  4. [gelöst] SQL # Datenbankname wird nicht genutzt
9 Beiträge 2 Kommentatoren 2.4k Aufrufe
  • derAugeD Offline
    derAugeD Offline
    derAuge
    EDIT
    Lösung wurde in neuer Version von SQLerstellt
    EDIT Off
    Laut beschreibung kann man dern Datenbankname ändern
    Default Database name is "iobroker", but it can be changed in configuration.
    Es wird jedoch die StandartDB genommen
    2016-05-30 23:00:15.848  - info: host.DS instance system.adapter.sql.0 started with pid 23862
    2016-05-30 23:00:19.141  - debug: sql.0 objectDB connected
    2016-05-30 23:00:19.163  - debug: sql.0 statesDB connected
    2016-05-30 23:00:19.260  - info: sql.0 starting. Version 1.0.5 in /volume2/ioBroker/Master/node_modules/iobroker.sql
    2016-05-30 23:00:19.612  - info: sql.0 enabled logging of yr.0.forecast.day0.wind_speed
    2016-05-30 23:00:19.614  - info: sql.0 enabled logging of yr.0.forecast.day0.temperature_actual
    2016-05-30 23:00:19.700  - debug: sql.0 CREATE DATABASE iobroker;
    2016-05-30 23:00:19.724  - debug: sql.0 Response: {"code":"ER_DB_CREATE_EXISTS","errno":1007,"sqlState":"HY000","index":0}
    2016-05-30 23:00:19.750  - debug: sql.0 CREATE TABLE iobroker.sources    (id INTEGER NOT NULL PRIMARY KEY AUTO_INCREMENT, name TEXT);
    2016-05-30 23:00:19.760  - debug: sql.0 Response: {"code":"ER_TABLE_EXISTS_ERROR","errno":1050,"sqlState":"42S01","index":0}
    2016-05-30 23:00:19.770  - debug: sql.0 CREATE TABLE iobroker.datapoints (id INTEGER NOT NULL PRIMARY KEY AUTO_INCREMENT, name TEXT, type INTEGER);
    2016-05-30 23:00:19.774  - debug: sql.0 Response: {"code":"ER_TABLE_EXISTS_ERROR","errno":1050,"sqlState":"42S01","index":0}
    2016-05-30 23:00:19.779  - debug: sql.0 CREATE TABLE iobroker.ts_number  (id INTEGER, ts BIGINT, val REAL,    ack BOOLEAN, _from INTEGER, q INTEGER, PRIMARY KEY                                     (id, ts));
    2016-05-30 23:00:19.782  - debug: sql.0 Response: {"code":"ER_TABLE_EXISTS_ERROR","errno":1050,"sqlState":"42S01","index":0}
    2016-05-30 23:00:19.789  - debug: sql.0 CREATE TABLE iobroker.ts_string  (id INTEGER, ts BIGINT, val TEXT,    ack BOOLEAN, _from INTEGER, q INTEGER, PRIMARY KEY                                     (id, ts));
    2016-05-30 23:00:19.794  - debug: sql.0 Response: {"code":"ER_TABLE_EXISTS_ERROR","errno":1050,"sqlState":"42S01","index":0}
    2016-05-30 23:00:19.803  - debug: sql.0 CREATE TABLE iobroker.ts_bool    (id INTEGER, ts BIGINT, val BOOLEAN, ack BOOLEAN, _from INTEGER, q INTEGER, PRIMARY KEY                                     (id, ts));
    2016-05-30 23:00:19.806  - debug: sql.0 Response: {"code":"ER_TABLE_EXISTS_ERROR","errno":1050,"sqlState":"42S01","index":0}
    2016-05-30 23:00:19.807  - info: sql.0 Connected to mysql
    Somit keine unterschiedlichen DB möglich
    Jürgen
    • BluefoxB Offline
      BluefoxB Offline
      Kannst du die Version 1.0.5 vom git ausprobieren?
      https://github.com/ioBroker/ioBroker.sql
      1.0.5 (2016-05-30)
      • (bluefox) allow setup DB name for mysql and mssql
      • derAugeD Offline
        derAugeD Offline
        derAuge
        @Bluefox:
        1.0.5 (2016-05-30)
        • (bluefox) allow setup DB name for mysql and mssql `
        Installation durchgeführt: (Ich hoffe das es so richtig war)
        admin@DS:/volume2/ioBroker/Master$ iobroker upgrade sql https://github.com/ioBroker/ioBroker.sql
        host.DS Adapter "system.adapter.sql.0" is stopped.
        npm install iobroker.sql --production --prefix "/volume2/ioBroker/Master" (System call)
        host.DS Adapter "system.adapter.sql.0" is started
        npm install --production --prefix "/volume2/ioBroker/Master/node_modules/iobroker.sql" (System call)
        got /volume2/ioBroker/Master/node_modules/iobroker.sql/admin
        upload [2] sql.admin /volume2/ioBroker/Master/node_modules/iobroker.sql/admin/storage.html storage.html text/html
        Update "system.adapter.sql.0"
        upload [1] sql.admin /volume2/ioBroker/Master/node_modules/iobroker.sql/admin/sql.png sql.png image/png
        upload [0] sql.admin /volume2/ioBroker/Master/node_modules/iobroker.sql/admin/index.html index.html text/html
        Adapter "sql" updated
        nach dem upgrade den Adapter auf DEBUG gestellt
        folgendes ist im LOG:
        2016-05-31 20:27:32.298  - info: host.DS object change system.adapter.sql.0
        2016-05-31 20:27:32.304  - info: host.DS "system.adapter.sql.0" disabled
        2016-05-31 20:27:32.307  - info: host.DS stopInstance system.adapter.sql.0
        2016-05-31 20:27:32.308  - info: host.DS stopInstance system.adapter.sql.0 killing pid 27821
        2016-05-31 20:27:32.377  - info: host.DS instance system.adapter.sql.0 terminated with code 0 (OK)
        2016-05-31 20:28:33.227  - info: host.DS object change system.adapter.sql.0
        2016-05-31 20:28:45.903  - info: host.DS object change system.adapter.sql.0
        2016-05-31 20:28:45.904  - info: host.DS "system.adapter.sql.0" enabled
        2016-05-31 20:28:46.179  - info: host.DS instance system.adapter.sql.0 started with pid 24171
        2016-05-31 20:28:50.554  - info: sql.0 starting. Version 1.0.5 in /volume2/ioBroker/Master/node_modules/iobroker.sql
        2016-05-31 20:28:51.716  - info: sql.0 Connected to mysql
        2016-05-31 20:28:54.086  - info: host.DS object change system.adapter.sql.0
        2016-05-31 20:28:54.087  - info: host.DS stopInstance system.adapter.sql.0
        2016-05-31 20:28:54.087  - info: host.DS stopInstance system.adapter.sql.0 killing pid 24171
        2016-05-31 20:28:54.102  - info: sql.0 terminating
        2016-05-31 20:28:54.123  - info: host.DS instance system.adapter.sql.0 terminated with code 0 (OK)
        2016-05-31 20:28:56.625  - info: host.DS instance system.adapter.sql.0 started with pid 24204
        2016-05-31 20:28:58.959  - info: sql.0 starting. Version 1.0.5 in /volume2/ioBroker/Master/node_modules/iobroker.sql
        2016-05-31 20:28:59.377  - info: sql.0 Connected to mysql
        2016-05-31 20:29:16.633  - info: host.DS object change system.adapter.sql.0
        2016-05-31 20:29:16.633  - info: host.DS stopInstance system.adapter.sql.0
        2016-05-31 20:29:16.634  - info: host.DS stopInstance system.adapter.sql.0 killing pid 24204
        2016-05-31 20:29:16.682  - info: host.DS instance system.adapter.sql.0 terminated with code 0 (OK)
        2016-05-31 20:29:19.171  - info: host.DS instance system.adapter.sql.0 started with pid 24237
        2016-05-31 20:29:21.327  - debug: sql.0 objectDB connected
        2016-05-31 20:29:21.350  - debug: sql.0 statesDB connected
        2016-05-31 20:29:21.477  - info: sql.0 starting. Version 1.0.5 in /volume2/ioBroker/Master/node_modules/iobroker.sql
        2016-05-31 20:29:21.739  - info: sql.0 enabled logging of yr.0.forecast.day0.wind_speed
        2016-05-31 20:29:21.740  - info: sql.0 enabled logging of yr.0.forecast.day0.temperature_actual
        2016-05-31 20:29:21.769  - debug: sql.0 CREATE DATABASE iobroker;
        2016-05-31 20:29:21.788  - debug: sql.0 Response: {"code":"ER_DB_CREATE_EXISTS","errno":1007,"sqlState":"HY000","index":0}
        2016-05-31 20:29:21.812  - debug: sql.0 CREATE TABLE iobroker.sources    (id INTEGER NOT NULL PRIMARY KEY AUTO_INCREMENT, name TEXT);
        2016-05-31 20:29:21.817  - debug: sql.0 Response: {"code":"ER_TABLE_EXISTS_ERROR","errno":1050,"sqlState":"42S01","index":0}
        2016-05-31 20:29:21.826  - debug: sql.0 CREATE TABLE iobroker.datapoints (id INTEGER NOT NULL PRIMARY KEY AUTO_INCREMENT, name TEXT, type INTEGER);
        2016-05-31 20:29:21.830  - debug: sql.0 Response: {"code":"ER_TABLE_EXISTS_ERROR","errno":1050,"sqlState":"42S01","index":0}
        2016-05-31 20:29:21.835  - debug: sql.0 CREATE TABLE iobroker.ts_number  (id INTEGER, ts BIGINT, val REAL,    ack BOOLEAN, _from INTEGER, q INTEGER, PRIMARY KEY(id, ts));
        2016-05-31 20:29:21.838  - debug: sql.0 Response: {"code":"ER_TABLE_EXISTS_ERROR","errno":1050,"sqlState":"42S01","index":0}
        2016-05-31 20:29:21.843  - debug: sql.0 CREATE TABLE iobroker.ts_string  (id INTEGER, ts BIGINT, val TEXT,    ack BOOLEAN, _from INTEGER, q INTEGER, PRIMARY KEY(id, ts));
        2016-05-31 20:29:21.846  - debug: sql.0 Response: {"code":"ER_TABLE_EXISTS_ERROR","errno":1050,"sqlState":"42S01","index":0}
        2016-05-31 20:29:21.855  - debug: sql.0 CREATE TABLE iobroker.ts_bool    (id INTEGER, ts BIGINT, val BOOLEAN, ack BOOLEAN, _from INTEGER, q INTEGER, PRIMARY KEY(id, ts));
        2016-05-31 20:29:21.858  - debug: sql.0 Response: {"code":"ER_TABLE_EXISTS_ERROR","errno":1050,"sqlState":"42S01","index":0}
        2016-05-31 20:29:21.859  - info: sql.0 Connected to mysql
        Es wurden keine Tabellen angelegt
        Jürgen
        • BluefoxB Offline
          BluefoxB Offline
          Bitte
          cd /opt/iobroker
          iobroker stop sql
          npm install https://github.com/ioBroker/ioBroker.sql
          iobroker start sql
          Ausführen
          • derAugeD Offline
            derAugeD Offline
            derAuge
            admin@DS:~$ cd /volume2/ioBroker/Master/
            admin@DS:/volume2/ioBroker/Master$ iobroker stop sql
            Adapter "sql.0 stopped.
            admin@DS:/volume2/ioBroker/Master$ npm install https://github.com/ioBroker/ioBroker.sql
            npm ERR! git clone --template=/var/services/homes/admin/.npm/_git-remotes/_templates --mirror https://github.com/ioBroker/ioBroker.sql.git /var/services/homes/admin/.npm/_git-remotes/https-github-com-ioBroker-ioBroker-sql-git-ee17b8ff: undefined
            npm ERR! Linux 3.10.77
            npm ERR! argv "/volume1/@appstore/Node.js_v4/usr/local/bin/node" "/usr/local/bin/npm" "install" "https://github.com/ioBroker/ioBroker.sql"
            npm ERR! node v4.2.6
            npm ERR! npm  v2.14.12
            npm ERR! code ENOGIT
            npm ERR! not found: git
            npm ERR!
            npm ERR! Failed using git.
            npm ERR! This is most likely not a problem with npm itself.
            npm ERR! Please check if you have git installed and in your PATH.
            npm ERR! Please include the following file with any support request:
            npm ERR!     /volume2/ioBroker/Master/npm-debug.log
            • BluefoxB Offline
              BluefoxB Offline
              Sorry. Sollte sein:
              npm install https://github.com/ioBroker/ioBroker.sql/tarball/master
              • derAugeD Offline
                derAugeD Offline
                derAuge
                admin@DS:/volume2/ioBroker/Master$ npm install https://github.com/ioBroker/ioBroker.sql/tarball/master
                > sqlite3@3.1.4 install /volume2/ioBroker/Master/node_modules/iobroker.sql/node_modules/sqlite3
                > node-pre-gyp install --fallback-to-build
                [sqlite3] Success: "/volume2/ioBroker/Master/node_modules/iobroker.sql/node_modules/sqlite3/lib/binding/node-v46-linux-x64/node_sqlite3.node" is installed via remote
                iobroker.sql@1.0.7 node_modules/iobroker.sql
                ├── mysql@2.10.2 (bignumber.js@2.1.4, readable-stream@1.1.14)
                ├── pg@4.5.5 (packet-reader@0.2.0, pg-connection-string@0.1.3, generic-pool@2.1.1, buffer-writer@1.0.1, semver@4.3.6, pg-types@1.11.0, pgpass@0.0.3)
                ├── sql-client@0.7.0 (argf@0.0.1, optimist@0.6.1, inote-util@0.8.1)
                ├── mssql@3.3.0 (generic-pool@2.4.2, promise@7.1.1, tedious@1.14.0)
                └── sqlite3@3.1.4 (nan@2.3.5)
                So sieht es besser aus.
                2016-06-01 07:06:08.001  - info: host.DS instance system.adapter.yr.0 terminated with code 0 (OK)
                2016-06-01 07:36:48.516  - warn: host.DS "system.host.RPi2-1" is offline
                2016-06-01 07:36:48.522  - warn: host.DS too delayed answer
                2016-06-01 07:36:48.570  - warn: host.DS "system.host.RPi2-1" is offline
                2016-06-01 07:36:48.570  - warn: host.DS too delayed answer
                2016-06-01 07:37:24.886  - info: host.DS object change system.adapter.sql.0
                2016-06-01 07:37:24.888  - info: host.DS stopInstance system.adapter.sql.0
                2016-06-01 07:37:24.889  - info: host.DS stopInstance system.adapter.sql.0 killing pid 25724
                2016-06-01 07:37:25.060  - info: host.DS instance system.adapter.sql.0 terminated with code 0 (OK)
                2016-06-01 07:37:27.417  - info: host.DS instance system.adapter.sql.0 started with pid 23321
                2016-06-01 07:37:30.955  - debug: sql.0 objectDB connected
                2016-06-01 07:37:30.978  - debug: sql.0 statesDB connected
                2016-06-01 07:37:31.083  - info: sql.0 starting. Version 1.0.7 in /volume2/ioBroker/Master/node_modules/iobroker.sql
                2016-06-01 07:37:31.438  - info: sql.0 enabled logging of yr.0.forecast.day0.wind_speed
                2016-06-01 07:37:31.440  - info: sql.0 enabled logging of yr.0.forecast.day0.temperature_actual
                2016-06-01 07:37:31.545  - debug: sql.0 CREATE DATABASE iobroker.master;
                2016-06-01 07:37:31.583  - debug: sql.0 Response: {"code":"ER_PARSE_ERROR","errno":1064,"sqlState":"42000","index":0}
                2016-06-01 07:37:31.584  - error: sql.0 CREATE DATABASE iobroker.master;
                2016-06-01 07:37:31.584  - error: sql.0 Error: ER_PARSE_ERROR: You have an error in your SQL syntax; check the manual that corresponds to your MariaDB server version for the right syntax to use near '.master' at line 1
                2016-06-01 07:38:01.600  - debug: sql.0 CREATE DATABASE iobroker.master;
                2016-06-01 07:38:01.605  - debug: sql.0 Response: {"code":"ER_PARSE_ERROR","errno":1064,"sqlState":"42000","index":0}
                2016-06-01 07:38:01.605  - error: sql.0 CREATE DATABASE iobroker.master;
                2016-06-01 07:38:01.605  - error: sql.0 Error: ER_PARSE_ERROR: You have an error in your SQL syntax; check the manual that corresponds to your MariaDB server version for the right syntax to use near '.master' at line 1
                2016-06-01 07:38:18.646  - debug: inMem message  *.logging system.adapter.admin.0.logging val=true, ack=true, ts=1464759498638, q=0, from=system.adapter.admin.0, lc=1464759393462
                2016-06-01 07:38:31.613  - debug: sql.0 CREATE DATABASE iobroker.master;
                2016-06-01 07:38:31.618  - debug: sql.0 Response: {"code":"ER_PARSE_ERROR","errno":1064,"sqlState":"42000","index":0}
                2016-06-01 07:38:31.619  - error: sql.0 CREATE DATABASE iobroker.master;
                2016-06-01 07:38:31.620  - error: sql.0 Error: ER_PARSE_ERROR: You have an error in your SQL syntax; check the manual that corresponds to your MariaDB server version for the right syntax to use near '.master' at line 1
                2016-06-01 07:38:40.963  - info: host.DS object change system.adapter.sql.0
                2016-06-01 07:38:40.964  - info: host.DS stopInstance system.adapter.sql.0
                2016-06-01 07:38:40.964  - info: host.DS stopInstance system.adapter.sql.0 killing pid 23321
                2016-06-01 07:38:40.994  - debug: inMem message  * system.adapter.sql.0 _id=system.adapter.sql.0, type=instance, name=sql, title=SQL History, en=Logging of states into SQL DB, de=Loggt die Historie von einzelnen Zuständen in einer SQL DB, ru=Сохраняет историю событий для отдельных состояний в SQL DB, version=1.0.5, en=try to calculate old timestamps, de=try to calculate old timestamps, ru=try to calculate old timestamps, en=fix error with io-package, de=fix error with io-package, ru=fix error with io-package, en=fix error with SQLite, de=fix error with SQLite, ru=fix error with SQLite, en=change default aggregation name, de=change default aggregation name, ru=change default aggregation name, en=check retention of data if set [never], de=check retention of data if set [never], ru=check retention of data if set [never], en=switch max and min with each other, de=switch max and min with each other, ru=switch max and min with each other, mode=daemon, platform=Javascript/Node.js, loglevel=debug, messagebox=true, subscribe=messagebox, keywords=[charts, sql, logging, graphs, archive], preserveSettings=history, enabled=true, stopBeforeUpdate=true, authors=[bluefox <dogafox@gmail.com>], license=MIT, readme=https://github.com/ioBroker/ioBroker.sql/blob/master/README.md, icon=sql.png, extIcon=https://raw.githubusercontent.com/ioBroker/ioBroker.sql/master/admin/sql.png, type=storage, minWidth=570, width =435, minHeight=200, height=540, installedVersion=1.0.5, host=DS, connLink=, debounce=10000, retention=0, host=192.168.28.24, port=0, user=iobroker, password=jbu, dbtype=mysql, fileName=sqlite.db, encrypt=false, round=4, dbname=iobroker_master
                2016-06-01 07:38:41.001  - info: sql.0 terminating
                2016-06-01 07:38:41.018  - info: host.DS instance system.adapter.sql.0 terminated with code 0 (OK)</dogafox@gmail.com>
                ABER: CREATE DATABASE iobroker.master
                Der Datenbankname darf kein "." haben
                Ohne "." geht es besser:
                CREATE DATABASE iobroker_master
                2016-06-01 07:38:43.481  - info: host.DS instance system.adapter.sql.0 started with pid 23390
                2016-06-01 07:38:45.641  - debug: sql.0 objectDB connected
                2016-06-01 07:38:45.663  - debug: sql.0 statesDB connected
                2016-06-01 07:38:45.761  - info: sql.0 starting. Version 1.0.7 in /volume2/ioBroker/Master/node_modules/iobroker.sql
                2016-06-01 07:38:46.005  - info: sql.0 enabled logging of yr.0.forecast.day0.wind_speed
                2016-06-01 07:38:46.007  - info: sql.0 enabled logging of yr.0.forecast.day0.temperature_actual
                2016-06-01 07:38:46.037  - debug: sql.0 CREATE DATABASE iobroker_master;
                2016-06-01 07:38:46.132  - debug: sql.0 Response: null
                2016-06-01 07:38:46.156  - debug: sql.0 CREATE TABLE iobroker_master.sources    (id INTEGER NOT NULL PRIMARY KEY AUTO_INCREMENT, name TEXT);
                2016-06-01 07:38:46.704  - debug: sql.0 Response: null
                2016-06-01 07:38:46.713  - debug: sql.0 CREATE TABLE iobroker_master.datapoints (id INTEGER NOT NULL PRIMARY KEY AUTO_INCREMENT, name TEXT, type INTEGER);
                2016-06-01 07:38:46.802  - debug: sql.0 Response: null
                2016-06-01 07:38:46.808  - debug: sql.0 CREATE TABLE iobroker_master.ts_number  (id INTEGER, ts BIGINT, val REAL,    ack BOOLEAN, _from INTEGER, q INTEGER, PRIMARY KEY(id, ts));
                2016-06-01 07:38:46.963  - debug: sql.0 Response: null
                2016-06-01 07:38:46.968  - debug: sql.0 CREATE TABLE iobroker_master.ts_string  (id INTEGER, ts BIGINT, val TEXT,    ack BOOLEAN, _from INTEGER, q INTEGER, PRIMARY KEY(id, ts));
                2016-06-01 07:38:47.103  - debug: sql.0 Response: null
                2016-06-01 07:38:47.108  - debug: sql.0 CREATE TABLE iobroker_master.ts_bool    (id INTEGER, ts BIGINT, val BOOLEAN, ack BOOLEAN, _from INTEGER, q INTEGER, PRIMARY KEY(id, ts));
                2016-06-01 07:38:47.218  - debug: sql.0 Response: null
                2016-06-01 07:38:47.220  - info: sql.0 Connected to mysql
                Die Datenbank wurde angelegt und Daten werden geschrieben.
                interissant ist, dass nun eine Gruppe angelegt wurde
                PS: die Datenbank "iobroker.master" hatte ich manuell angelegt. Die werde ich nun wieder löschen
                Jürgen
                • BluefoxB Offline
                  BluefoxB Offline
                  Was meinst du damit?
                  • derAugeD Offline
                    derAugeD Offline
                    derAuge
                    @Bluefox:
                    Was meinst du damit? `
                    bei SQL wurden die beiden Datenbanken (iobroker und iobroker_master) in dem "Ordner" (Gruppe) ioBroker zusammen gefasst. (Siehe Bild)
                    Ich kann nicht sagen wo das her kommt.
                    PS:
                    Nun steht im Admin dass es eine Version 1.0.7 gibt. (Installiert = 1.0.5) Er wird jedoch kein Update-Symbol angezeigt
                    Jürgen
