  4. InfluxDB läuft nicht mehr
15 Beiträge 4 Kommentatoren 1.9k Aufrufe
    Hallo Bluefox,
    nach deiner Update-Orgie hat fast alles super geklappt.
    Nur bekomme ich jetzt probleme meinen View aufzurufen, bei dem ein flot-chart mit Daten aus der influxDB ist.
    der influxdb-Adapter wirft einige Fehler:
    uncaught	23 18:17:33.707	error	exception: this._createKeyValueString is not a function
    influxdb-0	23 18:17:33.681	warn	Exception: TypeError: this._createKeyValueString is not a function
    TypeError:	23 18:17:33.678	error	at InfluxDB.writeSeries (/opt/iobroker/node_modules/iobroker.influxdb/lib/node-influx/index.js:322:16)
    TypeError:	23 18:17:33.678	error	at InfluxDB._prepareValues (/opt/iobroker/node_modules/iobroker.influxdb/lib/node-influx/index.js:271:5)
    TypeError:	23 18:17:33.678	error	at Function.forEach (/opt/iobroker/node_modules/iobroker.influxdb/node_modules/lodash/lodash.js:8617:14)
    TypeError:	23 18:17:33.678	error	at /opt/iobroker/node_modules/iobroker.influxdb/node_modules/lodash/lodash.js:4380:18
    TypeError:	23 18:17:33.678	error	at baseForOwn (/opt/iobroker/node_modules/iobroker.influxdb/node_modules/lodash/lodash.js:2654:24)
    TypeError:	23 18:17:33.678	error	at /opt/iobroker/node_modules/iobroker.influxdb/node_modules/lodash/lodash.js:4411:15
    TypeError:	23 18:17:33.678	error	at /opt/iobroker/node_modules/iobroker.influxdb/lib/node-influx/index.js:272:7
    TypeError:	23 18:17:33.678	error	at arrayEach (/opt/iobroker/node_modules/iobroker.influxdb/node_modules/lodash/lodash.js:451:11)
    TypeError:	23 18:17:33.678	error	at /opt/iobroker/node_modules/iobroker.influxdb/lib/node-influx/index.js:284:28
    TypeError:	23 18:17:33.678	error	this._createKeyValueString is not a function
    uncaught	23 18:17:33.662	error	exception: this._createKeyValueString is not a function
    influxdb-0	23 18:17:17.303	error	Error: retention policy already exists
    …und das alles nur, weil ich auf meinem Testsystem nicht die influxDB installiert hatte 😢 😢 :oops: :oops: 😢 😢
    Rainer
    • BluefoxB Offline
      BluefoxB Offline
      Heißt es, dass es gelöst ist?
        @Bluefox:
        Heißt es, dass es gelöst ist? `
        Sorry - Nein, nicht gelöst.
        Wollte nur sagen, dass ich die Influx nicht bei dem Github-Testing mit bestehenden Daten getestet habe.
        Fehler ist aktuell noch da.
        Rainer
        Danke für deine Geduld mit uns!
          PrinzEisenherz1
          Ich hab ähnlichen Fehler nach m update mit influxdb
          Hier Auszug aus m Log
          raspberrypi	24 19:22:21.829	info	host.raspberrypi Restart adapter system.adapter.influxdb.0 because enabled
          raspberrypi	24 19:22:21.827	error	host.raspberrypi instance system.adapter.influxdb.0 terminated with code 0 (OK)
          raspberrypi	24 19:22:21.812	info	host.raspberrypi Restart adapter system.adapter.influxdb.0 because enabled
          raspberrypi	24 19:22:21.810	error	host.raspberrypi instance system.adapter.influxdb.0 terminated with code 0 (OK)
          influxdb.0	24 19:22:21.263	warn	influxdb.0 Exception: TypeError: this._createKeyValueString is not a function
          influxdb.0	24 19:22:21.262	error	TypeError: this._createKeyValueString is not a function at /opt/iobroker/node_modules/iobroker.influxdb/lib/node-influx/index.js:284:28 at arrayEach (/opt/iobroker/node_modules/iobroker.influx
          influxdb.0	24 19:22:21.260	error	uncaught exception: this._createKeyValueString is not a function
          influxdb.0	24 19:21:58.728	info	influxdb.0 enabled logging of hm-rega.0.24379
          influxdb.0	24 19:21:58.724	info	influxdb.0 enabled logging of hm-rega.0.23766
          influxdb.0	24 19:21:58.621	info	influxdb.0 Connecting http://192.168.178.28:8086 ...
          influxdb.0	24 19:21:58.619	info	influxdb.0 starting. Version 0.3.0 in /opt/iobroker/node_modules/iobroker.influxdb
          raspberrypi	24 19:21:52.340	info	host.raspberrypi instance system.adapter.influxdb.0 started with pid 5604
          raspberrypi	24 19:21:52.338	info	host.raspberrypi instance system.adapter.influxdb.0 started with pid 5604
          raspberrypi	24 19:21:22.431	info	host.raspberrypi Restart adapter system.adapter.influxdb.0 because enabled
          raspberrypi	24 19:21:22.429	error	host.raspberrypi instance system.adapter.influxdb.0 terminated with code 6 (uncaught exception)
          raspberrypi	24 19:21:22.296	info	host.raspberrypi Restart adapter system.adapter.influxdb.0 because enabled
          raspberrypi	24 19:21:22.293	error	host.raspberrypi instance system.adapter.influxdb.0 terminated with code 6 (uncaught exception)
          influxdb.0	24 19:21:21.151	error	uncaught exception: this._createKeyValueString is not a function
          influxdb.0	24 19:20:58.350	info	influxdb.0 enabled logging of hm-rega.0.24379
          influxdb.0	24 19:20:58.348	info	influxdb.0 enabled logging of hm-rega.0.23766
          influxdb.0	24 19:20:58.247	info	influxdb.0 Connecting http://192.168.178.28:8086 ...
          influxdb.0	24 19:20:58.244	info	influxdb.0 starting. Version 0.3.0 in /opt/iobroker/node_modules/iobroker.influxdb
          raspberrypi	24 19:20:51.744	info	host.raspberrypi instance system.adapter.influxdb.0 started with pid 5401
          raspberrypi	24 19:20:51.741	info	host.raspberrypi instance system.adapter.influxdb.0 started with pid 5401
          host-raspberrypi	24 19:20:21.662	info	Restart adapter system.adapter.influxdb.0 because enabled
          host-raspberrypi	24 19:20:21.658	error	instance system.adapter.influxdb.0 terminated with code 0 (OK)
          influxdb-0	24 19:20:21.621	info	terminating
          influxdb-0	24 19:20:21.302	warn	Exception: TypeError: this._createKeyValueString is not a function
          TypeError:	24 19:20:21.300	error	at InfluxDB.writeSeries (/opt/iobroker/node_modules/iobroker.influxdb/lib/node-influx/index.js:322:16)
          TypeError:	24 19:20:21.300	error	at InfluxDB._prepareValues (/opt/iobroker/node_modules/iobroker.influxdb/lib/node-influx/index.js:271:5)
          TypeError:	24 19:20:21.300	error	at Function.forEach (/opt/iobroker/node_modules/iobroker.influxdb/node_modules/lodash/lodash.js:8634:14)
          TypeError:	24 19:20:21.300	error	at /opt/iobroker/node_modules/iobroker.influxdb/node_modules/lodash/lodash.js:4380:18
          TypeError:	24 19:20:21.300	error	at baseForOwn (/opt/iobroker/node_modules/iobroker.influxdb/node_modules/lodash/lodash.js:2654:24)
          TypeError:	24 19:20:21.300	error	at /opt/iobroker/node_modules/iobroker.influxdb/node_modules/lodash/lodash.js:4411:15
          TypeError:	24 19:20:21.300	error	at /opt/iobroker/node_modules/iobroker.influxdb/lib/node-influx/index.js:272:7
          TypeError:	24 19:20:21.300	error	at arrayEach (/opt/iobroker/node_modules/iobroker.influxdb/node_modules/lodash/lodash.js:451:11)
          TypeError:	24 19:20:21.300	error	at /opt/iobroker/node_modules/iobroker.influxdb/lib/node-influx/index.js:284:28
          TypeError:	24 19:20:21.300	error	this._createKeyValueString is not a function
          uncaught	24 19:20:21.296	error	exception: this._createKeyValueString is not a function
          influxdb-0	24 19:20:21.106	warn	Exception: TypeError: this._createKeyValueString is not a function
          TypeError:	24 19:20:21.100	error	at InfluxDB.writeSeries (/opt/iobroker/node_modules/iobroker.influxdb/lib/node-influx/index.js:322:16)
          TypeError:	24 19:20:21.100	error	at InfluxDB._prepareValues (/opt/iobroker/node_modules/iobroker.influxdb/lib/node-influx/index.js:271:5)
          TypeError:	24 19:20:21.100	error	at Function.forEach (/opt/iobroker/node_modules/iobroker.influxdb/node_modules/lodash/lodash.js:8634:14)
          TypeError:	24 19:20:21.100	error	at /opt/iobroker/node_modules/iobroker.influxdb/node_modules/lodash/lodash.js:4380:18
          TypeError:	24 19:20:21.100	error	at baseForOwn (/opt/iobroker/node_modules/iobroker.influxdb/node_modules/lodash/lodash.js:2654:24)
          TypeError:	24 19:20:21.100	error	at /opt/iobroker/node_modules/iobroker.influxdb/node_modules/lodash/lodash.js:4411:15
          TypeError:	24 19:20:21.100	error	at /opt/iobroker/node_modules/iobroker.influxdb/lib/node-influx/index.js:272:7
          TypeError:	24 19:20:21.100	error	at arrayEach (/opt/iobroker/node_modules/iobroker.influxdb/node_modules/lodash/lodash.js:451:11)
          TypeError:	24 19:20:21.100	error	at /opt/iobroker/node_modules/iobroker.influxdb/lib/node-influx/index.js:284:28
          TypeError:	24 19:20:21.100	error	this._createKeyValueString is not a function
          Gibts da vielleicht schon ne Lösung?
          Johnny
          Intel-NUC mit ProxMox: ioBroker,SQL, logging Strom- Gas- u. Wasserzähler;10Zoll Tab im Flur für VIS; weiteres: Homematic CCU2, Homeduino, Kameras, selbstgebaute Wetterstation;
            Ich habe mir das bei mir nochmal näher angesehen:
            host-Test-Pi3 24 21:12:39.371 error instance system.adapter.influxdb.0 terminated with code 0 (OK)
            influxdb-0 24 21:12:39.350 info terminating
            influxdb-0 24 21:12:38.841 warn Exception: TypeError: this._createKeyValueString is not a function
            TypeError: 24 21:12:38.837 error at InfluxDB.writeSeries (/opt/iobroker/node_modules/iobroker.influxdb/lib/node-influx/index.js:322:16)
            TypeError: 24 21:12:38.837 error at InfluxDB._prepareValues (/opt/iobroker/node_modules/iobroker.influxdb/lib/node-influx/index.js:271:5)
            TypeError: 24 21:12:38.837 error at Function.forEach (/opt/iobroker/node_modules/iobroker.influxdb/node_modules/lodash/lodash.js:8617:14)
            TypeError: 24 21:12:38.837 error at /opt/iobroker/node_modules/iobroker.influxdb/node_modules/lodash/lodash.js:4380:18
            TypeError: 24 21:12:38.837 error at baseForOwn (/opt/iobroker/node_modules/iobroker.influxdb/node_modules/lodash/lodash.js:2654:24)
            TypeError: 24 21:12:38.837 error at /opt/iobroker/node_modules/iobroker.influxdb/node_modules/lodash/lodash.js:4411:15
            TypeError: 24 21:12:38.837 error at /opt/iobroker/node_modules/iobroker.influxdb/lib/node-influx/index.js:272:7
            TypeError: 24 21:12:38.837 error at arrayEach (/opt/iobroker/node_modules/iobroker.influxdb/node_modules/lodash/lodash.js:451:11)
            TypeError: 24 21:12:38.837 error at /opt/iobroker/node_modules/iobroker.influxdb/lib/node-influx/index.js:284:28
            TypeError: 24 21:12:38.837 error this._createKeyValueString is not a function
            uncaught 24 21:12:38.808 error exception: this._createKeyValueString is not a function
            inMem 24 21:12:28.769 debug message hm-rega.1.12885 hm-rega.1.12885 val=0, ack=true, ts=1464117148762, q=0, from=system.adapter.hm-rega.1, lc=1464116968710
            influxdb-0 24 21:12:11.650 error Error: retention policy already exists
            Der wahrscheinliche Übeltäter ist eine Systemvariable vom Typ Zahl.
            Er scheint irgendwie als String erkannt zu werden.
            @Bluefox: Es kann sein, dass das die gleiche Ursache für die bisherige Meldung ist, die in etwa lautete Ein Datenpunkt vom Typ String/Value kann nicht angelegt werden, da er bereits als Typ Value/String existiert. Ich hatte dir das in Kassel bereits erzählt.
            Hoffe das hilft etwas bei der Suche
            Rainer
              PrinzEisenherz1
              Gibt's schon irgend ne Lösung für das Problem?
              Johnny
                PrinzEisenherz1
                Hi Bluefox, hast du vielleicht schon herausgefunden warum influxdb nicht mehr läuft?
                Gruß Johnny
                • BluefoxB Offline
                  BluefoxB Offline
                  Bei mir mit influxdDb 0.13 läuft.. Aber man muss vom git installieren.
                  Bitte berichten.
                    Bei mir hat es nicht geholfen:
                    Test-Pi3	05 21:02:26.426	info	host.Test-Pi3 Restart adapter system.adapter.influxdb.0 because enabled
                    Test-Pi3	05 21:02:26.425	error	host.Test-Pi3 instance system.adapter.influxdb.0 terminated with code 0 (OK)
                    influxdb.0	05 21:02:25.888	warn	influxdb.0 Exception: TypeError: err.indexOf is not a function
                    influxdb.0	05 21:02:25.888	error	TypeError: err.indexOf is not a function at /opt/iobroker/node_modules/iobroker.influxdb/main.js:70:36 at /opt/iobroker/node_modules/iobroker.influxdb/node_modules/influx/index.js:384:14 a
                    influxdb.0	05 21:02:25.887	error	uncaught exception: err.indexOf is not a function
                    influxdb.0	05 21:02:25.845	info	influxdb.0 Connected!
                    EDIT:
                    kommt der Fehler von der Änderung:
                    hm-rega-1	05 21:03:33.811	error	runScriptFile Error: ENOENT: no such file or directory, open '/opt/iobroker/node_modules/iobroker.hm-rega/lib/../regascripts/alarms.fn'
                    Sorry
                    Rainer
                    • BluefoxB Offline
                      BluefoxB Offline
                      Aktuelle Version auf dem git sollte laufen (auch bei Reiner sollte die besser laufen :lol: )
                        @Bluefox:
                        (auch bei Reiner sollte die besser laufen :lol: ) `
                        leider Nein:
                        Test-Pi3	2016-06-07 09:23:05.460	error	host.Test-Pi3 instance system.adapter.influxdb.0 terminated with code 0 (OK)
                        influxdb.0	2016-06-07 09:23:04.929	warn	influxdb.0 Exception: TypeError: err.indexOf is not a function
                        influxdb.0	2016-06-07 09:23:04.929	error	TypeError: err.indexOf is not a function at /opt/iobroker/node_modules/iobroker.influxdb/main.js:70:36 at /opt/iobroker/node_modules/iobroker.influxdb/node_modules/influx/index.js:384:14 a
                        influxdb.0	2016-06-07 09:23:04.928	error	uncaught exception: err.indexOf is not a function
                        • BluefoxB Offline
                          BluefoxB Offline
                          Irgendwie sind die Änderungen weg gewesen.
                          Noch mal ausprobieren.
                            @Bluefox:
                            Irgendwie sind die Änderungen weg gewesen. `
                            so sah es für mich auch aus,.
                            War wieder so wie es war, bevor deine Testversion eingespielt hatte :(
                            Installation ist durchgelaufen und jetzt seit 5 Minuten keine Meldung mehr.
                            Vorsichtigfreu :)
                            Rainer
                            • Z Offline
                              Z Offline
                              Zeebo
                              Ich habe leider auch dieses Problem, aber keine Ahnung wie ich die Version von Git installieren soll.
                              Da ich das auf meinem Raspberry Pi 3B teste, habe ich hier ein fertiges Package der ARM-Version für Debian genommen:
                              https://dl.influxdata.com/influxdb/rele … _armhf.deb
                              Kann mir hier eventuell jemand weiterhelfen?
                              Vielen Dank schon mal!
                              ioBroker auf Ubuntu 16.04.5 LTS (VM auf ESXi 6.5 Hypervisor) • CCU2 • HomeMatic • Alexa • Harmony Hub
                                Leider beschreibst du nicht genau was du gemacht hast und wie dein Fehler aussieht.
                                Redest du von der influxDB oder von dem Adapter?
                                Installieren von influxDB mit apt-get install influxdb
                                Installieren des Adapters ganz normal, die damalige GitHub Version ist inzwischen im normalen Repository.
                                Rainer
