-27 19:36:38.144	error	(31601) Failed to start Zigbee
    zigbee.0	2020-01-27 19:36:37.915	info	(31601) Starting Zigbee...
    zigbee.0	2020-01-27 19:36:37.913	info	(31601) Try to reconnect. 1 attempts left
    zigbee.0	2020-01-27 19:36:27.911	error	at process._tickCallback (internal/process/next_tick.js:189:7)
    zigbee.0	2020-01-27 19:36:27.911	error	at <anonymous>
    zigbee.0	2020-01-27 19:36:27.911	error	at fulfilled (/opt/iobroker/node_modules/iobroker.zigbee/node_modules/zigbee-herdsman/dist/controller/controller.js:5:58)
    zigbee.0	2020-01-27 19:36:27.911	error	at Generator.next (<anonymous>)
    zigbee.0	2020-01-27 19:36:27.911	error	at Controller.<anonymous> (/opt/iobroker/node_modules/iobroker.zigbee/node_modules/zigbee-herdsman/dist/controller/controller.js:88:48)
    zigbee.0	2020-01-27 19:36:27.911	error	at Function.open (/opt/iobroker/node_modules/iobroker.zigbee/node_modules/zigbee-herdsman/dist/controller/database.js:17:35)
    zigbee.0	2020-01-27 19:36:27.911	error	at JSON.parse (<anonymous>)
    zigbee.0	2020-01-27 19:36:27.911	error	(31601) SyntaxError: Unexpected end of JSON input
    zigbee.0	2020-01-27 19:36:27.910	error	(31601) Failed to start Zigbee
    zigbee.0	2020-01-27 19:36:27.467	info	(31601) Starting Zigbee...
    zigbee.0	2020-01-27 19:36:27.409	info	(31601) starting. Version 1.0.1 in /opt/iobroker/node_modules/iobroker.zigbee, node: v8.15.0
    Dachte ok, bekomme ja einen neuen Zigbee Stick.
    Also komplett deinstall vom Adapter mit
    Sudo iobroker del zigbee
    Anschließend neuinstalliert über Katze mit aktuellem repo, bekomme aber wieder den Fehler...
    Was mache ich falsch?
    MfG eMd
    Master: Intel NUC 16GB/500GB
    Slave: Raspberry Pi 3 + Homematicmodul
    Shelly, Google Home, Zigbee Aqara, Sonoff
    Meine VIS: https://youtu.be/JMYr2KYlpME
    • E eMd
      NPM-Version: 6.4. 1
      Image genutzt: Ja
       close	Zeit
      Meldung
      MfG eMd
      AsgothianA Offline
      AsgothianA Offline
      Asgothian
      @eMd
      Bitte mach folgendes:
      iobroker stop
      iobroker del zigbee
      cd /opt/iobroker/node_modules
      rm -rf iobroker.zigbee
      iobroker install zigbee
      iobroker start
      sudo sollte nicht notwendig sein, da der ioBroker inzwischen nicht mehr mit root rechten laufen muss.
      A.
      E 1 Antwort Letzte Antwort
      • AsgothianA Asgothian
        @eMd
        iobroker stop
        iobroker del zigbee
        iobroker start
        A.
        eMd
        @Asgothian
        Geht ohne root, aber hat das Problem nicht beseitigt, wieder gleicher Fehler... Weird
        • E eMd
          @Asgothian
          AsgothianA Offline
          AsgothianA Offline
          Asgothian
          @eMd
          Allerdings.. ich kann das (aber erst morgen) mal testen.
          A.
          • E Offline
            eMd
            Hab noch die anderen Ordner gelöscht, aber es scheint noch mehr zu geben...
            MfG eMd
            • E eMd
              MfG eMd
              eMd
              @eMd
              Also ich habe noch andere Ordner gefunden, also alles was mit zigbee zu tun hat. Nun funktionierte die Neuinstallation.
              Danke fürs trotzdem rübersehen.
              MfG eMd
              • tobasiumT Offline
                tobasiumT Offline
                tobasium
                schrieb am zuletzt editiert von tobasium
                Hallo Zusammen,
                ich habe das gleiche Problem:
                zigbee.0	2020-02-03 21:11:28.778	error	at process._tickCallback (internal/process/next_tick.js:68:7)
                zigbee.0	2020-02-03 21:11:28.778	error	at fulfilled (/opt/iobroker/node_modules/zigbee-herdsman/dist/controller/controller.js:5:58)
                zigbee.0	2020-02-03 21:11:28.778	error	at Generator.next (<anonymous>)
                zigbee.0	2020-02-03 21:11:28.778	error	at Controller.<anonymous> (/opt/iobroker/node_modules/zigbee-herdsman/dist/controller/controller.js:88:48)
                zigbee.0	2020-02-03 21:11:28.778	error	at Function.open (/opt/iobroker/node_modules/zigbee-herdsman/dist/controller/database.js:17:35)
                zigbee.0	2020-02-03 21:11:28.778	error	at JSON.parse (<anonymous>)
                zigbee.0	2020-02-03 21:11:28.778	error	(13089) SyntaxError: Unexpected token { in JSON at position 1010
                zigbee.0	2020-02-03 21:11:28.777	error	(13089) Failed to start Zigbee
                Ich komme hier absolut nicht weiter. Vorher lief es noch dann hab ich die Version geändert und jetzt geht nichts mehr.
                Kann mich jemand unterstützen?
                Hab den Adapter inzwischen wieder zum laufen bekommen indem ich Version 0.10.2 installiert habe.
                Jetzt habe ich aber immer noch Fehler inzwischen wieder auf der aktuellen 1.0.2:
                zigbee.0	2020-02-03 22:03:52.066	error	at rejected (/opt/iobroker/node_modules/zigbee-herdsman/dist/controller/model/endpoint.js:6:65))
                zigbee.0	2020-02-03 22:03:52.066	error	at Generator.throw (<anonymous>)
                zigbee.0	2020-02-03 22:03:52.066	error	at Endpoint.<anonymous> (/opt/iobroker/node_modules/zigbee-herdsman/dist/controller/model/endpoint.js:235:23)
                zigbee.0	2020-02-03 22:03:52.066	error	(22440) Failed to configure 0xec1bbdfffe76d432 RH3040, attempt 2 (Error: Bind 0xec1bbdfffe76d432/1 genPowerCfg from '0x00124b00014d7cd4/1' failed (Error: AREQ - ZDO - bindRsp after 10000ms)
                Evtl. jemand einen Tip.
                • tobasiumT tobasium
                  Hallo Zusammen,
                  AsgothianA Offline
                  AsgothianA Offline
                  Asgothian
                  @Tobias-Armbruster sagte in [gelöst] Zigbee Adapter problem neuinstallation:
                  Failed to configure 0xec1bbdfffe76d432 RH3040, attempt 2 (Error: Bind 0xec1bbdfffe76d432/1 genPowerCfg from '0x00124b00014d7cd4/1' failed (Error: AREQ - ZDO - bindRsp after 10000ms)\
                  Diese Meldung besagt das ein Gerät (Typ RH3040, Adresse 0xec1bbdfffe76d432) auf den Versuch eine Konfiguration auf das Gerät zu Scheiben nicht reagiert hat. Das deutet zumeist auf Verbindungsprobleme hin.
                  A.
                    A.
                    mediaDS
                    schrieb am zuletzt editiert von mediaDS
                    @Asgothian
                    Macht keinen Sinn, alte Version funktioniert, neue Adpaterversion 1.0.2 nicht. Dann kann es doch nicht an der Hardware bzw. Verbindung liegen. Ich werde da mal weiter testen.
                    Edit:
                    Nach Neu-Installation erkennt der Zigbee Stick (CC2531) nur noch ein Gerät (Philips Bewegungsmelder), alle anderen Leuchtmittel (12 Stück, 11 Philips Hue, eins Müller)) sind nicht mehr "gejoined" (was auch immer das heißen mag). Praktisch sitze ich jetzt im Dunkeln. Tolles Update.
                    Ist mir damals auch mit Z-Wave bei openHAB passiert, ein Update und das ganze Haus war dunkel, nichts funktionierte mehr. Bin dann auf ioBroker umgestiegen. Jetzt derselbe Mist bei ioBroker und Zigbee. Ich könnte kotzen.
                    Noch ein Edit:
                    Nach Neu-Start ist jetzt alles weg, kein Zigbee Gerät mehr da. Das heißt, ich darf alles nochmal pairen (joinen?) Auch nach Installation der vorherigen Version funktioniert jetzt nichts mehr - keine Geräte gefunden. Na, danke auch ... :(
                      mediaDS
                      Toll, Pairing funktioniert auch nicht mehr. Der SML001 Bewegungsmelder ist das einzige erkannte Gerät. Ich habe eine Hue zurückgesetzt, danach kam im Pairing mit 1.0.2 nur noch:
                      zigbee.0	2020-02-05 21:53:24.724	error	(27578) Failed to interview '0x001766010253cfc6', device has not succesfully been paired. undefined
                      zigbee.0	2020-02-05 21:53:11.495	info	(27578) Starting interview of '0x001766010253cfc6'
                      zigbee.0	2020-02-05 21:53:07.047	error	(27578) Failed to interview '0x0017660103e78a44', device has not succesfully been paired. undefined
                      zigbee.0	2020-02-05 21:52:55.439	info	(27578) Starting interview of '0x0017660103e78a44'
                      zigbee.0	2020-02-05 21:52:39.547	info	(27578) Zigbee: allowing new devices to join.
                      Im Pairing-Log des Adapters erscheint am Ende noch ein "undefined.undefined".
                      Egal welches Leuchtmittel oder wie oft ich es mache - kein Erfolg. Auch mit einer alten Version das gleiche - hier geht nichts mehr, ich gebe auf.
                      • M mediaDS
                        mediaDS
                        Altes Backup wieder eingespielt, alten Adapter 0.10.3 installiert - funktioniert wieder alles. Ab sofort keine Updates mehr. Never touch a running system.
