  4. IoBroker.vis Android App
    6.8k
947 Beiträge 108 Kommentatoren 417.7k Aufrufe 17 Beobachtet
    pustekuchen
    #421
    @dtp:
    Hast Du 67 Views in einem Projekt? Das ist aber wirklich verdammt viel. `
    Ich habe viele Views durch die Verwendung des "view in widget"-Widgets. Die Strategie war: viele Views, aber dafür keine zu sehr "überladen".
    • BluefoxB Offline
      BluefoxB Offline
      #422
      Brauche wieder Übersetzung:
      ` > ### Battery and location
      There is a possibility to report position and battery status to server.
      • Device name - device name is used to create states on server (see below).
      • Report battery status - if battery status must be reported to server or not. Only changes of battery level or plugged state will be reported. No cyclic update.
      • Position poll interval (sec) - If position should be reported to server. Position is reported on change and cyclic. To disable report of position set interval to zero. (E.g. to save the battery)
      • High accuracy position - If position must be high accuracy or not. In high accuracy mode more battery drain.
      Following states will be created if battery status reporting is activated:
      • vis.0.<devicename>.battery.level - the battery charge percentage.
      • vis.0.<devicename>.battery.isPlugged - a boolean that indicates whether the device is plugged in.
      Battery status will be updated when the battery charge percentage changes by at least 1 percent, or when the device is plugged in or unplugged.
      Following states will be created if position poll interval is not zero:
      • vis.0.<devicename>.coords.latitude - latitude in decimal degrees.
      • vis.0.<devicename>.coords.longitude - longitude in decimal degrees.
      • vis.0.<devicename>.coords.accuracy - accuracy level of the latitude and longitude coordinates in meters.
      Following states are not available on all devices:
      • vis.0.<devicename>.coords.altitude - height of the position in meters above the ellipsoid.
      • vis.0.<devicename>.coords.altitudeAccuracy - accuracy level of the altitude coordinate in meters..
      • vis.0.<devicename>.coords.heading - direction of travel, specified in degrees counting clockwise relative to the true north.
      • vis.0.<devicename>.coords.speed - current ground speed of the device, specified in meters per second.
      • vis.0.<devicename>.coords.speedKm - current ground speed of the device, specified in km per hours.</devicename></devicename></devicename></devicename></devicename></devicename></devicename></devicename></devicename></devicename> `
        dtp
        #423
        Hilft das?
        ` > ### Batterie und Standort
        Es gibt eine Möglichkeit, dem Server die Position und den Batteriestatus zu melden.
        • Gerätename - Der Gerätename wird verwendet, um den Status auf dem Server zu erzeugen (siehe unten).
        • Melde Batteriestatus - Angabe, ob der Batteriestatus an den Server gemeldet werden soll, oder nicht. Nur Änderungen des Batteriestandes oder der angeschlossene Zustand der Batterie werden gemeldet; keine zyklische Aktualisierung.
        • Sendeintervall der Position (in Sekunden) - Angabe, ob die Postion an den Server gemeldet werden soll. Die Position wird sowohl nach einer Änderung als auch zyklisch übertragen. Um die Meldung der Position zu beenden, setze das Intervall auf Null (z.B. aus Energiespargründen).
        • Postion mit hoher Genauigkeit - Angabe, ob die Position mit hoher Genauigkeit erfolgen muss, oder nicht. Eine hohe Genauigkeit führt zu einem erhöhten Energieverbrauch.
        Die folgenden Zustände werden erzeugt, wenn eine Meldung des Batteriestatus aktiviert ist:
        • vis.0.<gerätename>.battery.level - Batterieladezustand in Prozent.
        • vis.0.<gerätename>.battery.isPlugged - Angabe als boolscher Wert, ob das Gerät angeschlossen ist.
        Der Batteriezustand wird aktualisiert, wenn sich der Ladezustand der Batterie um mindestens 1 % verändert oder wenn das Gerät angeschlossen oder abgesteckt wurde.
        Die folgenden Zustände werden erzeugt, wenn das Sendeintervall der Position nicht Null beträgt:
        • vis.0.<gerätename>.coords.latitude - Breitengrad als Dezimalwert.
        • vis.0.<gerätename>.coords.longitude - Längengrad als Dezimalwert.
        • vis.0.<gerätename>.coords.accuracy - Grad der Genauigkeit für Breiten- und Längengrad in Metern.
        Die folgenden Zustände sind nicht auf allen Geräten verfügbar:
        • vis.0.<gerätename>.coords.altitude - Höhe der Position über dem Referenzellipsoid in Metern.
        • vis.0.<gerätename>.coords.altitudeAccuracy - Genauigkeit der Höhe in Metern.
        • vis.0.<gerätename>.coords.heading - Bewegungsrichtung im Uhrzeigersinn bezogen auf den geographischen Norden in Grad.
        • vis.0.<gerätename>.coords.speed - aktuelle Geschwindigkeit des Geräts in m/s.
        • vis.0.<gerätename>.coords.speedKm - aktuelle Geschwindigkeit des Geräts in km/h.</gerätename></gerätename></gerätename></gerätename></gerätename></gerätename></gerätename></gerätename></gerätename></gerätename> `
        Gruß,
        Thorsten
          #424
          Hallo Thorsten,
          Gefällt mir ganz gut, bis auf:
          @dtp:
          • vis.0.<gerätename>.battery.isPlugged - Angabe als boolscher Wert, ob das Gerät angeschlossen ist.</gerätename> `
            …, ob der Netzstecker eingesteckt ist. (oder etwas sinnvolleres)
          @dtp:
          • vis.0.<gerätename>.coords.altitude - Höhe der Position über dem Referenzellipsoid in Metern.</gerätename> `
            Was um alles in der Welt ist ein referenzellipsoid????
          Gibt es da auch eine Bezeichnung die jeder versteht? Oder einfach Höhe der Position in Metern.
          Rainer
          • BluefoxB Offline
            BluefoxB Offline
            #425
            @dtp:
            Hilft das?
            Gruß,
            Thorsten `
            Cool. Super und danke.
              dtp
              #426
              Hallo Rainer!
              @Homoran:
              …, ob der Netzstecker eingesteckt ist. (oder etwas sinnvolleres) `
              Wie wär's mit: "…ob das Gerät mit dem Stromnetz verbunden ist."
              @Homoran:
              Gibt es da auch eine Bezeichnung die jeder versteht? Oder einfach Höhe der Position in Metern. `
              Da weiß ich leider nicht so genau, was Bluefox wirklich braucht. Hatte es daher versucht, 1:1 zu übersetzen. Es gibt durchaus Unterschiede zwischen dem Referenzellipsoid und der Höhe über Normalnull. Siehe https://de.wikipedia.org/wiki/Normalh%C3%B6hennull.
              Gruß,
              Thorsten
              • L Offline
                Lenz2k3
                #427
                Hab die App jetzt auch mal installiert bei meinen Schwiegereltern (Ich hab in dem Fall "leider" ein iPhone und komm da nicht in den Genuss).
                Großes Lob, es läuft alles super und genau wie man sich das vorstellt.
                Auch die Sprachsteuerung funktioniert blendent.
                Gibt es eigentlich eine Möglichkeit die Reichweite zu erhöhen? Externes Mikrofon oder ähnliches? Hat da wer Erfahrung?
                Viele Grüße,
                Lenz
                  dtp
                  #428
                  winkewinke
                  Würde mich über ein kleines Update der App zur Anzeige des http://forum.iobroker.net/viewtopic.php?f=30&t=3717 freuen. 8-)
                    dtp
                    #429
                    Kein Problem. Genieß die Wiesn.
                      dtp
                      #430
                      Hab gestern mal die Sprachsteuerung mit der App ausprobieren wollen. Problem war, dass sie nach Eingabe des - wie heißt das noch? - Auslöseworts und des text2command-Adapters sofort abstürzte und auch nicht mehr zur Mitarbeit zu bewegen war. Musste die App dann komplett deinstallieren, neu installieren und konfigurieren.
                      Bis dann,
                      Thorsten
                      • E Offline
                        eastcoast
                        #431
                        kann die App leider auf einem Gerät nicht installieren, im Store erscheint "Dein Gerät ist nicht mit dieser Version kompatibel."
                        Amaz0n Fire Tablet 7 Zoll
                        CyanogenMod-Version 12.1
                        Android-Version 5.1.1
                        • E Offline
                          eastcoast
                          #432
                          @eastcoast:
                          …im Store erscheint "Dein Gerät ist nicht mit dieser Version kompatibel."... `
                          Kann man irgendwo die APK der App downloaden damit ich die Kompatibilitätsprüfung umgehen kann?
                          • E Offline
                            eastcoast
                            #433
                            @eastcoast:
                            @eastcoast:
                            …im Store erscheint "Dein Gerät ist nicht mit dieser Version kompatibel."... Kann man irgendwo die APK der App downloaden damit ich die Kompatibilitätsprüfung umgehen kann?
                            …habe mir nun die APK auf einem anderen Gerät extrahiert und wollte diese installieren,
                            leider auch ohne Erfolg => Erhielt nur eine Meldung ohne Aussagekraft: "App wurde nicht installiert."
                            @Bluefox: Würde mich freuen falls Du Dir das bei Gelegenheit ansehen könntest ;)
                            • G Offline
                              Gregor
                              #434
                              ich nutze die App und habe ein Problem das, obwohl die Funktion "nicht einschlafen" aktiv ist denoch nach einiger Zeit die Views erst geladen werden müssen wenn das Tablet nicht länger benutzt wurde.
                              Das Tablet ist eine Wandmontage mit Tasker für Ladefunktion und Motion Detctor um das Tablet über die Fronkamera einzuschalten?
                              Hätte jemand einen Tipp was ich einstellen muß damit die App nicht in den Ruhemodus fällt?
                              • L Offline
                                Loomii
                                #435
                                Moin,
                                Habe auch dieses Problem wie eastcoast "gestern erst bemerkt".
                                "Ihr Gerät ist nicht kompatibel"
                                Habe noch die 0.5.2 version drauf.Habe es nur bemerkt weil ich text2command aktivieren wollten.
                                Probiere es auch mal die Version von meinen Handy zunehmen.
                                Tablet Android 4.4
                                Mfg
                                Sven
                                Debian Buster ,Node v12.19.0 NPM 6.14.8
                                Billig Tablet an der Wand Android 4.4 und VIS App
                                :mrgreen:
                                • G Offline
                                  Gregor
                                  #436
                                  @Gregor:
                                  Hätte jemand einen Tipp was ich einstellen muß damit die App nicht in den Ruhemodus fällt? `
                                  Guten Morgen zusammen,
                                  hat niemand eine Idee oder ist es noch bug ?
                                  Gregor
                                    rascal
                                    #437
                                    Much würde überhaupt interessieren, ob die vis App schon abgeschlossen ist oder nicht. Es wäre sehr schön, wenn sie zumindest 24 Stunden ohne Neustart bedienbar wäre, was sie anscheinend für viele noch nicht ist.
                                    Gesendet von meinem HUAWEI CRR-L09 mit Tapatalk
                                      #438
                                      Hallo rascal,
                                      ich kann jetzt dein posting leider nicht einordnen.
                                      Was willst du mit der APP machen, was sie nicht kann?
                                      Rainer
                                        dtp
                                        #439
                                        Also auf meinem Tablet läuft sie nun seit mehreren Wochen problemlos durch. Wenn der Connect einmal unterbrochen wurde (WLAN-Verbindung weg oder ioBroker neu gestartet), synchronisiert sich die App automatisch so lange neu, bis die Verbindung wieder hergestellt wurde. So merke ich in der Regel von einem Re-Sync nahezu nichts. Finde ich super gelöst und ist im Unterschied zu DashUI unter CCU.IO eine absolute Verbesserung.
                                        Ich bin sehr zufrieden mit der ioBroker.vis App in der aktuellen Version 0.7.1.
                                        Gruß,
                                        Thorsten
                                          rascal
                                          #440
                                          Ganz einfach nur views anzeigen, ohne dass sie träge und unbenutzbar wird. Das Problem habe ich allerdings nicht nur mit der App, sondern auch mit Browsern. Wie schon so oft erwähnt und diskutiert. Auch sockets only hilft da leider wenig
