  4. Server (RPI) Temperatur Alarm Funktion
    5.4k
51 Beiträge 7 Kommentatoren 11.1k Aufrufe
  • V Offline
    V Offline
    versteckt
    #41
    Hallo, hey cool zumindest hast du schon Inhalt.
    Den Fehler schaue ich mir nachher an, bin grad nicht vor dem Rechner.
    Gesendet von meinem iPhone mit Tapatalk
    Raspi 1, Raspi 2, iobroker, Mac Mini: alles mit aktueller ioBroker Version
    homegear für Homematic und MAX!
    occ, zWave, rpi, hmm und homekit Entwickler
    • V Offline
      V Offline
      versteckt
      #42
      Kannst du mal den Inhalt des Objekts "system.adapter.rpi.0" posten?
      Und zwar von dem Tab "raw (experts only)".
        stephan61
        #43
        Hallo hier der Inhalt
        [code{
        "common": {
        "name": "rpi",
        "title": "RPI-Monitor",
        "version": "0.0.2",
        "mode": "daemon",
        "platform": "javascript/Node.js",
        "loglevel": "info",
        "main": "main.js",
        "license": "MIT",
        "readme": "https://github.com/husky-koglhof/ioBrok … /README.md",
        "icon": "rpi-monitor.png",
        "type": "hardware",
        "extIcon": "https://raw.githubusercontent.com/husky ... onitor.png",
        "installedVersion": "0.0.2",
        "host": "raspberrypi",
        "schedule": "",
        "singletonHost": true,
        "enabled": true,
        "desc": {
        "en": "RPI-Monitor for ioBroker Installations",
        "de": "RPI-Monitor für ioBroker",
        "ru": "RPI-Монитор для ioBroker"
        "os": [
        "linux",
        "darwin"
        "keywords": [
        "ioBroker",
        "monitoring",
        "raspberry",
        "orangepi",
        "odroid",
        "bananapi"
        "authors": [
        "Christian Baumgartner",
        "husky-koglhof husky.koglhof@icloud.com"
        "native": {
        "interval": 60000,
        "c_cpu": true,
        "c_raspberry": true,
        "c_memory": true,
        "c_network": true,
        "c_sdcard": true,
        "c_swap": true,
        "c_temperature": true,
        "c_uptime": true,
        "c_wlan": true,
        "cpu": {
        "cpu_frequency": {
        "command": "cat /sys/devices/system/cpu/cpu0/cpufreq/cpuinfo_cur_freq",
        "regexp": "(.*)",
        "post": "$1/1000"
        "load1,load5,load15": {
        "command": "cat /proc/loadavg",
        "regexp": "^(\S+)\s(\S+)\s(\S+)",
        "post": ""
        "scaling_governor": {
        "command": "cat /sys/devices/system/cpu/cpu0/cpufreq/scaling_governor",
        "regexp": "(.*)",
        "post": ""
        "raspberry": {
        "cpu_voltage": {
        "command": "vcgencmd measure_volts core",
        "regexp": "(\d+.\d+)V",
        "post": ""
        "mem_arm": {
        "command": "vcgencmd get_mem arm",
        "regexp": "(\d+)",
        "post": ""
        "mem_gpu": {
        "command": "vcgencmd get_mem gpu",
        "regexp": "(\d+)",
        "post": ""
        "memory": {
        "memory_total": {
        "command": "cat /proc/meminfo",
        "regexp": "MemTotal:\s+(\d+)",
        "post": "$1/1024"
        "memory_free": {
        "regexp": "MemFree:\s+(\d+)",
        "post": "$1/1024"
        "memory_available": {
        "command": "/usr/bin/free -mk",
        "regexp": "^-\/\+ buffers\/cache:\s+\d+\s+(\d+)",
        "post": "$1/1024",
        "multiline": true
        "network": {
        "net_received": {
        "command": "cat /sys/class/net/eth0/statistics/rx_bytes",
        "regexp": "(.*)",
        "post": "$1*-1"
        "net_send": {
        "command": "cat /sys/class/net/eth0/statistics/tx_bytes",
        "regexp": "(.*)",
        "post": ""
        "sdcard": {
        "sdcard_root_total": {
        "command": "df /",
        "regexp": "\S+\s+(\d+).*\/$",
        "post": "$1/1024",
        "multiline": true
        "sdcard_boot_total": {
        "command": "df /boot",
        "regexp": "\S+\s+(\d+).*\/boot$",
        "post": "$1/1024",
        "multiline": true
        "sdcard_root_used": {
        "command": "df /",
        "regexp": "\S+\s+\d+\s+(\d+).*\/$",
        "post": "$1/1024",
        "multiline": true
        "sdcard_boot_used": {
        "regexp": "\S+\s+\d+\s+(\d+).*\/boot$",
        "post": "$1/1024",
        "multiline": true
        "swap": {
        "swap_total": {
        "regexp": "SwapTotal:\s+(\d+)",
        "post": "$1/1024",
        "multiline": true
        "swap_used": {
        "regexp": "SwapFree:\s+(\d+)",
        "post": "rpi.swap_total - ($1/1024)",
        "multiline": true
        "temperature": {
        "soc_temp": {
        "command": "cat /sys/devices/virtual/thermal/thermal_zone0/temp",
        "regexp": "(.*)",
        "post": "$1/1000"
        "uptime": {
        "uptime": {
        "command": "cat /proc/uptime",
        "regexp": "(^\S+)",
        "post": ""
        "wlan": {
        "wifi_received": {
        "command": "cat /sys/class/net/wlan0/statistics/rx_bytes",
        "regexp": "(.*)",
        "post": "$1*-1"
        "wifi_send": {
        "command": "cat /sys/class/net/wlan0/statistics/tx_bytes",
        "regexp": "(.*)",
        "post": ""
        "acl": {
        "object": 1638,
        "owner": "system.user.admin",
        "_id": "system.adapter.rpi.0",
        "type": "instance"
        • fischi87F Offline
          fischi87F Offline
          fischi87
          #44
          Also bei mir läuft der Adapter tadellos. Nur stellen nach dem Komma sind etwas viele :-)
          Mfg
          • V Offline
            V Offline
            versteckt
            #45
            @stephan61: Hast du WLAN und Network aktiviert?
            Wenn ja, hast du Ethernet und WLAN aktiv an deinem Raspberry?
            Für mich sieht das stark danach aus und eines der beiden liefert aber keine Werte.
            @fischi87: Ja ich weiss, das muss ich noch anpassen, aber ansonsten funktioniert alles?
            • fischi87F Offline
              fischi87F Offline
              fischi87
              #46
              Jap, bei mir füllt es alles und hab keine Fehler im log.
              Mfg
              • V Offline
                V Offline
                versteckt
                #47
                Hab eine 0.0.3 Version hochgeladen.
                ` > 0.0.3 (2015-12-28)
                • (husky-koglhof) Fixed value calc.
                Set Value to 2 digits `
                LG Christian
                • V Offline
                  V Offline
                  versteckt
                  #48
                  Mein Adapter läuft jetzt schon länger und habe dadurch entdeckt, das die Temperatur durchgehend um die 55 Grad war.
                  Gehäuse aufgemacht, bin mittlerweile schon runter auf 46.
                  Hoch lebe mein neuer Adapter!
                  • fischi87F Offline
                    fischi87F Offline
                    fischi87
                    #49
                    wer es auch möglich mit einem aktualisier button bei dem Reiter adapter?
                    mag
                    • V Offline
                      V Offline
                      versteckt
                      #50
                      Geht erst wenn Bluefox ihn in die Liste der Adapter aufgenommen hat und ich in in npmjs drinnen hab. Mein Teil kommt morgen rein.
                      • fischi87F Offline
                        fischi87F Offline
                        fischi87
                        #51
                        Grüße Christian,
                        bekomme seid ich den occ adapter installiert habe diese Fehlermeldung?!
