  4. SQL-Fehlermeldung bei Neustart "Duplicate entry"
46 Beiträge 4 Kommentatoren 4.9k Aufrufe
    PrinzEisenherz1
    Hi zusammen,
    Ich hab auf meinem ProxMox eine VM für ioBroker und eine wo MariaDB 10 drauf läuft.
    Wenn ich den NUC mal neustarte dann erhalte ich im log massig an solchen Fehlermeldungen.
    2018-08-07 00:02:06.893  - [31merror[39m: sql.0 Cannot insert INSERT INTO `iobroker`.ts_number (id, ts, val, ack, _from, q) VALUES(67, 1533592926847, 19, 0, 5, 0);: Error: ER_DUP_ENTRY: Duplicate entry '67-1533592926847' for key 'PRIMARY'
    2018-08-07 00:02:06.919  - [31merror[39m: sql.0 Cannot insert INSERT INTO `iobroker`.ts_number (id, ts, val, ack, _from, q) VALUES(67, 1533592926848, 19, 0, 5, 0);: Error: ER_DUP_ENTRY: Duplicate entry '67-1533592926848' for key 'PRIMARY'
    2018-08-07 00:02:06.934  - [31merror[39m: sql.0 Cannot insert INSERT INTO `iobroker`.ts_number (id, ts, val, ack, _from, q) VALUES(65, 1533592926850, 19, 0, 5, 0);: Error: ER_DUP_ENTRY: Duplicate entry '65-1533592926850' for key 'PRIMARY'
    2018-08-07 00:02:06.934  - [31merror[39m: sql.0 Cannot insert INSERT INTO `iobroker`.ts_number (id, ts, val, ack, _from, q) VALUES(65, 1533592926849, 19, 0, 5, 0);: Error: ER_DUP_ENTRY: Duplicate entry '65-1533592926849' for key 'PRIMARY'
    2018-08-07 00:02:06.935  - [31merror[39m: sql.0 Cannot insert INSERT INTO `iobroker`.ts_number (id, ts, val, ack, _from, q) VALUES(65, 1533592926849, 19, 0, 5, 0);: Error: ER_DUP_ENTRY: Duplicate entry '65-1533592926849' for key 'PRIMARY'
    2018-08-07 00:02:06.946  - [31merror[39m: sql.0 Cannot insert INSERT INTO `iobroker`.ts_number (id, ts, val, ack, _from, q) VALUES(66, 1533592926860, 58.63, 0, 5, 0);: Error: ER_DUP_ENTRY: Duplicate entry '66-1533592926860' for key 'PRIMARY'
    2018-08-07 00:02:06.952  - [31merror[39m: sql.0 Cannot insert INSERT INTO `iobroker`.ts_number (id, ts, val, ack, _from, q) VALUES(66, 1533592926861, 58.63, 0, 5, 0);: Error: ER_DUP_ENTRY: Duplicate entry '66-1533592926861' for key 'PRIMARY'
    2018-08-07 00:02:06.953  - [31merror[39m: sql.0 Cannot insert INSERT INTO `iobroker`.ts_number (id, ts, val, ack, _from, q) VALUES(65, 1533592926850, 19, 0, 5, 0);: Error: ER_DUP_ENTRY: Duplicate entry '65-1533592926850' for key 'PRIMARY'
    2018-08-07 00:02:06.954  - [31merror[39m: sql.0 Cannot insert INSERT INTO `iobroker`.ts_number (id, ts, val, ack, _from, q) VALUES(64, 1533592926863, 58.63, 0, 5, 0);: Error: ER_DUP_ENTRY: Duplicate entry '64-1533592926863' for key 'PRIMARY'
    2018-08-07 00:02:06.955  - [31merror[39m: sql.0 Cannot insert INSERT INTO `iobroker`.ts_number (id, ts, val, ack, _from, q) VALUES(64, 1533592926862, 58.63, 0, 5, 0);: Error: ER_DUP_ENTRY: Duplicate entry '64-1533592926862' for key 'PRIMARY'
    2018-08-07 00:02:06.956  - [31merror[39m: sql.0 Cannot insert INSERT INTO `iobroker`.ts_number (id, ts, val, ack, _from, q) VALUES(64, 1533592926862, 58.63, 0, 5, 0);: Error: ER_DUP_ENTRY: Duplicate entry '64-1533592926862' for key 'PRIMARY'
    2018-08-07 00:02:06.961  - [31merror[39m: sql.0 Cannot insert INSERT INTO `iobroker`.ts_number (id, ts, val, ack, _from, q) VALUES(64, 1533592926863, 58.63, 0, 5, 0);: Error: ER_DUP_ENTRY: Duplicate entry '64-1533592926863' for key 'PRIMARY'
    Proxmox ist so eingestellt das zuerst die VM mit SQL gestartet wird und drei Minuten Später die VM für iobroker.
    Weiß jemand wieso diese Fehlermeldungen mit duplicate auflaufen?
    Oder soll ich die MariaDB lieber auf der gleichen VM laufen lassen wie ioBroker?
    Was meint ihr?
    Johnny
    Intel-NUC mit ProxMox: ioBroker,SQL, logging Strom- Gas- u. Wasserzähler;10Zoll Tab im Flur für VIS; weiteres: Homematic CCU2, Homeduino, Kameras, selbstgebaute Wetterstation;
    • apollon77A Offline
      Der Fehler kommt weil (warum auch immer) er für eine ID und einen Timestamp mehrfach Werte loggen will … Man müsste jetzt rausfinden warum das passiert ...
        PrinzEisenherz1
        hmmm…das ist jetzt ne gute Frage warum er das machen will.
        Wie würde ich denn das am besten rausbekommen?
        Johnny
          Instanz mal auf Loglevel Debug stellen und Log posten
            PrinzEisenherz1
            so, hier mal ein auszug aus m log
            sql.0	2018-08-07 16:04:06.630	debug	SELECT id, type, name FROM `iobroker`.datapoints WHERE name='javascript.0.IntelNUC.Temp-Core0';
            sql.0	2018-08-07 16:04:06.630	debug	Type (from State) for javascript.0.IntelNUC.Temp-Core0: 0
            sql.0	2018-08-07 16:04:06.616	debug	Type set in Def for javascript.0.IntelNUC.Temp-Core0: undefined
            sql.0	2018-08-07 16:04:06.616	debug	Type (from Obj) for javascript.0.IntelNUC.Temp-Core0: undefined
            sql.0	2018-08-07 16:04:06.616	debug	mixed / undefined / {"name":"Systemtemperatur Core-0","unit":"°C","role":"javascript","type":"mixed","custom":{"sql.0":{"enabled":true,"changesOnly":true,"debounce":"5000","maxLength":10,"retention":"
            sql.0	2018-08-07 16:04:06.614	debug	Type set in Def for javascript.0.IntelNUC.Temp-Core0: false
            sql.0	2018-08-07 16:04:06.614	debug	Datatype javascript.0.IntelNUC.Temp-Core0: Currently: number, StorageType: false
            sql.0	2018-08-07 16:04:06.535	debug	INSERT INTO `iobroker`.ts_number (id, ts, val, ack, _from, q) VALUES(303, 1533650641391, 0.22, 0, 7, 0);
            sql.0	2018-08-07 16:04:06.535	info	changed history configuration to pin detected datatype for javascript.0.IntelNUC.VM-ioBroker.load15Min
            sql.0	2018-08-07 16:04:06.528	error	Cannot insert INSERT INTO `iobroker`.ts_number (id, ts, val, ack, _from, q) VALUES(303, 1533650641389, 0.22, 0, 7, 0);: Error: ER_DUP_ENTRY: Duplicate entry '303-1533650641389' for key 'PRIMARY'
            sql.0	2018-08-07 16:04:06.525	error	Cannot delete DELETE FROM `iobroker`.undefined WHERE id=303 AND ts < 1530972240511;: Error: ER_NO_SUCH_TABLE: Table 'iobroker.undefined' doesn't exist
            sql.0	2018-08-07 16:04:06.522	debug	INSERT INTO `iobroker`.ts_number (id, ts, val, ack, _from, q) VALUES(303, 1533650641390, 0.22, 0, 7, 0);
            sql.0	2018-08-07 16:04:06.522	debug	Type (from DB-Type) for javascript.0.IntelNUC.VM-ioBroker.load15Min: 0
            sql.0	2018-08-07 16:04:06.522	debug	Type set in Def for javascript.0.IntelNUC.VM-ioBroker.load15Min: undefined
            sql.0	2018-08-07 16:04:06.522	debug	Type (from Obj) for javascript.0.IntelNUC.VM-ioBroker.load15Min: undefined
            sql.0	2018-08-07 16:04:06.522	debug	mixed / undefined / {"name":"System-load 15-Min","role":"javascript","type":"mixed","custom":{"sql.0":{"enabled":true,"changesOnly":true,"debounce":"5000","maxLength":10,"retention":"2678400","changes
            sql.0	2018-08-07 16:04:06.522	debug	INSERT INTO `iobroker`.ts_number (id, ts, val, ack, _from, q) VALUES(303, 1533650641389, 0.22, 0, 7, 0);
            sql.0	2018-08-07 16:04:06.522	debug	Type (from State) for javascript.0.IntelNUC.VM-ioBroker.load15Min: 0
            sql.0	2018-08-07 16:04:06.522	debug	UPDATE `iobroker`.datapoints SET type = 0 WHERE id = 303;
            sql.0	2018-08-07 16:04:06.521	debug	Type (from State) for javascript.0.IntelNUC.VM-ioBroker.load15Min: 0
            sql.0	2018-08-07 16:04:06.521	error	Cannot insert INSERT INTO `iobroker`.ts_number (id, ts, val, ack, _from, q) VALUES(303, 1533650641388, 0.22, 0, 7, 0);: Error: ER_DUP_ENTRY: Duplicate entry '303-1533650641388' for key 'PRIMARY'
            sql.0	2018-08-07 16:04:06.521	debug	DELETE FROM `iobroker`.undefined WHERE id=303 AND ts < 1530972240511;
            sql.0	2018-08-07 16:04:06.501	error	Cannot insert INSERT INTO `iobroker`.ts_string (id, ts, val, ack, _from, q) VALUES(300, 1533650641340, '2,8', 0, 7, 0);: Error: ER_DUP_ENTRY: Duplicate entry '300-1533650641340' for key 'PRIMARY'
            sql.0	2018-08-07 16:04:06.501	error	Cannot insert INSERT INTO `iobroker`.ts_number (id, ts, val, ack, _from, q) VALUES(302, 1533650641374, 0.17, 0, 7, 0);: Error: ER_DUP_ENTRY: Duplicate entry '302-1533650641374' for key 'PRIMARY'
            sql.0	2018-08-07 16:04:06.501	debug	Type set in Def for javascript.0.IntelNUC.VM-ioBroker.load15Min: undefined
            sql.0	2018-08-07 16:04:06.501	debug	Type (from Obj) for javascript.0.IntelNUC.VM-ioBroker.load15Min: undefined
            sql.0	2018-08-07 16:04:06.501	debug	mixed / undefined / {"name":"System-load 15-Min","role":"javascript","type":"mixed","custom":{"sql.0":{"enabled":true,"changesOnly":true,"debounce":"5000","maxLength":10,"retention":"2678400","changes
            sql.0	2018-08-07 16:04:06.501	error	Cannot insert INSERT INTO `iobroker`.ts_number (id, ts, val, ack, _from, q) VALUES(302, 1533650641373, 0.17, 0, 7, 0);: Error: ER_DUP_ENTRY: Duplicate entry '302-1533650641373' for key 'PRIMARY'
            sql.0	2018-08-07 16:04:06.501	debug	INSERT INTO `iobroker`.ts_number (id, ts, val, ack, _from, q) VALUES(303, 1533650641388, 0.22, 0, 7, 0);
            sql.0	2018-08-07 16:04:06.501	debug	INSERT INTO `iobroker`.ts_number (id, ts, val, ack, _from, q) VALUES(303, 1533650641389, 0.22, 0, 7, 0);
            sql.0	2018-08-07 16:04:06.501	debug	INSERT INTO `iobroker`.ts_number (id, ts, val, ack, _from, q) VALUES(302, 1533650641375, 0.17, 0, 7, 0);
            sql.0	2018-08-07 16:04:06.501	info	changed history configuration to pin detected datatype for javascript.0.IntelNUC.VM-ioBroker.load5Min
            sql.0	2018-08-07 16:04:06.501	error	Cannot insert INSERT INTO `iobroker`.ts_number (id, ts, val, ack, _from, q) VALUES(301, 1533650641355, 0.12, 0, 7, 0);: Error: ER_DUP_ENTRY: Duplicate entry '301-1533650641355' for key 'PRIMARY'
            sql.0	2018-08-07 16:04:06.501	debug	DELETE FROM `iobroker`.ts_number WHERE id=302 AND ts < 1530972240481;
            sql.0	2018-08-07 16:04:06.500	debug	INSERT INTO `iobroker`.ts_number (id, ts, val, ack, _from, q) VALUES(301, 1533650641356, 0.12, 0, 7, 0);
            sql.0	2018-08-07 16:04:06.500	info	changed history configuration to pin detected datatype for javascript.0.IntelNUC.VM-ioBroker.load1Min
            sql.0	2018-08-07 16:04:06.500	debug	Type (from State) for javascript.0.IntelNUC.VM-ioBroker.load15Min: 0
            sql.0	2018-08-07 16:04:06.500	error	Cannot insert INSERT INTO `iobroker`.ts_number (id, ts, val, ack, _from, q) VALUES(301, 1533650641354, 0.12, 0, 7, 0);: Error: ER_DUP_ENTRY: Duplicate entry '301-1533650641354' for key 'PRIMARY'
            sql.0	2018-08-07 16:04:06.447	debug	INSERT INTO `iobroker`.ts_string (id, ts, val, ack, _from, q) VALUES(300, 1533650641340, '2,8', 0, 7, 0);
            sql.0	2018-08-07 16:04:06.447	info	changed history configuration to pin detected datatype for javascript.0.IntelNUC.VM-ioBroker.StorageUsed
            sql.0	2018-08-07 16:04:06.447	debug	Type set in Def for javascript.0.IntelNUC.VM-ioBroker.load15Min: undefined
            sql.0	2018-08-07 16:04:06.447	debug	Type (from Obj) for javascript.0.IntelNUC.VM-ioBroker.load15Min: undefined
            sql.0	2018-08-07 16:04:06.447	debug	mixed / undefined / {"name":"System-load 15-Min","role":"javascript","type":"mixed","custom":{"sql.0":{"enabled":true,"changesOnly":true,"debounce":"5000","maxLength":10,"retention":"2678400","changes
            sql.0	2018-08-07 16:04:06.447	debug	INSERT INTO `iobroker`.ts_number (id, ts, val, ack, _from, q) VALUES(302, 1533650641374, 0.17, 0, 7, 0);
            sql.0	2018-08-07 16:04:06.447	debug	Type (from DB-Type) for javascript.0.IntelNUC.VM-ioBroker.load5Min: 0
            sql.0	2018-08-07 16:04:06.447	debug	Type set in Def for javascript.0.IntelNUC.VM-ioBroker.load5Min: undefined
            sql.0	2018-08-07 16:04:06.447	debug	Type (from Obj) for javascript.0.IntelNUC.VM-ioBroker.load5Min: undefined
            sql.0	2018-08-07 16:04:06.447	debug	mixed / undefined / {"name":"System-load 5-Min","role":"javascript","type":"mixed","custom":{"sql.0":{"enabled":true,"changesOnly":true,"debounce":"5000","maxLength":10,"retention":"2678400","changesR
            sql.0	2018-08-07 16:04:06.447	error	Cannot insert INSERT INTO `iobroker`.ts_string (id, ts, val, ack, _from, q) VALUES(300, 1533650641339, '2,8', 0, 7, 0);: Error: ER_DUP_ENTRY: Duplicate entry '300-1533650641339' for key 'PRIMARY'
            sql.0	2018-08-07 16:04:06.447	error	Cannot insert INSERT INTO `iobroker`.ts_number (id, ts, val, ack, _from, q) VALUES(301, 1533650641355, 0.12, 0, 7, 0);: Error: ER_DUP_ENTRY: Duplicate entry '301-1533650641355' for key 'PRIMARY'
            sql.0	2018-08-07 16:04:06.447	error	Cannot insert INSERT INTO `iobroker`.ts_number (id, ts, val, ack, _from, q) VALUES(301, 1533650641354, 0.12, 0, 7, 0);: Error: ER_DUP_ENTRY: Duplicate entry '301-1533650641354' for key 'PRIMARY'
            sql.0	2018-08-07 16:04:06.447	debug	DELETE FROM `iobroker`.ts_number WHERE id=301 AND ts < 1530972240424;
            sql.0	2018-08-07 16:04:06.447	debug	Type (from State) for javascript.0.IntelNUC.VM-ioBroker.load15Min: 0
            sql.0	2018-08-07 16:04:06.447	debug	INSERT INTO `iobroker`.ts_number (id, ts, val, ack, _from, q) VALUES(302, 1533650641373, 0.17, 0, 7, 0);
            sql.0	2018-08-07 16:04:06.447	debug	Type (from State) for javascript.0.IntelNUC.VM-ioBroker.load5Min: 0
            sql.0	2018-08-07 16:04:06.447	debug	SELECT id, type, name FROM `iobroker`.datapoints WHERE name='javascript.0.IntelNUC.VM-ioBroker.load15Min';
            sql.0	2018-08-07 16:04:06.447	debug	UPDATE `iobroker`.datapoints SET type = 0 WHERE id = 302;
            sql.0	2018-08-07 16:04:06.446	debug	Type (from State) for javascript.0.IntelNUC.VM-ioBroker.load5Min: 0
            sql.0	2018-08-07 16:04:06.446	debug	INSERT INTO `iobroker`.ts_number (id, ts, val, ack, _from, q) VALUES(301, 1533650641355, 0.12, 0, 7, 0);
            sql.0	2018-08-07 16:04:06.446	debug	Type (from State) for javascript.0.IntelNUC.VM-ioBroker.load1Min: 0
            sql.0	2018-08-07 16:04:06.446	error	Cannot insert INSERT INTO `iobroker`.ts_number (id, ts, val, ack, _from, q) VALUES(299, 1533650641318, 27, 0, 7, 0);: Error: ER_DUP_ENTRY: Duplicate entry '299-1533650641318' for key 'PRIMARY'
            sql.0	2018-08-07 16:04:06.446	debug	INSERT INTO `iobroker`.ts_number (id, ts, val, ack, _from, q) VALUES(302, 1533650641374, 0.17, 0, 7, 0);
            sql.0	2018-08-07 16:04:06.446	debug	INSERT INTO `iobroker`.ts_number (id, ts, val, ack, _from, q) VALUES(302, 1533650641373, 0.17, 0, 7, 0);
            sql.0	2018-08-07 16:04:06.446	debug	Type set in Def for javascript.0.IntelNUC.VM-ioBroker.load15Min: undefined
            sql.0	2018-08-07 16:04:06.446	debug	Type (from Obj) for javascript.0.IntelNUC.VM-ioBroker.load15Min: undefined
            sql.0	2018-08-07 16:04:06.446	debug	mixed / undefined / {"name":"System-load 15-Min","role":"javascript","type":"mixed","custom":{"sql.0":{"enabled":true,"changesOnly":true,"debounce":"5000","maxLength":10,"retention":"2678400","changes
            sql.0	2018-08-07 16:04:06.446	debug	Type set in Def for javascript.0.IntelNUC.VM-ioBroker.load5Min: undefined
            sql.0	2018-08-07 16:04:06.446	debug	Type (from Obj) for javascript.0.IntelNUC.VM-ioBroker.load5Min: undefined
            sql.0	2018-08-07 16:04:06.446	debug	mixed / undefined / {"name":"System-load 5-Min","role":"javascript","type":"mixed","custom":{"sql.0":{"enabled":true,"changesOnly":true,"debounce":"5000","maxLength":10,"retention":"2678400","changesR
            sql.0	2018-08-07 16:04:06.446	debug	INSERT INTO `iobroker`.ts_number (id, ts, val, ack, _from, q) VALUES(301, 1533650641354, 0.12, 0, 7, 0);
            sql.0	2018-08-07 16:04:06.446	debug	Type (from DB-Type) for javascript.0.IntelNUC.VM-ioBroker.load1Min: 0
            sql.0	2018-08-07 16:04:06.446	debug	Type set in Def for javascript.0.IntelNUC.VM-ioBroker.load1Min: undefined
            sql.0	2018-08-07 16:04:06.446	debug	Type (from Obj) for javascript.0.IntelNUC.VM-ioBroker.load1Min: undefined
            sql.0	2018-08-07 16:04:06.446	debug	mixed / undefined / {"name":"System-load 1-Min","role":"javascript","type":"mixed","custom":{"sql.0":{"enabled":true,"changesOnly":true,"debounce":"5000","maxLength":10,"retention":"2678400","changesR
            sql.0	2018-08-07 16:04:06.446	error	Cannot insert INSERT INTO `iobroker`.ts_string (id, ts, val, ack, _from, q) VALUES(300, 1533650641340, '2,8', 0, 7, 0);: Error: ER_DUP_ENTRY: Duplicate entry '300-1533650641340' for key 'PRIMARY'
            sql.0	2018-08-07 16:04:06.446	error	Cannot insert INSERT INTO `iobroker`.ts_string (id, ts, val, ack, _from, q) VALUES(300, 1533650641339, '2,8', 0, 7, 0);: Error: ER_DUP_ENTRY: Duplicate entry '300-1533650641339' for key 'PRIMARY'
            sql.0	2018-08-07 16:04:06.446	debug	DELETE FROM `iobroker`.ts_string WHERE id=300 AND ts < 1530972240406;
            sql.0	2018-08-07 16:04:06.446	debug	UPDATE `iobroker`.datapoints SET type = 0 WHERE id = 301;
            sql.0	2018-08-07 16:04:06.446	debug	Type set in Def for javascript.0.IntelNUC.VM-ioBroker.load15Min: false
            sql.0	2018-08-07 16:04:06.446	debug	Datatype javascript.0.IntelNUC.VM-ioBroker.load15Min: Currently: number, StorageType: false
            sql.0	2018-08-07 16:04:06.445	debug	Type (from Obj) for javascript.0.IntelNUC.VM-ioBroker.load1Min: undefined
            sql.0	2018-08-07 16:04:06.445	debug	mixed / undefined / {"name":"System-load 1-Min","role":"javascript","type":"mixed","custom":{"sql.0":{"enabled":true,"changesOnly":true,"debounce":"5000","maxLength":10,"retention":"2678400","changesR
            sql.0	2018-08-07 16:04:06.445	debug	INSERT INTO `iobroker`.ts_string (id, ts, val, ack, _from, q) VALUES(300, 1533650641339, '2,8', 0, 7, 0);
            sql.0	2018-08-07 16:04:06.445	debug	Type (from DB-Type) for javascript.0.IntelNUC.VM-ioBroker.StorageUsed: 1
            sql.0	2018-08-07 16:04:06.445	debug	Type set in Def for javascript.0.IntelNUC.VM-ioBroker.StorageUsed: undefined
            sql.0	2018-08-07 16:04:06.445	debug	Type (from Obj) for javascript.0.IntelNUC.VM-ioBroker.StorageUsed: undefined
            sql.0	2018-08-07 16:04:06.445	debug	mixed / undefined / {"name":"HDD-Speicher Verbraucht","unit":"GByte","role":"javascript","type":"mixed","custom":{"sql.0":{"enabled":true,"changesOnly":true,"debounce":"5000","maxLength":10,"retention
            sql.0	2018-08-07 16:04:06.445	debug	INSERT INTO `iobroker`.ts_number (id, ts, val, ack, _from, q) VALUES(301, 1533650641355, 0.12, 0, 7, 0);
            sql.0	2018-08-07 16:04:06.445	debug	INSERT INTO `iobroker`.ts_number (id, ts, val, ack, _from, q) VALUES(301, 1533650641354, 0.12, 0, 7, 0);
            sql.0	2018-08-07 16:04:06.445	debug	INSERT INTO `iobroker`.ts_number (id, ts, val, ack, _from, q) VALUES(299, 1533650641318, 27, 0, 7, 0);
            sql.0	2018-08-07 16:04:06.445	info	changed history configuration to pin detected datatype for javascript.0.IntelNUC.VM-ioBroker.StorageFree
            sql.0	2018-08-07 16:04:06.445	error	Cannot insert INSERT INTO `iobroker`.ts_number (id, ts, val, ack, _from, q) VALUES(298, 1533650641285, 0.962891, 0, 7, 0);: Error: ER_DUP_ENTRY: Duplicate entry '298-1533650641285' for key 'PRIMARY'
            sql.0	2018-08-07 16:04:06.445	debug	SELECT id, type, name FROM `iobroker`.datapoints WHERE name='javascript.0.IntelNUC.VM-ioBroker.load5Min';
            sql.0	2018-08-07 16:04:06.445	debug	Type (from State) for javascript.0.IntelNUC.VM-ioBroker.load5Min: 0
            sql.0	2018-08-07 16:04:06.445	debug	Type (from State) for javascript.0.IntelNUC.VM-ioBroker.load1Min: 0
            sql.0	2018-08-07 16:04:06.445	debug	UPDATE `iobroker`.datapoints SET type = 1 WHERE id = 300;
            sql.0	2018-08-07 16:04:06.445	debug	Type (from State) for javascript.0.IntelNUC.VM-ioBroker.StorageUsed: 1
            sql.0	2018-08-07 16:04:06.445	error	Cannot insert INSERT INTO `iobroker`.ts_number (id, ts, val, ack, _from, q) VALUES(299, 1533650641317, 27, 0, 7, 0);: Error: ER_DUP_ENTRY: Duplicate entry '299-1533650641317' for key 'PRIMARY'
            sql.0	2018-08-07 16:04:06.445	debug	Type set in Def for javascript.0.IntelNUC.VM-ioBroker.load5Min: undefined
            sql.0	2018-08-07 16:04:06.445	debug	Type (from Obj) for javascript.0.IntelNUC.VM-ioBroker.load5Min: undefined
            sql.0	2018-08-07 16:04:06.445	debug	mixed / undefined / {"name":"System-load 5-Min","role":"javascript","type":"mixed","custom":{"sql.0":{"enabled":true,"changesOnly":true,"debounce":"5000","maxLength":10,"retention":"2678400","changesR
            sql.0	2018-08-07 16:04:06.445	debug	Type set in Def for javascript.0.IntelNUC.VM-ioBroker.load1Min: undefined
            sql.0	2018-08-07 16:04:06.445	debug	INSERT INTO `iobroker`.ts_string (id, ts, val, ack, _from, q) VALUES(300, 1533650641340, '2,8', 0, 7, 0);
              PrinzEisenherz1
              Konntest du was erkennen?
              Gruß Johnny
                Auszug zu kurz. Am besten wirklich starten mit dem Start vom Adapter und dann bis der ganze initiale Kram durch ist.
                Gesendet vom Handy …
                  PrinzEisenherz1
                  So Apollon, hier der log ab dem Moment wo ich den sql Adapter auf debug gestellt habe, bis zu dem Zeitpunkt wo sich die sache mit den errors beruhigt hat.
                  1058_iobroker.2018-08-08.log
                  Ich hoffe Du finest was raus!?!?
                  Johnny
                    PrinzEisenherz1
                    Apollon hattest Du schon mal n Minütchen wo Du den log ansehen konntest?
                    Hast Du was entdeckt?
                    Johnny
                      Nope noch keine Zeit gehabt
                      • StabilostickS Offline
                        Stabilostick
                        Die Datenbank irrt hier nicht:
                        Zuerst:
                        INSERT INTO ts_number .... VALUES(107, 1533758018663, 22.98, 0, 7, 0);
                        INSERT INTO ts_number .... VALUES(107, 1533758018664, 22.98, 0, 7, 0);
                        INSERT INTO ts_number .... VALUES(168, 1533758018668, 22.98, 0, 5, 0);
                        INSERT INTO ts_number .... VALUES(168, 1533758018669, 22.98, 0, 5, 0);
                        dann kommt
                        changed history configuration to pin detected datatype ...
                        ````für die verschiedenen Datenpunkte und dann gleich darauf:
                        DELETE FROM ts_number WHERE id=107 AND ts < 1502221980756;
                        INSERT INTO ts_number .... VALUES(107, 1533758018663, 22.98, 0, 7, 0);: Error: ER_DUP_ENTRY: Duplicate entry '107-1533758018663' for key 'PRIMARY'
                        INSERT INTO ts_number .... VALUES(107, 1533758018664, 22.98, 0, 7, 0);: Error: ER_DUP_ENTRY: Duplicate entry '107-1533758018664' for key 'PRIMARY'
                        INSERT INTO ts_number .... VALUES(168, 1533758018669, 22.98, 0, 5, 0);: Error: ER_DUP_ENTRY: Duplicate entry '168-1533758018669' for key 'PRIMARY'
                        DELETE FROM ts_number WHERE id=168 AND ts < 1502221980762;
                        INSERT INTO ts_number .... VALUES(168, 1533758018668, 22.98, 0, 5, 0);: Error: ER_DUP_ENTRY: Duplicate entry '168-1533758018668' for key 'PRIMARY'
                        Hmm, das Delete ist um ein Jahr nach vorne verschoben … 08.08.2017 21:53:01
                        Kannst Du zur Vollständigkeit das JavaScript posten, das die Werte setzt?
                          Das ist ein Timing-Issue in der Initialisierung. Soweit bin ich schon …
                          Das Problem ist das Dinge noch nicht sauber initialisiert sind (sql calls sind halt asynchron) aber dann schnell Werte reinkommen. Und dann passieren komische Dinge ...
                          Mal warten bitte
                            So, bitte mal die 1.9.3 vom Github installieren, instanz neustarten (mit Debug an wieder) und mir in jedem Fall das Log schicken/posten.
                            jetzt besser?
                              PrinzEisenherz1
                              Hab das update durchgeführt und den Adapter auf debugging gestellt. bis jetzt keine Verbesserung. Was mir aber aufgefallen ist, auf den ersten blick sind das alles Fehlermeldungen von Statusänderungen durch z.b. Arduinos die über simple api senden (http://<ip-adresse>:8082/set/javascript.0.xxxxxx)
                              hier mal das log-File
                              1058_iobroker.2018-08-10.log
                              Johnny</ip-adresse>
                                Stabilostick
                                javascript.0.IntelNUC.*
                                  PrinzEisenherz1
                                  Das ist kein Javascript sondern ein bash-script auf dem Proxmox
                                  Der vollständigkeithalber
                                  #!/bin/sh
                                  ### Scriptname:                sysinfo.sh
                                  ### Kurzbeschreibung:      Ermitteln von Systemwerten InterlNUC root-System und überträgt an ioBroker
                                  ### Ersteller:                    Prinzeisenherz1 (Schneider Johnny) am 24072018
                                  ### Lokale Variablen anlegen
                                  ioBrokerIP="192.168.178.2:8082"
                                  echo "ip "$ioBrokerIP
                                  URL_set_StorageTotal="http://"$ioBrokerIP"/set/javascript.0.IntelNUC.VM-ioBroker.StorageTotal?value="
                                  URL_set_StorageFree="http://"$ioBrokerIP"/set/javascript.0.IntelNUC.VM-ioBroker.StorageFree?value="
                                  URL_set_StorageUsed="http://"$ioBrokerIP"/set/javascript.0.IntelNUC.VM-ioBroker.StorageUsed?value="
                                  URL_set_MemTotal="http://"$ioBrokerIP"/set/javascript.0.IntelNUC.VM-ioBroker.MemTotal?value="
                                  URL_set_MemFree="http://"$ioBrokerIP"/set/javascript.0.IntelNUC.VM-ioBroker.MemFree?value="
                                  URL_set_MemUsed="http://"$ioBrokerIP"/set/javascript.0.IntelNUC.VM-ioBroker.MemUsed?value="
                                  URL_set_load1Min="http://"$ioBrokerIP"/set/javascript.0.IntelNUC.VM-ioBroker.load1Min?value="
                                  URL_set_load5Min="http://"$ioBrokerIP"/set/javascript.0.IntelNUC.VM-ioBroker.load5Min?value="
                                  URL_set_load15Min="http://"$ioBrokerIP"/set/javascript.0.IntelNUC.VM-ioBroker.load15Min?value="
                                  URL_set_Uptime_day="http://"$ioBrokerIP"/set/javascript.0.IntelNUC.VM-ioBroker.UptimeDay?value="
                                  URL_set_Uptime_hour="http://"$ioBrokerIP"/set/javascript.0.IntelNUC.VM-ioBroker.UptimeHour?value="
                                  ### Gesamtspeicherplatz Arbeitsspeicher in Gigabyte ermitteln und an die ioBroker übertragen
                                  tmp2=$(free -m | awk '{print $2/1024}' | sed -n '2p' | sed 's/G//g')
                                  ### Freier Speicherplatz Arbeitsspeicher in Gigabyte ermitteln und an die ioBroker übertragen
                                  tmp3=$(free -m | awk '{print $4/1024}' | sed -n '2p' | sed 's/G//g')
                                  ### Belegter Speicherplatz Arbeitsspeicher in Gigabyte ermitteln und an die ioBroker übertragen
                                  tmp4=$(free -m | awk '{print $3/1024}' | sed -n '2p' | sed 's/G//g')
                                  ### Gesamtspeicherplatz Datenträger in Gigabyte ermitteln und an die ioBroker übertragen
                                  tmp10=$(df -H | awk '{print $2}' | sed -n '4p' | sed 's/G//g')
                                  ### Freier Speicherplatz Datenträger in Gigabyte ermitteln und an die ioBroker übertragen
                                  tmp11=$(df -H | awk '{print $4}' | sed -n '4p' | sed 's/G//g')
                                  ### Belegter Speicherplatz Datenträger in Gigabyte ermitteln und an die ioBroker übertragen
                                  tmp12=$(df -H | awk '{print $3}' | sed -n '4p' | sed 's/G//g')
                                  ### Systemload 1-Min ermitteln und an die ioBroker übertragen
                                  tmp5=$(cat /proc/loadavg | awk '{print $1}')
                                  ### Systemload 5-Min ermitteln und an die ioBroker übertragen
                                  tmp6=$(cat /proc/loadavg | awk '{print $2}')
                                  ### Systemload 15-Min ermitteln und an die ioBroker übertragen
                                  tmp7=$(cat /proc/loadavg | awk '{print $3}')
                                  ### UpTime in Tage und Stunden ermitteln und an ioBroker übertragen
                                  tmp8=$(cat /proc/uptime | awk '{printf"%.0f\n", $1}')
                                  days=$(($tmp8 / 86400 ))
                                  hours=$((($tmp8 / 3600) - (days * 24)))
                                  ####### Sende Gesamtspeicherplatz in Gigabyte an ioBroker
                                  url_tmp2=$URL_set_MemTotal$tmp2
                                  echo "$url_tmp2"
                                  curl -s $url_tmp2 > /dev/null 2>&1
                                  ####### Sende freien Speicherplatz in Gigabyte an ioBroker
                                  url_tmp3=$URL_set_MemFree$tmp3
                                  echo "$url_tmp3"
                                  curl -s $url_tmp3 > /dev/null 2>&1
                                  ####### Sende belegter Speicherplatz in Gigabyte an ioBroker
                                  url_tmp4=$URL_set_MemUsed$tmp4
                                  echo "$url_tmp4"
                                  curl -s $url_tmp4 > /dev/null 2>&1
                                  url_tmp10=$URL_set_StorageTotal$tmp10
                                  echo "$url_tmp10"
                                  curl -s $url_tmp10 > /dev/null 2>&1
                                  url_tmp11=$URL_set_StorageFree$tmp11
                                  echo "$url_tmp11"
                                  curl -s $url_tmp11 > /dev/null 2>&1
                                  url_tmp12=$URL_set_StorageUsed$tmp12
                                  echo "$url_tmp12"
                                  curl -s $url_tmp12 > /dev/null 2>&1
                                  ####### Sende freien Speicherplatz in Prozent an ioBroker
                                  url_tmp5=$URL_set_load1Min$tmp5
                                  echo "$url_tmp5"
                                  curl -s $url_tmp5 > /dev/null 2>&1
                                  ####### Sende belegter Speicherplatz in Prozent an ioBroker
                                  url_tmp6=$URL_set_load5Min$tmp6
                                  echo "$url_tmp6"
                                  curl -s $url_tmp6 > /dev/null 2>&1
                                  url_tmp7=$URL_set_load15Min$tmp7
                                  echo "$url_tmp7"
                                  curl -s $url_tmp7 > /dev/null 2>&1
                                  ####### Sende UpTime an ioBroker
                                  url_days=$URL_set_Uptime_day$days
                                  echo "$url_days"
                                  curl -s $url_days > /dev/null 2>&1
                                  url_hours=$URL_set_Uptime_hour$hours
                                  echo "$url_hours"
                                  curl -s $url_hours > /dev/null 2>&1
                                  Johnny
                                    PrinzEisenherz1
                                    Hab mal auf Version 1.6.1 downgegraded und da gibt es die Probleme nicht!
                                    Johnny
                                      Hi, sorry für die Wartezeit … bitte versuch die Github Version nochmal. Habe noch was gefunden.
                                      Zuerst wurden alle Typen und Indizes aus der DB eingelesen nur um das dann grad wieder zu überschreiben :-)
                                      Wenn immer noch blöd dann bitte wieder log.
                                      Das muss zu fixen sein :-)
                                        @PrinzEisenherz1: kamst Du schon zum testen der Github Version?
                                        • SegwayS Offline
                                          SegwayS Offline
                                          Segway
                                          @Apollon77:
                                          Habe ebenso das Problem mit Duplicate Entry mit meiner NAS SQL-DB.
                                          Bin auch an der Lösung interessiert. Habe mir mal ein Lesezeichen gesetzt.
                                          2018-08-20 06:25:28.243  - [31merror[39m: sql.0 Cannot insert INSERT INTO `iobroker`.ts_bool (id, ts, val, ack, _from, q) VALUES(1760, 1970000, false, 1, 4, 0);: Error: ER_DUP_ENTRY: Duplicate entry '1760-1970000' for key 'PRIMARY'
                                          oder möchtest du das ich das teste ? habe aber kein Testsystem, kann ich nur auf meinem Prod. System machen.
                                          Gruß Dirk
