  3. Entwicklung
  4. [Neuer Adapter] Xiaomi Luftfilter
188 Beiträge 38 Kommentatoren 49.6k Aufrufe 28 Beobachtet
    moeff
    #111
    Hi, komme leider auch nicht weiter. Token ist korrekt (mehrfach geprüft).
    host.iobroker	2020-12-25 02:16:31.218	error	instance system.adapter.mihome-airpurifier.0 terminated with code 1 (JS_CONTROLLER_STOPPED)
    host.iobroker	2020-12-25 02:16:31.218	error	Caught by controller[0]: at Object.Module._extensions..js (internal/modules/cjs/loader.js:789:10)
    host.iobroker	2020-12-25 02:16:31.218	error	Caught by controller[0]: at Module._compile (internal/modules/cjs/loader.js:778:30)
    host.iobroker	2020-12-25 02:16:31.218	error	Caught by controller[0]: at Object.<anonymous> (/opt/iobroker/node_modules/miio/lib/devices/air-purifier.js:11:18)
    host.iobroker	2020-12-25 02:16:31.218	error	Caught by controller[0]: at require (internal/modules/cjs/helpers.js:25:18)
    host.iobroker	2020-12-25 02:16:31.218	error	Caught by controller[0]: at Module.require (internal/modules/cjs/loader.js:692:17)
    host.iobroker	2020-12-25 02:16:31.218	error	Caught by controller[0]: at Function.Module._load (internal/modules/cjs/loader.js:585:3)
    host.iobroker	2020-12-25 02:16:31.218	error	Caught by controller[0]: at tryModuleLoad (internal/modules/cjs/loader.js:593:12)
    host.iobroker	2020-12-25 02:16:31.218	error	Caught by controller[0]: at Module.load (internal/modules/cjs/loader.js:653:32)
    host.iobroker	2020-12-25 02:16:31.218	error	Caught by controller[0]: at Module._compile (internal/modules/cjs/loader.js:723:23)
    host.iobroker	2020-12-25 02:16:31.218	error	Caught by controller[0]: SyntaxError: Unexpected token =
    host.iobroker	2020-12-25 02:16:31.218	error	Caught by controller[0]: ^
    host.iobroker	2020-12-25 02:16:31.218	error	Caught by controller[0]: fs1 = -1;
    host.iobroker	2020-12-25 02:16:31.218	error	Caught by controller[0]: /opt/iobroker/node_modules/miio/lib/devices/capabilities/fan-speed.js:7
    dontobiD 1 Antwort Letzte Antwort
    • M moeff
      dontobiD Offline
      dontobiD Offline
      dontobi
      #112
      @moeff Leider komme ich derzeit nicht dazu mir den Adapter anzusehen. Daher werde ich erst einmal den Support für die 3er Serie raus nehmen, damit sich die Meldungen hier nicht häufen.
      Vielleicht kann mir jemand bei dem Support der 3er Serie helfen. Am besten jemand, der auch ein solches Gerät hat. Jedoch sollte dieser ein wenig Vorkenntnisse in Sachen Programmierung mitbringen.
      Frohe Weihnachten.
      Smart Home Zentrale: Raspberry Pi 4 4GB
      Meine Homepage: https://www.myHome.zone
      M E 2 Antworten Letzte Antwort
      • dontobiD dontobi
        Frohe Weihnachten.
        moeff
        #113
        @dontobi vielen Dank für die schnelle Antwort. Es handelt sich in meinem Falle um den 2H. Gibt es eine frühere Version die du empfehlen kannst?
        • M moeff
          dontobiD Offline
          dontobiD Offline
          dontobi
          #114
          @moeff said in [Neuer Adapter] Xiaomi Luftfilter:
          Ich hab auch den 2H und mit meiner Version (mein GitHub Repo) klappt dieser.
          • dontobiD dontobi
            moeff
            schrieb am zuletzt editiert von moeff
            #115
            @dontobi ich nutze = https://github.com/JoJ123/ioBroker.mihome-airpurifier auf 0.1.8
            gibt es noch eine andere ?
            omg zu blöd:
            https://github.com/dontobi/ioBroker.mihome-airpurifier
            aber mit der bekomme ich nur oben genannten Fehler.
            • M moeff
              omg zu blöd:
              moeff
              #116
              omg zu blöd:
              Hab den 2h nun über den miio adapter ohne Probleme eingebunden bekommen.
              dasquiddiD 1 Antwort Letzte Antwort
              • dontobiD dontobi
                Frohe Weihnachten.
                Ente
                schrieb am zuletzt editiert von Ente
                #117
                @dontobi
                Den 3h habe ich. Leider sieht es mit Programmierung eher mau aus.
                Chris
                • M moeff
                  omg zu blöd:
                  dasquiddiD Offline
                  dasquiddiD Offline
                  dasquiddi
                  #118
                  @moeff
                  Wie konntest du das Problem lösen? Ich stehe vo dem gleichen Problem
                  dontobiD M 2 Antworten Letzte Antwort
                  • dasquiddiD dasquiddi
                    @moeff
                    dontobiD Offline
                    dontobiD Offline
                    dontobi
                    #119
                    @dasquiddi am besten installierst du den Adapter komplett neu. Also erst den alten deinstallieren und dann über.den GitHub Link meine Version des Adapters installieren.
                    • dontobiD dontobi
                      JensA
                      #120
                      Erstmal vielen Dank für die Programmierung und die Unterstützung. Ich habe die Diskussion hier interessiert verfolgt, aber ehrlich gesagt etwas den Überblick verloren.
                      Was ich bisher geschafft habe: Token auslesen per vacuum adapter. Was ich nicht hinbekomme: 2H einbinden. Welche Version aus welchem git Link sollte damit funktionieren?
                        @moeff
                        moeff
                        #121
                        @dasquiddi hab es über den miio Adapter gelöst. wäre zwar schön gewesen den Adapter von dontobi zu nutzen, aber startet einfach nicht, auch nach kompletter Deinstallation und Neuinstrallation.
                        für miio, siehe Screenshots - beim grauen Balken dein Token eintragen
                        J E 2 Antworten Letzte Antwort
                        • M moeff
                          JensA
                          #122
                          @moeff
                          Danke. Bei mir startet zwar der Adapter von dontobi aus dem link https://github.com/JoJ123/ioBroker.mihome-airpurifier ohne Probleme. Aber weder bei diesem Adapter noch bei dem miio Adapter gelingt mir die Verbindung mit dem 2H. Der 2H reagiert einfach gar nicht.
                          • M moeff
                            Ente
                            #123
                            Bei mir hat der Adapter den H3 erkannt, dann aber die Werte wieder gelöscht. Keine Ahnung warum. Hab ihn erstmal wieder de-aktiviert.
                              moeff
                              #124
                              @Ente im miio sieht es bei mir so aus
                              @JensA https://github.com/JoJ123/ioBroker.mihome-airpurifier ist der alte Adapter, hier habe ich nur die Vorgängerversionen der Xiaomi Purifier zur Auswahl - der Adapter startet zwar, sagt aber Unknown Purifier Version
                              der Adapter von dontobi - https://github.com/dontobi/ioBroker.mihome-airpurifier Startet leider bei mir nicht - sondern bleibt mit hängen:
                              dontobiD J 2 Antworten Letzte Antwort
                              • M moeff
                                dontobiD Offline
                                dontobiD Offline
                                dontobi
                                #125
                                @moeff in deiner Fehlermeldung steht auch woran es liegt, nämlich am Token. Ich pushe im Laufe der Woche eine neue Version, die lediglich die 2er Serie unterstützt. Dann ist wenigstens eine stabile Version online.
                                • M moeff
                                  JensA
                                  #126
                                  @moeff
                                  Aha, dann war ich also mit den git Links durcheinander gekommen. Der Adapter von dontobi - https://github.com/dontobi/ioBroker.mihome-airpurifier (0.2.1) startet bei mir ohne Probleme. Beim Abspeichern der Konfiguration bekomme ich folgende Meldung: "Einige Daten wurden nicht gespeichert. Verwerfen?" Er scheint sich aber die Daten doch zu merken, zumindest sind sie beim erneuten Aufrufen der Konfiguration vollständig:
                                  Ich bekomme aber den Kontakt zum 2H nicht hin. Das Log sieht folgendermaßen aus:
                                  Kann ich beim Auslesen des Token über den vacuum adapter was falsch gemacht haben? (mehrfach gecheckt, keine Leerzeichen am Ende etc.)
                                  Ist vielleicht meine H2 Firmware nicht kompatibel?
                                  • J JensA
                                    @moeff
                                    dontobiD Offline
                                    dontobiD Offline
                                    dontobi
                                    #127
                                    @JensA stell den Adapter bitte Mal auf debug und starte ihn neu. Anschließend poste hier Mal das Log, dann sollten wir mehr wissen.
                                    • dontobiD dontobi
                                      JensA
                                      #128
                                      @dontobi
                                      Hier wie gewünscht:
                                      • J JensA
                                        @dontobi
                                        Hier wie gewünscht:
                                        dontobiD Offline
                                        dontobiD Offline
                                        dontobi
                                        #129
                                        @JensA an dem Token liegt es wahrscheinlich nicht. Ist die IP richtig?
                                        • dontobiD dontobi
                                          JensA
                                          #130
                                          @dontobi
                                          Ja, die IP stimmt. Die Daten aus dem vacuum adapter sehen so aus:
