  4. Sonnenschutz funzt nicht, warum?(Blockly)
    5.8k
27 Beiträge 5 Kommentatoren 2.3k Aufrufe
  • totocotonioT Offline
    totocotonio
    ich habe folgendes Blockly nachgebaut.
    Das obere funktioniert nicht. Das unter wo der Rolladen hoch gehen soll funzt.
    Welchen entscheidenden Fehler habe ich denn da drin.
     <block xmlns="http://www.w3.org/1999/xhtml" type="astro" id="5-Anuk{JD%/^)fse!e3X" x="-412" y="-187"><field name="TYPE">solarNoon</field>
      <field name="OFFSET">-120</field>
      <statement name="STATEMENT"><block type="controls_if" id="75Gdo}lxL}4Ydc;?MvTN"><value name="IF0"><block type="logic_compare" id="juF@#zw9Utu88mp30`KM"><field name="OP">EQ</field>
              <value name="A"><block type="get_value" id="KZ}@Gq:1NYRrcj8NdlRo"><field name="ATTR">val</field>
                  <field name="OID">javascript.0.Rolladen_Automatic</field></block></value>
              <value name="B"><block type="logic_boolean" id=",@Z8K;`zh)}M^U^j6,xV"><field name="BOOL">TRUE</field></block></value></block></value>
          <statement name="DO0"><block type="controls_if" id="8u9H^efTZo95v%5)TO8`"><value name="IF0"><block type="logic_compare" id="Wr-Iyv[I*%i|Q6kZ7U0)"><field name="OP">GT</field>
                  <value name="A"><block type="get_value" id="jsuBQUC=0v`DPo{h:8Y("><field name="ATTR">val</field>
                      <field name="OID">yr.0.forecast.day0.temperature_max</field></block></value>
                  <value name="B"><block type="math_number" id="ipu0uC0.VXaC+KD3%?R("><field name="NUM">22</field></block></value></block></value>
              <statement name="DO0"><block type="control" id="u~X@=#WQH5m-?N_HHD3w"><mutation delay_input="false"></mutation>
                  <field name="OID">hm-rpc.0.OEQ0259579.1.LEVEL</field>
                  <value name="VALUE"><block type="math_number" id="3g?m]SK5fUAQgkuY=wF#"><field name="NUM">75</field></block></value>
                  <next><block type="control" id="HcSOHm5r9%gZm@F*JfLE"><mutation delay_input="false"></mutation>
                      <field name="OID">hm-rpc.0.OEQ0259191.1.LEVEL</field>
                      <value name="VALUE"><block type="math_number" id="aTz,:VRSPZV][4HsUgam"><field name="NUM">75</field></block></value></block></next></block></statement></block></statement></block></statement></block>
    Gruß Totocotonio
    Bin noch Anfänger in Sachen IO-Broker und lerne gerne dazu. :P
      Ist der wert vom Forecast eine Zahl?
      Gruß Rainer
        totocotonio
        ja eine Zahl (Type Number) mit Grad C
        Gruß Totocotonio
          RappiRN
          Dann war wohl die vorhergesagte Temperatur nicht über 22°C, oder?
          Enrico
            totocotonio
            doch wir hatten heute 24 ° C
            Habe ich da einen Fehler drin?
            Eigentlich doch nicht, zumindest fällt er mir nicht auf.
            Der boolaen Datenpunkt steht auch auf "true"
            Gruß Totocotonio
              Dann mach mal ein paar sinnvolle debug blöcke rein.
              • paul53P Offline
                @totocotonio:
                ja eine Zahl (Type Number) mit Grad C `
                Wenn der Datenpunkt vom Typ "Zahl" (number) ist, bedeutet es nicht, dass der Wert tatsächlich auch eine Zahl ist. Füge mal ein:
                debug output | Typ von | Wert vom Objekt ID Forecast of temperature for today
                  totocotonio
                  wo mache ich die denn am besten rein und vor allem welche.
                  Wie gesagt ich bin noch Anfänger.
                  Gruß Totocotonio
                    totocotonio
                    @paul53:
                    @totocotonio:
                    da bin ich überfordert wo kommt das hin.
                    Gruß Totocotonio
                    • paul53P Offline
                      @totocotonio:
                      wo kommt das hin. `
                      Separat (außerhalb der anderen Böcke), damit es gleich beim Skriptstart abgearbeitet wird.
                        totocotonio
                        so
                        Gruß Totocotonio
                        • paul53P Offline
                          Nein, so.
                            RappiRN
                            Habs grad mal ausprobiert, der Wert scheint aus dem yr-Adapter zu sein.
                            Da kommt "number" raus, also sollte es auch ne Zahl sein, oder? Oder gibt es die Möglichkeit, dass der Adapter die Zahl als Text in das Objekt schreibt?
                            Enrico
                              totocotonio
                              Wann wird das denn dann angezeigt.
                              Wenn das script startet?
                              Gruß Totocotonio
                                RappiRN
                                Genau, direkt nach dem Speichern wird das Script ja neugestartet (wenn es denn schon läuft) und dann kommt der Eintrag.
                                Enrico
                                  totocotonio
                                  @RappiRN:
                                  Enrico `
                                  Ja ist der yr.
                                  Ich habe da keinen Plan.
                                  Gruß Totocotonio
                                    totocotonio
                                    @RappiRN:
                                    Enrico `
                                    mehr kommt nicht? komisch
                                    Gruß Totocotonio
                                    • paul53P Offline
                                      Stelle mal den Debug output von debug auf info.
                                        totocotonio
                                        @paul53:
                                        Stelle mal den Debug output von debug auf info. `
                                        ok, da kommt jetzt number raus, also müsste es doch funzen
                                        Gruß Totocotonio
                                          War der wert denn heute morgen um 11:00 bereits über 22°C?
