  2. English
  3. Visualization
  4. getting started with visualisations
    apollon77A
Geplant Angeheftet Gesperrt Verschoben Visualization
vis
43 Beiträge 4 Kommentatoren 10.1k Aufrufe 4 Beobachtet
  • T
    T
    Taragorm
    Update
    Reloaded iobroker from scratch, just to be sure
    Updated iob.js-controller to 1.5.7
    iobroker@iobrokerdev /o/iobroker> npm list iobroker.js-controller
    iobroker.inst@2.0.2 /opt/iobroker
    └── iobroker.js-controller@1.5.7
    Same error on iob visdebug
    Also
    Lots of warnings caused by this:
    └─┬ iobroker.js-controller@1.5.7
      └─┬ winston-syslog@1.2.6
        └── UNMET OPTIONAL DEPENDENCY unix-dgram@~0.2.1
    Is there any way to suppress it? I hate clutter in the logfiles!
    Also2
    I can't see my widget in the vis builder. There's no obvious error in the log tho.
    • T
      T
      Taragorm
      done a bit more digging into the visdebug error, and it seems like the project folder isn't being recognised as a directory:
      Trying:/opt/iobroker/iobroker.vis-taragorm
      Got stats:{"dev":2049,"mode":41471,"nlink":1,"uid":1001,"gid":1001,"rdev":0,"blksize":4096,"ino":792374,"size":24,"blocks":0,"atimeMs":1552471012718.894,"mtimeMs":1552471012714.892,"ctimeMs":1552471012714.892,"birthtimeMs":1552471012714.892,"atime":"2019-03-13T09:56:52.719Z","mtime":"2019-03-13T09:56:52.715Z","ctime":"2019-03-13T09:56:52.715Z","birthtime":"2019-03-13T09:56:52.715Z"}  isDir=false
      trace code:
                          console.log("Trying:" + process.cwd() + "/" + adapterNames2Try[i]);
                          var adapterDir2Try = tools.getAdapterDir(adapterNames2Try[i]);
                          // Query the entry
                          var stats = fs.lstatSync(adapterDir2Try);
                          console.log("Got stats:" + JSON.stringify(stats) + "  isDir=" + stats.isDirectory());
      But it surely is a dir:
      iobroker@iobrokerdev /o/iobroker> ls -l
      total 248
      -rw-rwxr--+   1 iobroker iobroker   1474 Mar 13 09:40 CHANGELOG_INSTALLER_LINUX.md*
      drwxrwxr-x+   3 iobroker iobroker   4096 Mar 13 09:40 install/
      -rwxrwxrwx+   1 iobroker iobroker    169 Mar 13 09:41 INSTALLER_INFO.txt*
      lrwxrwxrwx    1 iobroker iobroker     22 Mar 13 09:41 iob -> /opt/iobroker/iobroker*
      -rwxrwxr-x+   1 iobroker iobroker    209 Mar 13 09:41 iobroker*
      drwxrwxrwx+   4 iobroker iobroker   4096 Mar 13 09:42 iobroker-data/
      drwxrwxrwx+   8 iobroker iobroker   4096 Mar 13 09:59 iobroker.vis-taragorm/
      -rw-rwxrw-+   1 iobroker iobroker     92 Mar 13 09:41 killall.sh*
      drwxrwxr-x+   2 iobroker iobroker   4096 Mar 13 09:40 lib/
      -rw-rwxr--+   1 iobroker iobroker   1137 Mar 13 09:40 LICENSE*
      drwxrwxrwx+   2 iobroker iobroker   4096 Mar 13 09:41 log/
      drwxrwxr-x+ 451 iobroker iobroker  20480 Mar 13 09:56 node_modules/
      -rw-rwxrw-+   1 iobroker iobroker    658 Mar 13 09:56 package.json*
      -rw-rwxrw-+   1 iobroker iobroker 166878 Mar 13 09:41 package-lock.json*
      -rw-rwxr--+   1 iobroker iobroker   6101 Mar 13 09:40 README.md*
      -rw-rw-rw-+   1 iobroker iobroker   5868 Mar 13 09:51 reinstall.js
      -rw-rwxrw-+   1 iobroker iobroker    709 Mar 13 09:41 reinstall.sh*
      it's as if fs is misbehaving?
      BluefoxB 1 Antwort Letzte Antwort
      • T Taragorm
        trace code:
                            // Query the entry
        total 248
        schrieb am zuletzt editiert von Bluefox
        @Taragorm is the normal iobroker upload vis does not work?
        You can force all the steps manually.
        1. Copy your widgets files into /opt/iobroker/node_modules/iobroker.vis/www/widgets directory.
        2. Change /opt/iobroker/node_modules/iobroker.vis/www/js/config.js
        3. Change /opt/iobroker/node_modules/iobroker.vis/www/cache.manifest (just add/change some char to change the hash)
        4. iobroker u vis
        5. To be sure clear the browser cache
        • T
          T
          Taragorm
          fyi, in enableDebug I think:
          maybe should be
          var stats = fs.statSync(adapterDir2Try);
          As diagnostics suggest we're finding the link, and lstatSync() returns the link itself, rather than the target of the link.
          Changing it, lets things go a bit further, but it still fails somewhat messily:
          Got stats:{"dev":2049,"mode":16895,"nlink":8,"uid":1001,"gid":1001,"rdev":0,"blksize":4096,"ino":791105,"size":4096,"blocks":8,"atimeMs":1552471286715.824,"mtimeMs":1552471172270.63,"ctimeMs":1552471172270.63,"birthtimeMs":1552471172270.63,"atime":"2019-03-13T10:01:26.716Z","mtime":"2019-03-13T09:59:32.271Z","ctime":"2019-03-13T09:59:32.271Z","birthtime":"2019-03-13T09:59:32.271Z"}  isDir=true isLink=false
          Upload "/opt/iobroker/node_modules/iobroker.vis/www/index.html.original"
          fs.js:119
              throw err;
          Error: ENOENT: no such file or directory, open '/opt/iobroker/node_modules/iobroker.js-controller/lib/setup/../../../iobroker.vis/www/index.html.original'
              at Object.openSync (fs.js:448:3)
              at Object.readFileSync (fs.js:348:35)
              at VisDebug.enableDebug (/opt/iobroker/node_modules/iobroker.js-controller/lib/setup/setupVisDebug.js:91:23)
              at _objects (/opt/iobroker/node_modules/iobroker.js-controller/lib/setup.js:2460:30)
              at Object.connected (/opt/iobroker/node_modules/iobroker.js-controller/lib/setup.js:3133:17)
              at Socket.<anonymous> (/opt/iobroker/node_modules/iobroker.js-controller/lib/states/statesInMemClient.js:87:68)
              at Socket.Emitter.emit (/opt/iobroker/node_modules/socket.io-client/node_modules/component-emitter/index.js:133:20)
              at Socket.emit (/opt/iobroker/node_modules/socket.io-client/lib/socket.js:136:10)
              at Socket.onconnect (/opt/iobroker/node_modules/socket.io-client/lib/socket.js:328:8)
              at Socket.onpacket (/opt/iobroker/node_modules/socket.io-client/lib/socket.js:224:12)
          For now, I'm going to switch my development environment to Windows, as that seems to be working for you.
          • T Taragorm
            maybe should be
            fs.js:119
                throw err;
            @Taragorm It is very well, that you want to get the visbebug runnnig, but
            I don't understand, why you ignore my other suggestions:
            • https://forum.iobroker.net/topic/19929/getting-started-with-visualisations/15
            • https://forum.iobroker.net/topic/19929/getting-started-with-visualisations/8
            The problem with non existing index.html.original is fixed only on github.
            • BluefoxB Bluefox
              @Taragorm No matter. With iobroker r vis && iobroker u vis it should work.
              Not Fast, but work.
              Just tried to execute (windows):
              and cannot see any errors
              T
              T
              Taragorm
              @Bluefox I
              @Bluefox said in getting started with visualisations:
              Not Fast, but work.
              I tried this; I don't get any errors, but I don't get a visualisation in the toolbox either.
              That's why I trying to enable debug.
              • BluefoxB Bluefox
                @Taragorm I do it like this.
                My folder structure is like this one:
                /opt/iobroker
                        iobroker.my-new-adapter
                        node_modules
                               iobroker.js-controle
                               iobroker.xxxx
                Then I install my new adapter by writing npm i iobroker.my-new-adapter in /opt/iobroker.
                As result the npm creates a sym-link to my developer folder:
                /opt/iobroker
                        node_modules
                               iobroker.my-new-adapter (symlink)
                               iobroker.xxxx
                after that I develop my adapter as usual in /opt/iobroker/iobroker.my-new-adapter even as a git repo.
                after every change I write iobroker r vis && iobroker u vis This should work 100%.
                Additionally I can write iobroker visdebug my-new-adapter and if I see the output
                Disable cache I restart the iobroker (only for the first time).
                After that I can directly modify the file /opt/iobroker/iobroker-data/files/vis/widgets/my-new-adapter.html and after every browser refresh it will be loaded anew from disk. So you can fast see your changes.
                But, the changes in /opt/iobroker/iobroker-data/files/vis/widgets/my-new-adapter.html must be copied to /opt/iobroker/iobroker.my-new-adapter/widgets/ manually and you may not call iobroker u vis till you do that, else they will be overwritten
                T
                T
                Taragorm
                /opt/iobroker
                        node_modules
                               iobroker.xxxx
                /opt/iobroker
                        node_modules
                               iobroker.xxxx
                ...and I have also set my environment up like this.
                • BluefoxB
                  Please set here the names without vis-
                  • BluefoxB
                    And you may not change class.
                    • T
                      T
                      Taragorm
                      thanks, will do
                      • T
                        T
                        Taragorm
                        It's showing in the toolbox now - many thanks!
                        • T
                          T
                          Taragorm
                          Much progress, but another small issue.
                          My visualisation shows values ok in the edit dialog.
                          In the normal view, it shows the "undefined" value... unless the value is used by a different widget.
                          This suggests I've done something wrong in binding, but as far as I can see, I've done pretty much what the template does.
                          Have I missed something out? It feels like whatever code that populates vis.states[] hasn't been invoked correctly. (i.e. the view seems to be unaware of the points I'm asking for).
                          • T
                            T
                            Taragorm
                            ps: Changed the repo to: https://github.com/Taragorm/ioBroker.vistaragorm
                            • T Taragorm
                              @Taragorm It can be, that I forgot to describe, that all ObjectID Variables Names must start with "oid..." or end with "...oid" or "...oidN" (N is any number from 0 to 99)
                              Please use following files, that work:
                              vistaragorm.js
                              vistaragorm.html
                              • T
                                T
                                Taragorm
                                Ah, that would be it then - I may have missed it.
                                I assumed that the /id type in the attr declaration was what did it.
                                • T
                                  T
                                  Taragorm
                                  That works nicely, thanks.
                                  Out of curiosity, is there any way to force subscription?
                                  I have a case where I have mutiple values on a sensor, and I'd like to be able to just specify the sensor oid for the widget, and have the implementation figure out the values.
                                  e.g. I have
                                  foo.bah.x
                                  foo.bah.y
                                  foo.bah.z
                                  .. I'd like to only have to supply an oid of foo.bah - the widget can add .x, .y etc as those are fixed.
                                  or does supplying an oid = "foo.bah" create a subscription for changes of all children too?
                                  • T
                                    T
                                    Taragorm
                                    In case it's not obvious, I'd like a widget to be able to generate oids based on, or relative to, an oid in an attribute, and have the object correctly added to the widget/view so I can get data from it.
                                    Surely there must be a way to do this?
                                    • T Taragorm
                                      @Taragorm I must check it
                                      • T
                                        T
                                        Taragorm
                                        Appreciated
                                        • T Taragorm
                                          e.g. I have
                                          foo.bah.x
                                          foo.bah.y
                                          foo.bah.z
                                          @Taragorm Now I understand, what you want.
                                          The solution is to provide all OIDs during configuration. You can see the example:
                                          • https://github.com/ioBroker/ioBroker.vis-hqwidgets/blob/master/widgets/hqwidgets.html#L61
                                          • https://github.com/ioBroker/ioBroker.vis-hqwidgets/blob/master/widgets/hqwidgets/js/hqwidgets.js#L3069
                                          If your first OID is changed, the defined function (in example vis.binds.hqwidgets.changedButtonId) will be called and you can define other fields there with desired OIDs.
                                          84.0k
                                          1.4m
