  4. Alexa 2 Adapter gibt Error im log aus?
alexa 2 adapter
7 Beiträge 5 Kommentatoren 436 Aufrufe 5 Beobachtet
  • MyzerATM Offline
    MyzerATM Offline
    MyzerAT
    schrieb am zuletzt editiert von MyzerAT
    hi Ihrs,
    seit kurzem bekomme ich im log folgende Meldung, habe nichts verändert oder getan und es schaut auch so aus als ob alles noch funktioniert!
    alexa2.0	2019-11-12 20:11:20.631	info	Alexa-Push-Connection established. Disable Polling
    alexa2.0	2019-11-12 20:10:27.271	info	Alexa-Push-Connection Error: Error: read ECONNRESET
    alexa2.0	2019-11-12 20:10:21.950	info	Alexa-Push-Connection disconnected - retry: Retry Connection in 5s
    alexa2.0	2019-11-12 20:10:21.950	info	Alexa-Push-Connection Error: Error: read ECONNRESET
    alexa2.0	2019-11-12 20:08:01.355	info	Alexa-Push-Connection disconnected - retry: Retry Connection in 5s
    alexa2.0	2019-11-12 20:08:01.354	info	Alexa-Push-Connection Error: Error: Hostname/IP doesn't match certificate's altnames: "Host: dp-gw-na.amazon.de. is not in the cert's altnames: DNS:www.rdjl.eu"
    alexa2.0	2019-11-12 20:07:56.307	info	Alexa-Push-Connection disconnected - retry: Retry Connection in 5s
    alexa2.0	2019-11-12 20:07:56.305	info	Alexa-Push-Connection Error: Error: Hostname/IP doesn't match certificate's altnames: "Host: dp-gw-na.amazon.de. is not in the cert's altnames: DNS:www.rdjl.eu"
    alexa2.0	2019-11-12 20:07:51.277	info	Alexa-Push-Connection disconnected - retry: Retry Connection in 5s
    alexa2.0	2019-11-12 20:07:51.275	info	Alexa-Push-Connection Error: Error: Hostname/IP doesn't match certificate's altnames: "Host: dp-gw-na.amazon.de. is not in the cert's altnames: DNS:www.rdjl.eu"
    alexa2.0	2019-11-12 20:07:46.238	info	Alexa-Push-Connection disconnected - retry: Retry Connection in 5s
    alexa2.0	2019-11-12 20:07:46.237	info	Alexa-Push-Connection Error: Error: Hostname/IP doesn't match certificate's altnames: "Host: dp-gw-na.amazon.de. is not in the cert's altnames: DNS:www.rdjl.eu"
    alexa2.0	2019-11-12 20:07:41.154	info	Alexa-Push-Connection disconnected - retry: Retry Connection in 5s
    alexa2.0	2019-11-12 20:07:41.153	info	Alexa-Push-Connection Error: Error: Hostname/IP doesn't match certificate's altnames: "Host: dp-gw-na.amazon.de. is not in the cert's altnames: DNS:www.rdjl.eu"
    lg Rudi
    Node 22.23.0
    Nodejs 22.23.0
    npm 10.9.8
    js-controller 7.2.2
    • Dr. BakteriusD Offline
      Dr. Bakterius
      Diese Meldungen habe ich auch seit heute Abend!
      Wenn man sie etwas sagen lassen will (per 'speak'), sagt sie jetzt vor dem Text "sprich mir nach...". Manchmal kommt auch nur das und der eigentliche Text fehlt. Über 'SSML' funktioniert aber alles normal.
      Handelt sich um einen DOT2 mit FW 647642120 aber auch bei anderen Echo-Geräten. Da dürfte Amazon heute Nachmittag etwas geändert haben!
      @apollon77: was meinst du dazu?
      • F Offline
        fuchs1978
        Bei mir gleiches Problem
        • liv-in-skyL Offline
          liv-in-skyL Offline
          liv-in-sky
          dito - bei mir auch
          bei mir haben heute nachmittag auch die smarhome geräte nicht geschaltet
            Dr. Bakterius
            Habe gerade begonnen einige Skripte für 'SSML' umzubauen, da hat es plötzlich wieder normal funktioniert.
            Hoffentlich war das nur ein kurzer Schluckauf...
            • apollon77A Offline
              Ja klingt nach nem kaputten Amazon Update :-(
              • MyzerATM Offline
                MyzerATM Offline
                MyzerAT
                seit 20:15 sind die Meldungen im log weg!
                eventuell ist es ja wieder behoben seitens Amazon ?
                lg Rudi
                Node 22.23.0
                Nodejs 22.23.0
                npm 10.9.8
                js-controller 7.2.2
