  3. Entwicklung
  4. [Neuer Adapter] Xiaomi Luftfilter
188 Beiträge 38 Kommentatoren 49.6k Aufrufe 28 Beobachtet
  • FenriswolfF Fenriswolf
    @dontobi
    leider immer noch Fehler:
    mihome-airpurifier.0	2020-11-29 15:45:16.453	info	(7663) Terminated (NO_ERROR): Without reason
    mihome-airpurifier.0	2020-11-29 15:45:16.444	info	(7663) terminating
    mihome-airpurifier.0	2020-11-29 15:45:16.413	info	(7663) cleaned everything up...
    mihome-airpurifier.0	2020-11-29 15:45:16.411	error	(7663) TypeError: Cannot read property 'toString' of undefined at MiHomeAirPurifier.<anonymous> (/opt/iobroker/node_modules/iobroker.mihome-airpurifier/build/main.js:293:37) at Generator.next
    mihome-airpurifier.0	2020-11-29 15:45:16.410	error	(7663) unhandled promise rejection: Cannot read property 'toString' of undefined
    mihome-airpurifier.0	2020-11-29 15:45:16.409	error	Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
    mihome-airpurifier.0	2020-11-29 15:45:16.406	debug	(7663) subscribeToValues
    mihome-airpurifier.0	2020-11-29 15:45:16.405	debug	(7663) filterHoursUsed: undefined
    mihome-airpurifier.0	2020-11-29 15:45:16.404	debug	(7663) filterLifeRemaining: undefined
    mihome-airpurifier.0	2020-11-29 15:45:16.402	debug	(7663) led: undefined
    mihome-airpurifier.0	2020-11-29 15:45:16.401	debug	(7663) buzzer: undefined
    mihome-airpurifier.0	2020-11-29 15:45:16.400	debug	(7663) pm25: undefined
    mihome-airpurifier.0	2020-11-29 15:45:16.398	debug	(7663) humidity: undefined
    mihome-airpurifier.0	2020-11-29 15:45:16.396	debug	(7663) manuallevel: NaN
    mihome-airpurifier.0	2020-11-29 15:45:16.394	debug	(7663) mode: undefined
    mihome-airpurifier.0	2020-11-29 15:45:16.392	debug	(7663) power: undefined
    mihome-airpurifier.0	2020-11-29 15:45:16.391	debug	(7663) checkValues
    mihome-airpurifier.0	2020-11-29 15:45:16.389	info	(7663) Connected!
    mihome-airpurifier.0	2020-11-29 15:45:15.839	debug	(7663) Connect to device: 192.168.99.122
    mihome-airpurifier.0	2020-11-29 15:45:15.837	info	(7663) Connecting...
    mihome-airpurifier.0	2020-11-29 15:45:15.831	info	(7663) Started
    mihome-airpurifier.0	2020-11-29 15:45:15.795	info	(7663) starting. Version 0.2.1 in /opt/iobroker/node_modules/iobroker.mihome-airpurifier, node: v12.20.0, js-controller: 3.1.6
    dontobiD Offline
    dontobiD Offline
    dontobi
    #101
    @Fenriswolf So wie es scheint, gibt es zwischen der 2. Serie und der 3. Serie größere Abweichungen, wie die Daten abgefragt werden. Der Error von dir wir bei meinem 2H nicht erzeugt. In dem Fall ließt der Adapter die Temperatur aus.
    Das wird also eine größere Aktion und dafür muss ich mich tiefer in den Adapter und miio einarbeiten. Aber vielleicht kann mir ja noch jemand helfen.
    Smart Home Zentrale: Raspberry Pi 4 4GB
    Meine Homepage: https://www.myHome.zone
    • 9 Offline
      9 Offline
      9_Mad-Max_5
      #102
      Hat es jemand geschafft den chinesischen 2S auszulesen?
      Device ID: 31556799X
      Model info: Unknown
      Address: 192.168.2.136
      Token: ???
      Support: Unknown
      Das ist leider alles was meiner mir miio auspuckt...
      dontobiD 1 Antwort Letzte Antwort
      • 9 9_Mad-Max_5
        Model info: Unknown
        Token: ???
        Support: Unknown
        dontobiD Offline
        dontobiD Offline
        dontobi
        #103
        @9_Mad-Max_5 Ich hab es damals mit miio auch nicht geschaft. Es gibt eine angepasste App, mit der man die ID auslesen kann. Google mal danach.
        • dontobiD dontobi
          MrLee
          #104
          @dontobi
          Moin!
          So, bin jetzt auch mal zum testen gekommen.
          Purifier 3H, im WLAN eingebunden, bisher über HAM gesteuert (soweit möglich).
          Leider stürtzt der Adapter bei mir ab:
          host.iobroker_host	2020-12-14 09:01:47.629	error	instance system.adapter.mihome-airpurifier.0 terminated with code 1 (JS_CONTROLLER_STOPPED)
          host.iobroker_host	2020-12-14 09:01:47.628	error	Caught by controller[0]: at Object.Module._extensions..js (internal/modules/cjs/loader.js:789:10)
          host.iobroker_host	2020-12-14 09:01:47.628	error	Caught by controller[0]: at Module._compile (internal/modules/cjs/loader.js:778:30)
          host.iobroker_host	2020-12-14 09:01:47.628	error	Caught by controller[0]: at Object.<anonymous> (/usr/local/iobroker/node_modules/miio/lib/devices/air-purifier.js:11:18)
          host.iobroker_host	2020-12-14 09:01:47.628	error	Caught by controller[0]: at require (internal/modules/cjs/helpers.js:25:18)
          host.iobroker_host	2020-12-14 09:01:47.628	error	Caught by controller[0]: at Module.require (internal/modules/cjs/loader.js:692:17)
          host.iobroker_host	2020-12-14 09:01:47.628	error	Caught by controller[0]: at Function.Module._load (internal/modules/cjs/loader.js:585:3)
          host.iobroker_host	2020-12-14 09:01:47.628	error	Caught by controller[0]: at tryModuleLoad (internal/modules/cjs/loader.js:593:12)
          host.iobroker_host	2020-12-14 09:01:47.627	error	Caught by controller[0]: at Module.load (internal/modules/cjs/loader.js:653:32)
          host.iobroker_host	2020-12-14 09:01:47.627	error	Caught by controller[0]: at Object.Module._extensions..js (internal/modules/cjs/loader.js:789:10)
          host.iobroker_host	2020-12-14 09:01:47.627	error	Caught by controller[0]: at Module._compile (internal/modules/cjs/loader.js:723:23)
          host.iobroker_host	2020-12-14 09:01:47.627	error	Caught by controller[0]: SyntaxError: Unexpected token =
          host.iobroker_host	2020-12-14 09:01:47.627	error	Caught by controller[0]: ^
          host.iobroker_host	2020-12-14 09:01:47.626	error	Caught by controller[0]: fs1 = -1;
          host.iobroker_host	2020-12-14 09:01:47.626	error	Caught by controller[0]: /usr/local/iobroker/node_modules/miio/lib/devices/capabilities/fan-speed.js:7
          Kann ich irgendwie unterstützen?
          Mr.Lee
          • M MrLee
            @dontobi
            Moin!
            Mr.Lee
            #105
            @MrLee
            Ich glaube, da ist deine Grundinstallation schon krumm.
            Das Verzeichnis /usr/local/iobroker sollte nicht vorhanden sein.
            Schau mal ob nodeJS richtig tickt:
            which nodejs && nodejs -v && which node && node -v && which npm && npm -v && apt policy nodejs
            • FenriswolfF Offline
              FenriswolfF Offline
              Fenriswolf
              #106
              Moin,
              ich hatte mit @dontobi schon ein wenig getestet, bzw. @dontobi hatte einige Änderungen gemacht und ich getestet. Es gibt immer noch Probleme mit dem 3H.
              Also nicht wundern, wenn da immernoch Probleme auftreten.
              Press any key to continue or any other to quit
                @MrLee
                MrLee
                #107
                @Thomas-Braun
                Moin!
                Danke für den Hinweis, aber meine installation ist etwas "anders" von den Pfaden ...
                Hatte bisher aber keinen negativen Einfluß.
                Mr.Lee
                • M MrLee
                  @Thomas-Braun
                  Moin!
                  Mr.Lee
                  #108
                  @MrLee sagte in [Neuer Adapter] Xiaomi Luftfilter:
                  Das sieht man... Was hast du denn da 'umgebogen'? Und warum?
                    SaiBot1981
                    #109
                    Moin, falls du für den H3 auch noch weiter entwickelst wäre das klassen
                    • S SaiBot1981
                      dontobiD Offline
                      dontobiD Offline
                      dontobi
                      #110
                      @SaiBot1981 Ich bin dabei den Code zu sichten und lese mich in Sachen Adapter Entwicklung ein. Außerdem bin ich in JS nicht so fit und muss auch da noch einiges lernen.
                        moeff
                        #111
                        Hi, komme leider auch nicht weiter. Token ist korrekt (mehrfach geprüft).
                        host.iobroker	2020-12-25 02:16:31.218	error	instance system.adapter.mihome-airpurifier.0 terminated with code 1 (JS_CONTROLLER_STOPPED)
                        host.iobroker	2020-12-25 02:16:31.218	error	Caught by controller[0]: at Object.Module._extensions..js (internal/modules/cjs/loader.js:789:10)
                        host.iobroker	2020-12-25 02:16:31.218	error	Caught by controller[0]: at Module._compile (internal/modules/cjs/loader.js:778:30)
                        host.iobroker	2020-12-25 02:16:31.218	error	Caught by controller[0]: at Object.<anonymous> (/opt/iobroker/node_modules/miio/lib/devices/air-purifier.js:11:18)
                        host.iobroker	2020-12-25 02:16:31.218	error	Caught by controller[0]: at require (internal/modules/cjs/helpers.js:25:18)
                        host.iobroker	2020-12-25 02:16:31.218	error	Caught by controller[0]: at Module.require (internal/modules/cjs/loader.js:692:17)
                        host.iobroker	2020-12-25 02:16:31.218	error	Caught by controller[0]: at Function.Module._load (internal/modules/cjs/loader.js:585:3)
                        host.iobroker	2020-12-25 02:16:31.218	error	Caught by controller[0]: at tryModuleLoad (internal/modules/cjs/loader.js:593:12)
                        host.iobroker	2020-12-25 02:16:31.218	error	Caught by controller[0]: at Module.load (internal/modules/cjs/loader.js:653:32)
                        host.iobroker	2020-12-25 02:16:31.218	error	Caught by controller[0]: at Module._compile (internal/modules/cjs/loader.js:723:23)
                        host.iobroker	2020-12-25 02:16:31.218	error	Caught by controller[0]: SyntaxError: Unexpected token =
                        host.iobroker	2020-12-25 02:16:31.218	error	Caught by controller[0]: ^
                        host.iobroker	2020-12-25 02:16:31.218	error	Caught by controller[0]: fs1 = -1;
                        host.iobroker	2020-12-25 02:16:31.218	error	Caught by controller[0]: /opt/iobroker/node_modules/miio/lib/devices/capabilities/fan-speed.js:7
                        • M moeff
                          dontobiD Offline
                          dontobiD Offline
                          dontobi
                          #112
                          @moeff Leider komme ich derzeit nicht dazu mir den Adapter anzusehen. Daher werde ich erst einmal den Support für die 3er Serie raus nehmen, damit sich die Meldungen hier nicht häufen.
                          Vielleicht kann mir jemand bei dem Support der 3er Serie helfen. Am besten jemand, der auch ein solches Gerät hat. Jedoch sollte dieser ein wenig Vorkenntnisse in Sachen Programmierung mitbringen.
                          Frohe Weihnachten.
                          M E 2 Antworten Letzte Antwort
                          • dontobiD dontobi
                            Frohe Weihnachten.
                            moeff
                            #113
                            @dontobi vielen Dank für die schnelle Antwort. Es handelt sich in meinem Falle um den 2H. Gibt es eine frühere Version die du empfehlen kannst?
                            • M moeff
                              dontobiD Offline
                              dontobiD Offline
                              dontobi
                              #114
                              @moeff said in [Neuer Adapter] Xiaomi Luftfilter:
                              Ich hab auch den 2H und mit meiner Version (mein GitHub Repo) klappt dieser.
                              • dontobiD dontobi
                                moeff
                                schrieb am zuletzt editiert von moeff
                                #115
                                @dontobi ich nutze = https://github.com/JoJ123/ioBroker.mihome-airpurifier auf 0.1.8
                                gibt es noch eine andere ?
                                omg zu blöd:
                                https://github.com/dontobi/ioBroker.mihome-airpurifier
                                aber mit der bekomme ich nur oben genannten Fehler.
                                • M moeff
                                  omg zu blöd:
                                  moeff
                                  #116
                                  omg zu blöd:
                                  Hab den 2h nun über den miio adapter ohne Probleme eingebunden bekommen.
                                  dasquiddiD 1 Antwort Letzte Antwort
                                  • dontobiD dontobi
                                    Frohe Weihnachten.
                                    Ente
                                    schrieb am zuletzt editiert von Ente
                                    #117
                                    @dontobi
                                    Den 3h habe ich. Leider sieht es mit Programmierung eher mau aus.
                                    VG
                                    Chris
                                    • M moeff
                                      omg zu blöd:
                                      dasquiddiD Offline
                                      dasquiddiD Offline
                                      dasquiddi
                                      #118
                                      @moeff
                                      Wie konntest du das Problem lösen? Ich stehe vo dem gleichen Problem
                                      dontobiD M 2 Antworten Letzte Antwort
                                      • dasquiddiD dasquiddi
                                        @moeff
                                        dontobiD Offline
                                        dontobiD Offline
                                        dontobi
                                        #119
                                        @dasquiddi am besten installierst du den Adapter komplett neu. Also erst den alten deinstallieren und dann über.den GitHub Link meine Version des Adapters installieren.
                                        J 1 Antwort Letzte Antwort
                                        • dontobiD dontobi
                                          JensA
                                          #120
                                          Erstmal vielen Dank für die Programmierung und die Unterstützung. Ich habe die Diskussion hier interessiert verfolgt, aber ehrlich gesagt etwas den Überblick verloren.
                                          Was ich bisher geschafft habe: Token auslesen per vacuum adapter. Was ich nicht hinbekomme: 2H einbinden. Welche Version aus welchem git Link sollte damit funktionieren?
