  4. Problem mit ioBroker Sma-em Adapter nach node update
problem mit node 10.16
23 Beiträge 8 Kommentatoren 3.4k Aufrufe 5 Beobachtet
  • WinniW Winni
    @apollon77 vielen Dank für die schnelle Hilfe, nach der Korrektur läuft es unter 8.17 aber leider nicht unter 10.18 :(
    da bleibt der Adapter rot und der Log schaut es so aus:
    host.winni-NUC6CAYH	2020-01-05 13:42:03.970	error	Caught by controller[0]: at UDP.onMessage [as onmessage] (dgram.js:628:8)
    host.winni-NUC6CAYH	2020-01-05 13:42:03.970	error	Caught by controller[0]: at Socket.emit (events.js:198:13)
    host.winni-NUC6CAYH	2020-01-05 13:42:03.969	error	Caught by controller[0]: at Socket.<anonymous> (/opt/iobroker/node_modules/iobroker.sma-em/main.js:76:53)
    host.winni-NUC6CAYH	2020-01-05 13:42:03.969	error	Caught by controller[0]: TypeError: Cannot mix BigInt and other types, use explicit conversions
    sma-em.0	2020-01-05 13:42:03.444	info	(4206) Terminated (NO_ERROR): Without reason
    sma-em.0	2020-01-05 13:42:03.443	info	(4206) terminating
    sma-em.0	2020-01-05 13:42:03.395	info	(4206) cleaned everything up...
    sma-em.0	2020-01-05 13:42:03.394	error	(4206) TypeError: Cannot mix BigInt and other types, use explicit conversions at Socket.<anonymous> (/opt/iobroker/node_modules/iobroker.sma-em/main.js:76:53) at Socket.emit (events.js:198:13)
    sma-em.0	2020-01-05 13:42:03.394	error	(4206) uncaught exception: Cannot mix BigInt and other types, use explicit conversions
    sma-em.0	2020-01-05 13:42:02.553	info	(4206) Details L1 false Details L2 false Details L3 false
    sma-em.0	2020-01-05 13:42:02.553	info	(4206) Listen via UDP on Port 9522 for Multicast IP 239.12.255.254
    sma-em.0	2020-01-05 13:42:02.510	info	(4206) starting. Version 0.5.3 in /opt/iobroker/node_modules/iobroker.sma-em, node: v10.18.0
    host.winni-NUC6CAYH	2020-01-05 13:42:02.555	info	instance system.adapter.sma-speedwire.1 terminated with code 0 (NO_ERROR)
    sma-speedwire.1	2020-01-05 13:42:01.474	info	(4193) starting. Version 0.6.6 in /opt/iobroker/node_modules/iobroker.sma-speedwire, node: v10.18.0
    host.winni-NUC6CAYH	2020-01-05 13:42:00.956	info	instance system.adapter.sma-em.0 started with pid 4206
    host.winni-NUC6CAYH	2020-01-05 13:42:00.022	info	instance system.adapter.sma-speedwire.1 started with pid 4193
    host.winni-NUC6CAYH	2020-01-05 13:41:36.554	info	instance system.adapter.sma-speedwire.1 terminated with code 0 (NO_ERROR)
    sma-speedwire.1	2020-01-05 13:41:35.487	info	(4177) starting. Version 0.6.6 in /opt/iobroker/node_modules/iobroker.sma-speedwire, node: v10.18.0
    host.winni-NUC6CAYH	2020-01-05 13:41:34.040	info	instance system.adapter.sma-speedwire.1 started with pid 4177
    host.winni-NUC6CAYH	2020-01-05 13:41:32.557	info	instance system.adapter.sma-speedwire.0 terminated with code 0 (NO_ERROR)
    sma-speedwire.0	2020-01-05 13:41:31.469	info	(4162) starting. Version 0.6.6 in /opt/iobroker/node_modules/iobroker.sma-speedwire, node: v10.18.0
    host.winni-NUC6CAYH	2020-01-05 13:41:30.941	info	Restart adapter system.adapter.sma-em.0 because enabled
    host.winni-NUC6CAYH	2020-01-05 13:41:30.941	info	instance system.adapter.sma-em.0 terminated with code 0 (NO_ERROR)
    host.winni-NUC6CAYH	2020-01-05 13:41:30.941	error	Caught by controller[0]: at UDP.onMessage [as onmessage] (dgram.js:628:8)
    host.winni-NUC6CAYH	2020-01-05 13:41:30.941	error	Caught by controller[0]: at Socket.emit (events.js:198:13)
    host.winni-NUC6CAYH	2020-01-05 13:41:30.941	error	Caught by controller[0]: at Socket.<anonymous> (/opt/iobroker/node_modules/iobroker.sma-em/main.js:76:53)
    host.winni-NUC6CAYH	2020-01-05 13:41:30.940	error	Caught by controller[0]: TypeError: Cannot mix BigInt and other types, use explicit conversions
    sma-em.0	2020-01-05 13:41:30.411	info	(4147) Terminated (NO_ERROR): Without reason
    sma-em.0	2020-01-05 13:41:30.410	info	(4147) terminating
    sma-em.0	2020-01-05 13:41:30.400	info	(4147) cleaned everything up...
    sma-em.0	2020-01-05 13:41:30.399	error	(4147) TypeError: Cannot mix BigInt and other types, use explicit conversions at Socket.<anonymous> (/opt/iobroker/node_modules/iobroker.sma-em/main.js:76:53) at Socket.emit (events.js:198:13)
    sma-em.0	2020-01-05 13:41:30.398	error	(4147) uncaught exception: Cannot mix BigInt and other types, use explicit conversions
    zurück auf die 8.17 und es läuft wieder, ohne die main.js nochmal mit der orginalen ersetzt zu haben, also mit der Version von @andiling
    @Winni Also ist das "n" wohl doch nötig gewesen ...
    WinniW 1 Antwort Letzte Antwort
    • apollon77A apollon77
      WinniW Offline
      WinniW Offline
      Winni
      Sorry da hab ich mich falsch ausgedrückt, es ist die Version von @andiling, aber ohne n, die jetzt unter 8.17 läuft.
      Es gibt nicht Gutes. Außer man tut es. Erich Kästner
      • WinniW Offline
        WinniW Offline
        Winni
        Hallo in die Runde, möchte mich hier bei allen bedanken, die an der "Rettung" dieses Adapters mitgewirkt haben. Ich habe mir heute ein neues Ubuntu 19.10 installiert und natürlich iobroker, übernommen hatte ich den iobroker-data Ordner. Zum Schluss dann den Adapter in der Version 0.5.6 installiert und läuft seit ein paar Stunden ohne Probleme. Neben der Steuerung der Heizung ist die Überwachung der PV und Stromverbrauch das wichtigste Feld meines Smathome. Also nochmals vielen Dank an andiling, Dutchman, Apollon77, GermanBluefox und wervsonst noch mitgewirkt hat.
