  4. [Tester] error: sql.0 Cannot insert INSERT INTO
4 Beiträge 2 Kommentatoren 1.5k Aufrufe
  • derAugeD Offline
    derAugeD Offline
    derAuge
    2016-05-07 11:47:46.102  - error: sql.0 Cannot select SELECT id, type FROM datapoints WHERE name='dwd.0.warning.severity';: Error: SQLITE_BUSY: database is locked
    2016-05-07 11:47:46.106  - warn: sql.0 Cannot get index of "dwd.0.warning.severity": Error: SQLITE_BUSY: database is locked
    2016-05-07 11:47:46.109  - error: sql.0 Cannot insert INSERT INTO datapoints (name, type) VALUES('dwd.0.warning.end', 1);: Error: SQLITE_BUSY: database is locked
    2016-05-07 11:47:46.111  - warn: sql.0 Cannot get index of "dwd.0.warning.end": Error: SQLITE_BUSY: database is locked
    2016-05-07 11:47:46.135  - error: sql.0 Cannot select SELECT id, type FROM datapoints WHERE name='dwd.0.warning.text';: Error: SQLITE_BUSY: database is locked
    2016-05-07 11:47:46.136  - warn: sql.0 Cannot get index of "dwd.0.warning.text": Error: SQLITE_BUSY: database is locked
    2016-05-07 11:47:47.207  - info: javascript.0 starting. Version 2.0.6 in /opt/iobroker/node_modules/iobroker.javascript
    2016-05-07 11:47:47.263  - info: javascript.0 requesting all states
    2016-05-07 11:47:47.272  - info: javascript.0 requesting all objects
    2016-05-07 11:47:47.098  - error: sql.0 Cannot insert INSERT INTO datapoints (name, type) VALUES('dwd.0.warning1.end', 1);: Error: SQLITE_BUSY: database is locked
    2016-05-07 11:47:47.099  - warn: sql.0 Cannot get index of "dwd.0.warning1.end": Error: SQLITE_BUSY: database is locked
    2016-05-07 11:47:47.103  - error: sql.0 Cannot insert INSERT INTO datapoints (name, type) VALUES('dwd.0.warning1.severity', 0);: Error: SQLITE_BUSY: database is locked
    2016-05-07 11:47:47.105  - warn: sql.0 Cannot get index of "dwd.0.warning1.severity": Error: SQLITE_BUSY: database is locked
    2016-05-07 11:47:47.135  - error: sql.0 Cannot insert INSERT INTO datapoints (name, type) VALUES('dwd.0.warning1.text', 1);: Error: SQLITE_BUSY: database is locked
    2016-05-07 11:47:47.136  - warn: sql.0 Cannot get index of "dwd.0.warning1.text": Error: SQLITE_BUSY: database is locked
    2016-05-07 11:47:47.985  - info: javascript.0 received all states
    2016-05-07 11:47:48.135  - error: sql.0 Cannot delete DELETE FROM ts_string WHERE id=27 AND ts < 1431078420689;: Error: SQLITE_BUSY: database is locked
    2016-05-07 11:47:48.161  - info: javascript.0 received all objects
    2016-05-07 11:47:50.282  - error: sql.0 Cannot delete DELETE FROM ts_string WHERE id=2 AND ts < 1431078420265;: Error: SQLITE_BUSY: database is locked
    2016-05-07 11:47:50.285  - error: sql.0 Cannot select SELECT id, type FROM datapoints WHERE name='yr.0.forecast.diagram';: Error: SQLITE_BUSY: database is locked
    2016-05-07 11:47:50.285  - warn: sql.0 Cannot get index of "yr.0.forecast.diagram": Error: SQLITE_BUSY: database is locked
    2016-05-07 11:47:50.287  - error: sql.0 Cannot select SELECT id, type FROM datapoints WHERE name='yr.0.forecast.day0.icon';: Error: SQLITE_BUSY: database is locked
    2016-05-07 11:47:50.288  - warn: sql.0 Cannot get index of "yr.0.forecast.day0.icon": Error: SQLITE_BUSY: database is locked
    2016-05-07 11:47:51.283  - error: sql.0 Cannot delete DELETE FROM ts_number WHERE id=7 AND ts < 1431078420466;: Error: SQLITE_BUSY: database is locked
    2016-05-07 11:47:51.286  - error: sql.0 Cannot insert INSERT INTO ts_number (id, ts, val, ack, _from, q) VALUES(8, 1462614459310, 1011, 1, 1, 0);: Error: SQLITE_BUSY: database is locked
    2016-05-07 11:47:51.288  - error: sql.0 Cannot delete DELETE FROM ts_number WHERE id=8 AND ts < 1431078420468;: Error: SQLITE_BUSY: database is locked
    2016-05-07 11:47:52.283  - error: sql.0 Cannot insert INSERT INTO datapoints (name, type) VALUES('yr.0.forecast.day2.precipitation_level', 0);: Error: SQLITE_BUSY: database is locked
    2016-05-07 11:47:52.284  - warn: sql.0 Cannot get index of "yr.0.forecast.day2.precipitation_level": Error: SQLITE_BUSY: database is locked
    2016-05-07 11:47:52.286  - error: sql.0 Cannot insert INSERT INTO datapoints (name, type) VALUES('yr.0.forecast.day2.precipitation_chance', 1);: Error: SQLITE_BUSY: database is locked
    2016-05-07 11:47:52.287  - warn: sql.0 Cannot get index of "yr.0.forecast.day2.precipitation_chance": Error: SQLITE_BUSY: database is locked
    2016-05-07 11:47:52.291  - error: sql.0 Cannot insert INSERT INTO ts_string (id, ts, val, ack, _from, q) VALUES(21, 1462614459460, 'O', 1, 1, 0);: Error: SQLITE_BUSY: database is locked
    2016-05-07 11:47:53.283  - error: sql.0 Cannot delete DELETE FROM ts_string WHERE id=13 AND ts < 1431078420808;: Error: SQLITE_BUSY: database is locked
    2016-05-07 11:47:53.286  - error: sql.0 Cannot insert INSERT INTO ts_string (id, ts, val, ack, _from, q) VALUES(14, 1462614459414, 'OSO', 1, 1, 0);: Error: SQLITE_BUSY: database is locked
    2016-05-07 11:47:53.290  - error: sql.0 Cannot delete DELETE FROM ts_string WHERE id=14 AND ts < 1431078420811;: Error: SQLITE_BUSY: database is locked
    2016-05-07 11:47:54.290  - error: sql.0 Cannot delete DELETE FROM ts_number WHERE id=23 AND ts < 1431078420849;: Error: SQLITE_BUSY: database is locked
    2016-05-07 11:50:16.360  - info: sql.0 enabled logging of admin.0.info.updatesList
    2016-05-07 11:47:12.717  - info: host.RPi2-1 instance system.adapter.admin.0 started with pid 723
    2016-05-07 11:50:27.172  - info: host.RPi2-1 object change system.adapter.yr.0
    2016-05-07 11:50:27.182  - info: host.RPi2-1 stopInstance system.adapter.yr.0
    2016-05-07 11:50:27.186  - info: host.RPi2-1 stopInstance canceled schedule system.adapter.yr.0
    2016-05-07 11:50:29.710  - info: host.RPi2-1 instance scheduled system.adapter.yr.0 6 * * * *
    2016-05-07 11:50:29.735  - info: host.RPi2-1 instance system.adapter.yr.0 started with pid 789
    2016-05-07 11:50:34.387  - info: yr.0 starting. Version 1.0.1 in /opt/iobroker/node_modules/iobroker.yr
    2016-05-07 11:50:35.130  - info: yr.0 got weather data from yr.no
    2016-05-07 11:50:36.213  - error: sql.0 Cannot select SELECT id, type FROM datapoints WHERE name='yr.0.forecast.day0.icon';: Error: SQLITE_BUSY: database is locked
    2016-05-07 11:50:36.214  - warn: sql.0 Cannot get index of "yr.0.forecast.day0.icon": Error: SQLITE_BUSY: database is locked
    2016-05-07 11:50:36.225  - error: sql.0 Cannot select SELECT id, type FROM datapoints WHERE name='yr.0.forecast.day0.text';: Error: SQLITE_BUSY: database is locked
    2016-05-07 11:50:36.226  - warn: sql.0 Cannot get index of "yr.0.forecast.day0.text": Error: SQLITE_BUSY: database is locked
    2016-05-07 11:50:37.213  - error: sql.0 Cannot insert INSERT INTO ts_number (id, ts, val, ack, _from, q) VALUES(8, 1462614635250, 1011, 1, 1, 0);: Error: SQLITE_BUSY: database is locked
    2016-05-07 11:50:37.225  - error: sql.0 Cannot insert INSERT INTO ts_number (id, ts, val, ack, _from, q) VALUES(9, 1462614635285, 24, 1, 1, 0);: Error: SQLITE_BUSY: database is locked
    2016-05-07 11:50:37.411  - error: sql.0 Cannot insert INSERT INTO ts_string (id, ts, val, ack, _from, q) VALUES(10, 1462614635295, '08.05.2016', 1, 1, 0);: Error: SQLITE_BUSY: database is locked
    2016-05-07 11:50:38.214  - error: sql.0 Cannot insert INSERT INTO ts_string (id, ts, val, ack, _from, q) VALUES(13, 1462614635335, 'null', 1, 1, 0);: Error: SQLITE_BUSY: database is locked
    2016-05-07 11:50:38.225  - error: sql.0 Cannot insert INSERT INTO ts_string (id, ts, val, ack, _from, q) VALUES(14, 1462614635339, 'OSO', 1, 1, 0);: Error: SQLITE_BUSY: database is locked
    2016-05-07 11:50:38.412  - error: sql.0 Cannot insert INSERT INTO ts_string (id, ts, val, ack, _from, q) VALUES(21, 1462614635386, 'O', 1, 1, 0);: Error: SQLITE_BUSY: database is locked
    2016-05-07 11:50:39.225  - error: sql.0 Cannot insert INSERT INTO ts_number (id, ts, val, ack, _from, q) VALUES(39, 1462614635373, 25, 1, 1, 0);: Error: SQLITE_BUSY: database is locked
    2016-05-07 11:50:40.528  - info: host.RPi2-1 instance system.adapter.yr.0 terminated with code 0 (OK)
    Jürgen
    • eric2905E Offline
      eric2905E Offline
      eric2905
      Ganz spannend …
      Ich bin von meinem mySQL (auf dem ioBroker-Host mit drauf) zu einem externen mySQL-Hoster gewechselt ...
      Und habe jetzt auch in produktiven ioBroker (normale npm-Installation) keine SQL-Fehler mehr.
      Keine Ahnung warum.
      Gruß,
      Eric
      • derAugeD Offline
        derAugeD Offline
        derAuge
        sql.0 07 20:03:08.061 error sql.0 Cannot insert INSERT INTO ts_string (id, ts, val, ack, _from, q) VALUES(31, 1462644186114, '', 1, 2, 0);: Error: SQLITE_BUSY: database is locked
        sql.0 07 20:03:07.238 error sql.0 Cannot insert INSERT INTO ts_string (id, ts, val, ack, _from, q) VALUES(27, 1462644186058, '', 1, 2, 0);: Error: SQLITE_BUSY: database is locked
        sql.0 07 20:03:07.237 warn sql.0 Cannot get index of "dwd.0.warning.severity": Error: SQLITE_BUSY: database is locked
        sql.0 07 20:03:07.237 error sql.0 Cannot select SELECT id, type FROM datapoints WHERE name='dwd.0.warning.severity';: Error: SQLITE_BUSY: database is locked
        sql.0 07 20:03:07.236 warn sql.0 Cannot get index of "dwd.0.warning.end": Error: SQLITE_BUSY: database is locked
        sql.0 07 20:03:07.235 error sql.0 Cannot select SELECT id, type FROM datapoints WHERE name='dwd.0.warning.end';: Error: SQLITE_BUSY: database is locked
        • derAugeD Offline
          derAugeD Offline
          derAuge
          habe mir heute mal der Fehler-log angeschaut
          sql-0	08 07:06:08.930	error	Cannot insert INSERT INTO ts_number (id, ts, val, ack, _from, q) VALUES(23, 1462683966071, 1010, 1, 1, 0);: Error: SQLITE_BUSY: database is locked
          sql-0	08 07:06:08.073	error	Cannot insert INSERT INTO ts_number (id, ts, val, ack, _from, q) VALUES(38, 1462683966012, 14, 1, 1, 0);: Error: SQLITE_BUSY: database is locked
          sql-0	08 07:06:07.930	error	Cannot insert INSERT INTO ts_string (id, ts, val, ack, _from, q) VALUES(10, 1462683965954, '09.05.2016', 1, 1, 0);: Error: SQLITE_BUSY: database is locked
          sql-0	08 07:06:07.910	error	Cannot insert INSERT INTO ts_number (id, ts, val, ack, _from, q) VALUES(8, 1462683965947, 1013, 1, 1, 0);: Error: SQLITE_BUSY: database is locked
          sql-0	08 07:06:07.073	error	Cannot insert INSERT INTO ts_number (id, ts, val, ack, _from, q) VALUES(3, 1462683965927, 24, 1, 1, 0);: Error: SQLITE_BUSY: database is locked
          sql-0	08 07:06:06.930	error	Cannot select SELECT id, type FROM datapoints WHERE name='yr.0.forecast.day0.text';: Error: SQLITE_BUSY: database is locked
          sql-0	08 07:06:06.910	error	Cannot select SELECT id, type FROM datapoints WHERE name='yr.0.forecast.day0.icon';: Error: SQLITE_BUSY: database is locked
          sql-0	08 07:03:06.798	error	Cannot insert INSERT INTO ts_number (id, ts, val, ack, _from, q) VALUES(48, 1462683785770, 0, 1, 2, 0);: Error: SQLITE_BUSY: database is locked
          sql-0	08 06:06:08.072	error	Cannot insert INSERT INTO ts_string (id, ts, val, ack, _from, q) VALUES(14, 1462680366171, 'O', 1, 1, 0);: Error: SQLITE_BUSY: database is locked
          sql-0	08 06:06:08.043	error	Cannot insert INSERT INTO ts_string (id, ts, val, ack, _from, q) VALUES(13, 1462680366167, 'null', 1, 1, 0);: Error: SQLITE_BUSY: database is locked
          sql-0	08 06:06:07.315	error	Cannot insert INSERT INTO ts_number (id, ts, val, ack, _from, q) VALUES(3, 1462680366069, 24, 1, 1, 0);: Error: SQLITE_BUSY: database is locked
          sql-0	08 06:06:07.058	error	Cannot select SELECT id, type FROM datapoints WHERE name='yr.0.forecast.day0.text';: Error: SQLITE_BUSY: database is locked
          sql-0	08 06:06:07.042	error	Cannot select SELECT id, type FROM datapoints WHERE name='yr.0.forecast.day0.icon';: Error: SQLITE_BUSY: database is locked
          sql-0	08 06:03:06.812	error	Cannot insert INSERT INTO ts_string (id, ts, val, ack, _from, q) VALUES(44, 1462680185771, '', 1, 2, 0);: Error: SQLITE_BUSY: database is locked
          sql-0	08 06:03:06.777	error	Cannot insert INSERT INTO ts_number (id, ts, val, ack, _from, q) VALUES(48, 1462680185758, 0, 1, 2, 0);: Error: SQLITE_BUSY: database is locked
          sql-0	08 05:06:07.125	error	Cannot insert INSERT INTO ts_string (id, ts, val, ack, _from, q) VALUES(17, 1462676765198, '10.05.2016', 1, 1, 0);: Error: SQLITE_BUSY: database is locked
          sql-0	08 05:06:07.108	error	Cannot insert INSERT INTO ts_number (id, ts, val, ack, _from, q) VALUES(16, 1462676765195, 1014, 1, 1, 0);: Error: SQLITE_BUSY: database is locked
          sql-0	08 05:06:06.125	error	Cannot insert INSERT INTO ts_number (id, ts, val, ack, _from, q) VALUES(35, 1462676765081, 14, 1, 1, 0);: Error: SQLITE_BUSY: database is locked
          sql-0	08 05:06:06.108	error	Cannot select SELECT id, type FROM datapoints WHERE name='yr.0.forecast.day0.text';: Error: SQLITE_BUSY: database is locked
          sql-0	08 05:06:06.104	error	Cannot select SELECT id, type FROM datapoints WHERE name='yr.0.forecast.day0.icon';: Error: SQLITE_BUSY: database is locked
          sql-0	08 05:03:06.704	error	Cannot insert INSERT INTO ts_string (id, ts, val, ack, _from, q) VALUES(44, 1462676585663, '', 1, 2, 0);: Error: SQLITE_BUSY: database is locked
          sql-0	08 05:03:06.701	error	Cannot insert INSERT INTO ts_number (id, ts, val, ack, _from, q) VALUES(48, 1462676585656, 0, 1, 2, 0);: Error: SQLITE_BUSY: database is locked
          sql-0	08 04:06:07.648	error	Cannot insert INSERT INTO ts_string (id, ts, val, ack, _from, q) VALUES(37, 1462673165699, 'Klarer Himmel', 1, 1, 0);: Error: SQLITE_BUSY: database is locked
          sql-0	08 04:06:08.653	error	Cannot insert INSERT INTO ts_string (id, ts, val, ack, _from, q) VALUES(36, 1462673165694, 'http://symbol.yr.no/grafikk/sym/b38/mf/01n.08.png', 1, 1, 0);: Error: SQLITE_BUSY: database is locked
          sql-0	08 04:06:06.823	error	Cannot insert INSERT INTO ts_number (id, ts, val, ack, _from, q) VALUES(3, 1462673165654, 24, 1, 1, 0);: Error: SQLITE_BUSY: database is locked
          sql-0	08 04:06:06.648	error	Cannot select SELECT id, type FROM datapoints WHERE name='yr.0.forecast.day0.text';: Error: SQLITE_BUSY: database is locked
          sql-0	08 04:06:06.633	error	Cannot select SELECT id, type FROM datapoints WHERE name='yr.0.forecast.day0.icon';: Error: SQLITE_BUSY: database is locked
          sql-0	08 04:03:06.848	error	Cannot insert INSERT INTO ts_string (id, ts, val, ack, _from, q) VALUES(27, 1462672985700, '', 1, 2, 0);: Error: SQLITE_BUSY: database is locked
          sql-0	08 04:03:06.846	error	Cannot insert INSERT INTO ts_string (id, ts, val, ack, _from, q) VALUES(44, 1462672985696, '', 1, 2, 0);: Error: SQLITE_BUSY: database is locked
          sql-0	08 04:03:06.843	error	Cannot insert INSERT INTO ts_number (id, ts, val, ack, _from, q) VALUES(48, 1462672985691, 0, 1, 2, 0);: Error: SQLITE_BUSY: database is locked
          sql-0	08 03:06:07.835	error	Cannot insert INSERT INTO ts_number (id, ts, val, ack, _from, q) VALUES(11, 1462669565906, 25, 1, 1, 0);: Error: SQLITE_BUSY: database is locked
          sql-0	08 03:06:07.820	error	Cannot insert INSERT INTO ts_number (id, ts, val, ack, _from, q) VALUES(38, 1462669565903, 14, 1, 1, 0);: Error: SQLITE_BUSY: database is locked
          sql-0	08 03:06:06.922	error	Cannot insert INSERT INTO ts_number (id, ts, val, ack, _from, q) VALUES(3, 1462669565831, 24, 1, 1, 0);: Error: SQLITE_BUSY: database is locked
          sql-0	08 03:06:06.840	error	Cannot select SELECT id, type FROM datapoints WHERE name='yr.0.forecast.day0.text';: Error: SQLITE_BUSY: database is locked
          sql-0	08 03:06:06.820	error	Cannot select SELECT id, type FROM datapoints WHERE name='yr.0.forecast.day0.icon';: Error: SQLITE_BUSY: database is locked
          sql-0	08 03:03:07.599	error	Cannot insert INSERT INTO ts_string (id, ts, val, ack, _from, q) VALUES(33, 1462669385663, '{}', 1, 2, 0);: Error: SQLITE_BUSY: database is locked
          sql-0	08 03:03:06.598	error	Cannot insert INSERT INTO ts_number (id, ts, val, ack, _from, q) VALUES(48, 1462669385583, 0, 1, 2, 0);: Error: SQLITE_BUSY: database is locked
          sql-0	08 03:03:06.588	error	Cannot insert INSERT INTO ts_string (id, ts, val, ack, _from, q) VALUES(49, 1462669385574, '', 1, 2, 0);: Error: SQLITE_BUSY: database is locked
          sql-0	08 02:06:08.173	error	Cannot insert INSERT INTO ts_string (id, ts, val, ack, _from, q) VALUES(19, 1462665966146, 'Wolkig', 1, 1, 0);: Error: SQLITE_BUSY: database is locked
          sql-0	08 02:06:09.052	error	Cannot insert INSERT INTO ts_number (id, ts, val, ack, _from, q) VALUES(23, 1462665966177, 1010, 1, 1, 0);: Error: SQLITE_BUSY: database is locked
          sql-0	08 02:06:08.052	error	Cannot insert INSERT INTO ts_number (id, ts, val, ack, _from, q) VALUES(16, 1462665966134, 1014, 1, 1, 0);: Error: SQLITE_BUSY: database is locked
          sql-0	08 02:06:08.049	error	Cannot insert INSERT INTO ts_number (id, ts, val, ack, _from, q) VALUES(15, 1462665966131, 24.9, 1, 1, 0);: Error: SQLITE_BUSY: database is locked
          sql-0	08 02:06:07.173	error	Cannot insert INSERT INTO ts_number (id, ts, val, ack, _from, q) VALUES(4, 1462665966041, 0, 1, 1, 0);: Error: SQLITE_BUSY: database is locked
          sql-0	08 02:06:07.051	error	Cannot select SELECT id, type FROM datapoints WHERE name='yr.0.forecast.day0.text';: Error: SQLITE_BUSY: database is locked
          sql-0	08 02:06:07.048	error	Cannot select SELECT id, type FROM datapoints WHERE name='yr.0.forecast.day0.icon';: Error: SQLITE_BUSY: database is locked
          sql-0	08 02:03:08.015	error	Cannot insert INSERT INTO ts_string (id, ts, val, ack, _from, q) VALUES(30, 1462665785998, '', 1, 2, 0);: Error: SQLITE_BUSY: database is locked
          sql-0	08 02:03:08.008	error	Cannot insert INSERT INTO ts_string (id, ts, val, ack, _from, q) VALUES(29, 1462665785994, '{}', 1, 2, 0);: Error: SQLITE_BUSY: database is locked
          sql-0	08 02:03:07.014	error	Cannot insert INSERT INTO ts_number (id, ts, val, ack, _from, q) VALUES(48, 1462665785956, 0, 1, 2, 0);: Error: SQLITE_BUSY: database is locked
          sql-0	08 02:03:07.008	error	Cannot insert INSERT INTO ts_string (id, ts, val, ack, _from, q) VALUES(27, 1462665785979, '', 1, 2, 0);: Error: SQLITE_BUSY: database is locked
          sql-0	08 02:03:06.972	error	Cannot insert INSERT INTO ts_string (id, ts, val, ack, _from, q) VALUES(49, 1462665785944, '', 1, 2, 0);: Error: SQLITE_BUSY: database is locked
          sql-0	08 01:06:07.663	error	Cannot insert INSERT INTO ts_string (id, ts, val, ack, _from, q) VALUES(36, 1462662365695, 'http://symbol.yr.no/grafikk/sym/b38/mf/01n.08.png', 1, 1, 0);: Error: SQLITE_BUSY: database is locked
          sql-0	08 01:06:07.647	error	Cannot insert INSERT INTO ts_string (id, ts, val, ack, _from, q) VALUES(10, 1462662365692, '09.05.2016', 1, 1, 0);: Error: SQLITE_BUSY: database is locked
          sql-0	08 01:06:08.881	error	Cannot insert INSERT INTO ts_string (id, ts, val, ack, _from, q) VALUES(25, 1462662365850, '[{"date":"08.05.2016","icon":"http://symbol.yr.no/grafikk/sym/b38/01d.png","text":"Klarer Himmel","temperat
          sql-0	08 01:06:08.665	error	Cannot insert INSERT INTO ts_string (id, ts, val, ack, _from, q) VALUES(41, 1462662365785, 'null', 1, 1, 0);: Error: SQLITE_BUSY: database is locked
          sql-0	08 01:06:08.647	error	Cannot insert INSERT INTO ts_number (id, ts, val, ack, _from, q) VALUES(40, 1462662365782, 0, 1, 1, 0);: Error: SQLITE_BUSY: database is locked
          sql-0	08 01:06:06.879	error	Cannot insert INSERT INTO ts_number (id, ts, val, ack, _from, q) VALUES(35, 1462662365662, 14, 1, 1, 0);: Error: SQLITE_BUSY: database is locked
          sql-0	08 01:06:06.663	error	Cannot select SELECT id, type FROM datapoints WHERE name='yr.0.forecast.day0.text';: Error: SQLITE_BUSY: database is locked
          sql-0	08 01:06:06.647	error	Cannot select SELECT id, type FROM datapoints WHERE name='yr.0.forecast.day0.icon';: Error: SQLITE_BUSY: database is locked
          sql-0	08 01:03:06.957	error	Cannot insert INSERT INTO ts_string (id, ts, val, ack, _from, q) VALUES(44, 1462662185946, '', 1, 2, 0);: Error: SQLITE_BUSY: database is locked
          sql-0	08 01:03:06.947	error	Cannot select SELECT id, type FROM datapoints WHERE name='dwd.0.warning.severity';: Error: SQLITE_BUSY: database is locked
          sql-0	08 00:06:08.262	error	Cannot insert INSERT INTO ts_number (id, ts, val, ack, _from, q) VALUES(38, 1462658766036, 14, 1, 1, 0);: Error: SQLITE_BUSY: database is locked
          sql-0	08 00:06:07.995	error	Cannot insert INSERT INTO ts_string (id, ts, val, ack, _from, q) VALUES(37, 1462658766033, 'Klarer Himmel', 1, 1, 0);: Error: SQLITE_BUSY: database is locked
          sql-0	08 00:06:07.978	error	Cannot insert INSERT INTO ts_string (id, ts, val, ack, _from, q) VALUES(36, 1462658766029, 'http://symbol.yr.no/grafikk/sym/b38/mf/01n.08.png', 1, 1, 0);: Error: SQLITE_BUSY: database is locked
          sql-0	08 00:06:08.995	error	Cannot insert INSERT INTO ts_number (id, ts, val, ack, _from, q) VALUES(40, 1462658766144, 0, 1, 1, 0);: Error: SQLITE_BUSY: database is locked
          sql-0	08 00:06:07.262	error	Cannot insert INSERT INTO ts_number (id, ts, val, ack, _from, q) VALUES(3, 1462658765998, 24, 1, 1, 0);: Error: SQLITE_BUSY: database is locked
          sql-0	08 00:06:06.994	error	Cannot select SELECT id, type FROM datapoints WHERE name='yr.0.forecast.day0.text';: Error: SQLITE_BUSY: database is locked
          sql-0	08 00:06:06.978	error	Cannot select SELECT id, type FROM datapoints WHERE name='yr.0.forecast.day0.icon';: Error: SQLITE_BUSY: database is locked
          sql-0	08 00:03:06.989	error	Cannot insert INSERT INTO ts_string (id, ts, val, ack, _from, q) VALUES(27, 1462658585925, '', 1, 2, 0);: Error: SQLITE_BUSY: database is locked
          sql-0	08 00:03:06.948	error	Cannot select SELECT id, type FROM datapoints WHERE name='dwd.0.warning.severity';: Error: SQLITE_BUSY: database is locked
          sql-0	08 00:00:08.016	error	Cannot insert INSERT INTO ts_string (id, ts, val, ack, _from, q) VALUES(60, 1462658403852, 'Pfingstsonntag', 1, 4, 0);: Error: SQLITE_BUSY: database is locked
          sql-0	08 00:00:07.016	error	Cannot insert INSERT INTO ts_bool (id, ts, val, ack, _from, q) VALUES(52, 1462658403835, 0, 1, 4, 0);: Error: SQLITE_BUSY: database is locked
          sql-0	08 00:00:06.953	error	Cannot delete DELETE FROM ts_bool WHERE id=52 AND ts < 1431122400827;: Error: SQLITE_BUSY: database is locked
          sql-0	08 00:00:06.951	error	Cannot delete DELETE FROM ts_string WHERE id=50 AND ts < 1431122400816;: Error: SQLITE_BUSY: database is locked
          sql-0	08 00:00:06.015	error	Cannot insert INSERT INTO ts_bool (id, ts, val, ack, _from, q) VALUES(51, 1462658403819, 0, 1, 4, 0);: Error: SQLITE_BUSY: database is locked
          sql-0	08 00:00:05.954	error	Cannot delete DELETE FROM ts_number WHERE id=63 AND ts < 1431122400877;: Error: SQLITE_BUSY: database is locked
          sql-0	08 00:00:05.951	error	Cannot insert INSERT INTO ts_number (id, ts, val, ack, _from, q) VALUES(63, 1462658403863, 6, 1, 4, 0);: Error: SQLITE_BUSY: database is locked
          sql-0	08 00:00:05.015	error	Cannot insert INSERT INTO datapoints (name, type) VALUES('feiertage.0.morgen.Name', 1);: Error: SQLITE_BUSY: database is locked
          und alle LOG-infos
          ! host-RPi2-1 08 07:06:11.183 info instance system.adapter.yr.0 terminated with code 0 (OK)
          ! sql-0 08 07:06:08.930 error Cannot insert INSERT INTO ts_number (id, ts, val, ack, _from, q) VALUES(23, 1462683966071, 1010, 1, 1, 0);: Error: SQLITE_BUSY: database is locked
          ! sql-0 08 07:06:08.073 error Cannot insert INSERT INTO ts_number (id, ts, val, ack, _from, q) VALUES(38, 1462683966012, 14, 1, 1, 0);: Error: SQLITE_BUSY: database is locked
          ! sql-0 08 07:06:07.930 error Cannot insert INSERT INTO ts_string (id, ts, val, ack, _from, q) VALUES(10, 1462683965954, '09.05.2016', 1, 1, 0);: Error: SQLITE_BUSY: database is locked
          ! sql-0 08 07:06:07.910 error Cannot insert INSERT INTO ts_number (id, ts, val, ack, _from, q) VALUES(8, 1462683965947, 1013, 1, 1, 0);: Error: SQLITE_BUSY: database is locked
          ! sql-0 08 07:06:07.073 error Cannot insert INSERT INTO ts_number (id, ts, val, ack, _from, q) VALUES(3, 1462683965927, 24, 1, 1, 0);: Error: SQLITE_BUSY: database is locked
          ! sql-0 08 07:06:06.931 warn Cannot get index of "yr.0.forecast.day0.text": Error: SQLITE_BUSY: database is locked
          ! sql-0 08 07:06:06.930 error Cannot select SELECT id, type FROM datapoints WHERE name='yr.0.forecast.day0.text';: Error: SQLITE_BUSY: database is locked
          ! sql-0 08 07:06:06.912 warn Cannot get index of "yr.0.forecast.day0.icon": Error: SQLITE_BUSY: database is locked
          ! sql-0 08 07:06:06.910 error Cannot select SELECT id, type FROM datapoints WHERE name='yr.0.forecast.day0.icon';: Error: SQLITE_BUSY: database is locked
          ! yr-0 08 07:06:05.831 info got weather data from yr.no
          ! yr-0 08 07:06:05.140 info starting. Version 1.0.1 in /opt/iobroker/node_modules/iobroker.yr
          ! host-RPi2-1 08 07:06:00.730 info instance system.adapter.yr.0 started with pid 2462
          ! sql-0 08 07:03:06.798 error Cannot insert INSERT INTO ts_number (id, ts, val, ack, _from, q) VALUES(48, 1462683785770, 0, 1, 2, 0);: Error: SQLITE_BUSY: database is locked
          ! sql-0 08 06:06:08.072 error Cannot insert INSERT INTO ts_string (id, ts, val, ack, _from, q) VALUES(14, 1462680366171, 'O', 1, 1, 0);: Error: SQLITE_BUSY: database is locked
          ! host-RPi2-1 08 07:03:06.334 info instance system.adapter.dwd.0 terminated with code 0 (OK)
          ! dwd-0 08 07:03:05.370 info starting. Version 2.0.3 in /opt/iobroker/node_modules/iobroker.dwd
          ! host-RPi2-1 08 07:03:00.615 info instance system.adapter.dwd.0 started with pid 2451
          ! host-RPi2-1 08 06:06:11.329 info instance system.adapter.yr.0 terminated with code 0 (OK)
          ! sql-0 08 06:06:08.043 error Cannot insert INSERT INTO ts_string (id, ts, val, ack, _from, q) VALUES(13, 1462680366167, 'null', 1, 1, 0);: Error: SQLITE_BUSY: database is locked
          ! sql-0 08 06:06:07.315 error Cannot insert INSERT INTO ts_number (id, ts, val, ack, _from, q) VALUES(3, 1462680366069, 24, 1, 1, 0);: Error: SQLITE_BUSY: database is locked
          ! sql-0 08 06:06:07.059 warn Cannot get index of "yr.0.forecast.day0.text": Error: SQLITE_BUSY: database is locked
          ! sql-0 08 06:06:07.058 error Cannot select SELECT id, type FROM datapoints WHERE name='yr.0.forecast.day0.text';: Error: SQLITE_BUSY: database is locked
          ! sql-0 08 06:06:07.043 warn Cannot get index of "yr.0.forecast.day0.icon": Error: SQLITE_BUSY: database is locked
          ! sql-0 08 06:06:07.042 error Cannot select SELECT id, type FROM datapoints WHERE name='yr.0.forecast.day0.icon';: Error: SQLITE_BUSY: database is locked
          ! yr-0 08 06:06:05.964 info got weather data from yr.no
          ! yr-0 08 06:06:05.265 info starting. Version 1.0.1 in /opt/iobroker/node_modules/iobroker.yr
          ! host-RPi2-1 08 06:06:00.733 info instance system.adapter.yr.0 started with pid 2217
          ! sql-0 08 06:03:06.812 error Cannot insert INSERT INTO ts_string (id, ts, val, ack, _from, q) VALUES(44, 1462680185771, '', 1, 2, 0);: Error: SQLITE_BUSY: database is locked
          ! sql-0 08 06:03:06.777 error Cannot insert INSERT INTO ts_number (id, ts, val, ack, _from, q) VALUES(48, 1462680185758, 0, 1, 2, 0);: Error: SQLITE_BUSY: database is locked
          ! host-RPi2-1 08 06:03:06.332 info instance system.adapter.dwd.0 terminated with code 0 (OK)
          ! dwd-0 08 06:03:05.364 info starting. Version 2.0.3 in /opt/iobroker/node_modules/iobroker.dwd
          ! host-RPi2-1 08 06:03:00.615 info instance system.adapter.dwd.0 started with pid 2206
          ! host-RPi2-1 08 05:06:10.359 info instance system.adapter.yr.0 terminated with code 0 (OK)
          ! sql-0 08 05:06:07.125 error Cannot insert INSERT INTO ts_string (id, ts, val, ack, _from, q) VALUES(17, 1462676765198, '10.05.2016', 1, 1, 0);: Error: SQLITE_BUSY: database is locked
          ! sql-0 08 05:06:07.108 error Cannot insert INSERT INTO ts_number (id, ts, val, ack, _from, q) VALUES(16, 1462676765195, 1014, 1, 1, 0);: Error: SQLITE_BUSY: database is locked
          ! sql-0 08 05:06:06.125 error Cannot insert INSERT INTO ts_number (id, ts, val, ack, _from, q) VALUES(35, 1462676765081, 14, 1, 1, 0);: Error: SQLITE_BUSY: database is locked
          ! sql-0 08 05:06:06.108 warn Cannot get index of "yr.0.forecast.day0.text": Error: SQLITE_BUSY: database is locked
          ! sql-0 08 05:06:06.108 error Cannot select SELECT id, type FROM datapoints WHERE name='yr.0.forecast.day0.text';: Error: SQLITE_BUSY: database is locked
          ! sql-0 08 05:06:06.106 warn Cannot get index of "yr.0.forecast.day0.icon": Error: SQLITE_BUSY: database is locked
          ! sql-0 08 05:06:06.104 error Cannot select SELECT id, type FROM datapoints WHERE name='yr.0.forecast.day0.icon';: Error: SQLITE_BUSY: database is locked
          ! yr-0 08 05:06:05.003 info got weather data from yr.no
          ! yr-0 08 05:06:04.291 info starting. Version 1.0.1 in /opt/iobroker/node_modules/iobroker.yr
          ! host-RPi2-1 08 05:06:00.731 info instance system.adapter.yr.0 started with pid 2147
          ! sql-0 08 05:03:06.704 error Cannot insert INSERT INTO ts_string (id, ts, val, ack, _from, q) VALUES(44, 1462676585663, '', 1, 2, 0);: Error: SQLITE_BUSY: database is locked
          ! sql-0 08 05:03:06.701 error Cannot insert INSERT INTO ts_number (id, ts, val, ack, _from, q) VALUES(48, 1462676585656, 0, 1, 2, 0);: Error: SQLITE_BUSY: database is locked
          ! sql-0 08 04:06:07.648 error Cannot insert INSERT INTO ts_string (id, ts, val, ack, _from, q) VALUES(37, 1462673165699, 'Klarer Himmel', 1, 1, 0);: Error: SQLITE_BUSY: database is locked
          ! host-RPi2-1 08 05:03:06.212 info instance system.adapter.dwd.0 terminated with code 0 (OK)
          ! dwd-0 08 05:03:05.232 info starting. Version 2.0.3 in /opt/iobroker/node_modules/iobroker.dwd
          ! host-RPi2-1 08 05:03:00.613 info instance system.adapter.dwd.0 started with pid 2138
          ! host-RPi2-1 08 04:06:11.177 info instance system.adapter.yr.0 terminated with code 0 (OK)
          ! sql-0 08 04:06:08.653 error Cannot insert INSERT INTO ts_string (id, ts, val, ack, _from, q) VALUES(36, 1462673165694, 'http://symbol.yr.no/grafikk/sym/b38/mf/01n.08.png', 1, 1, 0);: Error: SQLITE_BUSY: database is locked
          ! sql-0 08 04:06:06.823 error Cannot insert INSERT INTO ts_number (id, ts, val, ack, _from, q) VALUES(3, 1462673165654, 24, 1, 1, 0);: Error: SQLITE_BUSY: database is locked
          ! sql-0 08 04:06:06.649 warn Cannot get index of "yr.0.forecast.day0.text": Error: SQLITE_BUSY: database is locked
          ! sql-0 08 04:06:06.648 error Cannot select SELECT id, type FROM datapoints WHERE name='yr.0.forecast.day0.text';: Error: SQLITE_BUSY: database is locked
          ! sql-0 08 04:06:06.634 warn Cannot get index of "yr.0.forecast.day0.icon": Error: SQLITE_BUSY: database is locked
          ! sql-0 08 04:06:06.633 error Cannot select SELECT id, type FROM datapoints WHERE name='yr.0.forecast.day0.icon';: Error: SQLITE_BUSY: database is locked
          ! yr-0 08 04:06:05.547 info got weather data from yr.no
          ! yr-0 08 04:06:04.852 info starting. Version 1.0.1 in /opt/iobroker/node_modules/iobroker.yr
          ! host-RPi2-1 08 04:06:00.742 info instance system.adapter.yr.0 started with pid 2085
          ! sql-0 08 04:03:06.848 error Cannot insert INSERT INTO ts_string (id, ts, val, ack, _from, q) VALUES(27, 1462672985700, '', 1, 2, 0);: Error: SQLITE_BUSY: database is locked
          ! sql-0 08 04:03:06.846 error Cannot insert INSERT INTO ts_string (id, ts, val, ack, _from, q) VALUES(44, 1462672985696, '', 1, 2, 0);: Error: SQLITE_BUSY: database is locked
          ! sql-0 08 04:03:06.843 error Cannot insert INSERT INTO ts_number (id, ts, val, ack, _from, q) VALUES(48, 1462672985691, 0, 1, 2, 0);: Error: SQLITE_BUSY: database is locked
          ! host-RPi2-1 08 04:03:06.170 info instance system.adapter.dwd.0 terminated with code 0 (OK)
          ! dwd-0 08 04:03:05.199 info starting. Version 2.0.3 in /opt/iobroker/node_modules/iobroker.dwd
          ! host-RPi2-1 08 04:03:00.614 info instance system.adapter.dwd.0 started with pid 2076
          ! host-RPi2-1 08 03:06:11.066 info instance system.adapter.yr.0 terminated with code 0 (OK)
          ! sql-0 08 03:06:07.835 error Cannot insert INSERT INTO ts_number (id, ts, val, ack, _from, q) VALUES(11, 1462669565906, 25, 1, 1, 0);: Error: SQLITE_BUSY: database is locked
          ! sql-0 08 03:06:07.820 error Cannot insert INSERT INTO ts_number (id, ts, val, ack, _from, q) VALUES(38, 1462669565903, 14, 1, 1, 0);: Error: SQLITE_BUSY: database is locked
          ! sql-0 08 03:06:06.922 error Cannot insert INSERT INTO ts_number (id, ts, val, ack, _from, q) VALUES(3, 1462669565831, 24, 1, 1, 0);: Error: SQLITE_BUSY: database is locked
          ! sql-0 08 03:06:06.841 warn Cannot get index of "yr.0.forecast.day0.text": Error: SQLITE_BUSY: database is locked
          ! sql-0 08 03:06:06.840 error Cannot select SELECT id, type FROM datapoints WHERE name='yr.0.forecast.day0.text';: Error: SQLITE_BUSY: database is locked
          ! sql-0 08 03:06:06.821 warn Cannot get index of "yr.0.forecast.day0.icon": Error: SQLITE_BUSY: database is locked
          ! sql-0 08 03:06:06.820 error Cannot select SELECT id, type FROM datapoints WHERE name='yr.0.forecast.day0.icon';: Error: SQLITE_BUSY: database is locked
          ! yr-0 08 03:06:05.739 info got weather data from yr.no
          ! yr-0 08 03:06:05.022 info starting. Version 1.0.1 in /opt/iobroker/node_modules/iobroker.yr
          ! host-RPi2-1 08 03:06:00.731 info instance system.adapter.yr.0 started with pid 2022
          ! sql-0 08 03:03:07.599 error Cannot insert INSERT INTO ts_string (id, ts, val, ack, _from, q) VALUES(33, 1462669385663, '{}', 1, 2, 0);: Error: SQLITE_BUSY: database is locked
          ! sql-0 08 03:03:06.598 error Cannot insert INSERT INTO ts_number (id, ts, val, ack, _from, q) VALUES(48, 1462669385583, 0, 1, 2, 0);: Error: SQLITE_BUSY: database is locked
          ! sql-0 08 03:03:06.588 error Cannot insert INSERT INTO ts_string (id, ts, val, ack, _from, q) VALUES(49, 1462669385574, '', 1, 2, 0);: Error: SQLITE_BUSY: database is locked
          ! sql-0 08 02:06:08.173 error Cannot insert INSERT INTO ts_string (id, ts, val, ack, _from, q) VALUES(19, 1462665966146, 'Wolkig', 1, 1, 0);: Error: SQLITE_BUSY: database is locked
          ! host-RPi2-1 08 03:03:06.145 info instance system.adapter.dwd.0 terminated with code 0 (OK)
          ! dwd-0 08 03:03:05.200 info starting. Version 2.0.3 in /opt/iobroker/node_modules/iobroker.dwd
          ! host-RPi2-1 08 03:03:00.615 info instance system.adapter.dwd.0 started with pid 2011
          ! host-RPi2-1 08 02:06:11.297 info instance system.adapter.yr.0 terminated with code 0 (OK)
          ! sql-0 08 02:06:09.052 error Cannot insert INSERT INTO ts_number (id, ts, val, ack, _from, q) VALUES(23, 1462665966177, 1010, 1, 1, 0);: Error: SQLITE_BUSY: database is locked
          ! sql-0 08 02:06:08.052 error Cannot insert INSERT INTO ts_number (id, ts, val, ack, _from, q) VALUES(16, 1462665966134, 1014, 1, 1, 0);: Error: SQLITE_BUSY: database is locked
          ! sql-0 08 02:06:08.049 error Cannot insert INSERT INTO ts_number (id, ts, val, ack, _from, q) VALUES(15, 1462665966131, 24.9, 1, 1, 0);: Error: SQLITE_BUSY: database is locked
          ! sql-0 08 02:06:07.173 error Cannot insert INSERT INTO ts_number (id, ts, val, ack, _from, q) VALUES(4, 1462665966041, 0, 1, 1, 0);: Error: SQLITE_BUSY: database is locked
          ! sql-0 08 02:06:07.052 warn Cannot get index of "yr.0.forecast.day0.text": Error: SQLITE_BUSY: database is locked
          ! sql-0 08 02:06:07.051 error Cannot select SELECT id, type FROM datapoints WHERE name='yr.0.forecast.day0.text';: Error: SQLITE_BUSY: database is locked
          ! sql-0 08 02:06:07.049 warn Cannot get index of "yr.0.forecast.day0.icon": Error: SQLITE_BUSY: database is locked
          ! sql-0 08 02:06:07.048 error Cannot select SELECT id, type FROM datapoints WHERE name='yr.0.forecast.day0.icon';: Error: SQLITE_BUSY: database is locked
          ! yr-0 08 02:06:05.945 info got weather data from yr.no
          ! yr-0 08 02:06:05.286 info starting. Version 1.0.1 in /opt/iobroker/node_modules/iobroker.yr
          ! host-RPi2-1 08 02:06:00.746 info instance system.adapter.yr.0 started with pid 1961
          ! sql-0 08 02:03:08.015 error Cannot insert INSERT INTO ts_string (id, ts, val, ack, _from, q) VALUES(30, 1462665785998, '', 1, 2, 0);: Error: SQLITE_BUSY: database is locked
          ! sql-0 08 02:03:08.008 error Cannot insert INSERT INTO ts_string (id, ts, val, ack, _from, q) VALUES(29, 1462665785994, '{}', 1, 2, 0);: Error: SQLITE_BUSY: database is locked
          ! sql-0 08 02:03:07.014 error Cannot insert INSERT INTO ts_number (id, ts, val, ack, _from, q) VALUES(48, 1462665785956, 0, 1, 2, 0);: Error: SQLITE_BUSY: database is locked
          ! sql-0 08 02:03:07.008 error Cannot insert INSERT INTO ts_string (id, ts, val, ack, _from, q) VALUES(27, 1462665785979, '', 1, 2, 0);: Error: SQLITE_BUSY: database is locked
          ! sql-0 08 02:03:06.972 error Cannot insert INSERT INTO ts_string (id, ts, val, ack, _from, q) VALUES(49, 1462665785944, '', 1, 2, 0);: Error: SQLITE_BUSY: database is locked
          ! sql-0 08 01:06:07.663 error Cannot insert INSERT INTO ts_string (id, ts, val, ack, _from, q) VALUES(36, 1462662365695, 'http://symbol.yr.no/grafikk/sym/b38/mf/01n.08.png', 1, 1, 0);: Error: SQLITE_BUSY: database is locked
          ! sql-0 08 01:06:07.647 error Cannot insert INSERT INTO ts_string (id, ts, val, ack, _from, q) VALUES(10, 1462662365692, '09.05.2016', 1, 1, 0);: Error: SQLITE_BUSY: database is locked
          ! host-RPi2-1 08 02:03:06.537 info instance system.adapter.dwd.0 terminated with code 0 (OK)
          ! dwd-0 08 02:03:05.524 info starting. Version 2.0.3 in /opt/iobroker/node_modules/iobroker.dwd
          ! host-RPi2-1 08 02:03:00.619 info instance system.adapter.dwd.0 started with pid 1951
          ! host-RPi2-1 08 01:06:10.897 info instance system.adapter.yr.0 terminated with code 0 (OK)
          ! sql-0 08 01:06:08.881 error Cannot insert INSERT INTO ts_string (id, ts, val, ack, _from, q) VALUES(25, 1462662365850, '[{"date":"08.05.2016","icon":"http://symbol.yr.no/grafikk/sym/b38/01d … t Himmel","temperat
          ! sql-0 08 01:06:08.665 error Cannot insert INSERT INTO ts_string (id, ts, val, ack, _from, q) VALUES(41, 1462662365785, 'null', 1, 1, 0);: Error: SQLITE_BUSY: database is locked
          ! sql-0 08 01:06:08.647 error Cannot insert INSERT INTO ts_number (id, ts, val, ack, _from, q) VALUES(40, 1462662365782, 0, 1, 1, 0);: Error: SQLITE_BUSY: database is locked
          ! sql-0 08 01:06:06.879 error Cannot insert INSERT INTO ts_number (id, ts, val, ack, _from, q) VALUES(35, 1462662365662, 14, 1, 1, 0);: Error: SQLITE_BUSY: database is locked
          ! sql-0 08 01:06:06.664 warn Cannot get index of "yr.0.forecast.day0.text": Error: SQLITE_BUSY: database is locked
          ! sql-0 08 01:06:06.663 error Cannot select SELECT id, type FROM datapoints WHERE name='yr.0.forecast.day0.text';: Error: SQLITE_BUSY: database is locked
          ! sql-0 08 01:06:06.648 warn Cannot get index of "yr.0.forecast.day0.icon": Error: SQLITE_BUSY: database is locked
          ! sql-0 08 01:06:06.647 error Cannot select SELECT id, type FROM datapoints WHERE name='yr.0.forecast.day0.icon';: Error: SQLITE_BUSY: database is locked
          ! yr-0 08 01:06:05.559 info got weather data from yr.no
          ! yr-0 08 01:06:04.845 info starting. Version 1.0.1 in /opt/iobroker/node_modules/iobroker.yr
          ! host-RPi2-1 08 01:06:00.730 info instance system.adapter.yr.0 started with pid 1897
          ! sql-0 08 01:03:06.957 error Cannot insert INSERT INTO ts_string (id, ts, val, ack, _from, q) VALUES(44, 1462662185946, '', 1, 2, 0);: Error: SQLITE_BUSY: database is locked
          ! sql-0 08 01:03:06.948 warn Cannot get index of "dwd.0.warning.severity": Error: SQLITE_BUSY: database is locked
          ! sql-0 08 01:03:06.947 error Cannot select SELECT id, type FROM datapoints WHERE name='dwd.0.warning.severity';: Error: SQLITE_BUSY: database is locked
          ! sql-0 08 00:06:08.262 error Cannot insert INSERT INTO ts_number (id, ts, val, ack, _from, q) VALUES(38, 1462658766036, 14, 1, 1, 0);: Error: SQLITE_BUSY: database is locked
          ! sql-0 08 00:06:07.995 error Cannot insert INSERT INTO ts_string (id, ts, val, ack, _from, q) VALUES(37, 1462658766033, 'Klarer Himmel', 1, 1, 0);: Error: SQLITE_BUSY: database is locked
          ! sql-0 08 00:06:07.978 error Cannot insert INSERT INTO ts_string (id, ts, val, ack, _from, q) VALUES(36, 1462658766029, 'http://symbol.yr.no/grafikk/sym/b38/mf/01n.08.png', 1, 1, 0);: Error: SQLITE_BUSY: database is locked
          ! host-RPi2-1 08 01:03:06.507 info instance system.adapter.dwd.0 terminated with code 0 (OK)
          ! dwd-0 08 01:03:05.515 info starting. Version 2.0.3 in /opt/iobroker/node_modules/iobroker.dwd
          ! host-RPi2-1 08 01:03:00.611 info instance system.adapter.dwd.0 started with pid 1887
          ! host-RPi2-1 08 00:06:11.295 info instance system.adapter.yr.0 terminated with code 0 (OK)
          ! sql-0 08 00:06:08.995 error Cannot insert INSERT INTO ts_number (id, ts, val, ack, _from, q) VALUES(40, 1462658766144, 0, 1, 1, 0);: Error: SQLITE_BUSY: database is locked
          ! sql-0 08 00:06:07.262 error Cannot insert INSERT INTO ts_number (id, ts, val, ack, _from, q) VALUES(3, 1462658765998, 24, 1, 1, 0);: Error: SQLITE_BUSY: database is locked
          ! sql-0 08 00:06:06.995 warn Cannot get index of "yr.0.forecast.day0.text": Error: SQLITE_BUSY: database is locked
          ! sql-0 08 00:06:06.994 error Cannot select SELECT id, type FROM datapoints WHERE name='yr.0.forecast.day0.text';: Error: SQLITE_BUSY: database is locked
          ! sql-0 08 00:06:06.979 warn Cannot get index of "yr.0.forecast.day0.icon": Error: SQLITE_BUSY: database is locked
          ! sql-0 08 00:06:06.978 error Cannot select SELECT id, type FROM datapoints WHERE name='yr.0.forecast.day0.icon';: Error: SQLITE_BUSY: database is locked
          ! yr-0 08 00:06:05.890 info got weather data from yr.no
          ! yr-0 08 00:06:05.185 info starting. Version 1.0.1 in /opt/iobroker/node_modules/iobroker.yr
          ! host-RPi2-1 08 00:06:00.735 info instance system.adapter.yr.0 started with pid 1832
          ! sql-0 08 00:03:06.989 error Cannot insert INSERT INTO ts_string (id, ts, val, ack, _from, q) VALUES(27, 1462658585925, '', 1, 2, 0);: Error: SQLITE_BUSY: database is locked
          ! sql-0 08 00:03:06.950 warn Cannot get index of "dwd.0.warning.severity": Error: SQLITE_BUSY: database is locked
          ! sql-0 08 00:03:06.948 error Cannot select SELECT id, type FROM datapoints WHERE name='dwd.0.warning.severity';: Error: SQLITE_BUSY: database is locked
          ! host-RPi2-1 08 00:03:06.610 info instance system.adapter.dwd.0 terminated with code 0 (OK)
          ! dwd-0 08 00:03:05.494 info starting. Version 2.0.3 in /opt/iobroker/node_modules/iobroker.dwd
          ! host-RPi2-1 08 00:03:00.619 info instance system.adapter.dwd.0 started with pid 1820
          ! sql-0 08 00:00:08.016 error Cannot insert INSERT INTO ts_string (id, ts, val, ack, _from, q) VALUES(60, 1462658403852, 'Pfingstsonntag', 1, 4, 0);: Error: SQLITE_BUSY: database is locked
          ! sql-0 08 00:00:07.016 error Cannot insert INSERT INTO ts_bool (id, ts, val, ack, _from, q) VALUES(52, 1462658403835, 0, 1, 4, 0);: Error: SQLITE_BUSY: database is locked
          ! sql-0 08 00:00:06.953 error Cannot delete DELETE FROM ts_bool WHERE id=52 AND ts < 1431122400827;: Error: SQLITE_BUSY: database is locked
          ! sql-0 08 00:00:06.951 error Cannot delete DELETE FROM ts_string WHERE id=50 AND ts < 1431122400816;: Error: SQLITE_BUSY: database is locked
          ! sql-0 08 00:00:06.015 error Cannot insert INSERT INTO ts_bool (id, ts, val, ack, _from, q) VALUES(51, 1462658403819, 0, 1, 4, 0);: Error: SQLITE_BUSY: database is locked
          ! sql-0 08 00:00:05.954 error Cannot delete DELETE FROM ts_number WHERE id=63 AND ts < 1431122400877;: Error: SQLITE_BUSY: database is locked
          ! sql-0 08 00:00:05.951 error Cannot insert INSERT INTO ts_number (id, ts, val, ack, _from, q) VALUES(63, 1462658403863, 6, 1, 4, 0);: Error: SQLITE_BUSY: database is locked
          ! sql-0 08 00:00:05.017 warn Cannot get index of "feiertage.0.morgen.Name": Error: SQLITE_BUSY: database is locked
          ! sql-0 08 00:00:05.015 error Cannot insert INSERT INTO datapoints (name, type) VALUES('feiertage.0.morgen.Name', 1);: Error: SQLITE_BUSY: database is locked
          ! host-RPi2-1 08 00:00:04.423 info instance system.adapter.feiertage.0 terminated with code 0 (OK)
          ! feiertage-0 08 00:00:03.630 info starting. Version 0.3.1 in /opt/iobroker/node_modules/iobroker.feiertage
