  4. Zigbee Adapter startet nicht mehr: serialport.node Fehler?
zigbee adapterserialport.nodeserialport
5 Beiträge 2 Kommentatoren 1.5k Aufrufe 2 Beobachtet
    Sundance
    Hi Zusammen,
    ich habe nach einem Update/Upgrade und einigen Adapter-Aktualisierungen (nach einem längeren Urlaub..) das Problem, dass mein Zigbee Adapter nicht mehr richtig startet. Das Log wirft folgenden Fehler auf:
    host.HOME	2019-05-22 10:56:56.493	error	instance system.adapter.zigbee.0 terminated with code 1 ()
    host.HOME	2019-05-22 10:56:56.493	error	Caught by controller[0]: at Object.Module._extensions..js (module.js:664:10)
    host.HOME	2019-05-22 10:56:56.492	error	Caught by controller[0]: at Module._compile (module.js:653:30)
    host.HOME	2019-05-22 10:56:56.492	error	Caught by controller[0]: at Object.<anonymous> (/opt/iobroker/node_modules/iobroker.zigbee/node_modules/serialport/lib/bindings/linux.js:2:36)
    host.HOME	2019-05-22 10:56:56.491	error	Caught by controller[0]: at bindings (/opt/iobroker/node_modules/iobroker.zigbee/node_modules/bindings/bindings.js:81:44)
    host.HOME	2019-05-22 10:56:56.490	error	Caught by controller[0]: at require (internal/module.js:11:18)
    host.HOME	2019-05-22 10:56:56.490	error	Caught by controller[0]: at Module.require (module.js:597:17)
    host.HOME	2019-05-22 10:56:56.489	error	Caught by controller[0]: at Function.Module._load (module.js:498:3)
    host.HOME	2019-05-22 10:56:56.489	error	Caught by controller[0]: at tryModuleLoad (module.js:506:12)
    host.HOME	2019-05-22 10:56:56.488	error	Caught by controller[0]: at Module.load (module.js:566:32)
    host.HOME	2019-05-22 10:56:56.488	error	Caught by controller[0]: at Object.Module._extensions..node (module.js:682:18)
    host.HOME	2019-05-22 10:56:56.487	error	Caught by controller[0]: the module (for instance, using `npm rebuild` or `npm install`).
    host.HOME	2019-05-22 10:56:56.487	error	Caught by controller[0]: NODE_MODULE_VERSION 57. Please try re-compiling or re-installing
    host.HOME	2019-05-22 10:56:56.486	error	Caught by controller[0]: NODE_MODULE_VERSION 67. This version of Node.js requires
    host.HOME	2019-05-22 10:56:56.486	error	Caught by controller[0]: was compiled against a different Node.js version using
    host.HOME	2019-05-22 10:56:56.485	error	Caught by controller[0]: Error: The module '/opt/iobroker/node_modules/iobroker.zigbee/node_modules/serialport/build/Release/serialport.node'
    host.HOME	2019-05-22 10:56:56.483	error	Caught by controller[0]: ^
    host.HOME	2019-05-22 10:56:56.482	error	Caught by controller[0]: throw e
    host.HOME	2019-05-22 10:56:56.481	error	Caught by controller[0]: /opt/iobroker/node_modules/iobroker.zigbee/node_modules/bindings/bindings.js:88
    Ich habe bereits ein npm rebuild sowohl im /iobroker/ ordner als auch in dem entsprechenden /node_modules/ Ordner vorgenommen, aber das scheint nicht zu klappen... unter anderem erhielt ich folgende Fehlermeldung:
    root@HOME:/opt/iobroker# npm rebuild
    > serialport@6.2.2 install /opt/iobroker/node_modules/iobroker.discovery/node_modules/serialport
    > prebuild-install || node-gyp rebuild
    prebuild-install WARN install EACCES: permission denied, access '/root/.npm'
    gyp ERR! clean error
    gyp ERR! stack Error: EACCES: permission denied, unlink 'build/Makefile'
    gyp ERR! System Linux 4.19.42-v7+
    gyp ERR! command "/usr/local/bin/node" "/usr/local/lib/node_modules/npm/node_modules/node-gyp/bin/node-gyp.js" "rebuild"
    gyp ERR! cwd /opt/iobroker/node_modules/iobroker.discovery/node_modules/serialport
    gyp ERR! node -v v11.6.0
    gyp ERR! node-gyp -v v3.8.0
    gyp ERR! not ok
    npm ERR! code ELIFECYCLE
    npm ERR! errno 1
    npm ERR! serialport@6.2.2 install: `prebuild-install || node-gyp rebuild`
    npm ERR! Exit status 1
    npm ERR!
    npm ERR! Failed at the serialport@6.2.2 install script.
    npm ERR! This is probably not a problem with npm. There is likely additional logging output above.
    npm ERR!     /root/.npm/_logs/2019-05-22T09_05_44_386Z-debug.log
    Ich bin leider nicht so fit in der Konsole und mit den ganzen node packages. Ich wäre euch um jede Hilfe sehr dankbar!
    Beste Grüße
    Sundance
    • S Sundance
      Hi Zusammen,
      gyp ERR! not ok
      npm ERR! errno 1
      npm ERR!
      Beste Grüße
      Sundance
      AlCalzoneA Offline
      AlCalzoneA Offline
      AlCalzone
      schrieb am zuletzt editiert von AlCalzone
      @Sundance sagte in Zigbee Adapter startet nicht mehr: serialport.node Fehler?:
      npm rebuild
      Probiere mal npm rebuild --unsafe-perm
      node -v v11.6.0
      Aber vorher bitte auf eine gerade Version von Node wechseln. Entweder 8, 10 oder ggf. 12, aber bei v12 funktioniert einiges noch nicht 100%.
      Ungerade Versionen sind Entwicklerversionen.
      Warum sudo böse ist: https://forum.iobroker.net/post/17109
        Sundance
        Sorry für die Sendepause, ich hatte den Thread leider nicht abonniert.
        Kannst du mir sagen, wie ich am sichersten auf eine der graden Versionen wechsle? Sollte ich dann eher auf die grade Version 11 "downgraden"?
        Vielen Dank Vorab
        Sundance
        • S Sundance
          Vielen Dank Vorab
          Sundance
          AlCalzoneA Offline
          AlCalzoneA Offline
          AlCalzone
          grade Version 11
          Hast du in Mathe aufgepasst? ;)
          Siehe Doku: https://www.iobroker.net/#de/documentation/install/updatenode.md
          • AlCalzoneA AlCalzone
            grade Version 11
            Sundance
            @AlCalzone said in Zigbee Adapter startet nicht mehr: serialport.node Fehler?:
            grade Version 11
            Ich wusste nicht genau, was mit gerade oder ungerade gemeint ist.. ich dachte, dass sich das auf die zahlen nach der "Hauptversion" bezieht und das jede Zahl ohne die .x.x dahinter eine "gerade" Version ist. Verzeih mir meine Unwissenheit ;)
            Danke, ich teste es und melde mich nochmal, falls es immernoch probleme gibt..
