  5. Bitte Hilfe bei Interpretation von Fehlermeldungen
    6.0k
javascript
27 Beiträge 5 Kommentatoren 1.7k Aufrufe 4 Beobachtet
    skorpil
    ich erhalte bei der Scriptausführung folgende Warnhinweise:
    javascript.0	2019-03-24 08:23:01.124	warn	at TCP.onread (net.js:601:20)
    javascript.0	2019-03-24 08:23:01.124	warn	at Socket.Readable.push (_stream_readable.js:208:10)
    javascript.0	2019-03-24 08:23:01.124	warn	at readableAddChunk (_stream_readable.js:250:11)
    javascript.0	2019-03-24 08:23:01.124	warn	at addChunk (_stream_readable.js:263:12)
    javascript.0	2019-03-24 08:23:01.124	warn	at Socket.emit (events.js:211:7)
    javascript.0	2019-03-24 08:23:01.124	warn	at emitOne (events.js:116:13)
    javascript.0	2019-03-24 08:23:01.124	warn	at Socket.realHandler (/opt/iobroker/node_modules/ws/lib/WebSocket.js:825:20)
    javascript.0	2019-03-24 08:23:01.124	warn	at Receiver.add (/opt/iobroker/node_modules/ws/lib/Receiver.js:103:24)
    javascript.0	2019-03-24 08:23:01.124	warn	at Receiver.expectHandler (/opt/iobroker/node_modules/ws/lib/Receiver.js:499:31)
    javascript.0	2019-03-24 08:23:01.124	warn	at Receiver.finish (/opt/iobroker/node_modules/ws/lib/Receiver.js:541:12)
    javascript.0	2019-03-24 08:23:01.124	warn	at Receiver.flush (/opt/iobroker/node_modules/ws/lib/Receiver.js:347:3)
    javascript.0	2019-03-24 08:23:01.124	warn	at /opt/iobroker/node_modules/ws/lib/Receiver.js:508:14
    javascript.0	2019-03-24 08:23:01.124	warn	at Receiver.applyExtensions (/opt/iobroker/node_modules/ws/lib/Receiver.js:371:5)
    javascript.0	2019-03-24 08:23:01.124	warn	at /opt/iobroker/node_modules/ws/lib/Receiver.js:536:18
    javascript.0	2019-03-24 08:23:01.124	warn	at Receiver.ontext (/opt/iobroker/node_modules/ws/lib/WebSocket.js:841:10)
    javascript.0	2019-03-24 08:23:01.124	warn	at WebSocket.emit (events.js:214:7)
    javascript.0	2019-03-24 08:23:01.124	warn	at emitTwo (events.js:126:13)
    javascript.0	2019-03-24 08:23:01.124	warn	at WebSocket.onMessage (/opt/iobroker/node_modules/ws/lib/WebSocket.js:442:14)
    javascript.0	2019-03-24 08:23:01.124	warn	at WebSocket.ws.onmessage (/opt/iobroker/node_modules/engine.io-client/lib/transports/websocket.js:146:10)
    javascript.0	2019-03-24 08:23:01.124	warn	at WS.Transport.onData (/opt/iobroker/node_modules/engine.io-client/lib/transport.js:137:8)
    javascript.0	2019-03-24 08:23:01.123	warn	at WS.Transport.onPacket (/opt/iobroker/node_modules/engine.io-client/lib/transport.js:145:8)
    javascript.0	2019-03-24 08:23:01.123	warn	at WS.Emitter.emit (/opt/iobroker/node_modules/engine.io-client/node_modules/component-emitter/index.js:133:20)
    javascript.0	2019-03-24 08:23:01.123	warn	at WS.<anonymous> (/opt/iobroker/node_modules/engine.io-client/lib/socket.js:268:10)
    javascript.0	2019-03-24 08:23:01.123	warn	at Socket.onPacket (/opt/iobroker/node_modules/engine.io-client/lib/socket.js:451:14)
    javascript.0	2019-03-24 08:23:01.123	warn	at Socket.Emitter.emit (/opt/iobroker/node_modules/engine.io-client/node_modules/component-emitter/index.js:133:20)
    javascript.0	2019-03-24 08:23:01.123	warn	at Socket.<anonymous> (/opt/iobroker/node_modules/component-bind/index.js:21:15)
    javascript.0	2019-03-24 08:23:01.123	warn	at Manager.ondata (/opt/iobroker/node_modules/socket.io-client/lib/manager.js:322:16)
    javascript.0	2019-03-24 08:23:01.123	warn	at Decoder.add (/opt/iobroker/node_modules/socket.io-parser/index.js:246:12)
    javascript.0	2019-03-24 08:23:01.123	warn	at Decoder.Emitter.emit (/opt/iobroker/node_modules/component-emitter/index.js:134:20)
    javascript.0	2019-03-24 08:23:01.123	warn	at Decoder.<anonymous> (/opt/iobroker/node_modules/component-bind/index.js:21:15)
    javascript.0	2019-03-24 08:23:01.123	warn	at Manager.ondecoded (/opt/iobroker/node_modules/socket.io-client/lib/manager.js:332:8)
    javascript.0	2019-03-24 08:23:01.123	warn	at Manager.Emitter.emit (/opt/iobroker/node_modules/socket.io-client/node_modules/component-emitter/index.js:133:20)
    javascript.0	2019-03-24 08:23:01.123	warn	at Manager.<anonymous> (/opt/iobroker/node_modules/component-bind/index.js:21:15)
    javascript.0	2019-03-24 08:23:01.123	warn	at Socket.onpacket (/opt/iobroker/node_modules/socket.io-client/lib/socket.js:228:12)
    javascript.0	2019-03-24 08:23:01.123	warn	at Socket.onevent (/opt/iobroker/node_modules/socket.io-client/lib/socket.js:270:10)
    javascript.0	2019-03-24 08:23:01.123	warn	at Socket.Emitter.emit (/opt/iobroker/node_modules/socket.io-client/node_modules/component-emitter/index.js:133:20)
    javascript.0	2019-03-24 08:23:01.123	warn	at Socket.<anonymous> (/opt/iobroker/node_modules/iobroker.js-controller/lib/states/statesInMemClient.js:52:30)
    javascript.0	2019-03-24 08:23:01.123	warn	at Object.change (/opt/iobroker/node_modules/iobroker.js-controller/lib/adapter.js:3705:37)
    javascript.0	2019-03-24 08:23:01.123	warn	at Object.stateChange (/opt/iobroker/node_modules/iobroker.javascript/main.js:364:25)
    javascript.0	2019-03-24 08:23:01.123	warn	at Object.callback (/opt/iobroker/node_modules/iobroker.javascript/lib/sandbox.js:963:38)
    javascript.0	2019-03-24 08:23:01.123	warn	at Object.<anonymous> (script.js.common.Skripte_aktiviert.homematic_Variablen_aus_openweathermap:19:1)
    javascript.0	2019-03-24 08:23:01.123	warn	at Wetterdatenholenundsetzen (script.js.common.Skripte_aktiviert.homematic_Variablen_aus_openweathermap:123:5)
    javascript.0	2019-03-24 08:23:01.123	warn	at setState (/opt/iobroker/node_modules/iobroker.javascript/lib/sandbox.js:1258:20)
    javascript.0	2019-03-24 08:23:01.123	warn	Wrong type of hm-rega.0.29959: "object". Please fix, while deprecated and will not work in next versions.
    Was will mir de Adapter sagen?
    dslraserD HomoranH paul53P 3 Antworten Letzte Antwort
    • S skorpil
      dslraserD Offline
      dslraserD Offline
      dslraser
      @skorpil
      willst Du was in hm.rega schreiben ?
      (vielleicht mit dem falschen Angaben)
      Aber ohne das Script zu sehen....?
      • S skorpil
        @skorpil sagte in Bitte Hilfe bei Interpretation von Fehlermeldungen:
        Steht doch da ;-)
        Was liefert das Skript für einen Wert?
        Was ist der Datenpunkt für ein Typ?
        • sigi234S Online
          sigi234S Online
          sigi234
          Ich schätze er will von openweathermap eine Zahl in die CCU schreiben, diese ist wahrscheinlich als String und nicht als Zahl gesetzt.........
          Immer Daten sichern!
            skorpil
            Wow, seid Ihr schnell. Vielen Dank. sigi234 hat Recht. die Idee ist, aus openweathermap Werte in CCU Variablen zu schreiben.
            Hier mal das Script. Aber bitte nicht lachen. Ich bin kein JavaScript Profi. Dass kann man sicher alles effizienter und eleganter programmieren. Aber so entspricht das eben meinen Fähigkeiten.
            //    Wetterdaten aus openweathermap holen und in homematic Variable setzen
            // Aktualisierung der homematic Variable bei Aktualisierung openweathermap
            on ({id:'openweathermap.0.forecast.current.date'/*Actual date*/, change: 'any'}, function(data) {
            //Werte holen und setzen
            //Wetter Bedingung als String
            var idOpenWeater = 'openweathermap.0.forecast.current.state'/*Actual state*/;
            var idVariable = 'hm-rega.0.29954'/*Wetter Bedingungen*/;
            wetterdaten = getState(idOpenWeater).val
            if(wetterdaten == "null"){
                   wetterdaten = "windstill";
            setState(idVariable, wetterdaten);
            //Wetter Richtung als Zahl
            var idOpenWeater = 'openweathermap.0.forecast.current.windDirection'/*Forecast for wind direction*/;
            var idVariable = 'hm-rega.0.29959'/*Wetter Windrichtg*/;
            Wetterdatenholenundsetzen();
            //Wind Richtung als Angabe
            var idVariable = 'hm-rega.0.29958'/*Wetter Windrichtung*/;
                //******************* Windrichtung bestimmen***************
                //*******************Nord 339-23, Nordost 24-68, Ost 69-113, SüdOst 114-158, Süd 159-203, SüdWest 204-248, West 249-293, NordWest 394-338***************
                   wetterdaten = 0;
                if (wetterdaten > 23 && wetterdaten <= 68){
                    wetterdaten = "NordOst";
                if (wetterdaten > 68 && wetterdaten <= 113){
                    wetterdaten = "Ost";
                if (wetterdaten > 113 && wetterdaten <= 158){
                    wetterdaten = "SüdOst";
                if (wetterdaten > 158 && wetterdaten <= 203){
                    wetterdaten = "Süd";
                if (wetterdaten > 203 && wetterdaten <= 248){
                    wetterdaten = "SüdWest";
                if (wetterdaten > 248 && wetterdaten <= 293){
                    wetterdaten = "West";
                if (wetterdaten > 293 && wetterdaten <= 338){
                    wetterdaten = "NordWest";
                if (wetterdaten > 338 && wetterdaten <= 360){
                    wetterdaten = "Nord";
                if (wetterdaten > 0 && wetterdaten <= 23){
            //Temperatur als Zahl
            var idOpenWeater = 'openweathermap.0.forecast.current.temperature'/*Actual temperature for today*/
            var idVariable = 'hm-rega.0.29955'/*Wetter Temperatur*/;
            //Luftfeuchtigkeit als Zahl
            var idOpenWeater = 'openweathermap.0.forecast.current.humidity'/*Actual humidity*/
            var idVariable = 'hm-rega.0.29956'/*Wetter Luftfeuchte*/;
            //Windgeschwindigkeit als Zahl
            var idOpenWeater = 'openweathermap.0.forecast.current.windSpeed'/*Forecast for wind speed*/
            var idVariable = 'hm-rega.0.29960'/*Wetter Windgeschwindigkeit*/;
            //Aktualisierung (Zeit)
            var idOpenWeater = 'openweathermap.0.forecast.current.date'/*Actual date*/;
            var idVariable = 'hm-rega.0.29953'/*Wetter Aktualisierung*/;
            wetterdaten = getState(idOpenWeater).val;
            var date = new Date(wetterdaten);
            // Umwandeln in deutsches Format
                //Tagesdatum ermitteln
                var tag = date.getDate();
                //Monat ermitteln
                var month = new Array("1","2","3","4","5","6","7","8","9","10","11","12");
                var monat = month[date.getMonth()];
                //Jahr ermitteln
                var jahr = date.getFullYear();
                //Stunde ermitteln
                var stunde = date.getHours();
                //Minute ermitteln
                var minute = date.getMinutes();
                //Sekunde ermitteln
                var sekunde = date.getSeconds();
            var ausgabe = tag + "." + monat + "." + jahr + "   " + stunde + ":" + minute + ":" + sekunde;
            setState(idVariable, ausgabe);
            //                  FUNKTION Holen und setzen
             function Wetterdatenholenundsetzen() {
            Nun aber zur Frage: das mit String und Zahl hatte ich mir auch schon überlegt. Aber wie ich das löse, das weiß ich nicht und benötige Hilfe.
            HomoranH sigi234S 2 Antworten Letzte Antwort
            • S skorpil
                     wetterdaten = 0;
                  //Monat ermitteln
                  //Jahr ermitteln
                  //Stunde ermitteln
                  //Minute ermitteln
                  //Sekunde ermitteln
              @skorpil
              Dazu gibt es zwei Möglichkeiten
              Daher bitte meine Fragen beantworten
              • S skorpil
                       wetterdaten = 0;
                    //Monat ermitteln
                    //Jahr ermitteln
                    //Stunde ermitteln
                    //Minute ermitteln
                    //Sekunde ermitteln
                sigi234S Online
                sigi234S Online
                sigi234
                @skorpil
                Bespiel Duty Cycle in CCU schreiben:
                // DP in SV schreiben
                const idDP = "hm-rega.0.NEQ1531999.0.DUTY_CYCLE";
                const idSV = "hm-rega.0.30785";
                setState(idSV, parseFloat(getState(idDP).val)); // Skriptstart
                on(idDP, function(dp) {  // Wertänderung
                   setState(idSV, parseFloat(dp.state.val));
                  Steht doch da ;-)
                  @Homoran sagte in Bitte Hilfe bei Interpretation von Fehlermeldungen:
                    skorpil
                    @Homoran, hm-rega.0.29959 ist vom Typ Zahl. Und eigentlich sollte das Script auch eine Zahl liefern.
                    @sigi234 muß ich immer mit "parseFloat" arbeiten?
                      skorpil
                      da der Fehler nicht immer auftritt: es scheint, dass der Adapter "openweathermap" für den Fall, daß keine Werte vorhanden sind, statt einer "Zahl" eine "null" liefert. Und das kann mein Script dann nicht mehr verarbeiten. Ich bin auch nicht sicher, ob "null" ein string oder ein logikwert ist. Irritierend.
                      • S skorpil
                        @skorpil sagte:
                        Wenn der Wert ein Object enthält, wird parseFloat() nicht helfen. Schau Dir den Wert mal mit einem zusätzlichen Log an.
                        log(JSON.stringify(getState(idOpenWeather).val));
                        Variablen nur einmal deklarieren (var nur in den Zeilen 12, 13) !
                        • S skorpil
                          @skorpil sagte:
                          Dann ist das der Grund für die Warnung: null ist ein Objekt !
                          S sigi234S 2 Antworten Letzte Antwort
                            @skorpil sagte:
                            skorpil
                            @paul53 Danke. Und wie könnte ich das abfangen? Also, irgendwas wie "wenn objekt, dann....."
                              @skorpil sagte:
                              sigi234S Online
                              sigi234S Online
                              sigi234
                              @paul53 sagte in Bitte Hilfe bei Interpretation von Fehlermeldungen:
                              Und wieder was gelernt....
                              Zitat:
                              parseFloat kann zudem Objekte parsen, wenn diese eine toString- oder valueOf-Methode haben. Das Ergebnis ist dasselbe, als wenn parseFloat mit dem Ergebnis einer dieser beiden Methoden ausgerufen wurde.
                              • S skorpil
                                @skorpil sagte:
                                    if(wetterdaten) setState(idVariable, wetterdaten);
                                  skorpil
                                  schrieb am zuletzt editiert von skorpil
                                  merci, ich werde testen und berichten
                                    skorpil
                                    @paul53 dankeschön, das war es: "if (wetterdaten)". Denn augenscheinlich liefert der Adapter manchmal eben leere Objekte.
                                      skorpil
                                      @paul53 noch eine Frage: jetzt reagiert das Script ja nur, wenn ein Wert vorhanden ist. Eben durch die Abfrage if(Variable). Wie würde man das Gegenteil programmieren, also wenn „kein“ Wert vorhanden, dann.... ich würde nämlich gerne in meine CCU Variable noch schreiben, wenn kein Wert, dann „keine Angabe“.
                                      • S skorpil
                                        @skorpil sagte:
                                            if(wetterdaten === null) wetterdaten = 'keine Angabe';
                                        EDIT: Vergleich geändert, da Wert 0 ein gültiger Wert ist, der vorkommen kann.
                                          @skorpil sagte:
                                          skorpil
                                          @paul53 großartig! Vielen Dank u. nun ein schönes Wochenende.
                                          PS: ...wenn es dieses Forum nicht gäbe...
