  2. Русский
  3. ioBroker
  4. ioBroker драйвера
  5. Драйвер ioBroker MySensors
    5.9k
106 Beiträge 13 Kommentatoren 41.9k Aufrufe
  • H Offline
    Haba
    #61
    Bluefox переделал немного библиотеку, чтобы как и говорил ранее, добавлялись новые датчики, которые по умолчанию не входят в список.
    файл main.js
    /* jshint -W097 */// jshint strict:false /*jslint node: true */ "use strict"; ! // you have to require the utils module and call adapter function var utils = require(__dirname + '/lib/utils'); // Get common adapter utils var serialport; var Parses = require('sensors'); var MySensors = require(__dirname + '/lib/mysensors'); var getMeta = require(__dirname + '/lib/getmeta').getMetaInfo; var getMeta2 = require(__dirname + '/lib/getmeta').getMetaInfo2; ! var adapter = utils.adapter('mysensors'); var devices = {}; var mySensorsInterface; var floatRegEx = /^[+-]?\d+(\.\d*)$/; var inclusionOn = false; var inclusionTimeout = false; ! var config = {}; ! try { serialport = require('serialport');//.SerialPort; } catch (e) { console.warn('Serial port is not available'); } ! //принимаем и обрабатываем сообщения adapter.on('message', function (obj) { if (obj) { switch (obj.command) { case 'listUart': if (obj.callback) { if (serialport) { // read all found serial ports serialport.list(function (err, ports) { adapter.log.info('List of port: ' + JSON.stringify(ports)); adapter.sendTo(obj.from, obj.command, ports, obj.callback); }); } else { adapter.log.warn('Module serialport is not available'); adapter.sendTo(obj.from, obj.command, [{comName: 'Not available'}], obj.callback); } } ! break; } } }); ! // is called when adapter shuts down - callback has to be called under any circumstances! adapter.on('unload', function (callback) { adapter.setState('info.connection', false, true); try { if (mySensorsInterface) mySensorsInterface.destroy(); mySensorsInterface = null; callback(); } catch (e) { callback(); } }); ! // is called if a subscribed state changes adapter.on('stateChange', function (id, state) { if (!state || state.ack || !mySensorsInterface) return; ! // Warning, state can be null if it was deleted adapter.log.debug('stateChange ' + id + ' ' + JSON.stringify(state)); ! if (id === adapter.namespace + '.inclusionOn') { setInclusionState(state.val); } else // output to mysensors if (devices[id] && devices[id].type == 'state') { if (typeof state.val === 'boolean') state.val = state.val ? 1 : 0; if (state.val === 'true') state.val = 1; if (state.val === 'false') state.val = 0; ! mySensorsInterface.write( devices[id].native.id + ';' + devices[id].native.childId + ';1;0;' + devices[id].native.varTypeNum + ';' + state.val, devices[id].native.ip); } }); ! adapter.on('objectChange', function (id, obj) { if (!obj) { if (devices[id]) delete devices[id]; } else { if (obj.native.id !== undefined && obj.native.childId !== undefined && obj.native.subType !== undefined) { devices[id] = obj; } } }); ! // is called when databases are connected and adapter received configuration. // start here! adapter.on('ready', function () { main(); }); ! // start here! adapter.on('unload', function () { adapter.setState('inclusionOn', false, true); }); ! var presentationDone = false; ! function setInclusionState(val) { val = val === 'true' || val === true || val === 1 || val === '1'; inclusionOn = val; ! if (inclusionTimeout) clearTimeout(inclusionTimeout); inclusionTimeout = null; ! if (inclusionOn && adapter.config.inclusionTimeout) { inclusionTimeout = setTimeout(function () { inclusionOn = false; adapter.setState('inclusionOn', false, true); }, adapter.config.inclusionTimeout); } } ! function processPresentation(data, ip, port) { var result = Parses.parse(data.toString()); ! //var result = [{ // id: lineParts[0], // childId: lineParts[1], // type: Values.types[lineParts[2]], // ack: lineParts[3] === '1', // payload: lineParts[5] // subType: Values.subTypes[result.type][lineParts[4]]; //}]; ! if (!result || !result.length) { adapter.log.warn('Cannot parse data: ' + data); return null; } ! for (var i = 0; i < result.length; i++) { adapter.log.debug('Got: ' + JSON.stringify(result[i])); if (result[i].type === 'presentation' && result[i].subType) { adapter.log.debug('Сообщение Презетация'); presentationDone = true; var found = false; for (var id in devices) { adapter.log.debug('id = ' + id); if ((!ip || ip === devices[id].native.ip) && devices[id].native.id == result[i].id && devices[id].native.childId == result[i].childId && devices[id].native.subType == result[i].subType) { found = true; adapter.log.debug('Найден id = ' + id); break; } } ! // Add new node if (!found) { adapter.log.debug('Не найден id. Добавляем новый узел'); var objs = getMeta(result[i], ip, port, config[ip || 'serial']); for (var j = 0; j < objs.length; j++) { adapter.log.debug('Проверка ' + devices[adapter.namespace + '.' + objs[j]._id]); if (!devices[adapter.namespace + '.' + objs[j]._id]) { devices[adapter.namespace + '.' + objs[j]._id] = objs[j]; adapter.log.info('Add new object: ' + objs[j]._id + ' - ' + objs[j].common.name); adapter.setObject(objs[j]._id, objs[j], function (err) { if (err) adapter.log.error(err); }); } } } // проверяем, есть ли принятая переменная в объектах } else if (result[i].type === 'set' && result[i].subType) { adapter.log.debug('Тип "set". Ищем переменную в базе...'); var found = false; var id_found; // сюда сохраним id совпавший по параметрам id и childId for (var id in devices) { if ((!ip || ip === devices[id].native.ip) && devices[id].native.id == result[i].id && devices[id].native.childId == result[i].childId && devices[id].native.varType == result[i].subType) { found = true; adapter.log.debug('Найден id = ' + id); break; } if (devices[id].native.id == result[i].id && devices[id].native.childId == result[i].childId){ id_found = id; adapter.log.debug('Сохранили id_found с совпавшими id и childId'); adapter.log.debug('devices[id_found].native.id = ' + devices[id_found].native.id); adapter.log.debug('devices[id_found].native.childId = ' + devices[id_found].native.childId); } adapter.log.debug('Объект не найден!!!'); } // Добавляем новую переменную в существующий узел if (!found) { adapter.log.debug('Не найден id. Добавляем новую переменную'); var common_name = devices[id_found].common.name.split('.'); var objs = getMeta2(result[i], ip, port, config[ip || 'serial'],devices[id_found].native.subType,common_name[0]); if (!devices[adapter.namespace + '.' + objs[0]._id]) { devices[adapter.namespace + '.' + objs[0]._id] = objs[0]; adapter.log.info('Add new object: ' + objs[0]._id + ' - ' + objs[0].common.name); adapter.setObject(objs[0]._id, objs[0], function (err) { if (err) adapter.log.error(err); }); } } } else { // try to convert value var val = result[i].payload; if (floatRegEx.test(val)) val = parseFloat(val); if (val === 'true') val = true; if (val === 'false') val = false; result[i].payload = val; } } return result; } /* function syncObjects(index, cb) { if (typeof index === 'function') { cb = index; index = 0; } ! index = index || 0; ! if (!adapter.config.devices || index >= adapter.config.devices.length) { cb && cb(); return; } ! var id = adapter.config.devices[index].name.replace(/[.\s]+/g, '_'); ! adapter.getObject(id, function (err, obj) { if (err) adapter.log.error(err); ! // if new or changed if (!obj || JSON.stringify(obj.native) !== JSON.stringify(adapter.config.devices[index])) { adapter.setObject(id, { common: { name: adapter.config.devices[index].name, def: false, type: 'boolean', // нужный тип надо подставить read: 'true', write: 'true', // нужный режим надо подставить role: 'state', desc: obj ? obj.common.desc : 'Variable from mySensors' }, type: 'state', native: adapter.config.devices[index] }, function (err) { // Sync Rooms adapter.deleteStateFromEnum('rooms', '', '', id, function () { if (adapter.config.devices[index].room) { adapter.addStateToEnum('rooms', adapter.config.devices[index].room, '', '', id); } }); ! if (err) adapter.log.error(err); if (!obj) { adapter.log.debug('Create state ' + id); ! // if new object => create state adapter.setState(id, null, true, function () { setTimeout(function () { syncObjects(index + 1, cb); }, 0); }); } else { adapter.log.debug('Update state ' + id); setTimeout(function () { syncObjects(index + 1, cb); }, 0); } }); } else { setTimeout(function () { syncObjects(index + 1, cb); }, 0); } }); } ! function deleteStates(states, cb) { if (!states || !states.length) { cb && cb(); return; } var id = states.pop(); adapter.log.debug('Delete state ' + id); adapter.delForeignObject(id, function (err) { adapter.deleteStateFromEnum('rooms', '', '', id); ! if (err) adapter.log.error(err); ! adapter.delForeignState(id, function (err) { if (err) adapter.log.error(err); ! setTimeout(function () { deleteStates(states, cb); }, 0); }) }); } */ function main() { adapter.getState('inclusionOn', function (err, state) { setInclusionState(state ? state.val : false); }); ! // read current existing objects (прочитать текущие существующие объекты) adapter.getForeignObjects(adapter.namespace + '.*', 'state', function (err, states) { // subscribe on changes adapter.subscribeStates('*'); adapter.subscribeObjects('*'); devices = states; ! if (!devices[adapter.namespace + '.info.connection'] || !devices[adapter.namespace + '.info.connection'].common || (devices[adapter.namespace + '.info.connection'].common.type === 'boolean' && adapter.config.type !== 'serial') || (devices[adapter.namespace + '.info.connection'].common.type !== 'boolean' && adapter.config.type === 'serial')) { adapter.setForeignObject(adapter.namespace + '.info.connection', { "_id": "info.connection", "type": "state", "common": { "role": "indicator.connected", "name": adapter.config.type === 'serial' ? 'If connected to my sensors' : 'List of connected gateways', "type": adapter.config.type === 'serial' ? 'boolean' : 'string', "read": true, "write": false, "def": false }, "native": { ! } }, function (err) { if (err) adapter.log.error(err); }); } ! mySensorsInterface = new MySensors(adapter.config, adapter.log, function (error) { // if object created mySensorsInterface.write('0;0;3;0;14;Gateway startup complete'); ! // process received data mySensorsInterface.on('data', function (data, ip, port) { var result = processPresentation(data, ip, port); // update configuration if presentation received ! if (!result) return; ! for (var i = 0; i < result.length; i++) { if (result[i].type === 'set') { adapter.log.debug('Тип сообщения: set'); // If set quality if (result[i].subType == 77) { adapter.log.debug('subType = 77'); for (var id in devices) { if (devices[id].native && (!ip || ip == devices[id].native.ip) && devices[id].native.id == result[i].id && devices[id].native.childId == result[i].childId) { adapter.log.debug('Set quality of ' + (devices[id].common.name || id) + ' ' + result[i].childId + ': ' + result[i].payload + ' ' + typeof result[i].payload); adapter.setState(id, {q: typeof result[i].payload}, true); } } } else { if (result[i].subType === 'V_LIGHT') result[i].subType = 'V_STATUS'; if (result[i].subType === 'V_DIMMER') result[i].subType = 'V_PERCENTAGE'; ! for (var id in devices) { adapter.log.debug(devices[id].native.varType + ' /// ' + result[i].subType); if (devices[id].native && (!ip || ip == devices[id].native.ip) && devices[id].native.id == result[i].id && devices[id].native.childId == result[i].childId && devices[id].native.varType == result[i].subType) { ! if (devices[id].common.type == 'boolean') { result[i].payload = result[i].payload === 'true' || result[i].payload === true || result[i].payload === '1' || result[i].payload === 1; } adapter.log.debug('Set value ' + (devices[id].common.name || id) + ' ' + result[i].childId + ': ' + result[i].payload + ' ' + typeof result[i].payload); adapter.setState(id, result[i].payload, true); break; } } } } else if(result[i].type === 'internal') { var saveValue = false; adapter.log.debug('Внутреннее сообщение'); switch (result[i].subType) { case 'I_BATTERY_LEVEL': // 0 Use this to report the battery level (in percent 0-100). adapter.log.info('Battery level ' + (ip ? ' from ' + ip + ' ': '') + ':' + result[i].payload); saveValue = true; break; ! case 'I_TIME': // 1 Sensors can request the current time from the Controller using this message. The time will be reported as the seconds since 1970 adapter.log.info('Time ' + (ip ? ' from ' + ip + ' ': '') + ':' + result[i].payload); if (!result[i].ack) { // send response: internal, ack=1 mySensorsInterface.write(result[i].id + ';' + result[i].childId + ';3;1;' + result[i].subType + ';' + Math.round(new Date().getTime() / 1000), ip); } break; ! case 'I_VERSION': // 2 Used to request gateway version from controller. adapter.log.info('Version ' + (ip ? ' from ' + ip + ' ': '') + ':' + result[i].payload); saveValue = true; if (!result[i].ack) { // send response: internal, ack=1 mySensorsInterface.write(result[i].id + ';' + result[i].childId + ';3;1;' + result[i].subType + ';' + (adapter.version || 0), ip); } break; ! case 'I_SKETCH_NAME': // 2 Used to request gateway version from controller. adapter.log.info('Name ' + (ip ? ' from ' + ip + ' ': '') + ':' + result[i].payload); saveValue = true; break; ! case 'I_INCLUSION_MODE': // 5 Start/stop inclusion mode of the Controller (1=start, 0=stop). adapter.log.info('inclusion mode ' + (ip ? ' from ' + ip + ' ': '') + ':' + result[i].payload ? 'STARTED' : 'STOPPED'); break; ! case 'I_CONFIG': // 6 Config request from node. Reply with (M)etric or (I)mperal back to sensor. result[i].payload = (result[i].payload == 'I') ? 'Imperial' : 'Metric'; adapter.log.info('Config ' + (ip ? ' from ' + ip + ' ': '') + ':' + result[i].payload); config[ip || 'serial'] = config[ip || 'serial'] || {}; config[ip || 'serial'].metric = result[i].payload; saveValue = true; break; ! case 'I_LOG_MESSAGE': // 9 Sent by the gateway to the Controller to trace-log a message adapter.log.info('Log ' + (ip ? ' from ' + ip + ' ': '') + ':' + result[i].payload); break; ! case 'I_ID_REQUEST': if (inclusionOn) { // find maximal index var maxId = 0; for (var id in devices) { if (devices[id].native && (!ip || ip == devices[id].native.ip) && devices[id].native.id > maxId) { maxId = devices[id].native.id; } } maxId++; if (!result[i].ack) { // send response: internal, ack=0, I_ID_RESPONSE mySensorsInterface.write(result[i].id + ';' + result[i].childId + ';3;0;4;' + maxId, ip); } } else { adapter.log.warn('Received I_ID_REQUEST, but inclusion mode is disabled'); } break; ! default: adapter.log.info('Received INTERNAL message: ' + result[i].subType + ': ' + result[i].payload); } ! if (saveValue) { for (var id in devices) { adapter.log.debug('2 ' + devices[id].native.varType + ' /// ' + result[i].subType); if (devices[id].native && (!ip || ip == devices[id].native.ip) && devices[id].native.id == result[i].id && devices[id].native.childId == result[i].childId && devices[id].native.varType == result[i].subType) { ! if (devices[id].common.type == 'boolean') result[i].payload = !!result[i].payload; if (devices[id].common.type == 'number') result[i].payload = parseFloat(result[i].payload); ! adapter.log.info('Set value ' + (devices[id].common.name || id) + ' ' + result[i].childId + ': ' + result[i].payload + ' ' + typeof result[i].payload); adapter.setState(id, result[i].payload, true); break; } } } ! } } }); ! mySensorsInterface.on('connectionChange', function (isConn, ip, port) { adapter.setState('info.connection', isConn, true); // try soft request if (!presentationDone && isConn) { // request metric system mySensorsInterface.write('0;0;3;0;6;get metric', ip, port); mySensorsInterface.write('0;0;3;0;19;force presentation', ip, port); setTimeout(function () { // send reboot command if still no presentation if (!presentationDone) { mySensorsInterface.write('0;0;3;0;13;force restart', ip, port); } }, 1500); } }); }); }); }
    файл getmeta.js (добавил функцию)
    ! >! [spoiler]`~~[code]~~function getMetaInfo2(packet, ip, port, config, subType, common_name) {
    ! config = config || {};
    var type = presentation[subType];
    if (!type) {
    type = {
    type: 'string',
    role: 'state',
    vars: ['V_VAR1', 'V_VAR2', 'V_VAR3', 'V_VAR4', 'V_VAR5'],
    index: packet.subType
    var varType = packet.subType;
    var variable = vars[varType];
    var id = (ip ? ip.replace(/./g, '') + '.' : '') + packet.id + '.' + packet.childId + '' + subType.replace('S_', '') + /*'.' + packet.subType + */ '.' + varType;
    var result = [
                _id:            (ip ? ip.replace(/\./g, '_') + '.'  : '') + packet.id + '.' + packet.childId + '_' + subType.replace('S_', '') + '.' + varType,
                common: {
                    name:       common_name ? (common_name + '.' + varType) : id,
                    type:       variable.type,
                    role:       variable.role + (type.role ? '.' + type.role : ''),
                    min:        variable.min,
                    max:        variable.max,
                    unit:       variable.unit,
                    def:        variable.def,
                    read:       variable.read,
                    write:      variable.write
                native: {
                    ip:         ip,
                    childId:    packet.childId,
                    subType:    packet.subType,
                    subTypeNum: type.index,
                    varType:    varType,
                    varTypeNum: variable.index
                type: 'state'
    ! return result;
    ! module.exports.getMetaInfo = getMetaInfo;
    module.exports.getMetaInfo2 = getMetaInfo2;[/code]`[/spoiler][/i][/i][/i][/i][/i][/i][/i][/i][/i][/i][/i][/i][/i][/i][/i][/i][/i][/i][/i][/i][/i][/i][/i][/i][/i][/i][/i][/i][/i][/i][/i][/i][/i][/i][/i][/i][/i][/i][/i][/i][/i][/i][/i][/i][/i][/i][/i][/i][/i][/i][/i][/i][/i][/i][/i][/i][/i][/i][/i][/i][/i][/i][/i][/i][/i][/i][/i][/i][/i][/i][/i][/i][/i][/i][/i][/i][/i][/i][/i]
      sanich2908
      #62
      Почему не видит сом порт на Raspi ???
      evice converter now attached to ttyUSB0
      root@raspberrypi:~# dmesg
      Нажмите Ctrl+A и Ctrl+C, что бы скопировать в буфер обмена и после этого нажмите мышкой в любом месте.
      mysensors-0 2016-09-24 21:32:56.957 warn Module serialport is not available
      mysensors-0 2016-09-24 21:32:55.643 info starting. Version 1.0.2 in /opt/iobroker/node_modules/iobroker.mysensors
      host-raspberrypi 2016-09-24 21:32:53.436 info instance system.adapter.mysensors.0 started with pid 2654
      host-raspberrypi 2016-09-24 21:32:51.029 info instance system.adapter.mysensors.0 terminated with code 0 (OK)
      mysensors-0 2016-09-24 21:32:51.000 info terminating
      host-raspberrypi 2016-09-24 21:32:50.916 info stopInstance system.adapter.mysensors.0 killing pid 2648
      host-raspberrypi 2016-09-24 21:32:50.915 info stopInstance system.adapter.mysensors.0
      • H Offline
        Haus
        #63
        @sanich2908:
        host-raspberrypi 2016-09-24 21:32:50.915 info stopInstance system.adapter.mysensors.0 `
        sudo apt-get update
        sudo apt-get install build-essential
        sudo apt-get install python2.7
        js-controller: 1.5.7 / node.js: v8.15.1/ npm: 6.4.1
        admin: 3.6.0
        javascript: 4.1.10
        web: 2.4.1 vis: 1.1.10
        cloud: 2.6.2
        Server: DELL FX170 / linux: Debian 9.5 Stretch
        Adapter: MegaD-2561, Mega-ES…
          sanich2908
          #64
          Да установлено всё это, а СОМ порт не видит :oops:
          • BluefoxB Offline
            BluefoxB Offline
            #65
            @sanich2908:
            Да установлено всё это, а СОМ порт не видит :oops: `
            Ruf mal noch mal:
            cd /opt/iobroker
            iobroker stop mysensors
            npm install iobroker.mysensors --production --force
            iobroker upload mysensors
            iobroker start mysensors
            Danach sollten die Ports in der Konfig drin sein.
              sanich2908
              #66
              Ещё пару переустановок всего и заработало :shock:
                Maxtox
                #67
                @sanich2908:
                Ещё пару переустановок всего и заработало :shock: `
                Молодец!
                Arduino MEGA 2560 R3 / ioBroker / DOino Sketch
                  sanich2908
                  #68
                  Вот ни где не сказано, что inclusionON надо в Обьектах поставить в TRUE, и тогда добавляются сенсоры в Нодах.
                  • BluefoxB Offline
                    BluefoxB Offline
                    #69
                    @sanich2908:
                    Вот ни где не сказано, что inclusionON надо в Обьектах поставить в TRUE, и тогда добавляются сенсоры в Нодах. `
                    По идее должно управляться из настроек. Получается что не работает?
                    • G Offline
                      Genvik
                      #70
                      Добрый день.
                      Перечитал эту ветку.
                      Не могу понять, почему у меня не появляются данные с нод во вкладке "объекты"?
                      В логе вижу, что данные идут.
                      ` > mysensors-0 2016-10-07 15:25:29.157 info Connected
                      mysensors-0 2016-10-07 15:25:29.142 info disconnected
                      mysensors-0 2016-10-07 15:24:48.362 info List of port: [{"comName":"/dev/ttyAMA0"},{"comName":"/dev/ttyUSB0","manufacturer":"1a86","serialNumber":"1a86_USB2.0-Serial","pnpId":"usb-1a86_USB2.0-Serial-if00-port0","vendorId":"0x1a86","productI
                      mysensors-0 2016-10-07 15:24:29.147 info Log :TSP:SANCHK:OK
                      mysensors-0 2016-10-07 15:24:29.142 warn Serial data received: 0;255;3;0;9;TSP:SANCHK:OK
                      mysensors-0 2016-10-07 15:23:29.205 info Log :TSP:SANCHK:OK
                      mysensors-0 2016-10-07 15:23:29.191 warn Serial data received: 0;255;3;0;9;TSP:SANCHK:OK
                      mysensors-0 2016-10-07 15:23:29.157 info Connected
                      mysensors-0 2016-10-07 15:23:29.139 info disconnected
                      mysensors-0 2016-10-07 15:22:29.144 info Log :TSP:SANCHK:OK
                      mysensors-0 2016-10-07 15:22:29.139 warn Serial data received: 0;255;3;0;9;TSP:SANCHK:OK
                      mysensors-0 2016-10-07 15:22:26.284 info Log :TSP:MSG:SEND 0-0-10-10 s=3,c=1,t=2,pt=2,l=2,sg=0,ft=0,st=ok:0
                      mysensors-0 2016-10-07 15:22:26.264 warn Serial data received: 0;255;3;0;9;TSP:MSG:SEND 0-0-10-10 s=3,c=1,t=2,pt=2,l=2,sg=0,ft=0,st=ok:0
                      mysensors-0 2016-10-07 15:22:26.185 info Log :TSP:MSG:ACK msg
                      mysensors-0 2016-10-07 15:22:26.161 warn Serial data received: 0;255;3;0;9;TSP:MSG:ACK msg
                      mysensors-0 2016-10-07 15:22:26.158 info Log :TSP:MSG:READ 10-10-0 s=3,c=1,t=2,pt=2,l=2,sg=0:0
                      mysensors-0 2016-10-07 15:22:26.154 warn Serial data received: 0;255;3;0;9;TSP:MSG:READ 10-10-0 s=3,c=1,t=2,pt=2,l=2,sg=0:0
                      mysensors-0 2016-10-07 15:22:26.094 info Log :TSP:MSG:READ 10-10-0 s=3,c=1,t=2,pt=0,l=1,sg=0:0
                      mysensors-0 2016-10-07 15:22:26.084 warn Serial data received: 0;255;3;0;9;TSP:MSG:READ 10-10-0 s=3,c=1,t=2,pt=0,l=1,sg=0:0
                      mysensors-0 2016-10-07 15:22:26.024 info Log :TSP:MSG:SEND 0-0-10-10 s=2,c=1,t=2,pt=2,l=2,sg=0,ft=0,st=ok:0
                      mysensors-0 2016-10-07 15:22:26.014 warn Serial data received: 0;255;3;0;9;TSP:MSG:SEND 0-0-10-10 s=2,c=1,t=2,pt=2,l=2,sg=0,ft=0,st=ok:0
                      mysensors-0 2016-10-07 15:22:25.954 info Log :TSP:MSG:ACK msg
                      mysensors-0 2016-10-07 15:22:25.928 warn Serial data received: 0;255;3;0;9;TSP:MSG:ACK msg
                      mysensors-0 2016-10-07 15:22:25.884 info Log :TSP:MSG:READ 10-10-0 s=2,c=1,t=2,pt=2,l=2,sg=0:0
                      mysensors-0 2016-10-07 15:22:25.874 warn Serial data received: 0;255;3;0;9;TSP:MSG:READ 10-10-0 s=2,c=1,t=2,pt=2,l=2,sg=0:0
                      mysensors-0 2016-10-07 15:22:25.814 info Log :TSP:MSG:READ 10-10-0 s=3,c=1,t=2,pt=0,l=1,sg=0:0
                      mysensors-0 2016-10-07 15:22:25.809 warn Serial data received: 0;255;3;0;9;TSP:MSG:READ 10-10-0 s=3,c=1,t=2,pt=0,l=1,sg=0:0
                      mysensors-0 2016-10-07 15:22:15.577 info Log :TSP:MSG:SEND 0-0-10-138 s=3,c=1,t=2,pt=6,l=2,sg=0,ft=0,st=ok:0100
                      mysensors-0 2016-10-07 15:22:15.572 warn Serial data received: 0;255;3;0;9;TSP:MSG:SEND 0-0-10-138 s=3,c=1,t=2,pt=6,l=2,sg=0,ft=0,st=ok:0100
                      mysensors-0 2016-10-07 15:22:15.478 info Log :TSP:MSG:REL MSG
                      mysensors-0 2016-10-07 15:22:15.474 warn Serial data received: 0;255;3;0;9;TSP:MSG:REL MSG
                      mysensors-0 2016-10-07 15:22:15.449 info Log :TSP:MSG:READ 0-10-138 s=3,c=1,t=2,pt=6,l=2,sg=0:0100
                      mysensors-0 2016-10-07 15:22:15.435 warn Serial data received: 0;255;3;0;9;TSP:MSG:READ 0-10-138 s=3,c=1,t=2,pt=6,l=2,sg=0:0100
                      mysensors-0 2016-10-07 15:22:15.394 info Log :TSP:MSG:SEND 0-0-10-138 s=3,c=1,t=2,pt=6,l=2,sg=0,ft=0,st=ok:0100
                      mysensors-0 2016-10-07 15:22:15.369 warn Serial data received: 0;255;3;0;9;TSP:MSG:SEND 0-0-10-138 s=3,c=1,t=2,pt=6,l=2,sg=0,ft=0,st=ok:0100 `
                      Во вкладке "настройки драйверов" mysensors adapter вижу бледную надпись
                      "Включить режим присваивания адресов"
                      Сервер на малинке.
                        Maxtox
                        #71
                        Какую библиотеку юзаешь? У меня по другому лог выглядит. Я на 2.0
                        • G Offline
                          Genvik
                          #72
                          @Maxtox:
                          Какую библиотеку юзаешь? У меня по другому лог выглядит. Я на 2.0 `
                          2.0
                            Maxtox
                            #73
                            Сегодня вечером гляну… Может mysensors что изменили а мы инфу от них не получили...
                            Санкции наверно :roll:
                            • G Offline
                              Genvik
                              #74
                              У меня wifi gateway esp8266.
                                Maxtox
                                #75
                                Попробуй без nrf24l01…
                                Как лог выглядит?
                                • BluefoxB Offline
                                  BluefoxB Offline
                                  #76
                                  @Genvik:
                                  Добрый день.
                                  Сервер на малинке. `
                                  Я написал тест для драйвера и здесь
                                  https://github.com/ioBroker/ioBroker.my … mmands.txt
                                  можно увидеть, как выглядит вывод в библиотеке mysensors 2.0 в апреле. Твой лог отличается от апрельского.
                                  То что ты прислал в распечатке, это внутренний лог, который не несёт никакой информации для ioBrokera.
                                  0 - 			node-id
                                  255 - 		child-sensor-id
                                  3 - 			internal
                                  0 - 			ack
                                  I_LOG_MESSAGE - sub-type
                                  Payload -       TSP:MSG:READ 0-10-138 s=3,c=1,t=2,pt=6,l=2,sg=0:0100
                                  Что значит "TSP:MSG:READ 0-10-138 s=3,c=1,t=2,pt=6,l=2,sg=0:0100" я не имею ни малейшего представления. Может стоит спросить на mySensors, что этот лог значит и почему не посылаются данные?
                                  • H Offline
                                    Haba
                                    #77
                                    Судя по сообщениям: 0;255;3;0;9;TSP:SANCHK:OK
                                    это приходит внутренний лог с шлюза контроллеру.
                                    Расшифровка:
                                    0 - адрес узла (0 это шлюз)
                                    3 - message-type "internal" (внутреннее сообщение)
                                    0 - без подтверждения
                                    9 - I_LOG_MESSAGE "Sent by the gateway to the Controller to trace-log a message"
                                    далее сам текст лога в нашем случае например "TSP:SANCHK:OK"
                                    Предполагаю, что какой то не такой скетч в шлюз залит или выставлены не те служебные настройки шлюза.
                                    Больше похоже на какой то диагностический скетч.
                                    что загружено в шлюз? какие настройки библиотеки mySensors выставлены?
                                      DAndre
                                      #78
                                      И имеется com шлюз и клиент по радио с реле-температурой-влажностью и ур.освещением.
                                      Возможно ли запрашивать состояния датчиков c клиента принудительно?
                                      И как?
                                      sendTo ('mysensors.0', 'send', '1;0;2;1;37;1\n'); –--------- не работает ж(
                                      <size size="50">Ubuntu 14.04 trusty DISTRIB_DESCRIPTION="Ubuntu 14.04.3 LTS, Android v4.4.2"
                                      Ubuntu 16.04.1 LTS (GNU/Linux 4.4.0-31-generic x86_64)</size>
                                      • V Offline
                                        V Offline
                                        Vlad_k
                                        #79
                                        я правильно понимаю что текущая версия с 1.5 библиотекой не работает?
                                        у кого есть шлюз на esp8266 скиньте свой скетч рабочий и на какой нибудь сенсор, чет библиотека 2.0 у меня вообще не работает…
                                          sanich2908
                                          #80
                                          Попробовал подключить NRF24L01 + напрямую к Малине, запускаю шлюз, ./bin/mysgw -d, данные с сенсоров идут прекрасно, а как их в IOBrokere принять???
                                          Попробовал запустить шлюз с виртуальным портом, ./configure –my-gateway=serial --my-serial-is-pty --my-serial-pty=/dev/ttyUSB020, выбор порта в брокере не появляется. Мож кто уже проходил это дело?
