  4. Weatherunderground Adapter Reborn 3.0
    6.0k
adapterweatherundergroundwetter
160 Beiträge 34 Kommentatoren 31.7k Aufrufe 29 Beobachtet
    abg0002
    weatherunderground.0 2019-05-26 23:48:03.129 error TypeError: Cannot read property 'replace' of undefined at modifyExtractedUrl (/opt/iobroker/node_modules/iobroker.weatherunderground/main.js:1464:15) at getNewWuDataDailyForcast (/opt/iobroker
    weatherunderground.0 2019-05-26 23:48:03.129 error uncaught exception: Cannot read property 'replace' of undefined
    weatherunderground.0 2019-05-26 23:48:03.128 error Key rejected, reset webkey and try again
    weatherunderground.0 2019-05-26 23:48:03.043 debug get current observation data: https://api.weather.com/v2/pws/observations/current?stationId=IHORN16&format=json&units=m&apiKey=
    weatherunderground.0 2019-05-26 23:48:03.043 debug Use new API Key
    weatherunderground.0 2019-05-26 23:48:03.043 debug Use New API
    weatherunderground.0 2019-05-26 23:48:03.041 error Unable to get WU weather page: 403/null
    weatherunderground.0 2019-05-26 23:48:02.903 debug get WU weather page: https://www.wunderground.com/hourly/DE/Hamburg
    weatherunderground.0 2019-05-26 23:48:02.903 error Unable to get PWS dashboard page: null
    weatherunderground.0 2019-05-26 23:48:02.775 debug get PWS dashboard page: https://www.wunderground.com/personal-weather-station/dashboard?ID=IHORN16
    weatherunderground.0 2019-05-26 23:48:02.774 error Key rejected, reset webkey and try again
    weatherunderground.0 2019-05-26 23:48:02.683 debug get current observation data: https://api.weather.com/v2/pws/observations/current?stationId=IHORN16&format=json&units=m&apiKey=
    weatherunderground.0 2019-05-26 23:48:02.683 debug Use new API Key
    weatherunderground.0 2019-05-26 23:48:02.683 debug Use New API
    weatherunderground.0 2019-05-26 23:48:02.682 error Unable to get WU weather page: 403/null
    weatherunderground.0 2019-05-26 23:48:02.560 debug get WU weather page: https://www.wunderground.com/hourly/DE/Hamburg
    weatherunderground.0 2019-05-26 23:48:02.559 error Unable to get PWS dashboard page: null
    weatherunderground.0 2019-05-26 23:48:02.433 debug get PWS dashboard page: https://www.wunderground.com/personal-weather-station/dashboard?ID=IHORN16
    weatherunderground.0 2019-05-26 23:48:02.432 error Key rejected, reset webkey and try again
    weatherunderground.0 2019-05-26 23:48:02.231 debug get current observation data: https://api.weather.com/v2/pws/observations/current?stationId=IHORN16&format=json&units=m&apiKey=undefined
    weatherunderground.0 2019-05-26 23:48:02.231 debug Use new API Key undefined
    weatherunderground.0 2019-05-26 23:48:02.231 debug Use New API
    weatherunderground.0 2019-05-26 23:48:02.230 error Unable to get WU weather page: 403/null
    weatherunderground.0 2019-05-26 23:48:02.104 debug get WU weather page: https://www.wunderground.com/hourly/DE/Hamburg
    weatherunderground.0 2019-05-26 23:48:02.103 error Unable to get PWS dashboard page: null
    weatherunderground.0 2019-05-26 23:48:01.843 debug get PWS dashboard page: https://www.wunderground.com/personal-weather-station/dashboard?ID=IHORN16
    weatherunderground.0 2019-05-26 23:48:01.841 debug location has not changed, reuse extracted URLs
    weatherunderground.0 2019-05-26 23:48:01.710 debug init forecast objects
    weatherunderground.0 2019-05-26 23:48:01.710 debug init conditions objects
    weatherunderground.0 2019-05-26 23:48:01.710 debug on ready: DL true true true true
    weatherunderground.0 2019-05-26 23:48:01.710 info starting. Version 3.0.9 in /opt/iobroker/node_modules/iobroker.weatherunderground, node: v8.16.0
      abg0002
      crazy scheint mir, dass er bereits diese Seiten nicht abrufen kann
      • v522533V Offline
        v522533V Offline
        v522533
        bei mir das gleiche, bekomme auch die Fehlermeldung, egal was ich eingebe. Ort Koordinaten, Stations-ID, nächstgrößerer Ort, Geokoordinaten. Funktioniert leider nicht.
        Gruß Chris
          abg0002
          Habe mal mit wget auf dem Host, auf dem ioBroker läuft, versucht die Seite abzurufen.
          Da schau her, es erfolgt ein Redirect (301) zu einer anderen Adresse:
          wird per 301 weitergeleitet zu
          https://www.wunderground.com/dashboard/pws/IHORN16
          wget https://www.wunderground.com/personal-weather-station/dashboard?ID=IHORN16
          --2019-05-27 20:39:24-- https://www.wunderground.com/personal-weather-station/dashboard?ID=IHORN16
          Auflösen des Hostnamens »www.wunderground.com (www.wunderground.com)« … 23.51.108.33
          Verbindungsaufbau zu www.wunderground.com (www.wunderground.com)|23.51.108.33|:443 … verbunden.
          HTTP-Anforderung gesendet, auf Antwort wird gewartet … 301 Moved Permanently
          Platz: https://www.wunderground.com/dashboard/pws/IHORN16 [folgend]
          --2019-05-27 20:39:24-- https://www.wunderground.com/dashboard/pws/IHORN16
          Wiederverwendung der bestehenden Verbindung zu www.wunderground.com:443.
          HTTP-Anforderung gesendet, auf Antwort wird gewartet … 200 OK
          Länge: nicht spezifiziert [text/html]
          Wird in »»dashboard?ID=IHORN16«« gespeichert.
          • apollon77A Offline
            Der Adapter folgt an sich genau diesen Redirects. Ok, kann es nachvollziehen. Ich schaue mal
              WU ist etwas schärfer bei den Abfragen geworden. Habe eine 3.0.10 auf GitHub die bei mir wieder tut. Bitte mal testen und Feedback geben.
              • apollon77A apollon77
                NegaleinN Offline
                NegaleinN Offline
                Negalein
                @apollon77 sagte in Weatherunderground Adapter Reborn 3.0:
                Ich komm nur auf die 3.0.9
                Habs über die Katze mit https://github.com/dschaedl/ioBroker.weatherunderground versucht.
                ° Fixer ---> iob fix
                  https://github.com/iobroker-community-adapters/ioBroker.weatherunderground (wobei sollten beide URLs gleich funktionieren).
                  ggf danach manuell ein iobroker upload weatherundergound? Bei mir tat das update auf einem zweiten System auch per dschaedl URL ...
                    NegaleinN Offline
                    NegaleinN Offline
                    Negalein
                    Bleibt auch auf 3.0.9
                    Bekomme NPM Errors
                    $ ./iobroker url "https://github.com/iobroker-community-adapters/ioBroker.weatherunderground"
                    install https://github.com/iobroker-community-adapters/ioBroker.weatherunderground/tarball/master
                    npm install https://github.com/iobroker-community-adapters/ioBroker.weatherunderground/tarball/master --production --save --prefix "/opt/iobroker" (System call)
                    npm
                     WARN enoent ENOENT: no such file or directory, open '/opt/iobroker/node_modules/iobroker.discovery/node_modules/arr-swap/package.json'npm WARN enoent ENOENT: no such file or directory, open '/opt/iobroker/node_modules/iobroker.discovery/node_modules/choices-separator/package.json'
                    npm WARN enoent ENOENT: no such file or directory, open '/opt/iobroker/node_modules/iobroker.discovery/node_modules/clone-deep/package.json'
                    npm WARN enoent ENOENT: no such file or directory, open '/opt/iobroker/node_modules/iobroker.discovery/node_modules/prompt-actions/package.json'
                    npm WARN enoent ENOENT: no such file or directory, open '/opt/iobroker/node_modules/iobroker.discovery/node_modules/prompt-choices/package.json'
                    npm WARN enoent ENOENT: no such file or directory, open '/opt/iobroker/node_modules/iobroker.discovery/node_modules/prompt-question/package.json'npm WARN enoent ENOENT: no such file or directory, open '/opt/iobroker/node_modules/iobroker.discovery/node_modules/shallow-clone/package.json'
                    npm ERR! path /opt/iobroker/node_modules/iobroker.weatherunderground/node_modules/.bin/uuidnpm ERR!
                    code EEXISTnpm ERR! Refusing to delete /opt/iobroker/node_modules/iobroker.weatherunderground/node_modules/.bin/uuid: is outside /opt/iobroker/node_modules/iobroker.weatherunderground/node_modules/uuid and not a link
                    npm ERR! File exists: /opt/iobroker/node_modules/iobroker.weatherunderground/node_modules/.bin/uuid
                    npm ERR! Move it away, and try again.
                    npm ERR! A complete log of this run can be found in:npm ERR!     /home/iobroker/.npm/_logs/2019-05-27T22_10_15_876Z-debug.log
                    process exited with code 0
                    Upload danach läuft ohne Fehler durch
                    $ ./iobroker upload weatherunderground
                    got /opt/iobroker/node_modules/iobroker.weatherunderground/admin
                    upload [2] weatherunderground.admin /opt/iobroker/node_modules/iobroker.weatherunderground/admin/wu.png wu.png image/png
                    upload [1] weatherunderground.admin /opt/iobroker/node_modules/iobroker.weatherunderground/admin/words.js words.js application/javascript
                    upload [0] weatherunderground.admin /opt/iobroker/node_modules/iobroker.weatherunderground/admin/index_m.html index_m.html text/html
                      Naja der NPM Fehler bedeutet das er nichts installiert hat. Lösch mal das File was er anmeckert. Kann es sein das Du irgendwie dinge aus nem Backup zurückgespielt hast oder sowas? Oder durch die Gegend kopiert hast mit "cp"?
                      Ich hatte diesen Fehler als ich mal was mit cp kopiert habe ohne symbolische Links zu beachten und damit hat er alle Links in Files verwandelt und genau das führte zu diesem Fehler weil er an der Stelle nur Links erwartet!
                      Hat mit dem Adapter nix zu tun ... da ist irgendwas in deiner Verzeichnisstruktur komisch
                      A 1 Antwort Letzte Antwort
                        abg0002
                        @apollon77
                        Klasse, das funktioniert jetzt! Super Arbeit!
                        Was mich nur wundert, dass es auf dem anderen System nach wie vor läuft mit der 3.0.9
                          Der Adapter holt sich API keys aus den Webseiten falls keine da sind und genau bei dem Schritt gab es Probleme. Wenn die API Keys extrahiert sind werden Sie gespeichert und dann direkt genutzt um die Daten abzuholen. Nur falls da ein Fehler zurückkommen würde, würden die Keys neu geholt.
                          Von daher sind primär neuinstallationen betroffen.
                            abg0002
                            @apollon77
                            hab mir grad mal die Änderungen angesehen. Mit dem Header hätte ich auch drauf kommen können....
                            Zeigt ja aber auf, das WU da weiter die Zugriffe eindämmen will, oder?
                              We will see ... :-) The fight has started
                              • padrinoP Online
                                padrinoP Online
                                padrino
                                Kann mir jemand sagen, wie man dan Adapter nutzt bzw. gibt es eine Anleitung dafür?
                                Hab ihn und eine Instanz installiert, aber eine Objektstruktur legt er nicht an und auch bei Instanzen hat er keine "Status LED"?
                                Bin also ratlos... :(
                                  Alles einstellen, dann hat der Adapter eine "Schedule" (denke im normalfall läuft der einmal die Stunde zu Minute 12, siehe Info unter Instanzen da gibt es eine Spalte mit "12 * * * *" Kannst Du ändern). Die Objekte werden angelegt sobald er das erste mal Daten liesst, kann also dann "verspätet" kommen.
                                  padrinoP 1 Antwort Letzte Antwort
                                    padrinoP Online
                                    padrinoP Online
                                    padrino
                                    schrieb am zuletzt editiert von padrino
                                    @apollon77
                                    Danke, alles klar, damit (also Warten ;)) wurden die Objekte erzeugt. =)
                                    Leider läuft es nicht
                                    ohne "Ältere WU-APIs nutzen" spuckt das log
                                    2019-06-03 17:56:01.833 - info: weatherunderground.0 starting. Version 3.0.10 in /opt/iobroker/node_modules/iobroker.weatherunderground, node: v8.11.4
                                    2019-06-03 17:56:05.100 - error: weatherunderground.0 Unable to get PWS dashboard page: null / 503
                                    2019-06-03 17:56:05.645 - error: weatherunderground.0 exception in : body.daily_forecast2TypeError: original.lastIndexOf is not a function
                                    aus, mit "Ältere WU-APIs nutzen"
                                    2019-06-03 17:58:01.823 - info: weatherunderground.0 starting. Version 3.0.10 in /opt/iobroker/node_modules/iobroker.weatherunderground, node: v8.11.4
                                    2019-06-03 17:58:05.016 - error: weatherunderground.0 Unable to get PWS dashboard page: null / 503
                                    2019-06-03 17:58:05.266 - error: weatherunderground.0 Wunderground reported an error: null, 401
                                      Einstellunegn bzw Debug Log bitte.
                                        sigi234S Online
                                        sigi234S Online
                                        sigi234
                                        @apollon77
                                        Leider auch bei mir.............Es kommen keine Daten mehr.
                                        weatherunderground.0	2019-06-04 11:43:03.870	error	Wunderground reported an error: null, 401
                                        weatherunderground.0	2019-06-04 11:43:03.609	debug	get WU legacy data: http://api.wunderground.com/api/undefined/forecast/hourly/conditions/units:m/lang:DL/q/xx.xxxxxxxxx%xxxxxxxxxxx.json
                                        weatherunderground.0	2019-06-04 11:43:03.609	debug	Use legacy API Key undefined
                                        weatherunderground.0	2019-06-04 11:43:03.609	debug	Use Legacy API
                                        weatherunderground.0	2019-06-04 11:43:03.608	error	Unable to get PWS dashboard page: null / 503
                                        weatherunderground.0	2019-06-04 11:43:00.928	debug	get PWS dashboard page: https://www.wunderground.com/personal-weather-station/dashboard
                                        weatherunderground.0	2019-06-04 11:43:00.927	debug	location has not changed, reuse extracted URLs
                                        weatherunderground.0	2019-06-04 11:43:00.924	debug	initialize Hourly Forecast Url: https://api.weather.com/v1/geocode/48.15/14.24/forecast/hourly/240hour.json?apiKey=xxxxxxxxxxxxxxxxx&units=e&language=en-US
                                        weatherunderground.0	2019-06-04 11:43:00.921	debug	initialize Daily Forecast Url: https://api.weather.com/v1/geocode/xx.xx/forecast/daily/5day.json?apiKey=xxxxxxxxxxxxxxxx&units=e&language=en-US
                                        weatherunderground.0	2019-06-04 11:43:00.918	debug	initialize Current Observation url: https://api.weather.com/v2/pws/observations/current?apiKey=xxxxxxxxxxxxxxxxxx&units=e&stationId=xxxxxxxxxxxx&format=json
                                        weatherunderground.0	2019-06-04 11:43:00.916	debug	initialize Web Key: xxxxxxxxxxxxxxxxxxxxxxx
                                        weatherunderground.0	2019-06-04 11:43:00.589	debug	init forecast objects
                                        weatherunderground.0	2019-06-04 11:43:00.587	debug	init conditions objects
                                        weatherunderground.0	2019-06-04 11:43:00.585	debug	on ready: DL true true true true
                                        weatherunderground.0	2019-06-04 11:43:00.573	info	starting. Version 3.0.10 in C:/ioBroker/node_modules/iobroker.weatherunderground, node: v10.16.0
                                        weatherunderground.0	2019-06-04 11:43:00.561	debug	statesDB connected
                                        weatherunderground.0	2019-06-04 11:43:00.551	debug	objectDB connected
                                        weatherunderground.0	2019-06-04 11:41:05.571	error	Wunderground reported an error: null, 401
                                        weatherunderground.0	2019-06-04 11:41:05.312	error	Unable to get PWS dashboard page: null / 503
                                        weatherunderground.0	2019-06-04 11:41:01.628	info	starting. Version 3.0.10 in C:/ioBroker/node_modules/iobroker.weatherunderground, node: v10.16.0
                                        Platform: Windows
                                        Architecture: x64
                                        RAM: 7.9 GB
                                        Node.js: v10.16.0
                                        NPM: 6.9.0
                                        Admin: 3.6.3
                                        JS: 1.5.12
                                        Active instances: 45
                                        WU.log
                                        Immer Daten sichern!
                                        crunchipC apollon77A 2 Antworten Letzte Antwort
                                        • sigi234S sigi234
                                          @apollon77
                                          Platform: Windows
                                          Architecture: x64
                                          RAM: 7.9 GB
                                          Node.js: v10.16.0
                                          NPM: 6.9.0
                                          Admin: 3.6.3
                                          JS: 1.5.12
                                          WU.log
                                          crunchipC Abwesend
                                          crunchipC Abwesend
                                          @sigi234 DE funktioniert noch😆
                                          @apollon77 Messstation ist bei mir angegeben
