  4. 2 von 3 Ical Kalender gehen nicht mehr
25 Beiträge 7 Kommentatoren 4.8k Aufrufe
    audioconcept
    Hallo
    2 von meinen 3 Ical Kalendern gehen nicht.
    Hier mal ein log:
    rpi.0	2016-06-07 15:53:36.064	error	rpi.0 No Value found for wifi_send
    rpi.0	2016-06-07 15:53:36.062	error	rpi.0 No Value found for wifi_received
    rpi.0	2016-06-07 15:52:35.189	error	rpi.0 No Value found for wifi_send
    rpi.0	2016-06-07 15:52:35.187	error	rpi.0 No Value found for wifi_received
    host-raspberrypi	2016-06-07 15:30:14.450	info	instance system.adapter.ical.5 terminated with code 0 (OK)
    host-raspberrypi	2016-06-07 15:30:13.585	info	instance system.adapter.ical.3 terminated with code 0 (OK)
    host-raspberrypi	2016-06-07 15:30:10.408	info	instance system.adapter.ical.4 terminated with code 0 (OK)
    ical-4	2016-06-07 15:30:10.352	info	terminating
    TypeError:	2016-06-07 15:30:09.831	error	at IncomingMessage. (/opt/iobroker/node_modules/iobroker.ical/node_modules/request/request.js:1003:12)
    TypeError:	2016-06-07 15:30:09.831	error	at Request. (/opt/iobroker/node_modules/iobroker.ical/node_modules/request/request.js:1057:14)
    TypeError:	2016-06-07 15:30:09.831	error	at Request.self.callback (/opt/iobroker/node_modules/iobroker.ical/node_modules/request/request.js:198:22)
    TypeError:	2016-06-07 15:30:09.831	error	at Request._callback (/opt/iobroker/node_modules/iobroker.ical/main.js:190:39)
    ical-4	2016-06-07 15:30:09.376	info	processing URL: Dorotka http://www.xxx.net/kalenderdatei/Dorotka.ics
    ical-5	2016-06-07 15:30:08.776	info	processing URL: BVB http://www.xxx.net/kalenderdatei/BVB.ics
    ical-5	2016-06-07 15:30:08.258	info	starting. Version 1.1.1 in /opt/iobroker/node_modules/iobroker.ical
    ical-4	2016-06-07 15:30:08.180	info	starting. Version 1.1.1 in /opt/iobroker/node_modules/iobroker.ical
    ical-3	2016-06-07 15:30:07.408	info	processing URL: Mülltermine http://www.xxx.net/kalenderdatei/Muelltermine.ics
    ical-3	2016-06-07 15:30:06.916	info	starting. Version 1.1.1 in /opt/iobroker/node_modules/iobroker.ical
    host-raspberrypi	2016-06-07 15:30:00.916	info	instance system.adapter.ical.5 started with pid 11360
    host-raspberrypi	2016-06-07 15:30:00.883	info	instance system.adapter.ical.4 started with pid 11355
    host-raspberrypi	2016-06-07 15:30:00.824	info	instance system.adapter.ical.3 started with pid 11350
    host-raspberrypi	2016-06-07 15:00:14.367	info	instance system.adapter.ical.5 terminated with code 0 (OK)
    host-raspberrypi	2016-06-07 15:00:14.159	info	instance system.adapter.ical.3 terminated with code 0 (OK)
    host-raspberrypi	2016-06-07 15:00:10.248	info	instance system.adapter.ical.4 terminated with code 0 (OK)
    ical-4	2016-06-07 15:00:10.164	info	terminating
    TypeError:	2016-06-07 15:00:09.644	error	at IncomingMessage. (/opt/iobroker/node_modules/iobroker.ical/node_modules/request/request.js:1003:12)
    TypeError:	2016-06-07 15:00:09.644	error	at Request. (/opt/iobroker/node_modules/iobroker.ical/node_modules/request/request.js:1057:14)
    TypeError:	2016-06-07 15:00:09.644	error	at Request.self.callback (/opt/iobroker/node_modules/iobroker.ical/node_modules/request/request.js:198:22)
    TypeError:	2016-06-07 15:00:09.644	error	at Request._callback (/opt/iobroker/node_modules/iobroker.ical/main.js:190:39)
    ical-4	2016-06-07 15:00:09.173	info	processing URL: Dorotka http://www.xxx.net/kalenderdatei/Dorotka.ics
    ical-5	2016-06-07 15:00:08.693	info	processing URL: BVB http://www.xxx.net/kalenderdatei/BVB.ics
    ical-3	2016-06-07 15:00:08.243	info	processing URL: Mülltermine http://www.xxx.net/kalenderdatei/Muelltermine.ics
    ical-5	2016-06-07 15:00:07.846	info	starting. Version 1.1.1 in /opt/iobroker/node_modules/iobroker.ical
    ical-4	2016-06-07 15:00:07.779	info	starting. Version 1.1.1 in /opt/iobroker/node_modules/iobroker.ical
    ical-3	2016-06-07 15:00:07.704	info	starting. Version 1.1.1 in /opt/iobroker/node_modules/iobroker.ical
    host-raspberrypi	2016-06-07 15:00:00.921	info	instance system.adapter.ical.5 started with pid 10095
    host-raspberrypi	2016-06-07 15:00:00.876	info	instance system.adapter.ical.4 started with pid 10090
    host-raspberrypi	2016-06-07 15:00:00.822	info	instance system.adapter.ical.3 started with pid 10085
    host-raspberrypi	2016-06-07 14:30:15.098	info	instance system.adapter.ical.5 terminated with code 0 (OK)
    host-raspberrypi	2016-06-07 14:30:15.044	info	instance system.adapter.ical.3 terminated with code 0 (OK)
    host-raspberrypi	2016-06-07 14:30:10.662	info	instance system.adapter.ical.4 terminated with code 0 (OK)
    ical-4	2016-06-07 14:30:10.631	info	terminating
    debug	at IncomingMessage. (/opt/iobroker/node_modules/iobroker.ical/node_modules/request/request.js:1003:12)
    debug	at Request. (/opt/iobroker/node_modules/iobroker.ical/node_modules/request/request.js:1057:14)
    Ich benutze ical.3 der geht und ist auch unter Objekte im Adminmodul mit Daten gefüllt.
    nur ical.4 und ical.5 sind nicht mit Daten gefüllt und gehen nicht.
    Was mache ich falsch? Das lief sonst immer.
    Gruß aus Dortmund
    Michael
    <size size="85">Ausstattung: PI 4 , Rasbian , IOBroker , Admin 1.2.3, VIS 0.10.2, Host 0.90 [wird immer auf dem neuesten Stand geha…</size>
      Wieso 2 von 3 gehen nicht??
      Du hast 5 ical, und ich sehe nur Fehler beim ical.4 :
      Was passiert, wenn du die Url:
      in den Browser eingibst?
      Rainer
        audioconcept
        Hi
        da es damals nicht ging hatte ich mal einige ical gelöscht und neu angelegt. Hab jetzt nur noch ical3 , 4 und 5. ical 1 +2 gibt es nicht mehr.
        Wenn ich den Link aufrufe lädt er die ics Datei runter.
        Gruß aus Dortmund
        Michael
          audioconcept
          Hab jetzt noch mal alle 3 ical gelöscht und dann neu installiert. Hab jetzt ical.0 , ical.1 und ical.2.
          Hab es im VIS angepasst. Aber es geht wie vorher nur der ical.1 (Müllkalender) und der ical.2.
          Die Werte werden nicht gefüllt unter Objekte von ical.0
          Gruß aus Dortmund
          Michael
            und wie sieht dazu der log aus?
            Rainer
              audioconcept
              Hi Rainer
              das ist der Log zu ical.0
              host-raspberrypi	2016-06-08 14:30:10.668	info	instance system.adapter.ical.0 terminated with code 0 (OK)
              host-raspberrypi	2016-06-08 14:30:00.844	info	instance system.adapter.ical.0 started with pid 1724
              host-raspberrypi	2016-06-08 14:24:00.008	info	instance system.adapter.ical.0 terminated with code 0 (OK)
              host-raspberrypi	2016-06-08 14:23:50.679	info	instance system.adapter.ical.0 started with pid 1440
              host-raspberrypi	2016-06-08 14:23:50.649	info	instance scheduled system.adapter.ical.0 0,30 * * * *
              Gruß aus Dortmund
              Michael
                simpixo
                Aber das Problem haben doch schon einige das der iCal Adapter nichts mehr ins Objekt schreibt! Ich habe nämlich das gleiche Problem! Unter Objekten sehe ich nämlich keine Daten
                Gesendet von meinem iPhone mit Tapatalk
                  aquapro
                  @audiconcept
                  Schalt mal bitte ical.0 instanz auf debug.
                  Dann wird Dir der Grund gezeigt warum da nix kommt.
                  @simpixo
                  leider
                  <size size="85">BananaPi / Jessie / ioBroker deinstalliert, keine Upgradesicherheit</size>
                    simpixo
                    Ahh komisch!!!! Habe den Adapter neugestartet und komischerweise sind jetzt die Daten da! Ich weiß nicht wie oft ich den Adapter neugestartet habe! Jetzt geht es aber [emoji849][emoji53][emoji848]
                      aquapro
                      Hatte ich auch, aber wenn das Teil nach 30 Minuten wieder läuft, waren dann die daten wieder weg. Und mal wieder da nach paar Stunden.
                        audioconcept
                        Hi
                        hab ihn ausgeschaltet und auch angeschaltet, aktualisiert und auch im VIS neu installiert. Keine Anzeige.
                        Unter Objekte sind aber ical.1 und ical.2 mit Werten gefüllt. Nur ical.0 nicht.
                        Gruß aus Dortmund
                        Michael
                          aquapro
                          @aquapro:
                          @audiconcept
                          Dann wird Dir der Grund gezeigt warum da nix kommt. `
                            audioconcept
                            Also auf Instanzen gehen und deaktivieren? Meinst du das?
                            Dann steht im Log:
                            host-raspberrypi	2016-06-08 15:56:47.450	warn	stopInstance system.adapter.ical.0 not scheduled
                            host-raspberrypi	2016-06-08 15:39:37.319	info	stopInstance canceled schedule system.adapter.ical.0
                            host-raspberrypi	2016-06-08 15:39:37.315	info	stopInstance system.adapter.ical.0
                            host-raspberrypi	2016-06-08 15:39:37.294	info	object change system.adapter.ical.0
                            Gruß aus Dortmund
                            Michael
                              aquapro
                              Nein. Auf die Instanz gehen und da wo "Info" steht auf "debug" stellen.
                              Hab gerade keinen Screenshot zur Hand.
                                @audioconcept:
                                Also auf Instanzen gehen und deaktivieren? Meinst du das? `
                                Nein!
                                Er meint den debug modus einschalten.
                                Auf Instanzen gehen; die Admin Option aktivieren wenn sie es nicht bereits ist (Männchen-icon links oben), dann in der Zeile, in der die entsprechende ical Instanz ist (bei dir also ical.0) in der Spalte log Stufe auf debug stellen.
                                Rainer
                                Natürlich musst du jetzt deine Instanz wieder aktivieren.
                                  audioconcept
                                  Hi
                                  ok danke. Kannte die Funktion noch garnicht.
                                  Also es steht jetzt z.B. dort:
                                  host-raspberrypi	2016-06-08 18:50:43.407	info	instance system.adapter.ical.0 terminated with code 0 (OK)
                                  ical-0	2016-06-08 18:50:43.375	info	terminating
                                  TypeError:	2016-06-08 18:50:42.856	error	at IncomingMessage.emit (events.js:166:7)
                                  TypeError:	2016-06-08 18:50:42.856	error	at emitNone (events.js:72:20)
                                  TypeError:	2016-06-08 18:50:42.856	error	at IncomingMessage. (/opt/iobroker/node_modules/iobroker.ical/node_modules/request/request.js:1003:12)
                                  TypeError:	2016-06-08 18:50:42.856	error	at Request.emit (events.js:169:7)
                                  TypeError:	2016-06-08 18:50:42.856	error	at emitOne (events.js:82:20)
                                  TypeError:	2016-06-08 18:50:42.856	error	at Request. (/opt/iobroker/node_modules/iobroker.ical/node_modules/request/request.js:1057:14)
                                  TypeError:	2016-06-08 18:50:42.856	error	at Request.emit (events.js:172:7)
                                  TypeError:	2016-06-08 18:50:42.856	error	at emitTwo (events.js:87:13)
                                  TypeError:	2016-06-08 18:50:42.856	error	at Request.self.callback (/opt/iobroker/node_modules/iobroker.ical/node_modules/request/request.js:198:22)
                                  TypeError:	2016-06-08 18:50:42.856	error	at Request._callback (/opt/iobroker/node_modules/iobroker.ical/main.js:190:39)
                                  TypeError:	2016-06-08 18:50:42.856	error	Cannot read property 'setDate' of undefined
                                  uncaught	2016-06-08 18:50:42.841	error	exception: Cannot read property 'setDate' of undefined
                                  ical-0	2016-06-08 18:50:42.827	debug	RRule event:Steuervorauszahlung xxxx € Thu Mar 10 2016 00:00:00 GMT+0100 (CET) Wed Jun 15 2016 18:50:42 GMT+0200 (CEST) now:Wed Jun 08 2016 00:00:00 GMT+0200 (CEST) now2:Tue Jun 07 2016 23:59:59 GMT+
                                  ical-0	2016-06-08 18:50:42.814	debug	Event " " Weihnschtsbaum holen at Sat Dec 12 2015 12:00:00 GMT+0100 (CET) filtered out, because does not belongs to specified time interval
                                  ical-0	2016-06-08 18:50:42.810	debug	Event " " Weihnachtsbaum in Corinna Wagen laden at Wed Dec 16 2015 18:00:00 GMT+0100 (CET) filtered out, because does not belongs to specified time interval
                                  Komisch das da nur ein Termin drin steht von Heute. Die anderen liegen ja schon lange zurück. Im ical Konfigurator habe ich 7 Tage eingestellt und es sind auf jeden Fall morgen und übermorgen eingetragen.
                                  Verstehe es nicht. Scheint aber irgendwas mit dem Datum und Node zusammen zuhängen ?
                                  Gruß aus Dortmund
                                  Michael
                                    Erst einmal Danke für das log.
                                    @audioconcept:
                                    Komisch das da nur ein Termin drin steht von Heute. Die anderen liegen ja schon lange zurück. Im ical Konfigurator habe ich 7 Tage eingestellt und es sind auf jeden Fall morgen und übermorgen eingetragen. `
                                    @audioconcept:
                                    Scheint aber irgendwas mit dem Datum und Node zusammen zuhängen `
                                    Wieso? kannst du das log lesen?
                                    Der ical Adapter liest den gesamten Kalender ein und parst ihn. Wenn er damit fertig ist wertet er deine Einstellungen aus und zeigt die entsprechenden Daten an.
                                    So weit scheint er aber gar nicht gekommen zu sein.
                                    Bei deinem Finanzamt- Termin ist er hängengeblieben. Dies konnte er gar nicht auswerten und hat abgebrochen.
                                    Hier im Forum sind in den letzten Tagen (Wochen) zwei posts mit ical Fehlern aufgetaucht - kennst du die?
                                    Ist dieser Finanzamt-Termin ein wiederkehrender (Dauer-) termin?
                                    Wenn ja, lösch ihn mal testweise.
                                    Rainer
                                      audioconcept
                                      Hi
                                      ja der Finanzamttermin ist eine 3 monatige Wiederholung. Hab den mal gelöscht.
                                      Jetzt zeigt er es richtig an. Liegt anscheinend an einer Terminwiederholung.
                                      Danke euch. Vielen vielen Dank
                                      Vielleicht kann man dieses ja bei Gelegenheit mal reparieren.
                                      Gruß aus Dortmund
                                      Michael
                                        Das war ja jetzt eine schwere Geburt! ;-)
                                        aber geschafft!
                                        Bitte beim nächsten mal aussagekräftige Screenshots und logs posten, sonst kann keiner helfen!
                                        Rainer
                                          tcz
                                          gibt es zu dem Problem mit dem Serientermin mittlerweise einen Lösungsansatz oder besser eine Lösung?
                                          Danke und Gruß
                                          Torsten
                                          ioBroker auf Raspi, Homematic CCU2, VIS-App auf Galaxy Tab 4…
