  5. [gelöst] Osmose Wasser Aktuell & Max Verbrauch
    5.6k
79 Beiträge 2 Kommentatoren 4.6k Aufrufe 1 Beobachtet
  • AphofisA Offline
    AphofisA Offline
    Aphofis
    Die Steuerung sieht jetzt so aus!
      <variables>
        <variable type="" id="V]/%u4JGSoxh-Al{eT.g">ml_pro_Tag</variable>
        <variable type="" id="ihvas_{d.kg4gRlA_SmF">ml_Kumulativ</variable>
        <variable type="" id="n:v;eT@?L%cbL{M}xt_E">Differenz</variable>
        <variable type="" id="ckVaiUkVWNw*nrHYt1ho">ml_Aktuell</variable>
      </variables>
      <block type="variables_set" id="J.74*3iWof~,6Kx}~#T," x="-562" y="-137">
        <field name="VAR" id="V]/%u4JGSoxh-Al{eT.g" variabletype="">ml_pro_Tag</field>
        <value name="VALUE">
          <block type="get_value" id="j;OOKB1V1b_V.R-Z-tv=">
            <field name="OID">admin.1.Aquarium_Control.Osmose_Aktuell</field>
          </block>
        </value>
        <next>
          <block type="variables_set" id="r9eO:=nj*R8[_VP#N.B#">
            <field name="VAR" id="ihvas_{d.kg4gRlA_SmF" variabletype="">ml_Kumulativ</field>
              <block type="get_value" id="o`iB.H?7RH[)vaB~x33:">
                <field name="OID">admin.1.Aquarium_Control.Osmose_Max</field>
              </block>
            </value>
            <next>
              <block type="comment" id="5_dAu$u@jE|TAgl|;,XY">
                <field name="COMMENT">Magnetventil</field>
                <next>
                  <block type="on_ext" id=":Nr`7Jva*j~6F*k.h/^F">
                    <value name="OID0">
                      <shadow type="field_oid" id="eXd?Hfx6K/{9#D2So~zg">
                        <field name="oid">rpi2.0.gpio.21.state</field>
                      </shadow>
                      <block type="get_value" id="*%whagkPP!|G[e$-}J=j">
                        <field name="OID">rpi2.0.gpio.21.state</field>
                      </block>
                    </value>
                    <statement name="STATEMENT">
                      <block type="controls_if" id=",3lQx[D^fe0|wZv07i:F">
                        <value name="IF0">
                          <block type="logic_negate" id="5YH|]f]Y8q~OZzn6dp~c">
                            <value name="BOOL">
                              <block type="on_source" id="7V.$(3ehpmvx4I8d18aw">
                              </block>
                            </value>
                          </block>
                        </value>
                        <statement name="DO0">
                          <block type="variables_set" id="72%z_H5G5)(I?g,6w}y4">
                            <field name="VAR" id="n:v;eT@?L%cbL{M}xt_E" variabletype="">Differenz</field>
                              <block type="math_arithmetic" id="hbDOS/*?OV7f*;K%5]/B">
                                <value name="A">
                                  <shadow type="math_number" id="1qz=5}09VW70aU;#1XFo">
                                    <field name="NUM">1</field>
                                  </shadow>
                                  <block type="on_source" id="vRHoi8S{X(;fi6|?CNdR">
                                    <field name="ATTR">state.lc</field>
                                  </block>
                                </value>
                                <value name="B">
                                  <shadow type="math_number" id="igjc3(uZ:S);a(CB+~6G">
                                  </shadow>
                                  <block type="on_source" id="4o,`J,IU$mwUfG~ldTcS">
                                    <field name="ATTR">oldState.lc</field>
                                  </block>
                                </value>
                              </block>
                            </value>
                            <next>
                              <block type="variables_set" id="m=_{N_=!`*U)%~+=6k)M">
                                <field name="VAR" id="ckVaiUkVWNw*nrHYt1ho" variabletype="">ml_Aktuell</field>
                                  <block type="math_arithmetic" id="4kRl.?`8|Mh3F%NpuU)o">
                                    <field name="OP">MULTIPLY</field>
                                    <value name="A">
                                      </shadow>
                                      <block type="variables_get" id="Mhz6a_f|)g9t_NoX-J4o">
                                      </block>
                                    </value>
                                    <value name="B">
                                      </shadow>
                                      <block type="get_value" id="JvRB[I?w$,K)uyI4f^bs">
                                        <field name="OID">admin.1.Aquarium_Control.ml_multiplikator</field>
                                      </block>
                                    </value>
                                  </block>
                                </value>
                                <next>
                                  <block type="update" id="@DXH()Q[2XD)B|wzZ3,1">
                                    <field name="OID">admin.1.Aquarium_Control.ml_pro_Tag</field>
                                      <block type="math_rndfixed" id="`T$g_{-$PLe-SSBp~eRc">
                                        <field name="n">2</field>
                                        <value name="x">
                                          <shadow type="math_number" id="+-xoJC%#+sANg_OJ={H8">
                                            <field name="NUM">3.1234</field>
                                          </shadow>
                                          <block type="variables_get" id="f0]0D7lYkKvj8_p~z.%d">
                                          </block>
                                        </value>
                                      </block>
                                    </value>
                                    <next>
                                      <block type="math_change" id="i##pC}m@FZYhZ+UJ#P?b">
                                        <value name="DELTA">
                                          <shadow type="math_number" id="rjS|:BdoUJX*N=n`Ji[]">
                                          </shadow>
                                          <block type="variables_get" id="CpXbPP;H9nIQMrU;Uq)1">
                                          </block>
                                        </value>
                                        <next>
                                          <block type="math_change" id="{qy46Yh1+,z@=wazF=Sa">
                                              <shadow type="math_number" id=":iELaSM8MUE{v_j{wKtM">
                                              </shadow>
                                              <block type="variables_get" id="Uln@f]L*.73;Q))();nx">
                                              </block>
                                            </value>
                                            <next>
                                              <block type="update" id="Aoq8WBDY@Hokp`)m4/4X">
                                                  <block type="math_rndfixed" id="OzOc$JV79+l5~%[*Ls3q">
                                                    <value name="x">
                                                      </shadow>
                                                      <block type="variables_get" id="BspaT@-^5ZEI+SkZI[Mk">
                                                      </block>
                                                    </value>
                                                  </block>
                                                </value>
                                                <next>
                                                  <block type="update" id="$L)rekVx6$I,%e;4apgW">
                                                      <block type="math_round" id="0:*{$@p/*@-:+y#dr$zh">
                                                        <field name="OP">ROUND</field>
                                                        <value name="NUM">
                                                          <shadow type="math_number" id="@}^3%9A.jmf{F%7.Li8b">
                                                            <field name="NUM">3.1</field>
                                                          </shadow>
                                                          <block type="variables_get" id="QCo;X6-+|)pOF#Zl*cIe">
                                                          </block>
                                                        </value>
                                                      </block>
                                                    </value>
                                                    <next>
                                                      <block type="debug" id=";-vf26IOUB^od6zf#o6s">
                                                        <value name="TEXT">
                                                          <shadow type="text" id=".;Y[}a(8N_h0U)l?C.9:">
                                                          </shadow>
                                                          <block type="text_join" id="8!r$|^=,t[#JNZLQx94j">
                                                            <value name="ADD0">
                                                              <block type="text" id="r;GezYi}HE=H%]vDDLw4">
        <field name="TEXT">Dosierung aktuell </field>
                                                              </block>
                                                            </value>
                                                            <value name="ADD1">
                                                              <block type="math_rndfixed" id="61m!Va3FI+*)OeaUc!J]">
        <value name="x">
        </shadow>
        <block type="variables_get" id="jlT*`^NkkJGXF1HToYGY">
        </block>
        </value>
                                                              </block>
                                                            </value>
                                                          </block>
                                                        </value>
                                                        <next>
                                                          <block type="debug" id="HTt5R[I*-hwd.gKyl0{{">
                                                            <value name="TEXT">
                                                              </shadow>
                                                              <block type="text_join" id="FErg(6m]tZt5$=?8Ut5^">
        <value name="ADD0">
        <block type="text" id="h|=sT+)M-v/mq%hrnL5a">
        <field name="TEXT">Dosierung Gesamt </field>
        </block>
        </value>
        <value name="ADD1">
        <block type="math_rndfixed" id="8J1lCb1g%$wdUkP,-#l|">
        <value name="x">
        </shadow>
        <block type="variables_get" id="hm55C@pg}Ti[rjK+,]k|">
        </block>
        </value>
        </block>
        </value>
                                                              </block>
                                                            </value>
                                                          </block>
                                                        </next>
                                                      </block>
                                                    </next>
                                                  </block>
                                                </next>
                                              </block>
                                            </next>
                                          </block>
                                        </next>
                                      </block>
                                    </next>
                                  </block>
                                </next>
                              </block>
                            </next>
                          </block>
                        </statement>
                      </block>
                    </statement>
                    <next>
                      <block type="schedule" id="@{?t*Kbp)#F%kZ.QV7-P">
                        <field name="SCHEDULE">0 0 * * *</field>
                          <block type="variables_set" id="]hBT|HYa,^+;/_URpFpc">
                              <block type="math_number" id="/3j~a_2+DU]a%4W0RpQ(">
                                <field name="NUM">0</field>
                              </block>
                            </value>
                            <next>
                              <block type="update" id="F~SeVxhlc{!3syuJaRNO">
                                  </shadow>
                                  <block type="math_number" id="IEw|b8lc[)=9`zq5COIW">
                                  </block>
                                </value>
                              </block>
                            </next>
                          </block>
                        </statement>
                      </block>
                    </next>
                  </block>
                </next>
              </block>
            </next>
          </block>
        </next>
      </block>
    </xml>
    Die Werte Wert, letzteÄnderung und vorherigeLetzteÄnderung hab ich aus der Trigger ObjektID genommen.
    Doch werden keine Daten in die Datenpunkte geschrieben es steht immer nohch "null ml" in allen drei Datenpunkten.
    Osmose_Aktuell, Osmose_Max und ml_pro_Tag
    • AphofisA Aphofis
        <variables>
        </variables>
            </block>
          </value>
          <next>
                </block>
              </value>
              <next>
                  <next>
                      <value name="OID0">
                        </shadow>
                        </block>
                      </value>
                          <value name="IF0">
                              <value name="BOOL">
                                </block>
                              </value>
                            </block>
                          </value>
                                  <value name="A">
                                    </shadow>
                                    </block>
                                  </value>
                                  <value name="B">
                                    </shadow>
                                    </block>
                                  </value>
                                </block>
                              </value>
                              <next>
                                      <value name="A">
                                        </shadow>
                                        </block>
                                      </value>
                                      <value name="B">
                                        </shadow>
                                        </block>
                                      </value>
                                    </block>
                                  </value>
                                  <next>
                                          <value name="x">
                                            </shadow>
                                            </block>
                                          </value>
                                        </block>
                                      </value>
                                      <next>
                                            </shadow>
                                            </block>
                                          </value>
                                          <next>
                                                </shadow>
                                                </block>
                                              </value>
                                              <next>
                                                      <value name="x">
                                                        </shadow>
                                                        </block>
                                                      </value>
                                                    </block>
                                                  </value>
                                                  <next>
                                                          <value name="NUM">
                                                            </shadow>
                                                            </block>
                                                          </value>
                                                        </block>
                                                      </value>
                                                      <next>
                                                          <value name="TEXT">
                                                            </shadow>
                                                              <value name="ADD0">
        </block>
                                                              </value>
                                                              <value name="ADD1">
        <value name="x">
        </shadow>
        </block>
        </value>
        </block>
                                                              </value>
                                                            </block>
                                                          </value>
                                                          <next>
                                                              <value name="TEXT">
        </shadow>
        <value name="ADD0">
        </block>
        </value>
        <value name="ADD1">
        <value name="x">
        </shadow>
        </block>
        </value>
        </block>
        </value>
        </block>
                                                              </value>
                                                            </block>
                                                          </next>
                                                        </block>
                                                      </next>
                                                    </block>
                                                  </next>
                                                </block>
                                              </next>
                                            </block>
                                          </next>
                                        </block>
                                      </next>
                                    </block>
                                  </next>
                                </block>
                              </next>
                            </block>
                          </statement>
                        </block>
                      </statement>
                      <next>
                                </block>
                              </value>
                              <next>
                                    </shadow>
                                    </block>
                                  </value>
                                </block>
                              </next>
                            </block>
                          </statement>
                        </block>
                      </next>
                    </block>
                  </next>
                </block>
              </next>
            </block>
          </next>
        </block>
      </xml>
      @Aphofis
      Die Datenpunkte "Osmose_Aktuell" und "ml_pro_Tag" sind vertauscht.
      • AphofisA Offline
        AphofisA Offline
        Aphofis
        Ich verstehe nicht warum es nicht läuft!?
        • AphofisA Aphofis
          @Aphofis sagte:
          Ich schon: Der Tigger darf nicht der Wert vom Objekt ID ... sein, sondern muss die ID selbst sein, so wie hier.
           <variables>
           </variables>
               <block type="get_value_var" id=";qx8Kd*D1vAL]U;}P6L^">
                 <value name="OID">
                   <shadow type="text" id="6::J6t9Iao[MD{-O9uwB">
                     <field name="TEXT">admin.1.Aquarium_Control.ml_pro_Tag</field>
                   </shadow>
                 </value>
               </block>
             </value>
             <next>
                   </block>
                 </value>
                 <next>
                     <next>
                         <value name="OID0">
                           </shadow>
                         </value>
                             <value name="IF0">
                                 <value name="BOOL">
                                   </block>
                                 </value>
                               </block>
                             </value>
                                     <value name="A">
                                       </shadow>
                                       </block>
                                     </value>
                                     <value name="B">
                                       </shadow>
                                       </block>
                                     </value>
                                   </block>
                                 </value>
                                 <next>
                                         <value name="A">
                                           </shadow>
                                           </block>
                                         </value>
                                         <value name="B">
                                           </shadow>
                                           </block>
                                         </value>
                                       </block>
                                     </value>
                                     <next>
                                             <value name="x">
                                               </shadow>
                                               </block>
                                             </value>
                                           </block>
                                         </value>
                                         <next>
                                               </shadow>
                                               </block>
                                             </value>
                                             <next>
                                                   </shadow>
                                                   </block>
                                                 </value>
                                                 <next>
                                                         <value name="x">
                                                           </shadow>
                                                           </block>
                                                         </value>
                                                       </block>
                                                     </value>
                                                     <next>
                                                             <value name="NUM">
                                                               </shadow>
                                                               </block>
                                                             </value>
                                                           </block>
                                                         </value>
                                                         <next>
                                                             <value name="TEXT">
                                                               </shadow>
        <value name="ADD0">
        </block>
        </value>
        <value name="ADD1">
        <value name="x">
        </shadow>
        </block>
        </value>
        </block>
        </value>
                                                               </block>
                                                             </value>
                                                             <next>
        <value name="TEXT">
        </shadow>
        <value name="ADD0">
        </block>
        </value>
        <value name="ADD1">
        <value name="x">
        </shadow>
        </block>
        </value>
        </block>
        </value>
        </block>
        </value>
                                                               </block>
                                                             </next>
                                                           </block>
                                                         </next>
                                                       </block>
                                                     </next>
                                                   </block>
                                                 </next>
                                               </block>
                                             </next>
                                           </block>
                                         </next>
                                       </block>
                                     </next>
                                   </block>
                                 </next>
                               </block>
                             </statement>
                           </block>
                         </statement>
                         <next>
                                   </block>
                                 </value>
                                 <next>
                                   <block type="update" id=",5mG65Imrygz=PxUUDZ:">
                                       </block>
                                     </value>
                                   </block>
                                 </next>
                               </block>
                             </statement>
                           </block>
                         </next>
                       </block>
                     </next>
                   </block>
                 </next>
               </block>
             </next>
           </block>
          </xml>
          • AphofisA Offline
            AphofisA Offline
            Aphofis
            schrieb am zuletzt editiert von Aphofis
            Was soll ich sagen es läuft!!!
            Der Hammer das ist es Mega spitze
            Ich danke dir vielmals.
            Jetzt muss ich mich dran machen die Werte in eine Datenbank zu bekommen damit ich Diagramme per vis darstellen kann.
            Maria DB ist schon auf meinem NAS installiert!
            Nur wie am besten mit ioBroker verknüpfen und wie ich per Blockly die Daten da rein bekomme muss ich mich erstmal schlau machen.
            Man lernt ja nie aus.
            Nur verstehe ich es noch nicht wie der Zusammenhang ist
            Wert; letzteÄnderung ; vorherigeLetzteÄnderung
            Warum nicht Wert ist mir noch nicht verständlich.
            Ich gucke mir heute Abend mal an was ich falsch gemacht habe.
            Vielen Dank
            • AphofisA Aphofis
              Vielen Dank
              @Aphofis sagte:
              nicht Wert : Wert == falsch : Ventil schließt
              @Aphofis sagte in Osmose Wasser Aktuell & Max Verbrauch Hilfe!!!:
              letzte Änderung: Zeitpunkt vom Schließen des Ventils (in ms seit 1.1.1970)
              vorherige letzte Änderung: Zeitpunkt vom Öffnen des Ventils
              AphofisA 1 Antwort Letzte Antwort
                @Aphofis sagte:
                AphofisA Offline
                AphofisA Offline
                Aphofis
                Ok verstanden!
                Vielen dank
                So langsam steige ich hinter die Logik von Blockly
                • AphofisA Aphofis
                  Ok verstanden!
                  Vielen dank
                  @Aphofis sagte:
                  sind ioBroker-spezifisch.
                    @Aphofis sagte:
                    AphofisA Offline
                    AphofisA Offline
                    Aphofis
                    Die Liste ist gut! Dann kann ich mir eine Menge ableiten.
                    Habe jetzt auf deinen Rat einen neuen Datenpunkt im root erstellt und alle Unter Datenpunkte darin neu erstellt.
                    Aus dem Admin ist der Haupt Datenpunkt jetzt raus! und alle Steuerungen umgestellt auf die neuen Datenpunkte.
                    Ich denke Datenbank wird auch eine härtere Nuß für mich.
                    MariaDB ist schon per sql Adapter verknüpft aber um da was einzutragen muss ich mich erstmal ein wenig einlesen.
                    Schon mal toll solche Menschen wie dich hier zu haben, die einem so enorm weiter helfen.
                    Danke noch mal
                    • AphofisA Offline
                      AphofisA Offline
                      Aphofis
                      Wen es interessiert, und @paul53
                      ich hoffe ich habe das so richtig übersetzt.
                      Das ist eine Steuerung die meinen Vlies Verbrauch anzeigt und ermittelt.
                      Durch stoppen der Zeit für 10 cm habe ich den multiplikator ermittelt.
                      Die erstellten Datenpunkte zu dieser Steuerung
                      Mit cm pro Tag count habe ich noch was anderes vor aber ist erstmal außen vor und der Max Wert und cm pro Tag Werte stimmen natürlich nicht da ich zum testen den Vlies Motor mehrmals laufen lassen musste.
                      Der Tagesverbrauch liegt bei mir ca bei 30-40 cm. Den ich jetzt sehr genau ausgegeben bekomme.
                      • AphofisA Offline
                        AphofisA Offline
                        Aphofis
                        Der Code dazu Teil 1
                          <variables>
                            <variable type="" id="V]/%u4JGSoxh-Al{eT.g">cm_pro_Tag</variable>
                            <variable type="" id="ihvas_{d.kg4gRlA_SmF">cm_komulativ</variable>
                            <variable type="" id="ckVaiUkVWNw*nrHYt1ho">cm_Aktuell</variable>
                          </variables>
                          <block type="variables_set" id="J.74*3iWof~,6Kx}~#T," x="-487" y="-87">
                            <field name="VAR" id="V]/%u4JGSoxh-Al{eT.g" variabletype="">cm_pro_Tag</field>
                              <block type="get_value" id="!`-7w4Ob%M?7ztU!UD!8">
                                <field name="OID">Aqua_Control.0.cm_pro_Tag</field>
                              </block>
                            </value>
                            <next>
                                <field name="VAR" id="ihvas_{d.kg4gRlA_SmF" variabletype="">cm_komulativ</field>
                                    <field name="OID">Aqua_Control.0.cm_Max</field>
                                  </block>
                                </value>
                                <next>
                                    <next>
                                        <value name="OID0">
                                            <field name="oid">rpi2.0.gpio.13.state</field>
                                          </shadow>
                                        </value>
                                            <value name="IF0">
                                                <value name="BOOL">
                                                  </block>
                                                </value>
                                              </block>
                                            </value>
                                              <block type="comment" id="0_SP-:jo/~zs;Y(enH9B">
                                                <field name="COMMENT">1.1.1970 bis wert aktiv minus aktuelle zeit</field>
                                                <next>
                                                        <value name="A">
                                                          </shadow>
                                                          </block>
                                                        </value>
                                                        <value name="B">
                                                          </shadow>
                                                          </block>
                                                        </value>
                                                      </block>
                                                    </value>
                                                    <next>
                                                      <block type="comment" id="biINHf0{3Ed{bF)P{V].">
                                                        <field name="COMMENT">gemessene Zeit mal multiplikator um cm zu erlangen</field>
                                                        <next>
                                                            <field name="VAR" id="ckVaiUkVWNw*nrHYt1ho" variabletype="">cm_Aktuell</field>
        <value name="A">
        </shadow>
        </block>
        </value>
        <value name="B">
        </shadow>
        <field name="OID">Aqua_Control.0.cm_multiplikator</field>
        </block>
        </value>
                                                              </block>
                                                            </value>
                                                            <next>
                                                              <block type="comment" id="-qlvZlbKsCcmbXA9[|dQ">
        <field name="COMMENT">Datenpunkt cm Aktuell wird mit intern </field>
        <next>
        <block type="comment" id="=TI;v|K0P/XkMYJe@(7t">
        <field name="COMMENT">cm Aktuell aktualisiert</field>
        <next>
        <field name="OID">Aqua_Control.0.cm_Aktuell</field>
        <value name="x">
        </shadow>
        </block>
        </value>
        </block>
        </value>
        <next>
        <block type="comment" id="8a~s%M,NvYZjsSVhP.Ud">
        <field name="COMMENT">Gesamtverbrauch intern wird derm aktuell </field>
        <next>
        <block type="comment" id="vk3Hj5QI)t6bELlMM-PT">
        <field name="COMMENT">gemessenem internen Wert dazu addiert</field>
        <next>
        </shadow>
        </block>
        </value>
        <next>
        <block type="comment" id="w6gH[QW1DueK!oW_i)jC">
        <field name="COMMENT">aktueller interner Wert wird zum Tagesverbrauch</field>
        <next>
        <block type="comment" id="U(z%AO%43jU$y9N,z+58">
        <field name="COMMENT">intern dazu addiert</field>
        <next>
        </shadow>
        </block>
        </value>
        <next>
        <block type="comment" id="dlfZO9!sy]A{G$K%3LgU">
        <field name="COMMENT">Datenpunkt Max Verbrauch wird um </field>
        <next>
        <block type="comment" id="G7JT#a`YFY$^Z8D@[(aj">
        <field name="COMMENT">den wert cm komulativ erweitert</field>
        <next>
        <value name="x">
        </shadow>
        </block>
        </value>
        </block>
        </value>
        <next>
        <block type="comment" id="IpzJrPC/%Z]h.1cC%Rb%">
        <field name="COMMENT">Datenpunkt cm pro Tag wird um </field>
        <next>
        <block type="comment" id="mfr{3K9P[Z)cl(lf$fdO">
        <field name="COMMENT">den internen wert cm pro Tag erweitert</field>
        <next>
        <value name="NUM">
        </shadow>
        </block>
        </value>
        </block>
        </value>
        <next>
        <block type="update" id="W(KDa:5=i!wuWK%}[)9v">
        <field name="OID">Aqua_Control.0.cm_pro_Tag_count</field>
        <block type="math_round" id="UDqHQ8(*Q:mP3pndH_=`">
        <value name="NUM">
        </shadow>
        <block type="variables_get" id="g_^nhz*Y6k=+pA2.2;U:">
        </block>
        </value>
        </block>
        </value>
        <next>
                        • AphofisA Offline
                          AphofisA Offline
                          Aphofis
                          Code Teil 2:
        <block type="comment" id="YBYn$);:m{JKll-eoAq*">
        <field name="COMMENT">debug Information cm Aktuell wird geschrieben</field>
        <next>
        <value name="TEXT">
        </shadow>
        <value name="ADD0">
        <field name="TEXT">Vliesverbrauch Aktuell </field>
        </block>
        </value>
        <value name="ADD1">
        <value name="x">
        </shadow>
        </block>
        </value>
        </block>
        </value>
        <value name="ADD2">
        <block type="text" id="GJgiit^A/ocxR|R1|=Ec">
        <field name="TEXT"> cm</field>
        </block>
        </value>
        </block>
        </value>
        <next>
        <block type="comment" id="ycRu-bUF@.zKp{0$T(.x">
        <field name="COMMENT">debug Information Max Verbrauch wird geschrieben</field>
        <next>
        <value name="TEXT">
        </shadow>
        <value name="ADD0">
        <field name="TEXT">Vliesverbrauch Gesamt </field>
        </block>
        </value>
        <value name="ADD1">
        <value name="x">
        </shadow>
        </block>
        </value>
        </block>
        </value>
        <value name="ADD2">
        <block type="text" id="`?Q85d+`MK=Y/5c,(Pp#">
        </block>
        </value>
        </block>
        </value>
        <next>
        <block type="comment" id="cD*27_Y2tdw_GIyTU:Nv">
        <field name="COMMENT">Telegram Nachricht mit allen drei internen Werten</field>
        <next>
        <block type="comment" id="-L^:9Vmxh6uV*(W2t7uk">
        <next>
        <block type="telegram" id=",@Yhs5!tBj$jfQkF(0D{">
        <field name="INSTANCE">.0</field>
        <field name="LOG"></field>
        <value name="MESSAGE">
        <shadow type="text" id="$7Ei82pQ9.H~Qau_xGtl">
        </shadow>
        <block type="text_join" id="ZF0d^xTq54,5[,cG_O~^">
        <mutation items="11"></mutation>
        <value name="ADD0">
        <block type="text" id="~fGE@/olLb6IARVi5rQ0">
        </block>
        </value>
        <value name="ADD1">
        <block type="math_rndfixed" id="BX|mK)HM[k!~]pXVFWH)">
        <value name="x">
        </shadow>
        <block type="variables_get" id="-C`@AJ-i!d6s{8M}#msA">
        </block>
        </value>
        </block>
        </value>
        <value name="ADD2">
        <block type="text" id="Z]N}.Z]:$!G4#Opbd;A6">
        </block>
        </value>
        <value name="ADD3">
        <block type="text_newline" id="ml(ZU9/TVRa?B*_=V3yu">
        <field name="Type">\n</field>
        </block>
        </value>
        <value name="ADD4">
        <block type="text" id="=uXX~-{YU!^Hg7j(4g^2">
        <field name="TEXT">Vlies Tagesverbrauch </field>
        </block>
        </value>
        <value name="ADD5">
        <block type="math_rndfixed" id="8OofUBN*wRP)VlI#cP(z">
        <value name="x">
        </shadow>
        <block type="variables_get" id="2hm2SmFaEsAB5U0=G+f?">
        </block>
        </value>
        </block>
        </value>
        <value name="ADD6">
        <block type="text" id="c~Ze|7F~$iC]x[VTs=T3">
        </block>
        </value>
        <value name="ADD7">
        <block type="text_newline" id=")HorE+M1}k1cG#P4Nn_+">
        </block>
        </value>
        <value name="ADD8">
        <block type="text" id="I/X9x)QtAlGRgQI^qzLq">
        <field name="TEXT">Vliesverbrauch gesamt </field>
        </block>
        </value>
        <value name="ADD9">
        <block type="math_rndfixed" id="P;:cCx/oPZM-1^LquZ/p">
        <value name="x">
        </shadow>
        <block type="variables_get" id="yifK::$6eUEi^oGk_(q[">
        </block>
        </value>
        </block>
        </value>
        <value name="ADD10">
        <block type="text" id="!IRV9q+z,[`0#l]#ea]!">
        </block>
        </value>
        </block>
        </value>
        </block>
        </next>
        </block>
        </next>
        </block>
        </next>
        </block>
        </next>
        </block>
        </next>
        </block>
        </next>
        </block>
        </next>
        </block>
        </next>
        </block>
        </next>
        </block>
        </next>
        </block>
        </next>
        </block>
        </next>
        </block>
        </next>
        </block>
        </next>
        </block>
        </next>
        </block>
        </next>
        </block>
        </next>
        </block>
        </next>
        </block>
        </next>
        </block>
        </next>
        </block>
        </next>
        </block>
        </next>
        </block>
                                                              </next>
                                                            </block>
                                                          </next>
                                                        </block>
                                                      </next>
                                                    </block>
                                                  </next>
                                                </block>
                                              </statement>
                                            </block>
                                          </statement>
                                          <next>
                                            <block type="comment" id="[*LdX;p+0u?!x)JR`Tuu">
                                              <field name="COMMENT">Datenpunkt wie interner Wert vom Tagesverbrauch</field>
                                              <next>
                                                <block type="comment" id="rgm3:XiS;abWA[JD$V![">
                                                  <field name="COMMENT">werden alle 24 Std. zurückgesetzt</field>
                                                  <next>
                                                        <block type="comment" id="RYsm.L_lmjBfK5|Rw]Vl">
                                                          <field name="COMMENT">cm pro Tag intern wird auf null gesetzt</field>
                                                          <next>
        </block>
                                                              </value>
                                                              <next>
        <block type="comment" id="oj#8:ul0P~=_t/o$:i57">
        <field name="COMMENT">Datenpunkt cm pro Tag wird auf null gesetzt</field>
        <next>
        <field name="OID">Aqua_Control.0.ml_pro_Tag</field>
        </block>
        </value>
        </block>
        </next>
        </block>
                                                              </next>
                                                            </block>
                                                          </next>
                                                        </block>
                                                      </statement>
                                                    </block>
                                                  </next>
                                                </block>
                                              </next>
                                            </block>
                                          </next>
                                        </block>
                                      </next>
                                    </block>
                                  </next>
                                </block>
                              </next>
                            </block>
                          </xml>
                          • AphofisA Offline
                            AphofisA Offline
                            Aphofis
                            ist es möglich Osmose_Max den Wert manuell intern zu setzen?
                            Da ich mist gebaut habe und der zähler wieder von vorne anfängt !?
                            Weil wenn ich den Wert im Datenpunkt korrigiere wird er beim nachsten Pumpen wieder zurück auf Anfang gesetzt.
                            woher bekommt ml_komulativ den Wert wenn nicht aus dem Datenpunkt!?
                            • AphofisA Aphofis
                              @Aphofis sagte:
                              Du kannst den Wert manuell korrigieren und anschließend das Skript neu starten, damit der Wert in die Variable übernommen wird.
                                @Aphofis sagte:
                                AphofisA Offline
                                AphofisA Offline
                                Aphofis
                                ok i will try
                                • AphofisA Offline
                                  AphofisA Offline
                                  Aphofis
                                  Du bist ne Wucht !!! Auch wenns einfach ist, muss man sowas erstmal wissen.
                                  Es hat geklappt, beim Vlies und beim Osmose Verbrauch. Danke
                                  Daten werden auch alle fleißig in der Datenbank geloggt.
                                  Nur werden auch werte mit Wert - null - geloggt, das natürlich nicht so schön und dazu kommt noch das mein Flot Adapter nicht funktioniert. Hab schon Flot deinstalliert ob über iobroker und über ssh und auch über beide Wege neu installiert! keine Chance.
                                  Wenn ich Flot aufrufen will, kommt eine Fehler Meldung auf dem neuen Tab:
                                  File edit.html not found: permissionError
                                  Wenn ich mir die Charts angucken will in einem Datenpunkt von dem sql Adapter kommt keine Grafik.
                                  Hab schon überall im Netz nach dem Fehler gesucht, doch leider kein Erfolg.
                                  • AphofisA Aphofis
                                    @Aphofis sagte:
                                    Wenn ich Flot aufrufen will, kommt eine Fehler Meldung auf dem neuen Tab: File edit.html not found: permissionError
                                    Mache dazu besser ein neues Thema auf, denn es geht in diesem Thema hier unter.
                                    Bitte noch die Überschrift um [gelöst] ergänzen.
                                    • AphofisA Offline
                                      AphofisA Offline
                                      Aphofis
                                      Na klar mach ich das ! Wollte dir nur den Stand der Dinge mitteilen.
                                      • AphofisA Offline
                                        AphofisA Offline
                                        Aphofis
                                        Kannst du mir einen Riesen gefallen tun und mal drüber gucken
                                        Beide Steuerungen für Vlies Verbrauch in cm und osmose Verbrauch in ml spinnen.
                                        Ich habe neue datenpunkte angelegt in datenpunkt Ordnern und in den Steuerungen alles sauber neu verknüpft.
                                        Doch nach dem ich beide Steuerungen eingeschaltet hatte, und Osmose oder Vlies läuft
                                        Wird cm_Max auf den Wert von cm_Aktuell gestellt und cm_pro_Tag cm_pro_Tag_count werden aufgerundet auf den cm_Aktuell wert.
                                        Da stimmt was nicht und ich verstehe es nicht.
                                        Hab schon beide Steuerungen mehrfach kontrolliert und deaktiviert, werte manuell geändert Scripte gestartet und immer wieder werden die Werte nicht ergänzt sondern mit dem falschen Wert aktualisiert.
                                        Das wäre sehr nett wenn du mir helfen könntest.
                                        var cm_pro_Tag, cm_komulativ, Differenz, cm_Aktuell;
                                        cm_pro_Tag = getState("Aqua_Control.0.Vliesfilter.cm_pro_Tag").val;
                                        cm_komulativ = getState("Aqua_Control.0.Vliesfilter.cm_Max").val;
                                        on({id: 'rpi2.0.gpio.20.state', change: "ne"}, function (obj) {
                                          var value = obj.state.val;
                                          if (!(obj.state ? obj.state.val : "")) {
                                            Differenz = (obj.state ? obj.state.lc : "") - (obj.oldState ? obj.oldState.lc : "");
                                            cm_Aktuell = Differenz * getState("Aqua_Control.0.Vliesfilter.cm_multiplikator").val;
                                            setState("Aqua_Control.0.Vliesfilter.cm_Aktuell"/*cm_Aktuell*/, Math.round(cm_Aktuell*100)/100, true);
                                            cm_komulativ = (typeof cm_komulativ == 'number' ? cm_komulativ : 0) + cm_Aktuell;
                                            cm_pro_Tag = (typeof cm_pro_Tag == 'number' ? cm_pro_Tag : 0) + cm_Aktuell;
                                            setState("Aqua_Control.0.Vliesfilter.cm_Max"/*cm_Max*/, Math.round(cm_komulativ*100)/100, true);
                                            setState("Aqua_Control.0.Vliesfilter.cm_pro_Tag"/*cm_pro_Tag*/, (Math.round(cm_pro_Tag)), true);
                                            setState("Aqua_Control.0.Vliesfilter.cm_pro_Tag_count"/*cm_pro_Tag_count*/, (Math.round(cm_pro_Tag)), true);
                                            sendTo("telegram.0", "send", {
                                                text: (['Vliesverbrauch Aktuell ',Math.round(getState("Aqua_Control.0.Vliesfilter.cm_Aktuell").val*100)/100,' cm','\n','Vlies Tagesverbrauch ',Math.round(getState("Aqua_Control.0.Vliesfilter.cm_pro_Tag").val*100)/100,' cm','\n','Vliesverbrauch gesamt ',Math.round((getState("Aqua_Control.0.Vliesfilter.cm_Max").val / 100)*100)/100,' Meter'].join(''))
                                            console.log((['Vliesverbrauch Aktuell ',Math.round(getState("Aqua_Control.0.Vliesfilter.cm_Aktuell").val*100)/100,' cm'].join('')));
                                            console.log((['Vliesverbrauch Gesamt ',Math.round((getState("Aqua_Control.0.Vliesfilter.cm_Max").val / 100)*100)/100,'  cm'].join('')));
                                        schedule("0 0 * * *", function () {
                                          cm_pro_Tag = 0;
                                          setState("Aqua_Control.0.Vliesfilter.cm_pro_Tag"/*cm_pro_Tag*/, 0, true);
                                          setState("Aqua_Control.0.Vliesfilter.cm_pro_Tag_count"/*cm_pro_Tag_count*/, 0, true);
                                        Und noch komischer ist, in telegram werden die richtigen Werte angezeigt. Hatte auch mal unter Objekte den Experten Modus eingeschaltet nicht das die alten datenpunkte noch da sind aber sind sie nicht das da irgendwas durcheinander gekommen ist.
                                        • AphofisA Aphofis
                                            cm_pro_Tag = 0;
                                          @Aphofis
                                          Was ist der Unterschied zwischen "cm_pro_Tag" und "cm_pro_Tag_count" ? Ich kann keinen Unterschied erkennen.
                                          Für Telegram und Log verwende die Variablen cm_Aktuell, cm_komulativ und cm_pro_Tag, denn das Einlesen der Datenpunkte liefert einen veralteten Wert vom vorherigen Trigger.
