  2. Русский
  3. ioBroker
  4. ioBroker драйвера
  5. Драйвер ioBroker MySensors
    5.9k
106 Beiträge 13 Kommentatoren 41.9k Aufrufe
    Maxtox
    after a new reset ардуины:
    the LOG:
    [color]host-raspberrypi	2016-02-19 19:53:16	info	Restart adapter system.adapter.mysensors.0 because enabled
    host-raspberrypi	2016-02-19 19:53:16	error	instance system.adapter.mysensors.0 terminated with code 6 (uncaught exception)
    mysensors-0	2016-02-19 19:53:16	info	cleaned everything up...
    TypeError:	2016-02-19 19:53:16	error	at /opt/iobroker/node_modules/iobroker.mysensors/node_modules/serialport/serialport.js:388:9
    TypeError:	2016-02-19 19:53:16	error	at afterRead (/opt/iobroker/node_modules/iobroker.mysensors/node_modules/serialport/serialport.js:372:20)
    TypeError:	2016-02-19 19:53:16	error	at SerialPortFactory.SerialPort._emitData (/opt/iobroker/node_modules/iobroker.mysensors/node_modules/serialport/serialport.js:396:20)
    TypeError:	2016-02-19 19:53:16	error	at Object.SerialPort.opts.dataCallback (/opt/iobroker/node_modules/iobroker.mysensors/node_modules/serialport/serialport.js:181:12)
    TypeError:	2016-02-19 19:53:16	error	at Object.parser (/opt/iobroker/node_modules/iobroker.mysensors/node_modules/serialport/parsers.js:24:13)
    TypeError:	2016-02-19 19:53:16	error	at Array.forEach (native)
    TypeError:	2016-02-19 19:53:16	error	at /opt/iobroker/node_modules/iobroker.mysensors/node_modules/serialport/parsers.js:25:17
    TypeError:	2016-02-19 19:53:16	error	at SerialPort.EventEmitter.emit (events.js:95:17)
    TypeError:	2016-02-19 19:53:16	error	at SerialPort. (/opt/iobroker/node_modules/iobroker.mysensors/mysensors.js:293:8)
    TypeError:	2016-02-19 19:53:16	error	at mkdbmsgUnique (/opt/iobroker/node_modules/iobroker.mysensors/mysensors.js:121:23)
    TypeError:	2016-02-19 19:53:16	error	Cannot read property 'id' of undefined
    uncaught	2016-02-19 19:53:16	error	exception: Cannot read property 'id' of undefined
    mysensors-0	2016-02-19 19:53:16	info	Rx-Raw 255
    mysensors-0	2016-02-19 19:53:16	info	__0_|_255_|_internal_|_false_|_I_SKETCH_VERSION_|_1.0
    mysensors-0	2016-02-19 19:53:16	debug	количество сообщений 3
    mysensors-0	2016-02-19 19:53:16	info	Rx-Raw 0;255;3;0;12;1.0
    mysensors-0	2016-02-19 19:53:16	info	__0_|_255_|_internal_|_false_|_I_SKETCH_NAME_|_ETHduino by JR
    mysensors-0	2016-02-19 19:53:16	debug	количество сообщений 2
    mysensors-0	2016-02-19 19:53:16	info	Rx-Raw 0;255;3;0;11;ETHduino by JR
    mysensors-0	2016-02-19 19:53:16	info	__0_|_255_|_internal_|_false_|_I_GATEWAY_READY_|_Gateway startup complete.
    mysensors-0	2016-02-19 19:53:16	debug	количество сообщений 1
    mysensors-0	2016-02-19 19:53:16	info	Rx-Raw 0;255;3;0;14;Gateway startup complete.
    mysensors-0	2016-02-19 19:53:16	info	__Temperature for the sensor 42 is0_|_255_|_internal_|_false_|_I_LOG_MESSAGE_|_Starting gateway (R-NGA-, 2.0.0-beta)
    mysensors-0	2016-02-19 19:53:16	debug	количество сообщений 0
    mysensors-0	2016-02-19 19:53:16	info	Rx-Raw Temperature for the sensor 42 is0;255;3;0;9;Starting gateway (R-NGA-, 2.0.0-beta)
    mysensors-0	2016-02-19 19:53:15	debug	Communication port:/dev/ttyUSB0
    mysensors-0	2016-02-19 19:53:15	info	starting. Version 0.0.1 in /opt/iobroker/node_modules/iobroker.mysensors
    mysensors-0	2016-02-19 19:53:14	debug	statesDB connected
    mysensors-0	2016-02-19 19:53:14	debug	objectDB connected[/color]
    Arduino MEGA 2560 R3 / ioBroker / DOino Sketch
    • V Offline
      V Offline
      Vlad_k
      Переустанавливай драйвер, сделал фильтрацию мусора, должно работать.
      ты сам скетч писал?
        Maxtox
        Да… Писал сам....
        Спасибо!
        Сейчас оттестю...
          Maxtox
          Console LOG:
          root@raspberrypi:/opt/iobroker# npm install https://github.com/DJONvl/iobroker.myse … all/master
          npm http GET https://github.com/DJONvl/iobroker.myse ... all/master
          npm http 200 https://github.com/DJONvl/iobroker.myse ... all/master
          npm http GET https://registry.npmjs.org/sensors
          npm http GET https://registry.npmjs.org/serialport
          npm http 304 https://registry.npmjs.org/sensors
          npm http 304 https://registry.npmjs.org/serialport
          npm http GET https://registry.npmjs.org/optimist
          npm http GET https://registry.npmjs.org/nan
          npm http GET https://registry.npmjs.org/bindings/1.2.1
          npm http GET https://registry.npmjs.org/sf/0.1.7
          npm http GET https://registry.npmjs.org/async/0.9.0
          npm http GET https://registry.npmjs.org/debug
          npm http 304 https://registry.npmjs.org/nan
          npm http 304 https://registry.npmjs.org/debug
          npm http 304 https://registry.npmjs.org/sf/0.1.7
          npm http 200 https://registry.npmjs.org/optimist
          npm http 304 https://registry.npmjs.org/bindings/1.2.1
          npm http 304 https://registry.npmjs.org/async/0.9.0
          npm http GET https://registry.npmjs.org/ms/0.7.1
          npm http 304 https://registry.npmjs.org/ms/0.7.1
          npm http GET https://registry.npmjs.org/wordwrap
          npm http GET https://registry.npmjs.org/minimist
          npm http 304 https://registry.npmjs.org/wordwrap
          npm http 304 https://registry.npmjs.org/minimist
          serialport@2.0.6 install /opt/iobroker/node_modules/iobroker.mysensors/node_modules/serialport
          node-pre-gyp install --fallback-to-build
          node-pre-gyp http GET https://github.com/voodootikigod/node-s … arm.tar.gz
          node-pre-gyp http 404 https://github.com/voodootikigod/node-s ... arm.tar.gz
          node-pre-gyp http Pre-built binary not available for your system, looked for https://github.com/voodootikigod/node-s ... arm.tar.gz (falling back to source compile with node-gyp)
          make: Entering directory '/opt/iobroker/node_modules/iobroker.mysensors/node_modules/serialport/build'
          CXX(target) Release/obj.target/serialport/src/serialport.o
          CXX(target) Release/obj.target/serialport/src/serialport_unix.o
          CXX(target) Release/obj.target/serialport/src/serialport_poller.o
          SOLINK_MODULE(target) Release/obj.target/serialport.node
          SOLINK_MODULE(target) Release/obj.target/serialport.node: Finished
          COPY Release/serialport.node
          COPY /opt/iobroker/node_modules/iobroker.mysensors/node_modules/serialport/build/Release/node-v11-linux-arm/serialport.node
          TOUCH Release/obj.target/action_after_build.stamp
          make: Leaving directory '/opt/iobroker/node_modules/iobroker.mysensors/node_modules/serialport/build'
          iobroker.mysensors@0.0.1 node_modules/iobroker.mysensors
          ├── sensors@0.1.0
          └── serialport@2.0.6 (bindings@1.2.1, sf@0.1.7, async@0.9.0, nan@2.0.9, debug@2.2.0, optimist@0.6.1)
            Maxtox
            смотрим!!!
            https://youtu.be/SyWTYB084xQ
            УЖЕ ЛУЧШЕ!
            Только BIND не сработал!
            • V Offline
              V Offline
              Vlad_k
              bind срабатывает, только переменная не сохраняется
              смотри что сделай:
              нажми bind в списке devices появятся твои юниты щелкни по любому 2 раза и нажми сохранить, чтобы активировалась кнопка Сохранить и выйти
              ToDo сделать активацию сохранения при добавлении в список новых юнитов
                Maxtox
                Ок… Попробую...
                  Maxtox
                  Привет, могу ставить новую версию? Bluefox что-то запулил?!
                  • V Offline
                    V Offline
                    Vlad_k
                    да ставь
                      Maxtox
                      смотрим!!!
                      https://youtu.be/mvjW1XE959E
                        Maxtox
                        не читает… только информация из presentation
                        https://youtu.be/wylcfQUxXgk
                        • V Offline
                          V Offline
                          Vlad_k
                          @Maxtox:
                          смотрим!!!
                          https://youtu.be/mvjW1XE959E `
                          1 ты очень торопишься и не даешь запуститься драйверу, поэтому входя в настройки селектор ком портов пустой
                          2 ты добавил один и тот же юнит несколько раз, зачем? все равно имя переменной одно создается
                          3 для управления реле тебе нужно прописать в RAW посылку управляющую твоим реле без Value
                          а так все работает отлично
                            Maxtox
                            смотрим
                            почему ack TRUE?
                            https://youtu.be/rPdlEBoaDGc
                            в скетче на ардуине
                            `present(i, iomodus[i].sensorType, iomodus[i].description, false);`
                            смотрим что происходит
                            [https://youtu.be/mcUTM45SjG8](https://youtu.be/mcUTM45SjG8)[/i][/i]
                              Maxtox
                              @Vlad_k:
                              @Maxtox:
                              смотрим!!!
                              а так все работает отлично `
                              1. привык так :-)
                              2. убрал!
                              3. смотрим https://youtu.be/IiU1DlUT9cc
                              • V Offline
                                V Offline
                                Vlad_k
                                все правильно, что тебя смущает? то что в ком порт от юнита приходит то и отображается, в логе постоянно надо жать кнопку обновить иначе не корректно показывает, но это не проблема в драйвере
                                  Maxtox
                                  проблема в том что VALUE ПРЫГАЕТ, я думаю из за ack=TRUE,
                                  https://youtu.be/-uoDqlupOiE
                                  mysensors-0 2016-02-21 11:34:21 info Rx-Raw 0;58;1;1;0;55.91
                                  mysensors-0 2016-02-21 11:32:34 info _0|42|set|true|V_TEMP|_-127.00
                                  mysensors-0 2016-02-21 11:31:43 info raw_data_error 1
                                  mysensors-0 2016-02-21 11:33:36 info Rx-Raw 0;58;1;1;0;56.07
                                  mysensors-0 2016-02-21 11:34:21 info ack is not set!
                                  пробыvал изменит RAW от RELAY…Скрипт зависает! (последнее видео)
                                    Maxtox
                                    BUG
                                    смотри как время в логе выходит!
                                    Или как ты время лога сортируешь?
                                    mysensors-0	2016-02-21 11:34:25	info	raw_data_error 1
                                    mysensors-0	2016-02-21 11:31:47	info	Rx-Raw -127.00
                                    mysensors-0	2016-02-21 11:33:39	info	Rx-Raw TYPE
                                    mysensors-0	2016-02-21 11:32:38	info	raw_data_error 1
                                    mysensors-0	2016-02-21 11:34:25	info	Rx-Raw String
                                    mysensors-0	2016-02-21 11:31:47	info	raw_data_error 1
                                    mysensors-0	2016-02-21 11:33:39	info	raw_data_error 1
                                    mysensors-0	2016-02-21 11:32:38	info	Rx-Raw 58
                                    mysensors-0	2016-02-21 11:31:47	info	Rx-Raw String
                                    mysensors-0	2016-02-21 11:33:39	info	Rx-Raw -127.00
                                    mysensors-0	2016-02-21 11:34:25	info	Rx-Raw 42
                                    mysensors-0	2016-02-21 11:32:38	info	Rx-Raw PIN
                                    mysensors-0	2016-02-21 11:31:47	info	Rx-Raw 42
                                    mysensors-0	2016-02-21 11:33:39	info	Rx-Raw String
                                    mysensors-0	2016-02-21 11:32:38	info	__0_|_58_|_set_|_true_|_V_TEMP_|_40.08
                                    mysensors-0	2016-02-21 11:34:25	info	Rx-Raw PIN
                                    • V Offline
                                      V Offline
                                      Vlad_k
                                      0;8;1;1;2 для твоего реле напиши, остальные поля можно не трогать
                                      не понял какое время? только мусор и температура в логе
                                        Maxtox
                                        https://youtu.be/LFCIhMTMtIY
                                        • V Offline
                                          V Offline
                                          Vlad_k
                                          прыгает потому что твой шлюз отправляет данные постоянно
