  4. Osram Lightyfy Adapter Problem
    6.7k
Geplant Angeheftet Gesperrt Verschoben Ungelöst ioBroker Allgemein
56 Beiträge 20 Kommentatoren 9.7k Aufrufe 9 Beobachtet
  • hg6806H hg6806
    Hallo nochmal,
    kann hier jemand was dazu sagen, wie ich den Fehler abstellen kann?
    HeliosFan
    @hg6806
    Osram Bridge rauschschmeissen, durch Hue Bridge ersetzen. 😁 😁 😁
    • hg6806H hg6806
      OK, hatte immer folgendes Problem:
      host.rock64	2019-08-28 22:04:52.979	error	instance system.adapter.lightify.0 terminated with code 0 (OK)
      host.rock64	2019-08-28 22:04:52.979	error	Caught by controller[0]: at Socket.Readable.push (_stream_readable.js:224:10)
      host.rock64	2019-08-28 22:04:52.979	error	Caught by controller[0]: at readableAddChunk (_stream_readable.js:269:11)
      host.rock64	2019-08-28 22:04:52.979	error	Caught by controller[0]: at addChunk (_stream_readable.js:288:12)
      host.rock64	2019-08-28 22:04:52.978	error	Caught by controller[0]: at Socket.emit (events.js:198:13)
      host.rock64	2019-08-28 22:04:52.978	error	Caught by controller[0]: at Socket.<anonymous> (/opt/iobroker/node_modules/iobroker.lightify/lib/lightify.js:151:18)
      host.rock64	2019-08-28 22:04:52.978	error	Caught by controller[0]: at lightify.onData (/opt/iobroker/node_modules/iobroker.lightify/lib/lightify.js:173:18)
      host.rock64	2019-08-28 22:04:52.978	error	Caught by controller[0]: at lightify.processData (/opt/iobroker/node_modules/iobroker.lightify/lib/lightify.js:116:32)
      host.rock64	2019-08-28 22:04:52.978	error	Caught by controller[0]: at Object.cb (/opt/iobroker/node_modules/iobroker.lightify/lib/lightify.js:463:28)
      host.rock64	2019-08-28 22:04:52.978	error	Caught by controller[0]: at Uint8Array.readUInt8 (internal/buffer.js:137:5)
      host.rock64	2019-08-28 22:04:52.977	error	Caught by controller[0]: at boundsError (internal/buffer.js:43:11)
      host.rock64	2019-08-28 22:04:52.977	error	Caught by controller[0]: RangeError [ERR_OUT_OF_RANGE]: The value of "offset" is out of range. It must be an integer. Received 43.33333333333333
      lightify.0	2019-08-28 22:04:52.914	error	RangeError [ERR_OUT_OF_RANGE]: The value of "offset" is out of range. It must be an integer. Received 43.33333333333333 at boundsError (internal/buffer.js:43:11) at Uint8Array.readUInt8 (inter
      lightify.0	2019-08-28 22:04:52.910	error	uncaught exception: The value of "offset" is out of range. It must be an integer. Received 43.33333333333333
      lightify.0	2019-08-28 22:04:52.015	info	starting. Version 0.2.16 in /opt/iobroker/node_modules/iobroker.lightify, node: v10.16.2
      javascript.0	2019-08-28 22:04:51.587	info	script.js.common.Stromverbrauch.Strom_Zaehlerstaende_Verbrauch_Kosten: Fehler beim Auslesen des Datums. Eventuell falsche Syntax? null (Error:TypeError: Cannot read property 'match' of null)
      smartmeter.0	2019-08-28 22:04:51.322	info	Received 10 values, 3 updated
      host.rock64	2019-08-28 22:04:49.487	info	instance system.adapter.lightify.0 started with pid 30091
      host.rock64	2019-08-28 22:04:49.436	info	object change system.adapter.lightify.0
      host.rock64	2019-08-28 22:04:48.380	info	instance system.adapter.lightify.0 terminated with code 0 (OK)
      Caught	2019-08-28 22:04:48.380	error	by controller[0]: at Socket.Readable.push (_stream_readable.js:224:10)
      Caught	2019-08-28 22:04:48.380	error	by controller[0]: at readableAddChunk (_stream_readable.js:269:11)
      Caught	2019-08-28 22:04:48.379	error	by controller[0]: at addChunk (_stream_readable.js:288:12)
      Caught	2019-08-28 22:04:48.379	error	by controller[0]: at Socket.emit (events.js:198:13)
      Caught	2019-08-28 22:04:48.379	error	by controller[0]: at Socket.<anonymous> (/opt/iobroker/node_modules/iobroker.lightify/lib/lightify.js:151:18)
      Caught	2019-08-28 22:04:48.379	error	by controller[0]: at lightify.onData (/opt/iobroker/node_modules/iobroker.lightify/lib/lightify.js:173:18)
      Caught	2019-08-28 22:04:48.379	error	by controller[0]: at lightify.processData (/opt/iobroker/node_modules/iobroker.lightify/lib/lightify.js:116:32)
      Caught	2019-08-28 22:04:48.379	error	by controller[0]: at Object.cb (/opt/iobroker/node_modules/iobroker.lightify/lib/lightify.js:463:28)
      Caught	2019-08-28 22:04:48.379	error	by controller[0]: at Uint8Array.readUInt8 (internal/buffer.js:137:5)
      Caught	2019-08-28 22:04:48.379	error	by controller[0]: at boundsError (internal/buffer.js:43:11)
      Caught	2019-08-28 22:04:48.379	error	by controller[0]: RangeError [ERR_OUT_OF_RANGE]: The value of "offset" is out of range. It must be an integer. Received 43.33333333333333
      host.rock64	2019-08-28 22:04:48.307	info	stopInstance system.adapter.lightify.0 killing pid 30076
      host.rock64	2019-08-28 22:04:48.306	info	object change system.adapter.lightify.0
      lightify.0	2019-08-28 22:04:48.297	info	terminating
      lightify.0	2019-08-28 22:04:48.268	error	at Socket.Readable.push (_stream_readable.js:224:10)
      lightify.0	2019-08-28 22:04:48.268	error	at readableAddChunk (_stream_readable.js:269:11)
      lightify.0	2019-08-28 22:04:48.268	error	at addChunk (_stream_readable.js:288:12)
      lightify.0	2019-08-28 22:04:48.268	error	at Socket.emit (events.js:198:13)
      lightify.0	2019-08-28 22:04:48.268	error	at Socket.<anonymous> (/opt/iobroker/node_modules/iobroker.lightify/lib/lightify.js:151:18)
      lightify.0	2019-08-28 22:04:48.268	error	at lightify.onData (/opt/iobroker/node_modules/iobroker.lightify/lib/lightify.js:173:18)
      lightify.0	2019-08-28 22:04:48.268	error	at lightify.processData (/opt/iobroker/node_modules/iobroker.lightify/lib/lightify.js:116:32)
      lightify.0	2019-08-28 22:04:48.268	error	at Object.cb (/opt/iobroker/node_modules/iobroker.lightify/lib/lightify.js:463:28)
      lightify.0	2019-08-28 22:04:48.268	error	at Uint8Array.readUInt8 (internal/buffer.js:137:5)
      lightify.0	2019-08-28 22:04:48.268	error	at boundsError (internal/buffer.js:43:11)
      lightify.0	2019-08-28 22:04:48.268	error	RangeError [ERR_OUT_OF_RANGE]: The value of "offset" is out of range. It must be an integer. Received 43.33333333333333
      lightify.0	2019-08-28 22:04:48.256	error	uncaught exception: The value of "offset" is out of range. It must be an integer. Received 43.33333333333333
      lightify.0	2019-08-28 22:04:47.260	info	starting. Version 0.2.16 in /opt/iobroker/node_modules/iobroker.lightify, node: v10.16.2
      Nachdem ich dann von dir die Zeile 463 wie folgt geändert hatte:
      var cnt = data.readUInt8(Math.floor(pos + 0.5) + 16);
      erhalte ich nun:
      lightify.0	2019-10-16 10:48:18.149	error	at process._tickCallback (internal/process/next_tick.js:68:7)
      lightify.0	2019-10-16 10:48:18.149	error	at promise.then (/opt/iobroker/node_modules/standard-as-callback/built/index.js:19:49)
      lightify.0	2019-10-16 10:48:18.149	error	at tryCatcher (/opt/iobroker/node_modules/standard-as-callback/built/utils.js:11:23)
      lightify.0	2019-10-16 10:48:18.149	error	at (anonymous function).(anonymous function)._0x2f5fa7 (/opt/iobroker/node_modules/iobroker.objects-redis/index.js:17:72663)
      lightify.0	2019-10-16 10:48:18.149	error	at /opt/iobroker/node_modules/soef/soef.js:609:26
      lightify.0	2019-10-16 10:48:18.149	error	at Devices.setState (/opt/iobroker/node_modules/soef/soef.js:642:36)
      lightify.0	2019-10-16 10:48:18.149	error	(6129) TypeError: Cannot read property 'val' of undefined
      lightify.0	2019-10-16 10:48:18.147	error	(6129) uncaught exception: Cannot read property 'val' of undefined
      lightify.0	2019-10-16 10:48:17.470	info	(6129) starting. Version 0.2.16 in /opt/iobroker/node_modules/iobroker.lightify, node: v10.16.3
      AsgothianA Offline
      AsgothianA Offline
      Asgothian
      @hg6806 hier muss der Adapterentwickler ran. Es wird auf eine nicht korrekt mit Info gefüllten Variable zugegriffen.
      Eine Lösung ohne im Detail den Adapter zu debuggen wird schwer zu finden sein.
      A.
      • hg6806H Offline
        hg6806H Offline
        hg6806
        Hat doch funktioniert.
        Keine Ahnung warum jetzt erst. Vielleicht nach einem Reboot oder so.
        Auf jeden Fall funktioniert es mit dem Ändern der Zeile 463 in
        Endlich....eine Baustelle weniger und Frau ist auch happy :-)
        • hg6806H hg6806
          AsgothianA Offline
          AsgothianA Offline
          Asgothian
          @hg6806 Hattest du ein Upload gemacht nachdem du die Zeile angepasst hast ?
          A.
          • hg6806H Offline
            hg6806H Offline
            hg6806
            Glaube hatte ich nicht getan...
              AgentLibelle
              Hallo an alle,
              habe seit einigen Tagen auch diesen Fehler in meinem System. Zufällig habe ich dann diesen Thread gefunden und war direkt froh, dass dieser auch noch "lebt". Auf dem Adapter "Osram Ligtify" liegt mittlerweile auch viel Staub.....
              IOBroker läuft bei mir in einem Hyper-V Container, Betriebssystem CentOS, seit ein paar Monaten keine Updates durchgeführt. Nach allen möglichen Updates verbindet sich der Adapter Osram nicht mehr.
              Also habe ich einen weiteren Container für IOBroker eingerichtet, um den Osram Adapter alleine laufen zu lassen und Fehler zu suchen.
              Das Workaround habe ich versucht, ohne Erfolg....
              /opt/iobroker/node_modules/iobroker.lightify/lib/lightify.js        ///   Zeile 463 modifizieren
              Wird jemand aus den Angaben meines LOGs schlau?
              undefined2019-11-28 13:30:12.110 - info: host.iobroker "system.adapter.lightify.0" enabled
              2019-11-28 13:30:12.121 - info: host.iobroker instance system.adapter.lightify.0 started with pid 2405
              2019-11-28 13:30:12.403 - info: lightify.0 (2405) starting. Version 0.2.16 in /opt/iobroker/node_modules/iobroker.lightify, node: v10.17.0
              2019-11-28 13:30:12.956 - error: lightify.0 (2405) uncaught exception: Cannot read property 'val' of undefined
              2019-11-28 13:30:12.956 - error: lightify.0 (2405) TypeError: Cannot read property 'val' of undefined
              at (anonymous function).(anonymous function)._0x344e03 (/opt/iobroker/node_modules/iobroker.objects-redis/index.js:17:77549)
              2019-11-28 13:30:12.961 - info: lightify.0 (2405) terminating
              2019-11-28 13:30:12.961 - info: lightify.0 (2405) Terminated (NO_ERROR): Without reason
              2019-11-28 13:30:13.465 - error: host.iobroker Caught by controller[0]: TypeError: Cannot read property 'val' of undefined
              2019-11-28 13:30:13.465 - error: host.iobroker Caught by controller[0]: at Devices.setState (/opt/iobroker/node_modules/soef/soef.js:642:36)
              2019-11-28 13:30:13.465 - error: host.iobroker Caught by controller[0]: at /opt/iobroker/node_modules/soef/soef.js:609:26
              2019-11-28 13:30:13.465 - error: host.iobroker Caught by controller[0]: at (anonymous function).(anonymous function)._0x344e03 (/opt/iobroker/node_modules/iobroker.objects-redis/index.js:17:77549)
              2019-11-28 13:30:13.465 - error: host.iobroker Caught by controller[0]: at tryCatcher (/opt/iobroker/node_modules/standard-as-callback/built/utils.js:11:23)
              2019-11-28 13:30:13.465 - error: host.iobroker Caught by controller[0]: at promise.then (/opt/iobroker/node_modules/standard-as-callback/built/index.js:19:49)
              2019-11-28 13:30:13.465 - error: host.iobroker Caught by controller[0]: at process._tickCallback (internal/process/next_tick.js:68:7)
              2019-11-28 13:30:13.465 - info: host.iobroker instance system.adapter.lightify.0 terminated with code 0 (NO_ERROR)
              2019-11-28 13:30:13.465 - info: host.iobroker Restart adapter system.adapter.lightify.0 because enabled
              2019-11-28 13:30:15.664 - info: host.iobroker "system.adapter.lightify.0" disabled
              • A AgentLibelle
                Hallo an alle,
                AsgothianA Offline
                AsgothianA Offline
                Asgothian
                @AgentLibelle
                Es scheint so das in einer Bibliothek ein umgesetzter Wert nicht abgefangen wird. Das im Detail zu finden ist nicht einfach, insbesondere weil ich den Adapter selber nicht laufen lassen kann - ich hab die Hardware nicht.
                Du kannst versuchen im Modul soef in der Datei /opt/iobroker/node_modules/soef/soef.js folgende Anpassung vornehmen:
                this.setState = function (o, id, val, ack) {
                  if (val !== undefined) objects[id].val = val
                zu
                  if (objects[id] == undefined) return;
                ändern.
                Alles auf eigene Gefahr.
                A.
                  Marc-Nied
                  schrieb am zuletzt editiert von Marc-Nied
                  Das Problem besteht bei mir auch. Vor Wochen hatte die Anpassung "var cnt = data.readUInt8(~~pos + 16);" mal geholfen aber nach der heutigen Neuinstallation, klappt keine von den Lösungen. Hat jemand Kontakt zum Adapter Entwickler und kann mal darauf hinweisen?
                  @soef Der Adapter war doch von dir, oder? Kannst du uns vielleicht helfen?
                  Raspberry PI3 mit 120 GB SSD
                  Osram LED´s und Strip, TP Link HS100 & HS110, Z-Wave.Me USB, Fibaro Motion Sensor & Wall Plug, Philio 4-in-1 (Tür-/Fensterkontakt), Sonos, Echo Show, Echo und Echo Dot, Fritz DECT 210 & 100, Arlo Pro, Gi…
                  • F Offline
                    fischmir
                    schrieb am zuletzt editiert von fischmir
                    Gleiches Problem hier:
                    host.ioBroker-Pi	2019-12-11 10:21:00.024	info	instance system.adapter.dwd.0 started with pid 29168
                    host.ioBroker-Pi	2019-12-11 10:20:57.495	info	Restart adapter system.adapter.lightify.0 because enabled
                    host.ioBroker-Pi	2019-12-11 10:20:57.495	info	instance system.adapter.lightify.0 terminated with code 0 (NO_ERROR)
                    host.ioBroker-Pi	2019-12-11 10:20:57.495	error	Caught by controller[0]: at process._tickCallback (internal/process/next_tick.js:68:7)
                    host.ioBroker-Pi	2019-12-11 10:20:57.494	error	Caught by controller[0]: at promise.then (/opt/iobroker/node_modules/standard-as-callback/built/index.js:19:49)
                    host.ioBroker-Pi	2019-12-11 10:20:57.494	error	Caught by controller[0]: at tryCatcher (/opt/iobroker/node_modules/standard-as-callback/built/utils.js:11:23)
                    host.ioBroker-Pi	2019-12-11 10:20:57.494	error	Caught by controller[0]: at client.set.err (/opt/iobroker/node_modules/iobroker.js-controller/lib/objects/objectsInRedis.js:2044:51)
                    host.ioBroker-Pi	2019-12-11 10:20:57.494	error	Caught by controller[0]: at /opt/iobroker/node_modules/soef/soef.js:609:26
                    host.ioBroker-Pi	2019-12-11 10:20:57.493	error	Caught by controller[0]: at Devices.setState (/opt/iobroker/node_modules/soef/soef.js:642:36)
                    host.ioBroker-Pi	2019-12-11 10:20:57.493	error	Caught by controller[0]: TypeError: Cannot read property 'val' of undefined
                    Was kann man nun machen?
                      Marc-Nied
                      Seit dem heutigen Versuch mit den Anpassungen:
                      und
                      Funktioniert mein Lightify Adapter wieder! Endlich ist das Thema vom Tisch!
                      F 1 Antwort Letzte Antwort
                      • M Marc-Nied
                        und
                        fischmir
                        @Marc-Nied
                        Wie Wo mache ich diese Änderung?
                        • F fischmir
                          @Marc-Nied
                          Marc-Nied
                          @fischmir
                          in der Datei
                          in Zeile 463, in der Datei
                          sudo nano lightify.js aufrufen und zu der Zeile gehen
                          Dann Eintrag “var cnt = data.readUInt8(pos + 16);"
                          in "var cnt = data.readUInt8(~~pos + 16);" ändern und speichern.
                          Dann noch die Anpassung in der Datei soef
                          sudo nano soef.js aufrufen (die Zeile weiß ich nicht, habe es stumpf gesucht) und in diesen Code
                          ergänzen um if (objects[id] == undefined) return;
                          Also so muss es gesamt aussehen
                          Speichern, Linux Reboot und danach Adapter starten und es lief bei mir.
                            struppi_2000
                            der Vorschlag von Marc Nied war klasse die Änderung in Zeile 463 hat geholfen!
                            • S struppi_2000
                              Marc-Nied
                              @struppi_2000 Das war nicht meine Leistung sondern nur das zusammengefasste Wissen anderer :-)
                              Aber es freut mich das es bei dir nun auch wieder funktioniert!
                              horos73H 1 Antwort Letzte Antwort
                              • M Marc-Nied
                                horos73H Offline
                                horos73H Offline
                                horos73
                                schrieb am zuletzt editiert von horos73
                                @Marc-Nied Hallo Marc, (und jeder, der mitliest), ich bräuchte Deine/Eure Hilfe:
                                Ich habe heute Node von Version 8.x auf 10.x angehoben (gemäß der Doku, also auch den Fixer laufen lassen, Reihenfolge der Anweisungen beachtet). Zunächst hatte ich einige Fehler bei NPM rebuild, später starteten dann der Lightify, ioGo und Zwave-Adapter nicht mehr. [Node.js v10.18.0, NPM 6.13.4]
                                Ich habe dann zu guter letzt das reinstall.sh durchlaufen lassen, jetzt starten ioGo und Zwave zwar, doch Lightify nicht.
                                Ich habe eben basierend auf Deiner Zusammenfassung die beiden Dateien geändert, sowohl einen System-Reboot, als auch einen Adapter-Upload gemacht. Der Adapter bleibt aber auf Rot und spuckt diese Meldung im Log aus:
                                host.ioBrokerDeb	2020-01-04 16:51:59.258	error	instance system.adapter.lightify.0 terminated with code 1 (JS_CONTROLLER_STOPPED)
                                host.ioBrokerDeb	2020-01-04 16:51:59.258	error	Caught by controller[0]: at Module._compile (internal/modules/cjs/loader.js:778:30)
                                host.ioBrokerDeb	2020-01-04 16:51:59.257	error	Caught by controller[0]: at Object.<anonymous> (/opt/iobroker/node_modules/iobroker.lightify/lightify.js:17:16)
                                host.ioBrokerDeb	2020-01-04 16:51:59.257	error	Caught by controller[0]: at require (internal/modules/cjs/helpers.js:25:18)
                                host.ioBrokerDeb	2020-01-04 16:51:59.257	error	Caught by controller[0]: at Module.require (internal/modules/cjs/loader.js:692:17)
                                host.ioBrokerDeb	2020-01-04 16:51:59.257	error	Caught by controller[0]: at Function.Module._load (internal/modules/cjs/loader.js:585:3)
                                host.ioBrokerDeb	2020-01-04 16:51:59.257	error	Caught by controller[0]: at tryModuleLoad (internal/modules/cjs/loader.js:593:12)
                                host.ioBrokerDeb	2020-01-04 16:51:59.257	error	Caught by controller[0]: at Module.load (internal/modules/cjs/loader.js:653:32)
                                host.ioBrokerDeb	2020-01-04 16:51:59.257	error	Caught by controller[0]: at Object.Module._extensions..js (internal/modules/cjs/loader.js:789:10)
                                host.ioBrokerDeb	2020-01-04 16:51:59.257	error	Caught by controller[0]: at Module._compile (internal/modules/cjs/loader.js:778:30)
                                host.ioBrokerDeb	2020-01-04 16:51:59.257	error	Caught by controller[0]: at Object.<anonymous> (/opt/iobroker/node_modules/iobroker.lightify/lib/lightify.js:1:1)
                                host.ioBrokerDeb	2020-01-04 16:51:59.257	error	Caught by controller[0]: ReferenceError: W is not defined
                                host.ioBrokerDeb	2020-01-04 16:51:59.256	error	Caught by controller[0]: ^
                                host.ioBrokerDeb	2020-01-04 16:51:59.256	error	Caught by controller[0]: W// Taken from here https://github.com/rainlake/node-lightify
                                host.ioBrokerDeb	2020-01-04 16:51:59.256	error	Caught by controller[0]: /opt/iobroker/node_modules/iobroker.lightify/lib/lightify.js:1
                                Iobroker läuft bei mir in einer DebianVM auf Proxmox.
                                Ich bin leider (noch) nicht der Linux/Iobroker-Crack dass ich das alleine lösen konnte; SuFu habe ich benutzt, nur leider keine funktionierende Lösung gefunden.
                                Eine (verzweifelte) Idee hätte ich noch: den js-controller auf die v2 stable zu hieven. Könnte das was bringen?
                                Hast Du oder hat jemand eine Idee?
                                Wenn ich noch mehr Infos braucht, dann sagt bitte Bescheid (mir raucht langsam der Kopf.. 😰 )
                                Danke Dir/Euch,
                                schöne Grüße und noch ein nachträglich Frohes Neues!
                                Holger
                                Nachtrag: Adapter gelöscht und neu installiert bringt denselben Fehler..
                                Noch'n Nachtrag: keine Ahnung, wie das ging, aber ich habe wohl den js-controller mitgeupdated. Ist jetzt v2.1.1.
                                🤕 Ich raff's nicht.... Hab die Schritte im "js-controller 2 jetzt für alle im Stable" - Post gar nicht angerührt...
                                Naja, Problem besteht halt. Hab noch einen Snapshot, vielleicht ist ein Zurück die beste Option..?
                                ostseereiterO 1 Antwort Letzte Antwort
                                • horos73H horos73
                                  Danke Dir/Euch,
                                  Holger
                                  ostseereiterO Offline
                                  ostseereiter
                                  @horos73 Hast du schon eine Lösung meiner ist nach dem Update des js-Controller auch rot.
                                  Wird dieser Adapter noch weiterentwickelt?
                                  Gruß OSR
                                  Plattform
                                  Linux x64 CPUs2 AMD G-T56N Processor 1646 MHz 8GB RAM
                                  • ostseereiterO ostseereiter
                                    horos73H Offline
                                    horos73H Offline
                                    horos73
                                    @ostseereiter Hallo, ostseereiter,
                                    ich bin vor 2 Wochen mittels Snapshot wieder zurück auf eine System-Version vor dem Update-Debakel und lasse das System erstmal so.
                                    Aber: der Plan ist demnächst, wenn ich Zeit und Muße habe, eine neue VM mit Debian 10 und einem frischen, aktuellen iobroker aufzubauen; dann ein minal-Backup zurückspielen und beten.
                                    Wenn auch das nicht hilft, überlege ich mir eine Hue-Bridge zu holen; die soll ja mit den Osram-Lampen können (bis auf Firmware-Updates)- Und ich glaube der Hue-Adapter wird aktiver weitergeführt, als der Osram...
                                    Tut mir leid, dass ich Dir da grad keine große Hilfe bin. Vielleicht liest einer der Profis bzw. einer der anderen Thread-Teilnehmer mit und hat eine Idee...?
                                    Kur-/Mittel-/Langfristig - denke ich - "müssen" wir auf die neue Node/JS-Controller Versionen umsteigen (mein hm-reg und rpc brauchen inzwischen auch schon JS 2.x).
                                    Hast Du auch Proxmox?
                                    Lass uns in Kontakt bleiben! Ich melde mich, sowie ich weiter bin!
                                    Liebe Grüße,
                                    Holger
                                    • horos73H horos73
                                      Liebe Grüße,
                                      Holger
                                      ostseereiter
                                      @horos73 Nein habe kein Proxmox meine Iobroker läuft autark auf eine HP Client möchte ich auch so beibehalten. Eine Alternative wäre ja noch die Plugs mit Zigbee und Die 7 lampen austauschen, Da ist man auch ganz schnell bei 180 Euro dann vielleicht doch die Hue Bridge.
                                      Gruß OSR
                                      Plattform
                                      FredFF 1 Antwort Letzte Antwort
                                        FredFF Online
                                        FredFF Online
                                        FredF
                                        Most Active Forum Testing
                                        @ostseereiter @horos73
                                        Vorneweg ich nutze den Adapter nicht und habe hier nur interesse halber mitgelesen...
                                        Der Lightify Adapter, der über den Admin installiert wird, ist doch die soef Version (soef = Entwickler = nicht mehr aktiv).
                                        Da soef nicht mehr aktiv ist, hat @apollon77 (sorry, wenn ich dir noch mehr Arbeit gebe) den als community Adapter erstellt (sagt man das so?).
                                        Vielleicht solltet ihr den mal versuchen. Über Installieren aus eigener URL dann bei beliebig die URL einfügen.
                                        Wahrscheinlich solltet ihr dort in Github euer Problem als issue melden.
                                        Just my 50cents und wenn ich komplett falsch liegen sollte... duck und weg
                                        ostseereiterO horos73H apollon77A 3 Antworten Letzte Antwort
                                        • FredFF FredF
                                          ostseereiter
                                          @FredF sagte in Osram Lightyfy Adapter Problem:
                                          die soef Version
                                          Ich glaube es gibt blos die soef Version.
                                          Gruß OSR
                                          Plattform
