  4. InfluxDB läuft nicht mehr
15 Beiträge 4 Kommentatoren 1.9k Aufrufe
    Ich habe mir das bei mir nochmal näher angesehen:
    host-Test-Pi3 24 21:12:39.371 error instance system.adapter.influxdb.0 terminated with code 0 (OK)
    influxdb-0 24 21:12:39.350 info terminating
    influxdb-0 24 21:12:38.841 warn Exception: TypeError: this._createKeyValueString is not a function
    TypeError: 24 21:12:38.837 error at InfluxDB.writeSeries (/opt/iobroker/node_modules/iobroker.influxdb/lib/node-influx/index.js:322:16)
    TypeError: 24 21:12:38.837 error at InfluxDB._prepareValues (/opt/iobroker/node_modules/iobroker.influxdb/lib/node-influx/index.js:271:5)
    TypeError: 24 21:12:38.837 error at Function.forEach (/opt/iobroker/node_modules/iobroker.influxdb/node_modules/lodash/lodash.js:8617:14)
    TypeError: 24 21:12:38.837 error at /opt/iobroker/node_modules/iobroker.influxdb/node_modules/lodash/lodash.js:4380:18
    TypeError: 24 21:12:38.837 error at baseForOwn (/opt/iobroker/node_modules/iobroker.influxdb/node_modules/lodash/lodash.js:2654:24)
    TypeError: 24 21:12:38.837 error at /opt/iobroker/node_modules/iobroker.influxdb/node_modules/lodash/lodash.js:4411:15
    TypeError: 24 21:12:38.837 error at /opt/iobroker/node_modules/iobroker.influxdb/lib/node-influx/index.js:272:7
    TypeError: 24 21:12:38.837 error at arrayEach (/opt/iobroker/node_modules/iobroker.influxdb/node_modules/lodash/lodash.js:451:11)
    TypeError: 24 21:12:38.837 error at /opt/iobroker/node_modules/iobroker.influxdb/lib/node-influx/index.js:284:28
    TypeError: 24 21:12:38.837 error this._createKeyValueString is not a function
    uncaught 24 21:12:38.808 error exception: this._createKeyValueString is not a function
    inMem 24 21:12:28.769 debug message hm-rega.1.12885 hm-rega.1.12885 val=0, ack=true, ts=1464117148762, q=0, from=system.adapter.hm-rega.1, lc=1464116968710
    influxdb-0 24 21:12:11.650 error Error: retention policy already exists
    Der wahrscheinliche Übeltäter ist eine Systemvariable vom Typ Zahl.
    Er scheint irgendwie als String erkannt zu werden.
    @Bluefox: Es kann sein, dass das die gleiche Ursache für die bisherige Meldung ist, die in etwa lautete Ein Datenpunkt vom Typ String/Value kann nicht angelegt werden, da er bereits als Typ Value/String existiert. Ich hatte dir das in Kassel bereits erzählt.
    Hoffe das hilft etwas bei der Suche
    • P Offline
      PrinzEisenherz1
      Gibt's schon irgend ne Lösung für das Problem?
      Johnny
      Intel-NUC mit ProxMox: ioBroker,SQL, logging Strom- Gas- u. Wasserzähler;10Zoll Tab im Flur für VIS; weiteres: Homematic CCU2, Homeduino, Kameras, selbstgebaute Wetterstation;
      • P Offline
        PrinzEisenherz1
        Hi Bluefox, hast du vielleicht schon herausgefunden warum influxdb nicht mehr läuft?
        Gruß Johnny
        • BluefoxB Offline
          BluefoxB Offline
          Bei mir mit influxdDb 0.13 läuft.. Aber man muss vom git installieren.
          Bitte berichten.
            Bei mir hat es nicht geholfen:
            Test-Pi3	05 21:02:26.426	info	host.Test-Pi3 Restart adapter system.adapter.influxdb.0 because enabled
            Test-Pi3	05 21:02:26.425	error	host.Test-Pi3 instance system.adapter.influxdb.0 terminated with code 0 (OK)
            influxdb.0	05 21:02:25.888	warn	influxdb.0 Exception: TypeError: err.indexOf is not a function
            influxdb.0	05 21:02:25.888	error	TypeError: err.indexOf is not a function at /opt/iobroker/node_modules/iobroker.influxdb/main.js:70:36 at /opt/iobroker/node_modules/iobroker.influxdb/node_modules/influx/index.js:384:14 a
            influxdb.0	05 21:02:25.887	error	uncaught exception: err.indexOf is not a function
            influxdb.0	05 21:02:25.845	info	influxdb.0 Connected!
            EDIT:
            kommt der Fehler von der Änderung:
            hm-rega-1	05 21:03:33.811	error	runScriptFile Error: ENOENT: no such file or directory, open '/opt/iobroker/node_modules/iobroker.hm-rega/lib/../regascripts/alarms.fn'
            Sorry
            • BluefoxB Offline
              BluefoxB Offline
              Aktuelle Version auf dem git sollte laufen (auch bei Reiner sollte die besser laufen :lol: )
                @Bluefox:
                (auch bei Reiner sollte die besser laufen :lol: ) `
                leider Nein:
                Test-Pi3	2016-06-07 09:23:05.460	error	host.Test-Pi3 instance system.adapter.influxdb.0 terminated with code 0 (OK)
                influxdb.0	2016-06-07 09:23:04.929	warn	influxdb.0 Exception: TypeError: err.indexOf is not a function
                influxdb.0	2016-06-07 09:23:04.929	error	TypeError: err.indexOf is not a function at /opt/iobroker/node_modules/iobroker.influxdb/main.js:70:36 at /opt/iobroker/node_modules/iobroker.influxdb/node_modules/influx/index.js:384:14 a
                influxdb.0	2016-06-07 09:23:04.928	error	uncaught exception: err.indexOf is not a function
                • BluefoxB Offline
                  BluefoxB Offline
                  Irgendwie sind die Änderungen weg gewesen.
                  Noch mal ausprobieren.
                    @Bluefox:
                    Irgendwie sind die Änderungen weg gewesen. `
                    so sah es für mich auch aus,.
                    War wieder so wie es war, bevor deine Testversion eingespielt hatte :(
                    Installation ist durchgelaufen und jetzt seit 5 Minuten keine Meldung mehr.
                    Vorsichtigfreu :)
                    • Z Offline
                      Z Offline
                      Zeebo
                      Ich habe leider auch dieses Problem, aber keine Ahnung wie ich die Version von Git installieren soll.
                      Da ich das auf meinem Raspberry Pi 3B teste, habe ich hier ein fertiges Package der ARM-Version für Debian genommen:
                      https://dl.influxdata.com/influxdb/rele … _armhf.deb
                      Kann mir hier eventuell jemand weiterhelfen?
                      Vielen Dank schon mal!
                      ioBroker auf Ubuntu 16.04.5 LTS (VM auf ESXi 6.5 Hypervisor) • CCU2 • HomeMatic • Alexa • Harmony Hub
                        Leider beschreibst du nicht genau was du gemacht hast und wie dein Fehler aussieht.
                        Redest du von der influxDB oder von dem Adapter?
                        Installieren von influxDB mit apt-get install influxdb
                        Installieren des Adapters ganz normal, die damalige GitHub Version ist inzwischen im normalen Repository.
