  4. Google Home/Assistant ioBroker einrichten/nutzen
    5.3k
googlegoogle asisstantgoogle homegoogle home minihow-toanleitung
1.2k Beiträge 127 Kommentatoren 491.1k Aufrufe 139 Beobachtet
  • S Sundance
    Hiho,
    ich habe seit einem größeren Update von iobroker (alle Adapter nach und nach geupdated und auch den javascript Adapter auf 2.1.0 geupdated) Probleme mit iot bzw Google Home. Wann immer ich ein Thermostat anfragen bzw. den Wert in der Google Home App verändern will, tauchen folgende Fehlermeldungen im Log auf:
    iot.0	2019-11-21 17:06:04.483	warn	(3851) [GHOME] Invalid URL key. Status update is disabled you can set states but not receive state updates: {"error":"Invalid URL-KEY"}
    iot.0	2019-11-21 17:06:04.482	warn	(3851) [GHOME] Invalid URL key. Status update is disabled you can set states but not receive state updates: {"error":"Invalid URL-KEY"}
    iot.0	2019-11-21 17:06:04.481	error	(3851) [GHOME] Url Key error. Google Request and Response are working. But device states are not reported automatically: {"error":"Invalid URL-KEY"}
    iot.0	2019-11-21 17:06:04.448	info	(3851) Connection changed: connect
    iot.0	2019-11-21 17:06:04.303	info	(3851) hm-rpc.1.0012999395FE72.1 is auto added with type thermostat.
    iot.0	2019-11-21 17:06:04.302	info	(3851) hm-rpc.1.0012999395FA9D.1 is auto added with type thermostat.
    iot.0	2019-11-21 17:06:04.302	info	(3851) hm-rpc.1.0012999395FA94.1 is auto added with type thermostat.
    iot.0	2019-11-21 17:06:04.300	info	(3851) hm-rpc.1.0012999395E236.1 is auto added with type thermostat.
    iot.0	2019-11-21 17:06:04.299	info	(3851) hm-rpc.1.0012999395BDBF.1 is auto added with type thermostat.
    iot.0	2019-11-21 17:06:04.297	info	(3851) hm-rpc.1.0012999395E098.1 is auto added with type thermostat.
    iot.0	2019-11-21 17:06:04.191	info	(3851) hm-rpc.1.0012999395FE72.1 is auto added with type thermostat.
    iot.0	2019-11-21 17:06:04.169	info	(3851) hm-rpc.1.0012999395FA9D.1 is auto added with type thermostat.
    iot.0	2019-11-21 17:06:04.141	info	(3851) hm-rpc.1.0012999395FA94.1 is auto added with type thermostat.
    iot.0	2019-11-21 17:06:04.112	info	(3851) hm-rpc.1.0012999395E236.1 is auto added with type thermostat.
    iot.0	2019-11-21 17:06:04.089	info	(3851) hm-rpc.1.0012999395BDBF.1 is auto added with type thermostat.
    iot.0	2019-11-21 17:06:04.031	info	(3851) hm-rpc.1.0012999395E098.1 is auto added with type thermostat.
    iot.0	2019-11-21 17:06:03.411	info	(3851) Connecting with a18wym7vjdl22g.iot.eu-west-1.amazonaws.com
    iot.0	2019-11-21 17:06:03.368	info	(3851) starting. Version 1.1.8 in /opt/iobroker/node_modules/iobroker.iot, node: v10.17.0
    host.HOME	2019-11-21 17:06:00.241	info	instance system.adapter.iot.0 started with pid 3851
    host.HOME	2019-11-21 17:05:30.231	info	Restart adapter system.adapter.iot.0 because enabled
    host.HOME	2019-11-21 17:05:30.231	info	instance system.adapter.iot.0 terminated with code 0 (NO_ERROR)
    host.HOME	2019-11-21 17:05:30.230	error	Caught by controller[0]: at processImmediate (timers.js:658:5)
    host.HOME	2019-11-21 17:05:30.230	error	Caught by controller[0]: at tryOnImmediate (timers.js:676:5)
    host.HOME	2019-11-21 17:05:30.230	error	Caught by controller[0]: at runCallback (timers.js:705:18)
    host.HOME	2019-11-21 17:05:30.230	error	Caught by controller[0]: at Immediate.setImmediate (/opt/iobroker/node_modules/iobroker.iot/lib/GoogleHome.js:2074:41)
    host.HOME	2019-11-21 17:05:30.229	error	Caught by controller[0]: at GoogleHome.getStates (/opt/iobroker/node_modules/iobroker.iot/lib/GoogleHome.js:2072:26)
    host.HOME	2019-11-21 17:05:30.229	error	Caught by controller[0]: at Adapter.getForeignState (/opt/iobroker/node_modules/iobroker.js-controller/lib/adapter.js:5560:24)
    host.HOME	2019-11-21 17:05:30.228	error	Caught by controller[0]: TypeError: Cannot read property 'startsWith' of undefined
    iot.0	2019-11-21 17:05:29.755	info	(31018) Connection lost
    iot.0	2019-11-21 17:05:29.755	info	(31018) Connection changed: disconnect
    iot.0	2019-11-21 17:05:29.714	info	(31018) Terminated (NO_ERROR): Without reason
    iot.0	2019-11-21 17:05:29.713	info	(31018) terminating
    iot.0	2019-11-21 17:05:29.707	error	at processImmediate (timers.js:658:5)
    iot.0	2019-11-21 17:05:29.707	error	at tryOnImmediate (timers.js:676:5)
    iot.0	2019-11-21 17:05:29.707	error	at runCallback (timers.js:705:18)
    iot.0	2019-11-21 17:05:29.707	error	at Immediate.setImmediate (/opt/iobroker/node_modules/iobroker.iot/lib/GoogleHome.js:2074:41)
    iot.0	2019-11-21 17:05:29.707	error	at GoogleHome.getStates (/opt/iobroker/node_modules/iobroker.iot/lib/GoogleHome.js:2072:26)
    iot.0	2019-11-21 17:05:29.707	error	at Adapter.getForeignState (/opt/iobroker/node_modules/iobroker.js-controller/lib/adapter.js:5560:24)
    iot.0	2019-11-21 17:05:29.707	error	(31018) TypeError: Cannot read property 'startsWith' of undefined
    iot.0	2019-11-21 17:05:29.706	error	(31018) uncaught exception: Cannot read property 'startsWith' of undefined
    Ich habe schonmal neue Certs angefordert und auch nochmal alles neu eingerichtet in Google Home - aber mir werden alle Geräte als Offline angezeigt.
    Eine Idee, was ich tun könnte bzw. wo evtl. das Problem liegt? Habe ich eine Falsche Adapterversion? 🤔
    Danke vorab
    Beste Grüße
    Sundance
    tombox
    #781
    @Sundance Das sollte eigentlich nicht passieren, aber du kannst mal meine Version installieren (erster Beitrag letzter Absatz) und schauen was da als log angezeigt wird.
    • T tombox
      Sundance
      #782
      @tombox - Ja, mit deiner Version scheint alles wieder problemlos zu klappen! Gibt es etwas, was ich zum evtl. debugging beitragen kann, oder reicht dir das log? kann ich diese Version einfach weiterverwenden, oder sollte ich irgendwann wieder zurückwechseln?
      Vielen dank!
      • S Sundance
        Vielen dank!
        tombox
        #783
        @Sundance wenn ein Fehler kommt bräuchte es ch den log. Wenn ein update kommt führst du das aus und bist wieder auf der Standard Version
        • RummelmugR Rummelmug
          @tombox Das hört sich gut an. Hier die Daten der Systemvariable.
          Danke schonmal :-)
            "_id": "hm-rega.0.7580",
            "type": "state",
            "common": {
              "name": "PelletsHeizung",
              "type": "number",
              "read": true,
              "write": true,
              "role": "state",
              "states": {
                "0": "Aus",
                "1": "Auto",
                "2": "Manuell",
                "3": ""
              "min": 0,
              "max": 3,
              "custom": {
                "history.0": {
                  "enabled": true,
                  "changesOnly": true,
                  "debounce": "",
                  "maxLength": "",
                  "retention": "31536000",
                  "changesRelogInterval": "",
                  "changesMinDelta": "",
                  "aliasId": ""
              "smartName": false
            "native": {
              "Name": "PelletsHeizung",
              "TypeName": "VARDP",
              "DPInfo": "",
              "ValueMin": null,
              "ValueMax": null,
              "ValueUnit": "",
              "ValueType": 16,
              "ValueSubType": 29,
              "ValueList": "Aus;Auto;Manuell;"
            "from": "system.adapter.hm-rega.0",
            "ts": 1569722481830,
            "acl": {
              "object": 1636,
              "state": 1636,
              "owner": "system.user.admin",
            "user": "system.user.admin"
          RummelmugR Offline
          RummelmugR Offline
          Rummelmug
          #784
          @tombox Konntest du hier schon was rausfinden? Ich hab jetzt schon verschiedenen Traits versucht, komme aber zu keinem Ergebnis.
          @Rummelmug sagte in Google Home/Assistant ioBroker einrichten/nutzen:
          Danke schonmal :-)
            "type": "state",
            "common": {
              "type": "number",
              "read": true,
              "write": true,
              "role": "state",
              "states": {
                "0": "Aus",
                "1": "Auto",
                "2": "Manuell",
                "3": ""
              "min": 0,
              "max": 3,
              "custom": {
                "history.0": {
                  "enabled": true,
                  "debounce": "",
                  "maxLength": "",
                  "aliasId": ""
              "smartName": false
            "native": {
              "DPInfo": "",
              "ValueMin": null,
              "ValueMax": null,
              "ValueUnit": "",
              "ValueType": 16,
              "ValueSubType": 29,
            "acl": {
              "object": 1636,
              "state": 1636,
            Danke schonmal :-)
              "type": "state",
              "common": {
                "type": "number",
                "read": true,
                "write": true,
                "role": "state",
                "states": {
                  "0": "Aus",
                  "1": "Auto",
                  "2": "Manuell",
                  "3": ""
                "min": 0,
                "max": 3,
                "custom": {
                  "history.0": {
                    "enabled": true,
                    "debounce": "",
                    "maxLength": "",
                    "aliasId": ""
                "smartName": false
              "native": {
                "DPInfo": "",
                "ValueMin": null,
                "ValueMax": null,
                "ValueUnit": "",
                "ValueType": 16,
                "ValueSubType": 29,
              "acl": {
                "object": 1636,
                "state": 1636,
            tombox
            #785
            @Rummelmug noch keine zeit gehabt aber könntest du die json datei hochladen ?
            RummelmugR 1 Antwort Letzte Antwort
            • T tombox
              RummelmugR Offline
              RummelmugR Offline
              Rummelmug
              #786
              @tombox gerne :)
              hm-rega.0.7580.json
              • T tombox
                @eric1905
                Das Problem, dass keine Action und Trait in dem Google Tab gewählt wurde. Ich werde das in der nächsten Version noch verbessern.
                jmeister79J Offline
                jmeister79J Offline
                jmeister79
                schrieb am zuletzt editiert von jmeister79
                #787
                @tombox ich habe auch das problem wie eric, dass "Die Einstellung nicht übernommen worden konnte - Prüfe Deine Verbindung"
                Das passiert in der Android App für Google Home wenn ich vErsuche iobroker als Dienst hinzuzufügen
                Nutze iot Adapter Version: 1.1.9
                • jmeister79J jmeister79
                  tombox
                  #788
                  @jmeister79 wann genau kommt die Meldung
                  jmeister79J 1 Antwort Letzte Antwort
                  • T tombox
                    jmeister79J Offline
                    jmeister79J Offline
                    jmeister79
                    #789
                    @tombox
                    Wenn ich versuche einen neuen Dienst Hinzufügen.
                    ich Suche mir ioBroker raus (Zugangsdaten hat er ja nun).
                    Weiße Box mit ewigem Kreis: ""Sie werden angemeldet..."
                    Weiße Box mit ewigem Kreis:"Wird mit ioBroker Konto Verknüpft..."
                    Dann unten als schwarze Box am Rand: "Die Eisntellung konnte nicht aktualisiert werde, Bitte prüfe die Verbindung!"
                      @tombox
                      tombox
                      #790
                      @jmeister79 Liegt wahrscheinlich nicht im Adapter wahrscheinlich am iot konto. Vielleicht mal passwort zurücksetzen oder google home app löschen
                      • T tombox
                        jmeister79J Offline
                        jmeister79J Offline
                        jmeister79
                        #791
                        @tombox das Passwort mit dem ich dort im Webauftritt angemeldet bin sit doch nicht das gleiche wie das, dass ich in der Google App nutzen muss odeR?
                        Dafür war doch dieses Einmal Kennwort.
                        Wie setze ichd as denn zurück?
                          tombox
                          #792
                          @jmeister79 einfach ein neues einmal kennwort über die instanz optionen anfordern
                          • Herr.KnownH Offline
                            Herr.KnownH Offline
                            Herr.Known
                            #793
                            Kann man die Lampen über den Google Assistent auch dimmen? Wenn ja wie?
                            • Herr.KnownH Herr.Known
                              tombox
                              #794
                              @Herr-Known Ja wenn sie eine brightness level state haben kann man über die app oder per sprache auf den gewünschte helligkeit setzen
                                Herr.KnownH Offline
                                Herr.Known
                                #795
                                @tombox was ist damit gemeint? muss ich das in den Objekten irgendwie konfigurieren ?
                                B 1 Antwort Letzte Antwort
                                  Brati
                                  #796
                                  @Herr-Known Ja, in den Objekten wird der State einem Raum und der Funktion Licht zugeordnet. Wenn er nicht automatisch im iot Adapter auftaucht, dann von Hand hinzufügen und Light / Brightness auswählen. Danach kann man sagen : "Schalte das Licht xxx auf xx Prozent"....
                                  CCU2 - 46 Geräte, ioBroker auf Intel NUC (DN2820FYKH) mit Tab als Frontend, Projekt Gartenhaus mit HM
                                    Herr.KnownH Offline
                                    Herr.Known
                                    #797
                                    @tombox Jo Danke Funktioniert.
                                    • K Offline
                                      koema
                                      #798
                                      Hallo
                                      ich habe den Adapter auch installiert und er wird auch grün,
                                      aber ich abe immer folgende 3 Fehlermeldungen im Log, wenn ich ihn starte:
                                      (30598) [GHOME] Invalid URL Pro key. Status autoupdate is disabled you can set states but receive states only manually: {"error":"Invalid URL-KEY"}
                                      (30598) [GHOME] Url Key error. Google Request and Response are working. But device states are not reported automatically: {"error":"Invalid URL-KEY"}
                                      Ich bekomme sie nicht weg. Ich habe einen iobroker pro account und ein Jahr Fernzugriff.
                                      Eine Idee?
                                      T T 2 Antworten Letzte Antwort
                                      • K koema
                                        Hallo
                                        Eine Idee?
                                        tombox
                                        #799
                                        @koema Adapter nochmal komplett löschen und neuinstallieren bringt das was?
                                        • K koema
                                          Hallo
                                          Eine Idee?
                                          thomas.flaechsig
                                          schrieb am zuletzt editiert von thomas.flaechsig
                                          #800
                                          @koema Gleiches Problem bei mir seit heute - Konntest Du das Problem lösen? Neuinstallation hat nichts gebracht.
