Warnings bei Adapterinstallationen und Updates
Muß man bei folgenden Warnings was machen, oder macht man da eher ältere Adapter kaputt? Gibt es dafür eine Anleitung?
npm WARN deprecated gulp-util@3.0.8: gulp-util is deprecated - replace it, following the guidelines at https://medium.com/gulpjs/gulp-util-ca3b1f9f9ac5 npm WARN deprecated graceful-fs@3.0.11: please upgrade to graceful-fs 4 for compatibility with current and future versions of Node.js npm WARN deprecated minimatch@2.0.10: Please update to minimatch 3.0.2 or higher to avoid a RegExp DoS issue npm WARN deprecated minimatch@0.2.14: Please update to minimatch 3.0.2 or higher to avoid a RegExp DoS issue npm WARN deprecated graceful-fs@1.2.3: please upgrade to graceful-fs 4 for compatibility with current and future versions of Node.jsGruß klausiob
Hallo, ich möchte nochmal die Frage stellen, um die Warnings bei Updates und Installationen wegzubekommen die Aufgabe der Entwickler oder der User.
npm WARN optional SKIPPING OPTIONAL DEPENDENCY: xpc-connection@0.1.4 (node_modules/xpc-connection):npm WARN notsup SKIPPING OPTIONAL DEPENDENCY: Unsupported platform for xpc-connection@0.1.4: wanted {"os":"darwin","arch":"any"} (current: {"os":"linux","arch":"arm"}) npm install --production (System call) in "/opt/iobroker/node_modules/iobroker.backitup" npm WARN deprecated gulp-util@3.0.8: gulp-util is deprecated - replace it, following the guidelines at https://medium.com/gulpjs/gulp-util-ca3b1f9f9ac5 npm WARN deprecated graceful-fs@3.0.11: please upgrade to graceful-fs 4 for compatibility with current and future versions of Node.js npm WARN deprecated minimatch@2.0.10: Please update to minimatch 3.0.2 or higher to avoid a RegExp DoS issue npm WARN deprecated minimatch@0.2.14: Please update to minimatch 3.0.2 or higher to avoid a RegExp DoS issue npm WARN deprecated graceful-fs@1.2.3: please upgrade to graceful-fs 4 for compatibility with current andauch beim Update von Javascript gibt es immer ein problem mit coffescript.
@klausiob sagte in Warnings bei Adapterinstallationen und Updates:
Der Satz ergibt keinen Sinn
@Homoran Naja an wen sind denn diese Aufforderungen gerichtet "Please update to minimatch 3.0.2 or higher to avoid a RegExp DoS issue"? An den Entwickler des Adapters oder an mich, dem Nutzer des Adapters.
ich habe die "Warnings" auch.
Da es ja bei verschiedenen Adaptern kommt muss es ja an einer Zentralen stelle gefixt werden denke ich, oder?
Wenn ja, welches ist denn die Zentrale Stelle? JS-Controller ? Admin ? oder ?
Würde gerne an der richtigen Stelle ein Issue dazu öffnen.
@wendy2702
da müssen einige dependencys geändert werden
