  4. Test Adapter hue-extended
huehue-extended
167 Beiträge 49 Kommentatoren 44.3k Aufrufe 39 Beobachtet
  • ZefauZ Offline
    ZefauZ Offline
    Zefau
    schrieb am zuletzt editiert von Zefau
    Repository https://github.com/Zefau/ioBroker.hue-extended
    Meine Adapter: https://zefau.github.io/iobroker/
    A sigi234S Horst BöttcherH A 5 Antworten Letzte Antwort
    • ZefauZ Zefau
      aleks-83
      Der Punkt "Synchronisiere auch doppelte Szenen" ist jetzt übrigens auch verfügbar.
      = Dell Optiplex Micro - 10GB RAM - 200GB SSD - Debian VM =
      = Node.js v20.19.6 = NPM 10.8.2 = JS Controller 7.0.7 =
      Ubiquiti UAP-AC-LR - UAP-AC-Lite - Synology DS716+II - Fritz!Box 7490
      Glasfaser 400
        aleks-83
        Wasn nu los?
        Aus heiterem Himmel.
        Hat das was mit dem extended Adapter zu tun?
        2019-10-30 11:00:16.237 - info: weatherunderground.0 (1076) Terminated (NO_ERROR): Without reason
        2019-10-30 11:00:16.770 - info: host.NUC(NUCmaster) instance system.adapter.weatherunderground.0 terminated with code 0 (NO_ERROR)
        2019-10-30 11:00:23.131 - info: host.NUC(NUCmaster) instance system.adapter.ical.0 terminated with code 0 (NO_ERROR)
        2019-10-30 11:01:00.010 - info: host.NUC(NUCmaster) instance system.adapter.dwd.0 started with pid 8868
        2019-10-30 11:01:05.516 - info: host.NUC(NUCmaster) instance system.adapter.dwd.0 terminated with code 0 (NO_ERROR)
        2019-10-30 11:31:00.421 - info: host.NUC(NUCmaster) instance system.adapter.dwd.0 started with pid 8440
        2019-10-30 11:31:05.270 - info: host.NUC(NUCmaster) instance system.adapter.dwd.0 terminated with code 0 (NO_ERROR)
        2019-10-30 11:55:52.103 - error: host.NUC(NUCmaster) Caught by controller[1]: FATAL ERROR: Ineffectiv
        2019-10-30 11:55:52.104 - error: host.NUC(NUCmaster) Caught by controller[2]: e mark-compacts near heap limit Allocation failed - JavaScript heap out of memory
        2019-10-30 11:55:52.104 - error: host.NUC(NUCmaster) Caught by controller[3]: 1: 00007FF78CCFDD8A v8::int
        2019-10-30 11:55:52.104 - error: host.NUC(NUCmaster) Caught by controller[4]: ernal::GCIdleTimeHandler::GCIdleTimeHandler+4506
        2019-10-30 11:55:52.104 - error: host.NUC(NUCmaster) Caught by controller[4]: 2: 00007FF78CCD8886 node::MakeCallback+4534
        2019-10-30 11:55:52.105 - error: host.NUC(NUCmaster) Caught by controller[4]: 3: 00007FF78CCD9200 node_module
        2019-10-30 11:55:52.105 - error: host.NUC(NUCmaster) Caught by controller[5]: _register+2032
        2019-10-30 11:55:52.105 - error: host.NUC(NUCmaster) Caught by controller[5]: 4: 00007FF78CFF30DE v8::internal::FatalProc
        2019-10-30 11:55:52.106 - error: host.NUC(NUCmaster) Caught by controller[6]: essOutOfMemory+846
        2019-10-30 11:55:52.106 - error: host.NUC(NUCmaster) Caught by controller[6]: 5: 00007FF78CFF300F v8::inte
        2019-10-30 11:55:52.106 - error: host.NUC(NUCmaster) Caught by controller[7]: rnal:
        2019-10-30 11:55:52.106 - error: host.NUC(NUCmaster) Caught by controller[8]: :FatalProcessOutOfMemory+639
        2019-10-30 11:55:52.106 - error: host.NUC(NUCmaster) Caught by controller[8]: 6: 00007FF78D1D9804 v8::internal::Heap::MaxHeapGrowingFactor+9620
        2019-10-30 11:55:52.107 - error: host.NUC(NUCmaster) Caught by controller[8]: 7: 00007FF78D1D07E6 v8::internal::ScavengeJob::operator=+24550
        2019-10-30 11:55:52.107 - error: host.NUC(NUCmaster) Caught by controller[8]: 8: 00007FF78D1CEE3C v8::internal::ScavengeJob::operator=+17980
        2019-10-30 11:55:52.107 - error: host.NUC(NUCmaster) Caught by controller[8]: 9: 00007FF78D1D7B87 v8::internal:
        2019-10-30 11:55:52.110 - error: host.NUC(NUCmaster) Caught by controller[9]: :Heap::MaxHeapGrowingFactor+2327
        2019-10-30 11:55:52.111 - error: host.NUC(NUCmaster) Caught by controller[9]: 10: 00007FF78D1D7C06 v8::internal::Heap::MaxHeapGrowingFactor+2454
        2019-10-30 11:55:52.111 - error: host.NUC(NUCmaster) Caught by controller[9]: 11: 00007FF78D301EA7 v8::i
        2019-10-30 11:55:52.111 - error: host.NUC(NUCmaster) Caught by controller[10]: nternal::Factory::NewFillerObject+55
        2019-10-30 11:55:52.111 - error: host.NUC(NUCmaster) Caught by controller[10]: 12: 00007FF78D37F096 v8::internal::operator<<+73494
        2019-10-30 11:55:52.111 - error: host.NUC(NUCmaster) Caught by controller[10]: 13: 000003688D75C5C1
        2019-10-30 11:55:52.111 - error: host.NUC(NUCmaster) instance system.adapter.hue-extended.0 terminated with code 134 (134)
        2019-10-30 11:55:52.111 - info: host.NUC(NUCmaster) Restart adapter system.adapter.hue-extended.0 because enabled
        2019-10-30 11:56:22.122 - info: host.NUC(NUCmaster) instance system.adapter.hue-extended.0 started with pid 8052
        Glasfaser 400
        • A aleks-83
          Wasn nu los?
          BBTownB Online
          BBTownB Online
          BBTown
          @aleks-83 sagte in Test Adapter hue-extended v1.1.x GitHub/Latest:
          Da ist doch bereits ein Hinweis ...
            aleks-83
            ... den ich nicht verstehe 😬
            Glasfaser 400
            • A aleks-83
              BBTownB Online
              BBTownB Online
              BBTown
              @aleks-83
              ok, ich versuche dir auf die Sprünge zu helfen ... out of memory
              Du hast ein Speicher(platz) Problem
                aleks-83
                schrieb am zuletzt editiert von aleks-83
                Wüsste nicht wo
                Glasfaser 400
                • Dr. BakteriusD Online
                  Dr. Bakterius
                  Ich hatte heute auch eine Warnung (per Skript) bekommen, dass der RAM voll läuft. Die hue-extended Instanz hat fast 900 MB verbraucht. Nach einem Neustart der Instanz war der Verbrauch wieder normal, steigt aber wieder langsam an. 😕
                  H 1 Antwort Letzte Antwort
                    HeliosFan
                    @Dr-Bakterius Kann ich nicht bestätigen.
                    Bei mir macht der hue.exetended keinerlei Problemene.
                    Der einzige Adapter der sich völlig grundlos immer wieder über 100 MB aufbläst, ist der BackitUp.
                    Dr. BakteriusD 1 Antwort Letzte Antwort
                      Adnim
                      Hi!
                      nutze auch schon länger den extended, genaue einstiegsversion kann ich nicht sagen. Die Aktuelle Version schaltet meine Lampen aber nicht mehr zuverlässig. Die Trigger der Szenen werden ausgelöst das sehe ich im LOG, allerdings schaltet dann die Lampe nicht an. Manchmal funktioniert es, nachstellen wann und warum konnte ich nicht. Werde LOG nachreichen wenn ich den Fehler wieder sehe!
                      Hat sowas sonst jemand?
                      A 1 Antwort Letzte Antwort
                      • H HeliosFan
                        Dr. Bakterius
                        @HeliosFan Bisher auch keine Probleme in den letzten Monaten (seit ich diesen Adapter verwende). Doch in den letzten 2,5 Stunden hat er sich von ca. 80 MB nach dem Neustart auf fast 500 MB entwickelt.
                        ZefauZ 1 Antwort Letzte Antwort
                          Dr. Bakterius
                          schrieb am zuletzt editiert von Dr. Bakterius
                          Wie kann man eigentlich eine bestimmte / ältere Version des Adapters installieren? Wenn man auf das + klickt wo man die Version wählen kann, kommt bei mir nur folgendes:
                          Edit:
                          Habe es auf der Console gemacht:
                          root@iobroker:/# cd /opt/iobroker
                          root@iobroker:/opt/iobroker# npm install iobroker.hue-extended@1.1.1 --production
                            ZefauZ Offline
                            ZefauZ Offline
                            Zefau
                            @Dr-Bakterius sagte in Test Adapter hue-extended v1.1.x GitHub/Latest:
                            Ist der Garbage Collector in den Adapter Einstellungen aktiviert?
                            • ZefauZ Zefau
                              Dr. Bakterius
                              @Zefau sagte in Test Adapter hue-extended v1.1.x GitHub/Latest:
                              Nein, ist er nicht. Mit v1.1.1 habe ich das RAM-Problem bisher nicht.
                              • A Adnim
                                Hi!
                                Adnim
                                schrieb am zuletzt editiert von Adnim
                                @Adnim sagte in Test Adapter hue-extended v1.1.x GitHub/Latest:
                                Hi!
                                Hier mal die Logs @Zefau was ist falsch bei mir?
                                hue-extended.1	2019-10-31 06:00:03.421	debug	(24027) Attempt 1x - No commands to send to TreppeOG (NachtlichttreppeOG) (groups/2/action).
                                hue-extended.1	2019-10-31 06:00:03.401	debug	(24027) Add to queue ({"path":"scenes.002-treppeog.nachtlichttreppeog","type":"scenes","name":"TreppeOG (NachtlichttreppeOG)","uid":"sKOKnMzhniQQNzP","trigger":"groups/2/action"}) commands: {"scene":
                                hue-extended.1	2019-10-31 06:00:03.400	debug	(24027) State of hue-extended.1.scenes.002-treppeog.nachtlichttreppeog.action.trigger has changed {"val":true,"ack":false,"ts":1572498003399,"q":0,"from":"system.adapter.javascript.0","user":"system.
                                hue-extended.1	2019-10-31 05:57:40.287	debug	(24027) Attempt 1x - No commands to send to Bad (Nachtlicht) (groups/1/action).
                                hue-extended.1	2019-10-31 05:57:40.172	debug	(24027) Add to queue ({"path":"scenes.001-bad.nachtlicht","type":"scenes","name":"Bad (Nachtlicht)","uid":"dr0jUSsdM1VFCgt","trigger":"groups/1/action"}) commands: {"scene":"dr0jUSsdM1VFCgt"}
                                hue-extended.1	2019-10-31 05:57:40.172	debug	(24027) State of hue-extended.1.scenes.001-bad.nachtlicht.action.trigger has changed {"val":true,"ack":false,"ts":1572497860171,"q":0,"from":"system.adapter.javascript.0","user":"system.user.admin","
                                Weiterhin sehe ich gerade das der RAM verbrauch NIO ist:
                                  Dr. Bakterius
                                  Mit der v1.1.2 stimmt einiges nicht. Der RAM läuft voll und man kann keine ältere Version über die Weboberfläche installieren. Bei der v1.1.1 existieren diese Probleme nicht. Ob es auch Probleme beim Senden der Befehle gibt, habe ich erst gar nicht getestet.
                                    ZefauZ Offline
                                    ZefauZ Offline
                                    Zefau
                                    @Dr-Bakterius @Adnim @aleks-83 danke euch für das intensive Testen und das wertvolle Feedback. Die Version v1.1.3 sollte die Punkte beheben (changelog siehe https://github.com/Zefau/ioBroker.hue-extended/releases).
                                      aleks-83
                                      Wie kommst du dann eigentlich immer so schnell auf die Fehlerursachen?
                                      Sie werden doch wohl nicht so offensichtlich sein!?
                                      Sonst hättest du sie ja gar nicht erst "drin gelassen".
                                      EDIT:
                                      Bei mir steigt der RAM Verbrauch vom extended Adapter 1.1.3 immer noch stetig an.
                                      gestartet bei ca. 74 MB. Nach 10 Minuten bei 86 MB
                                      Glasfaser 400
                                      Dr. BakteriusD ZefauZ 2 Antworten Letzte Antwort
                                      • A aleks-83
                                        EDIT:
                                        Dr. Bakterius
                                        Das war bei v1.1.1 auch so. Bei mir hat er nach 24 Stunden etwa 200 MB beansprucht. Aber v1.1.2 war nach wenigen Stunden bei fast 1 GB! Mal sehen wie sich v1.1.3 verhält...
                                        • A aleks-83
                                          EDIT:
                                          ZefauZ Offline
                                          ZefauZ Offline
                                          Zefau
                                          @aleks-83 auf wie viel ist der refresh eingestellt? Was steht in der Instanzübersicht unter Ereignisse (neben RAM-Nutzung)? Ist die Warteschlange / Queue aktiviert?
