  4. SQL-Fehlermeldung bei Neustart "Duplicate entry"
46 Beiträge 4 Kommentatoren 4.9k Aufrufe
  • P Offline
    PrinzEisenherz1
    so, hier mal ein auszug aus m log
    sql.0	2018-08-07 16:04:06.630	debug	SELECT id, type, name FROM `iobroker`.datapoints WHERE name='javascript.0.IntelNUC.Temp-Core0';
    sql.0	2018-08-07 16:04:06.630	debug	Type (from State) for javascript.0.IntelNUC.Temp-Core0: 0
    sql.0	2018-08-07 16:04:06.616	debug	Type set in Def for javascript.0.IntelNUC.Temp-Core0: undefined
    sql.0	2018-08-07 16:04:06.616	debug	Type (from Obj) for javascript.0.IntelNUC.Temp-Core0: undefined
    sql.0	2018-08-07 16:04:06.616	debug	mixed / undefined / {"name":"Systemtemperatur Core-0","unit":"°C","role":"javascript","type":"mixed","custom":{"sql.0":{"enabled":true,"changesOnly":true,"debounce":"5000","maxLength":10,"retention":"
    sql.0	2018-08-07 16:04:06.614	debug	Type set in Def for javascript.0.IntelNUC.Temp-Core0: false
    sql.0	2018-08-07 16:04:06.614	debug	Datatype javascript.0.IntelNUC.Temp-Core0: Currently: number, StorageType: false
    sql.0	2018-08-07 16:04:06.535	debug	INSERT INTO `iobroker`.ts_number (id, ts, val, ack, _from, q) VALUES(303, 1533650641391, 0.22, 0, 7, 0);
    sql.0	2018-08-07 16:04:06.535	info	changed history configuration to pin detected datatype for javascript.0.IntelNUC.VM-ioBroker.load15Min
    sql.0	2018-08-07 16:04:06.528	error	Cannot insert INSERT INTO `iobroker`.ts_number (id, ts, val, ack, _from, q) VALUES(303, 1533650641389, 0.22, 0, 7, 0);: Error: ER_DUP_ENTRY: Duplicate entry '303-1533650641389' for key 'PRIMARY'
    sql.0	2018-08-07 16:04:06.525	error	Cannot delete DELETE FROM `iobroker`.undefined WHERE id=303 AND ts < 1530972240511;: Error: ER_NO_SUCH_TABLE: Table 'iobroker.undefined' doesn't exist
    sql.0	2018-08-07 16:04:06.522	debug	INSERT INTO `iobroker`.ts_number (id, ts, val, ack, _from, q) VALUES(303, 1533650641390, 0.22, 0, 7, 0);
    sql.0	2018-08-07 16:04:06.522	debug	Type (from DB-Type) for javascript.0.IntelNUC.VM-ioBroker.load15Min: 0
    sql.0	2018-08-07 16:04:06.522	debug	Type set in Def for javascript.0.IntelNUC.VM-ioBroker.load15Min: undefined
    sql.0	2018-08-07 16:04:06.522	debug	Type (from Obj) for javascript.0.IntelNUC.VM-ioBroker.load15Min: undefined
    sql.0	2018-08-07 16:04:06.522	debug	mixed / undefined / {"name":"System-load 15-Min","role":"javascript","type":"mixed","custom":{"sql.0":{"enabled":true,"changesOnly":true,"debounce":"5000","maxLength":10,"retention":"2678400","changes
    sql.0	2018-08-07 16:04:06.522	debug	INSERT INTO `iobroker`.ts_number (id, ts, val, ack, _from, q) VALUES(303, 1533650641389, 0.22, 0, 7, 0);
    sql.0	2018-08-07 16:04:06.522	debug	Type (from State) for javascript.0.IntelNUC.VM-ioBroker.load15Min: 0
    sql.0	2018-08-07 16:04:06.522	debug	UPDATE `iobroker`.datapoints SET type = 0 WHERE id = 303;
    sql.0	2018-08-07 16:04:06.521	debug	Type (from State) for javascript.0.IntelNUC.VM-ioBroker.load15Min: 0
    sql.0	2018-08-07 16:04:06.521	error	Cannot insert INSERT INTO `iobroker`.ts_number (id, ts, val, ack, _from, q) VALUES(303, 1533650641388, 0.22, 0, 7, 0);: Error: ER_DUP_ENTRY: Duplicate entry '303-1533650641388' for key 'PRIMARY'
    sql.0	2018-08-07 16:04:06.521	debug	DELETE FROM `iobroker`.undefined WHERE id=303 AND ts < 1530972240511;
    sql.0	2018-08-07 16:04:06.501	error	Cannot insert INSERT INTO `iobroker`.ts_string (id, ts, val, ack, _from, q) VALUES(300, 1533650641340, '2,8', 0, 7, 0);: Error: ER_DUP_ENTRY: Duplicate entry '300-1533650641340' for key 'PRIMARY'
    sql.0	2018-08-07 16:04:06.501	error	Cannot insert INSERT INTO `iobroker`.ts_number (id, ts, val, ack, _from, q) VALUES(302, 1533650641374, 0.17, 0, 7, 0);: Error: ER_DUP_ENTRY: Duplicate entry '302-1533650641374' for key 'PRIMARY'
    sql.0	2018-08-07 16:04:06.501	debug	Type set in Def for javascript.0.IntelNUC.VM-ioBroker.load15Min: undefined
    sql.0	2018-08-07 16:04:06.501	debug	Type (from Obj) for javascript.0.IntelNUC.VM-ioBroker.load15Min: undefined
    sql.0	2018-08-07 16:04:06.501	debug	mixed / undefined / {"name":"System-load 15-Min","role":"javascript","type":"mixed","custom":{"sql.0":{"enabled":true,"changesOnly":true,"debounce":"5000","maxLength":10,"retention":"2678400","changes
    sql.0	2018-08-07 16:04:06.501	error	Cannot insert INSERT INTO `iobroker`.ts_number (id, ts, val, ack, _from, q) VALUES(302, 1533650641373, 0.17, 0, 7, 0);: Error: ER_DUP_ENTRY: Duplicate entry '302-1533650641373' for key 'PRIMARY'
    sql.0	2018-08-07 16:04:06.501	debug	INSERT INTO `iobroker`.ts_number (id, ts, val, ack, _from, q) VALUES(303, 1533650641388, 0.22, 0, 7, 0);
    sql.0	2018-08-07 16:04:06.501	debug	INSERT INTO `iobroker`.ts_number (id, ts, val, ack, _from, q) VALUES(303, 1533650641389, 0.22, 0, 7, 0);
    sql.0	2018-08-07 16:04:06.501	debug	INSERT INTO `iobroker`.ts_number (id, ts, val, ack, _from, q) VALUES(302, 1533650641375, 0.17, 0, 7, 0);
    sql.0	2018-08-07 16:04:06.501	info	changed history configuration to pin detected datatype for javascript.0.IntelNUC.VM-ioBroker.load5Min
    sql.0	2018-08-07 16:04:06.501	error	Cannot insert INSERT INTO `iobroker`.ts_number (id, ts, val, ack, _from, q) VALUES(301, 1533650641355, 0.12, 0, 7, 0);: Error: ER_DUP_ENTRY: Duplicate entry '301-1533650641355' for key 'PRIMARY'
    sql.0	2018-08-07 16:04:06.501	debug	DELETE FROM `iobroker`.ts_number WHERE id=302 AND ts < 1530972240481;
    sql.0	2018-08-07 16:04:06.500	debug	INSERT INTO `iobroker`.ts_number (id, ts, val, ack, _from, q) VALUES(301, 1533650641356, 0.12, 0, 7, 0);
    sql.0	2018-08-07 16:04:06.500	info	changed history configuration to pin detected datatype for javascript.0.IntelNUC.VM-ioBroker.load1Min
    sql.0	2018-08-07 16:04:06.500	debug	Type (from State) for javascript.0.IntelNUC.VM-ioBroker.load15Min: 0
    sql.0	2018-08-07 16:04:06.500	error	Cannot insert INSERT INTO `iobroker`.ts_number (id, ts, val, ack, _from, q) VALUES(301, 1533650641354, 0.12, 0, 7, 0);: Error: ER_DUP_ENTRY: Duplicate entry '301-1533650641354' for key 'PRIMARY'
    sql.0	2018-08-07 16:04:06.447	debug	INSERT INTO `iobroker`.ts_string (id, ts, val, ack, _from, q) VALUES(300, 1533650641340, '2,8', 0, 7, 0);
    sql.0	2018-08-07 16:04:06.447	info	changed history configuration to pin detected datatype for javascript.0.IntelNUC.VM-ioBroker.StorageUsed
    sql.0	2018-08-07 16:04:06.447	debug	Type set in Def for javascript.0.IntelNUC.VM-ioBroker.load15Min: undefined
    sql.0	2018-08-07 16:04:06.447	debug	Type (from Obj) for javascript.0.IntelNUC.VM-ioBroker.load15Min: undefined
    sql.0	2018-08-07 16:04:06.447	debug	mixed / undefined / {"name":"System-load 15-Min","role":"javascript","type":"mixed","custom":{"sql.0":{"enabled":true,"changesOnly":true,"debounce":"5000","maxLength":10,"retention":"2678400","changes
    sql.0	2018-08-07 16:04:06.447	debug	INSERT INTO `iobroker`.ts_number (id, ts, val, ack, _from, q) VALUES(302, 1533650641374, 0.17, 0, 7, 0);
    sql.0	2018-08-07 16:04:06.447	debug	Type (from DB-Type) for javascript.0.IntelNUC.VM-ioBroker.load5Min: 0
    sql.0	2018-08-07 16:04:06.447	debug	Type set in Def for javascript.0.IntelNUC.VM-ioBroker.load5Min: undefined
    sql.0	2018-08-07 16:04:06.447	debug	Type (from Obj) for javascript.0.IntelNUC.VM-ioBroker.load5Min: undefined
    sql.0	2018-08-07 16:04:06.447	debug	mixed / undefined / {"name":"System-load 5-Min","role":"javascript","type":"mixed","custom":{"sql.0":{"enabled":true,"changesOnly":true,"debounce":"5000","maxLength":10,"retention":"2678400","changesR
    sql.0	2018-08-07 16:04:06.447	error	Cannot insert INSERT INTO `iobroker`.ts_string (id, ts, val, ack, _from, q) VALUES(300, 1533650641339, '2,8', 0, 7, 0);: Error: ER_DUP_ENTRY: Duplicate entry '300-1533650641339' for key 'PRIMARY'
    sql.0	2018-08-07 16:04:06.447	error	Cannot insert INSERT INTO `iobroker`.ts_number (id, ts, val, ack, _from, q) VALUES(301, 1533650641355, 0.12, 0, 7, 0);: Error: ER_DUP_ENTRY: Duplicate entry '301-1533650641355' for key 'PRIMARY'
    sql.0	2018-08-07 16:04:06.447	error	Cannot insert INSERT INTO `iobroker`.ts_number (id, ts, val, ack, _from, q) VALUES(301, 1533650641354, 0.12, 0, 7, 0);: Error: ER_DUP_ENTRY: Duplicate entry '301-1533650641354' for key 'PRIMARY'
    sql.0	2018-08-07 16:04:06.447	debug	DELETE FROM `iobroker`.ts_number WHERE id=301 AND ts < 1530972240424;
    sql.0	2018-08-07 16:04:06.447	debug	Type (from State) for javascript.0.IntelNUC.VM-ioBroker.load15Min: 0
    sql.0	2018-08-07 16:04:06.447	debug	INSERT INTO `iobroker`.ts_number (id, ts, val, ack, _from, q) VALUES(302, 1533650641373, 0.17, 0, 7, 0);
    sql.0	2018-08-07 16:04:06.447	debug	Type (from State) for javascript.0.IntelNUC.VM-ioBroker.load5Min: 0
    sql.0	2018-08-07 16:04:06.447	debug	SELECT id, type, name FROM `iobroker`.datapoints WHERE name='javascript.0.IntelNUC.VM-ioBroker.load15Min';
    sql.0	2018-08-07 16:04:06.447	debug	UPDATE `iobroker`.datapoints SET type = 0 WHERE id = 302;
    sql.0	2018-08-07 16:04:06.446	debug	Type (from State) for javascript.0.IntelNUC.VM-ioBroker.load5Min: 0
    sql.0	2018-08-07 16:04:06.446	debug	INSERT INTO `iobroker`.ts_number (id, ts, val, ack, _from, q) VALUES(301, 1533650641355, 0.12, 0, 7, 0);
    sql.0	2018-08-07 16:04:06.446	debug	Type (from State) for javascript.0.IntelNUC.VM-ioBroker.load1Min: 0
    sql.0	2018-08-07 16:04:06.446	error	Cannot insert INSERT INTO `iobroker`.ts_number (id, ts, val, ack, _from, q) VALUES(299, 1533650641318, 27, 0, 7, 0);: Error: ER_DUP_ENTRY: Duplicate entry '299-1533650641318' for key 'PRIMARY'
    sql.0	2018-08-07 16:04:06.446	debug	INSERT INTO `iobroker`.ts_number (id, ts, val, ack, _from, q) VALUES(302, 1533650641374, 0.17, 0, 7, 0);
    sql.0	2018-08-07 16:04:06.446	debug	INSERT INTO `iobroker`.ts_number (id, ts, val, ack, _from, q) VALUES(302, 1533650641373, 0.17, 0, 7, 0);
    sql.0	2018-08-07 16:04:06.446	debug	Type set in Def for javascript.0.IntelNUC.VM-ioBroker.load15Min: undefined
    sql.0	2018-08-07 16:04:06.446	debug	Type (from Obj) for javascript.0.IntelNUC.VM-ioBroker.load15Min: undefined
    sql.0	2018-08-07 16:04:06.446	debug	mixed / undefined / {"name":"System-load 15-Min","role":"javascript","type":"mixed","custom":{"sql.0":{"enabled":true,"changesOnly":true,"debounce":"5000","maxLength":10,"retention":"2678400","changes
    sql.0	2018-08-07 16:04:06.446	debug	Type set in Def for javascript.0.IntelNUC.VM-ioBroker.load5Min: undefined
    sql.0	2018-08-07 16:04:06.446	debug	Type (from Obj) for javascript.0.IntelNUC.VM-ioBroker.load5Min: undefined
    sql.0	2018-08-07 16:04:06.446	debug	mixed / undefined / {"name":"System-load 5-Min","role":"javascript","type":"mixed","custom":{"sql.0":{"enabled":true,"changesOnly":true,"debounce":"5000","maxLength":10,"retention":"2678400","changesR
    sql.0	2018-08-07 16:04:06.446	debug	INSERT INTO `iobroker`.ts_number (id, ts, val, ack, _from, q) VALUES(301, 1533650641354, 0.12, 0, 7, 0);
    sql.0	2018-08-07 16:04:06.446	debug	Type (from DB-Type) for javascript.0.IntelNUC.VM-ioBroker.load1Min: 0
    sql.0	2018-08-07 16:04:06.446	debug	Type set in Def for javascript.0.IntelNUC.VM-ioBroker.load1Min: undefined
    sql.0	2018-08-07 16:04:06.446	debug	Type (from Obj) for javascript.0.IntelNUC.VM-ioBroker.load1Min: undefined
    sql.0	2018-08-07 16:04:06.446	debug	mixed / undefined / {"name":"System-load 1-Min","role":"javascript","type":"mixed","custom":{"sql.0":{"enabled":true,"changesOnly":true,"debounce":"5000","maxLength":10,"retention":"2678400","changesR
    sql.0	2018-08-07 16:04:06.446	error	Cannot insert INSERT INTO `iobroker`.ts_string (id, ts, val, ack, _from, q) VALUES(300, 1533650641340, '2,8', 0, 7, 0);: Error: ER_DUP_ENTRY: Duplicate entry '300-1533650641340' for key 'PRIMARY'
    sql.0	2018-08-07 16:04:06.446	error	Cannot insert INSERT INTO `iobroker`.ts_string (id, ts, val, ack, _from, q) VALUES(300, 1533650641339, '2,8', 0, 7, 0);: Error: ER_DUP_ENTRY: Duplicate entry '300-1533650641339' for key 'PRIMARY'
    sql.0	2018-08-07 16:04:06.446	debug	DELETE FROM `iobroker`.ts_string WHERE id=300 AND ts < 1530972240406;
    sql.0	2018-08-07 16:04:06.446	debug	UPDATE `iobroker`.datapoints SET type = 0 WHERE id = 301;
    sql.0	2018-08-07 16:04:06.446	debug	Type set in Def for javascript.0.IntelNUC.VM-ioBroker.load15Min: false
    sql.0	2018-08-07 16:04:06.446	debug	Datatype javascript.0.IntelNUC.VM-ioBroker.load15Min: Currently: number, StorageType: false
    sql.0	2018-08-07 16:04:06.445	debug	Type (from Obj) for javascript.0.IntelNUC.VM-ioBroker.load1Min: undefined
    sql.0	2018-08-07 16:04:06.445	debug	mixed / undefined / {"name":"System-load 1-Min","role":"javascript","type":"mixed","custom":{"sql.0":{"enabled":true,"changesOnly":true,"debounce":"5000","maxLength":10,"retention":"2678400","changesR
    sql.0	2018-08-07 16:04:06.445	debug	INSERT INTO `iobroker`.ts_string (id, ts, val, ack, _from, q) VALUES(300, 1533650641339, '2,8', 0, 7, 0);
    sql.0	2018-08-07 16:04:06.445	debug	Type (from DB-Type) for javascript.0.IntelNUC.VM-ioBroker.StorageUsed: 1
    sql.0	2018-08-07 16:04:06.445	debug	Type set in Def for javascript.0.IntelNUC.VM-ioBroker.StorageUsed: undefined
    sql.0	2018-08-07 16:04:06.445	debug	Type (from Obj) for javascript.0.IntelNUC.VM-ioBroker.StorageUsed: undefined
    sql.0	2018-08-07 16:04:06.445	debug	mixed / undefined / {"name":"HDD-Speicher Verbraucht","unit":"GByte","role":"javascript","type":"mixed","custom":{"sql.0":{"enabled":true,"changesOnly":true,"debounce":"5000","maxLength":10,"retention
    sql.0	2018-08-07 16:04:06.445	debug	INSERT INTO `iobroker`.ts_number (id, ts, val, ack, _from, q) VALUES(301, 1533650641355, 0.12, 0, 7, 0);
    sql.0	2018-08-07 16:04:06.445	debug	INSERT INTO `iobroker`.ts_number (id, ts, val, ack, _from, q) VALUES(301, 1533650641354, 0.12, 0, 7, 0);
    sql.0	2018-08-07 16:04:06.445	debug	INSERT INTO `iobroker`.ts_number (id, ts, val, ack, _from, q) VALUES(299, 1533650641318, 27, 0, 7, 0);
    sql.0	2018-08-07 16:04:06.445	info	changed history configuration to pin detected datatype for javascript.0.IntelNUC.VM-ioBroker.StorageFree
    sql.0	2018-08-07 16:04:06.445	error	Cannot insert INSERT INTO `iobroker`.ts_number (id, ts, val, ack, _from, q) VALUES(298, 1533650641285, 0.962891, 0, 7, 0);: Error: ER_DUP_ENTRY: Duplicate entry '298-1533650641285' for key 'PRIMARY'
    sql.0	2018-08-07 16:04:06.445	debug	SELECT id, type, name FROM `iobroker`.datapoints WHERE name='javascript.0.IntelNUC.VM-ioBroker.load5Min';
    sql.0	2018-08-07 16:04:06.445	debug	Type (from State) for javascript.0.IntelNUC.VM-ioBroker.load5Min: 0
    sql.0	2018-08-07 16:04:06.445	debug	Type (from State) for javascript.0.IntelNUC.VM-ioBroker.load1Min: 0
    sql.0	2018-08-07 16:04:06.445	debug	UPDATE `iobroker`.datapoints SET type = 1 WHERE id = 300;
    sql.0	2018-08-07 16:04:06.445	debug	Type (from State) for javascript.0.IntelNUC.VM-ioBroker.StorageUsed: 1
    sql.0	2018-08-07 16:04:06.445	error	Cannot insert INSERT INTO `iobroker`.ts_number (id, ts, val, ack, _from, q) VALUES(299, 1533650641317, 27, 0, 7, 0);: Error: ER_DUP_ENTRY: Duplicate entry '299-1533650641317' for key 'PRIMARY'
    sql.0	2018-08-07 16:04:06.445	debug	Type set in Def for javascript.0.IntelNUC.VM-ioBroker.load5Min: undefined
    sql.0	2018-08-07 16:04:06.445	debug	Type (from Obj) for javascript.0.IntelNUC.VM-ioBroker.load5Min: undefined
    sql.0	2018-08-07 16:04:06.445	debug	mixed / undefined / {"name":"System-load 5-Min","role":"javascript","type":"mixed","custom":{"sql.0":{"enabled":true,"changesOnly":true,"debounce":"5000","maxLength":10,"retention":"2678400","changesR
    sql.0	2018-08-07 16:04:06.445	debug	Type set in Def for javascript.0.IntelNUC.VM-ioBroker.load1Min: undefined
    sql.0	2018-08-07 16:04:06.445	debug	INSERT INTO `iobroker`.ts_string (id, ts, val, ack, _from, q) VALUES(300, 1533650641340, '2,8', 0, 7, 0);
    Intel-NUC mit ProxMox: ioBroker,SQL, logging Strom- Gas- u. Wasserzähler;10Zoll Tab im Flur für VIS; weiteres: Homematic CCU2, Homeduino, Kameras, selbstgebaute Wetterstation;
    • P Offline
      PrinzEisenherz1
      Konntest du was erkennen?
      Gruß Johnny
      • apollon77A Offline
        Auszug zu kurz. Am besten wirklich starten mit dem Start vom Adapter und dann bis der ganze initiale Kram durch ist.
        Gesendet vom Handy …
        • P Offline
          PrinzEisenherz1
          So Apollon, hier der log ab dem Moment wo ich den sql Adapter auf debug gestellt habe, bis zu dem Zeitpunkt wo sich die sache mit den errors beruhigt hat.
          1058_iobroker.2018-08-08.log
          Ich hoffe Du finest was raus!?!?
          Johnny
          • P Offline
            PrinzEisenherz1
            Apollon hattest Du schon mal n Minütchen wo Du den log ansehen konntest?
            Hast Du was entdeckt?
            Johnny
              Nope noch keine Zeit gehabt
              • StabilostickS Offline
                Stabilostick
                Die Datenbank irrt hier nicht:
                Zuerst:
                INSERT INTO ts_number .... VALUES(107, 1533758018663, 22.98, 0, 7, 0);
                INSERT INTO ts_number .... VALUES(107, 1533758018664, 22.98, 0, 7, 0);
                INSERT INTO ts_number .... VALUES(168, 1533758018668, 22.98, 0, 5, 0);
                INSERT INTO ts_number .... VALUES(168, 1533758018669, 22.98, 0, 5, 0);
                dann kommt
                changed history configuration to pin detected datatype ...
                ````für die verschiedenen Datenpunkte und dann gleich darauf:
                DELETE FROM ts_number WHERE id=107 AND ts < 1502221980756;
                INSERT INTO ts_number .... VALUES(107, 1533758018663, 22.98, 0, 7, 0);: Error: ER_DUP_ENTRY: Duplicate entry '107-1533758018663' for key 'PRIMARY'
                INSERT INTO ts_number .... VALUES(107, 1533758018664, 22.98, 0, 7, 0);: Error: ER_DUP_ENTRY: Duplicate entry '107-1533758018664' for key 'PRIMARY'
                INSERT INTO ts_number .... VALUES(168, 1533758018669, 22.98, 0, 5, 0);: Error: ER_DUP_ENTRY: Duplicate entry '168-1533758018669' for key 'PRIMARY'
                DELETE FROM ts_number WHERE id=168 AND ts < 1502221980762;
                INSERT INTO ts_number .... VALUES(168, 1533758018668, 22.98, 0, 5, 0);: Error: ER_DUP_ENTRY: Duplicate entry '168-1533758018668' for key 'PRIMARY'
                Hmm, das Delete ist um ein Jahr nach vorne verschoben … 08.08.2017 21:53:01
                Kannst Du zur Vollständigkeit das JavaScript posten, das die Werte setzt?
                  Das ist ein Timing-Issue in der Initialisierung. Soweit bin ich schon …
                  Das Problem ist das Dinge noch nicht sauber initialisiert sind (sql calls sind halt asynchron) aber dann schnell Werte reinkommen. Und dann passieren komische Dinge ...
                  Mal warten bitte
                    So, bitte mal die 1.9.3 vom Github installieren, instanz neustarten (mit Debug an wieder) und mir in jedem Fall das Log schicken/posten.
                    jetzt besser?
                    • P Offline
                      PrinzEisenherz1
                      Hab das update durchgeführt und den Adapter auf debugging gestellt. bis jetzt keine Verbesserung. Was mir aber aufgefallen ist, auf den ersten blick sind das alles Fehlermeldungen von Statusänderungen durch z.b. Arduinos die über simple api senden (http://<ip-adresse>:8082/set/javascript.0.xxxxxx)
                      hier mal das log-File
                      1058_iobroker.2018-08-10.log
                      Johnny</ip-adresse>
                        Stabilostick
                        javascript.0.IntelNUC.*
                        • P Offline
                          PrinzEisenherz1
                          Das ist kein Javascript sondern ein bash-script auf dem Proxmox
                          Der vollständigkeithalber
                          #!/bin/sh
                          ### Scriptname:                sysinfo.sh
                          ### Kurzbeschreibung:      Ermitteln von Systemwerten InterlNUC root-System und überträgt an ioBroker
                          ### Ersteller:                    Prinzeisenherz1 (Schneider Johnny) am 24072018
                          ### Lokale Variablen anlegen
                          ioBrokerIP="192.168.178.2:8082"
                          echo "ip "$ioBrokerIP
                          URL_set_StorageTotal="http://"$ioBrokerIP"/set/javascript.0.IntelNUC.VM-ioBroker.StorageTotal?value="
                          URL_set_StorageFree="http://"$ioBrokerIP"/set/javascript.0.IntelNUC.VM-ioBroker.StorageFree?value="
                          URL_set_StorageUsed="http://"$ioBrokerIP"/set/javascript.0.IntelNUC.VM-ioBroker.StorageUsed?value="
                          URL_set_MemTotal="http://"$ioBrokerIP"/set/javascript.0.IntelNUC.VM-ioBroker.MemTotal?value="
                          URL_set_MemFree="http://"$ioBrokerIP"/set/javascript.0.IntelNUC.VM-ioBroker.MemFree?value="
                          URL_set_MemUsed="http://"$ioBrokerIP"/set/javascript.0.IntelNUC.VM-ioBroker.MemUsed?value="
                          URL_set_load1Min="http://"$ioBrokerIP"/set/javascript.0.IntelNUC.VM-ioBroker.load1Min?value="
                          URL_set_load5Min="http://"$ioBrokerIP"/set/javascript.0.IntelNUC.VM-ioBroker.load5Min?value="
                          URL_set_load15Min="http://"$ioBrokerIP"/set/javascript.0.IntelNUC.VM-ioBroker.load15Min?value="
                          URL_set_Uptime_day="http://"$ioBrokerIP"/set/javascript.0.IntelNUC.VM-ioBroker.UptimeDay?value="
                          URL_set_Uptime_hour="http://"$ioBrokerIP"/set/javascript.0.IntelNUC.VM-ioBroker.UptimeHour?value="
                          ### Gesamtspeicherplatz Arbeitsspeicher in Gigabyte ermitteln und an die ioBroker übertragen
                          tmp2=$(free -m | awk '{print $2/1024}' | sed -n '2p' | sed 's/G//g')
                          ### Freier Speicherplatz Arbeitsspeicher in Gigabyte ermitteln und an die ioBroker übertragen
                          tmp3=$(free -m | awk '{print $4/1024}' | sed -n '2p' | sed 's/G//g')
                          ### Belegter Speicherplatz Arbeitsspeicher in Gigabyte ermitteln und an die ioBroker übertragen
                          tmp4=$(free -m | awk '{print $3/1024}' | sed -n '2p' | sed 's/G//g')
                          ### Gesamtspeicherplatz Datenträger in Gigabyte ermitteln und an die ioBroker übertragen
                          tmp10=$(df -H | awk '{print $2}' | sed -n '4p' | sed 's/G//g')
                          ### Freier Speicherplatz Datenträger in Gigabyte ermitteln und an die ioBroker übertragen
                          tmp11=$(df -H | awk '{print $4}' | sed -n '4p' | sed 's/G//g')
                          ### Belegter Speicherplatz Datenträger in Gigabyte ermitteln und an die ioBroker übertragen
                          tmp12=$(df -H | awk '{print $3}' | sed -n '4p' | sed 's/G//g')
                          ### Systemload 1-Min ermitteln und an die ioBroker übertragen
                          tmp5=$(cat /proc/loadavg | awk '{print $1}')
                          ### Systemload 5-Min ermitteln und an die ioBroker übertragen
                          tmp6=$(cat /proc/loadavg | awk '{print $2}')
                          ### Systemload 15-Min ermitteln und an die ioBroker übertragen
                          tmp7=$(cat /proc/loadavg | awk '{print $3}')
                          ### UpTime in Tage und Stunden ermitteln und an ioBroker übertragen
                          tmp8=$(cat /proc/uptime | awk '{printf"%.0f\n", $1}')
                          days=$(($tmp8 / 86400 ))
                          hours=$((($tmp8 / 3600) - (days * 24)))
                          ####### Sende Gesamtspeicherplatz in Gigabyte an ioBroker
                          url_tmp2=$URL_set_MemTotal$tmp2
                          echo "$url_tmp2"
                          curl -s $url_tmp2 > /dev/null 2>&1
                          ####### Sende freien Speicherplatz in Gigabyte an ioBroker
                          url_tmp3=$URL_set_MemFree$tmp3
                          echo "$url_tmp3"
                          curl -s $url_tmp3 > /dev/null 2>&1
                          ####### Sende belegter Speicherplatz in Gigabyte an ioBroker
                          url_tmp4=$URL_set_MemUsed$tmp4
                          echo "$url_tmp4"
                          curl -s $url_tmp4 > /dev/null 2>&1
                          url_tmp10=$URL_set_StorageTotal$tmp10
                          echo "$url_tmp10"
                          curl -s $url_tmp10 > /dev/null 2>&1
                          url_tmp11=$URL_set_StorageFree$tmp11
                          echo "$url_tmp11"
                          curl -s $url_tmp11 > /dev/null 2>&1
                          url_tmp12=$URL_set_StorageUsed$tmp12
                          echo "$url_tmp12"
                          curl -s $url_tmp12 > /dev/null 2>&1
                          ####### Sende freien Speicherplatz in Prozent an ioBroker
                          url_tmp5=$URL_set_load1Min$tmp5
                          echo "$url_tmp5"
                          curl -s $url_tmp5 > /dev/null 2>&1
                          ####### Sende belegter Speicherplatz in Prozent an ioBroker
                          url_tmp6=$URL_set_load5Min$tmp6
                          echo "$url_tmp6"
                          curl -s $url_tmp6 > /dev/null 2>&1
                          url_tmp7=$URL_set_load15Min$tmp7
                          echo "$url_tmp7"
                          curl -s $url_tmp7 > /dev/null 2>&1
                          ####### Sende UpTime an ioBroker
                          url_days=$URL_set_Uptime_day$days
                          echo "$url_days"
                          curl -s $url_days > /dev/null 2>&1
                          url_hours=$URL_set_Uptime_hour$hours
                          echo "$url_hours"
                          curl -s $url_hours > /dev/null 2>&1
                          Johnny
                          • P Offline
                            PrinzEisenherz1
                            Hab mal auf Version 1.6.1 downgegraded und da gibt es die Probleme nicht!
                            Johnny
                              Hi, sorry für die Wartezeit … bitte versuch die Github Version nochmal. Habe noch was gefunden.
                              Zuerst wurden alle Typen und Indizes aus der DB eingelesen nur um das dann grad wieder zu überschreiben :-)
                              Wenn immer noch blöd dann bitte wieder log.
                              Das muss zu fixen sein :-)
                                @PrinzEisenherz1: kamst Du schon zum testen der Github Version?
                                • SegwayS Offline
                                  SegwayS Offline
                                  Segway
                                  @Apollon77:
                                  Habe ebenso das Problem mit Duplicate Entry mit meiner NAS SQL-DB.
                                  Bin auch an der Lösung interessiert. Habe mir mal ein Lesezeichen gesetzt.
                                  2018-08-20 06:25:28.243  - [31merror[39m: sql.0 Cannot insert INSERT INTO `iobroker`.ts_bool (id, ts, val, ack, _from, q) VALUES(1760, 1970000, false, 1, 4, 0);: Error: ER_DUP_ENTRY: Duplicate entry '1760-1970000' for key 'PRIMARY'
                                  oder möchtest du das ich das teste ? habe aber kein Testsystem, kann ich nur auf meinem Prod. System machen.
                                  Gruß Dirk
                                  • SegwayS Offline
                                    SegwayS Offline
                                    Segway
                                    Welchen verwharungsort muss ich einstellen um die version 1.9.3 zu bekommen ?
                                    Gruß Dirk
                                    • P Offline
                                      PrinzEisenherz1
                                      die 1.9.3 musst Du über git installieren.
                                      Hatte aber bei mir auch nicht geholfen bin dann auf ne 1.6er Version zurück und da hab ich keine Probleme.
                                      EDIT:
                                      Hab gerade erst gesehen das Apollon nochmal was geschrieben hat zu der 1.9.3 und da nochmal was geändert hat.
                                      Die Version hab ich noch nicht getestet. Werde ich nachholen.
                                      Johnny
                                      • SegwayS Offline
                                        SegwayS Offline
                                        Segway
                                        Edit: siehe oben
                                        Gruß Dirk
                                        • P Offline
                                          PrinzEisenherz1
                                          @Segway
                                          Hab meine Aussage editiert.
                                          Hab von Apollon die letzten Nachrichten übersehen
