  4. JS Adapter? heap out of memory
heap out of memory
8 Beiträge 5 Kommentatoren 1.8k Aufrufe 3 Beobachtet
  • kmxakK Offline
    kmxakK Offline
    kmxak
    Moin, hatte gestern Abend die erste Meldung darauf hin hatte ich den ioBroker neu gestartet ohne Erfolg.
    Dann alle JavaScripte gestoppt und den Adapter neu gestartet und die Scripte einzeln wieder eingeschaltet.
    Seit dem lief es wieder bis gerade eben.
    Folgende Fehlermeldung bekomme ich:
    host.ioBroker	2019-03-09 13:06:07.989	error	instance system.adapter.admin.0 terminated with code null ()
    host.ioBroker	2019-03-09 13:06:07.989	warn	instance system.adapter.admin.0 terminated due to SIGABRT
    Caught	2019-03-09 13:06:07.989	error	by controller[13]: 12: 0x1f763431b2e7
    Caught	2019-03-09 13:06:07.989	error	by controller[13]: [io.admin.0]
    Caught	2019-03-09 13:06:07.989	error	by controller[12]: 0x8e9444
    Caught	2019-03-09 13:06:07.989	error	by controller[11]: 11:
    Caught	2019-03-09 13:06:07.989	error	by controller[11]: node::Buffer::New(v8::Isolate*, v8::Local<v8::String>, node::encoding) [io.admin.0]
    Caught	2019-03-09 13:06:07.989	error	by controller[10]: 10:
    Caught	2019-03-09 13:06:07.989	error	by controller[10]: node::StringBytes::Write(v8::Isolate*, char*, unsigned long, v8::Local<v8::Value>, node::encoding, int*) [io.admin.0]
    Caught	2019-03-09 13:06:07.989	error	by controller[9]: 9:
    Caught	2019-03-09 13:06:07.989	error	by controller[9]: v8::String::WriteUtf8(char*, int, int*, int) const [io.admin.0]
    Caught	2019-03-09 13:06:07.989	error	by controller[8]: 8:
    Caught	2019-03-09 13:06:07.989	error	by controller[8]: v8::internal::String::Flatten(v8::internal::Handle<v8::internal::String>, v8::internal::PretenureFlag) [io.admin.0]
    Caught	2019-03-09 13:06:07.989	error	by controller[7]: 7:
    Caught	2019-03-09 13:06:07.989	error	by controller[7]: v8::internal::String::SlowFlatten(v8::internal::Handle<v8::internal::ConsString>, v8::internal::PretenureFlag) [io.admin.0]
    Caught	2019-03-09 13:06:07.989	error	by controller[6]: 6:
    Caught	2019-03-09 13:06:07.989	error	by controller[6]: v8::internal::Factory::NewRawTwoByteString(int, v8::internal::PretenureFlag) [io.admin.0]
    Caught	2019-03-09 13:06:07.989	error	by controller[5]: 5:
    Caught	2019-03-09 13:06:07.989	error	by controller[5]: v8::internal::V8::FatalProcessOutOfMemory(char const*, bool) [io.admin.0]
    Caught	2019-03-09 13:06:07.989	error	by controller[4]: 4:
    Caught	2019-03-09 13:06:07.988	error	by controller[4]: v8::Utils::ReportOOMFailure(char const*, bool) [io.admin.0]
    Caught	2019-03-09 13:06:07.988	error	by controller[3]: 3:
    Caught	2019-03-09 13:06:07.988	error	by controller[3]: 0x8ccf9c [io.admin.0]
    Caught	2019-03-09 13:06:07.988	error	by controller[2]: 2:
    Caught	2019-03-09 13:06:07.988	error	by controller[2]: node::Abort() [io.admin.0]
    Caught	2019-03-09 13:06:07.988	error	by controller[1]: 1:
    Caught	2019-03-09 13:06:07.988	error	by controller[0]: FATAL ERROR: CALL_AND_RETRY_LAST Allocation failed - JavaScript heap out of memory
    root@ioBroker:/home/alex# free -m
    Mem:           5829        3236        1939          50         653        2310
    Swap:          5996         328        5668
    Im Error steht auch der Admin Adapter. Sehe ich das ggf. falsch und der verursacher ist der Admin Adapter?
    Dieser ist teilweise auch echt langsam.
    Hat einer eine Idee?
    Gruß Alex
    • apollon77A Offline
      Welche nodejs Version ist im Einsatz? Welche js-controller Version? Welche javascript Adapter Version?
      Ein paar mehr Infos wären schon schön ;-)
      • kmxakK kmxak
        Swap:          5996         328        5668
        HomoranH Offline
        HomoranH Offline
        @kmxak sagte in JS Adapter? heap out of memory:
        Swap:          5996         328        5668
        Der Speicher ist knapp - der Swap wird schon benutzt
          Swap:          5996         328        5668
          SegwayS Offline
          SegwayS Offline
          Segway
          @Homoran sagte in JS Adapter? heap out of memory:
          Ist das so? Available ist ja noch über 2000 !
          Gruß Dirk
          • SegwayS Segway
            HomoranH Offline
            HomoranH Offline
            @Segway
            bessere Formulierung?:
            Der Speicher ist knapp gewesen - der Swap wurde schon benutzt
            • kmxakK kmxak
              Swap:          5996         328        5668
              @kmxak Vielleicht hilft das hier ?
              Es hat nichts mit dem JS-Adapter zu tun, sondern mit Node.js.
              • kmxakK Offline
                kmxakK Offline
                kmxak
                Node.js
                v8.15.0
                NPM
                6.4.1
                JS Controller
                1.4.2
                Alle Adapter auf latest aktuell.
                Der Fehler ist seit dem auch nicht mehr aufgetreten. An dem Tag ging nix...
                War sehr komisch.
                Danke paul53 werde ich mal testen falls es mal wieder auftritt
                Gruß Alex
                  Ok, also die nodejs version sollte nicht vom memory leak betroffen sein.
                  Was mir da noch so in den Sinn kommt: Was laufen denn da so für Skripte? Haben die alle gescheites Fehlerhandling? Vllt ist an dem tag ne externe Seite oder irgendwas abhängiggen nicht erreichbar gewesen und daher ein Skript wegen mangelndem Fehler-Handling amok gelaufen?
                  (zB externe URL wird per setInterval regelmässig abgefragt und hatte Timeouts und es haben sich daher laufende requests angestaut weil setInterval halt immer weiter neue requests macht ohne darauf zu achten ob der letzte beendet ist oder sowas)
