  4. Ubuntu 19.04 Update - SQL Adapter geht nicht mehr
sql-adapterubuntuupdate
12 Beiträge 3 Kommentatoren 1.3k Aufrufe 1 Beobachtet
    mdsv
    Nach dem Update auf 19.04 geht der SQL Adapter nicht mehr.
    Hätte zu bieten .... Nodejs Version: 10.15.2 - NPM 5.8.0
    Caught	2019-04-23 17:39:28.012	error	by controller[0]: at Module.load (internal/modules/cjs/loader.js:599:32)
    Caught	2019-04-23 17:39:28.012	error	by controller[0]: at Object.Module._extensions..js (internal/modules/cjs/loader.js:700:10)
    Caught	2019-04-23 17:39:28.012	error	by controller[0]: at Module._compile (internal/modules/cjs/loader.js:689:30)
    Caught	2019-04-23 17:39:28.012	error	by controller[0]: at Object.<anonymous> (/opt/iobroker/node_modules/mmmagic/lib/index.js:1:75)
    Caught	2019-04-23 17:39:28.012	error	by controller[0]: at require (internal/modules/cjs/helpers.js:22:18)
    Caught	2019-04-23 17:39:28.012	error	by controller[0]: at Module.require (internal/modules/cjs/loader.js:637:17)
    Caught	2019-04-23 17:39:28.012	error	by controller[0]: at Function.Module._load (internal/modules/cjs/loader.js:530:3)
    Caught	2019-04-23 17:39:28.012	error	by controller[0]: at tryModuleLoad (internal/modules/cjs/loader.js:538:12)
    Caught	2019-04-23 17:39:28.012	error	by controller[0]: at Object.Module._extensions..node (internal/modules/cjs/loader.js:718:18)
    Caught	2019-04-23 17:39:28.012	error	by controller[0]: the module (for instance, using `npm rebuild` or `npm install`).
    Caught	2019-04-23 17:39:28.012	error	by controller[0]: NODE_MODULE_VERSION 64. Please try re-compiling or re-installing
    Caught	2019-04-23 17:39:28.012	error	by controller[0]: NODE_MODULE_VERSION 57. This version of Node.js requires
    Caught	2019-04-23 17:39:28.012	error	by controller[0]: was compiled against a different Node.js version using
    Caught	2019-04-23 17:39:28.011	error	by controller[0]: Error: The module '/opt/iobroker/node_modules/mmmagic/build/Release/magic.node'
    Caught	2019-04-23 17:39:28.011	error	by controller[0]: ^
    Caught	2019-04-23 17:39:28.011	error	by controller[0]: return process.dlopen(module, path.toNamespacedPath(filename));
    Caught	2019-04-23 17:39:28.011	error	by controller[0]: internal/modules/cjs/loader.js:718
    • M mdsv
      mdsv
      @mdsv
      Hat sich erledigt, Lösung war:
      npm remove mmmagic
      npm install mmmagic
        mdsv
        schrieb am zuletzt editiert von mdsv
        Hm, irgendwie ist die Ubuntu NodeJs Version (10.15.2) neuer als iobroker verkraftet.
        Jetzt kommt beim Öffnen der Adminseite direkt ein Fenster: ioBroker unterstützt die LTS Versionen 6, 8, 10 oder neuer von Node.js. Bitte aktualisieren Sie die verwendete Node.js Version ("v9.3.0") auf dem Rechner "...." auf eine unterstützte Version. Wir empfehlen die Verwendung von Node.js 6.
        Der Work around beim SQL Adapter ging irgendwie leider doch nicht.
        Bin jetzt auf influxdb gewechselt, die ist robuster wohl als SQL. Sehr schade.
        HomoranH ThisoftT 2 Antworten Letzte Antwort
        • M mdsv
          @mdsv sagte in Ubuntu 19.04 Update - SQL Adapter geht nicht mehr:
          Dann gib Mal den Output von
          node -v
          nodejs -v
          Ich füchte du hast mit dem Upgrade auf die Entwickler Version von Ubuntu eine zweite node Version installiert
          • M mdsv
            ThisoftT Offline
            ThisoftT Offline
            Thisoft
            @mdsv
            Ich hatte ja nach dem Update des SQL-Adapters auch ein gravierendes Installationsproblem. Allerdings unter Windows, das lag an einem Versionsproblem der Windows-Build-Tool. Trifft bei dir ja schonmal nicht zu. Was aber auch bei mir der Auslöser war ist das mmmagic-Paket.
            Was wahrscheinlich nicht der Grund sein dürfte ist m.E. die Node-Version, ich hab seitdem auch die 10.15.3 drauf und es läuft damit. Was ich schon eher in Frage stellen würde ist deine 5er npm-Version - ich hab da schon seit Urzeiten die 6.4.1.
            Poste bitte mal noch den kompletten Output von "npm install mmmagic" - vielleicht sieht man ja noch was, ich hab da jetzt a bisserl Erfahrung damit :-)
              mdsv
              @Homoran sagte in Ubuntu 19.04 Update - SQL Adapter geht nicht mehr:
              node -v
              node -v
              v9.3.0
              nodejs -v
              v10.15.2
              npm install mmmagic
              path /opt/iobroker/node_modules/mmmagic/package.json
              npm ERR! code ELOOP
              npm ERR! errno -40
              npm ERR! syscall open
              npm ERR! ELOOP: too many symbolic links encountered, open '/opt/iobroker/node_modules/mmmagic/package.json'
              npm ERR! /home/mdsv/.npm/_logs/2019-04-30T17_55_09_255Z-debug.log
              Daran liegt es sicher, schon klar.
              NPM ... jetzt zeigt er an:
              6.9.0
              • M mdsv
                node -v
                node -v
                v9.3.0
                nodejs -v
                v10.15.2
                npm install mmmagic
                npm ERR! code ELOOP
                npm ERR! errno -40
                6.9.0
                @mdsv
                Wie befürchtet hast du zwei node Installationen parallel laufen.
                Da musst du eine von deinstallieren.
                Leider weiß ich nur, dass das schon öfter Thema war, aber leider nicht mehr wie es geht.
                  @mdsv
                  mdsv
                  Nach langen Hin- und Her habe ich nun:
                  $ npm -v
                  6.9.0
                  $ node -v
                  v10.15.3
                  $ nodejs -v
                  v10.15.2
                  Hatte auch gelesen, dass SQL mit 10er Versionen wohl nicht geht. Werde das Update mal abwarten.
                  Aber die Fehlermeldung: ioBroker unterstützt die LTS Versionen 6, 8, 10 oder neuer von Node.js. Bitte aktualisieren Sie die verwendete Node.js Version ("v9.3.0") auf dem Rechner "...." auf eine unterstützte Version. Wir empfehlen die Verwendung von Node.js 6. kommt nicht mehr.
                  • M mdsv
                    $ npm -v
                    6.9.0
                    $ node -v
                    v10.15.3
                    $ nodejs -v
                    v10.15.2
                    @mdsv
                    Du hast aber immer och zwei versi4parallel, auch wenn du die 9er jetztcauf eine andere 10er upgedated hast.
                      @mdsv
                      mdsv
                      @Homoran
                      woran siehst du das? an den Unterschied. Versionen?
                      • M mdsv
                        @Homoran
                        @Homoran
                        Ja!
                        Die Gefahr ist jetzt, dass du beide auf die gleiche Version bekommst, so dass es scheinbar gelöst ist.
                        Du musst unbedingt herausbekommen wo diese beiden Installationen sind (ich tippe nach wie vor, dass die ehemalige 9er mit dem Ubuntu Upgrade aus deren Repository kam), und beide entfernen und anschließend nach der Anleitung neu installieren.
                          @Homoran
                          Ja!
                          mdsv
                          @Homoran
                          Ok, dachte bisher, das sind 2 unterschiedl. Programme, die miteinander nichts zu tun haben.
                          which node
                          /usr/local/bin/node
                          which nodejs
                          /usr/bin/nodejs
                          Welches Risiko gibt es denn?
