  5. benötige Hilfe bei enigma2 Adapter Erweiterung
    5.2k
7 Beiträge 3 Kommentatoren 733 Aufrufe 1 Beobachtet
  • Matten MattenM Offline
    Matten Matten
    schrieb am zuletzt editiert von Matten Matten
    Hallo ich würde gerne den enigma2 Adapter erweitern, in dem ich die Timerabfrage einbauen möchte. Der code sieht wie folgt aus:
    function TimerSearch (command, deviceId, xml) {
    	//var bool;
        switch (command.toUpperCase())
            case "TIMERLIST":
                // Clear Timerlist
                adapter.delObject('Timer');
    			if(xml.e2timerlist.e2timer !== undefined)
    				for (var i = 0; i < xml.e2timerlist.e2timer.length; i++)
    					adapter.setObjectNotExists('Timer.' + i + '.Event_Name', {
    						type: 'state',
    						common: {
    							type: 'string',
    							role: 'state',
    							read:  true,
    							write: false
    						native: {}
    					adapter.setObjectNotExists('Timer.' + i + '.Station', {
    						type: 'state',
    						common: {
    							type: 'string',
    							role: 'state',
    							read:  true,
    							write: false
    						native: {}
    					adapter.setObjectNotExists('Timer.' + i + '.Disabled', {
    						type: 'state',
    						common: {
    							type: 'number',
    							role: 'state',
    							states: {
    								0: 'Timer aktiviert',
    								1: 'Timer deaktiviert'
    							name: 'Timer Aktivität',
    							read:  true,
    							write: false
    						native: {}
    					adapter.setObjectNotExists('Timer.' + i + '.Repeated', {
    						type: 'state',
    						common: {
    							type: 'number',
    							role: 'state',
    							name: 'Timer Wiederholung',
    							read:  true,
    							write: false
    						native: {}
    					adapter.setObjectNotExists('Timer.' + i + '.Timer_Start', {
    						type: 'state',
    						common: {
    							type: 'number',
    							role: 'state',
    							read:  true,
    							write: false
    						native: {}
    					adapter.setObjectNotExists('Timer.' + i + '.Timer_End', {
    						type: 'state',
    						common: {
    							type: 'number',
    							role: 'state',
    							read:  true,
    							write: false
    						native: {}
    					adapter.setObjectNotExists('Timer.' + i + '.Timer_servicereference', {
    						type: 'state',
    						common: {
    							type: 'number',
    							role: 'state',
    							read:  true,
    							write: false
    						native: {}
    					//++BUTTON++ 	Timer_Toggle
    					adapter.setObjectNotExists('Timer.' + i + '.Delete', {
    						type: 'state',
    						common: {
    							type: 'boolean',
    							role: 'button',
    							read:  false,
    							write: true
    						native: {}
    					adapter.setObjectNotExists('Timer.' + i + '.Timer_Toggle', {
    						type: 'state',
    						common: {
    							type: 'boolean',
    							role: 'button',
    							read:  false,
    							write: true
    						native: {}
    					adapter.setState('Timer.' + i + '.Event_Name', {val: xml.e2timerlist.e2timer[i].e2name[0], ack: true});
    					adapter.setState('Timer.' + i + '.Station', {val: xml.e2timerlist.e2timer[i].e2servicename[0], ack: true});
    					adapter.setState('Timer.' + i + '.Disabled', {val: xml.e2timerlist.e2timer[i].e2disabled[0], ack: true});
    					adapter.setState('Timer.' + i + '.Repeated', {val: xml.e2timerlist.e2timer[i].e2repeated[0], ack: true});
    					adapter.setState('Timer.' + i + '.Timer_servicereference', {val: xml.e2timerlist.e2timer[i].e2servicereference[0], ack: true});
    					adapter.setState('Timer.' + i + '.Timer_End', {val: DateTime(xml.e2timerlist.e2timer[i].e2timeend[0]), ack: true});
    					adapter.setState('Timer.' + i + '.Timer_Start', {val: DateTime(xml.e2timerlist.e2timer[i].e2timebegin[0]), ack: true});
    			break;
            default:
                adapter.log.info("received unknown TimerSearch '"+command+"' @ TimerSearch");
    function DateTime(eventtime) {
    	var date = new Date(eventtime * 1000);
    	// Hours part from the timestamp
    	var hours = date.getHours();
    	// Minutes part from the timestamp
    	var minutes = "0" + date.getMinutes();
    	// Will display time in 10:30 format
    	return hours + ':' + minutes.substr(-2);
    Das auslesen der xml und erstellen der Objekte funktioniert soweit, jetzt würde ich gerne auf das auslösen der Objekt-button: 'Timer.' + i + '.Delete' und 'Timer.' + i + '.Timer_Toggle' reagieren
    nun bin ich aber mit meinem Latein am Ende was java Programierung an geht, da die obigen Objekte ja jeh nach dem wie viele Timer Ermittelt wurden unterschiedlich viele sind.
    adapter.on('stateChange', function (id, state) {
    	if (id && state && !state.ack) {
            var parts = id.split('.');
            var name = parts.pop();
            if (id === adapter.namespace + '.Timer.0.Timer_Toggle') {
                adapter.getState('Timer.' + i + '.Timer_servicereference', function(err, state) {
                    var T_sRef  = state.val;
                    adapter.getState('Timer.' + i + '.Timer_Start', function(err, state) {
                        var T_begin  = state.val;
                        adapter.getState('Timer.' + i + '.Timer_End', function(err, state) {
                            var T_end  = state.val;
                            getResponse('NONE', deviceId, PATH['TIMER_TOGGLE'] + T_sRef + '&begin=' + T_begin + '&end=' + T_end, function (error, command, deviceId, xml) {
                                if (!error) {
                                    adapter.setState('Timer.' + i + '.Timer_Toggle', state.val, true);
                                } else {
                                    getResponse('TIMERLIST', deviceId, PATH['TIMERLIST'], TimerSearch);
    		} else if (id === adapter.namespace + '.Timer.0.Delete') {
                            getResponse('NONE', deviceId, PATH['DELETE'] + T_sRef + '&begin=' + T_begin + '&end=' + T_end, function (error, command, deviceId, xml) {
                                if (!error) {
                                    adapter.setState('Timer.' + i + '.Delete', state.val, true);
                                } else {
                                    adapter.setState('Timer.' + i + '.Delete', {val: state.val, ack: true});
    Ich hab jetzt das problem das ich nicht weiß wie ich statt :
    //und
    es ändern kann um das genau so dynamisch zu halten
    Ich hoffe ich hab mich verständlich ausgedrückt?
    Matten Matten
    ioBroker auf Beelink mit WIN10 home|CCU3 (Raspberrymatic)|Neato BotVac D3|HYPERION Ambilight auf RPI3 und RPI ZeroW|HA-Bridge|Milight LED|Nodered&Redmatic|VU Duo2 & Solo se V2
      Matten Matten
      die erstellten Objekte sehen dann z.b. so aus:
        Matten Matten
        ach ja und das einfache
        löscht leider nicht den Objektordner sammt der Timer :man-shrugging:
        ScroungerS 2 Antworten Letzte Antwort
        • Matten MattenM Matten Matten
          ScroungerS Offline
          ScroungerS Offline
          Scrounger
          @Matten-Matten
          Du kannst mit 'getStates("enigma2.0.Timer.*")' bzw. 'getObjects' alle Datenpunkte bekommen. Die musst dann in ner Schleife durchlaufen und die ID zum Löschen der einzelnen Datenpunkte verwenden.
          • DutchmanD Offline
            DutchmanD Offline
            Dutchman
            ich müsste die anstehende Struktur bzw Datenpunkte mal sehen.
            theoretisch reagierst du ja immer auf ein event das in iobroker der wert geandert wird, das macht man mit nem subscriptie state (zb * fuer all oder nur die du erstellt hast).
            Ergo der on event gibt dir den state, eventuell musst du nur die "." splitten und dan den letzten nemen fuer deinen wert ?
              ScroungerS Offline
              ScroungerS Offline
              Scrounger
              @Matten-Matten
              Ich hab nochmal über die Struktur der Timer Datenpunkte nachgedacht.
              Ich würde die nicht dynamisch erzeugen und löschen.
              Nehmen wir folgendes Beispiel. Die Box hat aktuell 5 Timer, d.h. es existieren x.Timer.0.x -> x.Timer.5.x. Wenn jetzt eine Aufnahme erfolgt ist würdest du z.B. x.Timer.5.x löschen. Wenn aber jetzt jmd z.B. im Vis oder Skripten den Timer x.Timer.5.x verwendet bekommt der ein Problem.
              Denke es wäre besser du machst z.B. 10 fixe Timer.x Datenpunkte, die dann aufsteigend nach RecordTime befüllt werden. Wenn dann ab Timer.5.x keine mehr existieren, dann lösch nur die Daten in den Datenpunkten. Zusätzlich würde ich noch ein Boolean einführen - timerExist - den du dann in diesem Fall auf 'false' setzen würdest.
              Matten MattenM 1 Antwort Letzte Antwort
              • ScroungerS Scrounger
                @Matten-Matten
                Matten Matten
                @Scrounger
                Die fixe Timerprogrammierung hatte ich schon Mal mit 6 oder sogar 10 timern. Ich denke aber auch das du Recht hast die Timer Datenpunkte fest anzulegen.
