  4. [Yeelight-2 Adapter] Rebuild Version 0.9.X
91 Beiträge 21 Kommentatoren 14.8k Aufrufe 5 Beobachtet
  • MeistertrM Offline
    MeistertrM Offline
    Meistertr
    #61
    @hanniko:
    control bleibt weiterhin leer ` Kannst du das nochmal durchfühten und vom Start an den log posten
    Gesendet von meinem Handy
    • H Offline
      hanniko
      #62
      Ich hatte zuerst alles gelöscht, und die Lampe zurück gesetzt, dann vergessen die Lan Steuerung zu aktivieren.
      Danach wurde die Lampe erkannt, es gab aber immer noch nichts unter control.
      yeelight-2.0 2018-11-25 20:01:45.692 debug YEELIGHT FOUND: 192.168.1.36:55443 id: 0x000000000000000 model: color
      yeelight-2.0 2018-11-25 20:01:43.678 debug SMARTNAME:
      yeelight-2.0 2018-11-25 20:01:43.676 debug OLD CONF. FROM OBJ: {"name":"color2","ip":"192.168.1.36","port":"","smart_name":"","type":"color","id":"0x000000000000000","supports":["get_prop","set_default","set_power","toggle","set_bright","star
      yeelight-2.0 2018-11-25 20:01:43.672 debug OBJ_ELEMENT: yeelight-2.0.color2
      yeelight-2.0 2018-11-25 20:01:43.672 debug DEVICES IN OBJECTS FOUND: 1
      yeelight-2.0 2018-11-25 20:01:43.671 debug DEVICES IN OBJECTS: {"yeelight-2.0.color2":{"type":"device","common":{"name":"color","icon":"/icons/color.png"},"native":{"sid":"color2","type":"color"},"from":"system.adapter.yeelight-2.0","ts":1543
      yeelight-2.0 2018-11-25 20:01:43.638 debug DEVICES IN CONFIG: [{"name":"color2","ip":"192.168.1.36","port":"55443","smart_name":"","type":"color","id":"0x000000000000000","supports":["get_prop","set_default","set_power","toggle","set_bright",
      yeelight-2.0 2018-11-25 20:01:43.628 info starting. Version 0.9.5 in /opt/iobroker/node_modules/iobroker.yeelight-2, node: v4.9.1
      yeelight-2.0 2018-11-25 20:01:43.522 debug statesDB connected
      yeelight-2.0 2018-11-25 20:01:43.454 debug objectDB connected
      yeelight-2.0 2018-11-25 20:01:14.397 info terminating
      yeelight-2.0 2018-11-25 20:01:14.392 info cleaned everything up…
      yeelight-2.0 2018-11-25 20:01:14.391 error at Timer.listOnTimeout (timers.js:92:15)
      yeelight-2.0 2018-11-25 20:01:14.391 error at null._onTimeout (/opt/iobroker/node_modules/iobroker.yeelight-2/main.js:481:74)
      yeelight-2.0 2018-11-25 20:01:14.391 error at YeelightSearch.addInitLights (/opt/iobroker/node_modules/yeelight-wifi/build/index.js:103:22)
      yeelight-2.0 2018-11-25 20:01:14.391 error at new Yeelight (/opt/iobroker/node_modules/yeelight-wifi/build/Yeelight.js:125:18)
      yeelight-2.0 2018-11-25 20:01:14.391 error at Socket.connect (net.js:888:37)
      yeelight-2.0 2018-11-25 20:01:14.391 error at Socket.connect (net.js:925:5)
      yeelight-2.0 2018-11-25 20:01:14.391 error at lookupAndConnect (net.js:946:13)
      yeelight-2.0 2018-11-25 20:01:14.391 error TypeError: port should be a number or string: null
      yeelight-2.0 2018-11-25 20:01:14.389 error uncaught exception: port should be a number or string: null
      yeelight-2.0 2018-11-25 20:01:12.368 debug SMARTNAME:
      yeelight-2.0 2018-11-25 20:01:12.366 debug OLD CONF. FROM OBJ: {"name":"color2","ip":"192.168.1.36","port":"","smart_name":"","type":"color","id":"0x000000000000000","supports":["get_prop","set_default","set_power","toggle","set_bright","star
      yeelight-2.0 2018-11-25 20:01:12.362 debug OBJ_ELEMENT: yeelight-2.0.color2
      yeelight-2.0 2018-11-25 20:01:12.362 debug DEVICES IN OBJECTS FOUND: 1
      yeelight-2.0 2018-11-25 20:01:12.362 debug DEVICES IN OBJECTS: {"yeelight-2.0.color2":{"type":"device","common":{"name":"color","icon":"/icons/color.png"},"native":{"sid":"color2","type":"color"},"from":"system.adapter.yeelight-2.0","ts":1543
      yeelight-2.0 2018-11-25 20:01:12.333 debug DEVICES IN CONFIG: [{"name":"color2","ip":"192.168.1.36","port":"","smart_name":"","type":"color","id":"0x000000000000000","supports":["get_prop","set_default","set_power","toggle","set_bright","star
      yeelight-2.0 2018-11-25 20:01:12.324 info starting. Version 0.9.5 in /opt/iobroker/node_modules/iobroker.yeelight-2, node: v4.9.1
      yeelight-2.0 2018-11-25 20:01:12.217 debug statesDB connected
      yeelight-2.0 2018-11-25 20:01:12.157 debug objectDB connected
      yeelight-2.0 2018-11-25 20:00:41.136 info terminating
      yeelight-2.0 2018-11-25 20:00:41.131 info cleaned everything up...
      yeelight-2.0 2018-11-25 20:00:41.130 error at Timer.listOnTimeout (timers.js:92:15)
      yeelight-2.0 2018-11-25 20:00:41.130 error at null._onTimeout (/opt/iobroker/node_modules/iobroker.yeelight-2/main.js:481:74)
      yeelight-2.0 2018-11-25 20:00:41.130 error at YeelightSearch.addInitLights (/opt/iobroker/node_modules/yeelight-wifi/build/index.js:103:22)
      yeelight-2.0 2018-11-25 20:00:41.130 error at new Yeelight (/opt/iobroker/node_modules/yeelight-wifi/build/Yeelight.js:125:18)
      yeelight-2.0 2018-11-25 20:00:41.130 error at Socket.connect (net.js:888:37)
      yeelight-2.0 2018-11-25 20:00:41.130 error at Socket.connect (net.js:925:5)
      yeelight-2.0 2018-11-25 20:00:41.130 error at lookupAndConnect (net.js:946:13)
      yeelight-2.0 2018-11-25 20:00:41.130 error TypeError: port should be a number or string: null
      yeelight-2.0 2018-11-25 20:00:41.128 error uncaught exception: port should be a number or string: null
      yeelight-2.0 2018-11-25 20:00:39.107 debug SMARTNAME:
      yeelight-2.0 2018-11-25 20:00:39.105 debug OLD CONF. FROM OBJ: {"name":"color2","ip":"192.168.1.36","port":"","smart_name":"","type":"color","id":"0x000000000000000","supports":["get_prop","set_default","set_power","toggle","set_bright","star
      yeelight-2.0 2018-11-25 20:00:39.101 debug OBJ_ELEMENT: yeelight-2.0.color2
      yeelight-2.0 2018-11-25 20:00:39.100 debug DEVICES IN OBJECTS FOUND: 1
      yeelight-2.0 2018-11-25 20:00:39.100 debug DEVICES IN OBJECTS: {"yeelight-2.0.color2":{"type":"device","common":{"name":"color","icon":"/icons/color.png"},"native":{"sid":"color2","type":"color"},"from":"system.adapter.yeelight-2.0","ts":1543
      yeelight-2.0 2018-11-25 20:00:39.038 debug DEVICES IN CONFIG: [{"name":"color2","ip":"192.168.1.36","port":"","smart_name":"","type":"color","id":"0x000000000000000","supports":["get_prop","set_default","set_power","toggle","set_bright","star
      yeelight-2.0 2018-11-25 20:00:39.028 info starting. Version 0.9.5 in /opt/iobroker/node_modules/iobroker.yeelight-2, node: v4.9.1
      yeelight-2.0 2018-11-25 20:00:38.921 debug statesDB connected
      yeelight-2.0 2018-11-25 20:00:38.868 debug objectDB connected
      yeelight-2.0 2018-11-25 20:00:07.838 info terminating
      yeelight-2.0 2018-11-25 20:00:07.807 info cleaned everything up...
      yeelight-2.0 2018-11-25 20:00:07.806 error at Timer.listOnTimeout (timers.js:92:15)
      yeelight-2.0 2018-11-25 20:00:07.806 error at null._onTimeout (/opt/iobroker/node_modules/iobroker.yeelight-2/main.js:481:74)
      yeelight-2.0 2018-11-25 20:00:07.806 error at YeelightSearch.addInitLights (/opt/iobroker/node_modules/yeelight-wifi/build/index.js:103:22)
      yeelight-2.0 2018-11-25 20:00:07.806 error at new Yeelight (/opt/iobroker/node_modules/yeelight-wifi/build/Yeelight.js:125:18)
      yeelight-2.0 2018-11-25 20:00:07.806 error at Socket.connect (net.js:888:37)
      yeelight-2.0 2018-11-25 20:00:07.806 error at Socket.connect (net.js:925:5)
      yeelight-2.0 2018-11-25 20:00:07.806 error at lookupAndConnect (net.js:946:13)
      yeelight-2.0 2018-11-25 20:00:07.806 error TypeError: port should be a number or string: null
      yeelight-2.0 2018-11-25 20:00:07.803 error uncaught exception: port should be a number or string: null
      yeelight-2.0 2018-11-25 20:00:07.776 debug CREATE DEVICE: yeelight-2.0.color2
      yeelight-2.0 2018-11-25 20:00:05.771 debug DEVICES IN OBJECTS FOUND: 0
      yeelight-2.0 2018-11-25 20:00:05.771 debug DEVICES IN OBJECTS: {}
      yeelight-2.0 2018-11-25 20:00:05.738 debug DEVICES IN CONFIG: [{"name":"color2","ip":"192.168.1.36","port":"","smart_name":"","type":"color","id":"0x000000000000000","supports":["get_prop","set_default","set_power","toggle","set_bright","star
      yeelight-2.0 2018-11-25 20:00:05.729 info starting. Version 0.9.5 in /opt/iobroker/node_modules/iobroker.yeelight-2, node: v4.9.1
      yeelight-2.0 2018-11-25 20:00:05.619 debug statesDB connected
      yeelight-2.0 2018-11-25 20:00:05.539 debug objectDB connected
      yeelight-2.0 2018-11-25 19:59:46.714 info terminating
      yeelight-2.0 2018-11-25 19:59:46.705 info cleaned everything up...
      yeelight-2.0 2018-11-25 19:59:46.666 debug SMARTNAME:
      yeelight-2.0 2018-11-25 19:59:46.665 debug OLD CONF. FROM OBJ: {"name":"color2","ip":"192.168.1.36","port":"","smart_name":"","type":"color","id":"0x000000000000000","supports":["get_prop","set_default","set_power","toggle","set_bright","star
      yeelight-2.0 2018-11-25 19:59:46.662 debug OBJ_ELEMENT: yeelight-2.0.color2
      yeelight-2.0 2018-11-25 19:59:46.662 debug DEVICES IN OBJECTS FOUND: 1
      yeelight-2.0 2018-11-25 19:59:46.661 debug DEVICES IN OBJECTS: {"yeelight-2.0.color2":{"type":"device","common":{"name":"color","icon":"/icons/color.png"},"native":{"sid":"color2","type":"color"},"from":"system.adapter.yeelight-2.0","ts":1543
      yeelight-2.0 2018-11-25 19:59:46.631 debug DEVICES IN CONFIG: [{"name":"color2","ip":"192.168.1.36","port":"","smart_name":"","type":"color","id":"0x000000000000000","supports":["get_prop","set_default","set_power","toggle","set_bright","star
      yeelight-2.0 2018-11-25 19:59:46.622 info starting. Version 0.9.5 in /opt/iobroker/node_modules/iobroker.yeelight-2, node: v4.9.1
      yeelight-2.0 2018-11-25 19:59:46.515 debug statesDB connected
      yeelight-2.0 2018-11-25 19:59:46.460 debug objectDB connected
      yeelight-2.0 2018-11-25 19:59:12.497 info terminating
      yeelight-2.0 2018-11-25 19:59:12.406 info cleaned everything up...
      yeelight-2.0 2018-11-25 19:59:12.405 error at Timer.listOnTimeout (timers.js:92:15)
      yeelight-2.0 2018-11-25 19:59:12.405 error at null._onTimeout (/opt/iobroker/node_modules/iobroker.yeelight-2/main.js:481:74)
      yeelight-2.0 2018-11-25 19:59:12.405 error at YeelightSearch.addInitLights (/opt/iobroker/node_modules/yeelight-wifi/build/index.js:103:22)
      yeelight-2.0 2018-11-25 19:59:12.405 error at new Yeelight (/opt/iobroker/node_modules/yeelight-wifi/build/Yeelight.js:125:18)
      yeelight-2.0 2018-11-25 19:59:12.405 error at Socket.connect (net.js:888:37)
      yeelight-2.0 2018-11-25 19:59:12.405 error at Socket.connect (net.js:925:5)
      yeelight-2.0 2018-11-25 19:59:12.405 error at lookupAndConnect (net.js:946:13)
      yeelight-2.0 2018-11-25 19:59:12.405 error TypeError: port should be a number or string: null
      yeelight-2.0 2018-11-25 19:59:12.403 error uncaught exception: port should be a number or string: null
      yeelight-2.0 2018-11-25 19:59:12.372 debug CREATE DEVICE: yeelight-2.0.color2
      yeelight-2.0 2018-11-25 19:59:10.368 debug DEVICES IN OBJECTS FOUND: 0
      yeelight-2.0 2018-11-25 19:59:10.368 debug DEVICES IN OBJECTS: {}
      yeelight-2.0 2018-11-25 19:59:10.330 debug DEVICES IN CONFIG: [{"name":"color2","ip":"192.168.1.36","port":"","smart_name":"","type":"color","id":"0x000000000000000","supports":["get_prop","set_default","set_power","toggle","set_bright","star
      yeelight-2.0 2018-11-25 19:59:10.320 info starting. Version 0.9.5 in /opt/iobroker/node_modules/iobroker.yeelight-2, node: v4.9.1
      yeelight-2.0 2018-11-25 19:59:10.212 debug statesDB connected
      yeelight-2.0 2018-11-25 19:59:10.155 debug objectDB connected
      yeelight-2.0 2018-11-25 19:58:50.951 error adapter disabled
      yeelight-2.0 2018-11-25 19:58:50.846 debug statesDB connected
      yeelight-2.0 2018-11-25 19:58:50.780 debug objectDB connected
      yeelight-2.0 2018-11-25 19:58:19.770 info terminating
      yeelight-2.0 2018-11-25 19:58:19.765 info cleaned everything up...
      yeelight-2.0 2018-11-25 19:58:19.764 error at Timer.listOnTimeout (timers.js:92:15)
      yeelight-2.0 2018-11-25 19:58:19.764 error at null._onTimeout (/opt/iobroker/node_modules/iobroker.yeelight-2/main.js:481:74)
      yeelight-2.0 2018-11-25 19:58:19.764 error at YeelightSearch.addInitLights (/opt/iobroker/node_modules/yeelight-wifi/build/index.js:103:22)
      yeelight-2.0 2018-11-25 19:58:19.764 error at new Yeelight (/opt/iobroker/node_modules/yeelight-wifi/build/Yeelight.js:125:18)
      yeelight-2.0 2018-11-25 19:58:19.764 error at Socket.connect (net.js:888:37)
      yeelight-2.0 2018-11-25 19:58:19.764 error at Socket.connect (net.js:925:5)
      yeelight-2.0 2018-11-25 19:58:19.764 error at lookupAndConnect (net.js:946:13)
      yeelight-2.0 2018-11-25 19:58:19.764 error TypeError: port should be a number or string: null
      yeelight-2.0 2018-11-25 19:58:19.762 error uncaught exception: port should be a number or string: null
      yeelight-2.0 2018-11-25 19:58:17.743 debug SMARTNAME:
      yeelight-2.0 2018-11-25 19:58:17.742 debug OLD CONF. FROM OBJ: {"name":"color2","ip":"192.168.1.36","port":"","smart_name":"","type":"color","id":"0x000000000000000","supports":["get_prop","set_default","set_power","toggle","set_bright","star
      yeelight-2.0 2018-11-25 19:58:17.737 debug OBJ_ELEMENT: yeelight-2.0.color2
      yeelight-2.0 2018-11-25 19:58:17.737 debug DEVICES IN OBJECTS FOUND: 1
      yeelight-2.0 2018-11-25 19:58:17.737 debug DEVICES IN OBJECTS: {"yeelight-2.0.color2":{"type":"device","common":{"name":"color","icon":"/icons/color.png"},"native":{"sid":"color2","type":"color"},"from":"system.adapter.yeelight-2.0","ts":1543
      yeelight-2.0 2018-11-25 19:58:17.704 debug DEVICES IN CONFIG: [{"name":"color2","ip":"192.168.1.36","port":"","smart_name":"","type":"color","id":"0x000000000000000","supports":["get_prop","set_default","set_power","toggle","set_bright","star
      yeelight-2.0 2018-11-25 19:58:17.694 info starting. Version 0.9.5 in /opt/iobroker/node_modules/iobroker.yeelight-2, node: v4.9.1
      yeelight-2.0 2018-11-25 19:58:17.588 debug statesDB connected
      yeelight-2.0 2018-11-25 19:58:17.536 debug objectDB connected
      yeelight-2.0 2018-11-25 19:58:14.882 info terminating
      yeelight-2.0 2018-11-25 19:58:14.873 info cleaned everything up...
      yeelight-2.0 2018-11-25 19:58:13.186 debug SMARTNAME:
      yeelight-2.0 2018-11-25 19:58:13.184 debug OLD CONF. FROM OBJ: {"name":"color2","ip":"192.168.1.36","port":"","smart_name":"","type":"color","id":"0x000000000000000","supports":["get_prop","set_default","set_power","toggle","set_bright","star
      yeelight-2.0 2018-11-25 19:58:13.180 debug OBJ_ELEMENT: yeelight-2.0.color2
      yeelight-2.0 2018-11-25 19:58:13.180 debug DEVICES IN OBJECTS FOUND: 1
      yeelight-2.0 2018-11-25 19:58:13.179 debug DEVICES IN OBJECTS: {"yeelight-2.0.color2":{"type":"device","common":{"name":"color","icon":"/icons/color.png"},"native":{"sid":"color2","type":"color"},"from":"system.adapter.yeelight-2.0","ts":1543
      yeelight-2.0 2018-11-25 19:58:13.142 debug DEVICES IN CONFIG: [{"name":"color2","ip":"192.168.1.36","port":"","smart_name":"","type":"color","id":"0x000000000000000","supports":["get_prop","set_default","set_power","toggle","set_bright","star
      yeelight-2.0 2018-11-25 19:58:13.132 info starting. Version 0.9.5 in /opt/iobroker/node_modules/iobroker.yeelight-2, node: v4.9.1
      yeelight-2.0 2018-11-25 19:58:13.028 debug statesDB connected
      yeelight-2.0 2018-11-25 19:58:12.970 debug objectDB connected
      yeelight-2.0 2018-11-25 19:57:55.622 info terminating
      yeelight-2.0 2018-11-25 19:57:55.616 info cleaned everything up...
      yeelight-2.0 2018-11-25 19:57:55.615 error at Timer.listOnTimeout (timers.js:92:15)
      yeelight-2.0 2018-11-25 19:57:55.615 error at null._onTimeout (/opt/iobroker/node_modules/iobroker.yeelight-2/main.js:481:74)
      yeelight-2.0 2018-11-25 19:57:55.615 error at YeelightSearch.addInitLights (/opt/iobroker/node_modules/yeelight-wifi/build/index.js:103:22)
      yeelight-2.0 2018-11-25 19:57:55.615 error at new Yeelight (/opt/iobroker/node_modules/yeelight-wifi/build/Yeelight.js:125:18)
      yeelight-2.0 2018-11-25 19:57:55.615 error at Socket.connect (net.js:888:37)
      yeelight-2.0 2018-11-25 19:57:55.615 error at Socket.connect (net.js:925:5)
      yeelight-2.0 2018-11-25 19:57:55.615 error at lookupAndConnect (net.js:946:13)
      yeelight-2.0 2018-11-25 19:57:55.615 error TypeError: port should be a number or string: null
      yeelight-2.0 2018-11-25 19:57:55.613 error uncaught exception: port should be a number or string: null
      yeelight-2.0 2018-11-25 19:57:53.595 debug SMARTNAME:
      yeelight-2.0 2018-11-25 19:57:53.593 debug OLD CONF. FROM OBJ: {"name":"color2","ip":"192.168.1.36","port":"","smart_name":"","type":"color","id":"0x000000000000000","supports":["get_prop","set_default","set_power","toggle","set_bright","star
      yeelight-2.0 2018-11-25 19:57:53.590 debug OBJ_ELEMENT: yeelight-2.0.color2
      yeelight-2.0 2018-11-25 19:57:53.589 debug DEVICES IN OBJECTS FOUND: 1
      yeelight-2.0 2018-11-25 19:57:53.589 debug DEVICES IN OBJECTS: {"yeelight-2.0.color2":{"type":"device","common":{"name":"color","icon":"/icons/color.png"},"native":{"sid":"color2","type":"color"},"from":"system.adapter.yeelight-2.0","ts":1543
      yeelight-2.0 2018-11-25 19:57:53.552 debug DEVICES IN CONFIG: [{"name":"color2","ip":"192.168.1.36","port":"","smart_name":"","type":"color","id":"0x000000000000000","supports":["get_prop","set_default","set_power","toggle","set_bright","star
      yeelight-2.0 2018-11-25 19:57:53.543 info starting. Version 0.9.5 in /opt/iobroker/node_modules/iobroker.yeelight-2, node: v4.9.1
      yeelight-2.0 2018-11-25 19:57:53.435 debug statesDB connected
      yeelight-2.0 2018-11-25 19:57:53.343 debug objectDB connected
      yeelight-2.0 2018-11-25 19:57:45.240 info terminating
      yeelight-2.0 2018-11-25 19:57:45.235 info cleaned everything up...
      yeelight-2.0 2018-11-25 19:57:45.234 error at Timer.listOnTimeout (timers.js:92:15)
      yeelight-2.0 2018-11-25 19:57:45.234 error at null._onTimeout (/opt/iobroker/node_modules/iobroker.yeelight-2/main.js:481:74)
      yeelight-2.0 2018-11-25 19:57:45.234 error at YeelightSearch.addInitLights (/opt/iobroker/node_modules/yeelight-wifi/build/index.js:103:22)
      yeelight-2.0 2018-11-25 19:57:45.234 error at new Yeelight (/opt/iobroker/node_modules/yeelight-wifi/build/Yeelight.js:125:18)
      yeelight-2.0 2018-11-25 19:57:45.234 error at Socket.connect (net.js:888:37)
      yeelight-2.0 2018-11-25 19:57:45.234 error at Socket.connect (net.js:925:5)
      yeelight-2.0 2018-11-25 19:57:45.234 error at lookupAndConnect (net.js:946:13)
      yeelight-2.0 2018-11-25 19:57:45.234 error TypeError: port should be a number or string: null
      yeelight-2.0 2018-11-25 19:57:45.233 error uncaught exception: port should be a number or string: null
      yeelight-2.0 2018-11-25 19:57:43.215 debug SMARTNAME:
      yeelight-2.0 2018-11-25 19:57:43.212 debug OLD CONF. FROM OBJ: {"name":"color2","ip":"192.168.1.36","port":"","smart_name":"","type":"color","id":"0x000000000000000","supports":["get_prop","set_default","set_power","toggle","set_bright","star
      yeelight-2.0 2018-11-25 19:57:43.209 debug OBJ_ELEMENT: yeelight-2.0.color2
      yeelight-2.0 2018-11-25 19:57:43.208 debug DEVICES IN OBJECTS FOUND: 1
      yeelight-2.0 2018-11-25 19:57:43.208 debug DEVICES IN OBJECTS: {"yeelight-2.0.color2":{"type":"device","common":{"name":"color","icon":"/icons/color.png"},"native":{"sid":"color2","type":"color"},"from":"system.adapter.yeelight-2.0","ts":1543
      yeelight-2.0 2018-11-25 19:57:43.176 debug DEVICES IN CONFIG: [{"name":"color2","ip":"192.168.1.36","port":"","smart_name":"","type":"color","id":"0x000000000000000","supports":["get_prop","set_default","set_power","toggle","set_bright","star
      yeelight-2.0 2018-11-25 19:57:43.166 info starting. Version 0.9.5 in /opt/iobroker/node_modules/iobroker.yeelight-2, node: v4.9.1
      yeelight-2.0 2018-11-25 19:57:43.060 debug statesDB connected
      yeelight-2.0 2018-11-25 19:57:43.002 debug objectDB connected
      • H Offline
        hanniko
        #63
        oder kann es an meiner node Version 4.9.1 liegen?
        • H Offline
          hanniko
          #64
          yeelight-2.0 2018-11-25 20:25:28.778 debug YEELIGHT OFFLINE: 0x0000000007c48da4
          yeelight-2.0 2018-11-25 20:24:28.775 debug YEELIGHT OFFLINE: 0x0000000007c48da4
          yeelight-2.0 2018-11-25 20:23:28.772 debug YEELIGHT OFFLINE: 0x0000000007c48da4
          yeelight-2.0 2018-11-25 20:22:28.766 debug YEELIGHT OFFLINE: 0x0000000007c48da4
          yeelight-2.0 2018-11-25 20:20:28.762 debug YEELIGHT FOUND: 192.168.1.36:55443 id: 0x0000000007c48da4 model: color
          yeelight-2.0 2018-11-25 20:20:26.748 debug SMARTNAME:
          yeelight-2.0 2018-11-25 20:20:26.746 debug OLD CONF. FROM OBJ: {"name":"color2","ip":"192.168.1.36","port":"55443","smart_name":"","type":"color","id":"0x000000000000000","supports":["get_prop","set_default","set_power","toggle","set_bright",
          yeelight-2.0 2018-11-25 20:20:26.743 debug OBJ_ELEMENT: yeelight-2.0.color2
          yeelight-2.0 2018-11-25 20:20:26.742 debug DEVICES IN OBJECTS FOUND: 1
          yeelight-2.0 2018-11-25 20:20:26.742 debug DEVICES IN OBJECTS: {"yeelight-2.0.color2":{"type":"device","common":{"name":"color","icon":"/icons/color.png"},"native":{"sid":"color2","type":"color"},"from":"system.adapter.yeelight-2.0","ts":1543
          yeelight-2.0 2018-11-25 20:20:26.705 debug DEVICES IN CONFIG: [{"name":"color2","ip":"192.168.1.36","port":"55443","smart_name":"","type":"color","id":"0x0000000007c48da4"}]
          yeelight-2.0 2018-11-25 20:20:26.696 info starting. Version 0.9.5 in /opt/iobroker/node_modules/iobroker.yeelight-2, node: v4.9.1
          yeelight-2.0 2018-11-25 20:20:26.589 debug statesDB connected
          yeelight-2.0 2018-11-25 20:20:26.503 debug objectDB connected
          yeelight-2.0 2018-11-25 20:20:23.004 info terminating
          yeelight-2.0 2018-11-25 20:20:22.997 info cleaned everything up…
          yeelight-2.0 2018-11-25 20:20:15.940 debug DEVICE FOUND SET NOTIFY STATE: {"name":"color2","ip":"192.168.1.36","port":"55443","smart_name":"","type":"color","id":"0x000000000000000","supports":["get_prop","set_default","set_power","toggle","s
          yeelight-2.0 2018-11-25 20:20:15.938 debug NOTIFY MESSAGE: from: 0x000000000000000, message: {"method":"props","params":{"power":"on"}}
          yeelight-2.0 2018-11-25 20:20:14.439 debug DEVICE FOUND SET NOTIFY STATE: {"name":"color2","ip":"192.168.1.36","port":"55443","smart_name":"","type":"color","id":"0x000000000000000","supports":["get_prop","set_default","set_power","toggle","s
          yeelight-2.0 2018-11-25 20:20:14.437 debug NOTIFY MESSAGE: from: 0x000000000000000, message: {"method":"props","params":{"power":"off"}}
          yeelight-2.0 2018-11-25 20:20:11.107 debug sendTo "discovery" to system.adapter.admin.0 from system.adapter.yeelight-2.0: [{"model":"color","host":"192.168.1.36","port":"55443","id":"0x0000000007c48da4"}]
          yeelight-2.0 2018-11-25 20:20:06.153 debug supports: get_prop,set_default,set_power,toggle,set_bright,start_cf,stop_cf,set_scene,cron_add,cron_get,cron_del,set_ct_abx,set_rgb,set_hsv,set_adjust,adjust_bright,adjust_ct,adjust_color,set_music,se
          yeelight-2.0 2018-11-25 20:20:06.153 debug Found Light{ id: 0x0000000007c48da4, name: , model: color,
          yeelight-2.0 2018-11-25 20:20:06.096 debug here is a Message{"command":"discovery","message":{"turnon":1},"from":"system.adapter.admin.0","callback":{"message":{"turnon":1},"id":38,"ack":false,"time":1543173606091},"_id":18687355}
          yeelight-2.0 2018-11-25 20:20:01.302 debug YEELIGHT FOUND: 192.168.1.36:55443 id: 0x000000000000000 model: color
          yeelight-2.0 2018-11-25 20:20:01.270 debug CREATE DEVICE: yeelight-2.0.color2
          yeelight-2.0 2018-11-25 20:19:59.266 debug DEVICES IN OBJECTS FOUND: 0
          yeelight-2.0 2018-11-25 20:19:59.266 debug DEVICES IN OBJECTS: {}
          yeelight-2.0 2018-11-25 20:19:59.233 debug DEVICES IN CONFIG: [{"name":"color2","ip":"192.168.1.36","port":"55443","smart_name":"","type":"color","id":"0x000000000000000","supports":["get_prop","set_default","set_power","toggle","set_bright",
          yeelight-2.0 2018-11-25 20:19:59.224 info starting. Version 0.9.5 in /opt/iobroker/node_modules/iobroker.yeelight-2, node: v4.9.1
          yeelight-2.0 2018-11-25 20:19:59.108 debug statesDB connected
          yeelight-2.0 2018-11-25 20:19:59.056 debug objectDB connected
          yeelight-2.0 2018-11-25 20:19:35.472 info terminating
          yeelight-2.0 2018-11-25 20:19:35.466 info cleaned everything up…
          yeelight-2.0 2018-11-25 20:18:45.767 debug YEELIGHT OFFLINE: 0x000000000000000
          yeelight-2.0 2018-11-25 20:17:45.762 debug YEELIGHT OFFLINE: 0x000000000000000
          yeelight-2.0 2018-11-25 20:16:45.760 debug YEELIGHT OFFLINE: 0x000000000000000
          yeelight-2.0 2018-11-25 20:15:45.756 debug YEELIGHT OFFLINE: 0x000000000000000
          yeelight-2.0 2018-11-25 20:14:45.754 debug YEELIGHT OFFLINE: 0x000000000000000
          yeelight-2.0 2018-11-25 20:13:45.752 debug YEELIGHT OFFLINE: 0x000000000000000
          yeelight-2.0 2018-11-25 20:12:45.748 debug YEELIGHT OFFLINE: 0x000000000000000
          yeelight-2.0 2018-11-25 20:12:33.367 debug SEND SCENE: id:0x000000000000000, state: notification, value:
          yeelight-2.0 2018-11-25 20:12:16.323 debug SEND SCENE: id:0x000000000000000, state: notification, value: true
          yeelight-2.0 2018-11-25 20:11:55.375 debug SEND SCENE: id:0x000000000000000, state: notification, value: true
          yeelight-2.0 2018-11-25 20:11:46.326 debug SEND SCENE: id:0x000000000000000, state: notification, value: false
          yeelight-2.0 2018-11-25 20:11:45.738 debug YEELIGHT OFFLINE: 0x000000000000000
          yeelight-2.0 2018-11-25 20:10:45.730 debug YEELIGHT OFFLINE: 0x000000000000000
          yeelight-2.0 2018-11-25 20:09:45.726 debug YEELIGHT OFFLINE: 0x000000000000000
          yeelight-2.0 2018-11-25 20:08:45.722 debug YEELIGHT OFFLINE: 0x000000000000000
          yeelight-2.0 2018-11-25 20:07:45.718 debug YEELIGHT OFFLINE: 0x000000000000000
          yeelight-2.0 2018-11-25 20:06:53.745 debug DEVICE FOUND SET NOTIFY STATE: {"name":"color2","ip":"192.168.1.36","port":"55443","smart_name":"","type":"color","id":"0x000000000000000","supports":["get_prop","set_default","set_power","toggle","s
          yeelight-2.0 2018-11-25 20:06:53.744 debug NOTIFY MESSAGE: from: 0x000000000000000, message: {"method":"props","params":{"bright":100}}
          yeelight-2.0 2018-11-25 20:06:52.248 debug DEVICE FOUND SET NOTIFY STATE: {"name":"color2","ip":"192.168.1.36","port":"55443","smart_name":"","type":"color","id":"0x000000000000000","supports":["get_prop","set_default","set_power","toggle","s
          yeelight-2.0 2018-11-25 20:06:52.247 debug NOTIFY MESSAGE: from: 0x000000000000000, message: {"method":"props","params":{"bright":65}}
          yeelight-2.0 2018-11-25 20:06:50.755 debug DEVICE FOUND SET NOTIFY STATE: {"name":"color2","ip":"192.168.1.36","port":"55443","smart_name":"","type":"color","id":"0x000000000000000","supports":["get_prop","set_default","set_power","toggle","s
          yeelight-2.0 2018-11-25 20:06:50.752 debug NOTIFY MESSAGE: from: 0x000000000000000, message: {"method":"props","params":{"bright":6}}
          yeelight-2.0 2018-11-25 20:06:45.716 debug YEELIGHT OFFLINE: 0x000000000000000
          yeelight-2.0 2018-11-25 20:06:40.280 debug DEVICE FOUND SET NOTIFY STATE: {"name":"color2","ip":"192.168.1.36","port":"55443","smart_name":"","type":"color","id":"0x000000000000000","supports":["get_prop","set_default","set_power","toggle","s
          yeelight-2.0 2018-11-25 20:06:40.278 debug NOTIFY MESSAGE: from: 0x000000000000000, message: {"method":"props","params":{"save_state":0}}
          yeelight-2.0 2018-11-25 20:06:25.318 debug DEVICE FOUND SET NOTIFY STATE: {"name":"color2","ip":"192.168.1.36","port":"55443","smart_name":"","type":"color","id":"0x000000000000000","supports":["get_prop","set_default","set_power","toggle","s
          yeelight-2.0 2018-11-25 20:06:25.317 debug NOTIFY MESSAGE: from: 0x000000000000000, message: {"method":"props","params":{"bright":1,"hue":36,"rgb":16750848,"color_mode":1}}
          yeelight-2.0 2018-11-25 20:06:23.824 debug DEVICE FOUND SET NOTIFY STATE: {"name":"color2","ip":"192.168.1.36","port":"55443","smart_name":"","type":"color","id":"0x000000000000000","supports":["get_prop","set_default","set_power","toggle","s
          yeelight-2.0 2018-11-25 20:06:23.823 debug NOTIFY MESSAGE: from: 0x000000000000000, message: {"method":"props","params":{"power":"on"}}
          yeelight-2.0 2018-11-25 20:06:19.335 debug DEVICE FOUND SET NOTIFY STATE: {"name":"color2","ip":"192.168.1.36","port":"55443","smart_name":"","type":"color","id":"0x000000000000000","supports":["get_prop","set_default","set_power","toggle","s
          yeelight-2.0 2018-11-25 20:06:19.333 debug NOTIFY MESSAGE: from: 0x000000000000000, message: {"method":"props","params":{"power":"off"}}
          yeelight-2.0 2018-11-25 20:05:45.713 debug YEELIGHT OFFLINE: 0x000000000000000
          yeelight-2.0 2018-11-25 20:04:45.706 debug YEELIGHT OFFLINE: 0x000000000000000
          yeelight-2.0 2018-11-25 20:03:45.696 debug YEELIGHT OFFLINE: 0x000000000000000
          yeelight-2.0
            MeistertrM Offline
            Meistertr
            #65
            es sieht so aus als ob bei dir garnicht gesendet wird. Die Steuer objecte werden erst erstellt, wenn eine rückmeldung von der Lampe gegeben wird, und dass passiert nicht, kannst du mal den adapter komplett löschen und noch einmal installieren, am besten auch unter adapter löschen. ich glaube, dass eine benötigtes repo nicht ordnungsgemäß geladen wurde.
            • H Offline
              hanniko
              #66
              Das ist das Log der Installation. Da gibt es gleich ein Warning zu beginn.
              $ ./iobroker add yeelight-2 –host hjkDiskStation
              NPM version: 4.6.1
              npm install iobroker.yeelight-2 --production --save --prefix "/opt/iobroker" (System call)
              npm
              WARN deprecated circular-json@0.5.9: CircularJSON is in maintenance only, flatted is its successor.
              host.hjkDiskStation install adapter yeelight-2
              got /opt/iobroker/node_modules/iobroker.yeelight-2/admin
              upload [19] yeelight-2.admin /opt/iobroker/node_modules/iobroker.yeelight-2/admin/yeelight.png yeelight.png image/png
              upload [18] yeelight-2.admin /opt/iobroker/node_modules/iobroker.yeelight-2/admin/words.js words.js application/javascript
              upload [17] yeelight-2.admin /opt/iobroker/node_modules/iobroker.yeelight-2/admin/lan.jpg lan.jpg image/jpeg
              upload [16] yeelight-2.admin /opt/iobroker/node_modules/iobroker.yeelight-2/admin/index_m.html index_m.html text/html
              upload [15] yeelight-2.admin /opt/iobroker/node_modules/iobroker.yeelight-2/admin/index.html index.html text/html
              upload [14] yeelight-2.admin /opt/iobroker/node_modules/iobroker.yeelight-2/admin/icons/stripe.png icons/stripe.png image/png
              upload [13] yeelight-2.admin /opt/iobroker/node_modules/iobroker.yeelight-2/admin/icons/mono.png icons/mono.png image/png
              upload [12] yeelight-2.admin /opt/iobroker/node_modules/iobroker.yeelight-2/admin/icons/desklamp.png icons/desklamp.png image/png
              upload [11] yeelight-2.admin /opt/iobroker/node_modules/iobroker.yeelight-2/admin/icons/color.png icons/color.png image/png
              upload [10] yeelight-2.admin /opt/iobroker/node_modules/iobroker.yeelight-2/admin/icons/ceiling4.png icons/ceiling4.png image/png
              upload [9] yeelight-2.admin /opt/iobroker/node_modules/iobroker.yeelight-2/admin/icons/ceiling3.png icons/ceiling3.png image/png
              upload [8] yeelight-2.admin /opt/iobroker/node_modules/iobroker.yeelight-2/admin/icons/ceiling1.png icons/ceiling1.png image/png
              upload [7] yeelight-2.admin /opt/iobroker/node_modules/iobroker.yeelight-2/admin/icons/bslamp1.png icons/bslamp1.png image/png
              upload [6] yeelight-2.admin /opt/iobroker/node_modules/iobroker.yeelight-2/admin/icons/7.png icons/7.png image/png
              upload [5] yeelight-2.admin /opt/iobroker/node_modules/iobroker.yeelight-2/admin/icons/6.png icons/6.png image/png
              upload [4] yeelight-2.admin /opt/iobroker/node_modules/iobroker.yeelight-2/admin/icons/5.png icons/5.png image/png
              upload [3] yeelight-2.admin /opt/iobroker/node_modules/iobroker.yeelight-2/admin/icons/4.png icons/4.png image/png
              upload [2] yeelight-2.admin /opt/iobroker/node_modules/iobroker.yeelight-2/admin/icons/3.png icons/3.png image/png
              upload [1] yeelight-2.admin /opt/iobroker/node_modules/iobroker.yeelight-2/admin/icons/2.png icons/2.png image/png
              upload [0] yeelight-2.admin /opt/iobroker/node_modules/iobroker.yeelight-2/admin/icons/1.png icons/1.png image/png
              host.hjkDiskStation object system.adapter.yeelight-2 created
              host.hjkDiskStation create instance yeelight-2
              host.hjkDiskStation object system.adapter.yeelight-2.0.outputCount created
              host.hjkDiskStation object system.adapter.yeelight-2.0.inputCount created
              host.hjkDiskStation object system.adapter.yeelight-2.0.uptime created
              host.hjkDiskStation object system.adapter.yeelight-2.0.memRss created
              host.hjkDiskStation object system.adapter.yeelight-2.0.memHeapTotal created
              host.hjkDiskStation object system.adapter.yeelight-2.0.memHeapUsed created
              host.hjkDiskStation object system.adapter.yeelight-2.0.connected created
              host.hjkDiskStation object system.adapter.yeelight-2.0.alive created
              host.hjkDiskStation object system.adapter.yeelight-2.0 created
              process exited with code 0
              Dann das Log mit dem Anlegen der Lampe, wobei wieder keine Control Items angelegt werden.
              yeelight-2.0 2018-11-26 09:24:26.361 debug DEVICE FOUND SET NOTIFY STATE: {"name":"color-0x0000000007c3a46a","ip":"192.168.1.37","port":"55443","smart_name":"","type":"color","id":"0x0000000007c3a46a"}
              yeelight-2.0 2018-11-26 09:24:26.360 debug NOTIFY MESSAGE: from: 0x0000000007c3a46a, message: {"method":"props","params":{"bright":1,"flowing":1}}
              yeelight-2.0 2018-11-26 09:24:24.863 debug DEVICE FOUND SET NOTIFY STATE: {"name":"color-0x0000000007c3a46a","ip":"192.168.1.37","port":"55443","smart_name":"","type":"color","id":"0x0000000007c3a46a"}
              yeelight-2.0 2018-11-26 09:24:24.862 debug NOTIFY MESSAGE: from: 0x0000000007c3a46a, message: {"method":"props","params":{"color_mode":1}}
              yeelight-2.0 2018-11-26 09:24:07.536 debug DEVICE FOUND SET NOTIFY STATE: {"name":"color-0x0000000007c3a46a","ip":"192.168.1.37","port":"55443","smart_name":"","type":"color","id":"0x0000000007c3a46a"}
              yeelight-2.0 2018-11-26 09:24:07.535 debug NOTIFY MESSAGE: from: 0x0000000007c3a46a, message: {"method":"props","params":{"bright":50,"flowing":1,"color_mode":2}}
              yeelight-2.0 2018-11-26 09:24:06.039 debug DEVICE FOUND SET NOTIFY STATE: {"name":"color-0x0000000007c3a46a","ip":"192.168.1.37","port":"55443","smart_name":"","type":"color","id":"0x0000000007c3a46a"}
              yeelight-2.0 2018-11-26 09:24:06.036 debug NOTIFY MESSAGE: from: 0x0000000007c3a46a, message: {"method":"props","params":{"flowing":1}}
              yeelight-2.0 2018-11-26 09:24:05.952 debug YEELIGHT FOUND: 192.168.1.37:55443 id: 0x0000000007c3a46a model: color
              yeelight-2.0 2018-11-26 09:24:03.940 debug SMARTNAME:
              yeelight-2.0 2018-11-26 09:24:03.938 debug OLD CONF. FROM OBJ: {"name":"color-0x0000000007c3a46a","ip":"192.168.1.37","port":"55443","smart_name":"","type":"color","id":"0x0000000007c3a46a"}
              yeelight-2.0 2018-11-26 09:24:03.931 debug OBJ_ELEMENT: yeelight-2.0.color-0x0000000007c3a46a
              yeelight-2.0 2018-11-26 09:24:03.931 debug DEVICES IN OBJECTS FOUND: 1
              yeelight-2.0 2018-11-26 09:24:03.930 debug DEVICES IN OBJECTS: {"yeelight-2.0.color-0x0000000007c3a46a":{"type":"device","common":{"name":"color","icon":"/icons/color.png"},"native":{"sid":"color-0x0000000007c3a46a","type":"color"},"from":"sy
              yeelight-2.0 2018-11-26 09:24:03.896 debug DEVICES IN CONFIG: [{"name":"color-0x0000000007c3a46a","ip":"192.168.1.37","port":"55443","smart_name":"","type":"color","id":"0x0000000007c3a46a"}]
              yeelight-2.0 2018-11-26 09:24:03.887 info starting. Version 0.9.5 in /opt/iobroker/node_modules/iobroker.yeelight-2, node: v4.9.1
              yeelight-2.0 2018-11-26 09:24:03.779 debug statesDB connected
              yeelight-2.0 2018-11-26 09:24:03.719 debug objectDB connected
              yeelight-2.0 2018-11-26 09:24:00.228 info terminating
              yeelight-2.0 2018-11-26 09:24:00.218 info cleaned everything up…
              yeelight-2.0 2018-11-26 09:23:50.515 debug YEELIGHT FOUND: 192.168.1.37:55443 id: 0x0000000007c3a46a model: color
              yeelight-2.0 2018-11-26 09:23:48.500 debug SMARTNAME:
              yeelight-2.0 2018-11-26 09:23:48.498 debug OLD CONF. FROM OBJ: {"name":"color-0x0000000007c3a46a","ip":"192.168.1.37","port":"55443","smart_name":"","type":"color","id":"0x0000000007c3a46a"}
              yeelight-2.0 2018-11-26 09:23:48.494 debug OBJ_ELEMENT: yeelight-2.0.color-0x0000000007c3a46a
              yeelight-2.0 2018-11-26 09:23:48.494 debug DEVICES IN OBJECTS FOUND: 1
              yeelight-2.0 2018-11-26 09:23:48.493 debug DEVICES IN OBJECTS: {"yeelight-2.0.color-0x0000000007c3a46a":{"type":"device","common":{"name":"color","icon":"/icons/color.png"},"native":{"sid":"color-0x0000000007c3a46a","type":"color"},"from":"sy
              yeelight-2.0 2018-11-26 09:23:48.454 debug DEVICES IN CONFIG: [{"name":"color-0x0000000007c3a46a","ip":"192.168.1.37","port":"55443","smart_name":"","type":"color","id":"0x0000000007c3a46a"}]
              yeelight-2.0 2018-11-26 09:23:48.445 info starting. Version 0.9.5 in /opt/iobroker/node_modules/iobroker.yeelight-2, node: v4.9.1
              yeelight-2.0 2018-11-26 09:23:48.340 debug statesDB connected
              yeelight-2.0 2018-11-26 09:23:48.259 debug objectDB connected
              yeelight-2.0 2018-11-26 09:23:44.763 info terminating
              yeelight-2.0 2018-11-26 09:23:44.755 info cleaned everything up…
              yeelight-2.0 2018-11-26 09:23:26.562 info starting. Version 0.9.5 in /opt/iobroker/node_modules/iobroker.yeelight-2, node: v4.9.1
              yeelight-2.0 2018-11-26 09:23:22.883 info terminating
              yeelight-2.0 2018-11-26 09:23:22.876 info cleaned everything up...
              yeelight-2.0 2018-11-26 09:18:40.564 info starting. Version 0.9.5 in /opt/iobroker/node_modules/iobroker.yeelight-2, node: v4.9.1
              yeelight-2.0 2018-11-26 09:10:22.584 info terminating
              yeelight-2.0 2018-11-26 09:10:22.579 info cleaned everything up...
                MeistertrM Offline
                Meistertr
                #67
                @hanniko:
                NPM version: 4.6.1
                npm
                yeelight-2.0 2018-11-26 09:10:22.579 info cleaned everything up... `
                warnings beim installieren sind nicht weiter schlimm, versuch mal bitte diese Version, installation übers terminal:
                 npm install https://github.com/MeisterTR/ioBroker.yeelight-2/tarball/add-yeelight-wifi --production --save
                • H Offline
                  hanniko
                  #68
                  klappt; control ist vorhanden ;-) Morgen teste ich das mal weiter aus. Danke schon mal.
                  • L Offline
                    ltsalvatore
                    #69
                    @hanniko:
                    klappt; control ist vorhanden ;-) Morgen teste ich das mal weiter aus. Danke schon mal. `
                    bin mal gespannt auf deine Rückmeldung.
                    ich muss nämlich sagen, auch wenn aktuell alles zur abwechslung problemlos und sehr reaktionsschnell funktioniert, es alles in allem nicht so ganz stabil läuft, wie ich es mir vorgestellt/erhofft habe.
                    was ich aber bemerkt habe und für den ein oder anderen evtl. interessant wäre zu wissen:
                    wenn ich die yeelight bulb über iobroker steuere (ob über vis oder aqara switch) und es einfach nicht (mehr) funktionieren will, dann funktioniert das steuern der bulb immer noch tadellos mit dem yeelight alexa skill.
                    als leihe würde ich sagen, das problem liegt entweder bei dem iobroker oder adapter.
                    zusätzlich war mir die tage aufgefallen, dass die yeelight bulb scheinbar enormst probleme hat, wenn man auf der fritzbox den 2,4GHz wifi kanal von auto auf manuell stellt.
                    das anlernen der bulb über die yeelight app funktioniert dann einfach überhaupt nicht mehr. setze ich den wifi kanal wieder zurück auf auto, funktioniert das anlernen tadellos.
                      MeistertrM Offline
                      Meistertr
                      #70
                      @ltsalvatore:
                      @hanniko:
                      das anlernen der bulb über die yeelight app funktioniert dann einfach überhaupt nicht mehr. setze ich den wifi kanal wieder zurück auf auto, funktioniert das anlernen tadellos. ` Die Kommunikation zwischen iobroker und den bulbs ist lokal über udp. Über den skill läuft und der app läuft es über den yeelight Server und hat mit deinem lokalen Netz nichts zu tun. Somit sind das zwei verschiedenen Sachen. Ich habe mittlerweile fast alle yeelight Modelle und alle laufen ohne probleme und Ausfälle. Der Adapter läuft auf drei Servern zum testen mit unterschiedlichen node Versionen und keiner hat bislang Probleme gemacht. Dann würde ich die Probleme eher in deinem Netzwerk oder bei deiner Installation suchen.
                      Desweiteren ist die Aussage dass es nicht läuft alles andere als konstruktiv. Hier wäre ein Debug log Auszug wenn es nicht läuft mehr als hilfreich. Dann kann ich dir auch sagen woran es liegt.
                      • ? Offline
                        #71
                        Als "Experdde" würd ich eher sagen, du hast n Wlan-Problem. Autokanal kann funktionieren, muss aber nicht, kommt drauf an, wo deine Empfänger stehen. Wenn am Standort der Fritzbox die Kanäle 1, 9, 13 belegt sind, wird Sie als Autokanal den 5er nehmen, wenn aber genau dann am Standort deines Empfängers (in dem Fall die Yeelight) dort ein Nachbar auf Kanal 5 sendet und dir den belegt, wirst du mit der Einstellung Probleme haben. Abgesehen davon, die Fritzbox eigenständig den Kanal von jetzt auf später wechseln kann, und du dich dann wunderst, warum es eben ging, und jetzt nicht mehr.
                        Wenn man nur 2-3 Endgeräte hat, ist das alles halb so wild, aber bei einem Smarthomesystem katastrophal. Ich hab hier 23 Netze von den umliegenden Nachbarn im 2,4GHz und 5 im 5GHz Bereich, und versorge ein zweifamilien Haus mit 4 Etagen mit insgesamt 170 Netzwerkgeräten, dazu noch 75 Zigbee und 10 Dect, die auch stören, der ganze Mist liegt ja im 2,4GHz Bereich… Bin froh wenn irgendwas auf 5GHz schaltet und mir auf dem 2,4er aus den Füssen ist.
                        Habe wochenlang nur durch ausprobieren herausgefunden, welcher Kanal für alle(und ich möchte mich nicht selbst im eigenen Haus mit verschiedenen Kanälen blockieren) am besten ist, und das ist genau der, den die Fritzbox nie! benutzt hat.. ;-)
                        Also ich hab nur ein Yeelight-Stripe und das läuft mit dem Adapter zuverlässig. Skill und App verwende ich schon lange nicht mehr. Ganz am Anfang hatte ich hier im Forum ein Javascript, das mir das schaltete, mit dem alten Yeelight-Adapter war ich auch zufrieden. Finde es klasse, dass bei dem neuen die Scenen mit drin sind.
                        ****Viel Erfolg bei der Fehlersuche, wenn sowas wieder auftritt, hilft nur eins, stell den Adapter mal auf Debug und poste hier dann das Logfile dazu.
                        ( Instanzen - Expertenmodus - Logstufe auf Debug, der Adapter startet dann neu, das Logfile findest du in /opt/iobroker/log und mit dem Befehl "less iobroker.2018-12-02.log | grep yeelight" erhälst du die Meldungen nur vom Yeelight Adapter, das bitte per copy und paste hier dann posten. )****
                        • L Offline
                          ltsalvatore
                          #72
                          danke @Meistertr und @ilovegym für eure konstruktive kritik.
                          werde mir das ganze nun mal etwas genauer anschauen, jetzt wo ich auch ein wenig mehr zeit dafür aufwenden kann. ;)
                          denke auch, dass es irgendwie machbar sein sollte, das ganze so zu optimieren, dass es zuverlässig läuft.
                          muss ich hierzu den yeelight und javascript adapter auf debug stellen?
                            southparkler
                            #73
                            Ich kann ähnliche Probleme allerdings bestätigen.
                            Meine Mono in der Küche wird seit kurzem über den ioBroker Adapter gesteuert und macht manchmal nicht mit. Der Yeelight Strip läuft hier deutlich zuverlässiger.
                            Hab mich bisher noch nicht gemeldet weil das Problem nicht so tragisch ist, da es nicht immer vorkommt und ich momentan dafür keine Zeit hab, noch hab ich wichtigere Sachen die ich zum Laufen bekommen möchte. ;)
                            iBroker läuft auf Raspi 3B über Gbit Lan
                            Geräte:
                            Licht: Hue Lampen mit Bridge, Osram Smart Plug, Tradfri Lampen über Hue, Yeelight Lampen
                            Sensoren: Xiaomi Aqara Sensoren (Zigbee Stick)
                            Heizung: Fritz!D…
                            • ? Offline
                              #74
                              yeelight sollte erstmal reichen, mal schauen, was da so steht.
                              • ? Offline
                                #75
                                @southparkler:
                                Hab mich bisher noch nicht gemeldet weil das Problem nicht so tragisch ist, da es nicht immer vorkommt und ich momentan dafür keine Zeit hab, noch hab ich wichtigere Sachen die ich zum Laufen bekommen möchte. ;) `
                                Ich hatte vor 6 Monaten nach einem Xiaomi -Firmwareupdate der Bulbs (hatte auch Mono und Color) und dem Stripe das Problem, dass sie sich manchmal aufhingen, erst ein Powerreset brachte sie wieder zur Funktion. Hatte damals nix als das xiaomi-firmware Update gemacht, downgrade ging nicht, hab die 3 Bulbs dann vertickert und mir sonoff B1 geholt ( die sind aber leider lange nicht so hell wie die Xiaomi) - aber die funktionieren. Habe seitdem nur noch das Stripe, das wird durch n Sonoff Basic einmal täglich for 1 minute vom Strom genommen.
                                Ich denke daher nicht, dass dieser Fehler etwas mit dem Adapter zu tun hat, eher was mit der Firmware … und da kann man bei Xiaomi leider nix machen...
                                • L Offline
                                  ltsalvatore
                                  #76
                                  @ilovegym:
                                  @southparkler:
                                  Ich denke daher nicht, dass dieser Fehler etwas mit dem Adapter zu tun hat, eher was mit der Firmware … und da kann man bei Xiaomi leider nix machen... `
                                  hm.. mit den sonoff B1 hatte ich auch mal geliebäugelt.. kommt da auch die tasmota firmware drauf? ich benötige die ganzen apps nämlich auch nicht zwangsläufig und versuche ja eh wenn dann alles über VIS und alexa zu steuern.
                                  gerne würde ich ja eigentlich eher zigbee lampen nutzen und am besten noch mit der möglichkeit diese parallel noch über den normalen wandschalter zu betätigen.
                                  gibt es da eigentlich mittlerweile alternativen / workarrounds, welche ohne neutralleiter betrieben werden können?
                                  • L Offline
                                    ltsalvatore
                                    #77
                                    @Meistertr:
                                    Gesendet von meinem Handy `
                                    was ich nicht so ganz verstehe..
                                    du sagst, dass es zwei verschiedene sachen sind… das leuchtet ein...aber..
                                    auch wenn die schaltung der lampe, sei es über alexa oder der yeelight app, angetriggert wurde und die kommunikation über das internet geht; das schaltsignal muss ja irgenwann an die lampe weitergereicht werden! und spätestens dann ist doch wieder das intern netz mit der zugewiesenen internen ip adresse der lampe das ziel.
                                    und da verstehe ich einfach nicht, wenn in dem moment das steuern über alexa/yeelight app funktioniert, wieso das nicht auch über egal welches iobroker objekt (sei es ein switch über zigbee oder VIS) geht. :?:
                                    des weiteren ist mir noch folgendes bei der fehlersuche aufgefallen:
                                    die lampe konnte mal wieder nicht gefunden werden.
                                    in der app stand die lampe auf offline und in dem router unter inaktive verbindungen.
                                    ein dauer ping auf die von mir über den router statisch vergebenen IP adresse, konnte diese nicht erreichen.
                                    also war ich mal wieder kurz davor, das ding zu resetten (5x an/aus) und neu einzurichten.
                                    dann fiel mir ein, was ich bis dato aus faulheit nicht gemacht hatte, diese einfach mal aus der glühbirnenfassung zu entfernen und wieder einzustecken.
                                    bedeutet, komplett vom strom zu trennen wie man das aus dem pc alltag von anderen geräten so kennt. :-D
                                    nachdem ich die lampe wieder in die fassung eingesteckt hatte, stand diese in der app wieder auf sichtbar und auf der fritzbox unter aktive verbindungen.
                                    ein ping bestätigt das ganze mit einer positiven rückmeldung.
                                    und auch der aqara switch hat keine probleme die lampe anzusteuern.
                                    bedeutet nun, die scheiß lampe stürzt ab und benötigt einen "neustart", den die nur bekommt indem ich die lampe vom strom trenne?
                                    wtf?
                                    interessant wäre jetzt natürlich zu wissen: was genau führt dazu, dass die lampe abstürzt?
                                    2018-12-02 17:48:37.002  - debug: yeelight-2.0 ERROR YEELIGHT CONNECTION: null: SyntaxError: Unexpected token { in JSON at position 45: {"method":"props","params":{"power":"off"}}
                                    2018-12-02 17:49:08.991  - debug: yeelight-2.0 RESPONSE MESSAGE: from: 0x000000000000000, id: 217, result:[on,90,16711680,2,4000]}
                                    2018-12-02 17:49:08.993  - debug: yeelight-2.0 DEVICE FOUND IN CONFIG: {"name":"SZ_Lampe","ip":"192.168.111.210","port":"55443","smart_name":"","type":"color","id":"0x000000000000000","supports":["get_prop","set_default","set_power","toggle","set_bright","start_cf","stop_cf","set_scene","cron_add","cron_get","cron_del","set_ct_abx","set_rgb","set_hsv","set_adjust","adjust_bright","adjust_ct","adjust_color","set_music","set_name"]}
                                    2018-12-02 17:49:16.391  - debug: yeelight-2.0 SEND STATE: id:0x000000000000000, state: power, value: false
                                    2018-12-02 17:49:26.884  - debug: yeelight-2.0 RESPONSE MESSAGE: from: 0x000000000000000, id: 218, result:[ok]}
                                    2018-12-02 17:49:26.909  - debug: yeelight-2.0 NOTIFY MESSAGE: from: 0x000000000000000, message: {"method":"props","params":{"power":"off"}}
                                    2018-12-02 17:49:26.911  - debug: yeelight-2.0 DEVICE FOUND SET NOTIFY STATE: {"name":"SZ_Lampe","ip":"192.168.111.210","port":"55443","smart_name":"","type":"color","id":"0x000000000000000","supports":["get_prop","set_default","set_power","toggle","set_bright","start_cf","stop_cf","set_scene","cron_add","cron_get","cron_del","set_ct_abx","set_rgb","set_hsv","set_adjust","adjust_bright","adjust_ct","adjust_color","set_music","set_name"]}
                                    2018-12-02 17:49:29.601  - debug: yeelight-2.0 SEND STATE: id:0x000000000000000, state: power, value: true
                                    2018-12-02 17:49:33.872  - debug: yeelight-2.0 RESPONSE MESSAGE: from: 0x000000000000000, id: 219, result:[ok]}
                                    2018-12-02 17:49:38.383  - debug: yeelight-2.0 NOTIFY MESSAGE: from: 0x000000000000000, message: {"method":"props","params":{"power":"on"}}
                                    2018-12-02 17:49:38.385  - debug: yeelight-2.0 DEVICE FOUND SET NOTIFY STATE: {"name":"SZ_Lampe","ip":"192.168.111.210","port":"55443","smart_name":"","type":"color","id":"0x000000000000000","supports":["get_prop","set_default","set_power","toggle","set_bright","start_cf","stop_cf","set_scene","cron_add","cron_get","cron_del","set_ct_abx","set_rgb","set_hsv","set_adjust","adjust_bright","adjust_ct","adjust_color","set_music","set_name"]}
                                    2018-12-02 17:49:54.823  - debug: yeelight-2.0 ERROR YEELIGHT CONNECTION: 0x000000000000000: Connection 192.168.111.210:55443: Error: read ECONNRESET
                                    2018-12-02 17:49:59.045  - debug: yeelight-2.0 NOTIFY MESSAGE: from: 0x000000000000000, message: {"method":"props","params":{"ct":2870}}
                                    2018-12-02 17:49:59.047  - debug: yeelight-2.0 DEVICE FOUND SET NOTIFY STATE: {"name":"SZ_Lampe","ip":"192.168.111.210","port":"55443","smart_name":"","type":"color","id":"0x000000000000000","supports":["get_prop","set_default","set_power","toggle","set_bright","start_cf","stop_cf","set_scene","cron_add","cron_get","cron_del","set_ct_abx","set_rgb","set_hsv","set_adjust","adjust_bright","adjust_ct","adjust_color","set_music","set_name"]}
                                    2018-12-02 17:50:02.186  - debug: yeelight-2.0 NOTIFY MESSAGE: from: 0x000000000000000, message: {"method":"props","params":{"bright":85}}
                                    2018-12-02 17:50:02.188  - debug: yeelight-2.0 DEVICE FOUND SET NOTIFY STATE: {"name":"SZ_Lampe","ip":"192.168.111.210","port":"55443","smart_name":"","type":"color","id":"0x000000000000000","supports":["get_prop","set_default","set_power","toggle","set_bright","start_cf","stop_cf","set_scene","cron_add","cron_get","cron_del","set_ct_abx","set_rgb","set_hsv","set_adjust","adjust_bright","adjust_ct","adjust_color","set_music","set_name"]}
                                    2018-12-02 17:50:02.199  - debug: yeelight-2.0 NOTIFY MESSAGE: from: 0x000000000000000, message: {"method":"props","params":{"bright":62,"ct":2799}}
                                    2018-12-02 17:50:02.200  - debug: yeelight-2.0 DEVICE FOUND SET NOTIFY STATE: {"name":"SZ_Lampe","ip":"192.168.111.210","port":"55443","smart_name":"","type":"color","id":"0x000000000000000","supports":["get_prop","set_default","set_power","toggle","set_bright","start_cf","stop_cf","set_scene","cron_add","cron_get","cron_del","set_ct_abx","set_rgb","set_hsv","set_adjust","adjust_bright","adjust_ct","adjust_color","set_music","set_name"]}
                                    2018-12-02 17:50:13.696  - debug: yeelight-2.0 NOTIFY MESSAGE: from: 0x000000000000000, message: {"method":"props","params":{"bright":60,"ct":2320}}
                                    2018-12-02 17:50:13.698  - debug: yeelight-2.0 DEVICE FOUND SET NOTIFY STATE: {"name":"SZ_Lampe","ip":"192.168.111.210","port":"55443","smart_name":"","type":"color","id":"0x000000000000000","supports":["get_prop","set_default","set_power","toggle","set_bright","start_cf","stop_cf","set_scene","cron_add","cron_get","cron_del","set_ct_abx","set_rgb","set_hsv","set_adjust","adjust_bright","adjust_ct","adjust_color","set_music","set_name"]}
                                    2018-12-02 17:50:14.722  - debug: yeelight-2.0 SEND STATE: id:0x000000000000000, state: power, value: false
                                    2018-12-02 17:50:18.188  - debug: yeelight-2.0 ERROR YEELIGHT CONNECTION: null: SyntaxError: Unexpected token { in JSON at position 53: {"method":"props","params":{"bright":62,"ct":2799}}
                                    2018-12-02 17:50:19.673  - debug: yeelight-2.0 ERROR YEELIGHT CONNECTION: null: SyntaxError: Unexpected token { in JSON at position 29: {"id":220, "result":["ok"]}
                                    2018-12-02 17:50:30.628  - debug: yeelight-2.0 SEND STATE: id:0x000000000000000, state: power, value: true
                                    2018-12-02 17:50:30.649  - debug: yeelight-2.0 RESPONSE MESSAGE: from: 0x000000000000000, id: 221, result:[ok]}
                                    2018-12-02 17:50:31.995  - debug: yeelight-2.0 NOTIFY MESSAGE: from: 0x000000000000000, message: {"method":"props","params":{"power":"on"}}
                                    2018-12-02 17:50:31.996  - debug: yeelight-2.0 DEVICE FOUND SET NOTIFY STATE: {"name":"SZ_Lampe","ip":"192.168.111.210","port":"55443","smart_name":"","type":"color","id":"0x000000000000000","supports":["get_prop","set_default","set_power","toggle","set_bright","start_cf","stop_cf","set_scene","cron_add","cron_get","cron_del","set_ct_abx","set_rgb","set_hsv","set_adjust","adjust_bright","adjust_ct","adjust_color","set_music","set_name"]}
                                    2018-12-02 17:50:40.646  - debug: yeelight-2.0 NOTIFY MESSAGE: from: 0x000000000000000, message: {"method":"props","params":{"bright":100}}
                                    2018-12-02 17:50:40.648  - debug: yeelight-2.0 DEVICE FOUND SET NOTIFY STATE: {"name":"SZ_Lampe","ip":"192.168.111.210","port":"55443","smart_name":"","type":"color","id":"0x000000000000000","supports":["get_prop","set_default","set_power","toggle","set_bright","start_cf","stop_cf","set_scene","cron_add","cron_get","cron_del","set_ct_abx","set_rgb","set_hsv","set_adjust","adjust_bright","adjust_ct","adjust_color","set_music","set_name"]}
                                    2018-12-02 17:50:40.993  - debug: yeelight-2.0 NOTIFY MESSAGE: from: 0x000000000000000, message: {"method":"props","params":{"power":"on"}}
                                    2018-12-02 17:50:40.996  - debug: yeelight-2.0 DEVICE FOUND SET NOTIFY STATE: {"name":"SZ_Lampe","ip":"192.168.111.210","port":"55443","smart_name":"","type":"color","id":"0x000000000000000","supports":["get_prop","set_default","set_power","toggle","set_bright","start_cf","stop_cf","set_scene","cron_add","cron_get","cron_del","set_ct_abx","set_rgb","set_hsv","set_adjust","adjust_bright","adjust_ct","adjust_color","set_music","set_name"]}
                                    2018-12-02 17:50:41.971  - debug: yeelight-2.0 SEND STATE: id:0x000000000000000, state: power, value: false
                                    2018-12-02 17:50:41.994  - debug: yeelight-2.0 RESPONSE MESSAGE: from: 0x000000000000000, id: 222, result:[ok]}
                                    2018-12-02 17:50:42.438  - debug: yeelight-2.0 NOTIFY MESSAGE: from: 0x000000000000000, message: {"method":"props","params":{"bright":53,"power":"off"}}
                                    2018-12-02 17:50:42.440  - debug: yeelight-2.0 DEVICE FOUND SET NOTIFY STATE: {"name":"SZ_Lampe","ip":"192.168.111.210","port":"55443","smart_name":"","type":"color","id":"0x000000000000000","supports":["get_prop","set_default","set_power","toggle","set_bright","start_cf","stop_cf","set_scene","cron_add","cron_get","cron_del","set_ct_abx","set_rgb","set_hsv","set_adjust","adjust_bright","adjust_ct","adjust_color","set_music","set_name"]}
                                    2018-12-02 17:50:46.151  - debug: yeelight-2.0 SEND STATE: id:0x000000000000000, state: power, value: true
                                    2018-12-02 17:50:46.195  - debug: yeelight-2.0 RESPONSE MESSAGE: from: 0x000000000000000, id: 223, result:[ok]}
                                    2018-12-02 17:50:51.131  - debug: yeelight-2.0 NOTIFY MESSAGE: from: 0x000000000000000, message: {"method":"props","params":{"power":"on"}}
                                    2018-12-02 17:50:51.133  - debug: yeelight-2.0 DEVICE FOUND SET NOTIFY STATE: {"name":"SZ_Lampe","ip":"192.168.111.210","port":"55443","smart_name":"","type":"color","id":"0x000000000000000","supports":["get_prop","set_default","set_power","toggle","set_bright","start_cf","stop_cf","set_scene","cron_add","cron_get","cron_del","set_ct_abx","set_rgb","set_hsv","set_adjust","adjust_bright","adjust_ct","adjust_color","set_music","set_name"]}
                                    2018-12-02 17:50:52.647  - debug: yeelight-2.0 NOTIFY MESSAGE: from: 0x000000000000000, message: {"method":"props","params":{"bright":100,"ct":2589}}
                                    2018-12-02 17:50:52.650  - debug: yeelight-2.0 DEVICE FOUND SET NOTIFY STATE: {"name":"SZ_Lampe","ip":"192.168.111.210","port":"55443","smart_name":"","type":"color","id":"0x000000000000000","supports":["get_prop","set_default","set_power","toggle","set_bright","start_cf","stop_cf","set_scene","cron_add","cron_get","cron_del","set_ct_abx","set_rgb","set_hsv","set_adjust","adjust_bright","adjust_ct","adjust_color","set_music","set_name"]}
                                    2018-12-02 17:50:52.716  - debug: yeelight-2.0 NOTIFY MESSAGE: from: 0x000000000000000, message: {"method":"props","params":{"ct":6500}}
                                    2018-12-02 17:50:52.719  - debug: yeelight-2.0 DEVICE FOUND SET NOTIFY STATE: {"name":"SZ_Lampe","ip":"192.168.111.210","port":"55443","smart_name":"","type":"color","id":"0x000000000000000","supports":["get_prop","set_default","set_power","toggle","set_bright","start_cf","stop_cf","set_scene","cron_add","cron_get","cron_del","set_ct_abx","set_rgb","set_hsv","set_adjust","adjust_bright","adjust_ct","adjust_color","set_music","set_name"]}
                                    2018-12-02 17:50:52.945  - debug: yeelight-2.0 NOTIFY MESSAGE: from: 0x000000000000000, message: {"method":"props","params":{"ct":2589}}
                                    2018-12-02 17:50:52.947  - debug: yeelight-2.0 DEVICE FOUND SET NOTIFY STATE: {"name":"SZ_Lampe","ip":"192.168.111.210","port":"55443","smart_name":"","type":"color","id":"0x000000000000000","supports":["get_prop","set_default","set_power","toggle","set_bright","start_cf","stop_cf","set_scene","cron_add","cron_get","cron_del","set_ct_abx","set_rgb","set_hsv","set_adjust","adjust_bright","adjust_ct","adjust_color","set_music","set_name"]}
                                    2018-12-02 17:51:09.111  - debug: yeelight-2.0 ERROR YEELIGHT CONNECTION: 0x000000000000000: Connection 192.168.111.210:55443: Error: read ECONNRESET
                                    2018-12-02 17:51:09.319  - debug: yeelight-2.0 SEND STATE: id:0x000000000000000, state: power, value: false
                                    2018-12-02 17:51:09.333  - debug: yeelight-2.0 RESPONSE MESSAGE: from: 0x000000000000000, id: 224, result:[ok]}
                                    2018-12-02 17:51:11.125  - debug: yeelight-2.0 NOTIFY MESSAGE: from: 0x000000000000000, message: {"method":"props","params":{"power":"off"}}
                                    2018-12-02 17:51:11.126  - debug: yeelight-2.0 DEVICE FOUND SET NOTIFY STATE: {"name":"SZ_Lampe","ip":"192.168.111.210","port":"55443","smart_name":"","type":"color","id":"0x000000000000000","supports":["get_prop","set_default","set_power","toggle","set_bright","start_cf","stop_cf","set_scene","cron_add","cron_get","cron_del","set_ct_abx","set_rgb","set_hsv","set_adjust","adjust_bright","adjust_ct","adjust_color","set_music","set_name"]}
                                    2018-12-02 17:51:12.809  - debug: yeelight-2.0 SEND STATE: id:0x000000000000000, state: power, value: true
                                    2018-12-02 17:51:12.937  - debug: yeelight-2.0 RESPONSE MESSAGE: from: 0x000000000000000, id: 225, result:[ok]}
                                    2018-12-02 17:51:13.936  - debug: yeelight-2.0 NOTIFY MESSAGE: from: 0x000000000000000, message: {"method":"props","params":{"power":"on"}}
                                    2018-12-02 17:51:13.939  - debug: yeelight-2.0 DEVICE FOUND SET NOTIFY STATE: {"name":"SZ_Lampe","ip":"192.168.111.210","port":"55443","smart_name":"","type":"color","id":"0x000000000000000","supports":["get_prop","set_default","set_power","toggle","set_bright","start_cf","stop_cf","set_scene","cron_add","cron_get","cron_del","set_ct_abx","set_rgb","set_hsv","set_adjust","adjust_bright","adjust_ct","adjust_color","set_music","set_name"]}
                                    2018-12-02 17:51:42.775  - debug: yeelight-2.0 SEND STATE: id:0x000000000000000, state: power, value: false
                                    2018-12-02 17:51:42.863  - debug: yeelight-2.0 RESPONSE MESSAGE: from: 0x000000000000000, id: 226, result:[ok]}
                                    2018-12-02 17:51:45.073  - debug: yeelight-2.0 NOTIFY MESSAGE: from: 0x000000000000000, message: {"method":"props","params":{"power":"off"}}
                                    2018-12-02 17:51:45.076  - debug: yeelight-2.0 DEVICE FOUND SET NOTIFY STATE: {"name":"SZ_Lampe","ip":"192.168.111.210","port":"55443","smart_name":"","type":"color","id":"0x000000000000000","supports":["get_prop","set_default","set_power","toggle","set_bright","start_cf","stop_cf","set_scene","cron_add","cron_get","cron_del","set_ct_abx","set_rgb","set_hsv","set_adjust","adjust_bright","adjust_ct","adjust_color","set_music","set_name"]}
                                    2018-12-02 17:51:53.628  - debug: yeelight-2.0 SEND STATE: id:0x000000000000000, state: power, value: true
                                    2018-12-02 17:51:56.699  - debug: yeelight-2.0 SEND STATE: id:0x000000000000000, state: power, value: false
                                    2018-12-02 17:51:58.061  - debug: yeelight-2.0 RESPONSE MESSAGE: from: 0x000000000000000, id: 227, result:[ok]}
                                    2018-12-02 17:51:58.156  - debug: yeelight-2.0 ERROR YEELIGHT CONNECTION: null: SyntaxError: Unexpected token { in JSON at position 44: {"method":"props","params":{"power":"on"}}
                                    2018-12-02 17:52:27.229  - debug: yeelight-2.0 SEND STATE: id:0x000000000000000, state: power, value: true
                                    2018-12-02 17:52:30.612  - debug: yeelight-2.0 ERROR YEELIGHT CONNECTION: 0x000000000000000: Connection 192.168.111.210:55443: Error: read ECONNRESET
                                    2018-12-02 17:52:41.459  - debug: yeelight-2.0 YEELIGHT OFFLINE: 0x000000000000000
                                    2018-12-02 17:53:03.078  - debug: yeelight-2.0 RESPONSE MESSAGE: from: 0x000000000000000, id: 230, result:[off,100,16711680,2,2589]}
                                    2018-12-02 17:53:03.080  - debug: yeelight-2.0 DEVICE FOUND IN CONFIG: {"name":"SZ_Lampe","ip":"192.168.111.210","port":"55443","smart_name":"","type":"color","id":"0x000000000000000","supports":["get_prop","set_default","set_power","toggle","set_bright","start_cf","stop_cf","set_scene","cron_add","cron_get","cron_del","set_ct_abx","set_rgb","set_hsv","set_adjust","adjust_bright","adjust_ct","adjust_color","set_music","set_name"]}
                                    2018-12-02 17:53:32.619  - debug: yeelight-2.0 SEND STATE: id:0x000000000000000, state: power, value: true
                                    2018-12-02 17:53:38.525  - debug: yeelight-2.0 RESPONSE MESSAGE: from: 0x000000000000000, id: 231, result:[ok]}
                                    2018-12-02 17:53:38.941  - debug: yeelight-2.0 NOTIFY MESSAGE: from: 0x000000000000000, message: {"method":"props","params":{"power":"on"}}
                                    2018-12-02 17:53:38.943  - debug: yeelight-2.0 DEVICE FOUND SET NOTIFY STATE: {"name":"SZ_Lampe","ip":"192.168.111.210","port":"55443","smart_name":"","type":"color","id":"0x000000000000000","supports":["get_prop","set_default","set_power","toggle","set_bright","start_cf","stop_cf","set_scene","cron_add","cron_get","cron_del","set_ct_abx","set_rgb","set_hsv","set_adjust","adjust_bright","adjust_ct","adjust_color","set_music","set_name"]}
                                    2018-12-02 17:48:20.808  - debug: yeelight-2.0 SEND STATE: id:0x000000000000000, state: power, value: false
                                    2018-12-02 17:48:20.878  - debug: yeelight-2.0 RESPONSE MESSAGE: from: 0x000000000000000, id: 213, result:[ok]}
                                    2018-12-02 17:48:23.023  - debug: yeelight-2.0 NOTIFY MESSAGE: from: 0x000000000000000, message: {"method":"props","params":{"power":"off"}}
                                    2018-12-02 17:48:23.025  - debug: yeelight-2.0 DEVICE FOUND SET NOTIFY STATE: {"name":"SZ_Lampe","ip":"192.168.111.210","port":"55443","smart_name":"","type":"color","id":"0x000000000000000","supports":["get_prop","set_default","set_power","toggle","set_bright","start_cf","stop_cf","set_scene","cron_add","cron_get","cron_del","set_ct_abx","set_rgb","set_hsv","set_adjust","adjust_bright","adjust_ct","adjust_color","set_music","set_name"]}
                                    2018-12-02 17:48:23.300  - debug: yeelight-2.0 SEND STATE: id:0x000000000000000, state: power, value: true
                                    2018-12-02 17:48:27.497  - debug: yeelight-2.0 RESPONSE MESSAGE: from: 0x000000000000000, id: 214, result:[ok]}
                                    2018-12-02 17:48:27.518  - debug: yeelight-2.0 NOTIFY MESSAGE: from: 0x000000000000000, message: {"method":"props","params":{"power":"on"}}
                                    2018-12-02 17:48:27.520  - debug: yeelight-2.0 DEVICE FOUND SET NOTIFY STATE: {"name":"SZ_Lampe","ip":"192.168.111.210","port":"55443","smart_name":"","type":"color","id":"0x000000000000000","supports":["get_prop","set_default","set_power","toggle","set_bright","start_cf","stop_cf","set_scene","cron_add","cron_get","cron_del","set_ct_abx","set_rgb","set_hsv","set_adjust","adjust_bright","adjust_ct","adjust_color","set_music","set_name"]}
                                    2018-12-02 17:48:31.055  - debug: yeelight-2.0 SEND STATE: id:0x000000000000000, state: power, value: false
                                    2018-12-02 17:48:33.686  - debug: yeelight-2.0 SEND STATE: id:0x000000000000000, state: power, value: true
                                    2018-12-02 17:48:35.488  - debug: yeelight-2.0 RESPONSE MESSAGE: from: 0x000000000000000, id: 215, result:[ok]}
                                    2018-12-02 17:49:38.385  - debug: yeelight-2.0 DEVICE F2018-12-02 17:54:09.980  - debug: yeelight-2.0 RESPONSE MESSAGE: from: 0x000000000000000, id: 232, result:[on,100,16711680,2,2589]}
                                    Reply from 192.168.111.210: bytes=32 time=5ms TTL=255
                                    Reply from 192.168.111.210: bytes=32 time=3ms TTL=255
                                    Reply from 192.168.111.210: bytes=32 time=4ms TTL=255
                                    Reply from 192.168.111.210: bytes=32 time=405ms TTL=255
                                    Reply from 192.168.111.210: bytes=32 time=8ms TTL=255
                                    Reply from 192.168.111.210: bytes=32 time=6ms TTL=255
                                    Reply from 192.168.111.210: bytes=32 time=7ms TTL=255
                                    Reply from 192.168.111.210: bytes=32 time=2ms TTL=255
                                    Reply from 192.168.111.210: bytes=32 time=132ms TTL=255
                                    Reply from 192.168.111.210: bytes=32 time=25ms TTL=255
                                    Reply from 192.168.111.210: bytes=32 time=11ms TTL=255
                                    Reply from 192.168.111.210: bytes=32 time=401ms TTL=255
                                    Reply from 192.168.111.210: bytes=32 time=15ms TTL=255
                                    Reply from 192.168.111.210: bytes=32 time=28ms TTL=255
                                    Reply from 192.168.111.210: bytes=32 time=407ms TTL=255
                                    Reply from 192.168.111.210: bytes=32 time=31ms TTL=255
                                    Reply from 192.168.111.210: bytes=32 time=10ms TTL=255
                                    Reply from 192.168.111.210: bytes=32 time=12ms TTL=255
                                    Reply from 192.168.111.210: bytes=32 time=55ms TTL=255
                                    Reply from 192.168.111.210: bytes=32 time=16ms TTL=255
                                    Reply from 192.168.111.210: bytes=32 time=412ms TTL=255
                                    Reply from 192.168.111.210: bytes=32 time=27ms TTL=255
                                    Reply from 192.168.111.210: bytes=32 time=414ms TTL=255
                                    Reply from 192.168.111.210: bytes=32 time=240ms TTL=255
                                    Reply from 192.168.111.210: bytes=32 time=26ms TTL=255
                                    Reply from 192.168.111.210: bytes=32 time=91ms TTL=255
                                    Request timed out.
                                    Request timed out.
                                    Reply from 192.168.111.210: bytes=32 time=21ms TTL=255
                                    Reply from 192.168.111.210: bytes=32 time=403ms TTL=255
                                    Reply from 192.168.111.210: bytes=32 time=72ms TTL=255
                                    Request timed out.
                                    Reply from 192.168.111.210: bytes=32 time=410ms TTL=255
                                    Reply from 192.168.111.210: bytes=32 time=30ms TTL=255
                                    Request timed out.
                                    Request timed out.
                                    Request timed out.
                                    Reply from 192.168.111.210: bytes=32 time=9ms TTL=255
                                    Reply from 192.168.111.210: bytes=32 time=13ms TTL=255
                                    Request timed out.
                                    Request timed out.
                                    Reply from 192.168.111.210: bytes=32 time=42ms TTL=255
                                    Request timed out.
                                    Request timed out.
                                    Request timed out.
                                    Request timed out.
                                    Reply from 192.168.111.210: bytes=32 time=85ms TTL=255
                                    Request timed out.
                                    Request timed out.
                                    Reply from 192.168.111.210: bytes=32 time=218ms TTL=255
                                    Reply from 192.168.111.210: bytes=32 time=14ms TTL=255
                                    Request timed out.
                                    Reply from 192.168.111.210: bytes=32 time=17ms TTL=255
                                    Reply from 192.168.111.210: bytes=32 time=19ms TTL=255
                                    Request timed out.
                                    Request timed out.
                                    Reply from 192.168.111.210: bytes=32 time=104ms TTL=255
                                    Request timed out.
                                    Request timed out.
                                    Reply from 192.168.111.210: bytes=32 time=23ms TTL=255
                                    Request timed out.
                                    Request timed out.
                                    Reply from 192.168.111.210: bytes=32 time=418ms TTL=255
                                    Request timed out.
                                    Request timed out.
                                    Request timed out.
                                    Request timed out.
                                    Reply from 192.168.111.210: bytes=32 time=474ms TTL=255
                                    Request timed out.
                                    Request timed out.
                                    Reply from 192.168.111.210: bytes=32 time=421ms TTL=255
                                    Reply from 192.168.111.210: bytes=32 time=20ms TTL=255
                                    Request timed out.
                                    Request timed out.
                                    Request timed out.
                                    Reply from 192.168.111.210: bytes=32 time=162ms TTL=255
                                    Request timed out.
                                    Request timed out.
                                    Reply from 192.168.111.210: bytes=32 time=71ms TTL=255
                                    Request timed out.
                                    Request timed out.
                                    Reply from 192.168.111.210: bytes=32 time=40ms TTL=255
                                    Request timed out.
                                    Request timed out.
                                    Request timed out.
                                    Request timed out.
                                    Request timed out.
                                    Reply from 192.168.111.210: bytes=32 time=41ms TTL=255
                                    Reply from 192.168.111.210: bytes=32 time=35ms TTL=255
                                    Reply from 192.168.111.210: bytes=32 time=22ms TTL=255
                                    Reply from 192.168.111.210: bytes=32 time=36ms TTL=255
                                    Reply from 192.168.111.210: bytes=32 time=119ms TTL=255
                                    Request timed out.
                                    Reply from 192.168.111.210: bytes=32 time=416ms TTL=255
                                    Request timed out.
                                    Request timed out.
                                    Request timed out.
                                    Request timed out.
                                    Reply from 192.168.111.210: bytes=32 time=46ms TTL=255
                                    Request timed out.
                                    Request timed out.
                                    Request timed out.
                                    Request timed out.
                                    Request timed out.
                                    Reply from 192.168.111.210: bytes=32 time=69ms TTL=255
                                    Request timed out.
                                    Request timed out.
                                    Request timed out.
                                    Request timed out.
                                    Request timed out.
                                    Request timed out.
                                    Request timed out.
                                    Request timed out.
                                    Request timed out.
                                    Request timed out.
                                    Request timed out.
                                    Request timed out.
                                    Reply from 192.168.111.210: bytes=32 time=128ms TTL=255
                                      Dirk18
                                      #78
                                      ich hab ein Yeelight 650, die funktionier mit dem Adapter soweit, nur die RGB Leds kann ich nicht steuern, weder die Helligkeit noch die Farbe.
                                      Im Log steht nicht auffälliges drin, mit der Version 0.4.1 hat das funktioniert.
                                      Jemand ein Tipp woran das liegen kann.
                                      yeelight-2.0 2018-12-08 12:06:02.087 debug DEVICE FOUND IN CONFIG: {"name":"Yeelight_Wohnzimmer","ip":"192.168.178.37","port":"55443","smart_name":"Wohnzimmer","type":"ceiling4","id":"0x0000000005ef6cd8"}
                                      yeelight-2.0 2018-12-08 12:06:02.086 debug RESPONSE MESSAGE: from: 0x0000000005ef6cd8, id: 28, result:[on,1,,2,2700]}
                                      yeelight-2.0 2018-12-08 12:05:49.132 debug system.adapter.admin.0: logging true
                                      yeelight-2.0 2018-12-08 12:05:44.622 debug SEND STATE: id:0x0000000005ef6cd8, state: bg_rgb, value: #ffaaaa
                                      yeelight-2.0 2018-12-08 12:05:32.065 debug DEVICE FOUND SET NOTIFY STATE: {"name":"Yeelight_Wohnzimmer","ip":"192.168.178.37","port":"55443","smart_name":"Wohnzimmer","type":"ceiling4","id":"0x0000000005ef6cd8"}
                                      yeelight-2.0 2018-12-08 12:05:32.064 debug NOTIFY MESSAGE: from: 0x0000000005ef6cd8, message: {"method":"props","params":{"bg_rgb":255,"bg_hue":240}}
                                      yeelight-2.0 2018-12-08 12:05:22.777 debug DEVICE FOUND SET NOTIFY STATE: {"name":"Yeelight_Wohnzimmer","ip":"192.168.178.37","port":"55443","smart_name":"Wohnzimmer","type":"ceiling4","id":"0x0000000005ef6cd8"}
                                      yeelight-2.0 2018-12-08 12:05:22.776 debug NOTIFY MESSAGE: from: 0x0000000005ef6cd8, message: {"method":"props","params":{"bright":1,"active_bright":1}}
                                      Danke Dirk
                                      • MeistertrM Offline
                                        MeistertrM Offline
                                        Meistertr
                                        #79
                                        @ltsalvatore dein angehängtes log ist ohne Auffälligkeiten. es wird ornungsgemäß aktualisiert und auch die schaltvörgänge werden von der Lampe positiv Rück gemeldet.Ein Verbindungsreset ist mit drin, das ist aber unprbelmatisch. Ich hatte zu beginn auch probleme mit aufhängen der Lampen die waren aber irgendwann einfach verschrunden weiß nciht was ich gemacht habe…
                                        @Dirk18 bitte versuche mal die 0.9.6 von git
                                          Dirk18
                                          #80
                                          mit der 0.9.6 funktioniert es
                                          Vielen Dank
