  4. IoBroker mach nur noch Probleme
46 Beiträge 6 Kommentatoren 7.6k Aufrufe
  • E Offline
    Elektroman
    #41
    @apollon77:
    @Elektroman:
    was soll ich sagen, die Ram Probleme sind weg.
    Ich habe aber leider weiterhin Adapter die nicht mehr funktionieren u.a. "s7" bzw. Adapter die immer mal wieder neu starten (grün-rot-grün)
    host.raspberrypi	2018-10-11 18:39:59.376	error	instance system.adapter.s7.0 terminated with code 0 (OK)
    host.raspberrypi	2018-10-11 18:39:59.376	error	Caught by controller[0]: at Module._compile (module.js:577:32)
    host.raspberrypi	2018-10-11 18:39:59.376	error	Caught by controller[0]: at Object. <anonymous>(/opt/iobroker/node_modules/iobroker.s7/node_modules/node-snap7/lib/node-snap7.js:9:45)
    host.raspberrypi	2018-10-11 18:39:59.375	error	Caught by controller[0]: at bindings (/opt/iobroker/node_modules/iobroker.s7/node_modules/node-snap7/node_modules/bindings/bindings.js:76:44)
    host.raspberrypi	2018-10-11 18:39:59.375	error	Caught by controller[0]: at require (internal/module.js:20:19)
    host.raspberrypi	2018-10-11 18:39:59.375	error	Caught by controller[0]: at Module.require (module.js:504:17)
    host.raspberrypi	2018-10-11 18:39:59.374	error	Caught by controller[0]: at Function.Module._load (module.js:445:3)
    host.raspberrypi	2018-10-11 18:39:59.374	error	Caught by controller[0]: at tryModuleLoad (module.js:453:12)
    host.raspberrypi	2018-10-11 18:39:59.374	error	Caught by controller[0]: at Module.load (module.js:494:32)
    host.raspberrypi	2018-10-11 18:39:59.373	error	Caught by controller[0]: at Object.Module._extensions..node (module.js:604:18)
    host.raspberrypi	2018-10-11 18:39:59.373	error	Caught by controller[0]: at Error (native)
    host.raspberrypi	2018-10-11 18:39:59.372	error	Caught by controller[0]: Error: Module version mismatch. Expected 48, got 46.</anonymous>
    Kann es sein das du nodejs Update gemacht hast?
    Betroffenen Adapter Neu installieren sollte das fixen.
    Oder in das Verzeichnis des Adapters in node_modules und npm rebuild eingeben.
    Gesendet vom Handy … `
    Beim Master oder bei einem der Slaves?
    • apollon77A Offline
      #42
      Na da Wonder s7 Adapter installiert ist der da meckert …
      Gesendet vom Handy ...
      • E Offline
        Elektroman
        #43
        Neuer Tag neues Glück
        ich habe beim Master und bei einem der zwei Slave das Verzeichnis "iobroker.s7" vorhanden? Habe es bei beiden es ausgeführt
        • E Offline
          Elektroman
          #44
          Es sind mehrere Adapter 😢
          npm rebuild ergab keine Besserung
          host.ioBroker-Pi3-slave-sw	2018-10-12 18:40:39.388	info	Restart adapter system.adapter.admin.0 because enabled
          host.ioBroker-Pi3-slave-sw	2018-10-12 18:40:39.387	error	instance system.adapter.admin.0 terminated with code 7 (Adapter already running)
          host.ioBroker-Pi3-slave-sw	2018-10-12 18:40:38.401	info	Restart adapter system.adapter.hm-rega.0 because enabled
          host.ioBroker-Pi3-slave-sw	2018-10-12 18:40:38.401	error	instance system.adapter.hm-rega.0 terminated with code 7 (Adapter already running)
          host.ioBroker-Pi3-slave-sw	2018-10-12 18:40:36.886	info	instance system.adapter.hm-rega.0 started with pid 3386
          host.ioBroker-Pi3-slave-sw	2018-10-12 18:40:36.439	info	instance system.adapter.admin.0 started with pid 3380
          host.ioBroker-Pi3-slave-sw	2018-10-12 18:40:35.691	info	Restart adapter system.adapter.hm-rpc.0 because enabled
            #45
            npm rebuild von s7 sorgt erstmal nur dafür das s7 wieder tut … alles andere ist was anderes.
            Schau Die betroffenen Adapter an die mit error 7 gemeckert werden und kille die prozesse die da laufen oder mach nen reboot
            • E Offline
              Elektroman
              #46
              Ich bin gerade vorsichtig optimistisch. ;-)
              Habe vor ca. 3 Std einen reboot an allen Hosts durchgeführt, bis jetzt bleibt es ruhig
              Hat doch was gebracht, danke dafür
