Драйвер ioBroker MySensors
Добрый день.
Перечитал эту ветку.
Не могу понять, почему у меня не появляются данные с нод во вкладке "объекты"?
В логе вижу, что данные идут.
` > mysensors-0 2016-10-07 15:25:29.157 info Connectedmysensors-0 2016-10-07 15:25:29.142 info disconnected
mysensors-0 2016-10-07 15:24:48.362 info List of port: [{"comName":"/dev/ttyAMA0"},{"comName":"/dev/ttyUSB0","manufacturer":"1a86","serialNumber":"1a86_USB2.0-Serial","pnpId":"usb-1a86_USB2.0-Serial-if00-port0","vendorId":"0x1a86","productI
mysensors-0 2016-10-07 15:24:29.147 info Log :TSP:SANCHK:OK
mysensors-0 2016-10-07 15:24:29.142 warn Serial data received: 0;255;3;0;9;TSP:SANCHK:OK
mysensors-0 2016-10-07 15:23:29.205 info Log :TSP:SANCHK:OK
mysensors-0 2016-10-07 15:23:29.191 warn Serial data received: 0;255;3;0;9;TSP:SANCHK:OK
mysensors-0 2016-10-07 15:23:29.157 info Connected
mysensors-0 2016-10-07 15:23:29.139 info disconnected
mysensors-0 2016-10-07 15:22:29.144 info Log :TSP:SANCHK:OK
mysensors-0 2016-10-07 15:22:29.139 warn Serial data received: 0;255;3;0;9;TSP:SANCHK:OK
mysensors-0 2016-10-07 15:22:26.284 info Log :TSP:MSG:SEND 0-0-10-10 s=3,c=1,t=2,pt=2,l=2,sg=0,ft=0,st=ok:0
mysensors-0 2016-10-07 15:22:26.264 warn Serial data received: 0;255;3;0;9;TSP:MSG:SEND 0-0-10-10 s=3,c=1,t=2,pt=2,l=2,sg=0,ft=0,st=ok:0
mysensors-0 2016-10-07 15:22:26.185 info Log :TSP:MSG:ACK msg
mysensors-0 2016-10-07 15:22:26.161 warn Serial data received: 0;255;3;0;9;TSP:MSG:ACK msg
mysensors-0 2016-10-07 15:22:26.158 info Log :TSP:MSG:READ 10-10-0 s=3,c=1,t=2,pt=2,l=2,sg=0:0
mysensors-0 2016-10-07 15:22:26.154 warn Serial data received: 0;255;3;0;9;TSP:MSG:READ 10-10-0 s=3,c=1,t=2,pt=2,l=2,sg=0:0
mysensors-0 2016-10-07 15:22:26.094 info Log :TSP:MSG:READ 10-10-0 s=3,c=1,t=2,pt=0,l=1,sg=0:0
mysensors-0 2016-10-07 15:22:26.084 warn Serial data received: 0;255;3;0;9;TSP:MSG:READ 10-10-0 s=3,c=1,t=2,pt=0,l=1,sg=0:0
mysensors-0 2016-10-07 15:22:26.024 info Log :TSP:MSG:SEND 0-0-10-10 s=2,c=1,t=2,pt=2,l=2,sg=0,ft=0,st=ok:0
mysensors-0 2016-10-07 15:22:26.014 warn Serial data received: 0;255;3;0;9;TSP:MSG:SEND 0-0-10-10 s=2,c=1,t=2,pt=2,l=2,sg=0,ft=0,st=ok:0
mysensors-0 2016-10-07 15:22:25.954 info Log :TSP:MSG:ACK msg
mysensors-0 2016-10-07 15:22:25.928 warn Serial data received: 0;255;3;0;9;TSP:MSG:ACK msg
mysensors-0 2016-10-07 15:22:25.884 info Log :TSP:MSG:READ 10-10-0 s=2,c=1,t=2,pt=2,l=2,sg=0:0
mysensors-0 2016-10-07 15:22:25.874 warn Serial data received: 0;255;3;0;9;TSP:MSG:READ 10-10-0 s=2,c=1,t=2,pt=2,l=2,sg=0:0
mysensors-0 2016-10-07 15:22:25.814 info Log :TSP:MSG:READ 10-10-0 s=3,c=1,t=2,pt=0,l=1,sg=0:0
mysensors-0 2016-10-07 15:22:25.809 warn Serial data received: 0;255;3;0;9;TSP:MSG:READ 10-10-0 s=3,c=1,t=2,pt=0,l=1,sg=0:0
mysensors-0 2016-10-07 15:22:15.577 info Log :TSP:MSG:SEND 0-0-10-138 s=3,c=1,t=2,pt=6,l=2,sg=0,ft=0,st=ok:0100
mysensors-0 2016-10-07 15:22:15.572 warn Serial data received: 0;255;3;0;9;TSP:MSG:SEND 0-0-10-138 s=3,c=1,t=2,pt=6,l=2,sg=0,ft=0,st=ok:0100
mysensors-0 2016-10-07 15:22:15.478 info Log :TSP:MSG:REL MSG
mysensors-0 2016-10-07 15:22:15.474 warn Serial data received: 0;255;3;0;9;TSP:MSG:REL MSG
mysensors-0 2016-10-07 15:22:15.449 info Log :TSP:MSG:READ 0-10-138 s=3,c=1,t=2,pt=6,l=2,sg=0:0100
mysensors-0 2016-10-07 15:22:15.435 warn Serial data received: 0;255;3;0;9;TSP:MSG:READ 0-10-138 s=3,c=1,t=2,pt=6,l=2,sg=0:0100
mysensors-0 2016-10-07 15:22:15.394 info Log :TSP:MSG:SEND 0-0-10-138 s=3,c=1,t=2,pt=6,l=2,sg=0,ft=0,st=ok:0100
mysensors-0 2016-10-07 15:22:15.369 warn Serial data received: 0;255;3;0;9;TSP:MSG:SEND 0-0-10-138 s=3,c=1,t=2,pt=6,l=2,sg=0,ft=0,st=ok:0100 `
Во вкладке "настройки драйверов" mysensors adapter вижу бледную надпись
"Включить режим присваивания адресов"
Сервер на малинке.
1530_mys.png -
Добрый день.
Сервер на малинке. `
Я написал тест для драйвера и здесьhttps://github.com/ioBroker/ioBroker.my … mmands.txt
можно увидеть, как выглядит вывод в библиотеке mysensors 2.0 в апреле. Твой лог отличается от апрельского.
То что ты прислал в распечатке, это внутренний лог, который не несёт никакой информации для ioBrokera.
0 - node-id 255 - child-sensor-id 3 - internal 0 - ack I_LOG_MESSAGE - sub-type Payload - TSP:MSG:READ 0-10-138 s=3,c=1,t=2,pt=6,l=2,sg=0:0100Что значит "TSP:MSG:READ 0-10-138 s=3,c=1,t=2,pt=6,l=2,sg=0:0100" я не имею ни малейшего представления. Может стоит спросить на mySensors, что этот лог значит и почему не посылаются данные?
Судя по сообщениям: 0;255;3;0;9;TSP:SANCHK:OK
это приходит внутренний лог с шлюза контроллеру.
Расшифровка:
0 - адрес узла (0 это шлюз)
3 - message-type "internal" (внутреннее сообщение)
0 - без подтверждения
9 - I_LOG_MESSAGE "Sent by the gateway to the Controller to trace-log a message"
далее сам текст лога в нашем случае например "TSP:SANCHK:OK"
Предполагаю, что какой то не такой скетч в шлюз залит или выставлены не те служебные настройки шлюза.
Больше похоже на какой то диагностический скетч.
что загружено в шлюз? какие настройки библиотеки mySensors выставлены?
Попробовал подключить NRF24L01 + напрямую к Малине, запускаю шлюз, ./bin/mysgw -d, данные с сенсоров идут прекрасно, а как их в IOBrokere принять???
Попробовал запустить шлюз с виртуальным портом, ./configure –my-gateway=serial --my-serial-is-pty --my-serial-pty=/dev/ttyUSB020, выбор порта в брокере не появляется. Мож кто уже проходил это дело?
Попробовал запустить шлюз с виртуальным портом, ./configure –my-gateway=serial --my-serial-is-pty --my-serial-pty=/dev/ttyUSB020, выбор порта в брокере не появляется. Мож кто уже проходил это дело? `
А вот этот драйвер не подойдет https://github.com/eisbaeeer/iobroker.p … /README.md ? -
Ты можешь попробовать напрямую прописать порт в объекте system.adapter.mysensors.0 => native.comNameЕсли заработает, то я посмотрю, почему в настройках не появляется
Ты можешь попробовать напрямую прописать порт в объекте system.adapter.mysensors.0 => native.comNameЕсли заработает, то я посмотрю, почему в настройках не появляется `
Да прописал system.adapter.mysensors.0 => /dev/ttyUSB020, заработало, IObroker принимает данные прекрасно. Вот теперь и Arduina не нужна в качестве шлюза.
Да прописал system.adapter.mysensors.0 => /dev/ttyUSB020, заработало, IObroker принимает данные прекрасно. Вот теперь и Arduina не нужна в качестве шлюза. `
Отлично. А можно ссылку или описание что и как сделано? А я пока посмотрю, почему имя порта не появляется.Edit: попробуй установи с гита. я там расширил список портов
На https://www.mysensors.org/build/raspberry всё расписано
Может кому пригодится кто захочет использовать аппаратный serial port ttyAMA0 на Малине.
Прикупил вот такую платку http://devicter.ru/goods/Raspberry-PI-n … ?from=YjY1 шлюз Mysensors + часы RTC. Удобно, ни каких проводов не болтается. Прошил её скетчем отсюда http://www.elecrow.com/wiki/index.php?t ... dd-on_V1.0. Подключаю её к Малине и не фига толком не работает. Давай копать инет, и нарыл вот тут http://spellfoundry.com/2016/05/29/conf ... ding-pi-3/ , что порт ttyAMA0 по умолчанию привязан к терминалу.
Отключаем сервис терминала
$ sudo systemctl stop serial-getty@ttyAMA0.service
$ sudo systemctl disable serial-getty@ttyAMA0.service
И правим файл cmdline.txt
$ sudo nano /boot/cmdline.txt
dwc_otg.lpm_enable=0 console=serial0,115200 console=tty1 root=/dev/mmcblk0p2 rootfstype=ext4 elevator=deadline fsck.repair=yes root wait
Удаляем из него console=serial0,115200
Перегружаем Малину и теперь порт ttyAMA0 прекрасно принимает и передаёт наши данные, платка заработала.
Обновил драйвер. Порт должен показываться. Можешь проверить? -
Обновил драйвер. Порт должен показываться. Можешь проверить?Обновил, теперь показывает выбор порта нормально. Спасибо за труды.
