  4. Hinzufuegen von Roomba Adapter wirft Fehler
roomba adapteradaptererror
3 Beiträge 3 Kommentatoren 2.4k Aufrufe 3 Beobachtet
  • scr2kS Offline
    scr2kS Offline
    scr2k
    ich bin iobroker Neueinsteiger, wollte nun meinen Roomba versuchen als Adapter hinzuzufügen und bekomme einen Fehler. Andere Adapter konnte ich bisher problemfrei hinzufügen. Den Fehler verstehe ich in der Tiefe nicht wirklich.
    Hoffe mir kann jemand einen Tipp geben!
    Zu meinem IO Broker: Neuste Version auf einem Raspberry 4
    $ ./iobroker add roomba  --host raspberrypi
    NPM version: 6.11.3
    npm install iobroker.roomba@1.0.7 --loglevel error --prefix "/opt/iobroker" (System call)
    Package pixman-1 was not found in the pkg-config search path.Perhaps you should add the directory containing `pixman-1.pc'to the PKG_CONFIG_PATH environment variableNo package 'pixman-1' found
    gyp: Call to 'pkg-config pixman-1 --libs' returned exit status 1 while in binding.gyp. while trying to load binding.gyp
    gyp ERR! configure error gyp ERR! stack Error: `gyp` failed with exit code: 1gyp ERR! stack     at ChildProcess.onCpExit (/usr/lib/node_modules/npm/node_modules/node-gyp/lib/configure.js:344:16)gyp ERR! stack     at ChildProcess.emit (events.js:198:13)gyp ERR! stack     at Process.ChildProcess._handle.onexit (internal/child_process.js:248:12)gyp ERR! System Linux 4.19.75-v7+gyp ERR! command "/usr/bin/node" "/usr/lib/node_modules/npm/node_modules/node-gyp/bin/node-gyp.js" "configure" "--fallback-to-build" "--module=/opt/iobroker/node_modules/canvas/build/Release/canvas.node" "--module_name=canvas" "--module_path=/opt/iobroker/node_modules/canvas/build/Release" "--napi_version=5" "--node_abi_napi=napi" "--napi_build_version=0" "--node_napi_label=node-v64"gyp ERR! cwd /opt/iobroker/node_modules/canvasgyp ERR! node -v v10.17.0gyp ERR! node-gyp -v v5.0.3gyp ERR! not ok
    node-pre-gyp ERR! build error
    node-pre-gyp ERR! stack Error: Failed to execute '/usr/bin/node /usr/lib/node_modules/npm/node_modules/node-gyp/bin/node-gyp.js configure --fallback-to-build --module=/opt/iobroker/node_modules/canvas/build/Release/canvas.node --module_name=canvas --module_path=/opt/iobroker/node_modules/canvas/build/Release --napi_version=5 --node_abi_napi=napi --napi_build_version=0 --node_napi_label=node-v64' (1)node-pre-gyp ERR! stack     at ChildProcess.<anonymous> (/opt/iobroker/node_modules/node-pre-gyp/lib/util/compile.js:83:29)node-pre-gyp ERR! stack     at ChildProcess.emit (events.js:198:13)node-pre-gyp ERR! stack     at maybeClose (internal/child_process.js:982:16)node-pre-gyp ERR! stack     at Process.ChildProcess._handle.onexit (internal/child_process.js:259:5)
    node-pre-gyp ERR! System Linux 4.19.75-v7+node-pre-gyp ERR! command "/usr/bin/node" "/opt/iobroker/node_modules/.bin/node-pre-gyp" "install" "--fallback-to-build"node-pre-gyp ERR! cwd /opt/iobroker/node_modules/canvasnode-pre-gyp ERR! node -v v10.17.0node-pre-gyp ERR! node-pre-gyp -v v0.11.0node-pre-gyp ERR! not ok
    npm ERR! code ELIFECYCLE
    npm ERR! errno 1npm ERR! canvas@2.6.0 install: `node-pre-gyp install --fallback-to-build`npm ERR! Exit status 1npm ERR! npm ERR! Failed at the canvas@2.6.0 install script.npm ERR! This is probably not a problem with npm. There is likely additional logging output above.
    npm ERR! A complete log of this run can be found in:npm ERR!     /home/iobroker/.npm/_logs/2019-11-19T20_18_03_891Z-debug.log
    ERROR: host.SmartHome Cannot install iobroker.roomba@1.0.7: 1
    Systemdata Bitte Ausfüllen
    Hardwaresystem: NUC/Pi3/etc.
    Arbeitsspeicher: 1GB
    Festplattenart: SD-Karte/SSD/HDD
    Betriebssystem: Ubuntu/Windows/Mac
    Node-Version: 10.x.x
    Nodejs-Version: 10.x.x
    NPM-Version: 6.x.x
    Installationsart: Skript/Manuell
    Image genutzt: Ja/Nein
    Ort/Name der Imagedatei: Link
    • scr2kS scr2k
      NPM version: 6.11.3
      NPM-Version: 6.x.x
      foxriver76F Offline
      foxriver76F Offline
      foxriver76
      @scr2k Laut Doku:
      sudo apt-get install build-essential libcairo2-dev libpango1.0-dev libjpeg-dev libgif-dev librsvg2-dev
      sudo npm install canvas --unsafe-perm=true
      Debian Pakete muessen aktuell leider manuell installiert werden. Steht allerdings auf der Agenda für den js-c.
      Canvas vermutlich manuell wegen unsafe-perm.
      Videotutorials & mehr
      • C Offline
        Coffeelover
        schrieb am zuletzt editiert von Coffeelover
        habe die Installation für meinen Xiaomi versucht, bekomme aber bei den Libraries folgende Meldung:
        E: Paket libcairo2-dev kann nicht gefunden werden.
        E: Paket libpango1.0-dev kann nicht gefunden werden.
        E: Mittels des Musters »libpango1.0-dev« konnte kein Paket gefunden werden.
        E: Mittels regulärem Ausdruck »libpango1.0-dev« konnte kein Paket gefunden werden.
        E: Paket libjpeg-dev kann nicht gefunden werden.
        E: Paket libgif-dev kann nicht gefunden werden.
        E: Paket librsvg2-dev kann nicht gefunden werden.
        Installation in einem QNAP Container / Docker.
        VG
        Edit: Gelöst durch ausführen von sudo apt update und dann sudo apt-get install
