  3. Entwicklung
  4. ZigBee CC253x Adapter - nur neue/unbekannte Geräte Version 0.9.x
894 Beiträge 82 Kommentatoren 326.7k Aufrufe 23 Beobachtet
  • MyzerATM MyzerAT
    am adapter 30
    beim pairen kommt das jetzt , er ist auf grün
    zigbee.0	2019-03-18 23:13:37.272	info	new dev 0x84182600000ff39d 5722 Plug 01
    zigbee.0	2019-03-18 23:13:35.564	info	new dev 0xd0cf5efffeea2f74 61451 TRADFRI signal repeater
    zigbee.0	2019-03-18 23:13:17.172	info	Zigbee: allowing new devices to join.
    zigbee.0	2019-03-18 23:13:17.147	error	Join failure.. Error: Shepherd is not enabled.
    zigbee.0	2019-03-18 23:13:17.147	info	Zigbee: allowing new devices to join.
    zigbee.0	2019-03-18 23:13:10.286	error	Join failure.. Error: request timeout
    zigbee.0	2019-03-18 23:13:08.785	info	Zigbee: allowing new devices to join.
    zigbee.0	2019-03-18 23:13:08.774	error	Join failure.. Error: Shepherd is not enabled.
    zigbee.0	2019-03-18 23:13:08.774	info	Zigbee: allowing new devices to join.
    zigbee.0	2019-03-18 23:13:03.511	info	new dev 0x0017880104101f75 63604 LWB010
    zigbee.0	2019-03-18 23:12:43.353	info	new dev 0x7cb03eaa00b1d521 2823 Plug 01
    zigbee.0	2019-03-18 23:12:41.220	info	new dev 0x000d6ffffe9cc0e8 32015 TRADFRI signal repeater
    zigbee.0	2019-03-18 23:12:07.087	info	new dev 0x000d6ffffe9c27d9 6020 TRADFRI signal repeater
    zigbee.0	2019-03-18 23:12:06.536	info	Zigbee: allowing new devices to join.
    zigbee.0	2019-03-18 23:12:06.488	error	Join failure.. Error: Shepherd is not enabled.
    zigbee.0	2019-03-18 23:12:06.488	info	Zigbee: allowing new devices to join.
    zigbee.0	2019-03-18 23:11:35.613	error	Cannot get the Node Descriptor of the Device: 0x00158d000192d245 (Error: Timed out after 10000 ms)
    zigbee.0	2019-03-18 23:11:15.608	error	Cannot get the Node Descriptor of the Device: 0x00158d000192d245 (Error: Timed out after 10000 ms)
    zigbee.0	2019-03-18 23:11:13.309	warn	Failed to configure 0x7cb03eaa00b0a6f0 Plug 01, try again in 300 sec
    zigbee.0	2019-03-18 23:11:13.299	warn	Failed to configure 0x7cb03eaa00b09a56 Plug 01, try again in 300 sec
    zigbee.0	2019-03-18 23:10:55.604	error	Cannot get the Node Descriptor of the Device: 0x00158d000192d245 (Error: Timed out after 10000 ms)
    zigbee.0	2019-03-18 23:10:53.139	info	Successfully configured 0x00158d0001922dcd
    zigbee.0	2019-03-18 23:10:35.601	error	Cannot get the Node Descriptor of the Device: 0x00158d000192d245 (Error: Timed out after 10000 ms)
    zigbee.0	2019-03-18 23:10:34.178	info	Successfully configured 0x84182600000ff39d
    zigbee.0	2019-03-18 23:10:24.317	info	Successfully configured 0x7cb03eaa00b1d521
    zigbee.0	2019-03-18 23:10:14.795	info	Zigbee: allowing new devices to join.
    zigbee.0	2019-03-18 23:10:14.784	error	Join failure.. Error: Shepherd is not enabled.
    zigbee.0	2019-03-18 23:10:14.779	info	Zigbee: allowing new devices to join.
    zigbee.0	2019-03-18 23:10:11.405	error	Error: spawn udevadm ENOENT
    zigbee.0	2019-03-18 23:10:11.398	error	Error: spawn udevadm ENOENT
    AsgothianA Offline
    AsgothianA Offline
    Asgothian
    #881
    @MyzerAT
    Das ist noch mit der "standard" Firmware, denke ich ? Wenn ja, mach mal bitte folgendes :
    • mach dir eine Kopie von der Datei /opt/iobroker/iobroker-data/zigbee.0/shepherd.db
    • editier die Datei, wirf 2 der darin enthaltenen Geräte hinaus. Einzelne Geräte sind als Text beschrieben - die Beschreibung beginnt immer mit {"id":
    • Speicher die Datei und starte dann den adapter neu.
    Ich bin mir inzwischen fast sicher das Du den Stick an der Grenze des machbaren betreibst.
    A.
    • G gosund
      Wo finde ich den besagten Adapter von gestern Abend? Link bitte.
      Welche Firmware meinst Du? Die max-devices?
      Und kannst Du bitte einen Screenshot Deiner Netzwerkkarte posten? Bzw. mir sagen, ob Du auch Verbindungen zwischen den Lampen selbst siehst?!
      AsgothianA Offline
      AsgothianA Offline
      Asgothian
      #882
      @gosund sagte in ZigBee CC253x Adapter - nur neue/unbekannte Geräte:
      du kannst ihn gerne versuchen:
      https://github.com/asgothian/ioBroker.zigbee/tarball/Admin_changes
      Das ganze aber ohne Gewähr. Bei mir (und anscheinend bei @Wildbill) läuft er, aber auf Github gab es (berechtigte) bedenken gegen einiges was ich da geändert hab.
      W 1 Antwort Letzte Antwort
      • MyzerATM Offline
        MyzerATM Offline
        MyzerAT
        schrieb am zuletzt editiert von MyzerAT
        #883
        @Asgothian
        hab ich gemacht bekomme ihn aber nicht mehr zum laufen
        host.RDJL_Home	2019-03-18 23:36:44.545	info	Restart adapter system.adapter.zigbee.0 because enabled
        host.RDJL_Home	2019-03-18 23:36:44.543	error	instance system.adapter.zigbee.0 terminated with code 7 (Adapter already running)
        host.RDJL_Home	2019-03-18 23:36:42.861	info	instance system.adapter.zigbee.0 started with pid 15542
        host.RDJL_Home	2019-03-18 23:36:42.859	info	object change system.adapter.zigbee.0
        host.RDJL_Home	2019-03-18 23:36:23.961	info	Do not restart adapter system.adapter.zigbee.0 because disabled or deleted
        host.RDJL_Home	2019-03-18 23:36:23.958	error	instance system.adapter.zigbee.0 terminated with code 7 (Adapter already running)
        host.RDJL_Home	2019-03-18 23:36:21.230	info	object change system.adapter.zigbee.0
        host.RDJL_Home	2019-03-18 23:35:52.794	info	Restart adapter system.adapter.zigbee.0 because enabled
        host.RDJL_Home	2019-03-18 23:35:52.792	error	instance system.adapter.zigbee.0 terminated with code 7 (Adapter already running)
        host.RDJL_Home	2019-03-18 23:35:51.537	info	instance system.adapter.zigbee.0 started with pid 15437
        host.RDJL_Home	2019-03-18 23:35:51.534	info	object change system.adapter.zigbee.0
        zigbee.0	2019-03-18 23:35:37.161	error	Error: spawn udevadm ENOENT
        admin.0	2019-03-18 23:35:37.009	info	successful connection to socket.io from ::ffff:192.168.0.2
        host.RDJL_Home	2019-03-18 23:35:32.507	info	Restart adapter system.adapter.zigbee.0 because enabled
        host.RDJL_Home	2019-03-18 23:35:32.506	error	instance system.adapter.zigbee.0 terminated with code 7 (Adapter already running)
        host.RDJL_Home	2019-03-18 23:35:31.094	info	instance system.adapter.zigbee.0 started with pid 15367
        host.RDJL_Home	2019-03-18 23:35:31.091	info	object change system.adapter.zigbee.0
        zigbee.0	2019-03-18 23:35:15.105	error	Error: spawn udevadm ENOENT
        admin.0	2019-03-18 23:35:14.859	info	successful connection to socket.io from ::ffff:192.168.0.2
        host.RDJL_Home	2019-03-18 23:35:13.221	info	object change system.adapter.zigbee.0
        host.RDJL_Home	2019-03-18 23:35:08.468	info	Restart adapter system.adapter.zigbee.0 because enabled
        host.RDJL_Home	2019-03-18 23:35:08.467	error	instance system.adapter.zigbee.0 terminated with code 7 (Adapter already running)
        host.RDJL_Home	2019-03-18 23:35:07.169	info	instance system.adapter.zigbee.0 started with pid 15318
        zigbee.0	2019-03-18 23:35:04.161	error	Error: spawn udevadm ENOENT
        admin.0	2019-03-18 23:35:04.012	info	successful connection to socket.io from ::ffff:192.168.0.2
        host.RDJL_Home	2019-03-18 23:34:37.162	info	Restart adapter system.adapter.zigbee.0 because enabled
        host.RDJL_Home	2019-03-18 23:34:37.160	error	instance system.adapter.zigbee.0 terminated with code 7 (Adapter already running)
        host.RDJL_Home	2019-03-18 23:34:35.774	info	instance system.adapter.zigbee.0 started with pid 15268
        host.RDJL_Home	2019-03-18 23:34:35.774	info	object change system.adapter.zigbee.0
        host.RDJL_Home	2019-03-18 23:34:17.327	info	Restart adapter system.adapter.zigbee.0 because enabled
        host.RDJL_Home	2019-03-18 23:34:17.327	error	instance system.adapter.zigbee.0 terminated with code 7 (Adapter already running)
        ich kanns nimmer lesen, er läuft nicht und dennoch bekomme ich die meldung
        lg Rudi
        Node 22.23.0
        Nodejs 22.23.0
        npm 10.9.8
        js-controller 7.2.2
        • MyzerATM MyzerAT
          @Asgothian
          AsgothianA Offline
          AsgothianA Offline
          Asgothian
          #884
          @MyzerAT du musst erst einmal sicher stellen das er komplett weg ist.
          MyzerATM 2 Antworten Letzte Antwort
          • AsgothianA Asgothian
            MyzerATM Offline
            MyzerATM Offline
            MyzerAT
            #885
            @Asgothian
            mach ich eh per killall -q io.zigbee
            jetzt bekomme ich das
            host.RDJL_Home	2019-03-18 23:41:22.782	info	Do not restart adapter system.adapter.zigbee.0 because disabled or deleted
            host.RDJL_Home	2019-03-18 23:41:22.780	error	instance system.adapter.zigbee.0 terminated with code 7 (Adapter already running)
            lg Rudi
            Node 22.23.0
            Nodejs 22.23.0
            npm 10.9.8
            js-controller 7.2.2
              MyzerATM Offline
              MyzerATM Offline
              MyzerAT
              #886
              @Asgothian sagte in ZigBee CC253x Adapter - nur neue/unbekannte Geräte:
              wie überprüfe ich das, so?
              lg Rudi
              Node 22.23.0
              Nodejs 22.23.0
              npm 10.9.8
              js-controller 7.2.2
              • MyzerATM MyzerAT
                AsgothianA Offline
                AsgothianA Offline
                Asgothian
                #887
                @MyzerAT ja
                • MyzerATM Offline
                  MyzerATM Offline
                  MyzerAT
                  #888
                  5 Aktoren hab ich raus geschmissen, will noch 2 Thermostate rein bekommen sinnlos
                  zigbee.0	2019-03-18 23:54:07.566	error	Cannot get the Node Descriptor of the Device: 0x00158d000192d245 (Error: Timed out after 10000 ms)
                  zigbee.0	2019-03-18 23:53:47.559	error	Cannot get the Node Descriptor of the Device: 0x00158d000192d245 (Error: Timed out after 10000 ms)
                  zigbee.0	2019-03-18 23:53:27.552	error	Cannot get the Node Descriptor of the Device: 0x00158d000192d245 (Error: Timed out after 10000 ms)
                  sonoff.0	2019-03-18 23:53:07.765	info	Client [DVES_3E4B4242] connected with secret 1552949587763_8968
                  zigbee.0	2019-03-18 23:53:07.550	error	Cannot get the Node Descriptor of the Device: 0x00158d000192d245 (Error: Timed out after 10000 ms)
                  sonoff.0	2019-03-18 23:53:07.493	info	Client [DVES_3E4B4242] connection closed: closed
                  zigbee.0	2019-03-18 23:52:47.543	error	Cannot get the Node Descriptor of the Device: 0x00158d000192d245 (Error: Timed out after 10000 ms)
                  zigbee.0	2019-03-18 23:52:43.794	info	Zigbee: allowing new devices to join.
                  zigbee.0	2019-03-18 23:52:27.539	error	Cannot get the Node Descriptor of the Device: 0x00158d000192d245 (Error: Timed out after 10000 ms)
                  zigbee.0	2019-03-18 23:52:07.535	error	Cannot get the Node Descriptor of the Device: 0x00158d000192d245 (Error: Timed out after 10000 ms)
                  zigbee.0	2019-03-18 23:51:47.532	error	Cannot get the Node Descriptor of the Device: 0x00158d000192d245 (Error: Timed out after 10000 ms)
                  zigbee.0	2019-03-18 23:51:27.528	error	Cannot get the Node Descriptor of the Device: 0x00158d000192d245 (Error: Timed out after 10000 ms)
                  zigbee.0	2019-03-18 23:51:27.150	info	Zigbee: allowing new devices to join.
                  zigbee.0	2019-03-18 23:51:07.522	error	Cannot get the Node Descriptor of the Device: 0x00158d000192d245 (Error: Timed out after 10000 ms)
                  zigbee.0	2019-03-18 23:50:47.519	error	Cannot get the Node Descriptor of the Device: 0x00158d000192d245 (Error: Timed out after 10000 ms)
                  zigbee.0	2019-03-18 23:50:38.629	warn	Failed to configure 0x7cb03eaa00b1d521 Plug 01, try again in 300 sec
                  zigbee.0	2019-03-18 23:50:38.611	warn	Failed to configure 0x84182600000ff39d Plug 01, try again in 300 sec
                  zigbee.0	2019-03-18 23:50:38.592	warn	Failed to configure 0x7cb03eaa00b0a6f0 Plug 01, try again in 300 sec
                  zigbee.0	2019-03-18 23:50:38.573	warn	Failed to configure 0x7cb03eaa00b09a56 Plug 01, try again in 300 sec
                  zigbee.0	2019-03-18 23:50:29.472	warn	Failed to configure 0x00158d0001922cdf SPZB0001, try again in 300 sec
                  zigbee.0	2019-03-18 23:50:27.052	info	Successfully configured 0x00158d0001922dcd
                  lg Rudi
                  Node 22.23.0
                  Nodejs 22.23.0
                  npm 10.9.8
                  js-controller 7.2.2
                  • MyzerATM Offline
                    MyzerATM Offline
                    MyzerAT
                    #889
                    ich gebs auf, sitze sicher seit einer woche an dem und es wird immer schlimmer statt besser, hab ein haufen geld ausgegeben für was was nicht funktioniert, das ärgert mich schon sehr !
                    lg Rudi
                    Node 22.23.0
                    Nodejs 22.23.0
                    npm 10.9.8
                    js-controller 7.2.2
                      W Online
                      W Online
                      Wildbill
                      #890
                      auch heute morgen noch keine einzige Meldung von zigbee im Log. Lampen haben ganz normal funktioniert.
                      In welchem Thread auf Github wird über Deine Anpassung diskutiert? Finde irgendwie nichts. In Deinem Repo sind ja keine Issues. Beim iobroker-Github oder bei Koenkk?
                      Gruss, Jürgen
                      • W Wildbill
                        Gruss, Jürgen
                        AsgothianA Offline
                        AsgothianA Offline
                        Asgothian
                        #891
                        @Wildbill
                        Die Diskussion ist am offiziellen repo: Hier
                        • MyzerATM MyzerAT
                          AsgothianA Offline
                          AsgothianA Offline
                          Asgothian
                          #892
                          @MyzerAT die Frage war nicht ob du noch was rein bekommst sondern ob das netz dann stabil ist.
                          Du bist mit deinen geräten nah am Limit dessen was der Stick verträgt. Da wir den Speicher des Stick nicht abfragen können müssen wir das durch versuche heraus bekommen.
                            @Wildbill
                            W Online
                            W Online
                            Wildbill
                            #893
                            @Wildbill
                            Danke, habe es eben mal durchgelesen. Ich befürchtete schon, dass irgendeine Anpassung dafür sorgt, dass der Adapter oder der Stick sich nach einer bestimmten Zeit automatisch abschiesst, löscht oder so etwas. 😁
                            Ich lasse mal weiter laufen und wenn bis heute Abend keine größeren Probleme aufgetaucht sind, dann werde ich noch ein paar Geräte anlernen. 4 IKEA-Birnen, 3 IKEA-BWMs, 2 IKEA Remote und 1 Hue-Dimmer-Switch warten noch auf den Einsatz.
                            Zumindest den IKEA-Gateway konnte ich gestern Abend mal abklemmen. Der muss ja nicht auch noch rumfunken, wenn auch auf Kanal 15, den Stick habe ich auf 25 und die WLANS auf 1 und 7 mit jeweils 20MHz.
                            @MyzerAT Das wäre vielleicht etwas, was Du bei Dir noch checken könntest. Wie sieht es funkmäßig generell auf dem von Dir für den Stick gewählten Adapter aus? Wenn Du den Standardkanal 11 übernommen hast und ein WLAN auf Kanal 1 in der Nähe, dann sind die beide auf der gleichen Frequenz und stören sich womöglich auch schon...
                            Gruss, Jürgen
                            • arteckA Offline
                              arteckA Offline
                              arteck
                              #894
                              hier gehts weiter
                              https://forum.iobroker.net/topic/21136/zigbee-cc253x-adapter-nur-neue-unbekannte-geräte-ab-adapter-0-10-x
