  2. Русский
  3. ioBroker
  4. ioBroker драйвера
  5. Драйвер ioBroker MySensors
Geplant Angeheftet Gesperrt Verschoben ioBroker драйвера
106 Beiträge 13 Kommentatoren 44.9k Aufrufe
  • M
    M
    Maxtox
    #75
    Попробуй без nrf24l01…
    Как лог выглядит?
    Arduino MEGA 2560 R3 / ioBroker / DOino Sketch
    • BluefoxB
      #76
      @Genvik:
      Добрый день.
      Перечитал эту ветку.
      Не могу понять, почему у меня не появляются данные с нод во вкладке "объекты"?
      В логе вижу, что данные идут.
      ` > mysensors-0 2016-10-07 15:25:29.157 info Connected
      mysensors-0 2016-10-07 15:25:29.142 info disconnected
      mysensors-0 2016-10-07 15:24:48.362 info List of port: [{"comName":"/dev/ttyAMA0"},{"comName":"/dev/ttyUSB0","manufacturer":"1a86","serialNumber":"1a86_USB2.0-Serial","pnpId":"usb-1a86_USB2.0-Serial-if00-port0","vendorId":"0x1a86","productI
      mysensors-0 2016-10-07 15:24:29.147 info Log :TSP:SANCHK:OK
      mysensors-0 2016-10-07 15:24:29.142 warn Serial data received: 0;255;3;0;9;TSP:SANCHK:OK
      mysensors-0 2016-10-07 15:23:29.205 info Log :TSP:SANCHK:OK
      mysensors-0 2016-10-07 15:23:29.191 warn Serial data received: 0;255;3;0;9;TSP:SANCHK:OK
      mysensors-0 2016-10-07 15:23:29.157 info Connected
      mysensors-0 2016-10-07 15:23:29.139 info disconnected
      mysensors-0 2016-10-07 15:22:29.144 info Log :TSP:SANCHK:OK
      mysensors-0 2016-10-07 15:22:29.139 warn Serial data received: 0;255;3;0;9;TSP:SANCHK:OK
      mysensors-0 2016-10-07 15:22:26.284 info Log :TSP:MSG:SEND 0-0-10-10 s=3,c=1,t=2,pt=2,l=2,sg=0,ft=0,st=ok:0
      mysensors-0 2016-10-07 15:22:26.264 warn Serial data received: 0;255;3;0;9;TSP:MSG:SEND 0-0-10-10 s=3,c=1,t=2,pt=2,l=2,sg=0,ft=0,st=ok:0
      mysensors-0 2016-10-07 15:22:26.185 info Log :TSP:MSG:ACK msg
      mysensors-0 2016-10-07 15:22:26.161 warn Serial data received: 0;255;3;0;9;TSP:MSG:ACK msg
      mysensors-0 2016-10-07 15:22:26.158 info Log :TSP:MSG:READ 10-10-0 s=3,c=1,t=2,pt=2,l=2,sg=0:0
      mysensors-0 2016-10-07 15:22:26.154 warn Serial data received: 0;255;3;0;9;TSP:MSG:READ 10-10-0 s=3,c=1,t=2,pt=2,l=2,sg=0:0
      mysensors-0 2016-10-07 15:22:26.094 info Log :TSP:MSG:READ 10-10-0 s=3,c=1,t=2,pt=0,l=1,sg=0:0
      mysensors-0 2016-10-07 15:22:26.084 warn Serial data received: 0;255;3;0;9;TSP:MSG:READ 10-10-0 s=3,c=1,t=2,pt=0,l=1,sg=0:0
      mysensors-0 2016-10-07 15:22:26.024 info Log :TSP:MSG:SEND 0-0-10-10 s=2,c=1,t=2,pt=2,l=2,sg=0,ft=0,st=ok:0
      mysensors-0 2016-10-07 15:22:26.014 warn Serial data received: 0;255;3;0;9;TSP:MSG:SEND 0-0-10-10 s=2,c=1,t=2,pt=2,l=2,sg=0,ft=0,st=ok:0
      mysensors-0 2016-10-07 15:22:25.954 info Log :TSP:MSG:ACK msg
      mysensors-0 2016-10-07 15:22:25.928 warn Serial data received: 0;255;3;0;9;TSP:MSG:ACK msg
      mysensors-0 2016-10-07 15:22:25.884 info Log :TSP:MSG:READ 10-10-0 s=2,c=1,t=2,pt=2,l=2,sg=0:0
      mysensors-0 2016-10-07 15:22:25.874 warn Serial data received: 0;255;3;0;9;TSP:MSG:READ 10-10-0 s=2,c=1,t=2,pt=2,l=2,sg=0:0
      mysensors-0 2016-10-07 15:22:25.814 info Log :TSP:MSG:READ 10-10-0 s=3,c=1,t=2,pt=0,l=1,sg=0:0
      mysensors-0 2016-10-07 15:22:25.809 warn Serial data received: 0;255;3;0;9;TSP:MSG:READ 10-10-0 s=3,c=1,t=2,pt=0,l=1,sg=0:0
      mysensors-0 2016-10-07 15:22:15.577 info Log :TSP:MSG:SEND 0-0-10-138 s=3,c=1,t=2,pt=6,l=2,sg=0,ft=0,st=ok:0100
      mysensors-0 2016-10-07 15:22:15.572 warn Serial data received: 0;255;3;0;9;TSP:MSG:SEND 0-0-10-138 s=3,c=1,t=2,pt=6,l=2,sg=0,ft=0,st=ok:0100
      mysensors-0 2016-10-07 15:22:15.478 info Log :TSP:MSG:REL MSG
      mysensors-0 2016-10-07 15:22:15.474 warn Serial data received: 0;255;3;0;9;TSP:MSG:REL MSG
      mysensors-0 2016-10-07 15:22:15.449 info Log :TSP:MSG:READ 0-10-138 s=3,c=1,t=2,pt=6,l=2,sg=0:0100
      mysensors-0 2016-10-07 15:22:15.435 warn Serial data received: 0;255;3;0;9;TSP:MSG:READ 0-10-138 s=3,c=1,t=2,pt=6,l=2,sg=0:0100
      mysensors-0 2016-10-07 15:22:15.394 info Log :TSP:MSG:SEND 0-0-10-138 s=3,c=1,t=2,pt=6,l=2,sg=0,ft=0,st=ok:0100
      mysensors-0 2016-10-07 15:22:15.369 warn Serial data received: 0;255;3;0;9;TSP:MSG:SEND 0-0-10-138 s=3,c=1,t=2,pt=6,l=2,sg=0,ft=0,st=ok:0100 `
      Во вкладке "настройки драйверов" mysensors adapter вижу бледную надпись
      "Включить режим присваивания адресов"
      Сервер на малинке. `
      Я написал тест для драйвера и здесь
      https://github.com/ioBroker/ioBroker.my … mmands.txt
      можно увидеть, как выглядит вывод в библиотеке mysensors 2.0 в апреле. Твой лог отличается от апрельского.
      То что ты прислал в распечатке, это внутренний лог, который не несёт никакой информации для ioBrokera.
      0 - 			node-id
      255 - 		child-sensor-id
      3 - 			internal
      0 - 			ack
      I_LOG_MESSAGE - sub-type
      Payload -       TSP:MSG:READ 0-10-138 s=3,c=1,t=2,pt=6,l=2,sg=0:0100
      Что значит "TSP:MSG:READ 0-10-138 s=3,c=1,t=2,pt=6,l=2,sg=0:0100" я не имею ни малейшего представления. Может стоит спросить на mySensors, что этот лог значит и почему не посылаются данные?
      • H
        H
        Haba
        #77
        Судя по сообщениям: 0;255;3;0;9;TSP:SANCHK:OK
        это приходит внутренний лог с шлюза контроллеру.
        Расшифровка:
        0 - адрес узла (0 это шлюз)
        3 - message-type "internal" (внутреннее сообщение)
        0 - без подтверждения
        9 - I_LOG_MESSAGE "Sent by the gateway to the Controller to trace-log a message"
        далее сам текст лога в нашем случае например "TSP:SANCHK:OK"
        Предполагаю, что какой то не такой скетч в шлюз залит или выставлены не те служебные настройки шлюза.
        Больше похоже на какой то диагностический скетч.
        что загружено в шлюз? какие настройки библиотеки mySensors выставлены?
        • D
          D
          DAndre
          #78
          И имеется com шлюз и клиент по радио с реле-температурой-влажностью и ур.освещением.
          Возможно ли запрашивать состояния датчиков c клиента принудительно?
          И как?
          sendTo ('mysensors.0', 'send', '1;0;2;1;37;1\n'); –--------- не работает ж(
          <size size="50">Ubuntu 14.04 trusty DISTRIB_DESCRIPTION="Ubuntu 14.04.3 LTS, Android v4.4.2"
          Ubuntu 16.04.1 LTS (GNU/Linux 4.4.0-31-generic x86_64)</size>
          • V
            V
            Vlad_k
            #79
            я правильно понимаю что текущая версия с 1.5 библиотекой не работает?
            у кого есть шлюз на esp8266 скиньте свой скетч рабочий и на какой нибудь сенсор, чет библиотека 2.0 у меня вообще не работает…
            • S
              S
              sanich2908
              #80
              Попробовал подключить NRF24L01 + напрямую к Малине, запускаю шлюз, ./bin/mysgw -d, данные с сенсоров идут прекрасно, а как их в IOBrokere принять???
              Попробовал запустить шлюз с виртуальным портом, ./configure –my-gateway=serial --my-serial-is-pty --my-serial-pty=/dev/ttyUSB020, выбор порта в брокере не появляется. Мож кто уже проходил это дело?
              • I
                I
                instalator
                #81
                @sanich2908:
                Попробовал запустить шлюз с виртуальным портом, ./configure –my-gateway=serial --my-serial-is-pty --my-serial-pty=/dev/ttyUSB020, выбор порта в брокере не появляется. Мож кто уже проходил это дело? `
                А вот этот драйвер не подойдет https://github.com/eisbaeeer/iobroker.p … /README.md ?
                Высокий уровень Децибел вреден для здоровья!
                http://blog.instalator.ru/
                • BluefoxB
                  #82
                  @sanich2908:
                  Ты можешь попробовать напрямую прописать порт в объекте system.adapter.mysensors.0 => native.comName
                  Если заработает, то я посмотрю, почему в настройках не появляется
                  • S
                    S
                    sanich2908
                    #83
                    @Bluefox:
                    @sanich2908:
                    Если заработает, то я посмотрю, почему в настройках не появляется `
                    Да прописал system.adapter.mysensors.0 => /dev/ttyUSB020, заработало, IObroker принимает данные прекрасно. Вот теперь и Arduina не нужна в качестве шлюза.
                    • BluefoxB
                      #84
                      @sanich2908:
                      @Bluefox:
                      @sanich2908:
                      Да прописал system.adapter.mysensors.0 => /dev/ttyUSB020, заработало, IObroker принимает данные прекрасно. Вот теперь и Arduina не нужна в качестве шлюза. `
                      Отлично. А можно ссылку или описание что и как сделано? А я пока посмотрю, почему имя порта не появляется.
                      Edit: попробуй установи с гита. я там расширил список портов
                      • S
                        S
                        sanich2908
                        #85
                        На https://www.mysensors.org/build/raspberry всё расписано
                        • S
                          S
                          sanich2908
                          #86
                          Может кому пригодится кто захочет использовать аппаратный serial port ttyAMA0 на Малине.
                          Прикупил вот такую платку http://devicter.ru/goods/Raspberry-PI-n … ?from=YjY1 шлюз Mysensors + часы RTC. Удобно, ни каких проводов не болтается. Прошил её скетчем отсюда http://www.elecrow.com/wiki/index.php?t ... dd-on_V1.0. Подключаю её к Малине и не фига толком не работает. Давай копать инет, и нарыл вот тут http://spellfoundry.com/2016/05/29/conf ... ding-pi-3/ , что порт ttyAMA0 по умолчанию привязан к терминалу.
                          Отключаем сервис терминала
                          $ sudo systemctl stop serial-getty@ttyAMA0.service
                          $ sudo systemctl disable serial-getty@ttyAMA0.service
                          И правим файл cmdline.txt
                          $ sudo nano /boot/cmdline.txt
                          dwc_otg.lpm_enable=0 console=serial0,115200 console=tty1 root=/dev/mmcblk0p2 rootfstype=ext4 elevator=deadline fsck.repair=yes root wait
                          Удаляем из него console=serial0,115200
                          Перегружаем Малину и теперь порт ttyAMA0 прекрасно принимает и передаёт наши данные, платка заработала.
                          • H
                            H
                            Haba
                            #87
                            > Прикупил вот такую платку [http://devicter.ru/goods/Raspberry-PI-n](http://devicter.ru/goods/Raspberry-PI-n) … ?from=YjY1 шлюз Mysensors + часы RTC
                            2600 руб, охренеть… :shock:
                            За такие деньги можно еще одну малинку взять
                            • BluefoxB
                              #88
                              @sanich2908:
                              @Bluefox:
                              @sanich2908:
                              Обновил драйвер. Порт должен показываться. Можешь проверить?
                              • S
                                S
                                sanich2908
                                #89
                                @Bluefox:
                                @sanich2908:
                                @Bluefox:
                                Да прописал system.adapter.mysensors.0 => /dev/ttyUSB020, заработало, IObroker принимает данные прекрасно. Вот теперь и Arduina не нужна в качестве шлюза. Обновил драйвер. Порт должен показываться. Можешь проверить?
                                Обновил, теперь показывает выбор порта нормально. Спасибо за труды.
                                • S
                                  S
                                  sanich2908
                                  #90
                                  Решил тут попробовать с IObroker шлюз EthernetGatewayW5100 и столкнулся с такой проблемой. Заливаю скетч в шлюз по умолчанию, подключаюсь к нему MYSController, данные принимаются прекрасно, а вот IObroker не хочет подключаться. Давай разбираться и выясняется, что по умолчанию шлюз EthernetGatewayW5100 работает в режим сервера, и драйвер IObroker тоже в режиме сервера. Ну ладно, правлю скетч, прописываю IP адрес IObroker, это переводит шлюз EthernetGatewayW5100 в режим клиента, заливаю, и MYSController не может подключиться к шлюзу, он тоже клиент. IObroker чёта пытается принимать от шлюза в итоге виснет. Копаю дальше, правлю скетч и перевожу шлюз на протокол UDP, в этом режиме IObroker принимает данные от шлюза нормально. Копаю дальше, снова правлю скетч шлюза на протокол TCP-server и правлю в свойствах обьекта
                                  system.adapter.mysensors.0 => mode client не помогло, данные не принимаются.
                                  А вся эта возня затевалась ради прошивки нодов по воздуху ОТА через MYSController, чтобы не дергать всякие шнурки, а стоит себе шлюз EthernetGatewayW5100 и всё работает, надо прошить нод запустил MYSController, прошил и дальше IObroker работает. Но вот не вышло.
                                  Попробовал ещё шлюз ESP8266_Gatewey, такая же фигня абсолютно как и с EthernetGatewayW5100 ….
                                  • P
                                    P
                                    Pooh
                                    #91
                                    Железо: шлюз с локальными датчиками (электросчетчик и датчики дверей) на mega256+w5100, нод нет
                                    Софт(скетч):
                                    сервер - коннекта с драйвером нет
                                    клиент TPC - коннект есть, датчиков нет
                                    клиент UDP - коннект есть, датчики есть, данные в сервер не идут! :-(
                                    куда копать?
                                    https://play.google.com/store/apps/details?id=com.roy.royclub - код: UMI201155
                                    https://play.google.com/store/apps/details?id=com.blockchainvault - код приглашения: Freepooh
                                    https://play.google.com/store/apps/details?id=games.bee.app - код приглашения: freepooh
                                    https://www.timestope.com/freepooh - witness code: freepooh
                                    • P
                                      P
                                      Pooh
                                      #92
                                      В режиме клиента шлюз не передает данные с локальных датчиков (ноды пока не подключал)
                                      Можно ли настроить драйвер так, чтобы он был клиентом?
                                      • P
                                        P
                                        Pooh
                                        #93
                                        Интересная история… ради эксперимента сделал serial-гейт на другой ардуинке. перешил свой изернетгейт с датчиками на ноду. данных в iobroker нет! мало того не видно пользовательских переменных (V-VAR1..5)
                                        ЗЫ данные появились после открывания/закрывания дверей. но пользовательских переменный нету!
                                        или их нужно принудительно создать? по-идее они должны были добавится в момент презентации
                                        • BluefoxB
                                          #94
                                          @Pooh:
                                          Можно ли настроить драйвер так, чтобы он был клиентом? `
                                          ioBroker не работает в режиме клиента.
                                          83.8k
