  4. gelöst: Cloudadapter startet nicht mehr
cloud adapter
5 Beiträge 3 Kommentatoren 639 Aufrufe 2 Beobachtet
  • MatzebhvM Offline
    MatzebhvM Offline
    Matzebhv
    schrieb am zuletzt editiert von Matzebhv
    Moin,
    nach dem Update auf 3.0.0 startet der Adapter nicht mehr.
    Fehlermeldung:
    host.raspberry	2020-01-04 22:22:30.011	error	instance system.adapter.cloud.0 terminated with code 6 (UNCAUGHT_EXCEPTION)
    host.raspberry	2020-01-04 22:22:30.011	error	Caught by controller[0]: at process._tickCallback (internal/process/next_tick.js:189:7)
    host.raspberry	2020-01-04 22:22:30.011	error	Caught by controller[0]: at <anonymous>
    host.raspberry	2020-01-04 22:22:30.010	error	Caught by controller[0]: at promise.then (/opt/iobroker/node_modules/standard-as-callback/built/index.js:19:49)
    host.raspberry	2020-01-04 22:22:30.010	error	Caught by controller[0]: at tryCatcher (/opt/iobroker/node_modules/standard-as-callback/built/utils.js:11:23)
    host.raspberry	2020-01-04 22:22:30.010	error	Caught by controller[0]: at (anonymous function).(anonymous function) (/opt/iobroker/node_modules/iobroker.objects-redis/index.js:17:65119)
    host.raspberry	2020-01-04 22:22:30.010	error	Caught by controller[0]: at objects.getObject (/opt/iobroker/node_modules/iobroker.js-controller/lib/adapter.js:2450:65)
    host.raspberry	2020-01-04 22:22:30.007	error	Caught by controller[0]: at adapter.getForeignObject (/opt/iobroker/node_modules/iobroker.cloud/main.js:757:36)
    host.raspberry	2020-01-04 22:22:30.006	error	Caught by controller[0]: TypeError: alexaCustom.setLanguage is not a function
    cloud.0	2020-01-04 22:22:29.109	info	(18983) terminating
    cloud.0	2020-01-04 22:22:28.930	warn	(18983) Terminated (UNCAUGHT_EXCEPTION): Without reason
    cloud.0	2020-01-04 22:22:28.457	info	(18983) Connection changed: io client disconnect
    cloud.0	2020-01-04 22:22:28.453	info	(18983) Adapter redirected temporally to "https://iobroker.net:10560" in one minute. Reason: command from server
    cloud.0	2020-01-04 22:22:28.234	info	(18983) Trying to connect as system.user.admin
    cloud.0	2020-01-04 22:22:27.927	error	(18983) TypeError: alexaCustom.setLanguage is not a function at adapter.getForeignObject (/opt/iobroker/node_modules/iobroker.cloud/main.js:757:36) at objects.getObject (/opt/iobroker/node_mod
    cloud.0	2020-01-04 22:22:27.926	error	(18983) uncaught exception: alexaCustom.setLanguage is not a function
    cloud.0	2020-01-04 22:22:27.909	info	(18983) Connecting with https://iobroker.net:10555 with "******************************************************"
    cloud.0	2020-01-04 22:22:27.905	warn	(18983) Pleas use ioBroker.iot for alexa control
    cloud.0	2020-01-04 22:22:27.753	info	(18983) starting. Version 3.0.0 in /opt/iobroker/node_modules/iobroker.cloud, node: v8.17.0
    host.raspberry	2020-01-04 22:22:24.296	info	instance system.adapter.cloud.0 started with pid 18983
    host.raspberry	2020-01-04 22:22:24.222	info	"system.adapter.cloud.0" enabled
    Ganz so viel einstellen kann man hier jetzt ja nicht mehr. Benötige den Fernzugriff nur ganz selten und könnte daher drauf verzichten, ist ja aber vermutlich nicht im Sinne des Erfinders.
    System latest / aktuell
    Betriebssystem
    linux
    Architektur
    x64
    CPUs
    Geschwindigkeit
    1497 MHz
    Modell
    Intel(R) Celeron(R) CPU J3455 @ 1.50GHz
    RAM
    3.86 GB
    System Betriebszeit
    5 T. 10:14:02
    Node.js
    v8.17.0 (Empfohlene Version v10.18.0)
    NPM
    6.13.4
    Festplatte Größe
    11.75 GB
    Festplatte frei
    5.74 GB
    Anzahl der Adapter
    311
    Betriebszeit
    5 T. 09:31:19
    Aktive Instanzen
    41
    Hostname
    raspberry
    Matze
    • MatzebhvM Offline
      MatzebhvM Offline
      Matzebhv
      Nach dem Update auf 3.0.1 funktioniert der Adapter wieder.
      Matze
      • MatzebhvM Matzebhv
        Moin,
        Fehlermeldung:
        Betriebssystem
        linux
        Architektur
        x64
        CPUs
        Geschwindigkeit
        1497 MHz
        Modell
        RAM
        3.86 GB
        System Betriebszeit
        5 T. 10:14:02
        Node.js
        NPM
        6.13.4
        Festplatte Größe
        11.75 GB
        Festplatte frei
        5.74 GB
        Anzahl der Adapter
        311
        Betriebszeit
        5 T. 09:31:19
        Aktive Instanzen
        41
        Hostname
        raspberry
        Matze
        NegaleinN Offline
        NegaleinN Offline
        Negalein
        @Matzebhv sagte in Cloudadapter startet nach Update nicht mehr:
        ~~Der Cloud-Adapter wurde deaktiviert.
        Gibt jetzt nur noch den IOT.
        https://forum.iobroker.net/topic/28454/04-01-deaktivierung-alexa-service-free-cloud~~
        ° Fixer ---> iob fix
        • NegaleinN Negalein
          haselchenH Offline
          haselchenH Offline
          haselchen
          @Negalein
          Was für ein Nonsens 🙈Der Cloudadapter kann für Alexa Befehle nicht mehr genutzt werden. Verlinkst es sogar noch selber.
          Für Fernzugriff was der TE möchte, ist er sehr wohl nutzbar.
          "Falls der Fernzugriff auf Eure Visualisierungen über die Free-Cloud nicht gebraucht wird bitten wir Euch den cloud-Adapter zu deaktivieren, um Ressourcen auf dem Free-Cloud Server zu sparen und den Usern zur Verfügung zu stellen die es benötigen. Danke!"
          • haselchenH haselchen
            @Negalein
            NegaleinN Offline
            NegaleinN Offline
            Negalein
            @haselchen sagte in Cloudadapter startet nach Update nicht mehr:
            Sorry, das hab ich beim TE überlesen.
            Kann ja mal passieren.
            • MatzebhvM Offline
              MatzebhvM Offline
              Matzebhv
              Matze
