  4. IOBroker - Radar2
    5.9k
IOBroker - Radar2
radar2 adapterraspberry
153 Beiträge 23 Kommentatoren 29.8k Aufrufe 26 Beobachtet
  • P pupsi
    Hallo ich habe ein problem...;-)ich habe mir hier so gut wie alles durchgelesen und probiert jedoch ohne erfolg. Wo liegt mein fehler?
    Hier ein Auszug aus dem LOG
    host.iobrokerslave	2020-06-18 07:59:40.528	info	Restart adapter system.adapter.radar2.1 because enabled
    host.iobrokerslave	2020-06-18 07:59:40.526	info	instance system.adapter.radar2.1 terminated with code 0 (NO_ERROR)
    radar2.1	2020-06-18 07:59:40.087	warn	(688) Promise problem unhandledRejection of Promise Promise { <rejected> TypeError: A.C.knownBTs.toLowerCase is not a function at /opt/iobroker/node_modules/iobroker.radar2/radar2.js:464:41 at process
    radar2.1	2020-06-18 07:59:40.080	info	(688) Adapter disconnected and stopped with dostop(false) and callback(true)
    radar2.1	2020-06-18 07:59:40.076	error	(688) TypeError: A.C.knownBTs.toLowerCase is not a function at /opt/iobroker/node_modules/iobroker.radar2/radar2.js:464:41 at processTicksAndRejections (internal/process/task_queues.js:97:5)
    radar2.1	2020-06-18 07:59:40.073	error	(688) unhandled promise rejection: A.C.knownBTs.toLowerCase is not a function
    radar2.1	2020-06-18 07:59:40.071	error	Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
    radar2.1	2020-06-18 07:59:40.054	info	(688) radar2 set to flag items away if they are not seen for 3 minutes
    radar2.1	2020-06-18 07:59:40.052	warn	(688) node-bluetooth not found!
    radar2.1	2020-06-18 07:59:40.048	info	(688) found '@abandonware/noble'
    radar2.1	2020-06-18 07:59:39.501	info	(688) Connected with '0.0.0.0' for DHCP Scan
    radar2.1	2020-06-18 07:59:39.043	info	(688) radar2 initialization started...
    radar2.1	2020-06-18 07:59:38.995	warn	(688) adapter.objects.getObjectList is deprecated, and will be removed in the future. Please use adapter.getObjectList/Async. Report this to Developer!
    radar2.1	2020-06-18 07:59:38.832	info	(688) starting. Version 1.0.9 in /opt/iobroker/node_modules/iobroker.radar2, node: v14.4.0, js-controller: 3.1.5
    host.iobrokerslave	2020-06-18 07:59:34.062	info	instance system.adapter.radar2.1 started with pid 688
    DiginixD Offline
    DiginixD Offline
    Diginix
    #101
    @pupsi Du hast Version 1.0.9 installiert, nicht 2.x
    ..:: So long! Tom ::..
    • P pupsi
      #102
      @pupsi
      Und node 14 ist vielleicht auch noch etwas früh. Ich würde an deiner Stelle die empfohlene node12 installieren.
        @frankjoke sagte in IOBroker - Radar2:
        Bin hier gerade zufällig reingestolpert
        Wie im readme beschrieben müssen nach updates diese Befehle wieder ausgeführt werden damit das neue Programm auch die Berechtigung kriegt!
        Hilft da der Fixer nicht?
        Wenn nein, wäre es nicht sinnvoll diese Funktion mit in den Fixer einzubauen?
        @AlCalzone ??
        #103
        @Homoran Ja der Fixer würde da Helfen. Der setzt mal mindestens einige setcap auf dem nodejs prozess.
        @frankjoke Der "Fixer" ist das Skript was man bei einer ioBroker Installation nutzen kann um sicherzustellen das die Installation so ist als wenn man "frisch" installieren würde. Der Macht setcap kram, installiert fehlende Pakete, fixt rechte, legt den ioBroker user an und richtet alles so ein wie es sein muss.
          aldoa1
          #104
          ich kann den Adapter nicht starten. Bleibt rot.
          Verwende iobroker mit synology / docker
          Von der Konsole aus mit
          node /opt/iobroker/node_modules/iobroker.radar2/radar2.js --force --logs --nolazy
          startet der Adapter.
          Dann ist radar2 sofort grün.
          Stoppe ich die Ausführung in der Konsole ist der Adapter sofort rot und startet nicht mehr.
          Wie kann ich das Problem lösen?
          apollon77A GlasfaserG 2 Antworten Letzte Antwort
          • A aldoa1
            #105
            @aldoa1 Wenn Du Ihn von der Kommandozeile startest ist es auch der iobroker user?
            Was steht im Logfile von iobroker wenn du es per ioBroker startest?
            A 1 Antwort Letzte Antwort
            • apollon77A apollon77
              aldoa1
              #106
              @apollon77
              per Konsole ist es der root.
              Log:
              radar2.0 2020-08-28 23:02:35.009 warn (7797) Adapter not running as root or iobroker has no sudo right, cannot use arp-scan!
              radar2.0 2020-08-28 23:02:34.977 info (7797) Adapter disconnected and stopped with dostop(null) and callback(true)
              radar2.0 2020-08-28 23:02:34.976 info (7797) Unload adapter now with null
              radar2.0 2020-08-28 23:02:34.973 warn (7797) Uncaught Exception: bind EACCES 0.0.0.0:67
              radar2.0 2020-08-28 23:02:34.968 error (7797) Error: bind EACCES 0.0.0.0:67 at dgram.js:338:20 at processTicksAndRejections (internal/process/task_queues.js:85:21)
              radar2.0 2020-08-28 23:02:34.967 error (7797) uncaught exception: bind EACCES 0.0.0.0:67
              radar2.0 2020-08-28 23:02:34.952 info (7797) arp-scan will use the following interfaces: [ 'eth1', 'docker0' ]
              radar2.0 2020-08-28 23:02:34.950 info (7797) debug: use known IP list: ['192.168.167.1','192.168.167.2','192.168.167.115','192.168.167.62']
              radar2.0 2020-08-28 23:02:34.946 info (7797) debug: use known BT list: []
              radar2.0 2020-08-28 23:02:34.945 info (7797) debug: radar2 set to flag items away if they are not seen for 3 minutes
              radar2.0 2020-08-28 23:02:34.883 info (7797) net-ping not available! Will try to use normal ping!
              radar2.0 2020-08-28 23:02:34.733 info (7797) debug: started #3 hciconfig hci0 up
              radar2.0 2020-08-28 23:02:34.582 info (7797) debug: started #2 hciconfig hci0 down
              radar2.0 2020-08-28 23:02:34.569 info (7797) Will run hcitool-mode and not noble on device []!
              radar2.0 2020-08-28 23:02:34.536 info (7797) debug: started #1 hcitool dev
              radar2.0 2020-08-28 23:02:34.507 info (7797) Will use l2Ping for BT scans.
              radar2.0 2020-08-28 23:02:34.492 info (7797) radar2 initialization started...
              apollon77A harrymH 2 Antworten Letzte Antwort
              • A aldoa1
                @apollon77
                Log:
                #107
                @aldoa1 Naja da steht es ... liesst mal die Readme des Adapters,da steht drin was Du ggf noch an extra Befehlen ausführen musst (Stichwort setcap) ... oder lass den iobroker fixer laufen
                  aldoa1
                  #108
                  @apollon77
                  den fixer habe ich schon probiert.
                  die setcap Befehle konnte ich nicht ausführen.
                  Wenn ich als root per Konsole starte, funktioniert der adapter super.
                  apollon77A Thomas BraunT 2 Antworten Letzte Antwort
                  • A aldoa1
                    @apollon77
                    Log:
                    harrymH Offline
                    harrymH Offline
                    harrym
                    #109
                    @aldoa1 sagte in IOBroker - Radar2:
                    keine Ahnung welchen fixer du laufen hast lassen ... es war nicht der richtige.
                    ASRock FM2A88X-ITX+ mit 32GB RAM, 128GB SSD mit Proxmox, 3x1 TB SSD als RAID mit CT und VMs.
                    • A aldoa1
                      @apollon77
                      #110
                      Warum nicht? Wenn die Programme nicht installiert sein sollten dann installiere sie bitte
                      • harrymH harrym
                        aldoa1
                        #111
                        @harrym
                        Hatte im Portainer beim iobroker die Kosole als root geöffnet und dann:
                        harrymH 1 Antwort Letzte Antwort
                        • A aldoa1
                          @apollon77
                          #112
                          Das ist aber falsch, du startest gar nichts aktiv als root.
                          Als user:
                          iobroker fix
                          • A aldoa1
                            @harrym
                            harrymH Offline
                            harrymH Offline
                            harrym
                            #113
                            @aldoa1 und wieso nicht einfach unter /opt/iobroker (zur sicherheit) iobroker fix .... iobroker bietet auch seine ganzen befehle an ... wenn man ihn aufruft ....
                            • harrymH harrym
                              aldoa1
                              #114
                              @harrym
                              habe nun iobroker fix durchgeführt. Es kam zu einer Erfolgsmeldung. Docker iobroker noch mal gestopt und neu gestartet.
                              radar2 immer noch rot :-(
                              (ein anderes Problem (Schreibrechte bei zigbee-Adapter) wurde aber gelöst)
                                aldoa1
                                #115
                                und hier habe ich noch was im Log (wenn ich manuell als user iobroker starte):
                                warn: radar2.0 (2621) radar initialization finished with error TypeError: Cannot read property 'push' of nullat main (/opt/iobroker/node_modules/iobroker.radar2/radar2.js:764:29)at processTicksAndRejections (internal/process/task_queues.js:97:5)at async IobAdapter.onReady (/opt/iobroker/node_modules/iobroker.radar2/fjadapter-core.js:212:3), will stop adapter!
                                • A aldoa1
                                  #116
                                  @aldoa1
                                  whoami && who -r && which nodejs && nodejs -v && which node && node -v && which npm && npm -v && apt policy nodejs
                                    @aldoa1
                                    aldoa1
                                    schrieb am zuletzt editiert von aldoa1
                                    #117
                                    @Thomas-Braun said in IOBroker - Radar2:
                                    iobroker
                                    /usr/bin/nodejs
                                    v12.18.3
                                    /usr/bin/node
                                    v12.18.3
                                    /usr/bin/npm
                                    6.14.6
                                    nodejs:
                                      Installiert:           12.18.3-1nodesource1
                                      Installationskandidat: 12.18.3-1nodesource1
                                      Versionstabelle:
                                     *** 12.18.3-1nodesource1 100
                                            100 /var/lib/dpkg/status
                                    • A aldoa1
                                      iobroker
                                      /usr/bin/nodejs
                                      v12.18.3
                                      /usr/bin/node
                                      v12.18.3
                                      /usr/bin/npm
                                      6.14.6
                                      nodejs:
                                        Versionstabelle:
                                      #118
                                      @aldoa1 Konsolenausgabe auch gerne als Text in </> CodeTags.
                                      NodeJS ist aber sauber.
                                        aldoa1
                                        #119
                                        könnte ich beim docker ein startscript erstellen und einfach
                                        als root ausführern?
                                        • A aldoa1
                                          #120
                                          @aldoa1
                                          Ups. Den Synology/Docker habe ich übersehen. Da dann doch mit root agieren, bin aber sonst raus aus dem Nummer. Gut möglich, dass das dort auch mit setcaps nicht funktioniert. Das ganze ist etwas 'komisch'
