  5. [gelöst] Osmose Wasser Aktuell & Max Verbrauch
    5.6k
79 Beiträge 2 Kommentatoren 4.6k Aufrufe 1 Beobachtet
  • AphofisA Offline
    AphofisA Offline
    Aphofis
    Der Code dazu Teil 1
      <variables>
        <variable type="" id="V]/%u4JGSoxh-Al{eT.g">cm_pro_Tag</variable>
        <variable type="" id="ihvas_{d.kg4gRlA_SmF">cm_komulativ</variable>
        <variable type="" id="n:v;eT@?L%cbL{M}xt_E">Differenz</variable>
        <variable type="" id="ckVaiUkVWNw*nrHYt1ho">cm_Aktuell</variable>
      </variables>
      <block type="variables_set" id="J.74*3iWof~,6Kx}~#T," x="-487" y="-87">
        <field name="VAR" id="V]/%u4JGSoxh-Al{eT.g" variabletype="">cm_pro_Tag</field>
        <value name="VALUE">
          <block type="get_value" id="!`-7w4Ob%M?7ztU!UD!8">
            <field name="OID">Aqua_Control.0.cm_pro_Tag</field>
          </block>
        </value>
        <next>
          <block type="variables_set" id="r9eO:=nj*R8[_VP#N.B#">
            <field name="VAR" id="ihvas_{d.kg4gRlA_SmF" variabletype="">cm_komulativ</field>
              <block type="get_value" id="o`iB.H?7RH[)vaB~x33:">
                <field name="OID">Aqua_Control.0.cm_Max</field>
              </block>
            </value>
            <next>
              <block type="comment" id="5_dAu$u@jE|TAgl|;,XY">
                <field name="COMMENT">Magnetventil</field>
                <next>
                  <block type="on_ext" id=":Nr`7Jva*j~6F*k.h/^F">
                    <mutation items="1"></mutation>
                    <value name="OID0">
                      <shadow type="field_oid" id="eXd?Hfx6K/{9#D2So~zg">
                        <field name="oid">rpi2.0.gpio.13.state</field>
                      </shadow>
                    </value>
                    <statement name="STATEMENT">
                      <block type="controls_if" id=",3lQx[D^fe0|wZv07i:F">
                        <value name="IF0">
                          <block type="logic_negate" id="5YH|]f]Y8q~OZzn6dp~c">
                            <value name="BOOL">
                              <block type="on_source" id="7V.$(3ehpmvx4I8d18aw">
                              </block>
                            </value>
                          </block>
                        </value>
                        <statement name="DO0">
                          <block type="comment" id="0_SP-:jo/~zs;Y(enH9B">
                            <field name="COMMENT">1.1.1970 bis wert aktiv minus aktuelle zeit</field>
                            <next>
                              <block type="variables_set" id="72%z_H5G5)(I?g,6w}y4">
                                <field name="VAR" id="n:v;eT@?L%cbL{M}xt_E" variabletype="">Differenz</field>
                                  <block type="math_arithmetic" id="hbDOS/*?OV7f*;K%5]/B">
                                    <value name="A">
                                      <shadow type="math_number" id="1qz=5}09VW70aU;#1XFo">
                                        <field name="NUM">1</field>
                                      </shadow>
                                      <block type="on_source" id="vRHoi8S{X(;fi6|?CNdR">
                                        <field name="ATTR">state.lc</field>
                                      </block>
                                    </value>
                                    <value name="B">
                                      <shadow type="math_number" id="igjc3(uZ:S);a(CB+~6G">
                                      </shadow>
                                      <block type="on_source" id="4o,`J,IU$mwUfG~ldTcS">
                                        <field name="ATTR">oldState.lc</field>
                                      </block>
                                    </value>
                                  </block>
                                </value>
                                <next>
                                  <block type="comment" id="biINHf0{3Ed{bF)P{V].">
                                    <field name="COMMENT">gemessene Zeit mal multiplikator um cm zu erlangen</field>
                                    <next>
                                      <block type="variables_set" id="m=_{N_=!`*U)%~+=6k)M">
                                        <field name="VAR" id="ckVaiUkVWNw*nrHYt1ho" variabletype="">cm_Aktuell</field>
                                          <block type="math_arithmetic" id="4kRl.?`8|Mh3F%NpuU)o">
                                            <field name="OP">MULTIPLY</field>
                                            <value name="A">
                                              </shadow>
                                              <block type="variables_get" id="Mhz6a_f|)g9t_NoX-J4o">
                                              </block>
                                            </value>
                                            <value name="B">
                                              </shadow>
                                              <block type="get_value" id="JvRB[I?w$,K)uyI4f^bs">
                                                <field name="OID">Aqua_Control.0.cm_multiplikator</field>
                                              </block>
                                            </value>
                                          </block>
                                        </value>
                                        <next>
                                          <block type="comment" id="-qlvZlbKsCcmbXA9[|dQ">
                                            <field name="COMMENT">Datenpunkt cm Aktuell wird mit intern </field>
                                            <next>
                                              <block type="comment" id="=TI;v|K0P/XkMYJe@(7t">
                                                <field name="COMMENT">cm Aktuell aktualisiert</field>
                                                <next>
                                                  <block type="update" id="$L)rekVx6$I,%e;4apgW">
                                                    <mutation delay_input="false"></mutation>
                                                    <field name="OID">Aqua_Control.0.cm_Aktuell</field>
                                                      <block type="math_rndfixed" id="`T$g_{-$PLe-SSBp~eRc">
                                                        <field name="n">2</field>
                                                        <value name="x">
                                                          <shadow type="math_number" id="+-xoJC%#+sANg_OJ={H8">
                                                            <field name="NUM">3.1234</field>
                                                          </shadow>
                                                          <block type="variables_get" id="f0]0D7lYkKvj8_p~z.%d">
                                                          </block>
                                                        </value>
                                                      </block>
                                                    </value>
                                                    <next>
                                                      <block type="comment" id="8a~s%M,NvYZjsSVhP.Ud">
                                                        <field name="COMMENT">Gesamtverbrauch intern wird derm aktuell </field>
                                                        <next>
                                                          <block type="comment" id="vk3Hj5QI)t6bELlMM-PT">
                                                            <field name="COMMENT">gemessenem internen Wert dazu addiert</field>
                                                            <next>
                                                              <block type="math_change" id="i##pC}m@FZYhZ+UJ#P?b">
        <value name="DELTA">
        <shadow type="math_number" id="rjS|:BdoUJX*N=n`Ji[]">
        </shadow>
        <block type="variables_get" id="CpXbPP;H9nIQMrU;Uq)1">
        </block>
        </value>
        <next>
        <block type="comment" id="w6gH[QW1DueK!oW_i)jC">
        <field name="COMMENT">aktueller interner Wert wird zum Tagesverbrauch</field>
        <next>
        <block type="comment" id="U(z%AO%43jU$y9N,z+58">
        <field name="COMMENT">intern dazu addiert</field>
        <next>
        <block type="math_change" id="{qy46Yh1+,z@=wazF=Sa">
        <shadow type="math_number" id=":iELaSM8MUE{v_j{wKtM">
        </shadow>
        <block type="variables_get" id="Uln@f]L*.73;Q))();nx">
        </block>
        </value>
        <next>
        <block type="comment" id="dlfZO9!sy]A{G$K%3LgU">
        <field name="COMMENT">Datenpunkt Max Verbrauch wird um </field>
        <next>
        <block type="comment" id="G7JT#a`YFY$^Z8D@[(aj">
        <field name="COMMENT">den wert cm komulativ erweitert</field>
        <next>
        <block type="update" id="Aoq8WBDY@Hokp`)m4/4X">
        <block type="math_rndfixed" id="OzOc$JV79+l5~%[*Ls3q">
        <value name="x">
        </shadow>
        <block type="variables_get" id="BspaT@-^5ZEI+SkZI[Mk">
        </block>
        </value>
        </block>
        </value>
        <next>
        <block type="comment" id="IpzJrPC/%Z]h.1cC%Rb%">
        <field name="COMMENT">Datenpunkt cm pro Tag wird um </field>
        <next>
        <block type="comment" id="mfr{3K9P[Z)cl(lf$fdO">
        <field name="COMMENT">den internen wert cm pro Tag erweitert</field>
        <next>
        <block type="update" id="@DXH()Q[2XD)B|wzZ3,1">
        <block type="math_round" id="0:*{$@p/*@-:+y#dr$zh">
        <field name="OP">ROUND</field>
        <value name="NUM">
        <shadow type="math_number" id="@}^3%9A.jmf{F%7.Li8b">
        <field name="NUM">3.1</field>
        </shadow>
        <block type="variables_get" id="QCo;X6-+|)pOF#Zl*cIe">
        </block>
        </value>
        </block>
        </value>
        <next>
        <block type="update" id="W(KDa:5=i!wuWK%}[)9v">
        <field name="OID">Aqua_Control.0.cm_pro_Tag_count</field>
        <block type="math_round" id="UDqHQ8(*Q:mP3pndH_=`">
        <value name="NUM">
        </shadow>
        <block type="variables_get" id="g_^nhz*Y6k=+pA2.2;U:">
        </block>
        </value>
        </block>
        </value>
        <next>
    • AphofisA Offline
      AphofisA Offline
      Aphofis
      Code Teil 2:
        <block type="comment" id="YBYn$);:m{JKll-eoAq*">
        <field name="COMMENT">debug Information cm Aktuell wird geschrieben</field>
        <next>
        <block type="debug" id=";-vf26IOUB^od6zf#o6s">
        <value name="TEXT">
        <shadow type="text" id=".;Y[}a(8N_h0U)l?C.9:">
        </shadow>
        <block type="text_join" id="8!r$|^=,t[#JNZLQx94j">
        <value name="ADD0">
        <block type="text" id="r;GezYi}HE=H%]vDDLw4">
        <field name="TEXT">Vliesverbrauch Aktuell </field>
        </block>
        </value>
        <value name="ADD1">
        <block type="math_rndfixed" id="61m!Va3FI+*)OeaUc!J]">
        <value name="x">
        </shadow>
        <block type="variables_get" id="jlT*`^NkkJGXF1HToYGY">
        </block>
        </value>
        </block>
        </value>
        <value name="ADD2">
        <block type="text" id="GJgiit^A/ocxR|R1|=Ec">
        <field name="TEXT"> cm</field>
        </block>
        </value>
        </block>
        </value>
        <next>
        <block type="comment" id="ycRu-bUF@.zKp{0$T(.x">
        <field name="COMMENT">debug Information Max Verbrauch wird geschrieben</field>
        <next>
        <block type="debug" id="HTt5R[I*-hwd.gKyl0{{">
        <value name="TEXT">
        </shadow>
        <block type="text_join" id="FErg(6m]tZt5$=?8Ut5^">
        <value name="ADD0">
        <block type="text" id="h|=sT+)M-v/mq%hrnL5a">
        <field name="TEXT">Vliesverbrauch Gesamt </field>
        </block>
        </value>
        <value name="ADD1">
        <block type="math_rndfixed" id="8J1lCb1g%$wdUkP,-#l|">
        <value name="x">
        </shadow>
        <block type="variables_get" id="hm55C@pg}Ti[rjK+,]k|">
        </block>
        </value>
        </block>
        </value>
        <value name="ADD2">
        <block type="text" id="`?Q85d+`MK=Y/5c,(Pp#">
        </block>
        </value>
        </block>
        </value>
        <next>
        <block type="comment" id="cD*27_Y2tdw_GIyTU:Nv">
        <field name="COMMENT">Telegram Nachricht mit allen drei internen Werten</field>
        <next>
        <block type="comment" id="-L^:9Vmxh6uV*(W2t7uk">
        <next>
        <block type="telegram" id=",@Yhs5!tBj$jfQkF(0D{">
        <field name="INSTANCE">.0</field>
        <field name="LOG"></field>
        <value name="MESSAGE">
        <shadow type="text" id="$7Ei82pQ9.H~Qau_xGtl">
        </shadow>
        <block type="text_join" id="ZF0d^xTq54,5[,cG_O~^">
        <mutation items="11"></mutation>
        <value name="ADD0">
        <block type="text" id="~fGE@/olLb6IARVi5rQ0">
        </block>
        </value>
        <value name="ADD1">
        <block type="math_rndfixed" id="BX|mK)HM[k!~]pXVFWH)">
        <value name="x">
        </shadow>
        <block type="variables_get" id="-C`@AJ-i!d6s{8M}#msA">
        </block>
        </value>
        </block>
        </value>
        <value name="ADD2">
        <block type="text" id="Z]N}.Z]:$!G4#Opbd;A6">
        </block>
        </value>
        <value name="ADD3">
        <block type="text_newline" id="ml(ZU9/TVRa?B*_=V3yu">
        <field name="Type">\n</field>
        </block>
        </value>
        <value name="ADD4">
        <block type="text" id="=uXX~-{YU!^Hg7j(4g^2">
        <field name="TEXT">Vlies Tagesverbrauch </field>
        </block>
        </value>
        <value name="ADD5">
        <block type="math_rndfixed" id="8OofUBN*wRP)VlI#cP(z">
        <value name="x">
        </shadow>
        <block type="variables_get" id="2hm2SmFaEsAB5U0=G+f?">
        </block>
        </value>
        </block>
        </value>
        <value name="ADD6">
        <block type="text" id="c~Ze|7F~$iC]x[VTs=T3">
        </block>
        </value>
        <value name="ADD7">
        <block type="text_newline" id=")HorE+M1}k1cG#P4Nn_+">
        </block>
        </value>
        <value name="ADD8">
        <block type="text" id="I/X9x)QtAlGRgQI^qzLq">
        <field name="TEXT">Vliesverbrauch gesamt </field>
        </block>
        </value>
        <value name="ADD9">
        <block type="math_rndfixed" id="P;:cCx/oPZM-1^LquZ/p">
        <value name="x">
        </shadow>
        <block type="variables_get" id="yifK::$6eUEi^oGk_(q[">
        </block>
        </value>
        </block>
        </value>
        <value name="ADD10">
        <block type="text" id="!IRV9q+z,[`0#l]#ea]!">
        </block>
        </value>
        </block>
        </value>
        </block>
        </next>
        </block>
        </next>
        </block>
        </next>
        </block>
        </next>
        </block>
        </next>
        </block>
        </next>
        </block>
        </next>
        </block>
        </next>
        </block>
        </next>
        </block>
        </next>
        </block>
        </next>
        </block>
        </next>
        </block>
        </next>
        </block>
        </next>
        </block>
        </next>
        </block>
        </next>
        </block>
        </next>
        </block>
                                                              </next>
                                                            </block>
                                                          </next>
                                                        </block>
                                                      </next>
                                                    </block>
                                                  </next>
                                                </block>
                                              </next>
                                            </block>
                                          </next>
                                        </block>
                                      </next>
                                    </block>
                                  </next>
                                </block>
                              </next>
                            </block>
                          </statement>
                        </block>
                      </statement>
                      <next>
                        <block type="comment" id="[*LdX;p+0u?!x)JR`Tuu">
                          <field name="COMMENT">Datenpunkt wie interner Wert vom Tagesverbrauch</field>
                          <next>
                            <block type="comment" id="rgm3:XiS;abWA[JD$V![">
                              <field name="COMMENT">werden alle 24 Std. zurückgesetzt</field>
                              <next>
                                <block type="schedule" id="@{?t*Kbp)#F%kZ.QV7-P">
                                  <field name="SCHEDULE">0 0 * * *</field>
                                    <block type="comment" id="RYsm.L_lmjBfK5|Rw]Vl">
                                      <field name="COMMENT">cm pro Tag intern wird auf null gesetzt</field>
                                      <next>
                                        <block type="variables_set" id="]hBT|HYa,^+;/_URpFpc">
                                            <block type="math_number" id="/3j~a_2+DU]a%4W0RpQ(">
                                              <field name="NUM">0</field>
                                            </block>
                                          </value>
                                          <next>
                                            <block type="comment" id="oj#8:ul0P~=_t/o$:i57">
                                              <field name="COMMENT">Datenpunkt cm pro Tag wird auf null gesetzt</field>
                                              <next>
                                                <block type="update" id=",5mG65Imrygz=PxUUDZ:">
                                                  <field name="OID">Aqua_Control.0.ml_pro_Tag</field>
                                                    <block type="math_number" id="IEw|b8lc[)=9`zq5COIW">
                                                    </block>
                                                  </value>
                                                </block>
                                              </next>
                                            </block>
                                          </next>
                                        </block>
                                      </next>
                                    </block>
                                  </statement>
                                </block>
                              </next>
                            </block>
                          </next>
                        </block>
                      </next>
                    </block>
                  </next>
                </block>
              </next>
            </block>
          </next>
        </block>
      </xml>
      • AphofisA Offline
        AphofisA Offline
        Aphofis
        schrieb am zuletzt editiert von Aphofis
        ist es möglich Osmose_Max den Wert manuell intern zu setzen?
        Da ich mist gebaut habe und der zähler wieder von vorne anfängt !?
        Weil wenn ich den Wert im Datenpunkt korrigiere wird er beim nachsten Pumpen wieder zurück auf Anfang gesetzt.
        woher bekommt ml_komulativ den Wert wenn nicht aus dem Datenpunkt!?
        • AphofisA Aphofis
          @Aphofis sagte:
          Du kannst den Wert manuell korrigieren und anschließend das Skript neu starten, damit der Wert in die Variable übernommen wird.
          AphofisA 1 Antwort Letzte Antwort
            @Aphofis sagte:
            AphofisA Offline
            AphofisA Offline
            Aphofis
            ok i will try
            • AphofisA Offline
              AphofisA Offline
              Aphofis
              Du bist ne Wucht !!! Auch wenns einfach ist, muss man sowas erstmal wissen.
              Es hat geklappt, beim Vlies und beim Osmose Verbrauch. Danke
              Daten werden auch alle fleißig in der Datenbank geloggt.
              Nur werden auch werte mit Wert - null - geloggt, das natürlich nicht so schön und dazu kommt noch das mein Flot Adapter nicht funktioniert. Hab schon Flot deinstalliert ob über iobroker und über ssh und auch über beide Wege neu installiert! keine Chance.
              Wenn ich Flot aufrufen will, kommt eine Fehler Meldung auf dem neuen Tab:
              File edit.html not found: permissionError
              Wenn ich mir die Charts angucken will in einem Datenpunkt von dem sql Adapter kommt keine Grafik.
              Hab schon überall im Netz nach dem Fehler gesucht, doch leider kein Erfolg.
              • AphofisA Aphofis
                @Aphofis sagte:
                Wenn ich Flot aufrufen will, kommt eine Fehler Meldung auf dem neuen Tab: File edit.html not found: permissionError
                Mache dazu besser ein neues Thema auf, denn es geht in diesem Thema hier unter.
                Bitte noch die Überschrift um [gelöst] ergänzen.
                • AphofisA Offline
                  AphofisA Offline
                  Aphofis
                  Na klar mach ich das ! Wollte dir nur den Stand der Dinge mitteilen.
                  • AphofisA Offline
                    AphofisA Offline
                    Aphofis
                    Kannst du mir einen Riesen gefallen tun und mal drüber gucken
                    Beide Steuerungen für Vlies Verbrauch in cm und osmose Verbrauch in ml spinnen.
                    Ich habe neue datenpunkte angelegt in datenpunkt Ordnern und in den Steuerungen alles sauber neu verknüpft.
                    Doch nach dem ich beide Steuerungen eingeschaltet hatte, und Osmose oder Vlies läuft
                    Wird cm_Max auf den Wert von cm_Aktuell gestellt und cm_pro_Tag cm_pro_Tag_count werden aufgerundet auf den cm_Aktuell wert.
                    Da stimmt was nicht und ich verstehe es nicht.
                    Hab schon beide Steuerungen mehrfach kontrolliert und deaktiviert, werte manuell geändert Scripte gestartet und immer wieder werden die Werte nicht ergänzt sondern mit dem falschen Wert aktualisiert.
                    Das wäre sehr nett wenn du mir helfen könntest.
                    var cm_pro_Tag, cm_komulativ, Differenz, cm_Aktuell;
                    cm_pro_Tag = getState("Aqua_Control.0.Vliesfilter.cm_pro_Tag").val;
                    cm_komulativ = getState("Aqua_Control.0.Vliesfilter.cm_Max").val;
                    on({id: 'rpi2.0.gpio.20.state', change: "ne"}, function (obj) {
                      var value = obj.state.val;
                      if (!(obj.state ? obj.state.val : "")) {
                        Differenz = (obj.state ? obj.state.lc : "") - (obj.oldState ? obj.oldState.lc : "");
                        cm_Aktuell = Differenz * getState("Aqua_Control.0.Vliesfilter.cm_multiplikator").val;
                        setState("Aqua_Control.0.Vliesfilter.cm_Aktuell"/*cm_Aktuell*/, Math.round(cm_Aktuell*100)/100, true);
                        cm_komulativ = (typeof cm_komulativ == 'number' ? cm_komulativ : 0) + cm_Aktuell;
                        cm_pro_Tag = (typeof cm_pro_Tag == 'number' ? cm_pro_Tag : 0) + cm_Aktuell;
                        setState("Aqua_Control.0.Vliesfilter.cm_Max"/*cm_Max*/, Math.round(cm_komulativ*100)/100, true);
                        setState("Aqua_Control.0.Vliesfilter.cm_pro_Tag"/*cm_pro_Tag*/, (Math.round(cm_pro_Tag)), true);
                        setState("Aqua_Control.0.Vliesfilter.cm_pro_Tag_count"/*cm_pro_Tag_count*/, (Math.round(cm_pro_Tag)), true);
                        sendTo("telegram.0", "send", {
                            text: (['Vliesverbrauch Aktuell ',Math.round(getState("Aqua_Control.0.Vliesfilter.cm_Aktuell").val*100)/100,' cm','\n','Vlies Tagesverbrauch ',Math.round(getState("Aqua_Control.0.Vliesfilter.cm_pro_Tag").val*100)/100,' cm','\n','Vliesverbrauch gesamt ',Math.round((getState("Aqua_Control.0.Vliesfilter.cm_Max").val / 100)*100)/100,' Meter'].join(''))
                        console.log((['Vliesverbrauch Aktuell ',Math.round(getState("Aqua_Control.0.Vliesfilter.cm_Aktuell").val*100)/100,' cm'].join('')));
                        console.log((['Vliesverbrauch Gesamt ',Math.round((getState("Aqua_Control.0.Vliesfilter.cm_Max").val / 100)*100)/100,'  cm'].join('')));
                    schedule("0 0 * * *", function () {
                      cm_pro_Tag = 0;
                      setState("Aqua_Control.0.Vliesfilter.cm_pro_Tag"/*cm_pro_Tag*/, 0, true);
                      setState("Aqua_Control.0.Vliesfilter.cm_pro_Tag_count"/*cm_pro_Tag_count*/, 0, true);
                    Und noch komischer ist, in telegram werden die richtigen Werte angezeigt. Hatte auch mal unter Objekte den Experten Modus eingeschaltet nicht das die alten datenpunkte noch da sind aber sind sie nicht das da irgendwas durcheinander gekommen ist.
                    • AphofisA Aphofis
                        cm_pro_Tag = 0;
                      @Aphofis
                      Was ist der Unterschied zwischen "cm_pro_Tag" und "cm_pro_Tag_count" ? Ich kann keinen Unterschied erkennen.
                      Für Telegram und Log verwende die Variablen cm_Aktuell, cm_komulativ und cm_pro_Tag, denn das Einlesen der Datenpunkte liefert einen veralteten Wert vom vorherigen Trigger.
                        @Aphofis
                        AphofisA Offline
                        AphofisA Offline
                        Aphofis
                        count war eigntl gedacht um zu zählen wie oft bzw wie lange osmose oder der vlies filter am tag läuft also wie lange auf true stand und wie oft true an war.
                        dH. ich muss count raus nehmen !?
                        Die werte kommen doch aus den Datenpunkten doch wenn ich die beiden scripte stoppe dann die Daten in den Datenpunkten so einstelle wie es gehört und die Scripte wieder starte schmeissen beide die Daten raus bei max und bei tages verbrauch.
                        • AphofisA Offline
                          AphofisA Offline
                          Aphofis
                          Vliesverbrauch sieht dann so aus:
                            cm_pro_Tag = 0;
                          Osmose Verbrauch:
                          var ml_pro_Tag, ml_Kumulativ, Differenz, ml_Aktuell;
                          ml_pro_Tag = getState("Aqua_Control.0.Osmose_System.ml_pro_Tag").val;
                          ml_Kumulativ = getState("Aqua_Control.0.Osmose_System.Osmose_Max").val;
                          // Magnetventil
                          on({id: 'rpi2.0.gpio.21.state', change: "ne"}, function (obj) {
                              ml_Aktuell = Differenz * getState("Aqua_Control.0.Osmose_System.ml_multiplikator").val;
                              setState("Aqua_Control.0.Osmose_System.Osmose_Aktuell"/*Osmose_Aktuell*/, Math.round(ml_Aktuell*100)/100, true);
                              ml_Kumulativ = (typeof ml_Kumulativ == 'number' ? ml_Kumulativ : 0) + ml_Aktuell;
                              ml_pro_Tag = (typeof ml_pro_Tag == 'number' ? ml_pro_Tag : 0) + ml_Aktuell;
                              setState("Aqua_Control.0.Osmose_System.Osmose_Max"/*Osmose_Max*/, Math.round(ml_Kumulativ*100)/100, true);
                              setState("Aqua_Control.0.Osmose_System.Osmose_Gesamtverbrauch"/*Osmose_Gesamtverbrauch*/, Math.round((ml_Kumulativ / 1000)*1000)/1000, true);
                              setState("Aqua_Control.0.Osmose_System.ml_pro_Tag"/*ml_pro_Tag*/, (Math.round(ml_pro_Tag)), true);
                              console.log((['Dosierung aktuell ',Math.round(ml_Aktuell),' ml'].join('')));
                              console.log((['Dosierung Gesamt ',Math.round((ml_Kumulativ / parseFloat(1000))*1000)/1000,' Liter'].join('')));
                                  text: (['Osmose Dosierung aktuell ',Math.round(getState("Aqua_Control.0.Osmose_System.Osmose_Aktuell").val),' ml','\n','Osmose Tages Dosierung ',Math.round((getState("Aqua_Control.0.Osmose_System.ml_pro_Tag").val / 1000)*100)/100,' Liter','\n','Osmose Gesamtverbrauch ',Math.round(getState("Aqua_Control.0.Osmose_System.Osmose_Gesamtverbrauch").val),' Liter'].join(''))
                            ml_pro_Tag = 0;
                            setState("Aqua_Control.0.Osmose_System.ml_pro_Tag"/*ml_pro_Tag*/, 0, true);
                          wäre es dann so korrekt und die steuerungen nehmen beim starten die werte aus den datenpunkten ?
                          • AphofisA Offline
                            AphofisA Offline
                            Aphofis
                            Ich habe jetzt ml_pr_Tag_count und cm_pro_Tag_count raus geschmissen aus den steuerungen und zum testen nicht das magnet ventil oder den vlies motor manuell betätigt sondern die beiden schwimmer und siehe da, es funktioniert wieder.
                            Was ich nur nicht verstehe wieso ging es die ganze Zeit und jetzt nicht mehr.
                            Kann es mit den neu angelegten und neu verknüpften Datenpunkten zu tun haben !?
                            Hatte ja vorher alle scripte gestoppt und dann die datenpunkt änderungen vorgenommen.
                            Da ja noch reichlich Steuerungen dazu kommen musste ich aufräumen.
                            Sonst wird es nachher ein unübersichtlicher Haufen Datenpunkte.
                            Dazu kommen noch zwei TDS ppm Meter dann eine Leitwert Sonde, eine PH Sonde und wenns klappt die Steuerung Zeitgesteuert zu dem Tunze Controller senden.
                            • AphofisA Aphofis
                              @Aphofis
                              Wandle am Besten den Wert vom Multiplikator nach Zahl, weil auch ein String in den Datenpunkt gelangen kann. Also:
                              setze Aktuell auf Differenz * nach Zahl Wert vom Multiplikator
                                @Aphofis
                                AphofisA Offline
                                AphofisA Offline
                                Aphofis
                                Meinst du so:
                                • AphofisA Aphofis
                                  Meinst du so:
                                  @Aphofis sagte:
                                  Meinst du so:
                                  Ja.
                                  • AphofisA Offline
                                    AphofisA Offline
                                    Aphofis
                                    OK, dann hoffe ich, das jetzt alles reibungslos läuft.
                                    • AphofisA Offline
                                      AphofisA Offline
                                      Aphofis
                                      Bis jetzt scheinen beide Steuerungen endlich wieder das zu tun was sie sollen.
                                      Sie zählen fleißig. 😊
                                      • AphofisA Offline
                                        AphofisA Offline
                                        Aphofis
                                        Bis auf Osmose Verbrauch, die Verbrauchssteuerung haut manchmal komische werte rein.
                                        Es werden normal immer so 50-300 ml dosiert am stück und manchmal steht dann in der aktuellen dosierung 4000ml aufwärts aber auch nur zwischendurch.
                                        Woran kann das liegen !?
                                        // Magnetventil
                                            ml_Aktuell = Differenz * parseFloat(getState("Aqua_Control.0.Osmose_System.ml_multiplikator").val);
                                          ml_pro_Tag = 0;
                                        • AphofisA Aphofis
                                          // Magnetventil
                                            ml_pro_Tag = 0;
                                          @Aphofis sagte:
                                          Nicht am Skript, denn im Skript passieren keine zufälligen Sachen.
                                          Hast Du den Datenpunkt 'rpi2.0.gpio.21.state' historisiert ? Falls nicht, solltest Du es machen.
