  4. JavaScript
  5. Bitte Hilfe bei Interpretation von Fehlermeldungen
    6.0k
javascript
27 Beiträge 5 Kommentatoren 1.7k Aufrufe 4 Beobachtet
  • S skorpil
    ich erhalte bei der Scriptausführung folgende Warnhinweise:
    javascript.0	2019-03-24 08:23:01.124	warn	at TCP.onread (net.js:601:20)
    javascript.0	2019-03-24 08:23:01.124	warn	at Socket.Readable.push (_stream_readable.js:208:10)
    javascript.0	2019-03-24 08:23:01.124	warn	at readableAddChunk (_stream_readable.js:250:11)
    javascript.0	2019-03-24 08:23:01.124	warn	at addChunk (_stream_readable.js:263:12)
    javascript.0	2019-03-24 08:23:01.124	warn	at Socket.emit (events.js:211:7)
    javascript.0	2019-03-24 08:23:01.124	warn	at emitOne (events.js:116:13)
    javascript.0	2019-03-24 08:23:01.124	warn	at Socket.realHandler (/opt/iobroker/node_modules/ws/lib/WebSocket.js:825:20)
    javascript.0	2019-03-24 08:23:01.124	warn	at Receiver.add (/opt/iobroker/node_modules/ws/lib/Receiver.js:103:24)
    javascript.0	2019-03-24 08:23:01.124	warn	at Receiver.expectHandler (/opt/iobroker/node_modules/ws/lib/Receiver.js:499:31)
    javascript.0	2019-03-24 08:23:01.124	warn	at Receiver.finish (/opt/iobroker/node_modules/ws/lib/Receiver.js:541:12)
    javascript.0	2019-03-24 08:23:01.124	warn	at Receiver.flush (/opt/iobroker/node_modules/ws/lib/Receiver.js:347:3)
    javascript.0	2019-03-24 08:23:01.124	warn	at /opt/iobroker/node_modules/ws/lib/Receiver.js:508:14
    javascript.0	2019-03-24 08:23:01.124	warn	at Receiver.applyExtensions (/opt/iobroker/node_modules/ws/lib/Receiver.js:371:5)
    javascript.0	2019-03-24 08:23:01.124	warn	at /opt/iobroker/node_modules/ws/lib/Receiver.js:536:18
    javascript.0	2019-03-24 08:23:01.124	warn	at Receiver.ontext (/opt/iobroker/node_modules/ws/lib/WebSocket.js:841:10)
    javascript.0	2019-03-24 08:23:01.124	warn	at WebSocket.emit (events.js:214:7)
    javascript.0	2019-03-24 08:23:01.124	warn	at emitTwo (events.js:126:13)
    javascript.0	2019-03-24 08:23:01.124	warn	at WebSocket.onMessage (/opt/iobroker/node_modules/ws/lib/WebSocket.js:442:14)
    javascript.0	2019-03-24 08:23:01.124	warn	at WebSocket.ws.onmessage (/opt/iobroker/node_modules/engine.io-client/lib/transports/websocket.js:146:10)
    javascript.0	2019-03-24 08:23:01.124	warn	at WS.Transport.onData (/opt/iobroker/node_modules/engine.io-client/lib/transport.js:137:8)
    javascript.0	2019-03-24 08:23:01.123	warn	at WS.Transport.onPacket (/opt/iobroker/node_modules/engine.io-client/lib/transport.js:145:8)
    javascript.0	2019-03-24 08:23:01.123	warn	at WS.Emitter.emit (/opt/iobroker/node_modules/engine.io-client/node_modules/component-emitter/index.js:133:20)
    javascript.0	2019-03-24 08:23:01.123	warn	at WS.<anonymous> (/opt/iobroker/node_modules/engine.io-client/lib/socket.js:268:10)
    javascript.0	2019-03-24 08:23:01.123	warn	at Socket.onPacket (/opt/iobroker/node_modules/engine.io-client/lib/socket.js:451:14)
    javascript.0	2019-03-24 08:23:01.123	warn	at Socket.Emitter.emit (/opt/iobroker/node_modules/engine.io-client/node_modules/component-emitter/index.js:133:20)
    javascript.0	2019-03-24 08:23:01.123	warn	at Socket.<anonymous> (/opt/iobroker/node_modules/component-bind/index.js:21:15)
    javascript.0	2019-03-24 08:23:01.123	warn	at Manager.ondata (/opt/iobroker/node_modules/socket.io-client/lib/manager.js:322:16)
    javascript.0	2019-03-24 08:23:01.123	warn	at Decoder.add (/opt/iobroker/node_modules/socket.io-parser/index.js:246:12)
    javascript.0	2019-03-24 08:23:01.123	warn	at Decoder.Emitter.emit (/opt/iobroker/node_modules/component-emitter/index.js:134:20)
    javascript.0	2019-03-24 08:23:01.123	warn	at Decoder.<anonymous> (/opt/iobroker/node_modules/component-bind/index.js:21:15)
    javascript.0	2019-03-24 08:23:01.123	warn	at Manager.ondecoded (/opt/iobroker/node_modules/socket.io-client/lib/manager.js:332:8)
    javascript.0	2019-03-24 08:23:01.123	warn	at Manager.Emitter.emit (/opt/iobroker/node_modules/socket.io-client/node_modules/component-emitter/index.js:133:20)
    javascript.0	2019-03-24 08:23:01.123	warn	at Manager.<anonymous> (/opt/iobroker/node_modules/component-bind/index.js:21:15)
    javascript.0	2019-03-24 08:23:01.123	warn	at Socket.onpacket (/opt/iobroker/node_modules/socket.io-client/lib/socket.js:228:12)
    javascript.0	2019-03-24 08:23:01.123	warn	at Socket.onevent (/opt/iobroker/node_modules/socket.io-client/lib/socket.js:270:10)
    javascript.0	2019-03-24 08:23:01.123	warn	at Socket.Emitter.emit (/opt/iobroker/node_modules/socket.io-client/node_modules/component-emitter/index.js:133:20)
    javascript.0	2019-03-24 08:23:01.123	warn	at Socket.<anonymous> (/opt/iobroker/node_modules/iobroker.js-controller/lib/states/statesInMemClient.js:52:30)
    javascript.0	2019-03-24 08:23:01.123	warn	at Object.change (/opt/iobroker/node_modules/iobroker.js-controller/lib/adapter.js:3705:37)
    javascript.0	2019-03-24 08:23:01.123	warn	at Object.stateChange (/opt/iobroker/node_modules/iobroker.javascript/main.js:364:25)
    javascript.0	2019-03-24 08:23:01.123	warn	at Object.callback (/opt/iobroker/node_modules/iobroker.javascript/lib/sandbox.js:963:38)
    javascript.0	2019-03-24 08:23:01.123	warn	at Object.<anonymous> (script.js.common.Skripte_aktiviert.homematic_Variablen_aus_openweathermap:19:1)
    javascript.0	2019-03-24 08:23:01.123	warn	at Wetterdatenholenundsetzen (script.js.common.Skripte_aktiviert.homematic_Variablen_aus_openweathermap:123:5)
    javascript.0	2019-03-24 08:23:01.123	warn	at setState (/opt/iobroker/node_modules/iobroker.javascript/lib/sandbox.js:1258:20)
    javascript.0	2019-03-24 08:23:01.123	warn	Wrong type of hm-rega.0.29959: "object". Please fix, while deprecated and will not work in next versions.
    Was will mir de Adapter sagen?
    @skorpil sagte:
    Wenn der Wert ein Object enthält, wird parseFloat() nicht helfen. Schau Dir den Wert mal mit einem zusätzlichen Log an.
    //Wetter Richtung als Zahl
    idOpenWeater = 'openweathermap.0.forecast.current.windDirection'/*Forecast for wind direction*/;
    log(JSON.stringify(getState(idOpenWeather).val));
    idVariable = 'hm-rega.0.29959'/*Wetter Windrichtg*/;
    Wetterdatenholenundsetzen();
    Variablen nur einmal deklarieren (var nur in den Zeilen 12, 13) !
    • S skorpil
      da der Fehler nicht immer auftritt: es scheint, dass der Adapter "openweathermap" für den Fall, daß keine Werte vorhanden sind, statt einer "Zahl" eine "null" liefert. Und das kann mein Script dann nicht mehr verarbeiten. Ich bin auch nicht sicher, ob "null" ein string oder ein logikwert ist. Irritierend.
      @skorpil sagte:
      Dann ist das der Grund für die Warnung: null ist ein Objekt !
      S sigi234S 2 Antworten Letzte Antwort
        @skorpil sagte:
        skorpil
        @paul53 Danke. Und wie könnte ich das abfangen? Also, irgendwas wie "wenn objekt, dann....."
          @skorpil sagte:
          sigi234S Online
          sigi234S Online
          @paul53 sagte in Bitte Hilfe bei Interpretation von Fehlermeldungen:
          Und wieder was gelernt....
          Zitat:
          parseFloat kann zudem Objekte parsen, wenn diese eine toString- oder valueOf-Methode haben. Das Ergebnis ist dasselbe, als wenn parseFloat mit dem Ergebnis einer dieser beiden Methoden ausgerufen wurde.
          • S skorpil
            @skorpil sagte:
            function Wetterdatenholenundsetzen() {
                wetterdaten = getState(idOpenWeater).val;
                if(wetterdaten) setState(idVariable, wetterdaten);
              skorpil
              schrieb am zuletzt editiert von skorpil
              merci, ich werde testen und berichten
                skorpil
                @paul53 dankeschön, das war es: "if (wetterdaten)". Denn augenscheinlich liefert der Adapter manchmal eben leere Objekte.
                  skorpil
                  @paul53 noch eine Frage: jetzt reagiert das Script ja nur, wenn ein Wert vorhanden ist. Eben durch die Abfrage if(Variable). Wie würde man das Gegenteil programmieren, also wenn „kein“ Wert vorhanden, dann.... ich würde nämlich gerne in meine CCU Variable noch schreiben, wenn kein Wert, dann „keine Angabe“.
                  • S skorpil
                    @skorpil sagte:
                        if(wetterdaten === null) wetterdaten = 'keine Angabe';
                    EDIT: Vergleich geändert, da Wert 0 ein gültiger Wert ist, der vorkommen kann.
                      @skorpil sagte:
                      skorpil
                      @paul53 großartig! Vielen Dank u. nun ein schönes Wochenende.
                      PS: ...wenn es dieses Forum nicht gäbe...
                      • S skorpil
                        @skorpil sagte in Bitte Hilfe bei Interpretation von Fehlermeldungen:
                        und warum bekommt Paul dann keine "postive Bewertung"
                        S HomoranH 2 Antworten Letzte Antwort
                          skorpil
                          @Homoran kriegt er ja gerne. Aber wie muß ich das machen?
                            skorpil
                            ...und der guten Ordnung halber noch das fertige Script. Es liest Daten aus openweathermap und schreibt sie in CCU Variablen. Sicher nicht profimäßig programmiert. Aber es läuft.
                            //    Wetterdaten aus openweathermap holen und in homematic Variable setzen
                            // Aktualisierung der homematic Variable bei Aktualisierung openweathermap
                            on ({id:'openweathermap.0.forecast.current.date'/*Actual date*/, change: 'any'}, function(data) {
                            //Werte holen und setzen
                            //Wetter Bedingung als String
                            var idOpenWeater = 'openweathermap.0.forecast.current.state'/*Actual state*/;
                            var idVariable = 'hm-rega.0.29954'/*Wetter Bedingungen*/;
                            if (wetterdaten) setState(idVariable, wetterdaten);
                            var idOpenWeater = 'openweathermap.0.forecast.current.windDirection'/*Forecast for wind direction*/;
                            //log(JSON.stringify(getState(idOpenWeater).val));
                            var idVariable = 'hm-rega.0.29959'/*Wetter Windrichtg*/;
                            //Wind Richtung als Angabe
                            var idVariable = 'hm-rega.0.29958'/*Wetter Windrichtung*/;
                                //******************* Windrichtung bestimmen***************
                                //*******************Nord 339-23, Nordost 24-68, Ost 69-113, SüdOst 114-158, Süd 159-203, SüdWest 204-248, West 249-293, NordWest 394-338***************
                                if (wetterdaten > 23 && wetterdaten <= 68){
                                    wetterdaten = "NordOst";
                                if (wetterdaten > 68 && wetterdaten <= 113){
                                    wetterdaten = "Ost";
                                if (wetterdaten > 113 && wetterdaten <= 158){
                                    wetterdaten = "SüdOst";
                                if (wetterdaten > 158 && wetterdaten <= 203){
                                    wetterdaten = "Süd";
                                if (wetterdaten > 203 && wetterdaten <= 248){
                                    wetterdaten = "SüdWest";
                                if (wetterdaten > 248 && wetterdaten <= 293){
                                    wetterdaten = "West";
                                if (wetterdaten > 293 && wetterdaten <= 338){
                                    wetterdaten = "NordWest";
                                if (wetterdaten > 338 && wetterdaten <= 360){
                                    wetterdaten = "Nord";
                                if (wetterdaten > 0 && wetterdaten <= 23){
                                if (!wetterdaten) {
                                    wetterdaten = "keine Angabe";
                            //Temperatur als Zahl
                            var idOpenWeater = 'openweathermap.0.forecast.current.temperature'/*Actual temperature for today*/
                            var idVariable = 'hm-rega.0.29955'/*Wetter Temperatur*/;
                            //Luftfeuchtigkeit als Zahl
                            var idOpenWeater = 'openweathermap.0.forecast.current.humidity'/*Actual humidity*/
                            var idVariable = 'hm-rega.0.29956'/*Wetter Luftfeuchte*/;
                            //Windgeschwindigkeit als Zahl
                            var idOpenWeater = 'openweathermap.0.forecast.current.windSpeed'/*Forecast for wind speed*/
                            var idVariable = 'hm-rega.0.29960'/*Wetter Windgeschwindigkeit*/;
                            //Aktualisierung (Zeit)
                            var idOpenWeater = 'openweathermap.0.forecast.current.date'/*Actual date*/;
                            var idVariable = 'hm-rega.0.29953'/*Wetter Aktualisierung*/;
                            var date = new Date(wetterdaten);
                            // Umwandeln in deutsches Format
                                //Tagesdatum ermitteln
                                var tag = date.getDate();
                                //Monat ermitteln
                                var month = new Array("1","2","3","4","5","6","7","8","9","10","11","12");
                                var monat = month[date.getMonth()];
                                if(monat.length < 2){
                                    monat = "0" + monat;
                                //Jahr ermitteln
                                var jahr = date.getFullYear();
                                //Stunde ermitteln
                                var stunde = date.getHours();
                                var stunde = stunde.toString();
                                if(stunde.length < 2){
                                    stunde = "0" + stunde;
                                //Minute ermitteln
                                var minute = date.getMinutes();
                                var minute = minute.toString();
                                if(minute.length < 2){
                                    minute = "0" + minute;
                                //Sekunde ermitteln
                                var sekunde = date.getSeconds();
                                var sekunde = sekunde.toString();
                                if(sekunde.length < 2){
                                    sekunde = "0" + sekunde;
                            var ausgabe = tag + "." + monat + "." + jahr + "   " + stunde + ":" + minute + ":" + sekunde;
                            setState(idVariable, ausgabe);
                            //                  FUNKTION Holen und setzen
                                if (wetterdaten != null) setState(idVariable, wetterdaten);
                              Wenn du die Signaturen ausgeblendet hast, kannst du es natürlich nicht lesen ;-) :
                              Unter jedem Beitrag befindet sich rechts unten neben "Zitieren" eine Bewertungsinfo mit einem "Bewertung hoch" ^ - dann dem Wert der Bewertung für diesen Beutrag (leider 0) und dann ein "Bewertung runter" Icon um wie auch immer geartetet schlechte Beiträge auch negativ beurteilen zu können
                              • S skorpil
                                    if (!wetterdaten) {
                                    //Monat ermitteln
                                    //Jahr ermitteln
                                    //Stunde ermitteln
                                    //Minute ermitteln
                                    //Sekunde ermitteln
                                @skorpil sagte:
                                das fertige Script.
                                Ändere bitte noch
                                in
                                da sonst die Aussentemperatur von 0 °C nicht in die SV geschrieben wird.
                                  skorpil
                                  @Homoran Dankeschön! Wußte ich nicht!
                                    @skorpil sagte:
                                    das fertige Script.
                                    Ändere bitte noch
                                    in
                                    skorpil
                                    @paul53 Danke! Habe ich nun auch in obigem Script geändert!
