  4. Update Javascript-Adapter schlägt fehl
javascript adaptererror
2 Beiträge 2 Kommentatoren 436 Aufrufe
  • K Offline
    Kylo Ren
    Hallo Zusammen,
    beim Update des Javascript-Adapters kommt folgende Fehlermeldung:
    $ ./iobroker upgrade javascript
    Update javascript from @4.0.11 to @4.1.12
    NPM version: 6.9.0
    npm install iobroker.javascript@4.1.12 --production --save --prefix "/opt/iobroker" (System call)
    npm
    WARN deprecated coffee-script@1.12.7: CoffeeScript on NPM has moved to "coffeescript" (no hyphen)
    npm
    WARN checkPermissions Missing write access to /opt/iobroker/node_modules/@types
    npm
    WARN
     enoent ENOENT: no such file or directory, open '/opt/iobroker/node_modules/bufferutil/package.json'
    npm WARN
    enoent
     ENOENT: no such file or directory, open '/opt/iobroker/node_modules/utf-8-validate/package.json'
    npm
    WARN
     enoent ENOENT: no such file or directory, open '/opt/iobroker/node_modules/build/package.json'npm
    WARN enoent ENOENT: no such file or directory, open '/opt/iobroker/node_modules/kodi-ws/node_modules/build/package.json'
    npm WARN
     babel-eslint@5.0.4 requires a peer of eslint@<2.3.0 but none is installed. You must install peer dependencies yourself.
    npm
    ERR! path
     /opt/iobroker/node_modules/@typesnpm
    ERR! code EACCES
    npm ERR!
    errno -13
    npm ERR! syscall access
    npm
    ERR! Error: EACCES: permission denied, access '/opt/iobroker/node_modules/@types'npm
     ERR!
      { Error: EACCES: permission denied, access '/opt/iobroker/node_modules/@types'npm ERR!
       stack: 'Error: EACCES: permission denied, access \'/opt/iobroker/node_modules/@types\'',
    npm ERR!   errno: -13,
    npm ERR!   code: 'EACCES',npm ERR!   syscall: 'access',
    npm ERR!
       path: '/opt/iobroker/node_modules/@types' }npm
    ERR! npm
     ERR! The operation was rejected by your operating system.npm ERR! It is likely you do not have the permissions to access this file as the current user
    npm ERR!
    npm ERR! If you believe this might be a permissions issue, please double-check the
    npm ERR! permissions of the file and its containing directories, or try running
    npm ERR! the command again as root/Administrator (though this is not recommended).
    npm ERR!
     A complete log of this run can be found in:
    npm
     ERR!     /home/iobroker/.npm/_logs/2019-03-15T23_31_34_360Z-debug.log
    ERROR: host.iobroker Cannot install iobroker.javascript@4.1.12: 243
    ioBroker auf Debian 12 (ESXi) • Echo dot • Steckdosen mit Tasmota • Broadlink RM pro • rund 20 Shellys • FritzBox 6490 + 7490 • 12 x Fritz!Dect 301
    • htreckslerH Offline
      htreckslerH Offline
      htrecksler
      Forum Testing
      Der meckert fehlende Berechtigungen an und sagt du sollst es nochmal als root/Adminstrator versuchen
      Gruss Hermann
      ioBroker auf Proxmox (Debian) auf IntelNuc als Produktivsystem
